Throtle body valve angle question
Mar4ix
Ireland
C?ID=81710
Hi folks. My friend asked me to have a look on his seat leon, 1.6 petrol, BSE engine, 1.6 petrol. Car running a bit rough. I've checked everything, seems to be fine, but when strolling through group 08, at 061 found that throtle valve angle is out of range. -19, but have to be between 1 and 3. Any idea does it affect idling and how to get it sorted?
I have done throtle body alignment, and it was OK.
Please post an Auto-Scan for context.
What do you see from the actual sensors in group 060.1 and 060.2?
What happens to the value in 061.3 when you step on the pedal?
Mar4ix
Ireland
C?ID=81710
thanks. when press accelerator, it just show a lot figures , from -20% to 20 %
attaching autoscan
Friday,28,May,2021,18:43:28:45963
VCDS Version: 21.3.0.0 (x64)
VIN: VSSZZZ1PZ6R083885   License Plate:
Mileage: 246690km-153286mi   Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: VSSZZZ1PZ6R083885   Mileage: 246690km-153286miles
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 FF
   Component: SIMOS71 1.6l 2V     7004
   Revision: --H01---    Serial number: SEZ7Z0F3456212
   Coding: 0002031
   Shop #: WSC 06441 067 57207
   VCID: 68D451255BC050CB6B-803C
Readiness: 0000 1000
   Part No: 1K0 907 379 P
   Coding: 0000641
   Shop #: WSC 06441 785 00200
   VCID: 3F86AA796ECE3773FA-806A
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000003925698
   Coding: 018C0F2F00041000001D00000000000000007F075C
   VCID: 2B5EEE298AB6BBD346-807E
   Subsystem 1 - Part No: 1P0 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SE350  012  0403
   Coding: 00056272
   Shop #: WSC 06441
   Part No SW: 3C0 909 605 H    HW: 3C0 909 605 H
   Component: R4 AIRBAG VW8   027 2521
   Revision: 09027000    Serial number: 003A1P5EQDEP
   Coding: 0021044
   Subsystem 1 - Serial number: 6332MSME0D161E21
   Subsystem 2 - Serial number: 6342MSME103D2179
   Subsystem 3 - Serial number: 6351HTS64IKQPJV2
   Subsystem 4 - Serial number: 6361HTS64IKA1QM2
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksдulenmodul 634 0070
   Coding: 0000012
   VCID: 76E80F5D0174B63BE9-8022
   Part No: 1P0 920 823 E
   Component: KOMBIINSTRUMENT VO3 0422
   Coding: 0002101
   Shop #: WSC 00905 067 57207
   VCID: 2E58E73DB9A4CEFB61-807A
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001063098765
   Coding: 3D0F0140070203
   VCID: 2A50EB2D854CA2DBBD-807E
   Component: IMMO            VO3 0422
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2352
   Coding: 0000688
   VCID: 3668CF5D41F4F63B29-8062
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 346CF5555788E42B17-8060
   Part No: 1K0 959 433 AK
   Coding: 1AC000BC09000505485B090004CC
   VCID: 79F20461306AD94384-802C
   Part No: 1T0 959 702 B
   Coding: 0000688
   VCID: 3776C25946FE0F3332-8062
01553 - Motor for Central Locking; Passenger Door (V57); Lock
   Part No: 1P2 035 152
   Component: Radio BNO           0035
   Coding: 0020400
   VCID: 63CE4609A2E63393BE-8036
End-------------------------(Elapsed Time: 01:23)--------------------------
there is screenshot of live data for few sec.
Mar4ix
Ireland
C?ID=81710
car is overfueling. have replaced all sparkplugs, ignition coil, temperature sensor, map sensor, no obvious inlet manifold leaks, pressure in inlet manifold within range, timing physically checked (marking on camshaft pulley and crankshaft pulley), electronically also - all good, Lambda (oxygen) sensor been replaced recently.
sparkplugs wet and looks dirty.
There is an idea that valve guides and/or oil rings on piston have gone, but there is no obvious smoke, however friend said he had top up oil twice in last half year.
Car runs rough, and idle isnt stable, fluctuates 590-670. Oxygen sensor voltage fluctuates within the range.
that throttle angle in negative .. is it closed too much ? as car was in some garage before, friend said them were doing something with throttle box , " adjusting to make car not to conk out at cross lights" .. wonder them did something to throtlebox ?
edit: also replaced fuel, as fuel was with some sort of contamination. ... i think water.
edit2: also did compression test. all figures fine.
NEtech
Denmark
C?ID=56995
61.3 is some sort of regulation/compensation, Range is -40...+40 %
For angle look at MWB 60 and 62.
Mar4ix
Ireland
C?ID=81710
ok, ill have a look, however in explanation box it states , that at idle should be between 1 and 3 %
NEtech
Denmark
C?ID=56995
In my label file I have written the above mentioned.
I have more than 10 log files, here are a few:
61,640 /min,Omdr.,13.74 V,Volt,-20.3 %,Lambda, 0000,Bin. bits,
61,864 /min,Omdr.,13.94 V,Volt,-13.3 %,Lambda, 0101,Bin. Bits,
61,1536 /min,Omdr.,13.94 V,Volt,-23.4 %,Lambda, 0000,Bin. bits,
;-24.2 %,Lambda,
;-18.8 %,Lambda,
61,0 /min,RPM,11.11 V,Voltage,0.0 %,Lambda, 0000,Bin. Bits,
Mar4ix
Ireland
C?ID=81710
Ok. Thanks.
But still have to find the reason why that car overfueling. I am not really good on vcds, might somebody would point what is the way to figure out what's goin on with that car?
Thanks.
Mar4ix
Ireland
C?ID=81710
Can anyone suggest which group to watch how operates lambda (oxigen) sensor?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Sounds like somebody made a mistake in that label file. It happens.
That'd be me. ;) I looked into this and this is supposed to be throttle valve actuation but as Niels already stated, it looks more like a correction/compensation value. The 06A-906-033-* controllers are not very compliant, when it comes to obeying the VW standards for measuring values. I've clarified this in our description, but honestly the documentation for this ECM from VAG is lacking. *sigh*
Standard groups (30+) should apply.
