Active cruise control
onodelta
Bought a 2013 audi s4 with ACC but it requires too much maintenance to constantly keep it running, is there a way vcds can code out acc completely and return to a regular cruise control? I do have clock spring and a regular cruise control stalk that I can install but I dont know if it can be coded out. I was thinking that it is possible since you can retrofit an oem acc kit to different models, so there should be a way to undo it no? is this something vcds can possibly do?
Should be possible, but will require coding changes to quite a few modules, and will probably take a few iterations to get sorted.
Totally different car, so the details aren't applicable to yours at all, but here's a current thread with such a de-contenting conversion in progress:
