2019 e-tron (USA) and disabling kick hitch open function
mmmzon
C?ID=405530
Good day,
I am trying to see whether anybody has successfully figured out how to disable the kick to open hatch on 2019 e-tron SUV. ODBeleven seems to be able to do it (so they claim, see https://forum.obdeleven.com/thread/7801/confirmed-tron-obdeleven-tweaks) but I'd prefer to continue with VCDS if there was an option to do just that. Is there any running list of VCDS tweaks to e-tron - I searched in here but it does not seem to exist or my search skills suck.
Thanks in advance !
Do we have an Auto-Scan from it somewhere to see how it is equipped and configured?
For lists of tweaks, a model-specific forum (or forum sub-section) may be a better bet than here.
mmmzon
C?ID=405530
I will run the scan when I have a chance (later today) - I will likely need to add VIN to my VCDS because I am likely out (used my 3 numbers already). I did not want to spend money, though, if there was no way to disable this "feature".
I searched high and low and unfortunately, no hits on eTron specific fora. I was hoping for more information here, where VCDS questions are asked / answered.
You do not need to register a VIN to run an Auto-Scan.
mmmzon
C?ID=405530
Uwe,
After several attempts, I am unable to perform the eTron scan. The software was updated, firmware as well, I plug the adapter into the ODB port, and ... nothing. All options remain grayed out. I tried several different PCs, same effect. I even tried a loaner adapter module, and the outcome is the same.
Thank you in advance
[Options] is not grayed out.
What happens when you click [Options] and then [Test]?
mmmzon
C?ID=405530
It shows good status of the adapter, when plugged into the car. As mentioned before, I did update the firmware on the adapter (it asked me to)
Please show us the "good status" when you do [Options] -> [Test].
You need to do [Options] -> [Test] -> [OK] -> [Save] for VCDS to know what kind of interface you are using and enable the other buttons.
mmmzon
C?ID=405530
That was dumb of me ... Indeed.
Full autoscan is below, I stripped the VIN number (does not matter for the reference IMHO).
Saturday,19,June,2021,17:20:32:15435
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 06 09 13 15 16 17 19 2B 36 3C 42 44 46 47 51 52 5F 69
          6D 74 75 81 82 84 8C A5 BB BC C0 C5 C6 CA CD CE CF D6 D7 DB
          DC DE 8104
51-Electric Drive -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
CE-Drive Motor 2 -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558 E    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0001
   Coding: 2A0A0012007E000034280000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558E 001001
   ROD: EV_VCU00XXX0204KE907558E.rod
   VCID: 4BC362722346D4E32A1-801E
   Parking lock:
   Subsystem 1 - Part No SW: 0MA 341 601 B    HW: 0MA 341 601 B
   Component: V682 ParkLock  H23 0611
   Serial number: 2018.11.17.000000191
   Part No SW: 4KE 909 059 AC    HW: 4KE 909 059 G
   Component: ESC           H09 0078
   Revision: 00000000    Serial number: 60199000004118
   Coding: 008800BA3D940BA093540C76187D52E4253EA90000BCD0C930184A27A47C95
   Shop #: WSC 56602 003 1048576
   ASAM Dataset: EV_BRSContiMKC1AU516 009376
   ROD: EV_BRSContiMKC1AU516_009.rod
   VCID: 08499D7E72B0FFFBC73-805C
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000362241561
   Coding: 001CB2400001BEA14843010101010000810000070700878700000000000000
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D273CAA6DF26A53A45-8068
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ800103011940258682
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ800120121811470072
   Part No SW: 4N0 907 063 EG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0671
   Coding: 07000363C0291CDD070257889CFB9C28131B37510C06009789010A0019231601086309024010200000000303004B181808028000C4030000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 015009
   ROD: EV_BCM1BOSCHAU651_015.rod
   VCID: 77ABEE820F4E8003BE9-8022
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000001811150400476
   Coding: 7DC727
   Serial number: 22527871X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 14S14.02.1900690659
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z00PV02
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 A    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0001
   Serial number: GX1NR109011923310797
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 L    HW: 4K0 947 135 L
   Component: Dachmodul  H42 0413
   Serial number: C00183916
   Coding: 0D0104
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA135933000061636214
   Coding: 0A0700
   Subsystem 8 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98AI33784229
   Subsystem 9 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98AI33753870
   Subsystem 10 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98AI33784221
   Subsystem 11 - Part No SW: 4N0 963 575     HW: 4N0 963 575
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98AI33784220
   Front windshield washer pump:
   Subsystem 12 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
   Component: J1100/SWP  H21 0015
   Serial number: 00000000001904401266
   Coding: 040000
   Part No SW: 4KE 907 561 B    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Coding: FE659F5C58082C0001038021000000BE4A1246595481009E05
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 42DD4F56140C15ABD97-8016
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Fault Frequency: 13
                    Reset counter: 65
                    Mileage: 12252 km
                    Date: 2021.06.14
                    Time: 16:36:04
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 14.2 V
                    Vehicle speed: 4.38 m/s
                    Longitudinal acceleration: 0.05 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
                    Steering_angle-Data: 94.400 °
                    Yaw_rate-Data: 2.109 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: -0.059 °
                    Misalignment angle: horiz: fast algorithm: -0.057 °
                    Congestion pilot: status: OFF
                    Outside temperature: 29.50 °C
                    Sensor blindness: radar: no blindness detected
2102 - Databus
          [FAULT_ESP_CONTROL_FAIL]
                    Fault Frequency: 13
                    Reset counter: 65
                    Mileage: 12252 km
                    Date: 2021.06.14
                    Time: 16:36:04
                    Vehicle speed: 4.34 m/s
                    Longitudinal acceleration: 0.08 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
                    Steering_angle-Data: 85.100 °
                    Yaw_rate-Data: 1.298 rad/s
   Part No SW: 4KE 959 655 A    HW: 4KE 959 655 A
   Component: AirbagVW32    H37 3122
   Serial number: 003XQM00978M
   Coding: BFCCFCC000200000A200003FFA1D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 4CC1616E2648D3DB23B-8018
   Left seat belt tensioner:
   Serial number: 00AI2019028313600000
   Coding: 03F002
   Right seat belt tensioner:
   Serial number: 00AI2019027349500000
   Coding: 03F002
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J19000B0K7Q0A
   Coding: 303138
   Subsystem 4 - Part No SW: -----------    HW: 480 000 502 19
   Serial number: 35700000000AD301B83L
   Subsystem 5 - Part No SW: -----------    HW: 480 000 502 19
   Serial number: 3580000000077601B83G
   Subsystem 6 - Part No SW: -----------    HW: 480 031 402 19
   Serial number: 351001C1C29316114E2Z
   Subsystem 7 - Part No SW: -----------    HW: 480 031 402 19
   Serial number: 352001C1C29319D06EDK
   Subsystem 8 - Part No SW: -----------    HW: 480 021 601 19
   Component: FrontSensor_D  000 0149
   Serial number: 3550001BD2F0DDC452DV
   Subsystem 9 - Part No SW: -----------    HW: 480 021 601 19
   Component: FrontSensor_P  000 0149
   Serial number: 3560001BD2F0DDC6047P
   Crash sensor high-voltage system 1:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 501 19
   Component: HVSensor_gSat  000 0149
   Serial number: 3510001C32F0DDC5F5FY
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 11 - Part No SW: -----------    HW: 480 022 501 19
   Component: SideSens_B_Df  000 0149
   Serial number: 3520001992ECF892C40L
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 12 - Part No SW: -----------    HW: 480 022 501 19
   Component: SideSens_B_Pf  000 0149
   Serial number: 3550001C32F0DDC4227D
1065477 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
                    Reset counter: 65
                    Mileage: 12372 km
                    Date: 2021.06.18
                    Time: 13:36:17
   Part No SW: 4N0 907 129 Q    HW: 4N0 907 129 Q
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 3FDB46A267FE7843B69-806A
7340544 - Heated Steering Wheel
          B1538 13 [009] - Open Circuit
                    Reset counter: 19
                    Mileage: 12252 km
                    Date: 2021.06.14
                    Time: 16:31:51
                    Freeze_Frame_Heated_Steering_Wheel-Current_Average: 0.00 A
                    Freeze_Frame_Heated_Steering_Wheel-Current_Peak: 0.00 A
                    Freeze_Frame_Heated_Steering_Wheel-Operation_time_counter: 20206 min
                    Freeze_Frame_Heated_Steering_Wheel-PWM_Duty_Cycle: 0 %
                    Freeze_Frame_Heated_Steering_Wheel-Steeringwheel_Temperatur_Raw_Busvalue: 0 °
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_12V: 11988.28 mV
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_5VS: 4914.84 mV
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_at_sensor: 0.00 V
                    Freeze_Frame_Heated_Steering_Wheel-Voltage_Output_Power_Switch: 1 bit
   Part No SW: 4KE 920 795 B    HW: 4KE 920 795
   Component: FHybRDWACC--- H13 0031
   Coding: 8B4600C97C88D7050286E170BB84680008000000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 46D553463824298BF5F-8012
   Part No SW: 4K1 907 468 D    HW: 4K1 907 468 C
   Component: Gateway       H04 0322
   Serial number: 1DF06031417301
   Coding: 02030005000100C000810000005B01329C8A0047180000000900009F00000000
   ASAM Dataset: EV_Gatew31xAU65x 003170
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 3635238648C4B90B65F-8062
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Serial number: 767496010019012105C4
   Subsystem 3 - Part No SW: 4N0 419 508     HW: 4N0 419 508
   Component: J1158 KLR  H44 0030
   Serial number: 18327027306S00304401
262693 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BAP_Timeout_BatteryControl]
                    Reset counter: 60
                    Mileage: 12284 km
                    Date: 2021.06.17
                    Time: 10:02:38
8913155 - Development Code 4
          B2F04 00 [009] - -
          [RWB_TME_Init_Abwurf_Dauerinit]
                    Reset counter: 19
                    Mileage: 12257 km
                    Date: 2021.06.14
                    Time: 17:54:00
8913156 - Development Code 5
          B2F05 00 [009] - -
          [RWB_BCME_Init_Abwurf_Dauerinit]
                    Reset counter: 19
                    Mileage: 12257 km
                    Date: 2021.06.14
                    Time: 17:54:00
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000016743008
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 3431198E5EB8AB1B5BB-8060
   Serial number: 00000362194865
   Coding: 001C9A400001BEA14803010101010000810000070700878700000000004000
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ8001191218402584FF
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ80011401191147005E
   Part No SW: 4KE 907 566     HW: 4N0 907 566 A
   Component: MRR_HR H12 0426
   Coding: 1FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 0557944A45A2E293BC5-8050
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        007 0387
   Serial number: 0000360547648
   Coding: 001DDB0152001482A009A032
   Shop #: WSC 00009 444 00000
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   VCID: 48C95D7E32303FFB073-801C
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0505
   Coding: B4000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D1F96A4ACA52B497-8066
   Part No SW: 8W0 907 064 GH    HW: 8W0 907 064 DH
   Component: BCM2 MLBevo   025 0424
   Coding: 017400004FB100C1650FA0046C01C88200004000810426582F0400000F04823F001E0101010F13
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016.rod
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY183360B63
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000046035665
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4KE 945 423 A    HW: 4KE 945 423 A
   Component: T1 LH SAE HD  H10 0403
   Serial number: A1WM00002BD
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11461562
   left tail lamp 2:
   Subsystem 5 - Part No SW: 4KE 945 429 C    HW: 4KE 945 429 C
   Component: T2 LH SAE HD  H12 0410
   Serial number: A1WP0000DYS
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 4KE 945 424 A    HW: 4KE 945 424 A
   Component: T1 RH SAE HD  H10 0403
   Serial number: A1WS0000207
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 4KE 945 430 C    HW: 4KE 945 430 C
   Component: T2 RH SAE HD  H12 0410
   Serial number: A1WQ0000DZ6
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJ7D00EBDX
   Coding: 0115160000AAAA2FAA0000010002
   Shop #: WSC 00022 444 00000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411E9CEEE583B9BCBB-8070
   Part No SW: 0EF 907 080 G    HW: 0EF 907 080 C
   Component: CUFZD683Q0AD2 H02 0010
   Revision: --------    Serial number: -00126.11.18000
   Coding: 01000000000000000000
   ASAM Dataset: EV_DMCMHITACAU516 003007
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3A2D37B67CDC5D6B817-806E
13828096 - Component protection
          U1115 00 [047] - No basic setting for SHE key
          [CmpntPrtctn_SHEKeyNoCnfg]
                    Mileage: 12252 km
                    Date: 2021.06.14
                    Time: 16:19:29
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       007 0387
   Serial number: 0000361159722
   Coding: 001DDB015E001482A009A030
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
   VCID: 47CB5E423F2E30830E9-8012
   Part No SW: 4K0 035 084 D    HW: 4KE 035 084
   Component: MU-H-LNS-US   047 2711
   Coding: 0115760200000000C3220002061C02302F0001E403F008048E
   VCID: 270BFEC29F6ED083EE9-8072
   Subsystem 1 - Part No: V03 959 807 TF
   Component: MIB2P_NA_Q420  0497
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4KE 919 605 B    HW: 4KE 919 605 A
   Component: DU AU516 High  H71 0147
   Serial number: INX00121111800131085
   Compact disc data bank:
   Component: Gracenote2  3007
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000006138029
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0147
   Serial number: INX00121111800140275
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 051900013183007
          B11CF 53 [009] - Deactivated
                    Reset counter: 19
                    Mileage: 12252 km
                    Date: 2021.06.14
                    Time: 16:19:25
                    Voltage terminal 30: 13.1 V
                    Satellite radio tuner status-Antenna current: 107 mA
                    Satellite radio tuner status-Reception quality: weak_signal
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 05
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 05
   Part No SW: 4M0 907 383 E    HW: 4M0 907 383
   Revision: 9C001003    Serial number: 0506637563
   Coding: 0200000200000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C744-8781-0
   Coding: 33B0
   VCID: 4ACD67762C3CCDEB117-801E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4KE 907 777 AD    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2311
   Serial number: 0602190701
   Coding: 98D86883DA4020
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 0E45AB6610D4A1CB0DF-805A
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130484628
   Coding: 303030
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F120363
   Coding: 01C020FFC040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809FDFE9270DFFBE73-807C
1114627 - Antenna 2 for Emergency Call and Communications Module
          B18BE 13 [008] - Open Circuit
                    Reset counter: 65
                    Mileage: 12373 km
                    Date: 2021.06.18
                    Time: 13:40:46
                    Voltage terminal 30: 14.60 V
                    Mobile communications antenna 2 for emergency call module and communications unit-Connection to antenna: Open circuit
                    Mobile communications antenna 2 for emergency call module and communications unit-Reception level antenna: -113.00 %
                    Mobile communications antenna 2 for emergency call module and communications unit-Voltage: 1010 mV
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145SB700108
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C2131AE76E8635B93B-8068
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4KL 919 617     HW: 4KL 919 617
   Component: HeadupDisplay H05 2831
   Coding: 5700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001010
   ROD: EV_HeadUpDisplAU65X_AU58.rod
   VCID: 0C41A16E66C893DBE3B-8058
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4KE 907 547 B    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H13 0260
   Serial number: 648027100201847
   Coding: 110112
   ASAM Dataset: EV_NightVisioG3AUTOLAU516 001002
   ROD: EV_NightVisioG3AUTOLAU516.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552 A    HW: 4G0 980 552
   Component: NV-CAM-Gen3  H06 0007
   Serial number: 639589400B1902400356
   Part No SW: 4KE 915 233 F    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0231
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_VW53.rod
   VCID: 41DF405A110A0EB3C0D-8014
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 B
   Component: BJB_MLBBEV  H12 0369
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AR    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0295
   Coding: 022184000000000000FFD60000F4470E539E5600000000000000000000969401019BA8000000000000000080000000000000000000000000F98040000000000000007CD80000009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001006
   ROD: EV_ZFASAU516_001.rod
   VCID: 0F7BB66217DEA8C3069-805A
233479 - Parking Sensor(s); Rear
          B107B F0 [008] - Function Limitation due to External Factors
                    Reset counter: 59
                    Mileage: 12257 km
                    Date: 2021.06.15
                    Time: 15:41:05
233523 - Parking Sensor(s); Front
          B10FC F0 [008] - Function Limitation due to External Factors
          [Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
                    Reset counter: 59
                    Mileage: 12257 km
                    Date: 2021.06.15
                    Time: 15:40:30
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Fault Frequency: 13
                    Reset counter: 65
                    Mileage: 12252 km
                    Date: 2021.06.14
                    Time: 16:36:04
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       006 0387
   Serial number: 0000362783943
   Coding: 000DDB0100001482E008A020
   ROD: EV_DCU2RearDriveMAXHKLO_VW53.rod
   Component: TSG HBFS      006 0387
   Serial number: 0000362771876
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C0: Act. for Ext. Noise (J943)       Labels:* None
   Part No SW: 4KE 035 335     HW: 3F0 035 335
   Component: E_SOUND_SGH05 0121
   Serial number: EN190426440000
   Coding: 04
   ASAM Dataset: EV_ESoundMLBEvoS1NN 003008
   ROD: EV_ESoundMLBEvoS1NN.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0020914
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00100.4W.4A20370472
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
   Component: J842 EKK es33  H03 0015
   Serial number: 00000000018122200387
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Coolant heating:
   Subsystem 5 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00100.5W.2A20370298
   Expansion valve 2 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000150561375
   Shut-off valve 2 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130524098
   Shut-off valve 3 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130524102
   Shut-off valve 4 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130524112
   Shut-off valve 5 for refrigerant:
   Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130524088
   Radiator shutter:
   Subsystem 11 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V544KJS1  H12 0109
   Serial number: 20190107020103053766
   Radiator louver 2:
   Subsystem 12 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V550KJS2  H12 0109
   Serial number: 20190107020103050985
   Coolant valve 1:
   Subsystem 13 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000053706
   Coolant valve 2:
   Subsystem 14 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000050440
   Coolant valve 3:
   Subsystem 15 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000045518
   Coolant valve 4:
   Subsystem 16 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000036321
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0023
   Serial number: ---------------
   Coding: 2A49A44542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56F58306E884990B85F-8002
   Flap 1 for charging socket:
   Subsystem 1 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F496LKL1       004 0004
   Serial number: 20190608030206082709
13705549 - Databus
          U1121 00 [040] - Missing Message
          [DCDC_01_Timeout]
                    Reset counter: 31
                    Mileage: 12257 km
                    Date: 2021.06.16
                    Time: 12:16:14
13709330 - Unknown Error Code
          U15C9 00 [040] - -
          [LMSF_intervention]
                    Reset counter: 31
   Component: SAD_STG_1     005 0002
   Coding: 228040051602
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
   VCID: 75B7E48A1542F213AC5-8020
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 C    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0205
   ASAM Dataset: EV_LaserScannAU651 013017
   ROD: EV_LaserScannAU651_013.rod
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 J    HW: 0EF 907 180 C
   Component: CUBZE683Q0AD2 H02 0010
   Revision: --------    Serial number: -00128.11.18000
   ASAM Dataset: EV_DMCM2HITACAU516 003007
   VCID: 3E253BA660F4714BBDF-806A
                    Mileage: 12252 km
                    Date: 2021.06.14
                    Time: 16:19:29
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0426
   Coding: 1FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 71BFD09A612ADE3370D-8024
0006 - Reset of Control Module
          B16CE 00 [008] - -
                    Reset counter: 65
Address D7: Light Ctrl Right 2 (A27)       Labels: None
          B16CE 00 [008] - -
                    Reset counter: 65
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4KE 907 669     HW: 4N0 907 669 A
   Component: MRR_VR H12 0426
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
   VCID: 094F987A69BA86F3D8D-805C
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0426
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 A    HW: 4N0 035 502 A
   Component: WLC Front     H10 0061
   Coding: 800000
   VCID: 221DEFD6F44C35ABB97-8076
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
End----------(Elapsed Time: 03:19, VBatt start/end: 13.2V/13.2V)-----------
@mmmzon: So-I've replicated the instruction-set from your link below:
DISABLE AUTOMATIC KICK-TO-OPEN REAR LID
Adaptation
Control unit: 46 Central Module Comfort System
Name: Personalization settings vehicle
Values:
Rear lid unlocking through rear lid opening sensors:
Old value: On
New value: Off
Your auto-scan confirms that the car has a hex46 module which VCDS calls Central Conv. (J393) and the scan nicely identifies a Rear lid opener control module as a slave. So, all good thus far
The language of the "other device" isn't too different to VCDS because both devices essentially access the same data - which is mostly resident within the module.
In the main, the major difference with Ross-Tech speak in respect of adaptation channels is that VCDS precedes the channel names with "Tag" numbers and these are not used in the "other device"
So, first-off - pop the bonnet lid (not sure if this is needed on your yanky car - but it's an easy safeguard
Then, fire-up VCDS and select the 46-Central Conv from the screen below:
then select Adaptation -10 (ignore the actual values in the screen below)
Then in the screen below (which I developed for another purpose) - instead of "ha59" in Step 1, enter "Personalization"
After this, click on step 2 and you should see a channel name Personalization settings vehicle-Rear lid unlocking through rear lid opening sensors (the channel name will be preceded with 2 x sets of Tag numbers). Select this channel and you should get a dialogue box like this (ignore the actual values):
If the instructions are correct, the Stored value box should read "On" - click on the down-arrow at the extreme right-side of the New value box and select "Off" from the options - then click Do It! and the magic should happen.
Hopefully, a security code isn't needed for this tweak - none is mentioned in your link instructions
PS: apropos of your hiding the VIN number - lots of folk do this, but I've never understood the rationale for this practice. Can you articulate your concerns (please) - particularly since anyone walking down the street where the car is parked can at anytime read/photograph this information from the plenum-cover window under the windshield?
Looks like Audi calls it "Rear lid release" rather than "Rear lid unlocking" in this module.
There appear to be four channels associated with each of the possible keys, plus another for the vehicle in general:
IDE08225-MAS10221 -- Personalization settings vehicle - Rear lid release via rear lid open sensors.
kczach
C?ID=123637
I don't want to hijack the thread but has anyone been able to get the rear lid to close with a foot swipe?
mmmzon
C?ID=405530
I will check it out as soon as I can. Since I am tapped out on VINs for my module (3/3), I will need to either get a new one or add more VINs to the existing one. Decisions, decisions ... I did confirm the kick sensor works for now, so I have at least baseline to work against once I get VINs added to the module.
I seem to hit this thread when looking for more information: https://forums.ross-tech.com/index.php?threads/13706/ but that seems to be Q5 2018 model. How do I pull the same kind of information from my eTron?
Personal preference, nothing more (and bad personal experience from the past). VIN can be checked against DMV records, especially with aunt / friend / colleague / mother working there and I do not exactly like my personally identifiable information floating around the Internets ...
