- May 29, 2021
- 14
- 5
- Netherlands
- C?ID=258023
Hex Net scan Golf 8 with malfunction some control unit shows OK 0000
What could be the cause?
onday,07,June,2021,14:59:04:22779
VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4543.4
VIN: WVWZZZCDZLW0100000 License Plate: J-00000
Mileage: 7169km-4454mi Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 52 5F 75 82
A5 D6 D7 8107 811E 811F 8120 8121
VIN: WVWZZZCDZLW000000 Mileage: 7169km-4454miles
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DPBA) Labels: None
Part No SW: 05E 906 012 HW: 05E 907 309 D
Component: R4 1.5l TFS H20 9970
Revision: 8AH20000
Coding: 011900322364150830080000000000000000000000000000
ASAM Dataset: EV_ECM15TFS01105E906012 002008
ROD: EV_ECM15TFS01105E906012.rod
VCID: 5CF4437957737C6BFF-8008
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5WA 614 517 BA HW: 5WA 614 517 A
Component: ESC H09 0020
Serial number: 60280000000378a
Coding: 34FC2C9022214471527A50070AC961862DB458F042D067C0019CA231218FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 007045
ROD: EV_Brake1ESCEPBMQB37W_007_VW38.rod
VCID: 085C4F29B36BC0CB8B-805C
Address 05: Acc/Start Auth. (J518) Labels: None
Part No SW: 5WA 959 436 C HW: 5WA 959 436 C
Component: Kessy IOBOX 070 0706
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w.rod
VCID: 54E4AB593FA3B42B37-8000
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 5WA 907 727 P HW: 5WA 907 727 T
Component: Climatronic H01 0341
Coding: 002000010211120010100000111011110000131100200000000000000000
ASAM Dataset: EV_ACClimaBHBVW38X 005067
ROD: EV_ACClimaBHBVW38X_VW38.rod
VCID: 5DF24E7D4C69756388-8008
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H01 0002
Serial number: 00000000000000046620
Rear A/C control head:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
Interior temperature sensor:
Subsystem 3 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001120120192656501
131076 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
Fault Frequency: 0
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5WA 937 086 Q HW: 5WA 937 086 J
Component: BCM 37W BOSCH 016 0136
Serial number: BXJ53F240120940
ASAM Dataset: EV_BCM37w 005001
ROD: EV_BCM37w_005_VW38.rod
VCID: 5F8E7475466567739A-800A
Subsystem 1 - Part No SW: 5H1 955 119 HW: 5H1 955 119
Component: FWISCHER_MYJT 003 0041
Serial number: 907453F0401930601788
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SBY20M01D21H16M29S00
Subsystem 3 - Part No SW: 5H0 941 193 AD HW: 5H0 941 193 AD
Component: LiSi H05 0007
Serial number: 92471TB50014I
Subsystem 4 - Part No SW: 5H0 925 200 P HW: 5H0 925 200 P
Component: DiETa H06 0007
Serial number: 92471TAR0008B
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000802470
Subsystem 6 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY200100429
Subsystem 7 - Part No SW: 5H0 959 561 H HW: 5H0 959 561 H
Component: DACHKONSOLE 006 0006
Serial number: 92413TA300658-------
Steering Column Switch:
Subsystem 8 - Part No SW: 5Q1 953 507 Q HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000013012004221083
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 298 HW: 5WA 919 298
Component: PLA 12K Kanal H04 0026
Serial number: 000020121994630
Coding: 8200026001
ASAM Dataset: EV_EPHBO2CVW3800000 002027
ROD: EV_EPHBO2CVW3800000_VW38.rod
VCID: 13666845FA2D73136E-8046
1080304 - Parking Sensor(s); Rear
B107B F0 [032] - Function Limitation due to External Factors
1113328 - Parking Sensor(s); Front
B10FC F0 [032] - Function Limitation due to External Factors
[Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
1114112 - Unknown Error Code
B1AE2 00 [032] - -
[sound_ouput_parkassist_disturbed]
13688835 - Databus
U1123 00 [040] - Received Error Message
[Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 1
Mileage: 7166 km
Date: 2021.06.07
Time: 12:21:46
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 A HW: 5WA 907 572
Component: ACC Bosch MQB H10 0246
Coding: 060318F70007404512474000000040054E4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
ROD: EV_FRONTRADARBOSCHVW380_003.rod
VCID: 4CD4B339E793ECEB6F-8018
209054 - Databus
[FAULT_BV_BLINDNESS_ERROR]
Address 15: Airbags (J234) Labels:* None
Part No SW: 5WA 959 655 A HW: 5WA 959 655 A
Component: AirbagVW40 007 0523
Serial number: 000000003C0DKR6
Coding: 88CC000000C0C000000000000000000051540000205400004000F68000130065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001028
ROD: EV_AirbaVW40SMEVW38X_VW38.rod
VCID: 55E2565D3459AD23C0-8000
Subsystem 1 - Part No SW: ----------- HW: 480 402 801 20
Serial number: 3510001A532AA632857
Subsystem 2 - Part No SW: ----------- HW: 480 402 801 20
Serial number: 3520001A532BE5946172
Subsystem 3 - Part No SW: ----------- HW: 480 001 512 19
Serial number: 35700000000237A4734C
Subsystem 4 - Part No SW: ----------- HW: 480 001 301 20
Serial number: 35800000000FAA79E443
Subsystem 5 - Part No SW: ----------- HW: 480 402 001 20
Component: FrontSensor_D 001 614A
Serial number: 3550001B931DC1B597AK
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 5H0 920 340 HW: 5H0 920 340
Component: KOMBI 237 1400
Coding: 04A40000639C00080180620B2000080810300800
ASAM Dataset: EV_DashBoardVDDMQB37W 002029
ROD: EV_DashBoardVDDMQB37W_002_VW38.rod
16777018 - Control unit for information electronics 1
U1054 00 [008] - No Communication
[Audio_0x31 communication error bap_error_timeout heartbeat]
Reset counter: 214
Mileage: 6937 km
Date: 2021.05.27
Time: 06:53:51
16777020 - Control unit for information electronics 1
[TEL_0x28 communication error bap_error_timeout heartbeat]
Reset counter: 214
Mileage: 6937 km
Date: 2021.05.27
Time: 06:53:51
16777022 - Control unit for information electronics 1
[NAV_SD_0x32 communication error bap_error_timeout heartbeat]
Reset counter: 214
Mileage: 6937 km
Date: 2021.05.27
Time: 06:53:51
Part No SW: 5WA 907 530 B HW: 5WA 907 530 B
Component: GW2020 High 734 7068
Revision: -------- Serial number: 150160900046131
Coding: 0000808D0F00000000000000010301307301610900000300030100000001010000000000000000000000000000000000
ASAM Dataset: EV_GatewMQB2020 004003
ROD: EV_GatewMQB2020_VW38.rod
VCID: 47DE8C15FEF50FB342-8012
Generator:
Component: 2-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 4921023805
Subsystem 3 - Part No SW: 3G0 959 442 R HW: 3G0 959 442 R
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440066323201105
Subsystem 4 - Part No SW: 5H0 959 542 D HW: 5H0 959 542 D
Component: KLR_JSS_1Zone 076 0019
2097338 - Unknown Error Code
U1646 00 [046] - -
[Antenna_control_module_1_no_communication_vlan]
Fault Frequency: 95
Reset counter: 39
Mileage: 6761 km
Date: 2021.05.04
Time: 15:43:19
8482816 - Activatable Functions
B18D3 F4 [040] - Authentication of Transmission Failed
[Fs_id_authentification_failed]
Reset counter: 10
Mileage: 6895 km
Date: 2021.05.23
Time: 06:06:49
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 E HW: 3Q0 909 059 A
Component: EBKV H06 0092
Serial number: BPA085210120013
Coding: 1002C140730000CE39E79C73000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 011021
ROD: EV_BrakeBoostG2BoschVW37W_011_VW38.rod
VCID: 52E8AD4105B7BA1B25-8006
369232 - Control Module Improper Shut Down
U3001 00 [040] - -
Reset counter: 33
435568 - Unknown Error Code
P06B8 00 [040] - -
[Not_ShutDown_Right_NvMWriteError]
Reset counter: 32
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H08 0040
Serial number: 20000006572008
Coding: 0000000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 3228CDC165779A1B05-8066
Part No SW: 5WA 959 760 H HW: 5WA 959 760 H
Component: MEM-FS 009 0361
Serial number: 00000401299567
Coding: 01589A400000A0508803010101010000000000212100000000000000215000
VCID: 59FA5A6D58418943E4-800C
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 E HW: 2Q0 907 686 D
Component: HRE_Master H25 0284
Serial number: 00000539504627
Coding: 569945D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
ROD: EV_HREntryHellaGen3Mstr_VW38.rod
VCID: 3C34E3F9B7335C6BDF-8068
Subsystem 1 - Part No SW: 2Q0 907 685 E HW: 2Q0 907 685 D
Component: HRE_Slave H25 0284
Serial number: 00000538239704
Lane change assistance display left:
Subsystem 2 - Part No SW: 5H1 949 145 HW: 5H1 949 145
Component: SWA LED VL H05 X005
Serial number: 00000000000016909060
Lane change assistance display right:
Subsystem 3 - Part No SW: 5H1 949 146 HW: 5H1 949 146
Component: SWA LED VR H05 X005
2240562 - Databus
[databus error value received - MainUnit_01 - MIB_Tongenerator_PH_verfuegbar]
Reset counter: 39
Mileage: 7166 km
Date: 2021.06.07
Time: 12:20:32
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0330
Serial number: YE007SLB18387
Coding: 003B1220D200040000001000
VCID: 49DA8A2DE8E1F9C354-801C
Subsystem 1 - Part No SW: 5Q0 959 408 C HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000037005403
Coding: 110000
Part No SW: 5WA 907 144 G HW: 5WA 907 144 C
Component: BASGEN1MQB37 101 1040
Serial number: 00041219
Coding: 0000000000000000000102010100010000000101010101
ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
VCID: 4DD2BE3D1C89E5E378-8018
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0330
Serial number: YE007SL911173
Coding: 003B1020DE00040000801000
VCID: 48DC8F29F3EB00CB4B-801C
Subsystem 1 - Part No SW: 5Q0 959 407 C HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000036942473
Coding: 090000
Part No SW: 5H0 035 816 C HW: 5H0 035 816 A
Component: MU-O-ND-EU H56 1668
Serial number: WG8LGM190000000
Coding: 23800000000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_VW38.rod
VCID: 271E2C955EB5EFB3A2-8072
No subsystems:
Subsystem 2 - Part No SW: V03 959 804 HW: -----------
Component: EU 2019/30 --- 202
1872 - Unknown Error Code
B1994 F4 [008] - Unknown Error Elaboration
[a2b_bus_micro_defect]
Reset counter: 18
Mileage: 6861 km
Date: 2021.05.17
Time: 22:42:03
Voltage terminal 30: 14.5 V
amount_of_nodes: 2
Node number: 1
Node name: Emergency call module and communication unit
Node status: OK
Part No SW: 5WA 035 284 A HW: 5WA 035 284 A
Component: OCU3HMQB37W H12 0067
Serial number: 0000000001VIRG8
Coding: 023800009068A8209405460071502E07
ASAM Dataset: EV_OCU3HMQB37W 001039
ROD: EV_OCU3HMQB37W_001_VW38.rod
VCID: 44C49B19CFC324ABA7-8010
0080 - Databus
[Ethernet Databus missing message - Transceiverbox]
Reset counter: 39
Mileage: 6950 km
Date: 2021.05.28
Time: 11:38:22
Voltage terminal 30: 12.6 V
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 5H1 919 608 HW: 5H1 919 608
Component: HeadupDisplay H15 0027
Coding: 5740C0
ASAM Dataset: EV_HeadUpDisplMQB37W 001017
ROD: EV_HeadUpDisplMQB37W.rod
VCID: 6FAE04B5B6C5F7F32A-803A
13894400 - Function limitation due to excessive temperature
B1050 00 [009] - -
[ECU_function_restriction_overtemperature]
Mileage: 7169 km
Date: 2021.06.07
Time: 14:56:04
16777040 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[NAV_0x32_communication_error_bap_error_timeout_heartbeat]
Reset counter: 28
Mileage: 6937 km
Date: 2021.05.27
Time: 06:53:51
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 5WA 980 653 A HW: 5WA 980 653
Component: MQB MFK 3.0 H05 3129
Serial number: E26735111200350
Coding: 00000888216CC040109E00001020002000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_VW38.rod
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 6582669D64393DA350-8030
Component: LED1R H08 9202
Address 8107: Antenna (J666) Labels:* None
Part No SW: 5WA 035 741 B HW: 5WA 035 741 B
Component: TrxModulHigh H10 0078
Serial number: 0000000002VIWP1
Coding: 02380011040080
ASAM Dataset: EV_TrxMLGEMQB37W 005006
ROD: EV_TrxMLGEMQB37W.rod
VCID: 43C69805CACD23939E-8016
Address 811E: Burglary Protection FL (J518) Labels: None
Part No SW: 5WA 962 133 B HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w.rod
Address 811F: Burglary Protection FR (J518) Labels: None
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w.rod
Address 8120: Burglary Protection RL (J518) Labels: None
ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518) Labels: None
ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 01:32, VBatt start/end: 14.0V/14.0V)-----------
