PQ35 2017 VW Scirocco - Cruise control retrofit help
Blanco92
C?ID=64435
Hi all,
I'm trying to complete a cruise control retrofit on my 2017 Scirocco 1.4 TSI GT BMT. My steering module is 5K0-953-569-BF and so I believe is cruise compatible according to Ross-Tech table. I have bought and fitted used combi stalks from a Skoda Yeti, p/n 5K0-953-521-GF.
I then adjusted the coding using longcoding helper:
Address 01 - selected “20-Cruise Control System (CCS) installed”
Address 16 - selected “10-Cruise Control controlled via Turn Signal Lever"
The turn signal function appears to be fine, but the MFD shows an exclamation mark, the cruise doesn't work and I have the following DTC:
226838 - Turn Signal Switch
B1144 12 [009] - Short to Plus
Reset counter: 171
Mileage: 51315 km
Date: 2021.05.24
Time: 14:47:34
When I revert the coding back to standard, the DTC goes away. Autoscan attached.
If anyone can advise what the problem might be and what I should do next, it would be greatly appreciated.
Cheers
Chris
Thursday,03,June,2021,17:04:46:32646
VCDS Version: 21.3.0.0 (x64)
VIN: WVWZZZ13ZHV009553   License Plate: FN67YHX
Mileage: 51310km-31882mi   Repair Order: 20210603
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61 B9
VIN: WVWZZZ13ZHV009553   Mileage: 51310km-31882miles
B9-Aux. Display -- Status: OK 0000
Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 AF    HW: 04E 907 309 AE
   Component: R4 1.4l TFS   H24 9232
   Revision: R9H24---
   Coding: 00190032232401080000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM14TFS01104E906027AF 001009
   ROD: EV_ECM14TFS01104E906027AF.rod
   VCID: 68DF6C6C930C5DCB6B-803C
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
                    Mileage: 51315 km
                    Date: 2021.05.30
                    Time: 11:23:08
                    Engine RPM: 762.00 /min
                    Normed load value: 23.9 %
                    Coolant temperature: 51 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.803 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 8
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System (CCS): switch position-Bits 0-7: 0
4584 - Knock Sensor 1 (G61)
          P0327 00 [101] - Signal too Low
                    Mileage: 51315 km
                    Date: 2021.06.02
                    Time: 08:35:41
                    Engine RPM: 1081.50 /min
                    Normed load value: 18.8 %
                    Vehicle speed: 4 km/h
                    Coolant temperature: 24 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 14.771 V
                    Outside temperature: 17 °C
                    Absolute intake pressure: 28 kPa abs
                    Engine torque: 22.7 Nm
                    Fuel level: 24.00 l
                    Oxygen sensor B1: sensor 1: specified value: 0.9851
                    Intake camshaft B1 active operating state-Bits 0-7: 0
                    Intake camshaft B1 active operating state-Bits 0-7: 1
                    Overrun cut-off-Bits 0-7: 0
4586 - Knock Sensor 1 (G61)
                    Mileage: 51315 km
                    Date: 2021.05.30
                    Time: 11:20:11
                    Engine RPM: 795.50 /min
                    Normed load value: 65.9 %
                    Coolant temperature: 46 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 13.169 V
                    Outside temperature: 18 °C
                    Absolute intake pressure: 101 kPa abs
                    Engine torque: 129.0 Nm
                    Fuel level: 24.00 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
Readiness: 1110 0001
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: 763B40F5492200036E1002E9921C0090A1000051
   Shop #: WSC 00020 790 00000
   VCID: 75E13518DCBEB023E0-8020
                    Reset counter: 171
                    Mileage: 51315 km
                    Date: 2021.06.01
                    Time: 00:00:40
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 297
                    Count: 42240
                    Count: 4
                    Reset counter: 171
                    Mileage: 51315 km
                    Date: 2021.06.01
                    Time: 00:00:50
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 16390
                    Count: 42496
                    Count: 4
   Part No SW: 1K8 907 044 CD    HW: 1K8 907 044 CD
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 001000C003
   VCID: 73E50B00DACAAE13CE-8026
          B10AB F0 [009] - Too Low
                    Reset counter: 171
                    Mileage: 51315 km
                    Date: 2021.05.30
                    Time: 11:09:36
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0186
   Revision: BC122001
   Coding: 48180A3C8825E100408800C0340001640BD1D408436D0920648087000041
   VCID: 458185D8CCDE60A3B0-8010
   Subsystem 1 - Part No SW: 1K8 955 119 J    HW: 1K8 955 119 J  Labels: 1KX-955-119.CLB
   Component: WWS364 140117  24  0654
   Coding: 044D9D
   Component: RLS 270417 05  54  0403
   Coding: 0230ED
   Subsystem 3 - Part No: 5C0 951 171
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 171
                    Mileage: 51315 km
                    Date: 2021.05.30
                    Time: 11:26:21
                    Voltage: 11.90 V
                    Reset counter: 171
                    Mileage: 51315 km
                    Date: 2021.05.30
                    Time: 11:26:21
                    Voltage: 11.90 V
                    Reset counter: 171
                    Mileage: 51315 km
                    Date: 2021.05.30
                    Time: 11:26:21
                    Voltage: 11.90 V
                    Reset counter: 171
                    Mileage: 51315 km
                    Date: 2021.05.30
                    Time: 11:26:21
                    Voltage: 11.90 V
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331711600514
   Coding: 0031051001
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 377DFF108E32023332-8062
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Reset counter: 171
                    Mileage: 51315 km
                    Date: 2021.05.30
                    Time: 11:09:35
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1C00HXMF
   Coding: 0012360
   VCID: 6FED07707EE28AF32A-803A
   Subsystem 1 - Serial number: 6332MSME5C6E3706O
   Subsystem 2 - Serial number: 6342MSME5C5C557CZ
   Subsystem 3 - Serial number: 6352QSME17712674C
   Subsystem 4 - Serial number: 6362QSME147131746
   Part No SW: 5K0 953 521 GE    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20170425100083
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 75E13518D4BEB023E0-8020
   Subsystem 1 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29170000635220097173
   Coding: A4FFFF
          B1144 12 [008] - Short to Plus
                    Reset counter: 211
                    Mileage: 51315 km
                    Date: 2021.05.30
                    Time: 11:23:08
   Part No SW: 1K8 920 975 J    HW: 1K8 920 975 J
   Component: KOMBI         H02 1107
   Coding: 410B010000
   VCID: 3E73EA34A108337BF1-806A
   Part No SW: 7N0 907 530 BJ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1682
   Revision:   H58       Serial number: 220417F1000020
   Coding: 354031
   VCID: 79F93928F0A6D44384-802C
   Component: IMMO          H02 1107
   VCID: 6ADB16648D006FDB7D-803E
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2162
   Coding: 0152119
   VCID: 3979F92870261443C4-806C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 68     3501
   Revision: 00H22000
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0152374
   VCID: 3A7BE62475201F5BCD-806E
   Part No SW: 5C0 035 680 E    HW: 5C0 035 680 E
   Component: MU-S-ND-ER    H32 0363
   Serial number: VWZAZ2T5196233
   Coding: 02630401FF00000011111101008808001F0100C600200100CF
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 23453B402AAA7E93FE-8076
   Subsystem 1 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
   Component: Batt.regelung H58 1682
   Coding: 032F7857
   VCID: 71E90108A8D69C033C-8024
   Subsystem 1 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 34117A12065831409425
Address B9: Aux. Display (J285)       Labels:* 5C5-919-527.clb
   Part No SW: 1K8 919 527 D    HW: 1K8 919 527 D
   Component: ZUSATZANZEIGE H01 0013
   Coding: 05
   ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
   ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
   VCID: 3979F928B8261443C4-806C
End-------------------------(Elapsed Time: 02:46)--------------------------
m87a
Bosnia and Herzegovina
C?ID=156900
have you considered that stalk could be defective?
sometimes if you open it and clean slider it will work.
Blanco92
C?ID=64435
Thanks for the info. I will try that. In the meantime, is there a way to verify the switch functions? I took some logs and can see some values changing.
In 16-Steering Wheel, go to [Adv. Meas. Values] and type 'Cruise' (without the quotes) into the Search/Filter box. This will give you a list of relevant things you can look at there, including one for each of the individual switches. You should be able to see those change as you actuate them.
Right, I'm not so sure the ones in his above dropbox log are ideal. I don't have a Mk6 based car handy but my mom's Tiggy data may be helpful:
She has the 12 button typical MK6 wheel on that vehicle and it was factory equipped with (wiper stalk type) CCS.
Blanco92
C?ID=64435
Guys, can anyone help as I'm pulling my hair out.
- I have tried a second used cruise/indicator combo stalk - same problem.
- I have verified the white/black wire from SWCM/J527 to ECU/J623 physically exists; and it has continuity.
Ref attached session. After checking the above, I cleared all codes, deactivated cruise and then went through the activation process again following the guidance to the letter. First address 16, then 01.
Saturday,31,July,2021,18:17:24:32646
VIN: WVWZZZ13ZHV009553   License Plate: W9CPB
Mileage: 51630km-32081mi   Repair Order: 20210731
VIN: WVWZZZ13ZHV009553   Mileage: 51630km-32081miles
B9-Aux. Display -- Status: Malfunction 0010
   Revision: R9H24---
   Coding: 00190032232401000000
          U1113 00 [032] - -
                    Mileage: 51610 km
                    Date: 2021.07.30
                    Time: 19:54:14
                    Engine RPM: 0.00 /min
                    Coolant temperature: 57 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 12.274 V
                    Cruise Control System (CCS): status-Bits 0-7: 200
                    Cruise Control System (CCS): switch position-Bits 0-7: 64
Readiness: 0000 0001
   Revision: 00H46001
                    Reset counter: 198
                    Mileage: 51637 km
                    Date: 2021.07.31
                    Time: 00:05:16
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 297
                    Count: 43520
                    Count: 65024
                    Reset counter: 198
                    Mileage: 51637 km
                    Date: 2021.07.31
                    Time: 00:05:26
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 16390
                    Count: 43776
                    Count: 65024
   Revision: 00001K05
   Coding: 001000C003
   Revision: BC122001
   Coding: 48180A3C8833E100408800C0340001E40FD1D408436D0920648087000041
   Shop #: WSC 00020 790 12345
   Coding: 044D9D
   Coding: 0230ED
                    Fault Status: 00101010
                    Reset counter: 238
                    Mileage: 51570 km
                    Date: 2021.07.30
                    Time: 15:33:08
                    Voltage: 11.90 V
   Coding: 0031051001
   Coding: 0012360
   Coding: 1082140000
   Coding: A4FFFF
                    Reset counter: 235
                    Mileage: 51610 km
                    Date: 2021.07.30
                    Time: 19:51:42
   Coding: 110B010000
   Shop #: WSC 00020 999 12345
   Coding: 354031
   Coding: 0152119
   Revision: 00H22000
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.2 V
                        PD
                    Temperature: 24.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Coding: 0152374
   Coding: 032F7857
   Coding: 05
2097157 - Databus
                    Reset counter: 195
                    Mileage: 51610 km
                    Date: 2021.07.30
                    Time: 19:30:20
End-------------------------(Elapsed Time: 02:49)--------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 09: DTCs cleared
Address 16: DTCs cleared
Address B9: DTCs cleared
   Revision: R9H24---
   Revision: 00H46001
   Revision: 00001K05
   Coding: 001000C003
   Revision: BC122001
   Coding: 044D9D
   Coding: 0230ED
   Coding: 0031051001
   Coding: 0012360
   Coding: 1082140000
   Coding: A4FFFF
   Coding: 110B010000
   Coding: 354031
   Coding: 0152119
   Revision: 00H22000
   Coding: 0152374
   Coding: 032F7857
   Coding: 05
2097157 - Databus
                    Reset counter: 198
                    Mileage: 51637 km
                    Date: 2021.07.31
                    Time: 00:11:28
End-------------------------(Elapsed Time: 02:40)--------------------------
Address 16,5K0 953 521 GE,recoded (Long Coding),from,1082140000,to,1082040000,(00020/999/00000),
Address 01,04E 906 027 AF,recoded (Long Coding),from,00190032232401000000,to,00190032230401000000,(00020/999/00000),
Address 16,5K0 953 521 GE,recoded (Long Coding),from,1082040000,to,1082140000,(00020/999/00000),
Address 01,04E 906 027 AF,recoded (Long Coding),from,00190032230401000000,to,00190032232401000000,(00020/999/00000),
                Address 01: Engine       Labels: 04E-907-309-V1.clb
Control Module Part Number: 04E 906 027 AF    HW: 04E 907 309 AE
  Component and/or Version: R4 1.4l TFS   H24 9232
           Software Coding: 00190032232401000000
            Work Shop Code: WSC 00020 999 00000
              ASAM Dataset: EV_ECM14TFS01104E906027AF 001009 (VW36)
4482 - Function Restriction due to Implausible Message(s)
          U1112 00 [038] - -
                    Mileage: 51637 km
                    Date: 2021.07.31
                    Time: 00:24:25
                    Coolant temperature: 66 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 12.321 V
4714 - Steering Column Control Module
          U0212 00 [038] - No Communications
                    Mileage: 51637 km
                    Date: 2021.07.31
                    Time: 00:24:25
                    Voltage terminal 30: 12.298 V
                    Outside temperature: 21 °C
                    Absolute intake pressure: 100 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 15.00 l
                Address 16: Steering wheel       Labels: 5K0-953-569.clb
Control Module Part Number: 5K0 953 521 GE    HW: 5K0 953 569 BF
  Component and/or Version: LENKS.MODUL   018 0230
           Software Coding: 1082140000
              ASAM Dataset: EV_SMLSNGVOLWSR8C 001001 (VW36)
                    Reset counter: 199
                    Mileage: 51637 km
                    Date: 2021.07.31
                    Time: 00:46:33
You see from these logs that no problem is known until the cruise stalk is switched from OFF to ON. At no point do any of the RES, SET etc buttons work in Adv MB. At this point the 226838 is also triggered.
Has anyone got proof that 5K0-953-569-BF is CCS compatible? And if so, could it be that it only supports CCS via MSFW, as opposed to the combo stalk? I have MSFW but no cruise buttons.
Also my combo stalks (both of them, I have 2) are from a Skoda. They couldn't possibly work differently to VW stalks, could they?
Spacewalker
Poland
C?ID=159607
if module not support CCS for example, coding will be reject
if your accept coding = support
1st - put back old stalk without CCS, disable CCS from coding in 16th -and check if there is a error regarding turn signal swich
also check if measure block see proper LEFT / right signal indicator enable
then you can do this same with new one
hovewer I think somebody open them and not proper put a spring switch inside, that is why.
It must working like that - for example.
when is middle - 2-2 pin connected
when is LEFT - 1-2 is connect
whel is Right - 2-1 is connect
Can not be open circuit if in middle
you can simple take a multimerter and start compare white socket connection with faulty stalk
but this same you can measure in MB
Blanco92
C?ID=64435
Hi all - just to update, my problems are (finally solved). Stalk based CCS now fully working. In case it helps others in future, here is the resolution/my findings:
It turned out the stalks work fine...
This is not true. Not on facelift PQ35 Scirocco anyway.
The problem was my original slip ring 5K0-957-569-BF does not support CCS (or not stalk-based, anyway). This is why I was getting error codes when a CCS stalk was installed, despite coding being accepted. It does however support MFSW. Whether it supports MFSW based cruise on other cars, I just don't know.
With a new slip ring CCS works as expected. Note for future readers - facelift Scirocco (2015-2018 here in UK & Europe) is very picky about slip ring p/n compared to the earlier cars. Only the following SWCMs will work (according to retrofit shops with ETKA): 5K0-959-569-H & 5K0-959-569-AL.
@Dana you might consider an update to the Steering Wheel Control Module Versions page.
Merry Christmas all!
OK, I think the facelift is relevant. Most of those cars (on our side of the pond) have the MQB style steering wheel. Here's a random 2016 Jetta with HW# 5K0 953 569 BF and 6C0 959 442 C (Mk7 style) slave:
At a glance most of the 183 HW# 5K0 953 569 BF search results in our files end in HEX 08 (that's the MFSW for MQB platform coding bit) but a select few have 00 without CCS enabled using this exact SW# 5K0 953 521 GE.
At the very least that Wiki page needs a *note indicating MQB wheel only but I'll dig into those alternative part numbers before I edit it. In the meanwhile, if you happen to have a final scan please post it!
Best,
Edit, a photo of the factory steering wheel buttons woudl be helpful as well!
Random notes here. 5K0-953-569-BF supers to 5K0-953-569-BC. BC doesn't support CCS per our chart, so that confirms the issue, but we have scans that have it combined with the MQB platform coding bit enabled. For this reason I believe BC needs edited on the Wiki as well.
I'm beginning to think the Wiki might need an entire column dedicated to newer wheels -or- a separation of the chart?​
Changelog of the edits today: http://wiki.ross-tech.com/wiki/inde...e_Versions&type=revision&diff=9215&oldid=8967
Time permitting a photo of the wheel with 1K8 959 442 slave and final scan woudl be excellent but the feedback is highly appreciated. This should save the next guy a lot of time.
Blanco92
C?ID=64435
Here's a photo of the standard wheel. 12 buttons and red illumination.
20211224_163408
by Chris B, on Flickr
I will follow up with a final scan in a few days, unfortunately me and my Ross-Tech cable are separated by some 200 miles just now.
I think this was the crucial aspect, the BF HW may support cruise but that GE SW# is where the party stops.
I actually have another wheel, 6C0-419-091 from a Polo, this includes CCS buttons. When fitted before, all MFSW buttons worked except cruise. I suppose that makes sense if the 5K0-953-569-BF is not cruise compatible? I'm tempted to try this wheel again mated to the new SWCM/slip ring SW and see if the cruise buttons begin to function.
vastechnics
C?ID=143747
BF only sipport on steering wheel. Use CNL huttons from polo 6c and all solved.
Blanco92
C?ID=64435
Here's the autoscan post stalk-based CCS retrofit. Seems that the new slip ring has the same SW but is different p/n, which goes against what I said a couple of posts ago. I can only conclude that 5K0 953 569 BF does not support stalk-based CCS whereas 5K0 953 569 BG (new slip ring/SWCM) does on PQ platform.
Wednesday,29,December,2021,17:21:34:30325
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
Mileage: 58930km-36617mi   Repair Order: 20211229
VIN: WVWZZZ13ZHV009553   Mileage: 58930km-36617miles
   Revision: R9H24---    CVN: DB5930B9
   Shop #: WSC 12345 123 61029
   VCID: 6889B9BEF2F4BC1B0F1-803C
   VINID: 9E69EAAAA043A989800091450C1E763E3B
   Revision: 00H46001
   VCID: 75B7E0CAB5C651F3847-8020
   Revision: 00001K05
   Coding: 001000C003
   VCID: 73B3DED2BB324FC3AA3-8026
   Revision: BC122001
   Coding: 40180A3CC82BE100408800C0340001E40FD9D408437D09206480C7000041
   VCID: 45D7500AA5A68173D47-8010
   Coding: 044D9D
   Coding: 0230ED
                    Reset counter: 206
                    Mileage: 58118 km
                    Date: 2021.12.22
                    Time: 00:48:26
                        Term 15 Off
                    Voltage: 12.70 V
                    Reset counter: 252
                    Mileage: 58118 km
                    Date: 2021.12.22
                    Time: 09:59:53
                    Voltage: 12.00 V
   Coding: 0031051001
   VCID: 372B2AC2EFCAE3E356B-8062
   Coding: 0012360
   VCID: 6FBBD2A2DB9A6B234EB-803A
   Part No SW: 5K0 953 521 GP    HW: 5K0 953 569 BG
   Revision: FF010042    Serial number: 20160115200057
   Coding: 108A140000
   VCID: 0059811EFA84645BA71-8054
   Coding: A4FFFF
   Coding: 110B010000
   VCID: 3E253FE6C0F0D2AB95D-806A
   Coding: 354031
   VCID: 79AFECFA99DE3593E0F-802C
   VCID: 6A8DC3B6ECF88E0B195-803E
   Coding: 0152119
   VCID: 392F2CFAD55EF593A0F-806C
   Revision: 00H22000
   Coding: 0152374
   VCID: 3A2D33F6D058FE8BA95-806E
   Coding: 02630401FF00000011111101008808001F0107C600200100CF
   VCID: 2313EE924B529F439A3-8076
   Subsystem 1 - Part No SW: 5NA 919 866 BH    HW: -----------
   Component: ECE1 2022  --- 1730
   Coding: 032F7857
   VCID: 71BFD4DAC1AE7DD358F-8024
   Coding: 05
   VCID: 392F2CFAD9DEF593A0F-806C
2097157 - Databus
          [Control unit for engine: please read out error memory oil temperature]
                    Reset counter: 202
                    Mileage: 58117 km
                    Date: 2021.12.22
                    Time: 00:38:26
End----------(Elapsed Time: 01:15, VBatt start/end: 11.9V/12.0V)-----------
Hi. You mean like this wheel?
20211221_200036
vastechnics
C?ID=143747
Depends on the Part No. If from MK7 then won't work need from Polo 6C if need GTI steering wheel. Can use from polo 6C gti
MikeMack
C?ID=509388
Hi all, just wanted to say thanks as this thread has been a great help for fitting a cruise control stalk on my 17 Scirocco today.
It originally had the 5K0-953-569-BC SWCM but I swapped that out for the 5K0-953-569-H and 5K0-953-921-BN stalks and everything is working as it should :thumbs:
I had a 2009 Scirocco previously and changed the stalk on that too - but that one was the good old days of being able to change just the stalk.
Wasn't much more work this time round, just a bit more cash on needing to change the SWCM
