2016 Skoda Superb III code B2032
VRSCD
Iceland
C?ID=369561
Hi
have a skoda Superb 2016
my lane assist is not working the car has been to the dealer with out much help expect empty my wallet
the code below i s the problem i have any one that can assist with this this is a secondhand unit that was replaced in the car
the dealer now wants to replace this unit and i am not convict throwing 900 euros out for new unit
1807 - No Enable Indentifications Active
B2032 00 [009] - -
[FAULT_SWAP_NO_FSID_ACTIVE]
kind regards
Bo
Monday,31,May,2021,21:41:50:45815
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4543.4
VIN: TMBJH7NP7G7052710   License Plate:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 52 55 5F 6C
          6D BB BC
VIN: TMBJH7NP7G7052710   Mileage: 93581km-58148miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H22 1343
   Revision: B5H22---
   Coding: 011D0012032405087000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002001
   ROD: EV_ECM20TDI01104L906026FL.rod
   VCID: 005981BE9A882C7B8F3-8054
   Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4905
   Revision: 06253104    Serial number: TFK01512082477
   ROD: EV_TCMDQ250021.rod
   VCID: 1D67D8CA0D3AE193845-8048
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63515000001672
   Coding: 1E076A9C34250B6E077E060141C34978562CD0E0608292F51061F078C202
   VCID: 79AFEC5AF9527DB3C8D-802C
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0390053655
   Coding: 030C0C0703
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3A2D3356BCD4B6AB817-806E
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 AG    HW: 3V0 907 044 AG
   Component: AC Automat    H32 3701
   Revision: 20K05000    Serial number: 00000B00049803
   Coding: 12010104002100011005100000101102
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaPrehVW37X 002012
   Rear A/C control head:
   Subsystem 1 - Part No SW: 3V0 907 049 C    HW: 3V0 907 049 C
   Component: E265KlimaHeck  H02 0101
263425 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Reset counter: 2
                    Mileage: 93581 km
                    Date: 2021.05.31
                    Time: 21:11:13
                    Outside temperature: 9.0 °C
                    Voltage terminal 30: 14.3 V
                    System run time-Engine running time: 253 s
                    Air quality status: Malfunction
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061535003330
   Coding: 0C011A46C2C722FB57C44004000C57080800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094F9C9AA9B26D33D8D-805C
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 151204  032 0121
   Serial number: 00000001512020301714
   Coding: 165DDD
   Component: RLHS  037 0059
   Serial number: S2Y16M01D13H13M03S37
   Coding: 00084D
787462 - Relay for Headlight Washer System
          B1262 15 [009] - Open or Short to Plus
                    Reset counter: 2
                    Mileage: 93581 km
                    Date: 2021.05.31
                    Time: 21:11:13
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391600401883
   Coding: 0071151051
   VCID: 44D14DAECE10F05BEBB-8010
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572
   Component: ACC Bosch MQB H03 0196
   Coding: 3200600150FFC428949C8045
   Shop #: WSC 12345 102 209715
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3537206A95CA59D36C5-8060
          B2032 00 [009] - -
                    Reset counter: 2
                    Mileage: 93581 km
                    Date: 2021.05.31
                    Time: 21:11:13
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 14.4 V
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R1CG408
   Coding: 98CCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   Subsystem 1 - Part No SW: -----------    HW: 480 001 812 15
   Serial number: 35700000000A684C781S
   Subsystem 2 - Part No SW: -----------    HW: 480 001 812 15
   Serial number: 358000000006904C781K
   Subsystem 3 - Part No SW: -----------    HW: 480 400 712 15
   Serial number: 3510002B51D73C6392A7
   Subsystem 4 - Part No SW: -----------    HW: 480 400 712 15
   Serial number: 3520002AF1D73C62D23D
   Subsystem 5 - Part No SW: -----------    HW: 480 400 612 16
   Serial number: 3550001B5234EB12C722
   Part No SW: 3Q0 953 521 AA    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20151218401194
   Coding: 1414
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 6FBBD202B7162303669-803A
   Part No SW: 3V0 920 751     HW: 3V0 920 751
   Component: KOMBI         313 6422
   Coding: 07A5091A2B80000801886A011000000000000000
   Shop #: WSC 73430 031 00063
   VCID: 71BFD47AA12235F370D-8024
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 11011610800316
   Coding: 0B0100045F087300EB00024A1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000A2243091215
   Serial number: 2524008903
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: WECHSELRICHTE  H53 0033
   Serial number: 0189554
   Serial number: 15000166045004
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OLI19884
   Coding: 001000000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_001.rod
   VCID: 3B233652B3EE8FA39A1-806E
   Serial number: 201015BJK02518
   Coding: 001D0920DE00040000001100
   VCID: 43D34EB2CB1EF763D21-8016
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000543751
   Coding: 01000010005000
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3D27384AADFA8193A45-8068
   Serial number: 231015BJM13348
   Coding: 001D0320DE00040000001100
   VCID: 42DD4BB6D404FE6BD97-8016
   Coding: 06DA00003F010000
   VCID: 40D941BEDA08EC7BCF3-8014
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B20000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B20000
   Part No SW: 5Q0 035 864 A    HW: 5Q0 035 864 A
   Component: MU-S-N-ER     H24 0245
   Serial number: SKZAZ2R8125463
   Coding: 03840201FF0000001111000100080A002F0200C401200100C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 313F147A61A275F330D-8064
   Subsystem 1 - Part No SW: 3V0 919 605 A    HW: 3V0 919 605 A
   Component: ABT_Std-2_Nav  H44 1028
   Serial number: SKZ8Z9SE600DJM
   Subsystem 2 - Part No SW: 5L0 051 236 E    HW: -----------
   Component: ECE 2015/16  --- 0430
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 04840201A2002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005.rod
   VCID: 77ABEA62CF466BC3BE9-8022
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30428629900000
   Coding: 0D08
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 3FDB4242A7F69383B69-806A
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 261115BKP05107
   Coding: 001801208000040000001100
   Serial number: 261115BKP05047
End----------(Elapsed Time: 01:38, VBatt start/end: 13.3V/13.3V)-----------
@VRSCD : Hi.
hmm...... isn't the DTC telling you that the retrofitted front radar (J428) can't find a SWAP code (i.e. FEC) on the vehicle database?
SWAP is "SoftWare As Product" - it is a type of license that is tailored to the car's VIN and it is usually provided (for the exchange of money) by a dealer.
Features which use J428 require a SWAP license which would have been tailored to the donor car (i.e. ONLY for that car's VIN).
Given that your auto-scan doesn't contain CP errors related to the fitment of J428 - it is clear that the retro-fit exercise has had dealer involvement. Has the license not been discussed as part of this involvement?
PS: Admin- should SWAP be in the forum lexicon?
VRSCD
Iceland
C?ID=369561
@VRSCD : Hi.
HI
the J428 is original equipment to this car but the car had front end accident and the radar unit was replace with the same part number and was install the second-hand unit from the doner , then calibrated
would I still need this SWAP code for that replacement unit ?
kind regards
Bo
HI
kind regards
Bo
Bo: Hi.
So, on MQB platform cars like your Skoda - J428 is captured by the Component Protection constellation. This means that on the first ignition cycle following the installation of the new J428, the master module for component protection (i.e. j533) would have identified that the identity of J428 had changed. This should have triggered a CP error in both the new J428 and in the master CP module.
Now, there are no CP errors in your auto-scan report - which strongly suggests (to me at least) that the vehicle has undergone a process of clearing said CP errors (possilbly by a dealer). Normally this is a multi-part process; one element being the re-alignment of existing licenses (FEC s) for the newly installed module.
