Map Controlled Thermostat
NZDubNurd
New Zealand
C?ID=230482
Hi all,
Just wondering about our 2006 Touran, with the BVY 2.0 FSI NA engine.
It has the Map Controlled Thermostat system, and I'd like to fit a standard thermostat.
I've done it to our BMW, and it logs a code, but doesn't turn on the MIL.
From what I can find, on the Touran ( basically the same as a MK V Golf ) it seems it will log a fault for an open circuit, AND turn on the MIL.
Can I code this out in VCDS?
I had wondered about leaving the old stat plugged in, but fitting the new mechanical one to trick it.
The existing thermostat must be slightly open, as the car takes forever to heat up. I don't want to fit the new expensive version, because I really hope the wheezy 4 cylinder will be turfed out in favour of the 3.2 VR6 fairly soon :-)
Autoscan: Old, but informational:
Thursday,08,January,2015,17:01:55:42165
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WVGZZZ1TZ6W129773   License Plate: TOURAN 1T1
Mileage: 120130km-74645mi   Repair Order:
Chassis Type: 1T (1K0)
VIN: WVGZZZ1TZ6W129773   Mileage: 120130km-74645miles
   Part No SW: 06F 906 056 EM    HW: Hardware No
   Component: MED9.5.10       G00 8229
   Revision: --H03---    Serial number: VWZ7Z0F3307625
   Coding: 0000075
   Shop #: WSC 01324 785 00200
   VCID: 78FFC7DA0B77FEE157B-802D
Readiness: 0000 0101
   Part No: 09G 927 750 CS
   Component: AQ 250 6F           0847
   Coding: 0000072
   VCID: 0407A32A47BFAA014B3-8051
01045 - Tiptronic Switch (F189)
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60-F.lbl
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H13001
   Coding: 0021190
   VCID: 68DF979A5BD76E61C7B-803D
   Part No: 1K0 907 044 BD
   Component: ClimatronicPQ35 090 0808
   VCID: 6ADBED9245DB5C71D1F-803F
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000005382893
   Coding: 008D0F210004100000120C000000000000097B075C
   VCID: 2A5B2D92855B9C7111F-807F
   Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW358  012  0401
   Coding: 00063445
   Shop #: WSC 01324
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 02 AIRBAG VW62 0506 1500
   Revision: 09025000    Serial number: 0038BD0H4NRK
   Coding: 0012338
   VCID: 35610EEE5CE5C3898CD-8060
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0010042
   VCID: 76E3C9E201638891457-8023
   Part No: 1T0 920 862 E
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0000001
   Shop #: WSC 00010 824 70462
   Coding: 0000001
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800106127113D
   Coding: 3F3F0340078003
   Component: IMMO            VDD 4312
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2302
   Coding: 0000692
   VCID: 366309E241E3C891857-8063
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.3   D06 1701
   VCID: 346733EA579FDA81BB3-8061
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 00C802087F2D8405485FC61010CC
   Shop #: WSC 00010 824 05318
   VCID: 79F9C2DE307DE7E9285-802C
   Subsystem 5 - Part No: 1K0 947 291 F
   Component: Innenraumueberw.009 4809
   Coding: 00000000
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Part No: 1T0 959 702 B
   Coding: 0000692
   VCID: 377D04E646E931999E1-8062
   Part No: 1K0 035 186 P
   Component: Radio GR0       015 0019
   Revision: 0001503S    Serial number: VWZ2Z2F3751220
   Coding: 0040400
   VCID: 336530F65291DDB9A29-8066
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2428
   Coding: 0000144
   VCID: 326B35F2AD8BD4B1A9F-8067
   Part No: 1K0 959 704 E
   Coding: 0000144
End-------------------------(Elapsed Time: 01:44)--------------------------
Don't take this as an absolutely definitive answer, but I doubt it.
Also, if you remove the ECU's ability to control the coolant temperature, even if you fool it into not setting an open circuit fault, you will probably end up with a different DTC, such as "Error in mapped cooling system".
NZDubNurd
New Zealand
C?ID=230482
I suspected as much, but you never know - It appears some models don't have it, but then that would be a different engine code.
Cheers.
