Fitted an RNS315 and getting 37 Navigation -- Status: Not registered 0011
ScottishGeek
Manchester, UK
C?ID=210460
Hi all,
As the title say I have swapped out the original radio unit for an RNS315. I have been unable to turn on the bluetooth in the device using VCDS and suspect I need to make changes elsewhere, such as CAN gateway first. Just not sure what?
Thanks.
UPDATE: gone in and ticked Navigation in CAN gateway. Updated log below.
Scan results:-
Wednesday,09,April,2014,07:46:58:56663
VCDS Version: 12.12.2.0
Data version: 20140212
Dealer/Shop Name: SGeek
VIN: WVWZZZ3CZ8E177597   License Plate: XXXX
Mileage: 104640km-65020mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ8E177597   Mileage: 104640km/65020miles
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 FG    HW: 03G 906 018 FG
   Component: R4 2.0l PPD1.5 G    0907
   Revision: --H55---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 05314 000 00000
   VCID: 6FC339027E405B6672D-803A
Readiness: N/A
   Part No SW: 02E 300 050 D    HW: 02E 927 770 AE
   Component: GSG DSG         081 1404
   Revision: 04708010    Serial number: 00000801091568
   Shop #: WSC 44551 111 44551
   VCID: 130B55F232A8DF86365-8046
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000785118028
   Coding: 0001294
   Shop #: WSC 05311 000 00000
   VCID: 1F6309C2CE608BE682D-804A
   Part No SW: 1K0 820 047 HB    HW: 1K0 820 047 HB
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6BFB2D124A58A7465E5-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000008002323
   Coding: 00880F0700041A00470A00000F000000000859435C000100000000000000
   Shop #: WSC 05124 000 00000
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 190108 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Component: J234__006 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP1MFZ0.
   Coding: 0012342
   VCID: 3B5BDD527AB8F7C68E5-806E
   Subsystem 1 - Serial number: 6333FTS626210098
   Subsystem 2 - Serial number: 6343FTS628150158
   Subsystem 3 - Serial number: 6353ETS6UVTASVNP
   Subsystem 4 - Serial number: 6363ETS6PRN9SVNP
   Part No SW: 3C0 953 549 AB    HW: 3C0 953 549 AB
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507AP
   Coding: 0001014
   VCID: 6CF92E0E4F56A07E57F-8039
   Part No SW: 3C0 920 960 N    HW: 3C0 920 960 N
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007405
   Shop #: WSC 00706 210 87584
   VCID: 2E7DE406B9CA126E39B-807B
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P08129009D
   Coding: FD807F064002022003
   VCID: 236B0532E208AF06A65-8076
                    Reset counter: 178
                    Mileage: 104420 km
                    Time: 12:55:14
01304 - Radio
                    Reset counter: 178
                    Mileage: 104420 km
                    Time: 12:55:17
00469 - Infotainment Databus in Single Wire Operation
                    Fault Status: 00111011
                    Reset counter: 174
                    Mileage: 104420 km
                    Time: 13:19:48
                    Reset counter: 178
                    Mileage: 104627 km
                    Time: 19:23:52
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 3957C75A7084C5D69C9-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C8 035 279     HW: 3C8 035 279
   Component: RNS315-EU   H59 0319
   Serial number: VWZAZ2M5562213
   Coding: 060004300400000000008000
   Shop #: WSC 00015 115 00000
   ROD: EV_RNS315EUV2UDS.rod
   VCID: E8F1D21E13AE0C5EB37-80BD
   Component: EUR_W_V4  0050
1048629 - Aux IN Socket
          B1104 13 [009] - Open Circuit
                    Reset counter: 140
                    Mileage: 104644 km
                    Time: 19:15:12
1048630 - CD Changer
          B1101 31 [009] - No Signal
                    Reset counter: 140
                    Mileage: 104644 km
                    Time: 19:15:09
1048641 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 140
                    Mileage: 104644 km
                    Time: 19:15:11
   Component: J386  TUER-SG FT    1132
   Revision: 32008001    Serial number: 00000521588121
   Coding: 0000693
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 364DCC66419A2AAE71B-8063
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0191020051030E763004941570085FCE1078A1
   Component: Neigungssensor  004 0611
                    Reset counter: 119
                    Mileage: 104305 km
                    Time: 13:57:50
   Component: J387  TUER-SG BT    1132
   Revision: 32008001    Serial number: 00000088888123
   Coding: 0000692
   VCID: 3C59DE4E7FB6F0FE87F-8069
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000333796
   Coding: 0000057
   VCID: 2977171A80247556EC9-807C
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000185609
   Coding: 0000144
   VCID: 70C13A7E637E449E6B7-8025
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000176600
   Coding: 0000144
   VCID: 71C73F7A68744D96649-8024
ScottishGeek
Manchester, UK
C?ID=210460
I appreciate that their is every possibility that it is not there however i was told by the vendor that he had bluetooth working on it is his old car.
At present though I am unable to change any setting on it, disabling the cd autochanger for example, without getting an error 31 from the software.
I am wondering it there is anything else i need to disable as I am getting some infotainment errors also.
steeldrivinman
Switzerland
C?ID=208345
Could be that he had an external module as well. Have you tried Module 37 Navigation. I think it is under Byte 4 bit 6 Bluetooth Audio Streaming, uncheck the box. Have you checked on the back of the unit? If it has bluetooth it will have a MAC address. If the MAC address is all 0's then you are out of luck.
ScottishGeek
Manchester, UK
C?ID=210460
Checked the photo on the label on the unit I took before fitting in and there is a MAC address (not just zeros). Any time I try and save changes in module 37 VCDS gives me a error 31 "request out of range".
