Body info help for EU Passat!
Orchid70
Sweden
C?ID=354348
Hi
I need help to find the correct part numbers for front bumper grills...
The PR codes gave me nothing...
VIN: WVWZZZ3CZCE089877
Id like to know if the grill/trim parts are Highline or Comfort.
Its the mid paret and right fog trim thas missing.
8qfFItS
V1Ef4Mz
Orchid70
Sweden
C?ID=354348
Dont know what happened with the pics:
You could start here and then send them a email to verify. Without completely decoding your vin , I don't know the engine, body trim. I believe you have a 2012 , but not sure if its a s, sel, etc. You can email them and I'm sure they will confirm your fitment.
On the Left is all of your PR codes. Probably more than you ever wanted to know!
"mounting time" I think is production date ; you will then be able to tell which body style you have. I think you can find the production date on the sticker in the door jam. (my Audi is 08/08)
siLc
Tallinn, Estonia
C?ID=330192
Orchid70
Sweden
C?ID=354348
THANK YOU!!!! Both!
The Stealer has taken over 20000 euros out of her, the past 5 years!
They wanted 3100 euros to fix this.
The car has run near 500000 km and is not even worth that much!
I called VAG and they are the only ones that dont want to help with original part numbers. BMW, Mercedes, Volvo, Toyota, all other dealers - never have a problem.
So, both her and I am very thankfull.
About the PR codes - untill this day, I have never had any use of them. As in this case - there is no mentioning of body style.
stefdds - where did you get that neat list of the codes? I have been using this: http://prsearch.planetvag.com
Completely not VCDS related. Moving to General VW/Audi Repair.
siLc
Tallinn, Estonia
C?ID=330192
Well, since the bumper also looks like it's cracked, then a new original part + painting in Sweden obviously is pretty expensive.
HI, Its very similar to yours, it just "stacks" them as you enter, and search for, the PR code one by one. I think yours is much more efficient. The one I used has a engine code feature as well. Oddly enough, I could not get any result for your trans. code ( NAU) ? http://vag-codes.info/
