Retrofit European DLA headlights to NAR 2017 MK7 Golf R
gruvenwest
Toronto, Canada
H11-2H(?)
Hello All,
Wondering if anyone out there would have some experience with this concern. I recently bought a set of Dynamic Light Assist headlights (5G1 941 043/044 E) that are Euro spec and for PR code '81M'.
My vehicle has High Beam Assist feature and is PR code '81P'. All 4 modules swapped over to the DLA lights and most features -main beams, turn signals, curve lighting motors, DRL's are working fine. Problem is no high beam function. It seems the DLA shutter 'roller' is not active and I'm having issues coding the modules.
From what I have tried with ODIS and VCDS the #55 J745 module can be coded to work with a DLA headlight but the slave modules at the lights do not accept the DLA coding.
Also, part numbers of slave modules don't seem to match some logs I have found on here.
Euro- 3D0941329D coding 90 00 00
NAR- 3D0941329E coding 2E 00 00
Do I just need to get a couple of slave AFS modules from European lights?
HERE IS THE SCAN LOG:
Tuesday,01,June,2021,09:22:01:62505
VIN: WVWWF7AU0HW111644   License Plate:
Mileage: 40551km-25197mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52 55
          5F A5 A9
VIN: WVWWF7AU0HW111644   Mileage: 40551km-25197miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 K    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091900122446000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259K 001005
   ROD: EV_ECM20TFS0208V0906259K.rod
   VCID: 48C9596D423CB9DB073-801C
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 62766000002103
   Coding: 01FA6BA15421096D457D030441C76980D62A90A2C0829637144050D4C0A803
   Shop #: WSC 57450 001 1048576
   ROD: EV_Brake1UDSContiMK100IPB_035.rod
   VCID: 7AADF3A54C501B4BC17-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0420184018
   Coding: 032C0C
   VCID: 3B2336A103EAE2439A1-806E
   Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 00020004200100010105000000101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 72BDDB851420630B897-8026
   Air quality sensor:
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061628500265
   Coding: 00010E46C041A2E149E44000091C07201800000000000000000000000000
   Shop #: WSC 49042 002 1048576
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04518D5D3E945DBBABB-8050
   Component: WWS    160919  043 0551
   Serial number:         161004035006
   Component: RLHS  042 0105
   Serial number: S5Y16M10D20H17M23S24
   Coding: 00A8DD
   Revision: --------    Serial number: 39361628708177
   Coding: 0071155001
   VCID: 43D34E417B1A9A83D21-8016
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 2D0000C151FFC428949C8045000006
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   Serial number: 06091641350105
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 382929AD32DCC95B773-806C
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM0360YL
   VCID: 51FF7409B166781350D-8004
   Serial number: IBH0000J160005T0E20-
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 001 310 16
   Serial number: 357000000004458CAF1V
   Subsystem 3 - Part No SW: -----------    HW: 480 001 310 16
   Serial number: 3580000000035249CE1N
   Subsystem 4 - Part No SW: -----------    HW: 480 403 009 16
   Serial number: 35100029D229A2E2320-
   Subsystem 5 - Part No SW: -----------    HW: 480 400 710 16
   Serial number: 3520002B522C8EB021C6
   Subsystem 6 - Part No SW: -----------    HW: 480 400 110 16
   Serial number: 3550002A1229A2E450C0
   Subsystem 7 - Part No SW: -----------    HW: 480 400 110 16
   Serial number: 3560002A3229A2E2A194
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 25091608491105
   Coding: 0C00
   VCID: 094F9C6919B600D3D8D-805C
   Part No SW: 5G1 920 758 B    HW: 5G1 920 758 B
   Component: KOMBI         304 8311
   Coding: 0BAD08127F88880902886B0B5400000000000000
   Shop #: WSC 93229 999 00000
   VCID: 2E050FF5C09807EB2DF-807A
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005442949
   Coding: 0101000838085900FB00023A880F00000001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA1F5BD4664257BD3B-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29160001640120026342
   Coding: 34FFFF
   Serial number: HA1-00008.09.16
   Coding: 0001
   VCID: 4ACD63655C304BCB117-801E
   Revision: 00000000    Serial number: 16000173740005
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311D9D2EB42D3B5BB-8060
   Serial number: 0417007511
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C2135BD06E4E57B93B-8068
   Serial number: 0417061340
   Coding: 020111
   Serial number: 210916EIK35571
   Coding: 003F1320D000040000000000
   Shop #: WSC 56033 002 1048576
   Serial number: 00000000000011939827
   Coding: 111000
   Coding: 9102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D33A50CD0DB4B817-806E
   Revision: 00000001    Serial number: VWZ8Z1GBA02MJQX
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D87C8F90D1EBCF3545-8038
   Serial number: 220916EIM10412
   Coding: 003F13209C00040000800000
   VCID: 42DD4B456400938BD97-8016
   Serial number: 00000000000011978845
   Coding: 091000
   Coding: 022202003F010400
   VCID: 40D9414D6A0C819BCF3-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3G0 035 047 B    HW: 3G0 035 047
   Component: MU-H-NS-US    H51 0703
   Serial number: A685J0G7501301
   Coding: 027300020000000051220002001828001F0207F401200105DE
   VCID: 1F1BE231B7329E63969-804A
   Subsystem 1 - Part No SW: 5G0 919 606 B    HW: 5G0 919 606 B
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SLR002G0
   Subsystem 2 - Part No SW: V03 959 802 NL    HW: -----------
   Component: NAR 2016  --- 0048
   Compact disc data bank:
   Component: Gracenote2---  --- 3009
          B11CF 53 [009] - Deactivated
                    Reset counter: 113
                    Mileage: 40429 km
                    Date: 2021.05.27
                    Time: 10:49:21
                    Voltage terminal 30: 14.4 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Serial number: 07101612P12281
   Coding: 0003070000000401002223548040490084000E100020
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 160828203567
   VCID: 2F3B12F1C7920EE3269-807A
End----------(Elapsed Time: 01:38, VBatt start/end: 12.3V/12.3V)-----------
downtime
Finland
C?ID=280813
Do you have the same 55 module or is it new as well? If you swap to DLA lights from conventional high beam assist, you also need to parameterize the AFS module 55 to dla parameters. That is something you cannot do with VCDS
gruvenwest
Toronto, Canada
H11-2H(?)
The #55 J745 module is the original that came with the car. I have an ODIS scan tool as well but to configure the module with 'SVM software config' it will set it by VIN# to the NAR specs.
Is there a way to parameterize the module without using the VIN#?
gruvenwest
Toronto, Canada
H11-2H(?)
Can I also just say how good it is to have someone actually know what the hell I am talking about, thank you very much for responding to this. Appreciated.
downtime
Finland
C?ID=280813
No, you always need a VIN for the SVM.
gruvenwest
Toronto, Canada
H11-2H(?)
If I buy all 3 modules used (#55 J745 and both AFS slave modules) from Europe and install, do you think the DLA will be active? Is there anything that would be component protected or need to be configured for a different VIN?
downtime
Finland
C?ID=280813
I think you only need to swap the AFS module. Not the slaves. The slaves are in the headlamps already so if I read you correctly you've bought complete DLA headlights with all modules included?
And the slaves are coded automatically after master is coded correctly so you don't need to code the slaves separately.
I did some googling and AFS module index D I could not find it was used in Passat, in fact I found several references of index C that was used in Passat.
Check this :
Are the DLA lights LED or bixenon?
gruvenwest
Toronto, Canada
H11-2H(?)
The DLA lights are Zenon as this is a pre-facelift Golf R. I swapped all the modules over to the new 81M headlights so the 2 slaves and AFS module are all original to the NAR-81P headlights/vehicle.
Part number of J745 (7P6 907 357 D) seems to match European scan logs and it did accept the coding from the European 81M-DLA lights, but the slaves disappeared with that coding and there were lots of faults. See log below...
GFF log:
Address: 0055 System name: 55 - Automatic vertical headlight aim control Log versions: UDS/ISOTP (Ereignisse: 7)
-Identification:
Data source:Vehicle
Hardware part number:7P6907357A
Part number:7P6907357D
Hardware version number:H07
Software version number:0090
Production date:13.10.2016
Coding:
Coding:02A202104F010200
Ability to flash:Unknown
System name:AFS-ECU
ASAM base version:BV_HeadlRegulUDS
ASAM 2D/ODX data set:EV_HeadlRegulVWAFSMQB
ASAM 2D/ODX data set version:001120
ASAM/ODX control module version being used:EV_HeadlRegulVWAFSMQB_001
Target data container:V03935205NP
Version of the target data container:0001
Equipment code:FF FF FF FF FF FF FF FF FF FF FF FF
System abbreviation:J745
-DTC memory entries (Data source: Vehicle):
DTC memory entry
Number:C107E54: Headlamps no basic setting
Error type 2:active/static
Symptom:5275220
Status:10001001
+Standard ambient conditions:
DTC memory entry
Number:C108131: Left headlamp power output stage No signal
Symptom:5275953
Status:10001001
DTC memory entry
Number:C1081F1: Left headlamp power output stage incorrectly coded
Symptom:5276145
Status:10001001
DTC memory entry
Number:C108231: Right headlamp power output stage No signal
Symptom:5276209
Status:10001001
DTC memory entry
Number:C1082F1: Right headlamp power output stage incorrectly coded
Symptom:5276401
Status:10001001
DTC memory entry
Number:U101400: Control module coded incorrectly
Symptom:13636608
Status:10001001
DTC memory entry
Number:U112100: Databus missing message
Symptom:13705479
Status:00001001
golfi_vend
Tartu, Estonia
C?ID=195131
You need different modules as non-DLA modules do disapear when DLA is coded. Use P/N latest available.
downtime
Finland
C?ID=280813
Ha, for some reason I read you have Passat. So you congratulated me for reading your post too early :D
According to ETKA the module 55 is correct for Golf and also the power modules are correct for DLA lights. For 2017 ETKA says D index power module and you have E, but I'm guessing those are just more recent modules.
So again, parameterization needed for module 55.
golfi_vend
Tartu, Estonia
C?ID=195131
Module E doesn't support DLA. I once had a customer who didn't believe me to the end, but between two visits module E changed to D. Customer claimed he didn't change it.
gruvenwest
Toronto, Canada
H11-2H(?)
That is weird that it supercedes from E to D....usually goes the other way. Even weird-er is that you can get the D module here in NAR where DLA lights don't exist. I checked on 'Parts On Command' and the part is available here in Canada/USA. Not sure if I want to risk the cost of the 2 modules to find out. Is it possible that the scan tool parameterization/adaptation changes the part number?
kevinm
Ireland
C?ID=90940
Rev A modules work also. See stock scan below from my old GTI. Car was built in December 2013 and was the first ever RHD mk7 built with DLA!
NOTE: it is RHD, so coding may differ
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Friday,17,January,2014,19:30:52:64864
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 2B 32 42 44 52 55 5F A5
          A9
VIN: WVWZZZAUZEW228017
Address 01: Engine (J623-CHHA)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0007
   Revision: --H13---
   Coding: 091D00124464050B3000
   ASAM Dataset: EV_ECM20TFS0215G0906259 001011
   ROD: EV_ECM20TFS0215G0906259_VW37.rod
   VCID: EBDEBCD102781046D11-80BE
Readiness: 1010 0001
   Part No SW: 0D9 300 020 D    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H52 4308
   Revision: 03252204    Serial number: TFK01311162844
   ROD: EV_TCMDQ250021.rod
   VCID: 16283D25E97AFDAE5EF-8043
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 63303000000220
   Coding: 01FA93A1542229740377060141CA6980C92A94C0608296F7F84250F9C209
   VCID: 7CFC0F8DF71607FEC8B-8029
Address 05: Acc/Start Auth. (J518)       Labels: None
   Revision: 00021000    Serial number: 0194909574
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3A70C995BDA2F9CE9A7-806F
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120004200100011105000000101000
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 66C84DE5999AAD2E0EF-8033
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011333702086
   Coding: 03011E46C20122FB0B244080B11C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 7BFE0C91F21800C6C11-802E
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    131121  042 0551
   Serial number:         131123075337
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
   Component: RLFS  024 0042
   Serial number: Y13M07D06H08M39S56S1
   Coding: 00A8DD
   Serial number: 000000000ZY133021UG7
   Serial number: 00000000000058181969
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 29111376510469
   Coding: 001C1700FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   ROD: EV_ACCMRRBoschVW372_VW37.rod
   VCID: 3668DDA589BA1DAE7EF-8063
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0115
   Serial number: 16111341354941
   ROD: EV_DRCONTITEMIC.rod
   VCID: F6E89DA5493ADDAE3EF-80A3
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R02YMF
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4182BE79D074AA16DBD-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 003 011 13
   Serial number: 35767000000552805E0O
   Subsystem 2 - Part No SW: -----------    HW: 480 003 011 13
   Serial number: 35867000000CD8115E0/
   Subsystem 3 - Part No SW: -----------    HW: 480 402 311 13
   Serial number: 3516502AD122076361F2
   Subsystem 4 - Part No SW: -----------    HW: 480 402 311 13
   Serial number: 3526502B71220765114R
   Subsystem 5 - Part No SW: -----------    HW: 480 402 311 13
   Serial number: 3556502AB1220765207-
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 28111304400470
   Coding: 0C10
   ROD: EV_SMLSKLOMQB.rod
Address 17: Instruments (J285)       Labels: None
   Part No SW: 5G6 920 870     HW: 5G6 920 870
   Component: KOMBI         314 2210
   Coding: 27AD01187F80000800886A03040000
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: ECDCBFCD0776177ED8B-80B9
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001305056
   Coding: 030100042B085900EF00027B9C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_VW37.rod
   VCID: 3F86B881A680DCE6AD9-806A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Component: E221__MFL-DC1  H06 0038
   Serial number: 27130001947120083472
   Coding: 2DFFFF
   Serial number: 7740921903
   Revision: 00000000    Serial number: 13000272623003
   Coding: DD00000000000000
   ROD: EV_ELVMarquMQB_VW37.rod
   VCID: 346CE7AD9FC60FBE40B-8061
Address 32: Differential Locks (J492)       Labels: None
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8040
   Serial number: HA1-00015.10.13
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001001
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 4796A061FE509426159-8012
   Serial number: 24111306070150
   Coding: 003F1220D001040100001000
   VCID: 4084BB7DDB7EA31ED43-8015
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 9103
   ROD: EV_SteerAssisMQB.rod
   VCID: 356ADAA994BC16B6775-8060
   Serial number: 18111306070985
   Coding: 003F1020DE01040100801000
Address 55: Xenon Range (J745)       Labels: 7P6-907-357.clb
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029603104F010200
   VCID: 3D7AC289AC8CCEF6BF5-8068
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A
   Component: LeiMo links  H05 0012
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A
   Component: LeiMo rechts  H05 0012
   Coding: 900000
   Part No SW: 5G0 035 043 C    HW: 5G0 035 043
   Component: MU-H-N-EU     H42 0290
   Serial number: A309K0D7505944
   Coding: 02730001FF00000011110001000800001F02039601000100D7
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1E382505014AB5EE86F-804B
   Media Player Position 1:
   Component: ABT_High  H51 0022
   Serial number: VWZ8Z9NJ6001ZT
   Engine Control Module 2:
   Subsystem 2 - Part No SW: V03 959 800 GP    HW: -----------
   Component: ECE 2014  --- 0078
   Door Electronics Rear Left:
   Component: Gracenote  --- 1008
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 10000015927
   Coding: 0101020001020303000400000100010100
   ROD: EV_MFKBoschAU370.rod
Address A9: Struct. Borne Sound (J869)       Labels: 5G0-907-159.clb
   Component: SAS-GEN 2     H06 0013
   Serial number: 131119201000
Westbury, UK
AFAIK neither parameterisation nor adaptation will change the part number.
golfi_vend
Tartu, Estonia
C?ID=195131
Module A maybe works here, but on newer modules with 55 module being newer it doesn't.
gruvenwest
Toronto, Canada
H11-2H(?)
I will try to parameterize the #55 module to a ROW VIN w/DLA lights and see what happens as there is no cost involved, if that does not work, I will have to get 2 slave AFS modules '3D0941329D' and see if the '90 00 00' coding is accepted.
Any views on the #A5 module being capable of DLA? The part # of my NAR 2017 Golf R is 3Q0 980 654 G and all the ROW cars seem to have 5Q0 980 653 F installed. Is this a R242 'high' and 'low' version? My vehicle was equipped with High Beam Assist and ACC but I'm not sure if the camera is the same for DLA.
Thanks for all the responses and suggestions.
downtime
Finland
C?ID=280813
Module 55 parameterization is needed anyway for the DLA function to work.
Camera is same for RoW and NAR models
