Jetta Sportwagen byte 18 issues
ejaeschke
C?ID=224588
Edit: If someone has the mk6 bixenon LED headlamp configuration in your BCM for a jetta sportwagen/golf variant please post your Address 09 coding
Hello, I am writing to solicit some help in getting the LED DRLs to work on my 2013 Jetta Sportwagen. The compatible Bixenon LED headlamps were recently retrofitted to the car along with some other components including AFS, high beam assist, and park assist. I am pretty sure it is a byte 18 issue in J519 and have read about byte 18 issues:
http://forums.vwvortex.com/showthread.php?5005802-For-those-with-Byte-18-issues-(MK6)
http://forums.ross-tech.com/showthread.php?2-VCDS-MKVI-MK6-Platform-Handy-Coding-tweaks
My own troubleshooting hasn't been able to activate either side, the wiring follows the schematic (with no shorting) and I got some help from here: http://forums.ross-tech.com/showthread.php?2183-Golf-MK6-Bi-Xenon-with-LED-DRL-and-AFS-retrofitted.
Two scans are attached, the first is prior to any part fitment for a baseline and the second is most recent last night. Some faults appear to occur because the car was just put back together.
Any help to activate the LED DRLs is greatly appreciated, thanks!
Auto-Scan baseline:
Tuesday,02,September,2014,19:17:39:62128
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
VIN: 3VWML7AJ0DM693810   License Plate:
Mileage: 15160   Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72 77
   Part No SW: 03L 906 019 HB    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  4817
   Revision: 12H15---    Serial number:
   Coding: 0050072
   Shop #: WSC 00066 000 00000
   VCID: 72C534446D5D918E9D9-8027
   Revision: 00H31001
   Coding: 114B600C492B00FD881306E592190042B70000
   VCID: 7DDF1778E403DEF6F0B-8028
01550 - Signal for Reverse Gear
                    Reset counter: 139
                    Mileage: 21876 km
                    Date: 2012.14.06
                    Time: 21:52:02
                    Count: 16384
                    Count: 32768
                    Count: 12800
                    Count: 202
                    Count: 49664
                    Count: 253
                    Count: 1024
                    Reset counter: 145
                    Mileage: 22335 km
                    Date: 2012.14.20
                    Time: 00:00:32
                    Count: 16386
                    Count: 2
                    Count: 12800
                    Count: 16390
                    Count: 50432
                    Count: 765
                    Count: 12544
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00146
   ROD: EV_ClimaBasis_SE36.rod
   VCID: 75CF0F58D43386B6B8B-8020
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 1068
   Revision: BG021001
   Coding: 2F380E1F802F3EC4008800C17000004449000086535D0560648020200040
   VCID: 3957C368B0AB22D69C3-806C
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 08061  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R01WPH1
   Coding: 00004E42
   Shop #: WSC 00066 790 00185
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C59DA7CB79917FE875-8069
   Subsystem 1 - Part No SW: 1KM 959 339 B    HW: 1KM 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--000079S600
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME33031378ZZZL
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME6E0A1378ZZZ0
   Serial number: 3511HSME0C714A2FZZZW
   Serial number: 3521HSME6106402FZZZG
   Serial number: 35527SME35593B2FZZZT
   Crash sensor for front airbag; passenger side:
   Serial number: 35627SME316B3B2FZZZT
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MF40017L
   Coding: 108A140000
   Shop #: WSC 00066 000 00184
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 72C53444A55D918E9D9-8027
   Serial number: 0204865 FLE 20130410
   Coding: 820000
   Part No SW: 5K0 920 973 C    HW: 5K0 920 973 C
   Component: KOMBI         H05 0705
   Coding: 270F01
   Shop #: WSC 00066 000 00120
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 3147FB4860DBEA96243-8064
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 08061303290220
   Coding: 352002
   VCID: 76CD0854C1358DAEB11-8023
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RNHRR07
   Coding: 0000002
   VCID: FEDD9074A90545EE691-80AB
   Component: IMMO          H05 0705
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EAF5AC240D8DD94EA59-80BF
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664571695
   Coding: 010100
   VCID: 2A75EC24450D994EE59-807F
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3753C55046BF34A66A7-8062
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 050B0500
   VCID: EFC3BD303E6F3C66F27-80BA
   Component: J245EE20SKB13  H05 0220
   Component: J394EE20SKB13  H05 0220
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0006885944
   Coding: 0004B4
   Shop #: WSC 01383 790 50316
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: DC99FAFCD7D9B7FE275-8089
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1509
   Serial number: 00000007813157
   Coding: 000490
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H05 0008
   Revision: -----09S    Serial number: VWZ4Z7N3493697
   Coding: 0100044004000C
   VCID: 2B7BE9204AF780461EF-807E
                    Reset counter: 127
                    Mileage: 576 km
                    Date: 2004.14.07
                    Time: 09:32:23
Auto-Scan current
Monday,13,April,2015,21:59:56:62128
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
Dealer/Shop Name: Ross-Tech LLC.
Workshop Code: 123 00066 000120
Mileage: 32490km-20188mi   Repair Order:
Scan: 01 03 08 09 10 15 16 17 19 1C 20 25 2E 42 44 46 4F 52 55 56
          62 72 77
VIN: 3VWML7AJ0DM693810   Mileage: 32490km-20188miles
   Coding: 0050072
   VCID: 72C534446D5D91B168B-8027
   Revision: 00H31001
   Coding: 114B600C492B00FD881306E592190042B70950
   Shop #: WSC 00066 123 12345
   VCID: 7DDF1778E403DEC9059-8028
                    Reset counter: 41
                    Mileage: 32495 km
                    Date: 2015.04.13
                    Time: 00:01:46
                    Count: 2
                    Count: 2
                    Count: 20480
                    Count: 16390
                    Count: 43008
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW32.rod
   VCID: 75CF0F58D43386894D9-8020
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 81
                    Mileage: 32495 km
                    Date: 2015.04.13
                    Time: 00:05:52
   Part No SW: 5K0 937 087 AD    HW: 5K0 937 087 AD
   Component: BCM PQ35 H    122 0173
   Revision: BK122001
   Coding: 2F380E1FC02F3EC4008800C9710089EC49FD0386537D0560E48428240040
   Shop #: WSC 00066 123 00120
   VCID: 77D30550C63FF4995F5-8022
   Coding: 009F95
   Component: RLS 080213 05  54  0403
   Coding: 0330AD
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 41
                    Mileage: 32495 km
                    Date: 2015.04.13
                    Time: 01:17:41
                    Voltage: 11.65 V
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0043
   Revision: --------    Serial number: 56231324503272
   Coding: 340003
   ASAM Dataset: EV_EPHVA2C000000000 002014
   ROD: EV_EPHVA2C000000000_SE36.rod
   VCID: 4BBB89A0E237A079CBD-801E
12658720 - Databus
                    Reset counter: 41
                    Mileage: 32494 km
                    Date: 2015.04.13
                    Time: 16:40:06
   Coding: 00004E42
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 3C59DA7CB79917C1727-8069
   Coding: 108A140000
   VCID: 72C53444A55D91B168B-8027
   Coding: 820000
   Coding: 170D01
   VCID: 3147FB4860DBEAA9D11-8064
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 130314F1002211
   Coding: 352002
   VCID: 7CD91A7CFF19D7C1327-8029
            000 -  -  - Intermittent
                    Mileage: 32495 km
                    Date: 2015.04.13
                    Time: 00:09:43
   Coding: 0000002
   VCID: 7EDD10742905C5D11C3-802B
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 02018C6B74745D545420363E00
   VCID: 2D7FE73874E38E49F59-8078
   VCID: 6AF52C248D8D5971D0B-803F
   Coding: 010100
   VCID: 2A75EC24450D997110B-807F
                    Reset counter: 78
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0006827757
   Coding: 0004F5
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 5B9B79E052D730F95BD-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1509
   Serial number: 00000007882957
   Coding: 000490
   Revision: 00H22000
   VCID: 3753C55046BF34999F5-8062
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.0 V
                        PD
                    Temperature: 21.0∞C
                    Count: 2
                    Steering Angle: 0.00∞
                    Count: 1
                        SteerAng n.Init
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1642
   Coding: 050B0500
   VCID: 6FC33D30BE6FBC59875-803A
01512 - Control Module for Sliding Roof
                    Reset counter: 81
                    Mileage: 32494 km
                    Date: 2015.04.13
                    Time: 16:39:48
   Coding: 0004B4
   VCID: 5C997AFC57D937C1527-8009
   Slave Passenger:
   Coding: 000490
   Coding: 1446940
   VCID: 3449F25C57C9DF81BA7-8061
   Subsystem 1 - Part No: 7L6 941 329 B
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B
   Coding: 00000022
   Coding: 01000440040007
   VCID: 2B7BE9204AF78079EBD-807E
                    Reset counter: 81
                    Mileage: 32494 km
                    Date: 2015.04.13
                    Time: 16:31:24
            000 -  -
                    Reset counter: 41
                    Mileage: 32494 km
                    Date: 2015.04.13
                    Time: 16:31:18
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664666994
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3A55DC64BDAD29F160B-806F
End-------------------------(Elapsed Time: 02:36)-------------------------
ejaeschke
C?ID=224588
The software revision for the highline BCM I installed seems to be the problem.
Revision: BK122001
I know this issue has been covered before, but perhaps someone can confirm that 0173 is the software revision of the highline BCM from my second auto scan above? It seems quite low for a module produced in late 2012. I would have expected a revision at least 575 and that is required for the LED DRLs... VWoA strikes again!
Yep, 0173 is definitely the software version in your BCM. However, I do not know whether a newer version would be helpful.
ejaeschke
C?ID=224588
Just wanted to share some updates here for other folks who are planning/doing a bixenon LED with AFS headlight conversion to their Jetta Sportwagen. You might also have byte 18 issues associated with it.
LED DRLs:
I currently have limited functionality of the LED DRLs. They operate fine as DRLs, and the lower orange side marker lights are bright. I also set it up so they work only in "auto" position (assistance driving DRL, can’t remember which byte). My LEDs do not dim but turn off completely when the headlights are on, similar to operation of the stock halogens. When the headlights are on and the DRLs are off the orange side marker lights are dimmed substantially.
It seems to be more than just software version for the BCM for the LED DRLs to work at factory functionality. VW has utilized software in the NAR BCMs that appears to differ from the ROW and therefore finding the correct BCM which dims, turns off with turn signal etc. is tough. I think that there are just a select few BCM versions/revisions (possibly older and not newer manufactured for replacements from the dealer) that have the proper software to drive the LED DRLs properly. VW stopped manufacturing the Golf wagon ROW like ours in late 2012 I think. This swap has everything to do with obtaining the correct BCM, I used the 5K0 937 087 G Z5Y.
Byte 18:
You can see how mine is coded in the auto scan below. I reconfigured to allow for a rear fog light and single reverse light. No bulb light errors.
AFS:
My AFS works fine set to Golf coding but I would like adjust it to be more “sensitive” to steering, particularly at low speeds.
Has anyone been able to achieve LED DRL dimming at low beams retrofitted in a Jetta Sportwagen? If so can you please share your code?
Also, can someone recommend a more “aggressive” AFS module code to enable more movement of the headlights who has done this on a Mk6 Jetta Sportwagen?
 Saturday,11,July,2015,09:27:19:62128
Mileage: 35610km-22127mi   Repair Order:
          62 72 77
VIN: 3VWML7AJ0DM693810   Mileage: 35610km-22127miles
   Coding: 0050072
   Revision: 00H31001
   Revision: 00009001
   Coding: 0000001002
   Part No SW: 5K0 937 087 G    HW: 5K0 937 087 G
   Component: BCM PQ35 H+   111 1129
   Revision: BL111001
   Coding: 2F380E3FC82F3EC400080088710089C4497D0486537D05B0E98068040040
   VCID: 3957C368B0AB22E9691-806C
   Coding: 009F95
   Coding: 0730AD
   Coding: 340003
12658720 - Databus
                    Reset counter: 111
                    Mileage: 35618 km
                    Date: 2015.07.11
                    Time: 09:19:17
   Coding: 00004E42
   Coding: 108A140000
   Coding: 820000
   Coding: 170D01
   Coding: 352002
   Coding: 0000002
   Revision: AA001002
   Coding: 010100
   Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0307
   Revision: 12101005    Serial number: 0000206824
   Coding: 0015F6
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 2871162C5301AB6106F-807D
   Slave Driver:
   Coding: 000490
   Revision: 00H22000
   Coding: 050B0500
   Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0307
   Revision: 14101005    Serial number: 0000351841
   Coding: 0015F6
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 29771328480B9269191-807C
   Slave Passenger:
   Coding: 000490
   Coding: 1446940
   Coding: 00000022
   Coding: 00000022
            000 -  -
                    Reset counter: 111
                    Mileage: 35618 km
                    Date: 2015.07.11
                    Time: 09:19:43
   ROD: EV_UHVNA.rod
End
ejaeschke
C?ID=224588
A final update on this. For those who have a 2013 Jetta Sportwagen and wish to add the LED DRL bixenon headlamps, here is my coding for full factory functionality. The magic byte 18 was "4E" for my installation.
Revision: BK122001
Coding: 2F380E3FC82F3EC400080088710089EC47FD4E08537D0560E4806024A040
VCID: 77D30550C63FF48667-8022
Coding: 009F95
Coding: 0730AD
