Polo 8 R-line 2019 crash data stored in steering module
Ash21
Durban, South Africa
LP/SN
How to clear crash data on a vw polo 8 2019 steering control module
If you have a legitimate VCDS, please post an Auto-Scan so people can see exactly what steering rack/module this is equipped with.
Ash21
LP/SN
Hello I'm unable to post an Auto scan has I'm awaiting account validation...
Email address is empyreholding@gmail.com
Account user name is Ash21
Please can u assist so that I can post an Auto scan thank you
Ash21
LP/SN
The fault that the car is picking up is ... Crash data stored in control module.. please can u assist thank u.
Ash21
LP/SN
Hi when I get to the ross tech website it says only verified members can post ... Please can u help me verify my account
You can post right here, in this thread.
Have you read this?
How do I post the auto scan here from my cellphone
Unless the scan itself is on your cellphone, which seems rather unlikely, I suggest you use a computer.
Ash21
LP/SN
When I'm trying to post the auto scan on the computer it says only verified members can post. Can u tell me how to check my information is correct so I can get verified.
Viking
C?ID=151455
You seem to be overthinking this. Log into your forum account ( You Do Not Need To Be Verified!) from your computer and find this thread here where you've already posted.
Find the text file of your autoscan, and copy / paste the complete text as a reply to any of the posts here.
Essentially, follow the instructions on the video which has been posted to help you understand. I'll post it again, watch it.
Ash21
LP/SN
Hello this is an auto scan of the vehicle fault code . Can your please assist me to solve this matter thank you.
Chassis Type: AW-VW27 (2Q0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: AAVZZZAWZJU070597   Mileage: 6580km-4088miles
Address 01: Engine (J623-CHZL)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 BD    HW: 04C 907 309 AT
   Component: R3 1.0l TFS   H21 5150
   Revision: WXH21---
   Coding: 01110012230411080000
Shop #: WSC 31414 790 00200
ASAM Dataset: EV_ECM10TFS01104C906026BD 002003
   ROD: EV_ECM10TFS01104C906026BD_002_VW27.rod
   VCID: 6490577E4ED7BA774E1-8030
   CAN Converter 01:
4527 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 00:03:54
                    Engine speed: 966.00 /min
                    Normed load value: 13.7 %
                    Coolant temperature: 64 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 13.311 V
                    Outside air temperature: 9 °C
Absolute intake pressure: 34 kPa abs
                    Engine torque: 15.9 Nm
                    Fuel: tank fill level: 0.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Engine operating condition: Idling
23813 - Engine Oil Temp. Sensor (G8)
          P0197 00 [039] - Signal too Low
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 00:03:56
                    Engine speed: 962.50 /min
                    Voltage terminal 30: 13.216 V
                    Oil fill level: 18.000 mm
                    Time since term 15 OFF StartStop: 65535 s
                    Engine oil temperature: 25.5 °C
                    Bit string for status of oil level-Bits 0-7: 0
          U0428 00 [039] - -
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 00:03:54
                    Engine speed: 959.00 /min
                    Normed load value: 14.1 %
Readiness: 1110 0001
   Part No SW: 2Q0 614 517 AB    HW: 2Q0 614 517 L
   Component: ESC_base      H13 0223
   Serial number: 08500846180629
   Coding: 09034B64154890ADD201A81F24E142A649124D26224A242444541254452442659248B26444522424222A482AA23196421D8C6942B8
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: 6E843556901B0027285-803A
1272 - Tire Pressure Warning
          C102D 00 [137] - -
                    Reset counter: 204
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 00:03:51
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 204
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 00:03:51
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 2G2 820 045 D    HW: 2G2 820 045 D
   Component: SG_AC_Manuell H50 0301
   Coding: 012100000800000001000400020000000000000000000000000000000000
ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0_VW27.rod
   VCID: 221C11661443F447FCD-8076
   Part No SW: 2Q0 937 089     HW: 2Q0 937 089
Component: BCM A0 Std H98 0916
   Serial number: 08001818800368
ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 77AA1032EF4141EFFB3-8022
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 2Q2 959 881 C    HW: 2Q2 959 881 C
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000021516316
   Coding: 1F0000
   Subsystem 2 - Part No SW: 2Q2 959 882     HW: 2Q2 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000021724966
   Coding: 050000
   Serial number: 000000000ZY1811703TF
   Serial number: 00000000000099967326
8202 - Bulb for Left DRL
          B121D 15 [009] - Open or Short to Plus
                    Reset counter: 204
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 00:03:54
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: not activated
                    Zusaetzliche Umgebungsdaten-OFF: not activated
                    Zusaetzliche Umgebungsdaten-Outside air temperature: 0
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
                    Zusaetzliche Umgebungsdaten-Parking light: not activated
                    Zusaetzliche Umgebungsdaten-Parking light left: not activated
                    Zusaetzliche Umgebungsdaten-Parking light right: not activated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: 45
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 13.5 V
8458 - Bulb for Right DRL
          B121E 15 [009] - Open or Short to Plus
                    Reset counter: 204
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 00:03:54
590853 - Window Regulator; Front Drivers Side
          B14D1 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 204
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 00:03:52
   Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
   Component: VW22Airbag    010 0248
   Revision: --------
   Coding: 88CCC000000000005C0000CF008800000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 025C71E6B4831447DCD-8056
   Subsystem 1 - Part No SW: -----------    HW: 442 061 606 18
   Serial number: 3577Y22B32771D03C20Z
   Subsystem 2 - Part No SW: -----------    HW: 442 061 606 18
   Serial number: 3587Y22A72771D00A2F6
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 505 18
   Serial number: 3517783AF295E543C25Y
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 505 18
   Serial number: 3527783AF295E540E2E0
   Subsystem 5 - Part No SW: -----------    HW: 442 132 605 18
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11C329B6A7123BW
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 204
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 31:03:51
          B1006 1B [137] - Resistance Too High
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 31:03:53
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 31:03:53
   Part No SW: 2G0 920 730 A    HW: 2G0 920 730 A
   Component: KOMBI         209 0461
   Coding: 24A0010021000008010800000000000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001023
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 1F1A18922731D9AFD33-804A
   Part No SW: 2Q0 909 901     HW: 2Q0 937 089
Component: GW MQB A0 H98 0916
   Coding: 030000046F085600F8000048080E00010001070000000000000000000000
ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_VW27.rod
   VCID: 6FBA28529711092F233-803A
   Subsystem 2 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 1007B2D9
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 J    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 620 6030
   Serial number: 0578212CB4J1603
   Coding: 00000000000000000101020101000101000001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 3A2CC9069CD39C87C4D-806E
15788544 - Crash Shut-Down Activated
          P1609 00 [137] - -
          [DEM_FRONT_CRASH_FAULT]
                    Mileage: 6580 km
                    Date: 2019.02.04
                    Time: 00:03:51
                    Engine speed: 961 /min
                    Voltage terminal 30: 13.50 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 215 °C
                    Steering assistance: engine output: 100 %
                    Engine angle: 65535 °
                    Electric motor speed: 45535 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: -0.3 Nm
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 17A 035 869     HW: 17A 035 869
   Component: MU-E--ER      690 8740
   Serial number: 13061800012483
   Coding: 027200003C00000041110001000110001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 6888434EB2FFDE17629-803C
End----------(Elapsed Time: 00:41, VBatt start/end: 13.4V/13.4V)-----------
Ash21
LP/SN
Hi can u tell me what would be the reason that a vw polo 2018 tsi would read incorrect module installed. And how to correct this . Thank u
Ash21
LP/SN
Good day ... Please could u assist with with information on how to clear stored crash data from an airbag ecu on the 2019 vw polo 8 tsi. Thank u . I await your response on this one
Which control module?
I see no crash data faults in the airbag module in the scan you posted.
