"Sorry, No coding info available"
rkdork
Irvine, CA, USA
C?ID=405017
Hi, I recently updated to v21.3.0 and upon trying to select the Long Coding Helper, I'm greeted with an error message that says "Sorry, no coding information is available for this ECU. If you would like to help, please send us an Auto-Scan and controller channel map".
I'm unsure why I'm seeing this as I was not having this issue with v20.4.1. I also recently upgraded the firmware on my Hex-V2.
Any idea why I can't use the long coding helper for my 2012 Audi R8 GT like I used to?
Derek
UK (ilexa)
C?ID=56983
Hello
Which ECU are you trying to change the coding on (engine, ABS etc)?
Would you post an autoscan please so the Ross-Tech engineers can see exactly which version of the ECU it is so they can check into it.
If you have one, a previous autoscan from the same vehicle might be useful too
Best regards
Derek
rkdork
Irvine, CA, USA
C?ID=405017
Hello
Best regards
Derek
Hi Derek,
I was trying to change Engine I when I received that error, but I've also tried various other areas and received the same.
Here is the latest scan:
Monday,31,May,2021,12:10:37:02197
VIN: WUA9NAFGXCN900272   License Plate:
Chassis Type: FG-AU35 (7N0)
Scan: 01 02 03 08 09 0F 10 11 31 15 16 17 19 25 2E 37 42 46 47 52
          56 61 65 77 A6
VIN: WUA9NAFGXCN900272   Mileage: 20240km-12576miles
A6-Microphone -- Status: OK 0000
Address 01: Engine (CMP)       Labels: None
   Part No SW: 42B 910 552 A    HW: 420 907 552 B
   Component: 5.2L V10HDZ/4V *   ª0010
   Revision: F5H09---    Serial number: AUX7Z0K8FNG040
   Coding: 011000091B0F0120
   Shop #: WSC 12341 538 411238
   VCID: 1F1BE62BCBBD55A3969-804A
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 420-910-156-V2.clb
   Part No SW: 42B 910 156 A    HW: 420 927 156
   Component: SL600 5.2L FSI HDZ  0030
   Revision: SBH04001    Serial number: 9P4N4AF6L
   Coding: 0000001
   Shop #: WSC 02197 785 00200
   Subsystem 1 - Part No: 420 713 041 C
   Component: A11 C02  12.07.11   0A11
Address 03: ABS Brakes        Labels: None
   Part No SW: 420 907 379     HW: 420 614 517 D
   Component: ESP8 quattro    H01 0200
   Coding: 0004370
   VCID: 59EF88339519FB93A8D-800C
Address 08: Auto HVAC        Labels: 420-820-043.clb
   Part No SW: 420 820 043 G    HW: 420 820 043 G
   Component: J255  Klima 1 Zone  0100
   Revision: 00H06007    Serial number: 00000001194521
   Coding: 0524330
   VCID: 0E45AB6F1C57EC2B0DF-805A
   Part No SW: 8P0 907 063 S    HW: 8P0 907 063 S
   Component: BCM PQ35  H   110 0665
   Revision: 00110 AD
   Coding: 6F000A00A8933624207044E008A0004150926A001100C92ADC080E1C0045
   Shop #: WSC 02391 823 56573
   VCID: 44D149470E9B567BEBB-8010
   Subsystem 1 - Part No SW: 423 955 113     HW: 423 955 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiR  H23 0040
   Coding: 005912
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7L0604226
   Coding: 0000100
   VCID: 3635238F4447F4EB65F-8062
                    Reset counter: 159
                    Mileage: 20244 km
                    Date: 2021.05.31
                    Time: 12:05:35
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X2.clb
   Part No SW: 8P0 919 475 N    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0140
   Revision: 11001001    Serial number: 12561126300752
   Coding: 10010D
   VCID: 49CF587329B98B1318D-801C
Address 11: Engine II        Labels: None
   Shop #: WSC 79671 924 394758
Address 15: Airbags        Labels: 420-959-655.lbl
   Part No SW: 420 959 655     HW: 420 959 655
   Component: SN Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 003B8000F0F9
   Coding: 0021326
   VCID: 5DE79C23813107B3C45-8008
   Subsystem 1 - Part No: 8J0 910 339 A
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 06C9T
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†63328RB4064B11B1Dÿ†63
   Subsystem 5 - Serial number: B11B1Dÿ†63428RB4064B086FTÿ†63
   Subsystem 6 - Serial number: B086FTÿ†63747RB4065F6FD33ÿ†63
   Subsystem 7 - Serial number: F6FD33ÿ†63847RB4065F6E32Zÿ
   Subsystem 8 - Serial number: F6E32Zÿ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Coding: 0003141
   VCID: 41DF40531D894353C0D-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 420-920-xxx-17.clb
   Part No SW: 420 920 981 M    HW: 420 920 981 M
   Component: KOMBIINSTR. VDO H02 0650
   Revision: D0H02002    Serial number: 2248K002000063
   Coding: 0016286
   Shop #: WSC 60124 003 1048576
   VCID: 2019E5D7F6C36A5BAF3-8074
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 200911F1001603
   Coding: 354100
   VCID: 372B2E8B4F4D0DE37E9-8062
   Revision: D0H02002    Serial number: AUX7Z0K8FNG040
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 420 035 785     HW: 420 035 785
   Component: SG ext.Player H08 0100
   Revision: 00000000
   Coding: 020302
   VCID: 52FD7F1FC4EFC8CB697-8006
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 423 035 192 H    HW: 423 035 192 H
   Component: RNS-E PU US     H06 0210
   Revision: 0000013S    Serial number: AUZBZ7L7201085
   Coding: 0730645
   VCID: 1577C40339811FF34C5-8040
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 420 959 801 G    HW: 420 959 801 G
   Component: Tuer-SG         H04 0103
   Coding: 0001141
   VCID: 1D67DC23C1B147B3845-8048
Address 47: Sound System        Labels: 420-035-223.lbl
   Part No SW: 420 035 223 D    HW: 420 035 223 A
   Component: J525 Amp High   H14 0230
   Revision: 00H14001    Serial number: 34844001287206
   Coding: 0246111
   VCID: 094F98736539CB13D8D-805C
   Part No SW: 420 959 802 G    HW: 420 959 802 G
   Coding: 0001141
   VCID: 1E65DB2FCCB75CAB9DF-804A
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0730645
   Component: Batt.regelung H43 1620
   Coding: F3220148
   VCID: 71BFD09361A993D370D-8024
   Subsystem 1 - Part No SW: 420 915 181     HW: 420 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650455815
Address 65: Tire Pressure        Labels: None
   Part No SW: 420 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0040
   Revision: 00050040    Serial number: 00000700007894
   Coding: 0462426
   VCID: 0D47AC631151D733F45-8058
            004 - No Signal/Communication - Intermittent - MIL ON
                    Fault Status: 10100100
                    Reset counter: 162
                    Mileage: 18391 km
                    Date: 2020.08.30
                    Time: 18:01:37
                    (no units): 60.0
                    Voltage: 14.00 V
                    (no units): 61.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
02214 - Tire Pressure Warning
                    Fault Frequency: 18
                    Reset counter: 177
                    (no units): 0.0
                    Temperature: 40.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005158539
   Coding: 0011407
   Shop #: WSC 02556 785 00200
Address A6: Microphone (J886)       Labels:. 420-907-394.clb
   Part No SW: 420 907 394     HW: 420 907 394
   Component: BELTMICBOX    H09 0060
   Coding: 0100010202
   Shop #: WSC 02197 785 00000
   ASAM Dataset: EV_BeltMicAU715 002011
   ROD: EV_BeltMicAU715_002.rod
   VCID: 56F5830FE887D4EB85F-8002
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.1V)-----------
Here is a scan from almost exactly 1 year ago
Sunday,14,June,2020,18:03:00:02197
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
          56 61 65 77 A6
VIN: WUA9NAFGXCN900272   Mileage: 17330km-10768miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
   VCID: 1F1BE62BCBBD55A34A1-804A
005386 - Engine Off Timer Performance
               P150A - 002 -  - Intermittent
                    Mileage: 16688 km
                    Temperature: 23.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.446 V
006435 - Please Check DTC Memory of ECU Number 2
               P1923 - 008 -
                    Fault Status: 01101000
                    Mileage: 17339 km
                    Date: 2020.06.14
                    Time: 18:48:54
                    Temperature: 24.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.446 V
   Coding: 0000001
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -  - Intermittent
                    Mileage: 15878 km
                    Torque: 0.0 Nm
                    Temperature: 16.0°C
                        0.00 %
010119 - Clutch Temperature Too High
               P2787 - 000 -  - Intermittent
                    Mileage: 16887 km
                    Date: 2019.07.18
                    Time: 12:29:34
                    RPM: 942 /min
                    Torque: 96.9 Nm
                    Temperature: 35.0°C
                        23.00 %
   Coding: 0004370
   VCID: 59EF88339519FB93745-800C
   Coding: 0524330
   VCID: 0E45AB6F1C57EC2BD17-805A
   Coding: 0000100
   VCID: 3635238F4447F4EBB97-8062
                    Reset counter: 97
                    Mileage: 17339 km
                    Date: 2020.06.14
                    Time: 19:01:19
   Coding: 10010D
   VCID: 49CF587329B98B13C45-801C
                    Mileage: 16688 km
                    Temperature: 23.0°C
                    Temperature: 27.0°C
                    Voltage: 12.446 V
   Coding: 0021326
   VCID: 5DE79C23813107B318D-8008
   Coding: 0003141
   VCID: 41DF40531D8943531C5-8014
   Coding: 0016286
   Shop #: WSC 29869 002 1048576
   VCID: 2019E5D7F6C36A5B73B-8074
   Coding: 354100
   VCID: 372B2E8B4F4D0DE3A21-8062
   Revision: 00000000
   Coding: 020302
   VCID: 52FD7F1FC4EFC8CBB5F-8006
   Coding: 0730645
   VCID: 1577C40339811FF390D-8040
   Coding: 0001141
   VCID: 1D67DC23C1B147B358D-8048
Address 46: Central Conv.
   Coding: 0246111
   VCID: 094F98736539CB13045-805C
   Coding: 0001141
   VCID: 1E65DB2FCCB75CAB417-804A
   Coding: 0730645
   Coding: F3220148
   VCID: 71BFD09361A993D3AC5-8024
   Coding: 0462426
   VCID: 0D47AC631151D73328D-8058
                    Fault Frequency: 253
                    Reset counter: 0
                    (no units): 0.0
                    Temperature: 40.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0011407
   Coding: 0100010202
   VCID: 56F5830FE887D4EB597-8002
End------(Elapsed Time: 01:25, VBatt start/end: 12.2V/12.2V, udsna)--------
There is no change; 01-Engine did not have a label file in version 20.4.1 either.
What exactly are you trying change in this engine?
What other module(s) are you having difficulties with, and what do you wish to change there?
rkdork
Irvine, CA, USA
C?ID=405017
I wasn't really looking to change anything specific... just browsing for options that may / may not be available. I was able to change my DRL always on while turn signal is on but the electronics coding now is giving me the same errors.
Hmm. 09 -- Cent. Elect. (J519) shows a label file in your latest scan. Labels:. 8P0-907-063.clb
Pleas post a screen shot illustrating the problem.
