Golf 7 side assist retrofit
   #21
@sers77: Here's a comparison of the Old and New long-code strings from the hex03 module
Code_String to Byte_list convert
ByteOld HexOld BinaryNew HexNew Binary
0001000000010100000001
01FA11111010FA11111010
026A011010106A01101010
03A110100001A110100001
0424001001002400100100
0521001000012100100001
0611000100011100010001
076D011011016D01101101
0807000001110700000111
0979011110017901111001
1006000001100600000110
1101000000010100000001
1241010000014101000001
13C511000101C511000101
1429001010012900101001
1580100000008010000000
1656010101105601010110
1724001001002400100100
1888100010008810001000
19E011100000E011100000
2060011000006001100000
2182100000108210000010
2294100101009410010100
23F311110011F311110011
2418000110001800011000
2522001000102200100010
26F0111100005001010000
2762011000106201100010
2810000100009010010000
29A2101000108210000010
Remember Binary numbers are read from-right-to-left. So Bit 0 is the right-most digit
From software switch information HERE (translator needed - for me, at least)
  • Byte 26 =type of Bi-Directional Wheel Speed Sensors; changed from Torsion Bar Rear Suspension to Multi-Link Rear Suspension - Why? Does the car have the latter?
  • Byte 29 = Emergency Alert (AWV) disabled - why ??
How have you coded the park assist module? I mean have you enabled the RCTA/BSD bit there?
Yes - see Byte 29, Bit 7 !
sers77
Norway
C?ID=26140
Thank you all for your help..
I switched PLA module after downtime posted.. The first PLA module was not compatible...
Will change Byte 26 and 29 to the right Bits :thumbs:
The EPB (now only manual release) problem, might be solved under adaptions..
   #23
downtime
Finland
C?ID=280813
Don, I meant RCTA bit in PLA module 10, not in ABS module 03 :)
   #24
sers77
Norway
C?ID=26140
Suspect multi-link?!?!
Lxfxycn
   #25
sers77
Norway
C?ID=26140
Unable to adapt ABS.. Tried 24990, 20103 and 40168..
Does anybody have another key?
   #27
sers77
Norway
C?ID=26140
Electro Mechanical Parking brake adaption login 37483
Auto hold 24990
40304 also works on some other adaptions..
But parking brake is still manual release! Pretty irritating :banghead:
   #28
sers77
Norway
C?ID=26140
So Byte 27, Bit 2 or 3 Dynamic Start Assist was the easy way to fix the parking brake "issue"..
I tested both, but don´t know the difference between then.. I chose Bit 3 :thumbs:
Waiting for new R cluster, so I can get the PLA working again..
Cluster is now ticking away to meet 100000km...
+Wednesday,16,June,2021,12:17:26:21522
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4544.4
VIN: WVWZZZAUZEW111212   License Plate: PIPPI5
Mileage: 100325km-62339mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
          69 A5
VIN: WVWZZZAUZEW111212   Mileage: 100325km-62339miles
Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
   Component: R4 1.4l TFS   H02 9225
   Revision: WKH02---
   Coding: 0125003A247405083000
   Shop #: WSC 61962 003 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
   ROD: EV_ECM14TFS01104E906016AD.rod
   VCID: 648489216F0FADAB47-8030
Readiness: 1110 0001
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5240
   Revision: 00043014    Serial number: CU501308185463
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 76A0C369C9932F3BE9-8022
   Revision: 00000000    Serial number: 61136000001318
   Coding: 01FA6AA12421116D0779060141C52980562488E0608294F33822506890A2
   Shop #: WSC 12345 666 45678
   VCID: 7AB8D759FD8B4B5B8D-802E
   Revision: 00021000    Serial number: 0194304581
   Coding: 030C1C
   VCID: 3A381759BD0B8B5BCD-806E
   Part No SW: 5G0 907 044 AB    HW: 5G0 907 044 AB
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00020004204101011105004000101000
   VCID: 679E9E2D9E39C6B362-8032
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011324200143
   Coding: 00031E46C24122FB4BE44000001C07081C0A000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77BECE6DCE995633F2-8022
   Component: WWS    130811  042 0551
   Serial number:         130820192717
   Coding: 0E4DFD
   Component: RLFS  024 0042
   Serial number: Y13M09D03H00M40S31S1
   Coding: 06A8DD
   Part No SW: 5QA 919 298 E    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0452
   Serial number: 000308417617305
   Coding: 0251065851
   ASAM Dataset: EV_EPHVA2CAU3700000 009038
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 52E85FF905BB531B25-8006
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H03 0141
   Serial number: 12071376510039
   Coding: 001C1D00FE033B
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: 352204659415642320-8060
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR005HKT
   Coding: 98FCC0C0000000005C5400CF004800000065
   VCID: 7F4E264DE6A96E73BA-802A
   Left seat belt tensioner:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667B05091371397
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668B06091350561
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 357670000008CC597D08
   Subsystem 4 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 35867000000AE2488D02
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3516502B71088B1140F3
   Subsystem 6 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3526502A71088B1101B$
   Subsystem 7 - Part No SW: -----------    HW: 480 402 408 13
   Serial number: 3556502C510EDE4302FN
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 23081308490093
   Coding: 0C00
   VCID: 0248AFB9955B039BD5-8056
   Part No SW: 5G0 920 871     HW: 5G0 920 871
   Component: KOMBI         353 2210
   Coding: 032519186F8C00081D887E0B440000
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000000655100
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000846596
   Coding: 030100342B086400EF00065E1C0F00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 3B36125DB231B253D6-806E
   Generator:
H14 0035
   Serial number: 02130001613530033155
   Coding: 2D0000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 3637991103
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000185018004
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73A6FA7DDAE13A13CE-8026
   Serial number: 0402084260
   Coding: 02032103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C341141B73FB56BDF-8068
   Component: HRE_Slave  H11 0071
   Serial number: 0388577079
   Coding: 020321
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 18081302090615
   Coding: 003F1320D000048000001001
   VCID: 3FCE664DA629AE73FA-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002561162
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 1301
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: 33263A7D9A617A130E-8066
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 16081303110333
   Coding: 003F11205E00048000801001
   VCID: 3E301B49A123A77BF1-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002497037
   Coding: 090000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029A01105F010200
   VCID: 3D321C45AC25BC63E8-8068
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 900000
   Part No SW: 5G0 035 020 H    HW: 5G0 035 020
   Component: MU-H-ND-EU    H40 0192
   Serial number: A458H0D7500229
   Coding: 027300010000000021111202002800001F0100340100010097
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1E70FBC901E3C77BD1-804A
   Component: ABT_High  H42 0020
   Serial number: VWZ8Z9N2300V09
   Subsystem 2 - Part No SW: V03 959 806 MR    HW: -----------
   Component: ECE 2021  --- 0189
   Compact disc data bank:
   Component: Gracenote  --- 1008
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H11 0030
   Revision: 6B001003    Serial number: 00000194338091
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000107988
   Coding: 0101020001020303010301010100000101
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:25, VBatt start/end: 12.5V/12.4V)-----------
[code/]
downtime
Finland
C?ID=280813
Sorry but I don't understand the issue you had with EPB? What do you mean with manual release? EPB does not automatically disengage whem you start to move?
   #30
sers77
Norway
C?ID=26140
It didn't before coding it to Dynamic Start Assist..
Before, belt on and put it in Drive, it would not release..
   #31
downtime
Finland
C?ID=280813
Aha ok, and now works fine?
Does your BSD and RCTA now function correctly? Did you get that sorted out?
   #33
downtime
Finland
C?ID=280813
Ok great:thumbs:
   #34
sers77
Norway
C?ID=26140
Now I have new cluster, but getting service reminder at startup and shutoff.
Also getting "ERROR RANGE"... Is this something I can fix with ODIS, or is the only option new gateway?
Is it possible to update "Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F" to AM or AJ?
New cluster does not light up "side assist", the green mirror at bottom right side (right of lane assist)...
I can see it with a flashlight, but it does not light up when I run the cluster TEST..! :eek:
Sunday,11,July,2021,15:36:52:21522
Workshop Code: 666 12345 045678
VIN: WVWZZZAUZEW111212   License Plate: PIPPIRULL
Mileage: 100711km-62578mi   Repair Order:
          69 A5
VIN: WVWZZZAUZEW111212   Mileage: 100711km-62578miles
   Revision: WKH02---
   VCID: E4840921EF0F2DABC7-80B0
Readiness: 0110 0001
   VCID: F6A043694993AF3B69-80A2
   VCID: FAB857597D8BCB5B0D-80AE
   Coding: 030C1C
   VCID: BA3897593D0B0B5B4D-80EE
   Revision: 00001K06
   VCID: E79E1E2D1E3946B3E2-80B2
   Air quality sensor:
   VCID: F7BE4E6D4E99D63372-80A2
   Coding: 0E4DFD
   Coding: 06A8DD
   Coding: 0351065851
   VCID: D2E8DFF985BBD31BA5-8086
   VCID: B52284651415E423A0-80E0
   VCID: FF4EA64D66A9EE733A-80AA
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   VCID: 82482FB9155B839B55-80D6
   Part No SW: 5G1 920 758 A    HW: 5G1 920 758 A
   Component: KOMBI         302 6420
   Coding: 032509186F8C00081D807A0B4401000000000000
   VCID: AD12AC05FC45ACE3D8-80F8
   Coding: 1309
   VCID: BB36925D3231325356-80EE
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001466590015304
   Coding: 2DFFFF
   VCID: F3A67A7D5AE1BA134E-80A6
   Coding: 02032103
   VCID: BC349141373F356B5F-80E8
   Coding: 020321
   VCID: BFCEE64D26292E737A-80EA
   Coding: 1301
   VCID: B326BA7D1A61FA138E-80E6
   VCID: BE309B492123277B71-80EA
   Coding: 090000
   VCID: BD329C452C253C6368-80E8
   Coding: 900000
   Coding: 900000
   VCID: 9E707BC981E3477B51-80CA
End----------(Elapsed Time: 01:28, VBatt start/end: 12.3V/12.2V)-----------
[code/]
downtime
Finland
C?ID=280813
you can. AJ flash is available but you also need AJ dataset that matches your car. Engine, alternator, start stop
flashing to another firmware wipes the dataset clean.
   #36
sers77
Norway
C?ID=26140
AJ does´nt work with ODIS...
Is there some other file I can try? Or is this Gateway "fried"?
   #37
myounus
Northwest UK
C?ID=321059
What do you mean AJ doesn’t work? How are you trying to update it?
   #38
sers77
Norway
C?ID=26140
Yes it´s updated to AJ, but cannot activate (FPA)driving profiles, (MKE) Fatigue Recognition and start/stop system.
Tried FES SWaP, but that did not help..
Have 3 DTC on gateway 00401, 00605 and 0060C..
   #39
myounus
Northwest UK
C?ID=321059
You need to restore FEC’s
   #40
sers77
Norway
C?ID=26140
Sorry, but i cannot find any FEC..
Test plan cannot do it..
Guessing AJ not compatible with this car..
The following malfunction has occurred:
ERP0617E
Software configuration (coding, adaptation/calibration, parameterization) could not be computed. Please check whether a compatible control module or replacement part is installed in the vehicle. If the malfunction continues, consult Customer Support.
