I’ve posted this question before but I could use some more help in figuring it out. After traveling a good distance at freeway speeds, meaning 75 mph, my Jetta runs fine until I reduce cruse speed to 65 mph. While traveling on a section of hiway described as rolling hills, the car has a hesitation or misfire while transitioning from downhill to uphill. The hesitation doesn’t happen all the time but, when it does it is brought on by the same conditions.
I’ve posted my most recent Auto Scan for those interested.
I’m planning a trip over the same route that this event happens in a couple of days. I’m wondering if I were to sit in the passenger seat with my laptop connected to the car and running the VCDS could I catch a real time recording of events as they happen? If so, how can I do this? What measuring blocks should I watch? Is there a tutorial showing me how to do this?
I know, a lot of questions but, I am so impressed with how this vehicle runs it seems such and uncomfortable mystery having this misfire or stumble to happen for no apparent reason.
Thank You for any help.
Steve
Sunday,23,May,2021,13:27:22:03388
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: 3VWDT81K86M742091 License Plate: 5-23-2021
Mileage: 327640km-203586mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 56 62 72
7D
VIN: 3VWDT81K86M742091 Mileage: 327640km-203586miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E3111540
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 6491ACAE525B6CEB0BB-8030
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000511100418
VCID: 51FF757A3DE9E94350D-8004
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Revision: 00H13001
Coding: 0021122
VCID: 71BFD5FA9DA9C94370D-8024
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BE
Component: ClimatronicPQ35 090 0808
VCID: 6B83C792BF8523934A1-803E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000233379
Coding: 14018E234004180000140000001400000028770B5C
Shop #: WSC 03082 444 00167
VCID: 2B0307927F05E3930A1-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 03082
Address 0F: Digital Radio Labels: None
Part No SW: 1K5 035 553 K HW: 1K5 035 553 K
Component: SDAR XM H04 0160
Revision: 00000000 Serial number: VWZ4Z7G0057807
VCID: 313F15FA5D29894330D-8064
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 38 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD036ZFC
Coding: 0013112
VCID: 392F2DDA8559410388D-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0C572716B
Subsystem 3 - Serial number: 6342MSME0B7B6343H
Subsystem 4 - Serial number: 6351HSME09004820X
Subsystem 5 - Serial number: 6361HSME0901260E0
Subsystem 6 - Serial number: 63727SME08311446U
Subsystem 7 - Serial number: 63827SME08316305U
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0012021
VCID: 7AADF2D6C0DF8A1BC17-802E
Component: E0221 007 0050
Part No: 1K0 920 972 L
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023207
Shop #: WSC 03099 444 83914
VCID: 353721EAA941A5636C5-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105A1282D2
Coding: 3F7F0B600F1002
VCID: 2A0D029670FFFA9BF17-807E
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T0FMH01
Coding: 0000003
Component: IMMO 3HL 4312
Shop #: WSC 09226 002 1048576
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C01048E7A0BE4AB03B-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 363526E6B447AE7B65F-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 323D1AF6582FB25B497-8066
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13900E880106281B0904058FB0080F0480A540
VCID: 025D8A36A80FC2DB997-8056
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372B2BE2B34D57737E9-8062
Part No SW: 1K0 035 180 HW: 1K0 035 180
Component: Radio ZSW 015 0035
Revision: 00015000 Serial number: VWZ5Z7E6278034
Coding: 0010400
Shop #: WSC 39612 828 149130
VCID: 5DE7994A71315D23C45-8008
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
Component: PTC-Element 0404
VCID: 2D07098A4111EDA3145-8078
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End----(Elapsed Time: 01:23, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Steve
