Golf 7 side assist retrofit
sers77
Norway
C?ID=26140
Just finished installing and coding, but it says not working..
Guessing RTA is the problem, but how do I disable it?
Mon,Jun,07,2021,10:54:23
VCDS Mobile: 0.4543
Data Version: 30000060
VIN: WVWZZZAUZEW111212
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 47 52 55
  5F 69 A5
Address 01: Engine (CPTA: J623)Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 ADHW: 04E 907 309 G
Component: R4 1.4l TFS H02 9225
Revision: WKH02---
Coding: 0125003A247405083000
Shop #: WSC 61962 003 1048576
ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
ROD: EV_ECM14TFS01104E906016AD.rod
VCID: 648B3F93932937482FFAF0-8031
No fault codes found.
Address 02: Auto Trans (J743)Labels: 0CW-927-769.clb
Part No SW: 0CW 300 045HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5240
Revision: 00043014
ROD: N/A
VCID: F6AFF5DBB5B535D8018E2A-80A3
No ASAM data for: "EV_TCMDQ200021"
Address 03: ABS Brakes (J104)Labels:
Part No SW: 5Q0 907 379 ABHW: 5Q0 907 379 H
Component: ESC H31 0557
Revision: 00000000
Coding: 01FA6AA12421116D0379060141C52980562488C0608294F3F822507AC102
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 7CBB67F30B99EF88F7CAE8-8029
Address 05: Acc/Start Auth. (J518)Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 AHW: 5Q0 959 435
Revision: 00021000
Coding: 030C1C
ROD: N/A
VCID: 3A37A1EB412D11B8A5563E-806F
No ASAM data for: "EV_KessyHellaMQBAB"
Address 08: Auto HVAC (J255)Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 ABHW: 5G0 907 044 AB
Component: Climatronic H02 0705
Revision: 00001K06
Coding: 00020004204101011105004000101000
Shop #: WSC 12345 666 45678
VCID: 6791289F621F5C500A18CF-8032
Subsystem 1 -
Subsystem 2 -
Address 09: Cent. Elect. (J519)Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AAHW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Coding: 00031E46C24122FB4BE44000001C07081C0A000000000000000000000000
ROD: EV_BCMCONTI_011.rod
VCID: 77B178DF32BFCCD09AB89F-8022
Subsystem 1 - Part No SW: 5G1-955-119-ALabels: 5Qx-955-119-V1.clb
Component: WWS 130811042 0551
Serial Number: 130820192717
Coding: 0E4DFD
Subsystem 2 - Part No SW: 5Q0-955-547Labels: 5Q0-955-547.clb
Component: RLFS 024 0042
Serial Number: Y13M09D03H00M40S31S1
Coding: 06A8DD
Address 10: Park/Steer Assist (J791)Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 AHW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Revision: --------
Coding: 0031061151
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 3D3DAAF75003268080741D-8068
Address 13: Auto Dist. Reg (J428)Labels: 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 AHW: 5Q0 907 572
Component: ACC Bosch MQB H03 0141
Coding: 001C1D00FE033B
ASAM Dataset: EV_ACCMRRBoschVW372 001013
ROD: EV_ACCMRRBoschVW372_VW37.rod
VCID: 352DB2D76833FEC04804F5-8060
Address 15: Airbags (J234)Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AAHW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Coding: 98FCC0C0000000005C5400CF004800000065
ROD: N/A
VCID: 7F4190FF1A8FF490D2E8C7-802A
No ASAM data for: "EV_AirbaVW20SMEVW37X"
Subsystem 1 - Part No SW: 5G0-980-945-B
Component: BeltPretRevFLH35 0340
Serial Number: 34169667B05091371397
Coding: 333135
Subsystem 2 - Part No SW: 5G0-980-946-B
Component: BeltPretRevFRH35 0340
Serial Number: 34169668B06091350561
Coding: 333135
Subsystem 3 - Part No SW: --------------
Component: SideSensor_Df001 0887
Serial Number: 357670000008CC597D08
Subsystem 4 - Part No SW: --------------
Component: SideSensor_Pf001 0887
Serial Number: 35867000000AE2488D02
Subsystem 5 - Part No SW: --------------
Component: SideSensor_Dr001 6149
Serial Number: 3516502B71088B1140F3
Subsystem 6 - Part No SW: --------------
Component: SideSensor_Pr001 6149
Serial Number: 3526502A71088B1101B$
Address 16: Steering wheel (J527)Labels: 5Q-16.lbl
Part No SW: 5Q0 953 507 BMHW: 5Q0 953 549
Revision: --------
Coding: 0C00
ROD: N/A
VCID: 8247990BE97D19783D0626-80D7
No ASAM data for: "EV_SMLSKLOMQB"
Address 17: Instruments (J285)Labels: 5G0-920-XXX-17.clb
Part No SW: 5G0 920 871HW: 5G0 920 871
Component: KOMBI 353 2210
Coding: 03AD19186F9C00081D887E0B040000
ROD: N/A
VCID: E791A89FE21FDC508A184F-80B2
No ASAM data for: "EV_DashBoardVDDMQBAB"
Address 18: Aux. Heat (J364)Labels: 5Q0-963-272.clb
Part No SW: 5Q0 963 272 BHW: 5Q0 963 272 B
Component: STH-MQB 006 0069
Coding: 1309
ASAM Dataset: EV_AuxilParkiHeateWOS 002014
Address 19: CAN Gateway (J533)Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 MHW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: --------
Coding: 030100342B086400EF00065E1C0F00010001000000000000000000000000
ROD: EV_GatewLear_009.rod
VCID: 3B39A4EF4E1728B0BE4033-806E
Subsystem 1 -
Subsystem 2 - Part No SW: 5G0-959-442-KLabels: 3C8-959-537.clb
Component: E221__MFL-DC1H14 0035
Serial Number: 02130001613530033155
Coding: 2D0000
Subsystem 3 - Part No SW: 5Q0-915-181-C
Component: J367-BDMHellaH03 8042
Serial Number: 3637991103
Address 2B: Steer. Col. Lock (J764)Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: N/A
VCID: F3A9CCCFA6C720F02690CB-80A6
No ASAM data for: "EV_ELVMarquMQB"
Address 3C: Lane Change (J1086)Labels: 5Q0-907-686.clb
Part No SW: 5Q0 907 686 BHW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Coding: 02032103
ROD: N/A
VCID: 3C3BA7F34B192F88B74A28-8069
No ASAM data for: "EV_HREntryHella"
336901 - ROD - Unknown faultcode
338048 - ROD - Unknown faultcode
Address 42: Door Elect, Driver (J386)Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 AHW: 5Q0 959 593
Component: TSG FS 012 0006
Coding: 003F1320D000048000001001
ROD: N/A
VCID: 3FC1D0FF5A0F3490926807-806A
No ASAM data for: "EV_DCUDriveSideEWMAXKLO"
Address 44: Steering Assist (J500)Labels: 5Q0-909-144.clb
Part No SW: 3Q0 909 144 DHW: 3Q0 909 144 E
Component: EPS_MQB_ZFLS 502 5011
Coding: 1301
ASAM Dataset: EV_SteerAssisMQB 009026
ROD: N/A
VCID: 33298CCF6647E0F066108B-8066
No ASAM data for: "EV_SteerAssisMQB"
Address 47: Sound System (J525)Labels: 5G0-035-456.clb
Part No SW: 5G0 035 456HW: 5G0 035 456
Component: MIB_lite_amp H30 0042
Coding: 120000008AAA8A0000
ASAM Dataset: EV_AMPMst12C1ALPI 001005
ROD: N/A
VCID: E389BC8F1627B07056F07B-80B6
No ASAM data for: "EV_AMPMst12C1ALPI"
Address 52: Door Elect, Pass. (J387)Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 AHW: 5Q0 959 592
Component: TSG BFS 012 0006
Coding: 003F11205E00048000801001
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 3E3FADFB5D053D98997E12-806B
Address 55: Xenon Range (J745)Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 AHW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: --------
Coding: 029A01105F010200
Subsystem 1 - Part No SW: 3D0-941-329-ALabels: 3D0-941-329.clb
Component: LeiMo links H05 0012
Coding: 900000
Address 5F: Information Electr. (J794)Labels: 5G-5f.clb
Part No SW: 5G0 035 020 HHW: 5G0 035 020
Component: MU-H-ND-EU H40 0192
Coding: 027300010000000021111202002800001F0100340100010097
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: N/A
VCID: 1E7F4D7BFDC55D98B93EF2-804B
No ASAM data for: "EV_MUHig4CHBAS"
Subsystem 1 - Part No SW: 5G0-919-606
Component: ABT_High H42 0020
Serial Number: VWZ8Z9N2300V09
Subsystem 2 - Part No SW: V03-959-806-MR
Component: ECE 2021 --- 0189
Serial Number: --------------------
Address 69: Trailer (J345)Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 AHW: 5Q0 907 383 A
Component: Anhaenger H11 0030
Revision: 6B001003
Coding: 0100000200000000
ASAM Dataset: EV_TrailFunctPivotHella 001001
ROD: N/A
No ASAM data for: "EV_TrailFunctPivotHella"
Address A5: Frt Sens. Drv. Assist (R242)Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 EHW: 5Q0 980 653
Component: MQB_MFK H05 0051
Coding: 0101020001020303000301010100000101
ROD: EV_MFKBoschAU370.rod
End--(Elapsed Time: 02:13, VBatt start/end: 12.3/12.3 Vign: 12.3)-
sers77
Norway
C?ID=26140
Ok, so I ordered a 3Q0907379AB ABS module.
Hope that helps!?!?
Also have a 5QA919298E module, but my guess is that it won´t work either!?!?
myounus
Northwest UK
C?ID=321059
Please can you explain what you installed as I’m not familiar with side assist. I suspect you may be referring blind spot assist. Thanks
sers77
Norway
C?ID=26140
Yes, 3C lane change is installed and not working.
Shows unavailable when I try to activate it in instrument cluster and radio.
But the new ABS should solve that problem and maybe create some new ones :eek:
Tried the 5QA919298E module for PLA 3.0, but the instrument cluster is to old (only available on newer than may 2015 instrument clusters, I suppose?).
Does anyone have a coding suggestion for the new 3Q0907379AB ABS module, so I don't get to many grey hairs?
downtime
Finland
C?ID=280813
Edit : Ah ok sorry. The first autoscan was already after.
I'm pretty sure your ABS should support RCTA as it's an IPB pump.
Have you tried to not enable Rear cross traffic alert from instrument cluster? Just blind spot?
And could you post adamap from 5F module as well. That is needed too.
sers77
Norway
C?ID=26140
Unable to enable either RTA or BSD..
"RTA/BSD not available"... So none of them work..
ABS module 3Q0907379AB is going in tomorrow, so I guess there will be a few days downtime to code it in..
;SW:5G0-035-020-H   HW:5G0-035-020 ---  Information Electr.
;Component:MU-H-ND-EU    H40 0192, Coding:027300010000000021111202002800001F0100340100010097
;EV_MUHig4CHBAS,001040,EV_MUHig4CHBAS_VW37.rod
;Wednesday,09,June,2021,21:18:21:21522
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
;VCID: 1E70FBC901E3C77BD1-804A
IDE00346-Summertime-automatic,Europe ,1
IDE00759-Base volume of speech output,50 %,1
IDE00760-Microphone sensitivity,0 dB,1
IDE00768-Country identification: country of sale,-- ,2
IDE00769-Call number 1 for info call,5E 03 A1 40 44 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 03 A1 40 44 F4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE00845-Wheel circumference,2000 mm,2
IDE02121-CD eject button,Enabled ,1
IDE02330-Call number 2 for info call,5E 05 91 74 22 80 16 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 05 91 74 22 80 16 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,49
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22 ,49
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22 ,49
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22 ,49
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22 ,49
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22 ,49
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22 ,49
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22 ,49
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,49
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,49
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,49
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,49
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,49
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22 ,49
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22 ,49
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22 ,49
IDE02502-Confirmation of installation change,57 5D ,2
IDE02506-MAS03229-Copy multimedia data-Data carrier,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,On ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF ,30
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,OFF ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,locked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,OFF ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,OFF ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,OFF ,30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1,not installed ,30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2,not installed ,30
IDE03471-ENG127492-Vehicle configuration-LGI,OFF ,30
IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF ,30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo,OFF ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation,no restriction ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,not installed ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi,activated ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,locked ,30
IDE03471-ENG137647-Vehicle configuration-UOTA,OFF ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF ,30
IDE03471-ENG127494-Vehicle configuration-VZO,OFF ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE03581-ENG117690-Vehicle function list CAN-Adaptive_key_msg_bus,Comfort data bus ,8
IDE03581-ENG117691-Vehicle function list CAN-Adaptive_key_school,Not available ,8
IDE03581-ENG117688-Vehicle function list CAN-Driving_school,available. ,8
IDE03581-ENG117689-Vehicle function list CAN-Driving_school_msg_bus,Infotainment data bus ,8
IDE03581-ENG107608-Vehicle function list CAN-MFL,available. ,8
IDE03581-ENG117681-Vehicle function list CAN-MFL_msg_bus,Extended data bus ,8
IDE03581-ENG117683-Vehicle function list CAN-Oil_level,Not available ,8
IDE03581-ENG117684-Vehicle function list CAN-Oil_level_msg_bus,Powertrain data bus ,8
IDE03581-ENG117685-Vehicle function list CAN-PDC_audio_lowering,available. ,8
IDE03581-ENG117686-Vehicle function list CAN-PDC_audio_lowering_msg_bus,Suspension data bus ,8
IDE03581-ENG98994-Vehicle function list CAN-Trailer,Not available ,8
IDE03581-ENG117682-Vehicle function list CAN-Trailer_msg_bus,Comfort data bus ,8
IDE03581-ENG99892-Vehicle function list CAN-VIN,available. ,8
IDE03581-ENG117687-Vehicle function list CAN-VIN_msg_bus,Comfort data bus ,8
IDE03902-Automatic ring break diagnostic,No automatic start ,1
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,40
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,40
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,40
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,40
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,40
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,40
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,40
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,40
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,40
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,40
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,40
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,40
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,40
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,40
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,40
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,40
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,40
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,40
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,40
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,40
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,40
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,40
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,40
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,activated ,40
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,40
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,40
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,activated ,40
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,40
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,40
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,40
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,40
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,40
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,40
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,activated ,40
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,40
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,40
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,activated ,40
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,40
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,40
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,40
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,40
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,40
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,40
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,40
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,40
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,40
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,40
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,40
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,40
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,40
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,40
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,40
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,40
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,40
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,40
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,40
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,40
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,40
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,40
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,40
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,40
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,40
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,40
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,not activated ,40
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,40
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,40
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,40
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,40
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,40
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,40
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,40
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,40
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,40
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,40
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,40
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,40
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,40
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,40
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,40
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,40
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,40
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,activated ,40
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,40
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,40
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,activated ,40
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,40
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,not activated ,40
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,40
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,40
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,40
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,40
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,40
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,40
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,40
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,40
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,40
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,40
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,40
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,40
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,40
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,40
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,40
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,40
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,40
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,40
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,40
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,40
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,40
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,40
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,40
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,40
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,40
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,40
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,40
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,40
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,40
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,40
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,40
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,40
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,40
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,40
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,activated ,40
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,40
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,40
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,40
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,40
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,40
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,40
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,40
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,40
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,40
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,40
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,40
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,40
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,40
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,40
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,activated ,40
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,40
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,40
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,40
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,40
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,activated ,40
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,40
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,40
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,activated ,40
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,40
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,40
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,40
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,40
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,activated ,40
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,40
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,40
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,40
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,40
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,40
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,40
IDE04300-ENG117511-Vehicle menu operation-menu_display_side_assistant,activated ,40
IDE04300-ENG117515-Vehicle menu operation-menu_display_side_assistant_after_disclaimer,not activated ,40
IDE04300-ENG117512-Vehicle menu operation-menu_display_side_assistant_clamp_15_off,not activated ,40
IDE04300-ENG117513-Vehicle menu operation-menu_display_side_assistant_over_threshold_high,activated ,40
IDE04300-ENG117514-Vehicle menu operation-menu_display_side_assistant_standstill,not activated ,40
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,40
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,40
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,40
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,40
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,40
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,activated ,40
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,40
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,40
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,activated ,40
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,40
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,40
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,40
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,40
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,40
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,40
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,40
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,40
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,40
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,40
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,40
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,40
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,40
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,40
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,40
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,40
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,40
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,40
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,40
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,40
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,40
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,40
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,40
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,40
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,40
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,40
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,53
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Extended data bus ,53
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,53
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,Suspension data bus ,53
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,53
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,Not available ,53
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,activated ,53
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,Comfort data bus ,53
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,53
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,53
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,activated ,53
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Infotainment data bus ,53
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,53
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,53
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,53
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Comfort data bus ,53
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,not activated ,53
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Infotainment data bus ,53
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,53
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,Comfort data bus ,53
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,53
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Comfort data bus ,53
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,53
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,Comfort data bus ,53
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,53
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,53
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,53
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,Infotainment data bus ,53
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,53
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,53
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,not activated ,53
IDE04307-ENG125040-Vehicle function list BAP-Ecall_msg_bus_0x33,Comfort data bus ,53
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,53
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Comfort data bus ,53
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,53
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,Comfort data bus ,53
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,53
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Powertrain data bus ,53
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,53
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort data bus ,53
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,53
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Extended data bus ,53
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,53
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Comfort data bus ,53
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,53
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,Infotainment data bus ,53
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,53
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,53
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,53
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,Not available ,53
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,53
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,53
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,53
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,Comfort data bus ,53
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,activated ,53
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Powertrain data bus ,53
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,53
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,53
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,53
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,Not available ,53
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,activated ,53
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,Infotainment data bus ,53
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,activated ,53
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Extended data bus ,53
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,53
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,53
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,activated ,53
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Extended data bus ,53
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,53
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,Terminal 15 ,53
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,53
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,53
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,not activated ,53
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Infotainment data bus ,53
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,53
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Infotainment data bus ,53
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,53
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Comfort data bus ,53
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04521-Sporadic ring break detection,optical ,1
IDE04522-Awakening ability on optical databus,OFF ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE05111-Fee-based traffic information (TMC),3 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,6
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,6
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,6
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,6
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,6
IDE09570-ENG117700-Vehicle function list BAP: extension-ACC_0x05,activated ,64
IDE09570-ENG117701-Vehicle function list BAP: extension-ACC_0x05_msg_bus,Extended data bus ,64
IDE09570-ENG117702-Vehicle function list BAP: extension-air_suspension_0x06,not activated ,64
IDE09570-ENG117703-Vehicle function list BAP: extension-air_suspension_0x06_msg_bus,Suspension data bus ,64
IDE09570-ENG117764-Vehicle function list BAP: extension-Amplifier_0x2D,not activated ,64
IDE09570-ENG117765-Vehicle function list BAP: extension-Amplifier_0x2D_msg_bus,Not available ,64
IDE09570-ENG122334-Vehicle function list BAP: extension-Angle_Of_Slope_0x24,not activated ,64
IDE09570-ENG122335-Vehicle function list BAP: extension-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
IDE09570-ENG117696-Vehicle function list BAP: extension-auxilary_heating_0x03,activated ,64
IDE09570-ENG117697-Vehicle function list BAP: extension-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
IDE09570-ENG117744-Vehicle function list BAP: extension-AWV_0x1B,activated ,64
IDE09570-ENG117745-Vehicle function list BAP: extension-AWV_0x1B_msg_bus,Terminal 15 ,64
IDE09570-ENG122336-Vehicle function list BAP: extension-Battery_Management_0x25,not activated ,64
IDE09570-ENG122337-Vehicle function list BAP: extension-Battery_Management_0x25_msg_bus,Comfort data bus ,64
IDE09570-ENG117758-Vehicle function list BAP: extension-BCmE_0x23,activated ,64
IDE09570-ENG117759-Vehicle function list BAP: extension-BCmE_0x23_msg_bus,Infotainment data bus ,64
IDE09570-ENG117760-Vehicle function list BAP: extension-Brake_0x26,activated ,64
IDE09570-ENG117761-Vehicle function list BAP: extension-Brake_0x26_msg_bus,Suspension data bus ,64
IDE09570-ENG117717-Vehicle function list BAP: extension-central_locking_0x0D,activated ,64
IDE09570-ENG117716-Vehicle function list BAP: extension-central_locking_0x0D_msg_bus,Comfort data bus ,64
IDE09570-ENG117736-Vehicle function list BAP: extension-charisma_0x17,not activated ,64
IDE09570-ENG117737-Vehicle function list BAP: extension-charisma_0x17_msg_bus,Infotainment data bus ,64
IDE09570-ENG117734-Vehicle function list BAP: extension-clima_slave_2_0x16,not activated ,64
IDE09570-ENG117735-Vehicle function list BAP: extension-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
IDE09570-ENG117692-Vehicle function list BAP: extension-climatic_master_0x01,activated ,64
IDE09570-ENG117693-Vehicle function list BAP: extension-climatic_master_0x01_msg_bus,Comfort data bus ,64
IDE09570-ENG117694-Vehicle function list BAP: extension-climatic_slave_0x02,not activated ,64
IDE09570-ENG117695-Vehicle function list BAP: extension-climatic_slave_0x02_msg_bus,Comfort data bus ,64
IDE09570-ENG117724-Vehicle function list BAP: extension-clock_0x11,activated ,64
IDE09570-ENG117725-Vehicle function list BAP: extension-clock_0x11_msg_bus,Comfort data bus ,64
IDE09570-ENG117732-Vehicle function list BAP: extension-compass_0x15,not activated ,64
IDE09570-ENG117733-Vehicle function list BAP: extension-compass_0x15_msg_bus,Infotainment data bus ,64
IDE09570-ENG117722-Vehicle function list BAP: extension-driver_seat_0x10,not activated ,64
IDE09570-ENG117723-Vehicle function list BAP: extension-driver_seat_0x10_msg_bus,Comfort data bus ,64
IDE09570-ENG117708-Vehicle function list BAP: extension-exterieur_light_0x09,activated ,64
IDE09570-ENG117709-Vehicle function list BAP: extension-exterieur_light_0x09_msg_bus,Comfort data bus ,64
IDE09570-ENG117698-Vehicle function list BAP: extension-headup_displ_0x04,not activated ,64
IDE09570-ENG117699-Vehicle function list BAP: extension-headup_displ_0x04_msg_bus,Comfort data bus ,64
IDE09570-ENG117746-Vehicle function list BAP: extension-Hybrid_0x1D,not activated ,64
IDE09570-ENG117747-Vehicle function list BAP: extension-Hybrid_0x1D_msg_bus,Powertrain data bus ,64
IDE09570-ENG117706-Vehicle function list BAP: extension-interieur_light_0x08,activated ,64
IDE09570-ENG117707-Vehicle function list BAP: extension-interieur_light_0x08_msg_bus,Comfort data bus ,64
IDE09570-ENG117740-Vehicle function list BAP: extension-LDW_HCA_0x19,activated ,64
IDE09570-ENG117741-Vehicle function list BAP: extension-LDW_HCA_0x19_msg_bus,Extended data bus ,64
IDE09570-ENG117720-Vehicle function list BAP: extension-MFA_0x0F,activated ,64
IDE09570-ENG117721-Vehicle function list BAP: extension-MFA_0x0F_msg_bus,Comfort data bus ,64
IDE09570-ENG117767-Vehicle function list BAP: extension-MFL_Jocker_0x34,not activated ,64
IDE09570-ENG117766-Vehicle function list BAP: extension-MFL_Jocker_msg_bus_0x34,Infotainment data bus ,64
IDE09570-ENG117719-Vehicle function list BAP: extension-mirror_0x0E,activated ,64
IDE09570-ENG117718-Vehicle function list BAP: extension-mirror_0x0E_msg_bus,Comfort data bus ,64
IDE09570-ENG117738-Vehicle function list BAP: extension-Night_Vision_0x18,not activated ,64
IDE09570-ENG117739-Vehicle function list BAP: extension-Night_Vision_0x18_msg_bus,Not available ,64
IDE09570-ENG117710-Vehicle function list BAP: extension-parking_assist_0x0A,activated ,64
IDE09570-ENG117711-Vehicle function list BAP: extension-parking_assist_0x0A_msg_bus,Terminal 15 ,64
IDE09570-ENG117752-Vehicle function list BAP: extension-Passenger_Seat_0x20,not activated ,64
IDE09570-ENG117753-Vehicle function list BAP: extension-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
IDE09570-ENG122333-Vehicle function list BAP: extension-Range_Data_0x39,not activated ,64
IDE09570-ENG125827-Vehicle function list BAP: extension-Range_Data_msg_bus_0x39,Comfort data bus ,64
IDE09570-ENG122327-Vehicle function list BAP: extension-RearSeatEntertainment_0x2E,not activated ,64
IDE09570-ENG122328-Vehicle function list BAP: extension-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
IDE09570-ENG117750-Vehicle function list BAP: extension-Reversible_Seat_Belt_Tightener_0x1F,activated ,64
IDE09570-ENG117751-Vehicle function list BAP: extension-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Powertrain data bus ,64
IDE09570-ENG117726-Vehicle function list BAP: extension-service_interval_display_0x12,activated ,64
IDE09570-ENG117727-Vehicle function list BAP: extension-service_interval_display_0x12_msg_bus,Comfort data bus ,64
IDE09570-ENG117748-Vehicle function list BAP: extension-SideView_0x1E,not activated ,64
IDE09570-ENG117749-Vehicle function list BAP: extension-SideView_0x1E_msg_bus,Not available ,64
IDE09570-ENG122329-Vehicle function list BAP: extension-Special_Functions_0x35,not activated ,64
IDE09570-ENG122330-Vehicle function list BAP: extension-Special_Functions_msg_bus_0x35,Comfort data bus ,64
IDE09570-ENG117762-Vehicle function list BAP: extension-Start_Stop_reasons_0x27,activated ,64
IDE09570-ENG117763-Vehicle function list BAP: extension-Start_Stop_reasons_0x27_msg_bus,Infotainment data bus ,64
IDE09570-ENG117742-Vehicle function list BAP: extension-SWA_0x1A,activated ,64
IDE09570-ENG117743-Vehicle function list BAP: extension-SWA_0x1A_msg_bus,Extended data bus ,64
IDE09570-ENG117704-Vehicle function list BAP: extension-tire_pressure_system_0x07,activated ,64
IDE09570-ENG117705-Vehicle function list BAP: extension-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
IDE09570-ENG117754-Vehicle function list BAP: extension-traffic_sign_recognition_0x21,activated ,64
IDE09570-ENG117755-Vehicle function list BAP: extension-traffic_sign_recognition_0x21_msg_bus,Extended data bus ,64
IDE09570-ENG122331-Vehicle function list BAP: extension-Trailer_Assistant_0x36,not activated ,64
IDE09570-ENG122332-Vehicle function list BAP: extension-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
IDE09570-ENG122325-Vehicle function list BAP: extension-TV_tuner_0x2C,not activated ,64
IDE09570-ENG122326-Vehicle function list BAP: extension-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
IDE09570-ENG117730-Vehicle function list BAP: extension-UGDO_0x14,not activated ,64
IDE09570-ENG117731-Vehicle function list BAP: extension-UGDO_0x14_msg_bus,Terminal 15 ,64
IDE09570-ENG117728-Vehicle function list BAP: extension-unit_master_0x13,activated ,64
IDE09570-ENG117729-Vehicle function list BAP: extension-unit_master_0x13_msg_bus,Comfort data bus ,64
IDE09570-ENG117712-Vehicle function list BAP: extension-VPS_0x0B,not activated ,64
IDE09570-ENG117713-Vehicle function list BAP: extension-VPS_0x0B_msg_bus,Infotainment data bus ,64
IDE09570-ENG117756-Vehicle function list BAP: extension-weariness_rcognition_0x22,activated ,64
IDE09570-ENG117757-Vehicle function list BAP: extension-weariness_rcognition_0x22_msg_bus,Infotainment data bus ,64
IDE09570-ENG117714-Vehicle function list BAP: extension-wiper_comfort_0x0C,activated ,64
IDE09570-ENG117715-Vehicle function list BAP: extension-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
MAS00951-Bluetooth,On ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
MAS03782-WLAN,On ,1
ENG117918-ENG117811-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_On_Off,OFF ,4
ENG117918-ENG117813-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_Time,500.00 ms,4
ENG117918-ENG117810-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_On_Off,OFF ,4
ENG117918-ENG117812-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_Time,500.00 ms,4
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay,0 ms,3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic,On ,3
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 02 ,2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
Elapsed Time: 00:33
[code/]
sers77
Norway
C?ID=26140
Would it be a good idea to just connect the "new" ABS and see if it`s even possible?
Or should I just go 4 it? :thumbs:
sers77
Norway
C?ID=26140
The ABS accepted 01FA6AA12421116D0779060141C52980562488E0608294F31422503AC082, but I have alot of DTC..
sers77
Norway
C?ID=26140
Thursday,10,June,2021,16:08:32:21522
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
Workshop Code: 666 12345 045678
VIN: WVWZZZAUZEW111212   License Plate: PIPPI2.0
Mileage: 100220km-62273mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
          69 A5
VIN: WVWZZZAUZEW111212   Mileage: 100220km-62273miles
Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
   Component: R4 1.4l TFS   H02 9225
   Revision: WKH02---
   Coding: 0125003A247405083000
   Shop #: WSC 61962 003 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
   ROD: EV_ECM14TFS01104E906016AD.rod
   VCID: E4840921EF0F2DABC7-80B0
Readiness: 0110 0001
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5240
   Revision: 00043014    Serial number: CU501308185463
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: F6A043694993AF3B69-80A2
   Revision: 00000000    Serial number: 61136000001318
   Coding: 01FA6AA12421116D0779060141C52980562488E0608294F31822F06210A2
   Shop #: WSC 12345 666 45678
   VCID: FAB857597D8BCB5B0D-80AE
   Revision: 00021000    Serial number: 0194304581
   Coding: 030C1C
   VCID: BA3897593D0B0B5B4D-80EE
   Part No SW: 5G0 907 044 AB    HW: 5G0 907 044 AB
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00020004204101011105004000101000
   VCID: E79E1E2D1E3946B3E2-80B2
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011324200143
   Coding: 00031E46C24122FB4BE44000001C07081C0A000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: F7BE4E6D4E99D63372-80A2
   Component: WWS    130811  042 0551
   Serial number:         130820192717
   Coding: 0E4DFD
   Component: RLFS  024 0042
   Serial number: Y13M09D03H00M40S31S1
   Coding: 06A8DD
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131322600084
   Coding: 0031061151
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: BD329C452C253C6368-80E8
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H03 0141
   Serial number: 12071376510039
   Coding: 001C1D00FE033B
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: B52284651415E423A0-80E0
1043 - Automatic Distance Control
          B10E7 F0 [008] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 180
                    Mileage: 100220 km
                    Date: 2021.06.10
                    Time: 15:57:41
                    Control Module temperature: 53 °C
                    Voltage terminal 15: 12.3 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR005HKT
   Coding: 98FCC0C0000000005C5400CF004800000065
   VCID: FF4EA64D66A9EE733A-80AA
   Left seat belt tensioner:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667B05091371397
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668B06091350561
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 357670000008CC597D08
   Subsystem 4 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 35867000000AE2488D02
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3516502B71088B1140F3
   Subsystem 6 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3526502A71088B1101B$
   Subsystem 7 - Part No SW: -----------    HW: 480 402 408 13
   Serial number: 3556502C510EDE4302FN
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 23081308490093
   Coding: 0C00
   VCID: 82482FB9155B839B55-80D6
   Part No SW: 5G0 920 871     HW: 5G0 920 871
   Component: KOMBI         353 2210
   Coding: 03A519186F9C00081D887E0B440000
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
   Component: STH-MQB       006 0069
   Coding: 1309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000000655100
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000846596
   Coding: 030100342B086400EF00065E1C0F00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: BB36925D3231325356-80EE
   Generator:
H14 0035
   Serial number: 02130001613530033155
   Coding: 2D0000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 3637991103
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000185018004
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: F3A67A7D5AE1BA134E-80A6
   Serial number: 0402084260
   Coding: 02032103
   ROD: EV_HREntryHella_VW37.rod
   VCID: BC349141373F356B5F-80E8
   Component: HRE_Slave  H11 0071
   Serial number: 0388577079
   Coding: 020321
338048 - Databus
          [Parkhilfe_01::PH_Tongeber_H_verfuegbar]
                    Reset counter: 140
                    Mileage: 100220 km
                    Date: 2021.06.10
                    Time: 15:58:23
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 18081302090615
   Coding: 003F1320D000048000001001
   VCID: BFCEE64D26292E737A-80EA
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002561162
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [008] - Electrical Failure
                    Reset counter: 180
                    Mileage: 100220 km
                    Date: 2021.06.10
                    Time: 16:05:18
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 1301
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: B326BA7D1A61FA138E-80E6
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 16081303110333
   Coding: 003F11205E00048000801001
   VCID: BE309B492123277B71-80EA
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000002497037
   Coding: 090000
                    Reset counter: 180
                    Mileage: 100220 km
                    Date: 2021.06.10
                    Time: 16:05:18
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029A01105F010200
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 900000
   Part No SW: 5G0 035 020 H    HW: 5G0 035 020
   Component: MU-H-ND-EU    H40 0192
   Serial number: A458H0D7500229
   Coding: 027300010000000021111202002800001F0100340100010097
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 9E707BC981E3477B51-80CA
   Component: ABT_High  H42 0020
   Serial number: VWZ8Z9N2300V09
   Subsystem 2 - Part No SW: V03 959 806 MR    HW: -----------
   Component: ECE 2021  --- 0189
   Compact disc data bank:
   Component: Gracenote  --- 1008
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 140
                    Mileage: 100220 km
                    Date: 2021.06.10
                    Time: 15:57:46
                    Voltage terminal 30: 12.6 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H11 0030
   Revision: 6B001003    Serial number: 00000194338091
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000107988
   Coding: 0101020001020303010301010100000101
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:31, VBatt start/end: 12.6V/12.5V)-----------
[code/]
sers77
Norway
C?ID=26140
Now atleast I can use the car :)
But still need some help with coding ;)
PDC turns on at 15km/h when driving (showing reversing on MIB1) down the road, cannot be turned off.. Unless I stop, but turns on again at 15km/h..
RTA/BSD is still showing not available.. No matter if I activate one or the other..
The doors.. 42 and 52.. I have no clue what has happened.. Started after BSD mirror installation.. Car has China Dynamic LED in both mirrors..
sers77
Norway
C?ID=26140
Byte 26 is the problem and solution..
downtime
Finland
C?ID=280813
Have you tried to clear this error in 3C module with VCDS and then try to enable BSD and RCTA?
338048 - Databus
                    Reset counter: 140
                    Mileage: 100220 km
                    Date: 2021.06.10
                    Time: 15:58:23
Codings look otherwise correct
xabhax
New Jersey, USA
C?ID=437708
You don't need a new abs module, I did this retrofit and did not change my abs unit.
sers77
Norway
C?ID=26140
Yes, but I have no clue how to remove it!?!?
Could it be PDC module? Cannot find anything to code or adapt that helps.
When I activate BSD and put it in reverse (only ign. on) I get "not available"..
TPMS cannot be set either.. "not available"..
downtime
Finland
C?ID=280813
I mean you open module 10, fault codes and clear dtcs
sers77
Norway
C?ID=26140
Just comes right back..
sers77
Norway
C?ID=26140
Changed a few bits in ABS and now the TPMS (via ABS) is ok...
Still no BSD/RCTA..
NEW 01FA6AA12421116D0779060141C52980562488E0608294F31822 50 62 90 82
OLD 01FA6AA12421116D0779060141C52980562488E0608294F31822 F0 62 10 A2
Friday,11,June,2021,11:22:19:21522
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4544.4
VIN: WVWZZZAUZEW111212   License Plate: PIPPI3
Mileage: 100233km-62281mi   Repair Order:
          69 A5
VIN: WVWZZZAUZEW111212   Mileage: 100233km-62281miles
   Revision: WKH02---
   VCID: 648489216F0FADAB47-8030
   VCID: 76A0C369C9932F3BE9-8022
   Coding: 01FA6AA12421116D0779060141C52980562488E0608294F3182250629082
   VCID: 7AB8D759FD8B4B5B8D-802E
   Coding: 030C1C
   VCID: 3A381759BD0B8B5BCD-806E
   Revision: 00001K06
   VCID: 679E9E2D9E39C6B362-8032
   Air quality sensor:
   VCID: 77BECE6DCE995633F2-8022
   Coding: 0E4DFD
   Coding: 06A8DD
   Coding: 0031061151
   VCID: 3D321C45AC25BC63E8-8068
   VCID: 352204659415642320-8060
   VCID: 7F4E264DE6A96E73BA-802A
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   VCID: 0248AFB9955B039BD5-8056
   Coding: 1309
   VCID: 3B36125DB231B253D6-806E
   Generator:
   Component: E221__MFL-DC1  H14 0035
   Coding: 2D0000
   VCID: 73A6FA7DDAE13A13CE-8026
   Coding: 02032103
   VCID: 3C341141B73FB56BDF-8068
   Coding: 020321
338048 - Databus
                    Reset counter: 143
                    Mileage: 100231 km
                    Date: 2021.06.11
                    Time: 11:13:49
   VCID: 3FCE664DA629AE73FA-806A
   Coding: 1301
   VCID: 33263A7D9A617A130E-8066
   VCID: 3E301B49A123A77BF1-806A
   Coding: 090000
   Coding: 900000
   Coding: 900000
   VCID: 1E70FBC901E3C77BD1-804A
End----------(Elapsed Time: 01:27, VBatt start/end: 12.9V/13.1V)-----------
[CODE/]
downtime
Finland
C?ID=280813
How have you coded the park assist module? I mean have you enabled the RCTA/BSD bit there?
sers77
Norway
C?ID=26140
P-assist module is to old.. Getting ERROR 31 on everything when trying to code it... Even after login..
The PLA 3.0 module is not talking to my cluster, so i guess the car needs a few more upgrades..
The emergency brake (hand brake) is only released manually, with seatbelt on or off and doors closed..
sers77
Norway
C?ID=26140
This is with PLA 3.0 module... "Everything" is working except self parking :banghead:
Friday,11,June,2021,16:59:25:21522
VIN: WVWZZZAUZEW111212   License Plate: PIPPI4
          69 A5
   Revision: WKH02---
Readiness: 1110 0001
   Coding: 01FA6AA12421116D0779060141C52980562488E0608294F3382250629082
   Coding: 030C1C
   Revision: 00001K06
   Air quality sensor:
   Coding: 0E4DFD
   Coding: 06A8DD
   Part No SW: 5QA 919 298 E    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0452
   Serial number: 000308417617305
   Coding: 0371065151
   ASAM Dataset: EV_EPHVA2CAU3700000 009038
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 52E85FF905BB531B25-8006
   Coding: 333135
   Coding: 333135
   Coding: 0C00
   Coding: 032519186F9C00081D887E0B440000
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 143
                    Mileage: 100233 km
                    Date: 2021.06.11
                    Time: 16:43:26
   Coding: 1309
   Generator:
   Coding: 2D0000
   Coding: 02032103
   Coding: 020321
                    Reset counter: 143
                    Mileage: 100233 km
                    Date: 2021.06.11
                    Time: 16:49:06
   Coding: 1301
   Coding: 090000
                    Reset counter: 183
                    Mileage: 100233 km
                    Date: 2021.06.11
                    Time: 16:49:06
   Coding: 900000
   Coding: 900000
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
[code/]
