Hi all,
I'm trying to complete a cruise control retrofit on my 2017 Scirocco 1.4 TSI GT BMT. My steering module is 5K0-953-569-BF and so I believe is cruise compatible according to Ross-Tech table. I have bought and fitted used combi stalks from a Skoda Yeti, p/n 5K0-953-521-GF.
I then adjusted the coding using longcoding helper:
Address 01 - selected “20-Cruise Control System (CCS) installed”
Address 16 - selected “10-Cruise Control controlled via Turn Signal Lever"
The turn signal function appears to be fine, but the MFD shows an exclamation mark, the cruise doesn't work and I have the following DTC:
226838 - Turn Signal Switch
B1144 12 [009] - Short to Plus
Reset counter: 171
Mileage: 51315 km
Date: 2021.05.24
Time: 14:47:34
When I revert the coding back to standard, the DTC goes away. Autoscan attached.
If anyone can advise what the problem might be and what I should do next, it would be greatly appreciated.
Cheers
Chris
Reset counter: 171
Mileage: 51315 km
Date: 2021.05.24
Time: 14:47:34
Cheers
Chris
Thursday,03,June,2021,17:04:46:32646
VCDS Version: 21.3.0.0 (x64)
VIN: WVWZZZ13ZHV009553 License Plate: FN67YHX
Mileage: 51310km-31882mi Repair Order: 20210603
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61 B9
VIN: WVWZZZ13ZHV009553 Mileage: 51310km-31882miles
B9-Aux. Display -- Status: OK 0000
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 AF HW: 04E 907 309 AE
Component: R4 1.4l TFS H24 9232
Revision: R9H24---
Coding: 00190032232401080000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM14TFS01104E906027AF 001009
ROD: EV_ECM14TFS01104E906027AF.rod
VCID: 68DF6C6C930C5DCB6B-803C
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Mileage: 51315 km
Date: 2021.05.30
Time: 11:23:08
Engine RPM: 762.00 /min
Normed load value: 23.9 %
Coolant temperature: 51 °C
Intake air temperature: 21 °C
Voltage terminal 30: 11.803 V
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status-Bits 0-7: 8
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System (CCS): switch position-Bits 0-7: 0
4584 - Knock Sensor 1 (G61)
P0327 00 [101] - Signal too Low
Mileage: 51315 km
Date: 2021.06.02
Time: 08:35:41
Engine RPM: 1081.50 /min
Normed load value: 18.8 %
Vehicle speed: 4 km/h
Coolant temperature: 24 °C
Intake air temperature: 16 °C
Voltage terminal 30: 14.771 V
Outside temperature: 17 °C
Absolute intake pressure: 28 kPa abs
Engine torque: 22.7 Nm
Fuel level: 24.00 l
Oxygen sensor B1: sensor 1: specified value: 0.9851
Intake camshaft B1 active operating state-Bits 0-7: 0
Intake camshaft B1 active operating state-Bits 0-7: 1
Overrun cut-off-Bits 0-7: 0
4586 - Knock Sensor 1 (G61)
Mileage: 51315 km
Date: 2021.05.30
Time: 11:20:11
Engine RPM: 795.50 /min
Normed load value: 65.9 %
Coolant temperature: 46 °C
Intake air temperature: 19 °C
Voltage terminal 30: 13.169 V
Outside temperature: 18 °C
Absolute intake pressure: 101 kPa abs
Engine torque: 129.0 Nm
Fuel level: 24.00 l
Oxygen sensor B1: sensor 1: specified value: 1.0000
Readiness: 1110 0001
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: 763B40F5492200036E1002E9921C0090A1000051
Shop #: WSC 00020 790 00000
VCID: 75E13518DCBEB023E0-8020
Reset counter: 171
Mileage: 51315 km
Date: 2021.06.01
Time: 00:00:40
Count: 2
Count: 2
Count: 28672
Count: 297
Count: 42240
Count: 4
Reset counter: 171
Mileage: 51315 km
Date: 2021.06.01
Time: 00:00:50
Count: 2
Count: 2
Count: 28672
Count: 16390
Count: 42496
Count: 4
Part No SW: 1K8 907 044 CD HW: 1K8 907 044 CD
Component: Climatronic H08 0405
Revision: 00001K05
Coding: 001000C003
VCID: 73E50B00DACAAE13CE-8026
B10AB F0 [009] - Too Low
Reset counter: 171
Mileage: 51315 km
Date: 2021.05.30
Time: 11:09:36
Part No SW: 5K0 937 086 T HW: 5K0 937 086 T
Component: BCM PQ35 M 122 0186
Revision: BC122001
Coding: 48180A3C8825E100408800C0340001640BD1D408436D0920648087000041
VCID: 458185D8CCDE60A3B0-8010
Subsystem 1 - Part No SW: 1K8 955 119 J HW: 1K8 955 119 J Labels: 1KX-955-119.CLB
Component: WWS364 140117 24 0654
Coding: 044D9D
Component: RLS 270417 05 54 0403
Coding: 0230ED
Subsystem 3 - Part No: 5C0 951 171
Component: Sensor, DWA 0 005 0502
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 171
Mileage: 51315 km
Date: 2021.05.30
Time: 11:26:21
Term 15 On
Voltage: 11.90 V
Reset counter: 171
Mileage: 51315 km
Date: 2021.05.30
Time: 11:26:21
Term 15 On
Voltage: 11.90 V
Reset counter: 171
Mileage: 51315 km
Date: 2021.05.30
Time: 11:26:21
Term 15 On
Voltage: 11.90 V
Reset counter: 171
Mileage: 51315 km
Date: 2021.05.30
Time: 11:26:21
Term 15 On
Voltage: 11.90 V
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331711600514
Coding: 0031051001
ASAM Dataset: EV_EPHVA18VW364GP00 001007
VCID: 377DFF108E32023332-8062
B10FC 13 [009] - Open Circuit
Reset counter: 171
Mileage: 51315 km
Date: 2021.05.30
Time: 11:09:35
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0H AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1C00HXMF
Coding: 0012360
VCID: 6FED07707EE28AF32A-803A
Subsystem 1 - Serial number: 6332MSME5C6E3706O
Subsystem 2 - Serial number: 6342MSME5C5C557CZ
Subsystem 3 - Serial number: 6352QSME17712674C
Subsystem 4 - Serial number: 6362QSME147131746
Part No SW: 5K0 953 521 GE HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20170425100083
Coding: 1082140000
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 75E13518D4BEB023E0-8020
Subsystem 1 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H04 0103
Serial number: 29170000635220097173
Coding: A4FFFF
B1144 12 [008] - Short to Plus
Reset counter: 211
Mileage: 51315 km
Date: 2021.05.30
Time: 11:23:08
Part No SW: 1K8 920 975 J HW: 1K8 920 975 J
Component: KOMBI H02 1107
Coding: 410B010000
VCID: 3E73EA34A108337BF1-806A
Part No SW: 7N0 907 530 BJ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1682
Revision: H58 Serial number: 220417F1000020
Coding: 354031
VCID: 79F93928F0A6D44384-802C
Component: IMMO H02 1107
VCID: 6ADB16648D006FDB7D-803E
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2162
Coding: 0152119
VCID: 3979F92870261443C4-806C
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 68 3501
Revision: 00H22000
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0152374
VCID: 3A7BE62475201F5BCD-806E
Part No SW: 5C0 035 680 E HW: 5C0 035 680 E
Component: MU-S-ND-ER H32 0363
Serial number: VWZAZ2T5196233
Coding: 02630401FF00000011111101008808001F0100C600200100CF
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 23453B402AAA7E93FE-8076
Data carrier:
Subsystem 1 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1682
Coding: 032F7857
VCID: 71E90108A8D69C033C-8024
Subsystem 1 - Part No SW: 1K0 915 181 L HW: 1K0 915 181 L
Component: J367-BDM H07 0270
Serial number: 34117A12065831409425
Address B9: Aux. Display (J285) Labels:* 5C5-919-527.clb
Part No SW: 1K8 919 527 D HW: 1K8 919 527 D
Component: ZUSATZANZEIGE H01 0013
Coding: 05
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
VCID: 3979F928B8261443C4-806C
End-------------------------(Elapsed Time: 02:46)--------------------------
