1.4 TSI CZC Knock Sensor fault
Blanco92
C?ID=64435
Hi all,
I have a 2017 Scirocco with G61 knock sensor fault that keeps coming back. I have changed the sensor but this made no difference.
I'm now suspecting a wiring fault. I did a brief bit of logging; would these voltage values be considered "too low?" I have no reference to what the voltage should be.
Logs
Does anybody know the pin/wire colour I need to check on the ECU side?
I've also read some comments by Dana about MAP sensor faults can cause false knock errors on Golf V-based cars. I have one on order as this car was involved in a light front accident, and when I got the car the MAP sensor was lying disconnected in the engine bay. A lot of the plastic on the intake had shattered so I'm guessing the sensor got dislodged and smashed itself around the bay for a brief moment. It looks fine but who knows...
Thursday,03,June,2021,20:32:19:32646
VCDS Version: 21.3.0.0 (x64)
VIN: WVWZZZ13ZHV009553   License Plate:
Mileage:    Repair Order: 20210603_KNOCK
                Address 01: Engine       Labels: 04E-907-309-V1.clb
Control Module Part Number: 04E 906 027 AF    HW: 04E 907 309 AE
  Component and/or Version: R4 1.4l TFS   H24 9232
           Software Coding: 00190032232401080000
            Work Shop Code: WSC 00020 999 00000
              ASAM Dataset: EV_ECM14TFS01104E906027AF 001009 (VW36)
                       ROD: EV_ECM14TFS01104E906027AF.rod
                      VCID: 68DF6C6C930C5DCB6B-803C
4586 - Knock Sensor 1 (G61)
          P0327 00 [039] - Signal too Low
                    Mileage: 51315 km
                    Date: 2046.14.03
                    Time: 00:03:13
                    Engine RPM: 1067.50 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 42 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 12.439 V
                    Outside temperature: 18 °C
                    Absolute intake pressure: 26 kPa abs
                    Engine torque: 20.6 Nm
                    Fuel level: 22.00 l
                    Oxygen sensor B1: sensor 1: specified value: 1.6563
                    Intake camshaft B1 active operating state-Bits 0-7: 0
                    Intake camshaft B1 active operating state-Bits 0-7: 1
                    Overrun cut-off-Bits 0-7: 0
Readiness: 1110 0001
                Address 01: Engine  (04E 906 027 AF)
20:35:20
  IDE01098   Test of knock sensors: short trip result Test off
  IDE01098-ENG127299   Test of knock sensors: short trip result-Test_Program_Channel 165 235
  IDE03692-ENG57549   Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7 136
  IDE06192   Knock sensor: cylinder 2: voltage 1.074 V
  IDE06193   Knock sensor: cylinder 3: voltage 1.064 V
  IDE06194   Knock sensor: cylinder 4: voltage 0.913 V
  IDE06195   Knock sensor: cylinder 1: voltage 0.923 V
Blanco92
C?ID=64435
Issue resolved, it was wiring.
With the help of a diagram from Erwin I decided to check the 2 wires from G61 to ECU (yellow to pin 55, green to pin 56). At this point I found damaged wires that were hidden by a black cable sleeving.
