Door Open Warning Icon the wrong way around.
Marty Coggins
Cardiff, UK
C?ID=404973
Hi Guys
Hope someone can help.
I have a Right Hand Drive T5.1 Transporter and ever since I had the Cluster swapped to a Highline version the door open warning icons on the cluster central display are the wrong way round. As in, if the Drivers door is open it shows as the Passenger Door is open (Although the left and only side sliding door is correct)
Any idea how I can correct this??
Auto Scan pasted below.
Cheers
Martin
Sunday,23,May,2021,12:33:36:56332
VIN: WV1ZZZ7HZFH057400   License Plate: GF64 UCV
Mileage: 228320km-141871mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 0D 15 17 19 25 56 0B
VIN: WV1ZZZ7HZFH057400   Mileage: 228320km-141871miles
01-Engine -- Status: Sporadic communication error 1000
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0001
0D-Slide Door, Left -- Status: Cannot be reached 1100
56-Radio -- Status: Not registered 0011
Address 01: Engine (J623-CAAB)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GG    HW: 03L 907 309 M
   Component: R4 2,0L EDC   X45 6291
   Revision: 26X45---    Serial number: 00000000000000
   Coding: 01114012232400080000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01103L906019GG 003004
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 76B41F3EA84AFD7BA5F-8022
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 L    HW: 7E0 907 379 L
   Component: ESP MK25A XT  H50 0113
   Revision: 00H50001
   Coding: 508724AD89A90A9C24A69171C95E12
   Shop #: WSC 02737 790 49152
   VCID: 3B22CE0AD36860139A1-806E
                    Reset counter: 69
                    Count: 16384
                    Count: 1
                    Count: 8242
                    Count: 762
03391 - Coding Not Possible
                    Reset counter: 69
                    Count: 16384
                    Count: 1
                    Count: 8254
                    Count: 762
                    Reset counter: 69
                    Count: 16384
                    Count: 1
                    Count: 8211
                    Count: 762
                    Reset counter: 53
                    Mileage: 226666 km
                    Date: 2021.04.12
                    Time: 20:41:01
                    Count: 16384
                    Count: 1
                    Count: 8194
                    Count: 760
                    Fault Status: 00101101
                    Reset counter: 53
                    Mileage: 226666 km
                    Date: 2021.04.12
                    Time: 20:47:19
                    Count: 16384
                    Count: 257
                    Count: 8193
                    Count: 760
   Serial number: 02101404650692
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA4071E807AB53BFDF-802A
   Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
   Component: Climatic-T5   H20 0506
   Revision: 00001012
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 7CA00D169666A72BD3B-8028
   Part No SW: 7H0 937 087 P    HW: 7H0 937 087
   Component: BCM T5GP H+4  H34 0424
   Revision: BO034001    Serial number: 0673 118200214
   Coding: E0A4303A0A212031002808102C2B8C540080632F60060000320000000800
   Shop #: WSC 18752 008 00032
   VCID: 41DEBCE2B1840AC3C0D-8014
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8653
   Serial number: KU0KU005081442171894
   Coding: 1000B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU001101442744166
   Coding: 0000A0
   Subsystem 3 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H07 0022
   Serial number: 70000000000000494944
   Coding: E20000
Address 0D: Slide Door, Left
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00SZDH5
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750_VN75.rod
   VCID: 3536D832F5CCB6636C5-8060
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1107
   Coding: 1408000300
   Shop #: WSC 02739 790 50316
   VCID: 3A2CCB0EDCD2591B817-806E
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BO034001
   Coding: 002000
   VCID: 70B82926CAAED34B7F3-8024
                    Fault Frequency: 9
                    Date: 2021.03.30
                    Time: 00:20:40
                    Reset counter: 53
                    Mileage: 226666 km
                    Date: 2021.04.12
                    Time: 20:41:02
03604 - Control Module Auomatic Sliding Door, Rear Left
                    Reset counter: 0
                    Mileage: 226237 km
                    Date: 2021.03.30
                    Time: 00:24:48
   Component: IMMO          H03 1107
   VCID: 6A8C3B4EECF2299B317-803E
Address 56: Radio
End----(Elapsed Time: 01:35, VBatt start/end: 11.4V/11.4V. VIgn 11.3V)-----
I don't see anything in that cluster that explicitly determines RHD vs. LHD.
Have you tried coding it for Great Britain rather than Rest of World? That's in a drop-down for Bits 4-7 in Byte 0.
Marty Coggins
Cardiff, UK
C?ID=404973
I did but didn't wait for the cluster to power down 100%, I just turned the ignition off and back on again. (The icon was still showing as the doors were still open)
I'll try again and leave until the warning icon goes out and then check, hopefully that'll work?
n4s
Portugal
C?ID=351319
Probably related with the coding of Gateway. Also Byte1-bit0 should be active in RHD.
Revision: BO034001
Coding: 002000
Marty Coggins
Cardiff, UK
C?ID=404973
That worked! Thanks guys!
Now all I need to work out is how the change it on my Anrdoid Head Unit, it's still the wrong way round there. :)
