Halogen to LED conversion or upgrade...
jettoso1994
Puerto Rico
C?ID=411326
Hi to all.
My car is a 2010 VW Golf MK6 Base 4 doors hatchback with factory halogen headlamps; (H7 and H15) bulbs.
I install a new set of LASFIT Led bulbs that are plug and play for my car. No modification needed. My problem is:
1- Advice in the dashboard of light not working only in highs side.
2- Flickering only when the engine is running on all 4 lights, with engine of and key on, all works fine with the exception of the bulb warning in the instrument cluster.
Any help to solve the flickering and bulb warning?
It sounds like whoever advertised them as "plug and play with no modification needed" lied. ;)
Please post an Auto-Scan for context, so people can see exactly how your car is equipped and configured.
jettoso1994
Puerto Rico
C?ID=411326
OK. At this moment I don't have a recent scan of my car system. Tomorrow I will post the scan of my car for you. Thanks for your help.
jettoso1994
Puerto Rico
C?ID=411326
Hi to all.
Here are my car scan.
Friday,11,June,2021,14:27:23:16815
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WVWDA7AJ6AW087433 License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: WVWDA7AJ6AW087433 Mileage: 179540km-111560miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 AH HW: 07K 906 055 M
Component: 2,5l R5/4V G 9206
Revision: G6H03--- Serial number:
Coding: 0000075
Shop #: WSC 09220 444 999999
VCID: 74B1D8D222BF355B9BB-8020
Readiness: 1110 0101
Part No SW: 09G 927 750 HG HW: 09G 927 750 HG
Component: AQ 250 6F 1631
Revision: 00H76000 Serial number:
Coding: 0000840
VCID: 7DA7FDF611F57413E45-8028
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 114B400C492A0001880F02E7921C00413000
VCID: 7EA5FAFA10F36F0BFDF-802A
02841 - Hydraulic Unit
014 - Defective
Fault Status: 01101110
Fault Frequency: 9
Reset counter: 96
Mileage: 178049 km
Date: 2015.11.02
Time: 00:28:21
Count: 3
Count: 14
Count: 12288
Count: 103
Count: 43264
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 97
Mileage: 178081 km
Date: 2015.11.02
Time: 08:28:39
Count: 3
Count: 32768
Count: 12800
Count: 8193
Count: 47447
Part No SW: 3C8 907 336 N HW: 3C8 907 336 N
Component: Climatic H13 0203
Revision: 00006001
Coding: 0000000000
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: 38292CE272D7913B773-806C
Part No SW: 1K0 937 085 G HW: 1K0 937 085 G
Component: BCM PQ35 B++ 103 0576
Revision: 00103 AD
Coding: 6D180A1A90272AC480080081500004C441010086524D8D60648020200000
Shop #: WSC 04200 444 57642
VCID: 33331BCE6B317263421-8066
Component: Wischer 28070 21 0501
Coding: 009795
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 20
Reset counter: 100
Mileage: 179455 km
Date: 2015.11.02
Time: 10:39:15
Voltage: 11.85 V
Term 50 Off
01495 - Bulb for High-Beams; Left (M30)
Fault Frequency: 20
Reset counter: 100
Mileage: 179455 km
Date: 2015.11.02
Time: 10:42:07
Voltage: 11.85 V
Term 50 Off
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 019 0706
Serial number: 003C4D074CV0
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 392F29E649DD883388D-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0004MQ4R00
Component: S.Sens.Fahr.V U01 ----
Serial number: 3572MSME71315349ZZZQ
Component: S.Sens.Beif.V U01 ----
Serial number: 3582MSME6C0F5349ZZZ5
Serial number: 3512QSME0827340DZZZS
Serial number: 3522QSME3024345CZZZP
Serial number: 35527SME682D1400ZZZA
Serial number: 35627SME18581100ZZZ1
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Fault Frequency: 33
Reset counter: 140
Mileage: 175551 km
Date: 2021.06.11
Time: 11:13:32
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001034
VCID: 025D8E0A680B0BEB997-8056
Part No SW: 5K0 920 970 K HW: 5K0 920 970 K
Component: KOMBI H05 0206
Coding: 270F00
VCID: 363522DA78C3674B65F-8062
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 160709F1001035
Coding: ED807F07001602000002
VCID: 6695B29A6463D7CB15F-8032
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T5X1X04
Coding: 0000002
VCID: 7EA5FAFA1CF36F0BFDF-802A
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H05 0206
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2109
Coding: 0001204
VCID: 313F11C69D2D407330D-8064
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 70 2901
Revision: 00H17000
VCID: 2F3B17BE8B195683269-807A
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2123
Coding: 0001204
VCID: 343118D2623F755B5BB-8060
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 019 0022
Revision: 00019000 Serial number: VWZ4Z7I6402582
Coding: 0042401
VCID: 2019E482C6C7F9FBAF3-8074
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018705
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0001168
VCID: 353725D669456C536C5-8060
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520188121
Coding: 401100
VCID: 290FF9A6B9FD38B3F8D-807C
End----------(Elapsed Time: 01:05, VBatt start/end: 12.1V/12.1V)-----------
Revision: 00103 AD
Coding: 009795
Fault Frequency: 20
Reset counter: 100
Mileage: 179455 km
Date: 2015.11.02
Time: 10:39:15
Voltage: 11.85 V
Term 50 Off
Fault Frequency: 20
Reset counter: 100
Mileage: 179455 km
Date: 2015.11.02
Time: 10:42:07
11-2-2015 ? Looks like they/faults have been there for some time. ?
jettoso1994
Puerto Rico
C?ID=411326
Yes,
my car started to give that ABS failure with little time of use. There was a recall related to that but I called Volkswagen of America and they did not want to honor the recall here in Puerto Rico.
jettoso1994
Puerto Rico
C?ID=411326
Today I wrote to LASFIT technical help where I bought the LED lights. I explained to him about the flickering when the car is key on engine running and he advised me to put a Canbus decoder for the H7 lights. Using the electrical diagram of the headlamps, I will have to cut the cable that feeds the H7 on each side and insert the decoder there since these bulbs are not prepared to put a plug and play decoder on them.
I understand, but the dates are also from the 09 central electrics module ; the headlights.
Did you remind him of their above statement? Anyway, good luck with that mod. ; I don't think its a retrofit.
jettoso1994
Puerto Rico
C?ID=411326
I really don't know why this date is. The LEDs are installed last Wednesday.
And yes, I let them know everything about the situation
