Unable to find .ROD file.
   #21
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Tom, when looking at your scan from June 26th, 2021 @ 18:44:01 is clearly shows 01, 93, 94, 95 (ROD Error), 96, 99, 9A, 9B, B0, B4, and B6 being scanned and responding. When you say "only 93, 94, 95, B4 and B6" are you saying that you have a different Auto-Scan result than what you sent us or are you talking about directly accessing the modules via the "Select" menu?
   #22
topcat2006
C?ID=433198
Hi Sebastian,
I'm talking about accessing the modules in the "LT3" tab.
The autoscan is the correct one for this attempt with the beta software.
Tom
   #23
Eric
HC800000
I have looked at the debugs from 96, 99, 9A, 9B, A1 and B0. All show normal comms with CB4548 both in autoscan and normal mode. No failure to connect recorded.
   #24
topcat2006
C?ID=433198
Thanks Eric,
What's the best way to show you the failure I'm getting? Video with my phone?
Tom
   #25
Eric
HC800000
If there's a failure to connect, it should be recorded in the debug files. Start by clearing your debug folder.
You could a screentogif, or a phone video. Phone video would let you show the complete sequence of steps (including ignition, plugging into car/computer, starting VCDS and connecting to the controllers).
First thing to do when you start VCDS is Debug 1024 and Save; then do your magic to show the autoscan works fine with all installed controllers but direct access doesn't. Then send us all the debug files, along with the video or gif (or a link thereto).
   #26
topcat2006
C?ID=433198
Thanks Eric, I'll do that this weekend when I'm back home.
Tom
   #27
topcat2006
C?ID=433198
Hi @Eric , I've sent an email to the support email this morning with a video link and files attached.
Tom
   #28
Eric
HC800000
Thanks for the video, it showed perfectly the cable connection, ignition/engine status and the steps you took!
I think it is just a matter of explaining a couple things now.
The video shows autoscan running through the addresses, and connecting to the expected modules during the autoscan; here is the autoscan for reference:
Thursday,08,July,2021,08:46:51:27111
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4548.4
VIN: WV1ZZZ2EZD6025860   License Plate: WJ13OMD
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTB)       Labels:. 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 Q    HW: 03L 906 012 A
   Component: R4 2,0L EDC   H26 8537
   Revision: 72H26---    Serial number: VWXDZ0M1004254
   Coding: 0119401220440C080000
   Shop #: WSC 131071 102 209715
   ASAM Dataset: EV_ECM20TDI01103L906012Q 002013
   ROD: EV_ECM20TDI01103L906012Q_002.rod
   VCID: 323D10EAE4A9FFEB497-8066
4348 - Please Check Fault Codes in Control Module for HVAC (J301)
          U1025 00 [047] - -
          [A/C control moduleRead out DTC]
                    Mileage: 6810 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Engine RPM: 0.00 /min
                    Coolant temperature: 18 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.020 V
                    Torque request: A/C compressor: 0.0 Nm
                    Status of compressor release-Bits 0-7: 1
                    A/C compressor: refrigerant pressure: 65534 hPa
                    A/C compressor torque: 0.0 Nm
                    Engine status: COENG_READY
11022 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [047] - -
          [Invalid Data Received FromInstrument Panel Cluster Control Module]
                    Mileage: 6810 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Voltage terminal 30: 12.040 V
                    Limitation: accelerator pedal: 91.0 Nm
                    selected gear-Bits 0-7: 0
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 A    HW: 906 900 270 2
   Component: IMMO          0805  1246
   Revision: 00805000    Serial number: VWXDZ0M1004254
   Shop #: WSC 00168 210 87671
   VCID: 2517FBB6A9E79853DC5-8070
Address 94: LT3 Airbag
   Part No HW: 9069005701
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F78B76B587C8D38C5-8000
Address 95: LT3 ESP
   Part No HW: 0009015901
   Serial number: 000901590110851
   ASAM Dataset: CRFT2_ESP 3
   ROD: CRFT1_ESP.rod
No Faults Found
Address 96: LT3 Instruments
   Part No SW: 9069023301    HW: 9069019800
   ASAM Dataset: 32 791
   ROD: CRFT_KOMBI_32_791.rod
   VCID: 015F8F26118F947380D-8054
Address 99: LT3 Ign. Switch
   Part No HW: 9069002702
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  1246
   Revision: 00805000    Serial number: 12345678901234
00171 - Key 1 not learned
Address 9B: LT3 Driver Door
   Part No HW: 9068204126
   ASAM Dataset: 33 773
   ROD: CRFT_FTUHR_33_773.rod (*)
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BA3FDCE7363FEA3DA1-802E
9020 - Interior light: Short circuit
            Test Complete - Active/Stored
Address B4: LT3 Central Elec.
   Part No SW: 9069022001    HW: 9069013100
   ASAM Dataset: 33 833
   ROD: CRFT_EZE_33_1088.rod (*)
   VCID: 7DA7F3D66D77F093E45-8028
Address B6: LT3 Steering Wheel
   Part No SW: 9065402645    HW: 9065402645
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 094F970629BFDC33D8D-805C
End-----(Elapsed Time: 01:04, VBatt start/end: 14.0V/14.2V, Deb=1024)------
Then we go to the LT3 tab and attempt to connect to:
*91-LT3 engine: No response
*99-Ign switch: talks OK
*9A-Central locks: talks OK
*93-LT3 immo: talks OK
*C1-Battery management: no response
91-LT3 engine: Your LT3 actually does not have/use this address. It seems as a general rule the earlier LT3s responded at address 91, the newer ones at address 01; it's possible some respond at both addresses. Notice how in your autoscan it's address 01 that responds. Seeing how this confused you, and there's no "01" on the LT3 tab, I feel maybe we need to make some changes in VCDS to clarify that point. That could be trying both 01 and 91 when the user clicks the latter in the LT3 tab, or having a messagebox to try 01 if 91 fails when connecting manually, or adding 01 to the LT3 tab.
C1-Battery management: just because a module is on the LT3 tab, doesn't mean it is installed in your LT3. VCDS tried to scan C1 during your autoscan, but got no reply; likewise, you're getting no reply when trying manually, because there's no C1 module in your LT3. Same goes for anything in the "scan" list:
01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3 B0 B1 B2 B3 B4 B5 B6 C1
that you are not seeing in your autoscan results: the module just isn't installed in your particular LT3.
Thanks for your testing and patience and getting us all we requested!
   #29
topcat2006
C?ID=433198
Brilliant, thanks @Eric .
My understanding of what you have said is that if I do not use the LT3 tab and instead go to 01 Engine I'll infact connect. I'll give that a go but from what you've explained I'm sure it will work.
Thanks again, and glad to have been able to give you what you need.
Tom
