Adblue resetting
Jef
HQ
2.0L TDI Engines
Forum post by Peter:
2012-2014 NAR Passat(A32) TDI/CKRA – AdBlue Level Reset Procedure
Prerequisites:
- Engine fully warmed up (above 80’C) and idling​
- Transmission in Park/Neutral​
- Emergency brake = On​
- Doors and hood are closed​
- Driver's seat belt latched. (some cars)​
- Do not depress any pedals during this procedure, until instructed to do so.​
To Reset the AdBlue Level:
- Clear all fault codes(yes, even if there are none present)​
- Select [01-Engine]
- Select [Basic Settings-04]
- From the pull down menu choose:​
- - - [IDE02147-Resetting of learned values of average quantity adaptation], press [Go!]
- - - - After completion, Press [Stop]
- - - [IDE02703-Reset learned values quant. meter. unit and press. contr. valve], press [Go!]
--- [IDE04732-Check of SCR efficiency], press [Go!]
- Depress Brake pedal, then depress accelerator pedal, the ECM should take control of the Engine speed.​
- This test may take up to 30+ minutes to complete!​
- Upon completion, you should see ‘System Okay’, the AdBlue light and the warning message about ‘miles to no start’ will be reset. Verify there are no fault codes.​
Done, end…​
Also see:
TT 26-12-02
2012-2013 Passat TDI – AdBlue Level Reset Procedure
2015 2.0L TDI Generation 3 (EA288) engines such as CRUA and CVCA:
UDS:​
Key on, engine off.​
[Select]
[01-Engine]
[Basic Settings - 04]
IDE04567 Resetting of SCR tank level detection​
[Go!]
Should get message of "Finished Correctly"​
[Stop]
IDE04730 Reset SCR lock​
[Go!]
[Stop]
[Done, Go Back]
If that fails see:
TT 26-17-03
2015 Gen III TDI AdBlue® Light, SCR Light Will Not Reset
3.0L V6 TDI engines:
CATA Generation 1
(CAN protocol/non-UDS):
Save 001 to Adaption Channel 80 to reset the level. If that fails see:​
TT 26-11-03​
2009 - 2010 Touareg​
TT 26-19-01​
2009 - 2010 Touareg Engine Start Not Possible message​
CNRB Generation 2 (UDS protocol):
UDS:​
[Select]
[01-Engine]
[Go!]
[Stop]
[Go!]
[Stop]
[Done, Go Back]
If that fails see:
Jef
HQ
If you have additional information, please contact me privately with details.
