2012 2.0CR VW Crafter.
It runs a scan and comesup with the below. It will not allow me to click onto any of the modules on the LT3 tab "no response from controller".
Please can anyone help.
Tuesday,01,June,2021,14:14:29:27111
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WV1ZZZ2EZD6025860 License Plate:
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 843 A HW: 906 900 270 2
Component: IMMO 0805 1246
Revision: 00805000 Serial number: VWXDZ0M1004254
Shop #: WSC 00168 210 87671
VCID: 2517FBB6A9E79853DC5-8070
01312 - Powertrain Data Bus
Address 94: LT3 Airbag
Part No HW: 9069005701
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55F78B76B587C8D38C5-8000
Address 95: LT3 ESP
Part No HW: 0009015901
Serial number: 000901590110851
ASAM Dataset: CRFT2_ESP 3
ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
Part No SW: 9069023301 HW: 9069019800
ASAM Dataset: 32 791
ROD: CRFT_KOMBI_32_791.rod
VCID: 015F8F26118F947380D-8054
Address 99: LT3 Ign. Switch
Part No HW: 9069002702
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
9002 - Voltage: Upper limit exceeded
Test Complete - Stored
9001 - Voltage: Lower limit not reached
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 1246
Revision: 00805000 Serial number: 12345678901234
00171 - Key 1 not learned
002 - Lower Limit Exceeded
Address 9B: LT3 Driver Door
Part No HW: 9068204126
ASAM Dataset: 33 773
ROD: CRFT_FTUHR_33_773.rod (*)
Address B0: LT3 Roof Display
Part No SW: 9069021000 HW: 9069010900
ASAM Dataset: 21 3
ROD: CRFT_DBE_21_3.rod (*)
VCID: 7BA3FDCE7363FEA3DA1-802E
9001 - Terminal 30: Lower limit not reached
90E4 - Instrument Cluster Control Module (J285): No communication
90E0 - Electronic ignition switch (D9): No communication
9020 - Interior light: Short circuit
Test Complete - Active/Stored
9091 - Roof Electronics Module (J528)/ Interior Monitoring Sensor (G273): Comm. error
Address B4: LT3 Central Elec.
Part No SW: 9069022001 HW: 9069013100
ASAM Dataset: 33 833
ROD: CRFT_EZE_33_1088.rod (*)
VCID: 7DA7F3D66D77F093E45-8028
9016 - Right side-marker lights: Short to Plus
9019 - Perimeter lights: Short to Plus
9095 - CAN data bus: No communication
9013 - Left side-marker lights: Short to Plus
Address B6: LT3 Steering Wheel
Part No SW: 9065402645 HW: 9065402645
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 094F970629BFDC33D8D-805C
End----(Elapsed Time: 01:27, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
