C6 A6 ACC CHANGE TO CCS
Rajeev
South Africa
C?ID=425910
Hi All,
I trust that you are well.
Pls can I request your asisstnce on the above 2005 car. The ACC has some malfunction that the local Audi dealership could not repair, but they did quote me R42k ($3036) to change the sensor.
Instead i would like to change the ACC to normal CCS. The TPMS system failed and i coded that out and removed the fuse.
Below is the scan i did of the car. Currently nothing happens with the ACC lever is pushed/pulled/pressed, not even a ACC Unavaialble on the dash.
Any asssitence will be greatly appreciated.
Wednesday,26,May,2021,14:56:05:48340
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WAUZZZ4F36N051338 License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 13 15 16 17 19 34 36 37 42 46 47 4F
52 53 55 56 61 62 67 6D 72 76 77
VIN: WAUZZZ4F36N051338 Mileage: 249810km-155224miles
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F0 910 401 A HW: 4F0 907 401 B
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 54579 003 1048576
VCID: 1A6C2CF62094749B617-804E
7 Faults Found:
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 000 - - Intermittent
Mileage: 249750 km
Date: 2021.05.25
Time: 15:39:05
Torque: 167.7 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Bin. Bits: 00101100
Torque: 93.6 Nm
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Fault Status: 01110001
Mileage: 249750 km
Date: 2021.05.25
Time: 15:48:02
Torque: 167.7 Nm
Duty Cycle: 1.0 %
Voltage: 11.55 V
Duty Cycle: 15.0 %
Temperature: 32.4°C
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Mileage: 249750 km
Date: 2021.05.25
Time: 15:48:02
Torque: 167.7 Nm
Duty Cycle: 1.0 %
Voltage: 11.55 V
Duty Cycle: 15.0 %
Temperature: 32.4°C
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 001 - Open Circuit
Mileage: 249750 km
Date: 2021.05.25
Time: 15:48:02
Torque: 167.7 Nm
Duty Cycle: 1.0 %
Voltage: 11.55 V
Duty Cycle: 15.0 %
Temperature: 32.4°C
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Mileage: 249750 km
Date: 2021.05.25
Time: 15:48:02
Torque: 167.7 Nm
Duty Cycle: 1.0 %
Voltage: 11.55 V
Duty Cycle: 15.0 %
Temperature: 32.4°C
005650 - Engine Control Module Incorrectly Coded
P1612 - 001 -
Fault Status: 01100001
Mileage: 249752 km
Date: 2021.05.25
Time: 20:44:50
Torque: 167.7 Nm
Duty Cycle: 1.0 %
Voltage: 11.70 V
Bin. Bits: 00101100
Torque: 93.6 Nm
P1653 - 001 - - Intermittent
Fault Status: 00100001
Mileage: 249752 km
Date: 2021.05.25
Time: 20:44:50
Torque: 167.7 Nm
Duty Cycle: 1.0 %
Voltage: 11.70 V
Bin. Bits: 11101100
Torque: 93.6 Nm
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3.0lTDI RdW 0030
Revision: --H01--- Serial number: 4059764
Coding: 0000001
Shop #: WSC 02327 785 00200
VCID: 2312111217DE3553B21-8076
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 C HW: 4F0 614 517 C
Component: ESP 8.0 quattro H03 0090
Coding: 0016776
VCID: 2410120E12D0326BCBB-8070
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10600500213587
Coding: 0000151
Shop #: WSC 02608 996 85516
VCID: 63925112575E7553F21-8036
Subsystem 1 - Part No: 4F0 910 131 C
Component: FBSAUDIC6 EZS H44 0070
Component: FBSAUDIC6 KSG H26 0080
Subsystem 3 - Part No: 4F0 910 220 F
Component: FBSAUDIC6 IDG H01 0060
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 HW: 4E0 035 729
Component: Interfacebox H43 1200
Revision: 00000000 Serial number: 350GW057580677
Coding: 0000002
Shop #: WSC 02335 785 00200
VCID: 5F9A5DE27B3651B3D69-800A
Component: Bedienteil MMIC6H03 0050
Subsystem 2 - Serial number: 00000000197584
Subsystem 3 - Serial number: 0108.07.050000000100010592ÿ
Subsystem 4 - Serial number: 010592ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F2 820 043 J
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000030035580
Coding: 0001302
VCID: 5BE269F26F2E4D93BA1-800E
Fault Status: 00100011
Reset counter: 108
Mileage: 249721 km
Date: 2021.05.24
Time: 14:40:11
Voltage: 13.30 V
Temperature: 25.0°C
(no units): 203.0
(no units): 218.0
Temperature: 25.0°C
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Fault Status: 00101010
Reset counter: 112
Mileage: 249774 km
Date: 2021.05.26
Time: 09:16:00
Voltage: 13.30 V
(no units): 223.0
(no units): 255.0
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H15 0080
Coding: 0012122
VCID: 66944806A46C007B15F-8032
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7201225
VCID: 1B6229F22FAE0D937A1-804E
Address 13: Auto Dist. Reg Labels: 4F0-910-561.lbl
Part No SW: 4F0 910 561 HW: 4F0 907 561
Component: ABSTANDSREGELUNGH15 0250
Revision: -------- Serial number: 00000000000000
Coding: 0031168
VCID: 60985E1E46486E4BEF3-8034
00003 - Control Module
Fault Status: 00101110
Reset counter: 109
Mileage: 249752 km
Date: 2021.05.24
Time: 16:53:44
Temperature: 39.0°C
Voltage: 11.90 V
Bin. Bits: 01000
Hex Value: 0x0055
Hex Value: 0x000A
Lateral Accel.: 0.00 m/s^2
Fault Status: 00101101
Reset counter: 111
Temperature: 20.0°C
Voltage: 11.78 V
Bin. Bits: 01000
Hex Value: 0x2515
Hex Value: 0x0001
Reset counter: 111
Temperature: 20.0°C
Voltage: 11.78 V
Bin. Bits: 01000
Hex Value: 0x2515
Hex Value: 0x0002
Fault Status: 01101101
Fault Frequency: 16
Reset counter: 114
Temperature: 32.0°C
Voltage: 11.65 V
Bin. Bits: 01000
Hex Value: 0x2512
Hex Value: 0x0006
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD08YFV3
Coding: 0013382
VCID: 290E033A75F2EF03F8D-807C
Subsystem 1 - Serial number: 6332CSME0A7C6C47J
Subsystem 2 - Serial number: 6342CSME0B18181E6
Subsystem 3 - Serial number: 6352QSME022B415FH
Subsystem 4 - Serial number: 6362QSME044C2F7DZ
Subsystem 5 - Serial number: 63734SME04421325M
Subsystem 6 - Serial number: 63834SME05083947
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025051830088
Coding: 0102152
Component: Lenkradmodul H07 0080
Part No SW: 4F0 910 930 A HW: 4F0 920 931 D
Component: KOMBIINSTR. M73 H16 0630
Revision: 00000000 Serial number: 4R035CC75
Coding: 3107843
VCID: 211E1B1A0DC22743A0D-8074
Reset counter: 73
Mileage: 249811 km
Date: 2021.05.26
Time: 14:39:21
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 E
Component: Gateway H10 0060
Revision: 10 Serial number: 11009053318073
Coding: EEFE7BCC1B7106
VCID: 270A050263E6D973EE9-8072
Fault Frequency: 17
Reset counter: 113
Mileage: 249752 km
Date: 2021.05.25
Time: 20:35:38
Fault Status: 00101011
Reset counter: 113
Mileage: 249811 km
Date: 2021.05.26
Time: 14:19:27
Address 34: Level Control Labels: 4F0-910-553.clb
Part No SW: 4F0 910 553 HW: 4F0 907 553
Component: J197 LUFTFEDER H15 0040
Serial number: 006280013172
Coding: 0001210
Shop #: WSC 00999 444 64523
VCID: 619E5B1A4D426743E0D-8034
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0091146
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 C
Component: MNS ECE H45 0850
Revision: 00000000 Serial number: 305GP057615761
VCID: 3B22C9728F6E6D939A1-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00-00000
Coding: 0020218
Shop #: WSC 02608 996 65837
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 B HW: 4F0 907 289 B
Component: Komfortgeraet H18 0130
Revision: 01300018 Serial number: 01005488870000
Coding: 3812345
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000210618
Coding: 0000123
Shop #: WSC 02638 996 82379
VCID: 1C602AEE2AA00AAB73B-8048
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000111903
Coding: 0001103
Shop #: WSC 02323 785 00200
VCID: 5EE460E67C3C58BBDDF-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00-00000
Coding: 0020218
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Shop #: WSC 02334 785 00200
VCID: 5DE667EA713A43A3C45-8008
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 D
Component: Dynamische LWR H01 0010
Coding: 0000004
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394BQ077731506
Coding: 0000006
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000073348
Shop #: WSC 04762 996 81293
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1507110036
Coding: 344630393135313035442056413031353037313130303336
Shop #: WSC 00000 640 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H11 0030
Coding: 0019498
VCID: 698E433AB5722F0338D-803C
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 D HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0560
Revision: 00000000 Serial number: 00000503240237
Shop #: WSC 12336 024 394758
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4F9 910 591 HW: 4F9 827 851 B
Component: ValeoHeckdeckel H14 0280
Revision: --H14001 Serial number: E5030000B
Shop #: WSC 23250 431 715754
VCID: 6C803A2EBA803A2B43B-8038
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: KK12.07.05--H14001001B0044ÿ
Subsystem 4 - Serial number: 1B0044ÿ
00317 - Rear Lid Control Module (J605)
Reset counter: 102
Mileage: 248900 km
Date: 2021.04.13
Time: 12:47:06
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H11 0030
Coding: 0019498
Part No SW: 4F0 910 283 C HW: 4F0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 11820518203607
Coding: 0201016
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 C HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007565800
Coding: 0010900
VCID: 221C141608C43C5BB97-8076
End----------(Elapsed Time: 02:11, VBatt start/end: 12.6V/12.5V)-----------
Hi and welcome.
If it were mine, I would start by disconnecting the ACC sensor and removing it from the Gateway Installation list. Then clear all fault codes, take the car for a short drive, and then do another scan so I could see which modules are upset about the ACC no longer being there.
Rajeev
South Africa
C?ID=425910
Hi and welcome.
Hi Uwe, i will do so and revert. Tx.
Rajeev
South Africa
C?ID=425910
Hi,
Just a point of clarity pls, must I physically unplug the radar sensor at the front bumper, or can i remove just the fuse for the ACC system on the left side of the dash?
If it has a dedicated fuse that nothing else gets power from (check wiring diagrams!), then removing the fuse should do the trick.
Rajeev
South Africa
C?ID=425910
Hi all,
So what I did was I reinstalled everything that the car had from factory and scanned the car. I know that the TPMS system is an issue due to the sensors in the wheels.
The first, scan 1, below is of that report.
The second, scan 2, is of Uwe's recommendations, fuse for the ACC out(dedcated fuse - checked wiring diagrams on the net and it does not seem to be connected to anything else), uninstalled in the Gateway and then cleared all codes, short drive and rescan.
Thoughts?
SCAN 1
Thursday,27,May,2021,12:55:48:48340
52 53 55 56 61 62 65 67 6D 72 76 77
VIN: WAUZZZ4F36N051338 Mileage: 249820km-155230miles
Component: 3.0L V6TDI A000AG 0020
Coding: 0011372
Mileage: 249817 km
Date: 2021.05.27
Time: 12:11:46
Torque: 198.9 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Duty Cycle: 15.0 %
Temperature: 22.5°C
Mileage: 249817 km
Date: 2021.05.27
Time: 12:11:46
Torque: 198.9 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Duty Cycle: 15.0 %
Temperature: 22.5°C
Mileage: 249817 km
Date: 2021.05.27
Time: 12:11:46
Torque: 198.9 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Duty Cycle: 15.0 %
Temperature: 22.5°C
Mileage: 249817 km
Date: 2021.05.27
Time: 12:11:46
Torque: 198.9 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Duty Cycle: 15.0 %
Temperature: 22.5°C
Coding: 0000001
Coding: 0016776
Coding: 0000151
Coding: 0000002
Coding: 0001302
Coding: 0012122
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Coding: 0031168
Reset counter: 115
Mileage: 249816 km
Date: 2021.05.27
Time: 12:51:38
Temperature: 34.0°C
Voltage: 11.52 V
Bin. Bits: 01000
Hex Value: 0x0055
Hex Value: 0x000A
Coding: 0013382
Coding: 0102152
Coding: 3315843
Coding: EEFE7BCD1B7106
Coding: 0001210
Coding: 0091146
Revision: 00-00000
Coding: 0020218
Coding: 3812345
Coding: 0000123
Coding: 0001103
Revision: 00-00000
Coding: 0020218
Revision: C63C0030
Coding: 0000321
Coding: 0000004
Coding: 0000006
Coding: 0019498
Address 65: Tire Pressure Labels: 4F0-910-273-HI.lbl
Part No SW: 4F0 910 273 A HW: 4F0 907 273
Component: Reifendruck 3 H04 0070
Revision: 00040070 Serial number: 00000900005501
Coding: 0222420
01467 - Front Left Tire Pressure Sensor (G222)
Fault Status: 11100100
Reset counter: 55
Mileage: 237625 km
Date: 2019.10.14
Time: 12:12:31
(no units): 67.0
Voltage: 13.00 V
(no units): 46.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01468 - Front Right Tire Pressure Sensor (G223)
Reset counter: 55
Mileage: 237625 km
Date: 2019.10.14
Time: 12:12:31
(no units): 67.0
Voltage: 13.00 V
(no units): 49.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01469 - Rear Left Tire Pressure Sensor (G224)
Reset counter: 55
Mileage: 237625 km
Date: 2019.10.14
Time: 12:12:31
(no units): 67.0
Voltage: 13.00 V
(no units): 52.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01470 - Rear Right Tire Pressure Sensor (G225)
Reset counter: 55
Mileage: 237625 km
Date: 2019.10.14
Time: 12:12:31
(no units): 67.0
Voltage: 13.00 V
(no units): 55.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Reset counter: 95
Mileage: 237621 km
Date: 2019.10.14
Time: 12:03:02
(no units): 0.0
Voltage: 13.20 V
(no units): 4.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Reset counter: 102
Mileage: 248900 km
Date: 2021.04.13
Time: 12:47:06
Coding: 0019498
Coding: 0201016
Coding: 0010900
End----------(Elapsed Time: 02:14, VBatt start/end: 12.3V/12.1V)-----------
SCAN 2
Friday,28,May,2021,12:51:32:48340
VIN: WAUZZZ4F36N051338 License Plate: NUM 395
Mileage: 249820km-155230mi Repair Order: 28.05.2021 rev1
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 36 37 42 46 47 4F 52
Coding: 0011372
Mileage: 249817 km
Date: 2021.05.27
Time: 12:11:46
Torque: 198.9 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Duty Cycle: 15.0 %
Temperature: 22.5°C
Mileage: 249817 km
Date: 2021.05.27
Time: 12:11:46
Torque: 198.9 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Duty Cycle: 15.0 %
Temperature: 22.5°C
Mileage: 249817 km
Date: 2021.05.27
Time: 12:11:46
Torque: 198.9 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Duty Cycle: 15.0 %
Temperature: 22.5°C
Mileage: 249817 km
Date: 2021.05.27
Time: 12:11:46
Torque: 198.9 Nm
Duty Cycle: 1.0 %
Voltage: 11.93 V
Duty Cycle: 15.0 %
Temperature: 22.5°C
005673 - Powertrain Data Bus
P1629 - 001 - Missing Message from Auto-Distance Controller
Mileage: 249821 km
Date: 2021.05.28
Time: 12:38:09
Torque: 210.6 Nm
Duty Cycle: 1.0 %
Voltage: 11.25 V
Bin. Bits: 00010100
Coding: 0000001
049412 - No Communication with Cruise Control Module
U0104 - 000 -
Mileage: 249821 km
Date: 2021.05.28
Time: 12:43:34
(no units): 30.0
(no units): 25.0
Temperature: 22.0°C
T.B. Angle: 0.0°
Coding: 0016776
02083 - Message for Delay Request
Reset counter: 75
Mileage: 249824 km
Date: 2021.05.28
Time: 12:52:12
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x002B
Hex Value: 0x0598
Hex Value: 0x00FF
Coding: 0000151
Coding: 0000002
Coding: 0001302
Coding: 0012122
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Coding: 0013382
Coding: 0102152
Coding: 3315843
01319 - Control Module for Distance Control (J428)
Reset counter: 75
Mileage: 249821 km
Date: 2021.05.28
Time: 12:43:35
Coding: ECFE7BCD1B7106
02001 - Data-Bus Automatic Distance Regulation
Reset counter: 75
Mileage: 249821 km
Date: 2021.05.28
Time: 12:43:35
Coding: 0001210
Coding: 0091146
Revision: 00-00000
Coding: 0020218
Coding: 3812345
Coding: 0000123
Coding: 0001103
Revision: 00-00000
Coding: 0020218
Revision: C63C0030
Coding: 0000321
Coding: 0000004
Coding: 0000006
Coding: 0019498
Coding: 0222420
Reset counter: 55
Mileage: 237625 km
Date: 2019.10.14
Time: 12:12:31
(no units): 67.0
Voltage: 13.00 V
(no units): 46.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Reset counter: 55
Mileage: 237625 km
Date: 2019.10.14
Time: 12:12:31
(no units): 67.0
Voltage: 13.00 V
(no units): 49.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Reset counter: 55
Mileage: 237625 km
Date: 2019.10.14
Time: 12:12:31
(no units): 67.0
Voltage: 13.00 V
(no units): 52.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Reset counter: 55
Mileage: 237625 km
Date: 2019.10.14
Time: 12:12:31
(no units): 67.0
Voltage: 13.00 V
(no units): 55.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Reset counter: 95
Mileage: 237621 km
Date: 2019.10.14
Time: 12:03:02
(no units): 0.0
Voltage: 13.20 V
(no units): 4.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Reset counter: 102
Mileage: 248900 km
Date: 2021.04.13
Time: 12:47:06
Coding: 0019498
Coding: 0201016
Coding: 0010900
End----------(Elapsed Time: 02:13, VBatt start/end: 12.4V/12.2V)-----------
01-Engine:
- Coding II with 16167.
- Turn off ignition for 30 seconds. Turn it back on
- Coding II with 11463
02-Transmission:
- Not sure; may sort itself based on Engine.
03-ABS Brakes:
- Not sure.
16-Steering Wheel:
- Change coding from 0102152 to 0102142
17-Instruments:
- Change coding from 3315843 to 3187843
19-CAN Gateway
- I am puzzled why it's still complaining since you removed 13 from the Installation List.
Try making the changes I've found so far, then re-scan the car (after a short test drive) and let's see where we are.
Rajeev
South Africa
C?ID=425910
Hi Uwe,
I have done as you recommended and after clearing codes and driving the car the following is the scan results:
Note: with the current steering wheel coding, the stalk does nothing, no matter the position, etc. Previously, I did get the ACC unavailable message when i tried to engage the ACC.
Saturday,29,May,2021,10:07:45:48340
Mileage: 249820km-155230mi   Repair Order: 29.05.2021 rev0
   Coding: 0011372
               P1698 - 000 -
                    Mileage: 249824 km
                    Date: 2021.05.29
                    Time: 09:54:41
                    Torque: 222.3 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 11.63 V
                    Bin. Bits: 00101100
                    Torque: 93.6 Nm
                    Mileage: 249824 km
                    Date: 2021.05.29
                    Time: 09:56:06
                    RPM: 882 /min
                    Torque: 97.5 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 13.30 V
                    Duty Cycle: 24.1 %
                    Temperature: 18.0°C
                    Mileage: 249824 km
                    Date: 2021.05.29
                    Time: 09:56:06
                    RPM: 882 /min
                    Torque: 97.5 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 13.30 V
                    Duty Cycle: 24.1 %
                    Temperature: 18.0°C
                    Mileage: 249824 km
                    Date: 2021.05.29
                    Time: 09:56:06
                    RPM: 882 /min
                    Torque: 97.5 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 13.30 V
                    Duty Cycle: 24.1 %
                    Temperature: 18.0°C
                    Mileage: 249824 km
                    Date: 2021.05.29
                    Time: 09:56:06
                    RPM: 882 /min
                    Torque: 97.5 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 13.30 V
                    Duty Cycle: 24.1 %
                    Temperature: 18.0°C
   Coding: 0000001
   Coding: 0016776
   Coding: 0000151
   Coding: 0000002
   Coding: 0001302
   Coding: 0012122
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00141886
   Shop #: WSC 02335
   Coding: 0013382
   Coding: 0102142
                    Reset counter: 75
                    Mileage: 249824 km
                    Date: 2021.05.29
                    Time: 09:55:11
   Coding: 3187843
                    Reset counter: 75
                    Mileage: 249824 km
                    Date: 2021.05.29
                    Time: 09:54:07
   Coding: 0001210
   Coding: 0091146
   Revision: 00-00000
   Coding: 0020218
   Coding: 3812345
   Coding: 0000123
   Coding: 0001103
   Revision: 00-00000
   Coding: 0020218
   Revision: C63C0030
   Coding: 0000321
   Coding: 0000004
   Coding: 0000006
   Coding: 0019498
   Coding: 0222420
                    Reset counter: 55
                    Mileage: 237625 km
                    Date: 2019.10.14
                    Time: 12:12:31
                    (no units): 67.0
                    Voltage: 13.00 V
                    (no units): 46.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 55
                    Mileage: 237625 km
                    Date: 2019.10.14
                    Time: 12:12:31
                    (no units): 67.0
                    Voltage: 13.00 V
                    (no units): 49.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 55
                    Mileage: 237625 km
                    Date: 2019.10.14
                    Time: 12:12:31
                    (no units): 67.0
                    Voltage: 13.00 V
                    (no units): 52.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 55
                    Mileage: 237625 km
                    Date: 2019.10.14
                    Time: 12:12:31
                    (no units): 67.0
                    Voltage: 13.00 V
                    (no units): 55.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 95
                    Mileage: 237621 km
                    Date: 2019.10.14
                    Time: 12:03:02
                    (no units): 0.0
                    Voltage: 13.20 V
                    (no units): 4.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Reset counter: 102
                    Mileage: 248900 km
                    Date: 2021.04.13
                    Time: 12:47:06
   Coding: 0019498
   Coding: 0201016
   Coding: 0010900
End----------(Elapsed Time: 02:11, VBatt start/end: 12.3V/12.1V)-----------
That combined with the fact that you now have an "Incorrectly Coded" DTC in 16-Steering wheel has me beginning to wonder: Is the ACC stalk different than the regular Cruise stalk?
Rajeev
South Africa
C?ID=425910
Hi, I think it is as the regular CCS stalk does not have the top button to set the distance between vehicles.
Then you may have to swap it out, but I am not certain.
Rajeev
South Africa
C?ID=425910
Hi Uwe,
Just wondering, in module
17-Instruments:
is there not another number that we should be adding back for CCS (???) as opposed to ACC (0128) so the cluster knows that it must still display CCS infor?
Not as far as I am aware.
Rajeev
South Africa
C?ID=425910
Hi All,
So i noticed that i get the "ESP Fault see owners manual" appearing on the dash when cyclying the key, but no faults under the ABS module. I thought it was related to the battery (2years old - Bosch) and put that on a charger, but the fault still comes up even on full charge.
Any ideas?
JMR
Romania
C?ID=432218
Old thread but i did a a6c6 avant today with just this problem . You are required to unplug acc module .
You need to modify coding in long coding helper in engine 01 with CCS installed , you need to code the CAN gateway without acc. ( uncheck 13 ) in installation list , code instruments without acc in long coding helper , code 5f inf electronics without menu for acc active ( uncheck) , code Steering wheel for CCS.
That s all
Here s the scan with and without acc but with ccs ( scan 2 ). Please ignore other errors as the tail lights were sent for repair.
Friday,02,June,2023,15:07:19:31189
VCDS Version: 23.3.1.0  HEX-NET2 CB: 0.4631.5
Dealer/Shop Name: JMR Car Diagnostic Services
Workshop Code: 599 34641 003519
VIN: WAUZZZ4F0BN056376   License Plate: IF 99 SUD
Mileage: 301230km-187175mi   Repair Order:
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 13 15 16 17 19 42 46 4F 52 53 55 56 5F
          62 72 76
VIN: WAUZZZ4F0BN056376   Mileage: 301230km-187175miles
Address 01: Engine (CAN)       Labels:. 059-907-401-CAN.clb
   Part No SW: 4F7 910 401 L    HW: 4F0 907 401 E
   Component: 2.7TDI EDC17A000AG  0100
   Revision: 16H14---    Serial number:
   Coding: 010D002C190F0228
   Shop #: WSC 66565 257 00032
   VCID: 2C0A6E902A0CAA3A833-8078
   VINID: 9D196AAAA1160127801460C71812574538
8 Faults Found:
001653 - Cylinder 5 Glow Plug Circuit (Q14)
               P0675 - 000 - Electrical Fault
                    Mileage: 299322 km
                    Date: 2022.12.27
                    Time: 13:43:44
                    RPM: 882 /min
                    Voltage: 12.69 V
                    Temperature: 7.2°C
                    Lambda: 21.9 %
                    Temperature: 15.3°C
001654 - Cylinder 6 Glow Plug Circuit (Q15)
               P0676 - 000 - Electrical Fault
                    Mileage: 299322 km
                    Date: 2022.12.27
                    Time: 13:43:44
                    RPM: 882 /min
                    Voltage: 12.69 V
                    Temperature: 7.2°C
                    Lambda: 21.9 %
                    Temperature: 15.3°C
004110 - Torque Intervention to Protect Turbocharger
               P100E - 000 -  - Intermittent
                    Fault Frequency: 168
                    Mileage: 299347 km
                    Date: 2022.12.27
                    Time: 15:31:57
                    RPM: 1827 /min
                    Speed: 109.8 km/h
                    Inj. Quantity: 39.0 mg/str
                    Bin. Bits: 00110100
                    Duty Cycle: 37.5 %
                    Bin. Bits: 00000011
000071 - Boost Pressure Control Valve/Solenoid (Bank 1)
               P0047 - 002 - Short to GND - Intermittent
                    Fault Frequency: 49
                    Mileage: 300796 km
                    Date: 2023.03.29
                    Time: 14:49:17
                    RPM: 2562 /min
                    Inj. Quantity: 59.0 mg/str
                    Voltage: 14.21 V
                    Lambda: 29.7 %
                    Lambda: 33.6 %
                    Lambda: 9.4 %
                    Temperature: 86.4°C
               P0047 - 001 - Short to GND - Intermittent
                    Fault Frequency: 35
                    Mileage: 300905 km
                    Date: 2023.04.02
                    Time: 13:58:45
                    RPM: 2289 /min
                    Inj. Quantity: 23.0 mg/str
                    Voltage: 14.06 V
                    Lambda: 29.7 %
                    Lambda: 52.3 %
                    Lambda: -10.2 %
                    Temperature: 86.4°C
001601 - Sensor Reference Voltage A
               P0641 - 000 - Open Circuit - Intermittent
                    Fault Frequency: 11
                    Mileage: 300101 km
                    Voltage: 10.87 V
                    Torque: 0.0 Nm
                    Bin. Bits: 00000001
                    Bin. Bits: 00000001
004463 - Mass Air Flow Sensor
               P116F - 001 - Interrupted Signal - Intermittent
                    Mileage: 301212 km
                    Date: 2023.05.26
                    Time: 19:46:49
                    Voltage: 2.550 V
                    Lambda: 0.0 %
                    Absolute Pres.: 989.4 mbar
                    Mass Air / Rev.: 1192.6 mg/str
                    Temperature: 27.0°C
000072 - Boost Pressure Control Valve/Solenoid (Bank 1)
               P0048 - 001 - Short to Plus - Intermittent
                    Mileage: 301222 km
                    Date: 2023.06.01
                    Time: 13:18:11
                    RPM: 2730 /min
                    Voltage: 13.91 V
                    Lambda: 29.7 %
                    Lambda: 46.9 %
                    Lambda: -10.2 %
                    Temperature: 88.2°C
Readiness: 0 2 0 0 0
   Part No SW: 4F5 910 156 M    HW: 09L 927 156 C
   Component: AG6 09L 2,7 TDI 140 0030
   Revision: --H05---    Serial number:        4603854
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 323670E80828FCCAC9F-8066
005913 - Functionality limited due to Engine Control Module
               P1719 - 002 -  - Intermittent
                    Mileage: 296755 km
                    Date: 2022.08.27
                    Time: 11:38:10
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BG
   Component: ESP8 quattro    H03 0060
   Coding: 0020872
   VCID: 6E8EA498DC90982AED7-803A
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0210
   Revision: 00H05000    Serial number: 10602901742538
   Coding: 0000131
   Shop #: WSC 44432 003 1048576
   VCID: 251C9BB449E69B725CD-8070
   Subsystem 1 - Part No: 4F0 910 132 G
   Component: FBSAUDIC6 EZS   H06 0020
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0054
                    Reset counter: 120
                    Mileage: 291486 km
                    Date: 2021.12.15
                    Time: 19:38:20
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000077    Serial number: 00000030606156
   Coding: 0000278
   VCID: 1D6CB35461B653B204D-8048
   Part No SW: 4F0 910 279 AB    HW: 4F0 907 279
   Component: ILM Fahrer      H27 0360
   Coding: 0013121
   VCID: 6984D784E57E7F12B85-803C
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H11 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 157CAB7495860BF2CCD-8040
   Part No SW: 4F0 910 561 C    HW: 4F0 907 561 B
   Component: ABSTANDSREGELUNGH03 0020
   Coding: 0051168
   VCID: 231885AC47D26542329-8076
02002 - Heater for Distance Regulation Sensor (Z47)
            009 - Open or Short to Ground
                    Fault Status: 01111001
                    Reset counter: 3
                    Mileage: 294257 km
                    Date: 2022.04.26
                    Time: 20:09:10
                    Temperature: 24.0°C
                    Voltage: 12.67 V
                    Bin. Bits:    01000
                    Hex Value: 0x2A11
                    Hex Value: 0x0002
                    Speed: -3.6 km/h
                    Lateral Accel.: -0.12 m/s^2
                    Fault Frequency: 9
                    Reset counter: 77
                    Mileage: 298662 km
                    Date: 2022.12.05
                    Time: 15:52:14
                    Temperature: 5.0°C
                    Voltage: 10.62 V
                    Bin. Bits:    01000
                    Hex Value: 0x2512
                    Hex Value: 0x0006
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 Q    HW: 4F0 959 655 G
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003F9004HGM0 Dataset Number: 4F0909602AC 0013
   Coding: 30314236303630303031554A304C34463053
   ROD: EV_Airba10AURB4_AU56.rod
   VCID: 353C4BF4F5C6EBF2ECD-8060
   Serial number: 3574SRB40000D338EA6H
   Serial number: 3584SRB40000D360A10.
   Serial number: 3516HRB402S076KATBHW
   Serial number: 3526HRB402JEO0UONRD-
   Serial number: 3554NRB400005F8D3E7I
   Serial number: 3564NRB400005F51B696
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026110040068
   Coding: 0002152
   VCID: 270091BC33EA89626E1-8072
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 934 A    HW: 4F0 920 934 A
   Component: KOMBIINSTR.   H09 0209
   Revision: 00000000    Serial number: FKH41RNDA
   Coding: 0357120506000008000000
   Shop #: WSC 12345 123 61029
   VCID: 261E9CB838E0906A557-8072
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Serial number: 3000M10C0402DB
   Coding: 000303
   Shop #: WSC 02391 823 56573
   VCID: 3A2658C8DC58048A01F-806E
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790378206
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0361
   Revision:             Serial number: 0008000170014
   Coding: 011F02204040410001
   VCID: 48C2320092B4661A87B-801C
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01414951300000
   Coding: 0139909
   VCID: 353C4BF4F946EBF2ECD-8060
                    Fault Status: 01101001
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:25
01506 - Bulb for Rear Fog; Right (L47)
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:27
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:28
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:30
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:32
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:33
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000590067
   Coding: 0001003
   VCID: 5EEEF4582C3008AA5D7-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0008000177274
   Coding: 011F02204C40410001
   VCID: 47C0313C9FAA69628E1-8012
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000521
   Shop #: WSC 02145 785 00200
   VCID: 21148FA45DCE7752205-8074
   Part No: 8P0 907 357 M
   Coding: 0000003
   VCID: 44DA2630A29C427A6B3-8010
   Part No SW: 4G0 035 056 D    HW: 4G0 035 056
   Component: Radio U STD   H52 0094
   Revision: AB001007    Serial number: 469A/0B7653580
   Coding: 010003020100000000
   VCID: 221680A854C86C4A39F-8076
   Part No SW: 4E0 035 666 H    HW: 4E0 035 666 C
   Component: H-BN-EU       H51 0174
   Revision: --------    Serial number: 454A+0B7575179
   Coding: 010100010002CBED01000315EF6300030001
   VCID: 2B086D8C2302AD028A9-807E
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Serial number: 9466AZ0B0287960
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 S
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001755559
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
                    Reset counter: 63
                    Mileage: 301084 km
                    Date: 2023.04.15
                    Time: 20:48:07
                    Voltage: 13.60 V
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0361
   Revision:             Serial number: 0004000184032
   Coding: 010E00204040220001
   VCID: 46DE3C3898A0706A757-8012
   Component: TSG HR        H11 0361
   Revision:             Serial number: 0004000184006
   Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Component: Parkhilfe 4-Kan H03 0500
   Revision: 00H03000    Serial number: 37231101102443
   Coding: 0201016
   Shop #: WSC 12345 111 45799
   VCID: 2904978425FEBF12785-807C
01545 - Sensor for Parking Aid; Rear Left (G203)
                    Fault Status: 00101001
                    Fault Frequency: 13
                    Reset counter: 116
                    Mileage: 296688 km
                    Date: 2022.08.22
                    Time: 10:11:23
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 296399 km
                    Date: 2022.08.04
                    Time: 09:06:42
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                    Fault Frequency: 22
                    Reset counter: 116
                    Mileage: 296830 km
                    Date: 2022.09.04
                    Time: 10:18:05
End----(Elapsed Time: 01:39, VBatt start/end: 11.7V/11.9V. VIgn 11.9V)-----
Friday,02,June,2023,16:52:16:31189
VIN: WAUZZZ4F0BN056376   License Plate: IF 99 SUD CCS
Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 4F 52 53 55 56 5F 62
          72 76
   Component: 2.7TDI EDC17G000AG  0100
   Coding: 010D002C190F0128
   Shop #: WSC 34641 599 03519
049717 - No Communications with Cruise Control (Front) Distance Sensor
               U0235 - 002 -  - Intermittent
                    Mileage: 301235 km
                    Date: 2023.06.02
                    Time: 16:21:17
                    Voltage: 12.31 V
                    Bin. Bits: 00000000
                    (no units): 0.0
                    Bin. Bits: 00000000
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 001 -  - Intermittent
                    Mileage: 301235 km
                    Date: 2023.06.02
                    Time: 16:25:53
                    (no units): 0.00
                    (no units): 0.00
                    Bin. Bits: 00000000
                    Bin. Bits: 00000100
                    Bin. Bits: 01000000
   Coding: 0000002
   Coding: 0020872
   Coding: 0000131
                    Reset counter: 76
                    Mileage: 301237 km
                    Date: 2023.06.02
                    Time: 16:46:13
   Coding: 0000278
   Coding: 0013121
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Revision: AA001001
   Coding: 0002142
                    Reset counter: 76
                    Mileage: 301237 km
                    Date: 2023.06.02
                    Time: 16:46:09
   Coding: 0357120502000008000000
   Coding: 000303
                    Reset counter: 76
                    Mileage: 301237 km
                    Date: 2023.06.02
                    Time: 16:46:09
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 7
                    Bin. Bits:    10011
   Coding: 0139909
10 Faults Found:
                    Fault Frequency: 11
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:25
                    Fault Frequency: 11
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:27
                    Fault Frequency: 11
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:28
                    Fault Frequency: 11
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:30
                    Fault Frequency: 11
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:32
                    Fault Frequency: 11
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 15:08:33
02930 - Control Circuit for Brake Light in Fender; Right
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 16:14:34
02931 - Control Circuit for Brake Light in Fender; Left
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 16:14:34
02932 - Control Circuit for Brake Light in Trunk/Hatch Lid; Right
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 16:14:37
02933 - Control Circuit for Brake Light in Trunk/Hatch Lid; Left
                    Reset counter: 76
                    Mileage: 301234 km
                    Date: 2023.06.02
                    Time: 16:14:37
   Coding: 0001003
   Revision: --H05---
   Coding: 0000521
   Coding: 0000003
   Coding: 010100010002C3ED01000315EF6300030001
                    Reset counter: 76
                    Mileage: 301237 km
                    Date: 2023.06.02
                    Time: 16:46:21
                    Voltage: 12.40 V
   Coding: 0201016
End----(Elapsed Time: 01:34, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
