Audi S3 8V "Vehicle lights malfunction" and no error in vcds scan
AudiS3S5
Switzerland
C?ID=443421
Hi,
The car have full led headlights and "Vehicle lights malfunction" warning is displayed on the dashbord.
Then i scan the car with VCDS or Odbeleven, no errors are found.
I tested my headlights on another same car and no error. The headlights are ok.
Any suggestion ?
AudiS3S5
Switzerland
C?ID=443421
I forgot to mention than all fonction are ok, leveling, turn signal, high beam, low beam, drl, etc..
Hi and welcome.
Even though there are no fault codes, please post an Auto-Scan for context.
m87a
Bosnia and Herzegovina
C?ID=156900
is this this retrofit? did you change adaptations? also post adaptaions
some of the possible issues are that if module doesnt support xenon or led and you set up adaptation for example you set low beam to led or xenon there is no dtc but there is warning in dash
AudiS3S5
Switzerland
C?ID=443421
Tuesday,25,May,2021,17:46:13:27707
VIN: WAUZZZ8V6EA067119   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 42 44 52 55
          5F A5 A9 BB BC D6 D7
VIN: WAUZZZ8V6EA067119   Mileage: 118071km-73365miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259     HW: 06K 907 425 A
   Component: 2.0l R4 TFSI  H09 0006
   Revision: --H09---
   Coding: 0A1D00322466010B3004
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0218V0906259 001008
   ROD: EV_ECM20TFS021_AU37.rod
   VCID: 7DA7F0F9BD77AD53E45-8028
Readiness: 1110 0001
   Part No SW: 0D9 300 011 N    HW: 02E 927 770 AN
   Component: DQ250-6A MQB  H52 4033
   Revision: 05652104    Serial number: TFK01308160712
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 2019E98D6A4520BBAF3-8074
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 6247300000040D
   Coding: 32F16BA254262A730178070141CC694CD62A5480E08296F6F84150788508
   VCID: 7CA1FDFDA66DA45BD3B-8028
   Revision: 00021000    Serial number: 0194353466
   Coding: 030C0C
   VCID: 3A2D3BE5ECD95A6B817-806E
   Part No SW: 8V0 820 043 A    HW: 8V0 820 043 A
   Component: AC Automat    H13 0032
   Revision: 20024000    Serial number: 00000000147882
   Coding: 03000014000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   VCID: 303919CD3AA5903B3F3-8064
   Humidity sensor: exterior:
   Serial number: B13947C6000000000001
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011325400136
   Coding: 04111D46C2C106FD03844004B31C07A8080C000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77ABE2D19F4B8703BE9-8022
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130826  041 0580
   Serial number:         130903195107
   Coding: 0A47F7
   Serial number: 21707138
   Coding: 00006C
   Serial number: 12 12 2019  20001688
   Serial number: 000000000ZY1321112V6
   Serial number: 00000000000027726628
   Sunroof control module:
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO2375859D
   Coding: 901E00
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231321301289
   Coding: 0070050051
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   VCID: 3B233EE1E3E363639A1-806E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 H    HW: 5Q0 907 567 H
   Component: ACC3          H09 0095
   Serial number: 14081375030856
   Coding: 003E1701FE0309
   ASAM Dataset: EV_ACCBoschMQB 001022
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 40D9490D8A0500BBCF3-8014
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R035B7.
   Coding: 98FCC0000C0000005C5400CA004800000065
   VCID: 4BC36E21B343D3E32A1-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 209 13
   Serial number: 357670000002378CDD00
   Subsystem 2 - Part No SW: -----------    HW: 480 000 209 13
   Serial number: 358670000001178CDD0+
   Subsystem 3 - Part No SW: -----------    HW: 480 400 909 13
   Serial number: 3516502B71118712710Q
   Subsystem 4 - Part No SW: -----------    HW: 480 400 909 13
   Serial number: 3526502A71118713708Y
   Subsystem 5 - Part No SW: -----------    HW: 480 400 908 13
   Serial number: 3556502C31088B03117
   Subsystem 6 - Part No SW: -----------    HW: 480 402 408 13
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502B510EDE4421AI
   Subsystem 7 - Part No SW: -----------    HW: 480 402 608 13
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502B71088B12B101
   Subsystem 8 - Part No SW: -----------    HW: 480 402 608 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502B11088B13C2C2
   Part No SW: 8V0 953 521 BD    HW: 5Q0 953 549
   Revision: --------    Serial number: 06091308491389
   Coding: EC18
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   Part No SW: 8V0 920 870 N    HW: 8V0 920 870 N
   Component: KOMBI         H03 2212
   Coding: 078D081A6F8400080081E800000000
   VCID: 46D55F15A8212E8BF5F-8012
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000950793
   Coding: 030100042B085A005B0002781C0B00000001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 14 08 2013  D0291159
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051996294
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00031.07.13
   Coding: 0001
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   VCID: 42DD4305840912ABD97-8016
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000200002005
   Coding: 0900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73B3D6C18B33EB23821-8026
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 05091304080238
   Coding: 001C9E205C00040000001003
   VCID: 3FDB4AF1F7FB7F43B69-806A
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 9101
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: 333316C1CBB3AB23421-8066
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 08091304081117
   Coding: 001C96205E00040000001003
   VCID: 3E2537F5F0F1764BBDF-806A
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0EEA04103B230200
   Shop #: WSC 06443 128 28888
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   Part No SW: 8V0 035 020 N    HW: 8V0 035 020
   Component: MU-H-ND-EU    H42 0198
   Serial number: A305H0GB007382
   Coding: 01730301FF0A000021111101000A00002F000205010001009E
   Shop #: WSC 49104 001 1048576
   ROD: EV_MUHig6C3HBAS_VW48.rod
   VCID: 36352FD5D8C1BE0B65F-8062
   Subsystem 1 - Part No SW: V03 959 802 CQ    HW: -----------
   Component: ECE 2019  --- 0172
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8V0 919 604 A    HW: 8V0 919 604 A
   Component: DU High  H49 0013
   Serial number: AUZ8Z9DG500GAR
   Subsystem 3 - Part No SW: 8V0 919 614 J    HW: 8V0 919 614 E
   Component: ControlUnit_H  H64 0764
   Serial number: C1000012071300010101
   Compact disc data bank:
   Component: Gracenote  --- 1008
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000109326
   Coding: 0101010001010303000500000100000100
   ROD: EV_MFKBoschAU370.rod
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0008
   Serial number: 130702200407
   Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
   Component: TSG HFS       010 0006
   Serial number: 31081301100389
   Coding: 000C96204000040000001002
   VCID: 41DF4C09810F09B3C0D-8014
   Component: TSG HBFS      010 0006
   Serial number: 31081304080390
   VCID: 176BC251BF0B67035E9-8042
End----------(Elapsed Time: 01:58, VBatt start/end: 12.0V/12.0V)-----------
vastechnics
C?ID=143747
when you have this fault you have the triangle with the fault? When you try to go in 09, will the traingle dissapear?
AudiS3S5
Switzerland
C?ID=443421
I m87a, yes it's a retrofit. The full led headlights pre-facelift are upgrated to Facelift version. the 55 Range was changed and 3 charnels for each headlights was changed in 09.
AudiS3S5
Switzerland
C?ID=443421
Hi vastechnics, yes with the fault i have the triangle and the triangle dont dissapear then i select 09 and i go for coding for exemple.
AudiS3S5
Switzerland
C?ID=443421
;SW:8V0-907-357-A   HW:7P6-907-357-B ---  Headlight Range --- SA: 20103
;Component:MxB-ECU       001 0230, Coding:0EEA04103B230200
;EV_HeadlRegulAUDIMXBAU64X,005014,EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
;Thursday,20,May,2021,19:32:10:27707
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
;VCID: 3E2537F5F0F1764BBDF-806A
IDE01996-SFT00041-Installation list: specified installations-Left light control,Yes ,1
IDE01996-SFT00057-Installation list: specified installations-Right light control,Yes ,1
IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,Yes ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE08418-Matrix light: total dimming,100.8 ,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,6
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG100660-PWM to Level Scaling Factor Front,3.30 mm/%,2
ENG103748-PWM to Level Scaling Factor Rear,5.50 mm/%,2
ENG124607-Reference_Run_Activation_Effect,Activation effect enabled by motor start ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
Elapsed Time: 00:05
AudiS3S5
Switzerland
C?ID=443421
;SW:5Q0-937-084-AA   HW:5Q0-937-084-AA ---  Cent. Elect. --- SA: 31347
;Component:BCM MQBAB H   H14 0112, Coding:04111D46C2C106FD03844004B31C07A8080C000000000000000000000000
;EV_BCMCONTI,011001,EV_BCMBOSCH_011.rod
;Thursday,20,May,2021,19:30:23:27707
;VCID: 77ABE2D19F4B8703BE9-8022
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,active ,9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8 ,9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,not active ,9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active ,9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,active ,9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,1000 ms,9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1200 ms,9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,1000 ms,9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,1000 ms,9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,1200 ms,9
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,active ,9
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,9
IDE01550-Service position,133.197670 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,No ,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,No ,2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,2
IDE02488-Anti-theft system interior monitoring,100 %,1
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen,not active ,3
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf,not active ,3
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken,not active ,3
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck,active ,3
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,3
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,3
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,3
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,3
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW,not active ,3
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,not active ,3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel,not enabled ,4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %,4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled ,4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,4
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,-0.25 °,13
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,50.0 %/s,13
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,OFF ,13
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.0 km/h,13
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C,13
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.0 °C,13
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,90 °,13
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.0 °C,13
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,30 °,13
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,32.0 km/h,13
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,OFF ,13
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separate ,3
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,3
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS ,3
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,3
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,3
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,3
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.248 %,3
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,1.0 %,3
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,separate ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active ,14
IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,not active ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic ,5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,16 ,5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,2 ,5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,20 seconds ,5
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,1 Minute ,5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,5
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,5
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,8
IDE04927-ENG116709-Window heater-Abschalttemperatur für Frontscheibenheizung,35.0 °C,8
IDE04927-ENG116708-Window heater-Abschalttemperatur für Heckscheibenheizung,35.0 °C,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,Default ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,1
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,1
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,driver door contact thatcham ,1
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,1
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,1 Alarm ,1
IDE04928-ENG148904-Anti-theft protection-Überwachung Innenentriegelungshebel,active ,1
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,4
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active ,4
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,4
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,not active ,4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,4
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,4
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active ,4
IDE05142-ENG115755-Access control-Notschließfunktion,not active ,4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,4
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,4
IDE05142-ENG115758-Access control-Valet Parking,not active ,4
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,4
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,active ,4
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,00 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,00 ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,00 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,00 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,08 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,18 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,00 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,09 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1C ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,00 ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,00 ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,00 ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,00 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,00 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,00 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,00 ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,minimize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,minimize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,0 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,0 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,0 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,0 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,127 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,30 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,30 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,100 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,127 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,100 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,100 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,100 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,100 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,127 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,0 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,30 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,30 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,0 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,127 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,127 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,127 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,127 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,127 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,00 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,00 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,00 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,00 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,41 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,42 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,00 ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2F ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,00 ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,03 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,04 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,05 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,06 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,00 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,00 ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,00 ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,00 ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,03 ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,04 ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,not active ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,not active ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,not active ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,not active ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,38 - LED Blinkleuchten ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,38 - LED Blinkleuchten ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,6 - LED Lichtmodul ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,39 - LED Bremsleuchten ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,39 - LED Bremsleuchten ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,37 - allgemeine LED bis 12W ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,8 - allgemeine Glühlampe 12W ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,6 - LED Lichtmodul ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,46 - LED Kleinleistung ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,6 - LED Lichtmodul ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,6 - LED Lichtmodul ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,6 - LED Lichtmodul ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,6 - LED Lichtmodul ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,46 - LED Kleinleistung ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,46 - LED Kleinleistung ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,only_if_closed ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,0 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,0 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,40 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,0 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,0 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,2 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,4 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,40 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,26 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,26 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,40 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,45 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,46 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,47 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,48 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,45 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,46 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,20 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,30 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,30 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,30 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,30 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,30 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,0 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,0 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,8 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,3 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,5 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,3 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,5 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,0 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,9 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,10 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,0 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,8 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,8 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,30 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,30 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,9 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,9 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,10 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,10 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,2 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,4 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,6 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,3 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,3 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-Anti-theft alarm system vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 09 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 FF F6 06 00 0F 1E 00 85 0F 32 F7 64 23 45 21 57 9B 24 42 3F 3A 69 58 95 2D 09 A3 02 FF F6 56 00 0F 1E 00 86 28 32 F7 65 0F 43 21 57 1B 03 32 3F 3A 69 58 93 0D 09 A3 03 F5 F6 26 00 0F 19 00 88 0F 2D F7 68 1E 45 21 57 1B 03 22 3F 3A 69 58 93 0C 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 66 23 45 21 57 9B 23 22 0C FA 0A 34 95 0D 09 A3 21 43 34 02 02 02 02 02 02 B1 20 24 2B 3F ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,14
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,14
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,20.00 °C,14
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,19.00 °C,14
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C,14
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C,14
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,14
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,14
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C,14
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C,14
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,50.00 °C,14
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,49.00 °C,14
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C,14
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C,14
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten,not active ,6
IDE06096-ENG116597-Interior lights-KL30G ohne PWM,active ,6
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe,not active ,6
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten,active ,6
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung,active ,6
IDE06096-ENG116595-Interior lights-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung,active ,6
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert,50 %,6
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag,Daytime running lamps ,2
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active ,2
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,2
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,2
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,2
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO,not active ,2
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,2
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte,not active ,2
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,2
IDE07007-ENG148891-Air conditioning/heating function via remote control-Anzahl zulaessiger Remotestarts,2 ,2
IDE07007-ENG148876-Air conditioning/heating function via remote control-RemoteStart Betrieb Dauer,10 min,2
IDE07356-Position during interval mode,21.197781 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,5
IDE08542-IDE02021-Access control 2-Comfort closing,active ,6
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,not active ,6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active ,6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,6
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,not active ,6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,Yes ,6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,Yes ,6
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,Yes ,6
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active ,6
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,6
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,not active ,6
IDE08542-ENG115671-Access control 2-Regenschließen,not active ,6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,active ,6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,active ,6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,active ,6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active ,6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active ,6
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,6
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,not active ,6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,800 ms,4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,present ,4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,1
IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner,active ,1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,not active ,1
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,1
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE10298-Alternating park position 1,18.197784 °,2
IDE10299-Alternating park position 2,21.197781 °,2
MAS01490-Energy management,active ,1
MAS05055-lower turn position,26.197776 °,2
MAS05056-upper turn position,166.197637 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active ,3
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,3
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,3
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active ,3
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active ,3
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active ,3
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,3
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active ,3
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active ,3
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active ,3
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active ,3
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active ,3
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active ,3
ENG99457-ENG98971-Head area heater-Temperature,-3 ,2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.0 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.0 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.0 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.0 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.0 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.0 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.0 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.0 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.0 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.0 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.0 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 lx,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 lx,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 lx,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.0 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.0 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.0 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.0 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.0 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.0 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.0 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.0 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.0 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.0 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.0 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.0 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.0 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.0 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.0 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.0 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.0 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.0 %,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.0 %,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.0 %,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.0 %,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.0 %,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.0 %,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.0 %,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.0 %,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.0 %,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.0 %,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,100 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,150 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,6.0 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,6.0 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,16.0 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,30.0 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,60.0 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.0 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.0 %,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.0 %,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.0 %,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.0 %,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.0 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.0 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.0 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.0 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.0 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.0 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.0 %,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.0 %,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.0 %,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.0 %,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.0 %,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.0 %,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.0 %,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.0 %,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.0 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.0 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.0 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.0 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.0 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.0 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.0 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.0 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.0 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.0 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.0 ,10
ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0,0 lx,8
ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1,8 lx,8
ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2,50 lx,8
ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3,500 lx,8
ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0,6.0 %,8
ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1,6.0 %,8
ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2,100.0 %,8
ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3,100.0 %,8
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,127 ,16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,127 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,4 - LED Tagfahrlichtmodul Signal ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Daytime running lamps ,16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,Parking light right ,16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,Blinken links aktiv (beide Phasen) ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,08 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,38 - LED Blinkleuchten ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Blinken links Dunkelphase ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,18 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,38 - LED Blinkleuchten ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Blinken rechts Dunkelphase ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,39 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,39 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,30 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,30 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,37 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,30 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,30 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,37 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Parking light right ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100 ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,100 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,8 - allgemeine Glühlampe 12W ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,8 - allgemeine Glühlampe 12W ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,127 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,6 - LED Lichtmodul ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Coming Home oder Leaving Home aktiv ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100 ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,127 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,6 - LED Lichtmodul ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Coming Home oder Leaving Home aktiv ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,6 - LED Lichtmodul ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lamps ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Blinken links Hellphase ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Blinken links Dunkelphase ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,6 - LED Lichtmodul ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lamps ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Blinken rechts Hellphase ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Blinken links Dunkelphase ,16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,00 ,16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,00 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,6 - LED Lichtmodul ,16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,00 ,16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,00 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,6 - LED Lichtmodul ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,03 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,46 - LED Kleinleistung ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Ambientelicht 1 ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,04 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,46 - LED Kleinleistung ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Ambientelicht 2 ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0 ,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,10 ,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,100 ,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,150 ,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,220 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,253 ,12
Elapsed Time: 01:08
AudiS3S5
Switzerland
C?ID=443421
These are de modified Lasttyp:
Before:
IDE05145-ENG115873-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6,5 - LED Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7,5 - LED Abblendlicht
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active
After:
IDE05145-ENG115873-Light configuration-Lasttyp 0,not active ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,not active ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,6 - LED Lichtmodul ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,6 - LED Lichtmodul ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,6 - LED Lichtmodul ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,6 - LED Lichtmodul ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,6 - LED Lichtmodul ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,6 - LED Lichtmodul ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,4 - LED Tagfahrlichtmodul Signal ,560
i have copied the adaptation set 0 to 7 and 10 from a Facelift S3.
On my 09 the "6-LED Lichtmodul" are not present in the entiere admap 09, do you think than is not supported by the BCM ?
"6-LED Lichtmodul" can be replace by "LED Tagfahrlichtmodul Versorgung" or "LED Tagfahrlichtmodul Signal" ?
hmm.......... very unique auto-scan; it contains both LED1R H09 LCMs AND hex55 module. And I can't find another auto-scan on the forum that combines LED1R H09 LCMs with the older type BCM that has an active long-code string.
AudiS3S5
Switzerland
C?ID=443421
What the Lasttyp affect in the adaptation channel , the voltage is alway 12V with duty cycle ratio ( Dimmwert) ?
@AudiS3S5: Hi.
Perhaps other forum colleagues are following your posts with better clarity than me (I hope so) - but I'm mighty confused!!
For clarification- you have said that this is a retrofit - good!! But what was the scope of the retrofit - or asked a different way, what was the original lighting equipment in the car as factory installed AND what specific equipment did you actually retrofit?
... and why are you fixated on the "Lasttyp" settings in the BCM? The values of the "Leuchte" channels and as a consequence, the "Light configuration" channels in the BCM for the headight lamps are only valid if it's the BCM that controls the headlight fittings.
However, your auto-scan clearly report modules @ address hexD7 and hexD6. Since LCM s are present (and active) in your auto-scan, isn't it these modules (and not the BCM) that is controlling the headlights? What am I missing?
Other observations that come to mind from your auto-scan (assuming that hexD7 & hexD6 modules were part of the retrofit project):
I don't have access to the information, but:
  • have you checked that your version of BCM (i.e. older style with an active long-code string) is compatible with LED1R H09 LCM s?
  • is it kosher for LED1R H09 LCM s to coexist with an active hex55 module?
AudiS3S5
Switzerland
C?ID=443421
Hi DV52.
my project was to carry out a complete facelift retrofit on an audi S3 from 2013 with headlights Full Led version to the last version 2020 Full LED (not matrix).
- Replacing the Front Headlights Facelift version
- Replacing the Rear tail lights Facelift version with dynamic turn signal.
- Replacing the Front and rear Bumper
in a first step I carried out the complete retrofit without coding anything.
I just buy a 55 Range module on Ebay and replaced on the car, do some wiring modifications and everything works ok.
in this step no wire are conected to the BCM 09 for controling the front Headlights.
In second step i decide to remove one physical fuse used in the wiring and use an output signal of BCM to realise this function in a programable manner.
Here is why my questions on the adaptations parameter set:
Example:
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion B 2,not active
On this example the +12V Terminal 15 is connected to the PIN 10 of connector B (t46b)
I have connected a scope on the output B10 an fixed a Dimwert AB to 50 and try to change the LastTyp.
In all the cases the 12v voltage and the duty cycle not change. only the frequency of PWM change from 100hz to 200Hz.
This has no impact if power LED or Bulbs.
My questions are to understand this lasttyp and what are the current limit of each Digital output of BCM.
How the maximal resistance of load on the output pin is controlled, what is the level ?
How the error is reported ?
Fehlerort mittleres Byte DTC-DFCC & Lampendefektbitposition ?
Ronaldo
Brazil
C?ID=357813
I think an excessive load would generate a "short to ground" error and a too low load would generate an "open or short to plus". Maybe it's not related to the lasttyp parameter. Did you replace your light switch in your retrofit? I'm asking this because I've seen a case when the "vehicle lights malfunction" warning was displayed because there was an incorrect coding for the light switch.
AudiS3S5
Switzerland
C?ID=443421
"vehicle lights malfunction" is gone, no more errors
I have replaced the lasttyp 6-LED Lichtmodul" by "LED Tagfahrlichtmodul Signal"
6-LED Lichtmodul is not supported by my BCM (i copy the addaptation from a S3 2018) but "LED Lichtmodul" lasttyp is not implemented in my older BCM.
For the Light Switch & rain sensor i not change.
AudiS3S5
Switzerland
C?ID=443421
I think an excessive load would generate a "short to ground" error and a too low load would generate an "open or short to plus" This ok,
but i think they are different currents like fuses.
For exemple PIN_B23 is physicaly a 0.63mm and PIN_B45 is 4.8mm
Ronaldo
Brazil
C?ID=357813
That's right, but it seems that the lasttyp setting will define the current limitis to fire the messages "short to ground" and "open or short to plus", I'm not sure about a "lights malfunction" warning. For example, I retrofitted door handle lights in the rear doors of my car connecting the LEDs directly to the BCM (since the car didn't have rear door modules) and only got rid of the "open or short to plus" message when I set the lasttyp to "low power LED". Never had a "lights malfunction".
