Golf 7 side assist retrofit
   #41
downtime
Finland
C?ID=280813
Of course official way cannot parameterize it because your car was not equipped with AJ from factory. You need other tools for this.
Function restore naturally works but you don’t need to do it.
The functions don’t work because invalid dataset
   #42
myounus
Northwest UK
C?ID=321059
FEC restore is done with SVM. It compares the car with the database and matches it.
   #43
sers77
Norway
C?ID=26140
Ok, so ODIS cannot do this?
Hoping VCP can, then :confused:
   #44
downtime
Finland
C?ID=280813
Yes, that can :)
   #45
sers77
Norway
C?ID=26140
Updated Gateway to AJ and wrote ZDC files with VCP..
All working well, until next retrofit :facepalm:
Thanks for all the good support :thumbs:
Saturday,24,July,2021,10:01:33:21522
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4544.4
Workshop Code: 666 12345 045678
VIN: WVWZZZAUZEW111212   License Plate: PIPPIRULL2.0
Mileage: 100921km-62709mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
          69 A5
VIN: WVWZZZAUZEW111212   Mileage: 100921km-62709miles
Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
   Component: R4 1.4l TFS   H02 9225
   Revision: WKH02---
   Coding: 0125003A247405083000
   Shop #: WSC 61962 003 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
   ROD: EV_ECM14TFS01104E906016AD.rod
   VCID: E4840921EF0F2DABC7-80B0
Readiness: 1110 0001
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5240
   Revision: 00043014    Serial number: CU501308185463
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: F6A043694993AF3B69-80A2
   Revision: 00000000    Serial number: 61136000001318
   Coding: 01FA6AA12421116D0779060141C52980562488E0608294F33822506890A2
   Shop #: WSC 12345 666 45678
   VCID: FAB857597D8BCB5B0D-80AE
   Revision: 00021000    Serial number: 0194304581
   Coding: 030C1C
   VCID: BA3897593D0B0B5B4D-80EE
   Part No SW: 5G0 907 044 AB    HW: 5G0 907 044 AB
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00020004204101011105004000101000
   VCID: E79E1E2D1E3946B3E2-80B2
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011324200143
   Coding: 00031E46C24122FB4BE44000001C07081C0A000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: F7BE4E6D4E99D63372-80A2
   Component: WWS    130811  042 0551
   Serial number:         130820192717
   Coding: 0E4DFD
   Component: RLFS  024 0042
   Serial number: Y13M09D03H00M40S31S1
   Coding: 06A8DD
   Part No SW: 5QA 919 298 E    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0452
   Serial number: 000308417617305
   Coding: 0251065951
   ASAM Dataset: EV_EPHVA2CAU3700000 009038
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: D2E8DFF985BBD31BA5-8086
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H03 0141
   Serial number: 12071376510039
   Coding: 001C1D00FE033B
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: B52284651415E423A0-80E0
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR005HKT
   Coding: 98FCC0C0000000005C5400CF004800000065
   VCID: FF4EA64D66A9EE733A-80AA
   Left seat belt tensioner:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667B05091371397
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668B06091350561
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 357670000008CC597D08
   Subsystem 4 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 35867000000AE2488D02
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3516502B71088B1140F3
   Subsystem 6 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3526502A71088B1101B$
   Subsystem 7 - Part No SW: -----------    HW: 480 402 408 13
   Serial number: 3556502C510EDE4302FN
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 23081308490093
   Coding: 0C00
   VCID: 82482FB9155B839B55-80D6
   Part No SW: 5G1 920 758 A    HW: 5G1 920 758 A
   Component: KOMBI         302 6420
   Coding: 032509186F8C00081D827A0B4401000000000000
   VCID: AD12AC05FC45ACE3D8-80F8
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000000655100
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1244
   Revision: --------    Serial number: 0000846596
   Coding: 030100342B086400EF00065E1C0F00010001000000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: F9BA4855788DC04304-80AC
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001466590015304
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 3637991103
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000185018004
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: F3A67A7D5AE1BA134E-80A6
   Serial number: 0402084260
   Coding: 02032103
   ROD: EV_HREntryHella_VW37.rod
   VCID: BC349141373F356B5F-80E8
   Component: HRE_Slave  H11 0071
   Serial number: 0388577079
   Coding: 020321
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 18081302090615
   Coding: 003F1320D000048000001001
   VCID: BFCEE64D26292E737A-80EA
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002561162
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 1301
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: B326BA7D1A61FA138E-80E6
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 16081303110333
   Coding: 003F11205E00048000801001
   VCID: BE309B492123277B71-80EA
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002497037
   Coding: 090000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029A01105F010200
   VCID: BD329C452C253C6368-80E8
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 900000
   Part No SW: 5G0 035 020 H    HW: 5G0 035 020
   Component: MU-H-ND-EU    H40 0192
   Serial number: A458H0D7500229
   Coding: 027300010000000021111202002800001F0100340100010097
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 9E707BC981E3477B51-80CA
   Component: ABT_High  H42 0020
   Serial number: VWZ8Z9N2300V09
   Subsystem 2 - Part No SW: V03 959 806 MR    HW: -----------
   Component: ECE 2021  --- 0189
   Compact disc data bank:
   Component: Gracenote  --- 1008
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H11 0030
   Revision: 6B001003    Serial number: 00000194338091
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000107988
   Coding: 0101020001020303000401010100000101
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:25, VBatt start/end: 13.6V/13.6V)-----------
[code:]
