- May 23, 2021
- 8
- 3
- Tirana, Albania
- C?ID=434806
Hello,just bought this Skoda Octavia 1.6Tdi and I am having problem with my dpf and egt sensor.First off with my dpf it says soot acculumation 59.99% but my car drives fine a bit slow but it passes 3000rpm and I don't get e dpf regen it says after 20min abortet for safety reason and for my egt s2b1 I changed it with a brand new one bought from vw dealer and it still says short to ground.
Sunday,23,May,2021,22:35:18:22866
VCDS Version: 21.3.0.0 HEX-V2 CB: 0.4543.4
VIN: TMBAF6NE6H0044753 License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: TMBAF6NE6H0044753 Mileage: 101128km-62838miles
Address 01: Engine (2D2D2-CXXA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CS HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2798
Revision: 22004001
Coding: 01114012430411090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI03004L906056CS 002008
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 00598A4C9A86962B8F3-8054
14119 - Exhaust Gas Temp Sensor; Bank 1 Sensor 2
P2031 00 [039] - Electrical Malfunction
Mileage: 101128 km
Date: 2021.05.21
Time: 23:29:28
Engine RPM: 769.50 /min
Normed load value: 41.2 %
Coolant temperature: 100 °C
Intake air temperature: 76 °C
Voltage terminal 30: 13.562 V
Air mass at air mass meter 1: 32.4 kg/h
Standardized air flow ratio: 1.108 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 0.970 bar
Absolute intake pressure: 105 kPa abs
Mean injection quantity: 5 mg/stroke
Index of current engine mode: 10
Index of next requested engine mode: 10
Index of engine target mode: 10
16971 - Exhaust Gas Temp Sensor; Bank 1 Sensor 2
P2032 00 [039] - Short to GND
Mileage: 101128 km
Date: 2021.05.21
Time: 23:29:33
Engine RPM: 769.00 /min
Normed load value: 22.0 %
Voltage terminal 30: 13.570 V
Standardized air flow ratio: 1.111 counts
30531 - Sensor for Exhaust Flap
P048B 00 [039] - Electrical Malfunction
Mileage: 101128 km
Date: 2021.05.21
Time: 23:29:28
Engine RPM: 770.00 /min
Normed load value: 43.9 %
Voltage terminal 30: 13.554 V
Status of starter activation relay-Relay 1 activated: not active
Status of starter activation relay-Relay 2 activated: not active
Engine shut-down overrides-Sporadic function prevention: On
Engine shut-down overrides-Poor start detection: OFF
Engine shut-down overrides-Mixture adaptation: OFF
Engine shut-down overrides-Brake vacuum: OFF
Engine shut-down overrides-Engine temperature: OFF
Engine shut-down overrides-Ambient pressure: OFF
Engine shut-down overrides-Start/stop sensors:: On
Engine shut-down overrides-Regeneration Mode: OFF
Engine starting requirements-Engine temperature too high: OFF
Engine starting requirements-Engine temperature too low: OFF
Engine starting requirements-Brake under pressure too low: OFF
Engine starting requirements-SCR System requires restart: OFF
Engine starting requirements: OFF
Engine starting requirements-Reserved_5: OFF
Engine starting requirements-Reserved_6: OFF
Engine starting requirements-Reserved_7: OFF
23902 - Diesel Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
Mileage: 101128 km
Date: 2021.05.21
Time: 23:29:28
Engine RPM: 769.75 /min
Normed load value: 21.2 %
Counter for regeneration time of particulate filter: 10801 s
Particle filter: kilometers since last regeneration: 1906.3
Particle filter: soot mass measured: 24.10 g
Particle filter: soot mass calculated: 59.99 g
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: -4.6 mbar
Particle filter: field regeneration lock status: 0
23967 - Diesel Particulate Filter
P2458 00 [175] - Regeneration Duration
Mileage: 101128 km
Date: 2021.05.21
Time: 23:29:28
Readiness: N/A
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component: ESC H62 0398
Revision: 00000000 Serial number: 51756000000485
Coding: 1A07629114240970407E060541C62458462890026082247200400070C00203
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_035.rod
VCID: 75B7EB98D544A383AC5-8020
0297 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 187
Mileage: 100518 km
Date: 2021.05.19
Time: 00:01:28
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Reset counter: 186
Mileage: 100518 km
Date: 2021.05.19
Time: 00:01:38
16413 - Display for Tire Pressure Monitoring
Reset counter: 186
Mileage: 100518 km
Date: 2021.05.19
Time: 00:01:38
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5E0 820 047 M HW: 5E0 820 047 M
Component: AC Manuell H05 1203
Revision: 00001K07
Coding: 01010104000110001000000000401000
ASAM Dataset: EV_ACManueBHBVW37X 003129
VCID: 2C010EFC468EA24B03B-8078
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 122
Mileage: 100336 km
Date: 2021.05.16
Time: 02:11:13
Outside temperature: 23.0 °C
Engine RPM: 0 /min
Temperature downstream of evaporator: 36.7 °C
System run time-Terminal 15 on: 56 s
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 5Q0 937 084 CH HW: 5Q0 937 084 AK
Component: BCM MQBAB B H24 0175
Serial number: 01061618600401
Coding: 0C0008424207005347E04000000007080000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_015.rod
Subsystem 1 - Part No SW: 5E1 955 119 A HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 170603 051 0915
Serial number: 887353F0401715402113
Coding: 164DDD
Part No SW: 3Q0 959 655 AT HW: 3Q0 959 655 AT
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SRPD7BVBR
Coding: 88CCC00000000000400000CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 1079BA0CCAE6E6AB1F3-8044
Subsystem 1 - Part No SW: ----------- HW: 454 000 707 16
Serial number: 3576U000000630580C10
Subsystem 2 - Part No SW: ----------- HW: 454 000 707 16
Serial number: 3586U000000561580C14
Subsystem 3 - Part No SW: ----------- HW: 454 802 606 16
Serial number: 3516RC37DE60B000000M
Subsystem 4 - Part No SW: ----------- HW: 454 801 706 16
Serial number: 3526R4FC4CA0B000000P
Subsystem 5 - Part No SW: ----------- HW: 454 801 206 16
Serial number: 3556V0ACAFE0A000000Z
Part No SW: 5Q0 953 507 FQ HW: 5Q0 953 549 F
Revision: -------- Serial number: 30061604221295
Coding: 0200
VCID: 0A4DA864ACBADC7BD17-805E
Part No SW: 5E0 920 721 C HW: 5E0 920 721 C
Component: KOMBI 105 8311
Coding: 0325020021000008010808001000000000000000
Shop #: WSC 73430 031 12345
VCID: 221DE0C4344A643BB97-8076
Part No SW: 5Q0 907 530 AK HW: 5Q0 907 530 D
Component: GW MQB Low 126 1265
Revision: -------- Serial number: 0005109626
Coding: 030000044F087300EB000048080E00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7AADF8A4FC5ACCFBC17-802E
Generator:
Subsystem 2 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001607280429
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0031
Serial number: 0000209927261
Coding: 001001208000040100001100
VCID: 45D75B58C5247303FC5-8010
B1487 54 [008] - Missing Calibration / Basic Setting
Reset counter: 183
Mileage: 100336 km
Date: 2021.05.16
Time: 02:10:54
65576 - Switch for Mirror Adjustment
B11F3 29 [009] - Signal Implausible
Reset counter: 130
Mileage: 100337 km
Date: 2021.05.16
Time: 02:31:08
Component: EPS_MQB_ZFLS 129 1072
Coding: 0107
ROD: EV_SteerAssisMQB_013.rod
12289 - Supply voltage
[Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (<5.5V für 3ms: KL50=0]
Reset counter: 127
Motor status: 00
Supply voltage: 7.00 V
Temperature: 27.0 °C
KFC: 30
KFA: 00 01
Freeze frame conditions: 21
uioUdNotFilt_xdu16: 5.17 V
uAdSensI_SwitchedKl30_xdu16: 5.18 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
26885 - Comfort limitation
C10D7 00 [008] - -
[Speicherinkonsistenz im Errorhandler]
Reset counter: 127
Motor status: 00
Supply voltage: 0.00 V
Temperature: 80.0 °C
KFC: 69
KFA: 00 05
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0031
Serial number: 0000210729381
VCID: 44D1465CCE1E4A0BEBB-8010
Reset counter: 189
Mileage: 100590 km
Date: 2021.05.20
Part No SW: 5E0 035 867 E HW: 5E0 035 867 E
Component: MU-E--ER 050 7060
Serial number: 12051600013350
Coding: 037301003C0000005011000100000200000000C40000010000
Shop #: WSC 73430 790 00063
ROD: EV_MUEnt4CGen2LGE_VW26.rod
End----------(Elapsed Time: 01:02, VBatt start/end: 13.3V/13.3V)-----------
