- May 16, 2021
- 20
- 2
- Durban, South Africa
- C?ID=444269
How to clear crash data on a vw polo 8 2019 steering control module
If you can post that, you can post an Auto-Scan.Please can u assist so that I can post an Auto scan thank you
You can post right here, in this thread.when I get to the ross tech website it says only verified members can post
Have you read this?Please can u help me verify my account
Unless the scan itself is on your cellphone, which seems rather unlikely, I suggest you use a computer.How do I post the auto scan here from my cellphone
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: AAVZZZAWZJU070597 Mileage: 6580km-4088miles
Address 01: Engine (J623-CHZL) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 026 BD HW: 04C 907 309 AT
Component: R3 1.0l TFS H21 5150
Revision: WXH21---
Coding: 01110012230411080000
Shop #: WSC 31414 790 00200
ASAM Dataset: EV_ECM10TFS01104C906026BD 002003
ROD: EV_ECM10TFS01104C906026BD_002_VW27.rod
VCID: 6490577E4ED7BA774E1-8030
CAN Converter 01:
4527 - Coolant Fan Control Circuit 1
P0480 00 [039] - Electrical Malfunction
Mileage: 6580 km
Date: 2019.02.04
Time: 00:03:54
Engine speed: 966.00 /min
Normed load value: 13.7 %
Coolant temperature: 64 °C
Intake air temperature: 11 °C
Voltage terminal 30: 13.311 V
Outside air temperature: 9 °C
Absolute intake pressure: 34 kPa abs
Engine torque: 15.9 Nm
Fuel: tank fill level: 0.0 l
Oxygen sensor bank 1 sensor 1: specified value: 1.0000
23813 - Engine Oil Temp. Sensor (G8)
P0197 00 [039] - Signal too Low
Mileage: 6580 km
Date: 2019.02.04
Time: 00:03:56
Engine speed: 962.50 /min
Voltage terminal 30: 13.216 V
Oil fill level: 18.000 mm
Time since term 15 OFF StartStop: 65535 s
Engine oil temperature: 25.5 °C
Bit string for status of oil level-Bits 0-7: 0
U0428 00 [039] - -
Mileage: 6580 km
Date: 2019.02.04
Time: 00:03:54
Engine speed: 959.00 /min
Normed load value: 14.1 %
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 2Q0 614 517 AB HW: 2Q0 614 517 L
Component: ESC_base H13 0223
Serial number: 08500846180629
Coding: 09034B64154890ADD201A81F24E142A649124D26224A242444541254452442659248B26444522424222A482AA23196421D8C6942B8
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
ROD: EV_Brake1BOSCHESPMQBA0.rod
VCID: 6E843556901B0027285-803A
1272 - Tire Pressure Warning
C102D 00 [137] - -
Reset counter: 204
Mileage: 6580 km
Date: 2019.02.04
Time: 00:03:51
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
[Scl_LWI_Lenkradwinkel_Error]
Reset counter: 204
Mileage: 6580 km
Date: 2019.02.04
Time: 00:03:51
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 2G2 820 045 D HW: 2G2 820 045 D
Component: SG_AC_Manuell H50 0301
Coding: 012100000800000001000400020000000000000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001011
ROD: EV_ACManuePrehMQBA0_VW27.rod
VCID: 221C11661443F447FCD-8076
Part No SW: 2Q0 937 089 HW: 2Q0 937 089
Component: BCM A0 Std H98 0916
Serial number: 08001818800368
ASAM Dataset: EV_BCMA0 204001
ROD: EV_BCMA0_204.rod
VCID: 77AA1032EF4141EFFB3-8022
Drivers Door Control Module:
Subsystem 1 - Part No SW: 2Q2 959 881 C HW: 2Q2 959 881 C
Component: FHSG_DRV 001 0002
Serial number: 00000000000021516316
Coding: 1F0000
Subsystem 2 - Part No SW: 2Q2 959 882 HW: 2Q2 959 882
Component: FHSG_PSG 001 0001
Serial number: 00000000000021724966
Coding: 050000
Serial number: 000000000ZY1811703TF
Serial number: 00000000000099967326
8202 - Bulb for Left DRL
B121D 15 [009] - Open or Short to Plus
Reset counter: 204
Mileage: 6580 km
Date: 2019.02.04
Time: 00:03:54
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: not activated
Zusaetzliche Umgebungsdaten-OFF: not activated
Zusaetzliche Umgebungsdaten-Outside air temperature: 0
Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
Zusaetzliche Umgebungsdaten-Parking light: not activated
Zusaetzliche Umgebungsdaten-Parking light left: not activated
Zusaetzliche Umgebungsdaten-Parking light right: not activated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: 45
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 13.5 V
8458 - Bulb for Right DRL
B121E 15 [009] - Open or Short to Plus
Reset counter: 204
Mileage: 6580 km
Date: 2019.02.04
Time: 00:03:54
590853 - Window Regulator; Front Drivers Side
B14D1 54 [009] - Missing Calibration / Basic Setting
Reset counter: 204
Mileage: 6580 km
Date: 2019.02.04
Time: 00:03:52
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AG HW: 2Q0 959 655 AG
Component: VW22Airbag 010 0248
Revision: --------
Coding: 88CCC000000000005C0000CF008800000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 025C71E6B4831447DCD-8056
Subsystem 1 - Part No SW: ----------- HW: 442 061 606 18
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y22B32771D03C20Z
Subsystem 2 - Part No SW: ----------- HW: 442 061 606 18
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y22A72771D00A2F6
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 505 18
Component: SideSensor_Dr 1C7 0148
Serial number: 3517783AF295E543C25Y
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 505 18
Component: SideSensor_Pr 1C7 0148
Serial number: 3527783AF295E540E2E0
Subsystem 5 - Part No SW: ----------- HW: 442 132 605 18
Component: FrontSensor_D 290 118A
Serial number: 355AG11C329B6A7123BW
1050117 - Databus
Reset counter: 204
Mileage: 6580 km
Date: 2019.02.04
Time: 31:03:51
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [137] - Resistance Too High
Mileage: 6580 km
Date: 2019.02.04
Time: 31:03:53
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 6580 km
Date: 2019.02.04
Time: 31:03:53
Part No SW: 2G0 920 730 A HW: 2G0 920 730 A
Component: KOMBI 209 0461
Coding: 24A0010021000008010800000000000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001023
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 1F1A18922731D9AFD33-804A
Part No SW: 2Q0 909 901 HW: 2Q0 937 089
Component: GW MQB A0 H98 0916
Coding: 030000046F085600F8000048080E00010001070000000000000000000000
ASAM Dataset: EV_GatewA0 013020
ROD: EV_GatewA0_VW27.rod
VCID: 6FBA28529711092F233-803A
Subsystem 2 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 1007B2D9
Address 44: Steering Assist (J792) Labels:* None
Part No SW: 2Q2 909 144 J HW: 2Q2 909 144 F
Component: TRW_G4L_MQBA0 620 6030
Serial number: 0578212CB4J1603
Coding: 00000000000000000101020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
VCID: 3A2CC9069CD39C87C4D-806E
15788544 - Crash Shut-Down Activated
P1609 00 [137] - -
[DEM_FRONT_CRASH_FAULT]
Mileage: 6580 km
Date: 2019.02.04
Time: 00:03:51
Engine speed: 961 /min
Voltage terminal 30: 13.50 V
Power steering current consumption: 0.5 A
max.value: 0.5 A
End stage temperature: 215 °C
Steering assistance: engine output: 100 %
Engine angle: 65535 °
Electric motor speed: 45535 /min
Steering assistance: target engine torque: 0.0 Nm
Steering torque: -0.3 Nm
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 17A 035 869 HW: 17A 035 869
Component: MU-E--ER 690 8740
Serial number: 13061800012483
Coding: 027200003C00000041110001000110001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001041
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 6888434EB2FFDE17629-803C
End----------(Elapsed Time: 00:41, VBatt start/end: 13.4V/13.4V)-----------
Looks like the same basic rack as here and ...Can your please assist me to solve this matter
Official guide from VW is replace rack if crash shutdown active.
Which control module?can u tell me what would be the reason that a vw polo 2018 tsi would read incorrect module installed.
I see no crash data faults in the airbag module in the scan you posted.could u assist with with information on how to clear stored crash data from an airbag ecu on the 2019 vw polo 8 tsi.
