2021 Audi e-tron Premium
Jeffy210
Texas, USA
HC?ID=249125
AutoScan: WA1AAAGE8MB028917
Sunday,16,May,2021,12:23:06:36589
Data version: 20210508 DS325.1
VIN: WA1AAAGE8MB028917   License Plate:
Chassis Type: GE-AU58 (4KL)
Scan: 01 03 09 13 15 16 17 19 2B 36 3C 42 44 46 51 52 5F 6D 74 75
          81 8C A5 BB BC C0 C5 C6 CA CE CF D6 D7 8104
VIN: WA1AAAGE8MB028917   Mileage: 921km-572miles
8C-Hybrid Battery -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CE-Drive Motor 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558 C    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0002
   Coding: 2A0A0012006E000034280000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558C 001003
   ROD: EV_VCU00XXX0204KE907558C.rod
   VCID: 49CF54084931EC9318D-801C
   Parking lock:
   Subsystem 1 - Part No SW: 0MA 341 601 D    HW: 0MA 341 601 D
   Component: V682 ParkLock  H25 0637
   Serial number: 2020.12.05.000000041
17176 - Databus
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
                    Engine RPM: 16383.75 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 77 km/h
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 12.617 V
                    Unlearning counter according OBD: 14
                    Engine status: Stop
                    ECU_STATE: ENG_STOP
                    ACC variants (coding): ACC with braking until standstill / Stop & Go
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: No
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: No
                    Drivetrain coordinator: brake function status-ASP intervention: No
                    Drivetrain coordinator: brake function status-ADS intervention: No
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: No
   Part No SW: 4KE 909 059 AF    HW: 4KE 909 059 N
   Component: ESC           H11 0242
   Revision: 00000000    Serial number: 60251000005096
   Coding: 008800BA3D960BA193590872187E52E0253EA90000BCD0C910184A07A47C95
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_BRSContiMKC1AU516 011001
   ROD: EV_BRSContiMKC1AU516_011.rod
   VCID: 0B43AE0003CDBE83EA1-805E
8413 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [044] - -
          [CCan_ACC_07_timeout]
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
                    Unlearning counter according OBD-OBD unlearning counter: 16
                    History Data-History data 1: 00
                    History Data-History data 2: 00
                    History Data-History data 3: 00
                    History Data-History data 4: 00
                    History Data-History data 5: 00
                    History Data-History data 6: 00
                    History Data-History data 7: 00
                    History Data-History data 8: 00
                    History Data-History data 9: 00
                    History Data-History data 10: 00
                    History Data-History data 11: 00
                    History Data-History data 12: 00
                    History Data-History data 13: 00
                    History Data-History data 14: 00
                    History Data-History data 15: 00
                    History Data-History data 16: 00
                    History Data-History data 17: 00
                    History Data-History data 18: 00
                    History Data-History data 19: 00
                    History Data-History data 20: 00
                    History Data-History data 21: 00
                    History Data-History data 22: 00
                    History Data-History data 23: 00
                    History Data-History data 24: 00
                    History Data-History data 25: 00
                    History Data-History data 26: 00
                    History Data-History data 27: 00
                    History Data-History data 28: 00
                    History Data-History data 29: 00
                    History Data-History data 30: 00
                    History Data-History data 31: 00
                    History Data-History data 0: 80
8418 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [044] - -
          [CCan_ACC_10_timeout]
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
8437 - Databus
          U1121 00 [044] - Missing Message
          [CCan_RCTA_01_timeout]
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
   Part No SW: 4N0 907 063 JG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0712
   Coding: 07000363C0E91CDD074007089CEF9C28130B37510C06009709010A0019231601086309024010200000000100004B181A0802800044010000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 7CA1FDDC5663893BD3B-8028
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000002012110402431
   Coding: 7DC727
   Component: G397_RLFSS  H06 0004
   Serial number: 40738637X81A955555B0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501 N    HW: 4K1 941 501 N
   Component: E1 - LTM  H06 0060
   Serial number: 17S08.01.2100301164
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00CO02
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR107122023311059
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AL    HW: 4K0 947 135 AL
   Component: Dachmodul  H42 0416
   Serial number: B01875087
   Coding: 0D0104
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H08 0210
   Serial number: WA146511000097286360
   Coding: 0A0700
   Part No SW: 4KE 907 561 E    HW: 4K0 907 561
   Component: LRR4R         H12 0500
   Coding: FF64875458082C00000080200000003A4A1246494401409E25
   ASAM Dataset: EV_ACCBOSCHAU65X 002031
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 45D75838652908F3FC5-8010
9 Faults Found:
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Reset counter: 60
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 13.2 V
                    Vehicle speed: 22.06 m/s
                    Longitudinal acceleration: -0.78 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
                    Steering_angle-Data: 3.900 °
                    Yaw_rate-Data: 0.349 rad/s
                    adjustment_calculation: OFF
                    Misalignment angle: horiz: 0.094 °
                    Misalignment angle: horiz: fast algorithm: 0.089 °
                    Congestion pilot: status: OFF
                    Outside temperature: 25.50 °C
                    Sensor blindness: radar: no blindness detected
2087 - Databus
          [FAULT_HMS_CONS_ACC]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
                    Voltage terminal 15: 13.6 V
                    Vehicle speed: 22.17 m/s
1075 - Databus
          [FAULT_TIMEOUT_GETRIEBE_11]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
                    Voltage terminal 15: 14.1 V
                    Vehicle speed: 22.36 m/s
                    Longitudinal acceleration: -0.68 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
                    Yaw_rate-Data: 0.383 rad/s
                    adjustment_calculation: On
1076 - Databus
          [FAULT_TIMEOUT_GRA_ACC_01]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
                    Vehicle speed: 22.33 m/s
                    Longitudinal acceleration: -0.70 m/s²
1087 - Databus
          [FAULT_TIMEOUT_LH_EPS_04]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
1031 - Databus
          [FAULT_TIMEOUT_LWI_01]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
1064 - Databus
          [FAULT_TIMEOUT_MOTOR_14]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
                    Voltage terminal 15: 13.5 V
                    Vehicle speed: 22.16 m/s
1086 - Databus
          [FAULT_TIMEOUT_TSG_FT_02]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
                    Vehicle speed: 22.13 m/s
                    Longitudinal acceleration: -0.80 m/s²
1088 - Databus
          [FAULT_TIMEOUT_TSK_06]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
   Part No SW: 4KE 959 655 J    HW: 4KE 959 655 J
   Component: AirbagVW32    H02 3303
   Serial number: 0032CM00X2C0
   Coding: BFCCFCC000300000A200003FFA0D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 55F788789589B8738C5-8000
   Left seat belt tensioner:
   Serial number: 00AI2021018031300000
   Coding: 03F002
   Right seat belt tensioner:
   Serial number: 00AI2021024006800000
   Coding: 03F002
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D20000F42B50C
   Coding: 303134
   Subsystem 4 - Part No SW: -----------    HW: 480 001 201 21
   Serial number: 3570000000041811EF4K
   Subsystem 5 - Part No SW: -----------    HW: 480 001 201 21
   Serial number: 3580000000030001EF4A
   Subsystem 6 - Part No SW: -----------    HW: 480 031 501 21
   Serial number: 351002C1452DEA014B8A
   Subsystem 7 - Part No SW: -----------    HW: 480 032 501 21
   Serial number: 352002C1490AF010FB59
   Subsystem 8 - Part No SW: -----------    HW: 480 022 801 21
   Serial number: 3550001BAC1BE747699T
   Subsystem 9 - Part No SW: -----------    HW: 480 022 801 21
   Serial number: 3560001BAC1BE747997V
   Crash sensor high-voltage system 1:
   Subsystem 10 - Part No SW: -----------    HW: 480 020 801 21
   Component: HVSensor_gSat  002 0149
   Serial number: I0T0001A4C09721145BS
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 11 - Part No SW: -----------    HW: 480 020 801 21
   Component: SideSens_B_Df  002 0149
   Serial number: I0P0001AEF6DA503C8EP
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 12 - Part No SW: -----------    HW: 480 021 801 21
   Component: SideSens_B_Pf  002 0149
   Serial number: I0Q0001BAC1735C46984
   Part No SW: 4N0 907 129 KF    HW: 4N0 907 129 KF
   Component: Lenks.Modul   H03 0009
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 7F5B0AD047759223F69-802A
   Part No SW: 4KE 920 795 D    HW: 4KE 920 795 D
   Component: FHybRDW------ H25 0056
   Coding: 8B4677C97E88CF050286E170BB04030008000000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU58.rod
   VCID: 48C9510C523B159B073-801C
   Part No SW: 4KL 907 468 C    HW: 4K1 907 468 C
   Component: Gateway       H09 0602
   Serial number: F0665943901031
   Coding: 02030001000100C000810000005901329C8A0047180000000900009F00000000
   ASAM Dataset: EV_Gatew31xAU65x 003220
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 50F9796CAA6BDD5B5F3-8004
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0010
   Subsystem 2 - Part No SW: 80D 915 181     HW: 80D 915 181
   Serial number: 77555200002101220B8C
   Subsystem 3 - Part No SW: 4N0 419 508 A    HW: 4N0 419 508
   Component: J1158 KLR  H46 0041
   Serial number: 21011006314S00414601
16711952 - IPv6 Address Conflict
          U12D0 00 [008] - -
          [Ip_Ipv6_address_conflict]
                    Reset counter: 87
                    Mileage: 218 km
                    Date: 2021.04.22
                    Time: 23:59:55
                    IP network: IPv6-addresses-IPv6 address: FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
                    IP network: MAC addresses-MAC address: F8 E8 77 29 26 7A
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H06 0020
   Serial number: 21000004668010
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 343115FC3EB3817B5BB-8060
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0064
   Serial number: 00000430612211
   Coding: 015C1A400000B4010003010101010000000000000000000000000000004000
   VCID: 7BA3FEC0536D8E03DA1-802E
   Part No SW: 4N0 907 566 L    HW: 4N0 907 566 A
   Component: MRR_HR H14 0487
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 3FDB4AD007F55223B69-806A
   Part No SW: 4M0 959 793 N    HW: 4M0 959 793 N
   Component: TSG FS        011 0390
   Serial number: 0000432284360
   Coding: 0014CB0052001480A001A032
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   Coding: B4000101010001
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D13E4C4A78F4B497-8066
   Part No SW: 8W1 907 064 BH    HW: 8W1 907 064 H
   Component: BCM2 MLBevo   044 0565
   Coding: 017400004FB100C1650FA0046C01880200004000810426582F0400000F04823F001E0681010F37
   ASAM Dataset: EV_BCM2HellaAU736 018017
   ROD: EV_BCM2HellaAU736_018.rod
   VCID: 0451853C2E93F1FBABB-8050
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY203151GC6
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000049171592
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4KE 945 423 A    HW: 4KE 945 423 A
   Component: T1 LH SAE HD  H11 0410
   Serial number: A1WM0000JHZ
   Subsystem 4 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 38434489
   left tail lamp 2:
   Subsystem 5 - Part No SW: 4KE 945 429 C    HW: 4KE 945 429 C
   Component: T2 LH SAE HD  H12 0410
   Serial number: A1WP0000XXK
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 4KE 945 424 A    HW: 4KE 945 424 A
   Component: T1 RH SAE HD  H11 0410
   Serial number: A1WS0000JPG
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 4KE 945 430 C    HW: 4KE 945 430 C
   Component: T2 RH SAE HD  H12 0410
   Serial number: A1WQ0000XY0
65605 - Databus
          [Brake control module: ESP_21: no signal/communication]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
                    Supply voltages-Terminal 30 power supply: 14.090 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.090 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.090 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 A2 94 01 E0
                    general_additional_freeze_frame-Vehicle speed: 79.08 km/h
65729 - Databus
          [Brake control module: ESP_05: no signal/communication]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
   Part No SW: 0EF 907 080 E    HW: 0EF 907 080 E
   Component: CUFZD68540AD0 H06 1002
   Revision: --------    Serial number: -00105.10.20000
   Coding: 01000000000000000000
   Shop #: WSC 25687 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003009
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 382921CC22DB651B773-806C
   Part No SW: 4M0 959 792 N    HW: 4M0 959 792 N
   Component: TSG BFS       011 0390
   Serial number: 0000432297214
   Coding: 0014CB005E001480A001A030
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
Address 5F: Information Electr.        Labels: None
   Part No SW: 4M2 035 092 A    HW: 4M2 035 092
   Component: MU-TP-NS-US   042 3385
   Coding: 15161030804000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU27.rod
   VCID: 270BF2B0FF65FAE3EE9-8072
          U1101 00 [008] - Active
          [Anti-theft protection - component protection active_xEA_x61_x00]
                    Reset counter: 87
                    Mileage: 529 km
                    Date: 2021.05.03
                    Time: 12:34:21
                    Voltage terminal 30: 12.2 V
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 4KE 959 107     HW: 4KE 959 107
   Component: HDSG-Modul    H04 0330
   Revision: --------    Serial number: A2-C765-4920-8
   Coding: 3320
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536.rod
   VCID: 035386202B9DF6C3921-8056
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4KE 907 777 AH    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H53 2320
   Serial number: 1701211559
   Coding: 18D8607BDA4020
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 127DB36464E76F4B297-8046
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132197415
   Coding: 303030
   Part No SW: 4KE 035 283 A    HW: 4KE 035 283 B
   Component: CB_H_NAR      039 0236
   Serial number: A971L0LS132725
   Coding: 01E0E0F9C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X.rod
   VCID: 3A2D3BC41CD7770B817-806E
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0045
   Serial number: 92145UAI00253
   ASAM Dataset: EV_GSMKLOAU516 001011
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C213DDC16E3493B93B-8068
   Part No SW: 4KE 915 233 D    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0442
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_VW53.rod
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4KE 915 253 D    HW: 4KE 915 253 D
   Component: BJB_MLBBEV  H08 0444
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215 B    HW: 4KE 915 215
H06 0110
4120 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [040] - -
          [Diag_C_HCAN_OBD_01_TO]
                    Mileage: 90 km
                    Date: 2021.04.18
                    Time: 14:55:36
                    Unlearning counter according OBD: 2
                    High-volt. battery mode: spec. value: Standby-mode
                    Mode HV battery actual value: Standby-mode
                    H-V battery voltage: 420.00 V
                    Voltage in H-V system-Voltage of hybrid battery after protection: 2.50 V
                    Current of H-V / hybrid battery: -0.00 A
                    Battery temperature: 26 °C
                    Battery charge level: 71 %
                    Voltage terminal 30: 12.60 V
                    Voltage terminal 30C: 12.40 V
                    Terminal 15 status via CAN: OFF
                    Power reduction status: not active
                    Malfunction Indicator Lamp-Start request: not active
                    Service Disconnect: Status: connected
                    Pilot line: closed
                    Status of voltage freedom: High voltage power off recognized
                    Crash signal: not active
                    Protection of posit. terminal of high voltage / hybrid battery: Open
                    Protection of neg. terminal of high voltage / hybrid battery: Open
                    Status pre-loader: Open
                    HV battery: cool. level requirement: Cooling level 3
                    Pump for HV battery coolant: specified speed value: 12.00 %
                    Pump for HV battery coolant: status: No malfunction
                    HV battery positive terminal insulation resistance-Status: Initialization
                    HV battery positive terminal insulation resistance: 10000 kOhm
                    HV battery minus terminal insulation resistance-Status: Initialization
                    HV battery minus terminal insulation resistance: 2560 kOhm
                    Entire HV system positive terminal insulation resistance-Status: Initialization
                    Entire HV system positive terminal insulation resistance: 20470 kOhm
                    Entire HV system minus terminal insulation resistance-Status: Initialization
                    Entire HV system minus terminal insulation resistance: 20470 kOhm
                    maximum voltage for battery cells-Index 1: 0
                    maximum voltage for battery cells-Value: 3.893 V
                    minimum voltage for battery cells-Index 1: 0
                    minimum voltage for battery cells-Value: 3.890 V
                    Highest measured temperature-Temperature sensor: 0
                    Highest measured temperature-Value: 27 °C
                    Lowest measured temperature-Temperature sensor: 0
                    Lowest measured temperature-Value: 25 °C
                    Air temperature of H-V / hybrid battery-Intake: -100 °C
                    Air temperature of H-V / hybrid battery-Exhaust: 26 °C
                    Maximum charge level-Index 1: 0
                    Maximum charge level-Value: 71 %
                    Minimum charge level-Index 1: 0
                    Minimum charge level-Value: 71 %
                    Dynamic limit for charge current-Limit for charge current: 40 A
                    Predictive limit for charge current-Limit for charge current: 40 A
                    Dynamic limit for discharge current-Limit for discharge current: 40 A
                    Predictive limit for discharge current-Limit for discharge current: 40 A
                    Maximum charging voltage: 459.00 V
                    Minimum discharge voltage: 225.00 V
                    Minimum dynamic charging voltage: 421.10 V
                    Minimum predictive charging voltage: 421.10 V
                    Minimum dynamic discharge voltage: 418.80 V
                    Minimum predictive discharge voltage: 418.80 V
4122 - No Communication with ABS Brake Control Module
          U0121 00 [040] - -
          [Diag_C_HCAN_ESP_21_TO]
                    Mileage: 90 km
                    Date: 2021.04.18
                    Time: 14:55:36
                    Unlearning counter according OBD: 36
                    H-V battery voltage: 423.20 V
                    Voltage in H-V system-Voltage of hybrid battery after protection: 3.20 V
                    Battery temperature: 25 °C
                    Battery charge level: 74 %
                    Voltage terminal 30: 13.00 V
                    Voltage terminal 30C: 12.80 V
                    Pilot line: closed
                    HV battery minus terminal insulation resistance: 20470 kOhm
                    maximum voltage for battery cells-Value: 3.921 V
                    minimum voltage for battery cells-Value: 3.919 V
                    Highest measured temperature-Value: 26 °C
                    Maximum charge level-Value: 74 %
                    Minimum charge level-Value: 74 %
                    Minimum dynamic charging voltage: 424.20 V
                    Minimum predictive charging voltage: 424.20 V
                    Minimum dynamic discharge voltage: 422.00 V
                    Minimum predictive discharge voltage: 422.00 V
4142 - No Communications with DC to DC Converter Control Module 1
          U0298 00 [032] - -
          [Diag_C_HCAN_DCDC_01_TO]
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 20:36:48
                    Unlearning counter according OBD: 31
                    H-V battery voltage: 418.70 V
                    Voltage in H-V system-Voltage of hybrid battery after protection: 3.50 V
                    Battery temperature: 30 °C
                    Battery charge level: 70 %
                    Voltage terminal 30C: 12.60 V
                    Pilot line: closed
                    maximum voltage for battery cells-Value: 3.881 V
                    minimum voltage for battery cells-Value: 3.879 V
                    Highest measured temperature-Value: 31 °C
                    Lowest measured temperature-Value: 28 °C
                    Air temperature of H-V / hybrid battery-Exhaust: 32 °C
                    Maximum charge level-Value: 70 %
                    Minimum charge level-Value: 69 %
                    Minimum dynamic charging voltage: 419.70 V
                    Minimum predictive charging voltage: 419.70 V
                    Minimum dynamic discharge voltage: 417.50 V
                    Minimum predictive discharge voltage: 417.50 V
4143 - Control Module for Thermal Management
          U0116 00 [032] - No Communications
          [Diag_C_HCAN_TME_11_TO]
                    Mileage: 478 km
                    Date: 2021.04.28
                    Time: 08:45:59
                    Unlearning counter according OBD: 16
                    Mode HV battery actual value: Initialization
                    H-V battery voltage: 409.50 V
                    Voltage in H-V system-Voltage of hybrid battery after protection: 3.00 V
                    Battery temperature: 27 °C
                    Battery charge level: 61 %
                    Pilot line: closed
                    HV battery minus terminal insulation resistance: 2620 kOhm
                    maximum voltage for battery cells-Value: 3.796 V
                    minimum voltage for battery cells-Value: 3.793 V
                    Highest measured temperature-Value: 28 °C
                    Lowest measured temperature-Value: 26 °C
                    Air temperature of H-V / hybrid battery-Exhaust: 27 °C
                    Maximum charge level-Value: 61 %
                    Minimum charge level-Value: 61 %
                    Dynamic limit for charge current-Limit for charge current: 600 A
                    Predictive limit for charge current-Limit for charge current: 277 A
                    Dynamic limit for discharge current-Limit for discharge current: 1100 A
                    Predictive limit for discharge current-Limit for discharge current: 400 A
                    Minimum dynamic charging voltage: 426.60 V
                    Minimum predictive charging voltage: 417.40 V
                    Minimum dynamic discharge voltage: 380.00 V
                    Minimum predictive discharge voltage: 398.80 V
4604 - Battery Control Module 5
          U01A4 00 [040] - No Communications
          [Diag_C_BatCAN_CMC_05_07_TO]
                    Mileage: 691 km
                    Date: 2021.05.07
                    Time: 19:39:48
                    Unlearning counter according OBD: 30
                    Mode HV battery actual value: Hybrid battery mode: emergency shutdown
                    H-V battery voltage: 429.00 V
                    Voltage in H-V system-Voltage of hybrid battery after protection: 0.20 V
                    Battery temperature: Initialization
                    Battery charge level: 78 %
                    Voltage terminal 30: 12.80 V
                    Pilot line: closed
                    Status of voltage freedom: High voltage power off not recognized
                    Pump for HV battery coolant: status: Shutdown dry run protection
                    HV battery positive terminal insulation resistance: 20470 kOhm
                    maximum voltage for battery cells-Value: 3.977 V
                    minimum voltage for battery cells-Value: 3.974 V
                    Highest measured temperature-Value: 0 °C
                    Lowest measured temperature-Value: 0 °C
                    Air temperature of H-V / hybrid battery-Exhaust: 31 °C
                    Maximum charge level-Value: 78 %
                    Minimum charge level-Value: 78 %
                    Dynamic limit for charge current-Limit for charge current: 0 A
                    Predictive limit for charge current-Limit for charge current: 0 A
                    Dynamic limit for discharge current-Limit for discharge current: 0 A
                    Predictive limit for discharge current-Limit for discharge current: 0 A
                    Minimum dynamic charging voltage: 429.00 V
                    Minimum predictive charging voltage: 428.70 V
                    Minimum dynamic discharge voltage: 428.70 V
                    Minimum predictive discharge voltage: 428.70 V
4612 - Battery Control Module 6
          U01A5 00 [174] - No Communications
          [Diag_C_BatCAN_CMC_06_07_TO]
                    Mileage: 529 km
                    Date: 2021.05.03
                    Time: 12:59:01
                    H-V battery voltage: 431.00 V
                    Voltage terminal 30: 12.40 V
                    Voltage terminal 30C: 12.20 V
                    Pilot line: closed
                    maximum voltage for battery cells-Value: 3.993 V
                    minimum voltage for battery cells-Value: 3.991 V
                    Minimum dynamic charging voltage: 431.00 V
                    Minimum predictive charging voltage: 428.90 V
                    Minimum dynamic discharge voltage: 428.90 V
                    Minimum predictive discharge voltage: 428.90 V
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4K4 907 117 F    HW: 4K4 907 117
   Component: zFAS Var C    H09 0365
   Coding: 0221840000000000003BD60000F4650E139E5600000000D8000000000096D401019BA80000000000000000800000000000000000000000000000800000000000000070180000009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 003008
   ROD: EV_ZFASAU516_003.rod
2114637 - Databus
          [LRR1_SensorHeader_LRR1_Fehler]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
233479 - Parking Sensor(s); Rear
          B107B F0 [008] - Function Limitation due to External Factors
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 21:00:23
233523 - Parking Sensor(s); Front
          B10FC F0 [008] - Function Limitation due to External Factors
          [Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 21:00:53
4108 - Databus
          [irreversibler_Fehler_im_ACC_System]
                    Reset counter: 60
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
   Part No SW: 4M0 959 795 N    HW: 4M0 959 795 N
   Component: TSG HFS       011 0390
   Serial number: 0000431781128
   Coding: 0004C90000001480E000A020
   ROD: EV_DCU2RearDriveMAXHKLO_VW53.rod
   VCID: 4BC36E00434DFE832A1-801E
   Component: TSG HBFS      011 0390
   Serial number: 0000431495597
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C0: Act. for Ext. Noise (J943)       Labels:* None
   Part No SW: 4KE 035 335 A    HW: 3F0 035 335
   Component: E_SOUND_SGH07 0462
   Serial number: E2102108950000
   Coding: 04
   ASAM Dataset: EV_ESoundMLBEvoS1NN 003009
   ROD: EV_ESoundMLBEvoS1NN.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0283163
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_AU58.rod
   VCID: 4ACD6B044C37E78B117-801E
   Subsystem 1 - Part No SW: 4M0 959 603 E    HW: 4M0 959 603 E
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00100.4Y.3A20370515
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 E    HW: 4G0 816 797 E
   Component: J842 EKK es33  H05 0017
   Serial number: 00000000020101501447
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 E    HW: 4M0 959 603 E
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 2 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151804860
   Shut-off valve 3 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 099     HW: 4M0 816 099
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 36000000000000075853
   Shut-off valve 5 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 099     HW: 4M0 816 099
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 33000000000000075853
   Radiator shutter:
   Subsystem 8 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1  H13 0110
   Serial number: 20210121060103051251
   Radiator louver 2:
   Subsystem 9 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V550KJS2  H13 0110
   Serial number: 20210114060104077134
   Coolant valve 1:
   Subsystem 10 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000002290306
   Coolant valve 2:
   Subsystem 11 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000002043577
   Coolant valve 3:
   Subsystem 12 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000002316930
   Coolant valve 4:
   Subsystem 13 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000002266832
   Part No SW: 5QE 915 684 AD    HW: 5QE 915 684 AD
   Component: OBC KOSTAL    H32 0070
   Serial number: EEEEEEEEEEEEEEE
   Coding: 2A49A44542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev16B 004001
   ROD: EV_OBC3Phase1KLOMLBev16B.rod
   VCID: 117FBC6861E1945310D-8044
   Flap 1 for charging socket:
   Subsystem 1 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F496LKL1       004 0004
   Serial number: 20210117030206080231
19 Faults Found:
1060352 - Charging Cover A; Locking Detection
          P31CF 00 [109] - Electrical Malfunction
          [Socket_A_Lock_2_Check_circuit_open]
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 16:24:11
2097152 - Battery Management
          P33EB 00 [040] - Read Event Memory
                    Mileage: 529 km
                    Date: 2021.05.03
                    Time: 12:59:02
13705501 - Databus
          U1121 00 [040] - Missing Message
          [ESP_21_TimeOut]
                    Fault Frequency: 20
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 17:53:51
13705478 - Databus
          [Klemmen_Status_01_TimeOut]
                    Reset counter: 35
                    Mileage: 858 km
                    Date: 2021.05.12
                    Time: 18:19:08
13705826 - Control Module for Active Park System
          U13AE 00 [040] - Implausible
          [error_hold_management_system]
                    Fault Frequency: 17
                    Reset counter: 35
                    Mileage: 52 km
                    Date: 2021.04.17
                    Time: 22:46:10
13705549 - Databus
          U1121 00 [032] - Missing Message
          [DCDC_01_Timeout]
13705553 - Databus
          U1121 00 [109] - Missing Message
          [AWC_01_TimeOut]
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 16:24:14
3211299 - Function Switch for Tailgate 1
          B1A86 04 [109] - Internal System Fault
          [push_button_LKL1_disconnected]
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 16:24:13
3211302 - Function Switch for Tailgate 2
          B1A87 04 [109] - Internal System Fault
          [push_button_LKL2_disconnected]
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 16:24:13
3276846 - Intelligent Charging Function
          U15BF 00 [108] - Communications Error
          [SCC_DEM_NVM_READ_CONTR_CERT_CHAIN_SIZE_FAIL]
                    Mileage: 921 km
                    Date: 2021.05.16
                    Time: 11:13:12
3276840 - Intelligent Charging Function
          U15BF 00 [032] - Communications Error
          [ETHTRCV_30_AR7000_E_ACCESS]
3276852 - Intelligent Charging Function
          [SCC_DEM_NVM_READ_ROOT_CERT_FAIL]
                    Mileage: 921 km
                    Date: 2021.05.16
                    Time: 11:13:11
3280913 - Signal Damping Protocol
          U15AC 00 [032] - Malfunction
          [ETHTRCV_30_AR7000_E_FW_DWLD]
13706243 - Databus
          [NavData_02_TimeOut]
                    Fault Frequency: 17
                    Mileage: 356 km
                    Date: 2021.04.26
                    Time: 08:29:30
13706269 - Unknown Error Code
          B191C F8 [109] - Unknown Error Elaboration
          [AM_RGB_Slave_03_TimeOut]
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 16:24:13
13706270 - Unknown Error Code
          [AM_RGB_Slave_04_TimeOut]
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 16:24:13
13706272 - Positioning Motor
          C12BB 00 [109] - -
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 16:24:13
14746766 - Charging Unit 2
          P1A15 00 [109] - Function Restricted
                    Mileage: 17 km
                    Date: 2021.03.23
                    Time: 16:24:15
13705524 - Databus
          [Motor_12_TimeOut]
                    Fault Frequency: 148
                    Mileage: 14 km
                    Date: 2021.03.17
                    Time: 17:59:31
   Coding: 228040051602
   ROD: EV_SunRoofCONTIAU736_009_AU58.rod
   VCID: 75B7E8F87549D873AC5-8020
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 K    HW: 0EF 907 180 K
   Component: CUBZE68550AD0 H07 1003
   ASAM Dataset: EV_DMCM2HITACAU516 003009
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H14 0487
   Coding: 0FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 71BFDCE80121F45370D-8024
1136 - Databus
          [can message ESP21 missing]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
1152 - Databus
          [can message Airbag01 missing]
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
Address D7: Light Ctrl Right 2 (A27)       Labels: None
1136 - Databus
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
1152 - Databus
                    Reset counter: 59
                    Mileage: 402 km
                    Date: 2021.04.26
                    Time: 20:56:43
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
End------(Elapsed Time: 33:08, VBatt start/end: 14.3V/13.1V, Deb=2)--------
blockmap-01-4KE-907-558-C_WA1AAAGE8MB028917-20210516-1155.CSV
;SW:4KE-907-558-C   HW:4KE-907-558 ---  Engine
;Component:I99 99.9l XXX H02 0002, Coding:2A0A0012006E000034280000000000000000000000000000
;EV_VCU00XXX0204KE907558C,001003,EV_VCU00XXX0204KE907558C.rod
;Sunday,16,May,2021,11:55:17:36589
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210508 DS325.1
;VCID: 49CF54084931EC9318D-801C
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WA1AAAGE8MB028917,
IDE00019,Voltage terminal 30,13.535, V
IDE00078,Time since engine start,0, s
IDE00086,Accelerator pedal position,15, %
IDE00089,Driving position,P,
IDE00097,OBD - requirements for which this vehicle is designed,None,
IDE00102,Control Module temperature,53.0, °C
IDE00150,Pressure in brake servo unit,0.000, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00392,Accelerator pedal: sensor voltage 1,0.751, V
IDE00393,Accelerator pedal: sensor voltage 2,0.376, V
IDE00451,Currently running routine,Unknown (0),
IDE00584,Distance driven since erasing DTC memory,911, km
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,47,
IDE00608,Fuel type,Battery/elec.,
IDE01880,Accelerator pedal position 2,15, %
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,0,
IDE03010-MAS01627,Number of prevented stop processes-Steering,0,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,0,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03361,Driver intention torque,0.0, Nm
IDE03767,Engine status,Stop,
IDE04913,Current speed of electric motor,0.0, /min
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,Yes,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC with Stop & Go,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC with braking until standstill / Stop & Go,
IDE07159-MAS00478,Control module switch-off: counter-Reserved,-1,
IDE07575,Driver intention torque,0.0, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Set,Not operated,
IDE07598-MAS00326,Cruise control switch actuation-Resume,Not operated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,Not operated,
IDE07598-MAS02310,Cruise control switch actuation-DELAY,Not operated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,Not operated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,Not operated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,Not operated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07904-ENG118117,Brake test switch status-actuated__activated,Not operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,Not operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG130099,Exhaust warning light: triggering contr. module-MIL-Request from All Wheel Drive Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG06494,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG06495,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989-MAS00106,Immobilizer: historic data-Year,2000,
IDE10989-MAS00107,Immobilizer: historic data-Month,0,
IDE10989-MAS00108,Immobilizer: historic data-Day,0,
IDE10989-MAS00109,Immobilizer: historic data-Hours,0,
IDE10989-MAS00110,Immobilizer: historic data-Minutes,0,
IDE10989-MAS00111,Immobilizer: historic data-Seconds,0,
IDE10989,Immobilizer: historic data,not active,
IDE11065,Accel. pedal pos. sensor 1,614,
IDE11066,Accel. pedal pos. sensor 2,307,
IDE13301-MAS06606,Drivetrain coordinator: brake fault status-Brake under pressure too low,No,
IDE13301-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE13301-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE13301-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE13301-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE13301-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE13301-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE13301-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE13301-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE13301-MAS16114,Drivetrain coordinator: brake fault status-Deceleration management error,No,
IDE13301-MAS16115,Drivetrain coordinator: brake fault status-Deceleration management: restricted performance,No,
IDE13301-MAS16116,Drivetrain coordinator: brake fault status-Deceleration management not available,No,
IDE13336-MAS04795,Drive train coordinator reversible switch off conditions-main switch off,No,
IDE13336-MAS05192,Drive train coordinator reversible switch off conditions-Driver braking,No,
IDE13336-MAS05823,Drive train coordinator reversible switch off conditions-Speed signal error during initialization,No,
IDE13336-MAS05824,Drive train coordinator reversible switch off conditions-Emer. engine operation,No,
IDE13336-MAS05836,Drive train coordinator reversible switch off conditions-Acceleration monitoring error,No,
IDE13336-MAS05901,Drive train coordinator reversible switch off conditions-Trans. emerg. operation,No,
IDE13336-MAS12585,Drive train coordinator reversible switch off conditions-Speed threshold for reversible ACC shut-off,No,
IDE13336-MAS12586,Drive train coordinator reversible switch off conditions-Speed threshold for ending the brake torque shut-off ramp,No,
IDE13336-MAS12588,Drive train coordinator reversible switch off conditions-Speed cut-off active,No,
IDE13336-MAS12590,Drive train coordinator reversible switch off conditions-Reversible brake system error,No,
IDE13336-MAS12591,Drive train coordinator reversible switch off conditions-Engine off or drive is not ready,Yes,
IDE13336-MAS15049,Drive train coordinator reversible switch off conditions-Drive train open or no gear selected,No,
IDE13336-MAS16227,Drive train coordinator reversible switch off conditions-Stopping distance reduction 3 interventions,No,
IDE13336-MAS16228,Drive train coordinator reversible switch off conditions-Tracking system interface shutdown,No,
IDE13336-MAS16230,Drive train coordinator reversible switch off conditions-ESP safety-related message condition,No,
IDE13336-MAS16231,Drive train coordinator reversible switch off conditions-ACC switch off because of driver braking,No,
IDE13336-MAS16232,Drive train coordinator reversible switch off conditions-PCC sensor: reversible error,No,
IDE13336-MAS16235,Drive train coordinator reversible switch off conditions-Intelligent parking assistant reversible error,No,
IDE13336-MAS16246,Drive train coordinator reversible switch off conditions-ACC breaking only possible because of CAN bus,No,
IDE13336-MAS16247,Drive train coordinator reversible switch off conditions-Diagnostics fadeout due to identified malfunction,No,
IDE13336-MAS16248,Drive train coordinator reversible switch off conditions-Safety computer detects crash,No,
IDE13336-MAS16249,Drive train coordinator reversible switch off conditions-Electrical parking brake: braking,No,
IDE13336-MAS16253,Drive train coordinator reversible switch off conditions-GRA breaking intervention: switch off due to brake disc temperature,No,
IDE13336-MAS16254,Drive train coordinator reversible switch off conditions-Hill descent assistant active,No,
IDE13336-MAS16255,Drive train coordinator reversible switch off conditions-Locking by trailer shunting assistant,No,
IDE13336-MAS16256,Drive train coordinator reversible switch off conditions-Blocking by parking assistant,No,
IDE13337-MAS05814,Drive train coordinator irreversible switch off conditions-CAN communication error,No,
IDE13337-MAS05815,Drive train coordinator irreversible switch off conditions-CAN signal error,No,
IDE13337-MAS05818,Drive train coordinator irreversible switch off conditions-Transmission coding not plausible,No,
IDE13337-MAS05820,Drive train coordinator irreversible switch off conditions-ACC error,No,
IDE13337-MAS05821,Drive train coordinator irreversible switch off conditions-Braking intervention too weak,No,
IDE13337-MAS05824,Drive train coordinator irreversible switch off conditions-Emer. engine operation,No,
IDE13337-MAS05825,Drive train coordinator irreversible switch off conditions-Engine control module fault,No,
IDE13337-MAS05829,Drive train coordinator irreversible switch off conditions-Brake light fault,No,
IDE13337-MAS05830,Drive train coordinator irreversible switch off conditions-CCS deactivated due to fault in control component,No,
IDE13337-MAS05831,Drive train coordinator irreversible switch off conditions-ACC deactivated due to fault in control component,No,
IDE13337-MAS05832,Drive train coordinator irreversible switch off conditions-Coding error,No,
IDE13337-MAS05833,Drive train coordinator irreversible switch off conditions-ESC error,No,
IDE13337-MAS05835,Drive train coordinator irreversible switch off conditions-Clutch pedal fault,No,
IDE13337-MAS05836,Drive train coordinator irreversible switch off conditions-Acceleration monitoring error,No,
IDE13337-MAS15052,Drive train coordinator irreversible switch off conditions-Brake light actuation malfunction,No,
IDE13337-MAS16257,Drive train coordinator irreversible switch off conditions-Brake pedal implausible,No,
IDE13337-MAS16258,Drive train coordinator irreversible switch off conditions-Transport mode active,No,
IDE13337-MAS16259,Drive train coordinator irreversible switch off conditions-GRA looking due to software as product,No,
IDE13337-MAS16260,Drive train coordinator irreversible switch off conditions-Emergency assistant: actual acceleration error,No,
IDE13337-MAS16262,Drive train coordinator irreversible switch off conditions-Vehicle speed determination: substitute value,No,
IDE13337-MAS16263,Drive train coordinator irreversible switch off conditions-Intelligent parking assistant irreversible error,No,
IDE14051,Parking lock actuator: actual position as a percentage,91, %
IDE14052,Parking lock actuator: actual position,selected,
IDE14054,Parking lock actuator: current,0.0, A
IDE14055,Parking lock actuator: supply voltage,14, V
IDE14056,Parking lock actuator: temperature,31, °C
MAS17268,Functions which can be activated: connection error counter,00 00,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,00 00 00 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Not available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,Yes,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,0,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
ENG118038,BSOC,79.500, %
ENG07601,Bypasstool_a2l_name,SCLH10,
ENG07600,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identification,4KE558C 0002AGAB,
ENG99697,Calibration Verification Number,7D 75 D4 C5,
ENG118062,CUR_CHA_MAX_DYN_2,594.0, A
ENG118063,CUR_DCHA_MAX_DYN_2,-1068.0, A
ENG100131,ECU_STATE,ENG_STOP,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG103667,ENVD_0_MON,0,
ENG99424,ENVD_1_MON,0,
ENG99790,ENVD_2_MON,0,
ENG99455,ENVD_3_MON,0,
ENG01743,ENVD_4_MON,0,
ENG01744,ENVD_5_MON,0,
ENG01745,ENVD_6_MON,0,
ENG114481,ENVD_MON_3[0],0,
ENG114482,ENVD_MON_3[1],0,
ENG114483,ENVD_MON_3[2],0,
ENG114484,ENVD_MON_3[3],0,
ENG114485,ENVD_MON_3[4],0,
ENG114486,ENVD_MON_3[5],0,
ENG114487,ENVD_MON_3[6],0,
ENG114488,ENVD_MON_3_CAN[0],0,
ENG114489,ENVD_MON_3_CAN[1],0,
ENG114490,ENVD_MON_3_CAN[2],0,
ENG114491,ENVD_MON_3_CAN[3],0,
ENG114492,ENVD_MON_3_CAN[4],0,
ENG114493,ENVD_MON_3_CAN[5],0,
ENG114494,ENVD_MON_3_CAN[6],0,
ENG114495,ENVD_MON_3_SW[0],0,
ENG114496,ENVD_MON_3_SW[1],0,
ENG114497,ENVD_MON_3_SW[2],0,
ENG114498,ENVD_MON_3_SW[3],0,
ENG114499,ENVD_MON_3_SW[4],0,
ENG114500,ENVD_MON_3_SW[5],0,
ENG114501,ENVD_MON_3_SW[6],0,
ENG114502,ENVD_MON_3_TMP[0],0,
ENG114503,ENVD_MON_3_TMP[1],0,
ENG114504,ENVD_MON_3_TMP[2],0,
ENG114505,ENVD_MON_3_TMP[3],0,
ENG114506,ENVD_MON_3_TMP[4],0,
ENG114507,ENVD_MON_3_TMP[5],0,
ENG114508,ENVD_MON_3_TMP[6],0,
ENG114509,ENVD_MON_3_VD[0],0,
ENG114510,ENVD_MON_3_VD[1],0,
ENG114511,ENVD_MON_3_VD[2],0,
ENG114512,ENVD_MON_3_VD[3],0,
ENG114513,ENVD_MON_3_VD[4],0,
ENG114514,ENVD_MON_3_VD[5],0,
ENG114515,ENVD_MON_3_VD[6],0,
ENG114516,ENVD_MON3_COD_PROT_COD_ADR[0],0,
ENG114517,ENVD_MON3_COD_PROT_COD_ADR[1],0,
ENG114518,ENVD_MON3_COD_PROT_COD_ADR[2],0,
ENG114519,ENVD_MON3_COD_PROT_COD_ADR[3],0,
ENG114520,ENVD_MON3_COD_PROT_COD_ADR[4],0,
ENG114521,ENVD_MON3_COD_PROT_COD_ADR[5],0,
ENG114522,ENVD_MON3_COD_PROT_COD_ADR[6],0,
ENG114523,ENVD_MON3_COD_PROT_COD_ADR[7],0,
ENG114524,ENVD_MON3_COD_PROT_COD_ADR[8],0,
ENG114525,ENVD_MON3_COD_PROT_COD_ADR[9],0,
ENG114526,ENVD_MON3_COD_PROT_IDF_CPU[0],0,
ENG114527,ENVD_MON3_COD_PROT_IDF_CPU[1],0,
ENG114528,ENVD_MON3_COD_PROT_IDF_CPU[2],0,
ENG114529,ENVD_MON3_COD_PROT_IDF_CPU[3],0,
ENG114530,ENVD_MON3_COD_PROT_IDF_CPU[4],0,
ENG114531,ENVD_MON3_COD_PROT_IDF_CPU[5],0,
ENG114532,ENVD_MON3_COD_PROT_IDF_CPU[6],0,
ENG114533,ENVD_MON3_COD_PROT_IDF_CPU[7],0,
ENG114534,ENVD_MON3_COD_PROT_IDF_CPU[8],0,
ENG114535,ENVD_MON3_COD_PROT_IDF_CPU[9],0,
ENG114536,ENVD_MON3_DATA_PROT_COD_ADR[0],0,
ENG114537,ENVD_MON3_DATA_PROT_COD_ADR[1],0,
ENG114538,ENVD_MON3_DATA_PROT_COD_ADR[2],0,
ENG114539,ENVD_MON3_DATA_PROT_COD_ADR[3],0,
ENG114540,ENVD_MON3_DATA_PROT_COD_ADR[4],0,
ENG114541,ENVD_MON3_DATA_PROT_COD_ADR[5],0,
ENG114542,ENVD_MON3_DATA_PROT_COD_ADR[6],0,
ENG114543,ENVD_MON3_DATA_PROT_COD_ADR[7],0,
ENG114544,ENVD_MON3_DATA_PROT_COD_ADR[8],0,
ENG114545,ENVD_MON3_DATA_PROT_COD_ADR[9],0,
ENG114546,ENVD_MON3_DATA_PROT_DATA_ADR[0],0,
ENG114547,ENVD_MON3_DATA_PROT_DATA_ADR[1],0,
ENG114548,ENVD_MON3_DATA_PROT_DATA_ADR[2],0,
ENG114549,ENVD_MON3_DATA_PROT_DATA_ADR[3],0,
ENG114550,ENVD_MON3_DATA_PROT_DATA_ADR[4],0,
ENG114551,ENVD_MON3_DATA_PROT_DATA_ADR[5],0,
ENG114552,ENVD_MON3_DATA_PROT_DATA_ADR[6],0,
ENG114553,ENVD_MON3_DATA_PROT_DATA_ADR[7],0,
ENG114554,ENVD_MON3_DATA_PROT_DATA_ADR[8],0,
ENG114555,ENVD_MON3_DATA_PROT_DATA_ADR[9],0,
ENG114556,ENVD_MON3_DATA_PROT_IDF_CPU[0],0,
ENG114557,ENVD_MON3_DATA_PROT_IDF_CPU[1],0,
ENG114558,ENVD_MON3_DATA_PROT_IDF_CPU[2],0,
ENG114559,ENVD_MON3_DATA_PROT_IDF_CPU[3],0,
ENG114560,ENVD_MON3_DATA_PROT_IDF_CPU[4],0,
ENG114561,ENVD_MON3_DATA_PROT_IDF_CPU[5],0,
ENG114562,ENVD_MON3_DATA_PROT_IDF_CPU[6],0,
ENG114563,ENVD_MON3_DATA_PROT_IDF_CPU[7],0,
ENG114564,ENVD_MON3_DATA_PROT_IDF_CPU[8],0,
ENG114565,ENVD_MON3_DATA_PROT_IDF_CPU[9],0,
ENG124827,FIBEX_Integration_Step,V8.14.01,
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG100634-ENG119860,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Completion Condition Counts,0, counts
ENG100634-ENG119872,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Conditions Encountered Counts,0, counts
ENG100634-ENG102823,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Ignition Cycle Counter,160, counts
ENG100634-ENG99988,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-OBD Monitoring Conditions Encountered Counts,47, counts
ENG100634-ENG119377,In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Com Enc Cou B 2-Raw Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG07602,LF_MVB_BUS_INTC_DIAG,0,
ENG07603,LF_MVB_PDU_INTC_DIAG_1,0,
ENG07604,LF_MVB_PDU_INTC_DIAG_10,0,
ENG37770,LF_MVB_PDU_INTC_DIAG_11,0,
ENG37771,LF_MVB_PDU_INTC_DIAG_12,0,
ENG07605,LF_MVB_PDU_INTC_DIAG_13,0,
ENG07607,LF_MVB_PDU_INTC_DIAG_15,0,
ENG07608,LF_MVB_PDU_INTC_DIAG_16,0,
ENG07609,LF_MVB_PDU_INTC_DIAG_17,0,
ENG07610,LF_MVB_PDU_INTC_DIAG_18,0,
ENG37772,LF_MVB_PDU_INTC_DIAG_19,0,
ENG07611,LF_MVB_PDU_INTC_DIAG_2,0,
ENG37773,LF_MVB_PDU_INTC_DIAG_20,0,
ENG37774,LF_MVB_PDU_INTC_DIAG_22,0,
ENG37775,LF_MVB_PDU_INTC_DIAG_23,0,
ENG37776,LF_MVB_PDU_INTC_DIAG_24,0,
ENG37777,LF_MVB_PDU_INTC_DIAG_25,0,
ENG37778,LF_MVB_PDU_INTC_DIAG_26,0,
ENG37779,LF_MVB_PDU_INTC_DIAG_27,0,
ENG07612,LF_MVB_PDU_INTC_DIAG_3,0,
ENG07613,LF_MVB_PDU_INTC_DIAG_4,0,
ENG07614,LF_MVB_PDU_INTC_DIAG_5,0,
ENG07615,LF_MVB_PDU_INTC_DIAG_6,0,
ENG07617,LF_MVB_PDU_INTC_DIAG_8,0,
ENG07618,LF_MVB_PDU_INTC_DIAG_9,0,
ENG127734-MAS00106,Life_cycle_data_start_requirement_development-Year,2000,
ENG127734-MAS00107,Life_cycle_data_start_requirement_development-Month,0,
ENG127734-MAS00108,Life_cycle_data_start_requirement_development-Day,0,
ENG127734-MAS00109,Life_cycle_data_start_requirement_development-Hours,0,
ENG127734-MAS00110,Life_cycle_data_start_requirement_development-Minutes,0,
ENG127734-MAS00111,Life_cycle_data_start_requirement_development-Seconds,0,
ENG127734,Life_cycle_data_start_requirement_development,not active,
ENG127735-MAS00106,Life_cycle_data_stop_prohibition_development-Year,2000,
ENG127735-MAS00107,Life_cycle_data_stop_prohibition_development-Month,0,
ENG127735-MAS00108,Life_cycle_data_stop_prohibition_development-Day,0,
ENG127735-MAS00109,Life_cycle_data_stop_prohibition_development-Hours,0,
ENG127735-MAS00110,Life_cycle_data_stop_prohibition_development-Minutes,0,
ENG127735-MAS00111,Life_cycle_data_stop_prohibition_development-Seconds,0,
ENG127735,Life_cycle_data_stop_prohibition_development,not active,
ENG127733-MAS00106,Life_cycle_data_system_failure-Year,2000,
ENG127733-MAS00107,Life_cycle_data_system_failure-Month,0,
ENG127733-MAS00108,Life_cycle_data_system_failure-Day,0,
ENG127733-MAS00109,Life_cycle_data_system_failure-Hours,0,
ENG127733-MAS00110,Life_cycle_data_system_failure-Minutes,0,
ENG127733-MAS00111,Life_cycle_data_system_failure-Seconds,0,
ENG127733,Life_cycle_data_system_failure,not active,
ENG118084,LV_GEAR_NEUT_PROD_REQ,00000000 ,
ENG112471,LV_IGK,00000001 ,
ENG118087,N_EM_3,16383.5, /min
ENG118088,N_EM_6,0.0, /min
ENG128797,PV,0.00, %
ENG118114,SbW_counter_limp_home_by_paddles,0,
ENG118115,SbW_counter_neutral_hold,15,
ENG118116,SbW_counter_P_engagement_EBKV,0,
ENG118117,SbW_counter_P_engagement_HMS,0,
ENG118118,SbW_counter_P_engagement_HMS_timeout,0,
ENG118119,SbW_counter_P_engagement_IgnOff,13,
ENG118120,SbW_counter_P_engagement_total,19,
ENG118121,SbW_counter_P_engagement_VLK,6,
ENG118122,SbW_counter_P_not_engaged,3,
ENG118123,SbW_counter_park_hold_HMS,0,
ENG118124,SbW_counter_shift_position_changes_IPA,0,
ENG00980,STATE_DCC_4WD_TQL_AXLE_1,0,
ENG00981,STATE_DCC_4WD_TQL_AXLE_2,0,
ENG00982,STATE_DIAG_ERR_4WD_CUS,0,
ENG00983,STATE_DIAG_TQ_VCT_ERR_CUS,0,
ENG118128,STATE_NEUT_GEAR_CUS_REQ,0,
ENG118129,STATE_NEUT_GEAR_CUS_REQ_SUC,0,
ENG118130,STATE_NEUT_GEAR_PROD_REQ_SUC,0,
ENG118131,STATE_REQ_ENG_HVS,20,
ENG00984,STATE_SIG_RATIO_MAX_DDC_4WD_AXLE_2,0,
ENG00985,STATE_SIG_RATIO_MIN_DDC_4WD_AXLE_2,0,
ENG112494,T_AST_SAE,0, s
ENG128802,T_IGK,450.97, s
ENG125440,TAA,0.000, °C
ENG118137,TQ_EM_1,0.00000, Nm
ENG118138,TQ_EM_2,0.00000, Nm
ENG118139,TQ_EM_3,1023.96875, Nm
ENG01013,VehDynCtl_errAcv_rDstrAx2,false,
ENG01014,VehDynCtl_errAcv_tqLimWdDstr,false,
ENG118144,VS_DIR_CUS,0.00, km/h
Elapsed Time: 00:25
blockmap-03-4KE-909-059-AF_WA1AAAGE8MB028917-20210516-1155.CSV
;SW:4KE-909-059-AF   HW:4KE-909-059-N ---  ABS Brakes
;Component:ESC           H11 0242, Coding:008800BA3D960BA193590872187E52E0253EA90000BCD0C910184A07A47C95
;EV_BRSContiMKC1AU516,011001,EV_BRSContiMKC1AU516_011.rod
;Sunday,16,May,2021,11:55:50:36589
;VCID: 0B43AE0003CDBE83EA1-805E
IDE00009-MAS00106,Date of manufacture-Year,37,
IDE00009-MAS00107,Date of manufacture-Month,1,
IDE00009-MAS00108,Date of manufacture-Day,33,
IDE00019,Voltage terminal 30,14.257, V
IDE00020-MAS06489,Terminal 15 status-Terminal 15 signal,On,
IDE00020-MAS06490,Terminal 15 status-Terminal 15 load,On,
IDE00021,Engine RPM,0, /min
IDE00025,Coolant temperature,215, °C
IDE00085,Normed load value,100.0, %
IDE00326,Steering wheel angle,-39.99, °
IDE00445-MAS01759,Unlearning counter according OBD-OBD unlearning counter,255,
IDE00556,Outside temperature,215, °C
IDE00611,Malfunction that has caused the ambient data to be stored,P0000,
IDE00725,Manufacturer test stand number,9999,
IDE00726,Component group and serial number,13E8,
IDE00920-ENG118281,Front left wheel speed-Wheelspeed,0.0, km/h
IDE00921-ENG118281,Wheel speed: right front-Wheelspeed,0.0, km/h
IDE00922-ENG118281,Left rear wheel speed-Wheelspeed,0.0, km/h
IDE00923-ENG118281,Right rear wheel speed-Wheelspeed,0.0, km/h
IDE02211-MAS09170,Brake pressure-Brake pressure sensor 1,0.00, bar
IDE02211-MAS16461,Brake pressure-Brake pressure sensor 2,0.00, bar
IDE02308,Status ESP button,Not operated,
IDE02311-ENG118300,Left front wheel speed sensor installation position-Actual_airgap_status,OK,
IDE02311-ENG118426,Left front wheel speed sensor installation position-Average_airgap_status,OK,
IDE02311-ENG16418,Left front wheel speed sensor installation position-Signal_amplitude,00,
IDE02311-ENG118210,Left front wheel speed sensor installation position-Signal_amplitude_measurement_status,invalid,
IDE02312-ENG118300,Right front wheel speed sensor installation position-Actual_airgap_status,OK,
IDE02312-ENG118426,Right front wheel speed sensor installation position-Average_airgap_status,OK,
IDE02312-ENG16418,Right front wheel speed sensor installation position-Signal_amplitude,00,
IDE02312-ENG118210,Right front wheel speed sensor installation position-Signal_amplitude_measurement_status,invalid,
IDE02313-ENG118300,Left rear wheel speed sensor installation position-Actual_airgap_status,OK,
IDE02313-ENG118426,Left rear wheel speed sensor installation position-Average_airgap_status,OK,
IDE02313-ENG16418,Left rear wheel speed sensor installation position-Signal_amplitude,00,
IDE02313-ENG118210,Left rear wheel speed sensor installation position-Signal_amplitude_measurement_status,invalid,
IDE02314-ENG118300,Right rear wheel speed sensor installation position-Actual_airgap_status,OK,
IDE02314-ENG118426,Right rear wheel speed sensor installation position-Average_airgap_status,OK,
IDE02314-ENG16418,Right rear wheel speed sensor installation position-Signal_amplitude,00,
IDE02314-ENG118210,Right rear wheel speed sensor installation position-Signal_amplitude_measurement_status,invalid,
IDE02315-MAS01466,Direction of rotation front left wheel speed sensor-Direction of rotation,invalid,
IDE02316-MAS01466,Direction of rotation front right wheel speed sensor-Direction of rotation,invalid,
IDE02317-MAS01466,Direction of rotation rear left wheel speed sensor-Direction of rotation,invalid,
IDE02318-MAS01466,Direction of rotation rear right wheel speed sensor-Direction of rotation,invalid,
IDE02319,Hill start assistant signals,passive,
IDE02611,Incline angle of parking brake,0, °
IDE02611,Incline angle of parking brake,valid_value,
IDE02612-MAS01849,Parking brake tensioning force attained-Left,18700, N
IDE02612-MAS01850,Parking brake tensioning force attained-Right,18700, N
IDE02613,Status of parking brake button,Not operated,
IDE02656-MAS00128,System condition of parking brake-Distance Regulation,coded,
IDE02656-MAS01090,System condition of parking brake-Transmission,automatic,
IDE02656-MAS02575,System condition of parking brake-Initiation,will be performed.,
IDE02656-MAS02665,System condition of parking brake-Automatic closing at button malfunction,active,
IDE02656-MAS02666,System condition of parking brake-Seat belt buckle scan,not active,
IDE02656-MAS02669,System condition of parking brake-Automatic closing with engine off (key),not active,
IDE02656-MAS02670,System condition of parking brake-Gradual release of brake,not active,
IDE02656-MAS02672,System condition of parking brake-Start-stop,not active,
IDE02656-MAS12067,System condition of parking brake-After automatic closing of the parking brake,Extended driver presence recognition,
IDE02656-MAS12068,System condition of parking brake-After manual closing of the parking brake,Driver side door contact and belt switch,
IDE02659-MAS01849,Parking brake status-Left,closed,
IDE02659-MAS01850,Parking brake status-Right,closed,
IDE03205,Manufacturer code,TT1,
IDE03315-MAS01000,Warnings-Warning text,0,
IDE03315-MAS01911,Warnings-Tone sensor,OFF,
IDE03315-MAS02590,Warnings-Red warning light,OFF,
IDE03315-MAS02591,Warnings-Yellow warning light,OFF,
IDE03315-MAS02592,Warnings-Red operating lamp,On,
IDE03315-MAS02593,Warnings-Green operating lamp,OFF,
IDE03315-MAS02594,Warnings-Indicator light in switch,On,
IDE03316,Deceleration: setpoint,-0.4, m/s²
IDE03680-MAS12065,Supply voltages-ABS valves,14.4, V
IDE03680-MAS16369,Supply voltages-ABS linear actuator,14.4, V
IDE04253,Sys status of tire press monitoring display,5F 20,
IDE04446,Hill descent control,switched off,
IDE04451-IDE02763,Tire press monitoring display indictor lamp-System malfunction lamp: status,passive,
IDE04451-IDE02765,Tire press monitoring display indictor lamp-Pressure warning lamp: status,passive,
IDE04604-MAS02472,Accelerator pedal travel-Qualification bit,active,
IDE04604,Accelerator pedal travel,0.0, %
IDE06752,Hill descent control button,Initialization/not installed,
IDE06921-ENG100973,Calculated vehicle speed-Vehicle_speed,0.0, km/h
IDE07641-MAS11141,Brake pedal position sensor-Zero point: error status,Zero point adjusted and error-free,
IDE07641-MAS13158,Brake pedal position sensor-Brake pedal position: calculated,-0.03, mm
IDE07641-ENG118326,Brake pedal position sensor-Actual_zero_point TMC Long Term Travel Offset 1,0.04, mm
IDE07641-ENG118402,Brake pedal position sensor-Actual_zero_point TMC Long Term Travel Offset 2,0.04, mm
IDE07641-ENG118333,Brake pedal position sensor-Calibrated_zero_point TMC Initial Travel Offset 1,-0.17, mm
IDE07641-ENG118232,Brake pedal position sensor-Calibrated_zero_point TMC Initial Travel Offset 2,-0.16, mm
IDE07641-ENG118211,Brake pedal position sensor-PWM_signal_1_raw_value,-0.03, mm
IDE07641-ENG118212,Brake pedal position sensor-PWM_signal_2_raw_value,-0.04, mm
IDE07905-MAS11308,Brake light switch status-"Driver braking" information from brake electronics,Not operated,
IDE07905-MAS11309,Brake light switch status-"Driver braking" information from brake booster,Not operated,
IDE07905-MAS11310,Brake light switch status-"Driver braking" information from brake electronics: qualif.,valid,
IDE07905-MAS11311,Brake light switch status-"Driver braking" information from brake booster: qualif.,valid,
IDE07905-MAS11644,Brake light switch status-Brake light activation hardware,Not operated,
IDE08586,Status: electromechanical power brake,On,
IDE08623,OBD configuration,NO OBD,
IDE08742,Operating time,60, H
IDE09285,Reason for tire monitoring warning,No warning display on,
IDE09286,Software version of tire monitoring display,C1409n,
IDE09289,Tire press monitor.display: diagnosis status,00 00 00 00,
IDE09580-MAS09177,RPM sensor: air gap-Left front: med. value,Malfunction,
IDE09580-MAS09178,RPM sensor: air gap-Left front: minimum,FF,
IDE09580-MAS09179,RPM sensor: air gap-Left front: maximum,00,
IDE09580-MAS09180,RPM sensor: air gap-Right front: med. value,Malfunction,
IDE09580-MAS09181,RPM sensor: air gap-Right front: minimum,FF,
IDE09580-MAS09182,RPM sensor: air gap-Right front: maximum,00,
IDE09580-MAS09183,RPM sensor: air gap-Left rear: med. value,Malfunction,
IDE09580-MAS09184,RPM sensor: air gap-Left rear: minimum,FF,
IDE09580-MAS09185,RPM sensor: air gap-Left rear: maximum,00,
IDE09580-MAS09186,RPM sensor: air gap-Right rear: med. value,Malfunction,
IDE09580-MAS09187,RPM sensor: air gap-Right rear: minimum,FF,
IDE09580-MAS09188,RPM sensor: air gap-Right rear: maximum,00,
IDE10034-ENG118312,RPM sensor: overall wiring fault-Front_left_average,0, µs
IDE10034-ENG118286,RPM sensor: overall wiring fault-Front_left_maximum,0.00, %
IDE10034-ENG118287,RPM sensor: overall wiring fault-Front_left_minimum,0.00, %
IDE10034-ENG118350,RPM sensor: overall wiring fault-Front_right_average,0, µs
IDE10034-ENG118444,RPM sensor: overall wiring fault-Front_right_maximum,0.00, %
IDE10034-ENG118262,RPM sensor: overall wiring fault-Front_right_minimum,0.00, %
IDE10034-ENG118349,RPM sensor: overall wiring fault-Rear_left_average,0, µs
IDE10034-ENG118291,RPM sensor: overall wiring fault-Rear_left_maximum,0.00, %
IDE10034-ENG118430,RPM sensor: overall wiring fault-Rear_left_minimum,0.00, %
IDE10034-ENG118428,RPM sensor: overall wiring fault-Rear_right_average,0, µs
IDE10034-ENG118405,RPM sensor: overall wiring fault-Rear_right_maximum,0.00, %
IDE10034-ENG118440,RPM sensor: overall wiring fault-Rear_right_minimum,0.00, %
IDE10035-MAS09177,RPM sensor: single separation fault-Left front: med. value,0, µs
IDE10035-MAS09178,RPM sensor: single separation fault-Left front: minimum,0.00, %
IDE10035-MAS09179,RPM sensor: single separation fault-Left front: maximum,0.00, %
IDE10035-MAS09180,RPM sensor: single separation fault-Right front: med. value,0, µs
IDE10035-MAS09181,RPM sensor: single separation fault-Right front: minimum,0.00, %
IDE10035-MAS09182,RPM sensor: single separation fault-Right front: maximum,0.00, %
IDE10035-MAS09183,RPM sensor: single separation fault-Left rear: med. value,0, µs
IDE10035-MAS09184,RPM sensor: single separation fault-Left rear: minimum,0.00, %
IDE10035-MAS09185,RPM sensor: single separation fault-Left rear: maximum,0.00, %
IDE10035-MAS09186,RPM sensor: single separation fault-Right rear: med. value,0, µs
IDE10035-MAS09187,RPM sensor: single separation fault-Right rear: minimum,0.00, %
IDE10035-MAS09188,RPM sensor: single separation fault-Right rear: maximum,0.00, %
IDE10348,Trip distance data,32 00 00 00 00 00 00 00 00 00 03 01 00 00 00 57 41 31 41 41 41 47 45 38 4D 42 30 32 38 39 31 37 00 00 00 00 00 00 00 00 00 06 00 02 00 00 03 BC,
IDE10636-MAS01447,Driving program for downhill driving assistance-Act.val.,2,
IDE10636-MAS01448,Driving program for downhill driving assistance-Target value,2,
IDE10636-MAS05631,Driving program for downhill driving assistance-System status,available.,
IDE10667-MAS01447,Driving program for brake electronics-Act.val.,2,
IDE10667-MAS01448,Driving program for brake electronics-Target value,2,
IDE10667-MAS05631,Driving program for brake electronics-System status,available.,
IDE10787-MAS00106,Tire press. monitoring sys.: last warning-Year,2021,
IDE10787-MAS00107,Tire press. monitoring sys.: last warning-Month,2,
IDE10787-MAS00108,Tire press. monitoring sys.: last warning-Day,9,
IDE10787-MAS00109,Tire press. monitoring sys.: last warning-Hours,14,
IDE10787-MAS00110,Tire press. monitoring sys.: last warning-Minutes,21,
IDE10787-MAS00111,Tire press. monitoring sys.: last warning-Seconds,3,
IDE10787-MAS00711,Tire press. monitoring sys.: last warning-Odometer reading,0, km
IDE10787-MAS02832,Tire press. monitoring sys.: last warning-Malfunction status,02 05 00 00,
IDE10788-MAS00106,Tire press. monitoring sys.: second last warning-Year,2021,
IDE10788-MAS00107,Tire press. monitoring sys.: second last warning-Month,2,
IDE10788-MAS00108,Tire press. monitoring sys.: second last warning-Day,9,
IDE10788-MAS00109,Tire press. monitoring sys.: second last warning-Hours,14,
IDE10788-MAS00110,Tire press. monitoring sys.: second last warning-Minutes,11,
IDE10788-MAS00111,Tire press. monitoring sys.: second last warning-Seconds,21,
IDE10788-MAS00711,Tire press. monitoring sys.: second last warning-Odometer reading,0, km
IDE10788-MAS02832,Tire press. monitoring sys.: second last warning-Malfunction status,02 05 00 00,
IDE10789-MAS00106,Tire press. monitoring sys.: third last warning-Year,2021,
IDE10789-MAS00107,Tire press. monitoring sys.: third last warning-Month,2,
IDE10789-MAS00108,Tire press. monitoring sys.: third last warning-Day,9,
IDE10789-MAS00109,Tire press. monitoring sys.: third last warning-Hours,14,
IDE10789-MAS00110,Tire press. monitoring sys.: third last warning-Minutes,10,
IDE10789-MAS00111,Tire press. monitoring sys.: third last warning-Seconds,59,
IDE10789-MAS00711,Tire press. monitoring sys.: third last warning-Odometer reading,0, km
IDE10789-MAS02832,Tire press. monitoring sys.: third last warning-Malfunction status,02 05 00 00,
IDE10790-MAS00106,Tire press. monitoring sys.: fourth last warning-Year,2021,
IDE10790-MAS00107,Tire press. monitoring sys.: fourth last warning-Month,2,
IDE10790-MAS00108,Tire press. monitoring sys.: fourth last warning-Day,9,
IDE10790-MAS00109,Tire press. monitoring sys.: fourth last warning-Hours,14,
IDE10790-MAS00110,Tire press. monitoring sys.: fourth last warning-Minutes,9,
IDE10790-MAS00111,Tire press. monitoring sys.: fourth last warning-Seconds,43,
IDE10790-MAS00711,Tire press. monitoring sys.: fourth last warning-Odometer reading,0, km
IDE10790-MAS02832,Tire press. monitoring sys.: fourth last warning-Malfunction status,02 05 00 00,
IDE10791-MAS00106,Tire press. monitoring sys.: fifth last warning-Year,2021,
IDE10791-MAS00107,Tire press. monitoring sys.: fifth last warning-Month,2,
IDE10791-MAS00108,Tire press. monitoring sys.: fifth last warning-Day,9,
IDE10791-MAS00109,Tire press. monitoring sys.: fifth last warning-Hours,14,
IDE10791-MAS00110,Tire press. monitoring sys.: fifth last warning-Minutes,8,
IDE10791-MAS00111,Tire press. monitoring sys.: fifth last warning-Seconds,2,
IDE10791-MAS00711,Tire press. monitoring sys.: fifth last warning-Odometer reading,0, km
IDE10791-MAS02832,Tire press. monitoring sys.: fifth last warning-Malfunction status,02 05 00 00,
IDE10792-MAS00106,Tire press. monitoring sys.: last calibration-Year,2021,
IDE10792-MAS00107,Tire press. monitoring sys.: last calibration-Month,2,
IDE10792-MAS00108,Tire press. monitoring sys.: last calibration-Day,9,
IDE10792-MAS00109,Tire press. monitoring sys.: last calibration-Hours,14,
IDE10792-MAS00110,Tire press. monitoring sys.: last calibration-Minutes,11,
IDE10792-MAS00111,Tire press. monitoring sys.: last calibration-Seconds,11,
IDE10792-MAS00711,Tire press. monitoring sys.: last calibration-Odometer reading,0, km
IDE10792-MAS02201,Tire press. monitoring sys.: last calibration-Temperature,20, °C
IDE10793-MAS00106,Tire press. monitoring sys.: second last calibration-Year,2000,
IDE10793-MAS00107,Tire press. monitoring sys.: second last calibration-Month,0,
IDE10793-MAS00108,Tire press. monitoring sys.: second last calibration-Day,0,
IDE10793-MAS00109,Tire press. monitoring sys.: second last calibration-Hours,0,
IDE10793-MAS00110,Tire press. monitoring sys.: second last calibration-Minutes,0,
IDE10793-MAS00111,Tire press. monitoring sys.: second last calibration-Seconds,0,
IDE10793-MAS00711,Tire press. monitoring sys.: second last calibration-Odometer reading,0, km
IDE10793-MAS02201,Tire press. monitoring sys.: second last calibration-Temperature,0, °C
IDE10794-MAS00106,Tire press. monitoring sys.: third last calibration-Year,2000,
IDE10794-MAS00107,Tire press. monitoring sys.: third last calibration-Month,0,
IDE10794-MAS00108,Tire press. monitoring sys.: third last calibration-Day,0,
IDE10794-MAS00109,Tire press. monitoring sys.: third last calibration-Hours,0,
IDE10794-MAS00110,Tire press. monitoring sys.: third last calibration-Minutes,0,
IDE10794-MAS00111,Tire press. monitoring sys.: third last calibration-Seconds,0,
IDE10794-MAS00711,Tire press. monitoring sys.: third last calibration-Odometer reading,0, km
IDE10794-MAS02201,Tire press. monitoring sys.: third last calibration-Temperature,0, °C
IDE10795-MAS00106,Tire press. monitoring sys.: fourth last calibration-Year,2000,
IDE10795-MAS00107,Tire press. monitoring sys.: fourth last calibration-Month,0,
IDE10795-MAS00108,Tire press. monitoring sys.: fourth last calibration-Day,0,
IDE10795-MAS00109,Tire press. monitoring sys.: fourth last calibration-Hours,0,
IDE10795-MAS00110,Tire press. monitoring sys.: fourth last calibration-Minutes,0,
IDE10795-MAS00111,Tire press. monitoring sys.: fourth last calibration-Seconds,0,
IDE10795-MAS00711,Tire press. monitoring sys.: fourth last calibration-Odometer reading,0, km
IDE10795-MAS02201,Tire press. monitoring sys.: fourth last calibration-Temperature,0, °C
IDE10796-MAS00106,Tire press. monitoring sys.: fifth last calibration-Year,2000,
IDE10796-MAS00107,Tire press. monitoring sys.: fifth last calibration-Month,0,
IDE10796-MAS00108,Tire press. monitoring sys.: fifth last calibration-Day,0,
IDE10796-MAS00109,Tire press. monitoring sys.: fifth last calibration-Hours,0,
IDE10796-MAS00110,Tire press. monitoring sys.: fifth last calibration-Minutes,0,
IDE10796-MAS00111,Tire press. monitoring sys.: fifth last calibration-Seconds,0,
IDE10796-MAS00711,Tire press. monitoring sys.: fifth last calibration-Odometer reading,0, km
IDE10796-MAS02201,Tire press. monitoring sys.: fifth last calibration-Temperature,0, °C
IDE11053-MAS00179,Brake light switch: signal from engine ctrl. mod.-Brake lamp switch,Not operated,
IDE11053-MAS12083,Brake light switch: signal from engine ctrl. mod.-"Driver braking" signal,Not operated,
IDE11053-MAS12084,Brake light switch: signal from engine ctrl. mod.-"Driver braking" signal: qualification,valid,
IDE11053-MAS12085,Brake light switch: signal from engine ctrl. mod.-Brake pedal information: plausibility,valid,
IDE11525-ENG118249,Brake pedal position sensor: position-Linear_actuator_position,1.84, mm
IDE11525-ENG118365,Brake pedal position sensor: position-TMC Position,-0.04, mm
IDE12738-IDE00056,History Data-History data 1,80,
IDE12738-IDE00057,History Data-History data 2,00,
IDE12738-IDE00058,History Data-History data 3,1A,
IDE12738-IDE00059,History Data-History data 4,31,
IDE12738-IDE00060,History Data-History data 5,00,
IDE12738-IDE00061,History Data-History data 6,00,
IDE12738-IDE00062,History Data-History data 7,00,
IDE12738-IDE00063,History Data-History data 8,90,
IDE12738-IDE00064,History Data-History data 9,90,
IDE12738-IDE00065,History Data-History data 10,FC,
IDE12738-IDE00066,History Data-History data 11,6E,
IDE12738-IDE00067,History Data-History data 12,00,
IDE12738-IDE00068,History Data-History data 13,14,
IDE12738-IDE00069,History Data-History data 14,FF,
IDE12738-IDE00070,History Data-History data 15,FF,
IDE12738-IDE00071,History Data-History data 16,00,
IDE12738-IDE01803,History Data-History data 17,0B,
IDE12738-IDE01804,History Data-History data 18,00,
IDE12738-IDE01805,History Data-History data 19,00,
IDE12738-IDE01806,History Data-History data 20,80,
IDE12738-IDE01807,History Data-History data 21,16,
IDE12738-IDE01808,History Data-History data 22,F0,
IDE12738-IDE01809,History Data-History data 23,00,
IDE12738-IDE01810,History Data-History data 24,00,
IDE12738-IDE01811,History Data-History data 25,00,
IDE12738-IDE01812,History Data-History data 26,00,
IDE12738-IDE01813,History Data-History data 27,00,
IDE12738-IDE01814,History Data-History data 28,00,
IDE12738-IDE01815,History Data-History data 29,00,
IDE12738-IDE01816,History Data-History data 30,00,
IDE12738-IDE01817,History Data-History data 31,00,
IDE12738-IDE80252,History Data-History data 0,00,
IDE13397-IDE11039,Tire pressure monitoring system indicator: counter for pressure loss-Tire pr.monit.sys.: counter for fast press. loss: le. frt,255,
IDE13397-IDE11040,Tire pressure monitoring system indicator: counter for pressure loss-Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,254,
IDE13397-IDE11041,Tire pressure monitoring system indicator: counter for pressure loss-Tire pr.monit.sys.:counter for fast press. loss: le. rr.,254,
IDE13397-IDE11042,Tire pressure monitoring system indicator: counter for pressure loss-Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,254,
IDE13397-IDE11043,Tire pressure monitoring system indicator: counter for pressure loss-Tire pr.monit.sys.: counter for slow press. loss: le. frt,254,
IDE13397-IDE11044,Tire pressure monitoring system indicator: counter for pressure loss-Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,254,
IDE13397-IDE11045,Tire pressure monitoring system indicator: counter for pressure loss-Tire pr.monit.sys.: counter for slow press. loss: le. rr.,254,
IDE13397-IDE11046,Tire pressure monitoring system indicator: counter for pressure loss-Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,254,
IDE13845-ENG117932,Production mode status-Routine Control Option PSM State,Production mode active,
IDE14176-ENG118227,Brake fluid level sensor-Brake_fluid_level_filtered,correct,
IDE14176-ENG118274,Brake fluid level sensor-Brake_fluid_level_not_filtered,correct,
IDE14176-ENG118276,Brake fluid level sensor-sensor_current_1,30.26, mA
IDE14176-ENG118454,Brake fluid level sensor-sensor_current_2,30.26, mA
IDE14176-ENG118208,Brake fluid level sensor-Sensor_status,no_error,
IDE14210,Ground break detection routine status,no_evaluation_this_ignition_cycle,
IDE15131-MAS00106,Multi-collision brake: information-Year,2021,
IDE15131-MAS00106,Multi-collision brake: information-Year,2000,
IDE15131-MAS00107,Multi-collision brake: information-Month,0,
IDE15131-MAS00107,Multi-collision brake: information-Month,2,
IDE15131-MAS00108,Multi-collision brake: information-Day,0,
IDE15131-MAS00108,Multi-collision brake: information-Day,9,
IDE15131-MAS00109,Multi-collision brake: information-Hours,0,
IDE15131-MAS00110,Multi-collision brake: information-Minutes,0,
IDE15131-MAS00111,Multi-collision brake: information-Seconds,1,
IDE15131-MAS00111,Multi-collision brake: information-Seconds,0,
IDE15131-ENG118368,Multi-collision brake: information-AB_MKB_Anforderung,not active,
IDE15131-ENG118450,Multi-collision brake: information-AB_MKB_Anforderung_qualifier,no error,
IDE15131-ENG118301,Multi-collision brake: information-AB_MKB_Safing,not active,
IDE15131-ENG118237,Multi-collision brake: information-AB_MKB_Safing_qualifier,no error,
IDE15131-ENG118237,Multi-collision brake: information-AB_MKB_Safing_qualifier,ERROR,
IDE15131-ENG118449,Multi-collision brake: information-Kilometer_0,0, km
IDE15131-ENG118304,Multi-collision brake: information-Kilometer_1,0, km
IDE15131-ENG118453,Multi-collision brake: information-Kilometer_2,0, km
IDE15131-ENG118406,Multi-collision brake: information-Kilometer_3,0, km
IDE15131-ENG118415,Multi-collision brake: information-Kilometer_4,0, km
IDE15131-ENG118257,Multi-collision brake: information-MKB_failsafe_state,Pcb_disabled,
IDE15131-ENG118221,Multi-collision brake: information-MKB_Trigger,Get_pcb_active,
IDE15131-ENG118221,Multi-collision brake: information-MKB_Trigger,Get_pcb_v_ref_off,
IDE15767-IDE05499,internal self test-Hydraulic test,not active,
IDE15767-MAS21000,internal self test-Zero point detection active,not active,
IDE80100-ENG98502,Analysis 100-Data,8D 0D 25 4C,
MAS00464-MAS00106,Standard - ambient data 1-Year,2021,
MAS00464-MAS00107,Standard - ambient data 1-Month,5,
MAS00464-MAS00108,Standard - ambient data 1-Day,16,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,55,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,44,
MAS01481,Temperature in control module,30.95, °C
MAS01481-MAS02194,Temperature in control module-Temperature 1,26, °C
MAS01481-MAS12885,Temperature in control module-Maximum measured temperature,32, °C
ENG04547-ENG04671,Apply Counter left_right-Left_Brake_Full_Clamping_Force,118,
ENG04547-ENG04672,Apply Counter left_right-Left_Brake_Reduced_Clamping_Force,59,
ENG04547-ENG04669,Apply Counter left_right-Right_Brake_Full_Clamping_Force,118,
ENG04547-ENG04670,Apply Counter left_right-Right_Brake_Reduced_Clamping_Force,59,
ENG04532,BTM_Driving_with_pushed_brakes,0, s
ENG04533-MAS00106,BTM_Last_occurence_of_driving_with_pushed_brakes-Year,2000,
ENG04533-MAS00107,BTM_Last_occurence_of_driving_with_pushed_brakes-Month,0,
ENG04533-MAS00108,BTM_Last_occurence_of_driving_with_pushed_brakes-Day,0,
ENG04533-MAS00109,BTM_Last_occurence_of_driving_with_pushed_brakes-Hours,0,
ENG04533-MAS00110,BTM_Last_occurence_of_driving_with_pushed_brakes-Minutes,0,
ENG04533-MAS00111,BTM_Last_occurence_of_driving_with_pushed_brakes-Seconds,0,
ENG04530-MAS00106,BTM_Last_occurence_of_maximum_temp_FL-Year,2000,
ENG04530-MAS00107,BTM_Last_occurence_of_maximum_temp_FL-Month,0,
ENG04530-MAS00108,BTM_Last_occurence_of_maximum_temp_FL-Day,0,
ENG04530-MAS00109,BTM_Last_occurence_of_maximum_temp_FL-Hours,0,
ENG04530-MAS00110,BTM_Last_occurence_of_maximum_temp_FL-Minutes,0,
ENG04530-MAS00111,BTM_Last_occurence_of_maximum_temp_FL-Seconds,0,
ENG04528-MAS00106,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Year,2000,
ENG04528-MAS00107,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Month,0,
ENG04528-MAS00108,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Day,0,
ENG04528-MAS00109,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Hours,0,
ENG04528-MAS00110,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Minutes,0,
ENG04528-MAS00111,BTM_Last_occurence_of_temperature_FL_greater_than_temp_limit-Seconds,0,
ENG04534-MAS00106,BTM_Last_reset_of_driving_with pushed_brakes-Year,2000,
ENG04534-MAS00107,BTM_Last_reset_of_driving_with pushed_brakes-Month,0,
ENG04534-MAS00108,BTM_Last_reset_of_driving_with pushed_brakes-Day,0,
ENG04534-MAS00109,BTM_Last_reset_of_driving_with pushed_brakes-Hours,0,
ENG04534-MAS00110,BTM_Last_reset_of_driving_with pushed_brakes-Minutes,0,
ENG04534-MAS00111,BTM_Last_reset_of_driving_with pushed_brakes-Seconds,0,
ENG04531-MAS00106,BTM_Last_reset_of_maximum_temp_FL-Year,2000,
ENG04531-MAS00107,BTM_Last_reset_of_maximum_temp_FL-Month,0,
ENG04531-MAS00108,BTM_Last_reset_of_maximum_temp_FL-Day,0,
ENG04531-MAS00109,BTM_Last_reset_of_maximum_temp_FL-Hours,0,
ENG04531-MAS00110,BTM_Last_reset_of_maximum_temp_FL-Minutes,0,
ENG04531-MAS00111,BTM_Last_reset_of_maximum_temp_FL-Seconds,0,
ENG04529-MAS00106,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Year,2000,
ENG04529-MAS00107,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Month,0,
ENG04529-MAS00108,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Day,0,
ENG04529-MAS00109,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Hours,0,
ENG04529-MAS00110,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Minutes,0,
ENG04529-MAS00111,BTM_Last_reset_of_temperature_FL_greater_than_temp_limit-Seconds,0,
ENG04545,BTM_Maximum_temp_of_temperature_brake_FL,-40.00, °C
ENG04527,BTM_Time_of_temperature_FL_greater_than_temp_limit,0, s
ENG101413,Calibration Identification,4KE059AF0242'p1%,
ENG99697,Calibration Verification Number,78 67 4C 94,
ENG118064,Dataset_ESC,AU516ESCA07P,
ENG118064,Dataset_ESC,A07P,
ENG118064,Dataset_ESC,00 46,
ENG118064,Dataset_ESC,71 00,
ENG118064,Dataset_ESC,Correct result,
ENG118064,Dataset_ESC,B1 19 7A 24,
ENG118065,Dataset_PBC,Correct result,
ENG118065,Dataset_PBC,A00G,
ENG118065,Dataset_PBC,39,
ENG118065,Dataset_PBC,B2 F5 89 95,
ENG118065,Dataset_PBC,AU516PBCA00G,
ENG118065,Dataset_PBC,71 01,
ENG118066,Dataset_Reku,D7,
ENG118066,Dataset_Reku,AU516RTCD715,
ENG118066,Dataset_Reku,Correct result,
ENG118066,Dataset_Reku,71 02,
ENG118066,Dataset_Reku,CE 21 D2 B4,
ENG118066,Dataset_Reku,D715,
ENG04552-ENG04693,Driver_Presence_Status-Input_Signal_A_Belt_Error,No malfunction,
ENG04552-ENG04692,Driver_Presence_Status-Input_Signal_A_Belt_Status,not installed,
ENG04552-ENG04695,Driver_Presence_Status-Input_Signal_B_Door_Error,No malfunction,
ENG04552-ENG04694,Driver_Presence_Status-Input_Signal_B_Door_Status,Initialization,
ENG04562-MAS02141,DSDL_VIN_Check_Status-Monitoring VIN,passive,
ENG04562,DSDL_VIN_Check_Status,will be performed.,
ENG100152-ENG104003,ECUNAME-ECU,BSCM,
ENG100152,ECUNAME,BrakeSystem,
ENG04543,EDS_active_flag,active,
ENG118076-MAS00106,EPB_Notstopp_Eventcounter-Year,2000,
ENG118076-MAS00107,EPB_Notstopp_Eventcounter-Month,0,
ENG118076-MAS00108,EPB_Notstopp_Eventcounter-Day,0,
ENG118076-MAS00109,EPB_Notstopp_Eventcounter-Hours,0,
ENG118076-MAS00110,EPB_Notstopp_Eventcounter-Minutes,0,
ENG118076-MAS00111,EPB_Notstopp_Eventcounter-Seconds,0,
ENG118076-ENG118371,EPB_Notstopp_Eventcounter-Accelerator_Status_0,0.0, %
ENG118076-ENG118372,EPB_Notstopp_Eventcounter-Accelerator_Status_1,0.0, %
ENG118076-ENG118343,EPB_Notstopp_Eventcounter-Accelerator_Status_2,0.0, %
ENG118076-ENG118241,EPB_Notstopp_Eventcounter-Accelerator_Status_3,0.0, %
ENG118076-ENG118323,EPB_Notstopp_Eventcounter-Activation_counter_0,0, ms
ENG118076-ENG118244,EPB_Notstopp_Eventcounter-Activation_counter_1,0, ms
ENG118076-ENG118425,EPB_Notstopp_Eventcounter-Activation_counter_2,0, ms
ENG118076-ENG118289,EPB_Notstopp_Eventcounter-Activation_counter_3,0, ms
ENG118076-ENG118451,EPB_Notstopp_Eventcounter-Driver_Braking_Status_0,Bsd_signal_not_avail,
ENG118076-ENG118409,EPB_Notstopp_Eventcounter-Driver_Braking_Status_1,Bsd_signal_not_avail,
ENG118076-ENG118299,EPB_Notstopp_Eventcounter-Driver_Braking_Status_2,Bsd_signal_not_avail,
ENG118076-ENG118306,EPB_Notstopp_Eventcounter-Driver_Braking_Status_3,Bsd_signal_not_avail,
ENG118076-ENG118229,EPB_Notstopp_Eventcounter-ENG_Status_0,Engine_state_not_configured,
ENG118076-ENG118431,EPB_Notstopp_Eventcounter-ENG_Status_1,Engine_state_not_configured,
ENG118076-ENG118217,EPB_Notstopp_Eventcounter-ENG_Status_2,Engine_state_not_configured,
ENG118076-ENG118403,EPB_Notstopp_Eventcounter-ENG_Status_3,Engine_state_not_configured,
ENG118076-ENG118250,EPB_Notstopp_Eventcounter-EPB_Status_0,Not applied (inactive),
ENG118076-ENG118447,EPB_Notstopp_Eventcounter-EPB_Status_1,Not applied (inactive),
ENG118076-ENG118307,EPB_Notstopp_Eventcounter-EPB_Status_2,Not applied (inactive),
ENG118076-ENG118441,EPB_Notstopp_Eventcounter-EPB_Status_3,Not applied (inactive),
ENG118076-ENG118319,EPB_Notstopp_Eventcounter-GEAR_Status_0,Ssi_e_gear_lvr2_notavail,
ENG118076-ENG118432,EPB_Notstopp_Eventcounter-GEAR_Status_1,Ssi_e_gear_lvr2_notavail,
ENG118076-ENG118328,EPB_Notstopp_Eventcounter-GEAR_Status_2,Ssi_e_gear_lvr2_notavail,
ENG118076-ENG118314,EPB_Notstopp_Eventcounter-GEAR_Status_3,Ssi_e_gear_lvr2_notavail,
ENG118076-ENG118334,EPB_Notstopp_Eventcounter-IGN_Status_0,Nothing detected/OFF,
ENG118076-ENG118260,EPB_Notstopp_Eventcounter-IGN_Status_1,Nothing detected/OFF,
ENG118076-ENG118321,EPB_Notstopp_Eventcounter-IGN_Status_2,Nothing detected/OFF,
ENG118076-ENG118238,EPB_Notstopp_Eventcounter-IGN_Status_3,Nothing detected/OFF,
ENG118076-ENG118449,EPB_Notstopp_Eventcounter-Kilometer_0,0, km
ENG118076-ENG118304,EPB_Notstopp_Eventcounter-Kilometer_1,0, km
ENG118076-ENG118453,EPB_Notstopp_Eventcounter-Kilometer_2,0, km
ENG118076-ENG118406,EPB_Notstopp_Eventcounter-Kilometer_3,0, km
ENG118076-ENG118341,EPB_Notstopp_Eventcounter-LAC_Voltage_0,0.00, V
ENG118076-ENG118234,EPB_Notstopp_Eventcounter-LAC_Voltage_1,0.00, V
ENG118076-ENG118353,EPB_Notstopp_Eventcounter-LAC_Voltage_2,0.00, V
ENG118076-ENG118226,EPB_Notstopp_Eventcounter-LAC_Voltage_3,0.00, V
ENG118076-ENG118351,EPB_Notstopp_Eventcounter-Velocity_0,0.00, km/h
ENG118076-ENG118387,EPB_Notstopp_Eventcounter-Velocity_1,0.00, km/h
ENG118076-ENG118367,EPB_Notstopp_Eventcounter-Velocity_2,0.00, km/h
ENG118076-ENG118376,EPB_Notstopp_Eventcounter-Velocity_3,0.00, km/h
ENG07646-ENG98502,ESC_Function_mode-Data,0,
ENG04536,FIBEX_Version,V8.15.00F,
ENG118077-ENG118324,Ground_breakdown_detection-current_distribution_gnd1_gnd2,111.1, %
ENG118077-ENG98933,Ground_breakdown_detection-Status,no_evaluation_this_ignition_cycle,
ENG111914,NoPata,00,
ENG111914,NoPata,01,
ENG118090-MAS03375,Parameterset_of_tyre_monitor_display-Major version,0A,
ENG118090-MAS03376,Parameterset_of_tyre_monitor_display-Minor version,09,
ENG118090-ENG118316,Parameterset_of_tyre_monitor_display-Parameterset_of_tyre_monitor_display_adress,71 03,
ENG118090-ENG118209,Parameterset_of_tyre_monitor_display-Parameterset_of_tyre_monitor_display_checksum,91 23 81 35,
ENG118090-ENG118315,Parameterset_of_tyre_monitor_display-Parameterset_of_tyre_monitor_display_name,AU516RKAEN0D,
ENG118090-ENG118347,Parameterset_of_tyre_monitor_display-Parameterset_of_tyre_monitor_display_version,EN0D,
ENG118091,Parameterset_of_tyre_monitor_display_content_checksum,D7 88 B6 8E DE 31 15 08,
ENG04553,PBC_SW_Version,S11_00,
ENG04526,Steering_angle_sensor_data,passive,
ENG04526,Steering_angle_sensor_data,valid,
ENG04526,Steering_angle_sensor_data,OK,
ENG07092-MAS00106,Time_Mileage_RollerBenchMode_907_Deactivation-Year,2000,
ENG07092-MAS00107,Time_Mileage_RollerBenchMode_907_Deactivation-Month,0,
ENG07092-MAS00108,Time_Mileage_RollerBenchMode_907_Deactivation-Day,0,
ENG07092-MAS00109,Time_Mileage_RollerBenchMode_907_Deactivation-Hours,0,
ENG07092-MAS00110,Time_Mileage_RollerBenchMode_907_Deactivation-Minutes,0,
ENG07092-MAS00111,Time_Mileage_RollerBenchMode_907_Deactivation-Seconds,0,
ENG07092-ENG07118,Time_Mileage_RollerBenchMode_907_Deactivation-RBM KM,0, km
ENG04561-MAS00106,Time_Mileage_Stamp_Rollover_Mitigation_Function-Year,2000,
ENG04561-MAS00107,Time_Mileage_Stamp_Rollover_Mitigation_Function-Month,0,
ENG04561-MAS00108,Time_Mileage_Stamp_Rollover_Mitigation_Function-Day,0,
ENG04561-MAS00109,Time_Mileage_Stamp_Rollover_Mitigation_Function-Hours,0,
ENG04561-MAS00110,Time_Mileage_Stamp_Rollover_Mitigation_Function-Minutes,0,
ENG04561-MAS00111,Time_Mileage_Stamp_Rollover_Mitigation_Function-Seconds,0,
ENG04561-ENG04717,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 KM,0, km
ENG04561-ENG04718,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_0 Status,not active,
ENG04561-ENG04725,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 KM,0, km
ENG04561-ENG04726,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_1 Status,not active,
ENG04561-ENG04733,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 KM,0, km
ENG04561-ENG04734,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_2 Status,not active,
ENG04561-ENG04741,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 KM,0, km
ENG04561-ENG04742,Time_Mileage_Stamp_Rollover_Mitigation_Function-RMF_3 Status,not active,
Elapsed Time: 00:26
blockmap-09-4N0-907-063-JG_WA1AAAGE8MB028917-20210516-1156.CSV
;SW:4N0-907-063-JG   HW:4N0-907-063-AG ---  Cent. Elect.
;Component:BCM1 MLBevo   H10 0712, Coding:07000363C0E91CDD074007089CEF9C28130B37510C06009709010A0019231601086309024010200000000100004B181A0802800044010000000000000000000000
;EV_BCM1BOSCHAU651,017002,EV_BCM1BOSCHAU651_017.rod
;Sunday,16,May,2021,11:56:35:36589
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210508 DS325.1
;VCID: 7CA1FDDC5663893BD3B-8028
Group,Description,Actual
IDE00025,Coolant temperature,24.10, °C
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00970,Coolant fan activation: actual value,0.00, %
IDE00971,Coolant fan activation: specified value,0.00, %
IDE00972,Idle speed increase,not active,
IDE00983,Inside temperature,26.60, °C
IDE01063,Status of recirculation air,Fresh air,
IDE01076,Time since ignition off,31, min
IDE01164-MAS06614,Parking aid button-Variant,Local data bus: operating unit 2,
IDE01164-MAS07693,Parking aid button-Button Status,Not operated,
IDE01164-MAS07694,Parking aid button-Button status on CAN,Not operated,
IDE01164-MAS07699,Parking aid button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Parking aid button-Indicator lamp activation,OFF,
IDE01227,Blower current,2.25, A
IDE01241,Position sensor in left side vent: voltage,not coded/not installed,
IDE01243,Position sensor in right side vent: voltage,not coded/not installed,
IDE01245,Position sensor in left center vent: voltage,not coded/not installed,
IDE01247,Position sensor in right center vent: voltage,not coded/not installed,
IDE01249,Left rear upper body vent position sensor: voltage,not coded/not installed,
IDE01251,Right rear upper body vent position sensor: voltage,not coded/not installed,
IDE01266-MAS01580,Coolant shut-off valve-Activation,not coded/not installed,
IDE01266-MAS07806,Coolant shut-off valve-Specified status,not coded/not installed,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),not coded/not installed,
IDE01268-MAS01464,Windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Windshield wiper-Status,not active,
IDE01268-MAS02832,Windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Windshield wiper-Overload,not active,
IDE01268-MAS03638,Windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Windshield wiper-Status local activity,not active,
IDE01268-MAS06897,Windshield wiper-Wipe cycle counter,22,
IDE01268-MAS07055,Windshield wiper-Response error,not active,
IDE01268-MAS07998,Windshield wiper-park position,active,
IDE01268-MAS09379,Windshield wiper-Service position,not active,
IDE01268-MAS09595,Windshield wiper-Production mode,not active,
IDE01268-MAS09596,Windshield wiper-Debug Data,Not available,
IDE01268-MAS09597,Windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Windshield wiper-Status error validity: wiper 2,invalid,
IDE01287,Counter of compressor switch-offs,0,
IDE01309,Recirculation air flap motor: actual value,10000,
IDE01311,Left side vent flap motor: actual value,11005,
IDE01312,Right side vent flap motor: actual value,11352,
IDE01313,Left footwell flap motor: actual value,10000,
IDE01314,Right footwell flap motor: actual value,10000,
IDE01315,Left center vent flap motor: actual value,10989,
IDE01316,Right center vent flap motor: actual value,10661,
IDE01325,Left B-Pillar/Footwell Shut-Off Flap Motor: actual value,11169,
IDE01326,Right B-Pillar/Footwell Shut-Off Flap Motor: actual value,11175,
IDE01328-IDE09056,Recirculation air flap motor: diagnostic-Last operating state,blockage,
IDE01328-MAS01458,Recirculation air flap motor: diagnostic-Operating condition,No routine started,
IDE01330-IDE09056,Left side vent flap motor: diagnostic-Last operating state,Move flap motor,
IDE01330-MAS01458,Left side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01331-IDE09056,Right side vent flap motor: diagnostic-Last operating state,Move flap motor,
IDE01331-MAS01458,Right side vent flap motor: diagnostic-Operating condition,No routine started,
IDE01332-IDE09056,Left footwell flap motor: diagnostic-Last operating state,blockage,
IDE01332-MAS01458,Left footwell flap motor: diagnostic-Operating condition,No routine started,
IDE01333-IDE09056,Right footwell flap motor: diagnostic-Last operating state,blockage,
IDE01333-MAS01458,Right footwell flap motor: diagnostic-Operating condition,No routine started,
IDE01334-IDE09056,Left center vent flap motor: diagnostic-Last operating state,blockage,
IDE01334-MAS01458,Left center vent flap motor: diagnostic-Operating condition,No routine started,
IDE01335-IDE09056,Right center vent flap motor: diagnostic-Last operating state,End impact,
IDE01335-MAS01458,Right center vent flap motor: diagnostic-Operating condition,No routine started,
IDE01344-IDE09056,Left B-pillar shut-off flap motor: diagnostic-Last operating state,Move flap motor,
IDE01344-MAS01458,Left B-pillar shut-off flap motor: diagnostic-Operating condition,No routine started,
IDE01345-IDE09056,Right B-pillar shut-off flap motor: diagnostic-Last operating state,End impact,
IDE01345-MAS01458,Right B-pillar shut-off flap motor: diagnostic-Operating condition,No routine started,
IDE01352,Temperature unit,°F,
IDE01419,Compressor shut-off condition: last,Compressor active: no shut-off condition is present,
IDE01420,Compressor shut-off requirement: penultimate,Compressor active: no shut-off condition is present,
IDE01421,Compressor shut-off requirement: antepenultimate,Compressor active: no shut-off condition is present,
IDE01425,Defrost flap motor: actual value,10000,
IDE01426,Left temperature flap motor: actual value,10000,
IDE01427,Right temperature flap motor: actual value,10000,
IDE01428-IDE09056,Defrost flap motor: diagnostic-Last operating state,blockage,
IDE01428-MAS01458,Defrost flap motor: diagnostic-Operating condition,No routine started,
IDE01429-IDE09056,Left temperature flap motor: diagnostic-Last operating state,blockage,
IDE01429-MAS01458,Left temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01430-IDE09056,Right temperature flap motor: diagnostic-Last operating state,blockage,
IDE01430-MAS01458,Right temperature flap motor: diagnostic-Operating condition,No routine started,
IDE01433,Air quality status,Clean air,
IDE01455,Key number,1,
IDE01488-MAS01458,Auxiliary heating retrofit without CAN-Operating condition,not coded/not installed,
IDE01488-MAS05773,Auxiliary heating retrofit without CAN-Voltage of signal line,not coded/not installed,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,not coded/not installed,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,not coded/not installed,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,not coded/not installed,
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,26.80, °C
IDE01540-MAS07052,Left front heated seat-Setting,Not available,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,7.45, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01540-MAS07921,Left front heated seat-Balance setting,Not available,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.04, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,not coded/not installed,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,not coded/not installed,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,not coded/not installed,
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,26.40, °C
IDE01541-MAS07052,Right front heated seat-Setting,Not available,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,7.54, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,not coded/not installed,
IDE01541-MAS07921,Right front heated seat-Balance setting,Not available,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,not coded/not installed,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,not coded/not installed,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not active,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.04, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-IDE01270,Auxiliary Air Heater-Enabling for auxiliary heater operation,No enabling,
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,OFF,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,OFF,
IDE01544-MAS07913,Auxiliary Air Heater-Heating stage: current value,OFF,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,OFF,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),0, mA
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),0, mA
IDE01622,Fresh air blower: speed,1900, /min
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Variant,Local data bus: operating unit 2,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,Not operated,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Not operated,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator lamp activation,OFF,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,F8 5F 4F 53,
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,can be reached,
IDE01992-SFT00041,Installation list: current installations-Left light control,not attainable,
IDE01992-SFT00057,Installation list: current installations-Right light control,not attainable,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,can be reached,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,can be reached,
IDE01992-SFT00216,Installation list: current installations-Projection module in left matrix headlamp,not attainable,
IDE01992-SFT00217,Installation list: current installations-Projection module in right matrix headlamp,not attainable,
IDE01992-SFT33232,Installation list: current installations-Central control for digital matrix light,not attainable,
IDE01993-SFT00009,Control module reference number-Electronic central electric,Electronic central electric,
IDE01993-SFT00041,Control module reference number-Left light control,Left light control,
IDE01993-SFT00057,Control module reference number-Right light control,Right light control,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01993-SFT00216,Control module reference number-Projection module in left matrix headlamp,Projection module in left matrix headlamp,
IDE01993-SFT00217,Control module reference number-Projection module in right matrix headlamp,Projection module in right matrix headlamp,
IDE01993-SFT33232,Control module reference number-Central control for digital matrix light,Central control for digital matrix light,
IDE01995-SFT00009,Control module protocol information-Electronic central electric,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Left light control,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Right light control,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE01995-SFT00216,Control module protocol information-Projection module in left matrix headlamp,ISO-TP,
IDE01995-SFT00217,Control module protocol information-Projection module in right matrix headlamp,ISO-TP,
IDE01995-SFT33232,Control module protocol information-Central control for digital matrix light,ISO-TP,
IDE02384-SFT00009,Status of event memory-Electronic central electric,Malfunction,
IDE02384-SFT00041,Status of event memory-Left light control,OK,
IDE02384-SFT00057,Status of event memory-Right light control,OK,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,Malfunction,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,Malfunction,
IDE02384-SFT00216,Status of event memory-Projection module in left matrix headlamp,OK,
IDE02384-SFT00217,Status of event memory-Projection module in right matrix headlamp,OK,
IDE02384-SFT33232,Status of event memory-Central control for digital matrix light,OK,
IDE02433,Left rear temperature flap motor: actual value,10000,
IDE02434-IDE09056,Left rear temperature flap motor: diagnostic-Last operating state,blockage,
IDE02434-MAS01458,Left rear temperature flap motor: diagnostic-Operating condition,No routine started,
IDE02436,Right rear temperature flap motor: actual value,10000,
IDE02437-IDE09056,Right rear temperature flap motor: diagnostic-Last operating state,blockage,
IDE02437-MAS01458,Right rear temperature flap motor: diagnostic-Operating condition,No routine started,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02492,Start/Stop Function: coding information,Start-stop function in control module not active,
IDE02711-MAS09598,Rear wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear wiper-Error status via CAN,No error: no wiper activation,
IDE02834,Fresh air flap motor: actual value,11223,
IDE02835-IDE09056,Fresh air flap motor: diagnostic-Last operating state,blockage,
IDE02835-MAS01458,Fresh air flap motor: diagnostic-Operating condition,No routine started,
IDE03008-IDE80251,Stop process prevented-Head area heater,not active,
IDE03008-MAS00385,Stop process prevented-Basic setting active,not active,
IDE03008-MAS01957,Stop process prevented-Outside temperature,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Blowout temperature difference to specifications,not active,
IDE03008-MAS03902,Stop process prevented-Adaptation A/C comfort stop activation,not active,
IDE03010-IDE80251,Number of prevented stop processes-Head area heater,0,
IDE03010-MAS00385,Number of prevented stop processes-Basic setting active,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01957,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Blowout temperature difference to specifications,0,
IDE03010-MAS03902,Number of prevented stop processes-Adaptation A/C comfort stop activation,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03011-IDE80251,Number of requested start processes-Head area heater,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01957,Number of requested start processes-Outside temperature,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Blowout temperature difference to specifications,0,
IDE03011-MAS03902,Number of requested start processes-Adaptation A/C comfort stop activation,0,
IDE03011-MAS03903,Number of requested start processes-Dew point gradient,0,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03111-MAS06885,Interior lighting-Terminal 30 for interior lighting,84, %
IDE03111-MAS06886,Interior lighting-Dimming for interior lighting,0, %
IDE03111-MAS06986,Interior lighting-Footwell illumination rear,0, %
IDE03111-MAS06987,Interior lighting-Footwell illumination front,84, %
IDE03111-MAS09295,Interior lighting-Ambient lighting channel 1,not coded/not installed,
IDE03111-MAS09297,Interior lighting-Ambient illumination power supply,0, %
IDE03111-MAS12622,Interior lighting-Terminal 30 for interior lighting: current draw (effect. value),0, mA
IDE03111-MAS12623,Interior lighting-Foot well illumination: rear: current draw (effective value),0, mA
IDE03111-MAS12624,Interior lighting-Foot well illumination: front: current draw (effective value),23, mA
IDE03111-MAS12625,Interior lighting-Ambient illumination channel 1: current draw (effective value),not coded/not installed,
IDE03111-MAS12626,Interior lighting-Supply for ambient illumination: current draw (effective value),0, mA
IDE03111-MAS12627,Interior lighting-Trunk illumination: front: current draw (effective value),0, mA
IDE03111-MAS12917,Interior lighting-Rear ambient lighting channel 1,not coded/not installed,
IDE03111-MAS12918,Interior lighting-Rear ambient light.chan. 1: current drawn (effective value),not coded/not installed,
IDE03111-MAS12919,Interior lighting-Roof ambient lighting channel 1,not coded/not installed,
IDE03111-MAS12920,Interior lighting-Roof ambient lighting channel 1: current drawn (effect. value),not coded/not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Left light control,active,
IDE03150-SFT00057,Readiness for bus sleep mode-Right light control,active,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03150-SFT00216,Readiness for bus sleep mode-Projection module in left matrix headlamp,active,
IDE03150-SFT00217,Readiness for bus sleep mode-Projection module in right matrix headlamp,active,
IDE03150-SFT33232,Readiness for bus sleep mode-Central control for digital matrix light,active,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,On,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,0, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,Initialization,
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,OFF,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Dark,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,24, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,System malfunction,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE03602,Left front level control system sensor,Measuring value not available,
IDE03604,Left rear level control system sensor,Measuring value not available,
IDE03620,Front jounce travel,-2, mm
IDE03621,Rear jounce travel,-4, mm
IDE03622,Left headlight beam adjusting motor: status,Fault position run started,
IDE03623,Right headlight beam adjusting motor: status,Fault position run started,
IDE03624,Left dynamic AFS light motor: specified value,Measuring value not available,
IDE03625,Right dynamic AFS light motor: specified value,Measuring value not available,
IDE03626,Left dynamic AFS light motor: status,Measuring value not available,
IDE03627,Right dynamic AFS light motor: status,Measuring value not available,
IDE03628,Adjusting motor for variable left front lighting: status,Measuring value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measuring value not available,
IDE03630,Left headlight beam adjusting motor: specified value,Initialization,
IDE03631,Right headlight beam adjusting motor: specified value,Initialization,
IDE03632,Left-/right hand driving switch-over,Measuring value not available,
IDE03638-IDE03717,Stationary cornering lamp-Dim static left AFS light,0.00, %
IDE03638-IDE03718,Stationary cornering lamp-Dim static right AFS light,0.00, %
IDE03640,Dynamic AFS light,OFF,
IDE03662-MAS06614,ASR/ESP button-Variant,Local data bus: operating unit 1,
IDE03662-MAS07693,ASR/ESP button-Button Status,Not operated,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Not operated,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator lamp activation,OFF,
IDE03663-MAS06614,-AUTO HOLD- Button-Variant,not coded/not installed,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,not coded/not installed,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Initialization/not installed,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator lamp activation,not coded/not installed,
IDE03669,Status of light distribution,Measuring value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,On,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded/not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded/not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded/not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded/not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,not coded/not installed,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,not coded/not installed,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,not coded/not installed,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded/not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,not coded/not installed,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,14.36, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,14.19, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,14.39, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,14.28, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,14.13, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,14.21, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,14.30, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,14.32, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,14.28, V
IDE03727,Variable left front lighting specified position,Measuring value not available,
IDE03728,Variable right front lighting specified position,Measuring value not available,
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adapt. value (zero pos),Measuring value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Measuring value not available,
IDE04312-IDE04095,System run time-Engine running time,0, s
IDE04312-MAS00084,System run time-Terminal 15 on,530, s
IDE04343-SFT00009,Bus identification-Electronic central electric,Bus master,
IDE04343-SFT00041,Bus identification-Left light control,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Right light control,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04343-SFT00216,Bus identification-Projection module in left matrix headlamp,AFS/From light data bus,
IDE04343-SFT00217,Bus identification-Projection module in right matrix headlamp,AFS/From light data bus,
IDE04343-SFT33232,Bus identification-Central control for digital matrix light,AFS/From light data bus,
IDE04741-MAS06614,Rear window defogger button-Variant,Local data bus: operating unit 1,
IDE04741-MAS07693,Rear window defogger button-Button Status,Not operated,
IDE04741-MAS07694,Rear window defogger button-Button status on CAN,Not operated,
IDE04741-MAS07699,Rear window defogger button-Status indicator light on CAN,OFF,
IDE04741-MAS08062,Rear window defogger button-Indicator lamp activation,OFF,
IDE04806-MAS06614,Driving profile selection button-Variant,Local data bus: operating unit 1,
IDE04806-MAS07693,Driving profile selection button-Button Status,Not operated,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Not operated,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Variant,Local data bus: operating unit 1,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator lamp activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Variant,not coded/not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded/not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator lamp activation,not coded/not installed,
IDE05534-MAS01580,Headlamp washer system-Activation,OFF,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),0, mA
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,26.30, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,26.00, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,55.50, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,16.90, °C
IDE06091-MAS07055,Humidity sensor: interior-Response error,not active,
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,24.90, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,53.00, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,21.40, °C
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Defrost active,
IDE06307,Stop prevention history data,Adaptation A/C comfort stop activation,
IDE06307,Stop prevention history data,Outside temperature,
IDE06307,Stop prevention history data,Maximum cooling and heating set,
IDE06307,Stop prevention history data,Interior temperature difference to specifications,
IDE06307,Stop prevention history data,Blowout temperature difference to specifications,
IDE06307,Stop prevention history data,Fogging hazard (humidity sensor),
IDE06307,Stop prevention history data,Interior comfort humidity too high (humidity sensor),
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Maximum cooling and heating set,
IDE06308,Start request history data,Defrost active,
IDE06308,Start request history data,Interior comfort humidity too high (humidity sensor),
IDE06308,Start request history data,Maximum permissible stop duration reached,
IDE06308,Start request history data,Fogging hazard (humidity sensor),
IDE06308,Start request history data,Outside temperature,
IDE06308,Start request history data,Dew point gradient,
IDE06308,Start request history data,Blowout temperature difference to specifications,
IDE06308,Start request history data,Adaptation A/C comfort stop activation,
IDE06308,Start request history data,Interior temperature difference to specifications,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded/not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded/not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded/not installed,
IDE06752-MAS06614,Hill descent control button-Variant,not coded/not installed,
IDE06752-MAS07693,Hill descent control button-Button Status,not coded/not installed,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Initialization/not installed,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator lamp activation,not coded/not installed,
IDE06807,Fresh-air door motor / specified value,11223,
IDE06808,Fresh-air door motor / dynamics,1223,
IDE06809,Left temp. door motor / specified value,10000,
IDE06810,Left temp. door motor / dynamics,1417,
IDE06811,Right temp. door motor: specified value,10000,
IDE06812,Right temp. door motor: dynamics,1427,
IDE06813,Defroster door motor: specified value,10000,
IDE06814,Defroster door motor: dynamics,1516,
IDE06815,Recirc. air flap motor: spec.value,10000,
IDE06816,Recirc. air flap motor: dynamics,1581,
IDE06823,Left center vent motor / specified value,10989,
IDE06824,Left center vent motor / dynamics,989,
IDE06825,Right center vent motor: specified value,10661,
IDE06826,Right center vent motor: dynamics,1033,
IDE07080-MAS07921,Left rear seat ventilation setting-Balance setting,not coded/not installed,
IDE07080-MAS07928,Left rear seat ventilation setting-Ventilation stage,not coded/not installed,
IDE07080-MAS07929,Left rear seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE07133,Fresh air blower motor: temperature,28, °C
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07244-MAS07921,Right rear seat ventilation setting-Balance setting,not coded/not installed,
IDE07244-MAS07928,Right rear seat ventilation setting-Ventilation stage,not coded/not installed,
IDE07244-MAS07929,Right rear seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Target value,not coded/not installed,
IDE07246-MAS01447,Left rear seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE07246-MAS01448,Left rear seat backrest fan 2: activation-Target value,not coded/not installed,
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Target value,not coded/not installed,
IDE07248-MAS01447,Left rear seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE07248-MAS01448,Left rear seat cushion fan 2: activation-Target value,not coded/not installed,
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Target value,not coded/not installed,
IDE07250-MAS01447,Right rear seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE07250-MAS01448,Right rear seat backrest fan 2: activation-Target value,not coded/not installed,
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Target value,not coded/not installed,
IDE07252-MAS01447,Right rear seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE07252-MAS01448,Right rear seat cushion fan 2: activation-Target value,not coded/not installed,
IDE07253-IDE11719,Installation info: rear seat ventilation-Fan 1 for left rear seat backrest,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Fan 1 for right rear seat backrest,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Fan 1 for right rear seat cushion,not installed,
IDE07253-IDE11723,Installation info: rear seat ventilation-Fan 2 for left rear seat backrest,not installed,
IDE07253-IDE11724,Installation info: rear seat ventilation-Fan 2 for left rear seat cushion,not installed,
IDE07253-IDE11725,Installation info: rear seat ventilation-Fan 2 for right rear seat backrest,not installed,
IDE07253-IDE11726,Installation info: rear seat ventilation-Fan 2 for right rear seat cushion,not installed,
IDE07259,Rear left air distribution servomotor: actual value,14358,
IDE07260,Rear left air distribution servomotor: reference value,14358,
IDE07261,Rear left air distribution servomotor: dynamic,6317,
IDE07262-IDE09056,Rear left air distribution servomotor: diagnosis-Last operating state,End impact,
IDE07262-MAS01458,Rear left air distribution servomotor: diagnosis-Operating condition,No routine started,
IDE07263,Rear right air distribution servomotor: actual value,14351,
IDE07264,Rear right air distribution servomotor: reference value,14351,
IDE07265,Rear right air distribution servomotor: dynamic,6307,
IDE07266-IDE09056,Rear right air distribution servomotor: diagnosis-Last operating state,End impact,
IDE07266-MAS01458,Rear right air distribution servomotor: diagnosis-Operating condition,No routine started,
IDE07459,Left footwell door motor / specified value,10000,
IDE07460,Left footwell door motor: dynamics,983,
IDE07461,Right footwell door motor / specified value,10000,
IDE07462,Right footwell door motor: dynamics,968,
IDE07491,Left rear temp door motor: spec. value,10000,
IDE07492,Left rear temp door motor: dynamics,1581,
IDE07493,Right rear temp door motor: spec. value,10000,
IDE07494,Right rear temp door motor: dynamics,1542,
IDE07499,Left side vent flap motor: spec.value,11005,
IDE07500,Left side vent flap motor: dynamics,1648,
IDE07501,Right side vent flap motor: spec. value,11352,
IDE07502,Right side vent flap motor: dynamics,1779,
IDE07505,Left B-Pillar/Footwell Shut-Off Flap Motor: specified value,11186,
IDE07506,Left B-Pillar/Footwell Shut-Off Flap Motor: dynamic,1745,
IDE07507,Right B-Pillar/Footwell Shut-Off Flap Motor: specified value,11175,
IDE07508,Right B-Pillar/Footwell Shut-Off Flap Motor: dynamic,1755,
IDE07950-IDE04095,Historical data of motors-Engine running time,510, s
IDE07950-IDE09056,Historical data of motors-Last operating state,Unknown (31),
IDE07950-MAS00084,Historical data of motors-Terminal 15 on,510, s
IDE07950-MAS00106,Historical data of motors-Year,2127,
IDE07950-MAS00107,Historical data of motors-Month,15,
IDE07950-MAS00108,Historical data of motors-Day,31,
IDE07950-MAS00109,Historical data of motors-Hours,31,
IDE07950-MAS00110,Historical data of motors-Minutes,63,
IDE07950-MAS00111,Historical data of motors-Seconds,63,
IDE07950-MAS01458,Historical data of motors-Operating condition,Unknown (31),
IDE07950-MAS03118,Historical data of motors-Logic address,255,
IDE07950-MAS03180,Historical data of motors-Local data bus,255,
IDE07950,Historical data of motors,25.50, V
IDE07991-MAS01580,A/C clutch-Activation,not coded/not installed,
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,not coded/not installed,
IDE07991-MAS12621,A/C clutch-Current draw (effective value),not coded/not installed,
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,not coded/not installed,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,not coded/not installed,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS02832,Left head area heater-Malfunction status,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08125-MAS07055,Left head area heater-Response error,not coded/not installed,
IDE08125-MAS09644,Left head area heater-Vent temperature,not coded/not installed,
IDE08125-MAS12677,Left head area heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS02832,Right head area heater-Malfunction status,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS07055,Right head area heater-Response error,not coded/not installed,
IDE08126-MAS09644,Right head area heater-Vent temperature,not coded/not installed,
IDE08126-MAS12677,Right head area heater-PTC heater element: current draw (effective value),not coded/not installed,
IDE08196-IDE01351,Terminal activation-Terminal 75 status,On,
IDE08196-MAS06982,Terminal activation-Terminal 15 status signal,On,
IDE08196-MAS07720,Terminal activation-Terminal 15 via CAN,On,
IDE08196-MAS08123,Terminal activation-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,BE 7F C4 66,
IDE08364-MAS01447,Left seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE08364-MAS01448,Left seat backrest fan 1: activation-Target value,not coded/not installed,
IDE08365-MAS01447,Left seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Target value,not coded/not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Target value,not coded/not installed,
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Target value,not coded/not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE08368-MAS01448,Right seat backrest fan 1: activation-Target value,not coded/not installed,
IDE08369-MAS01447,Right seat backrest fan 2: activation-Act.val.,not coded/not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Target value,not coded/not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE08370-MAS01448,Right seat cushion fan 1: activation-Target value,not coded/not installed,
IDE08371-MAS01447,Right seat cushion fan 2: activation-Act.val.,not coded/not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Target value,not coded/not installed,
IDE08372,Fresh air blower: target speed,1900, /min
IDE08376-MAS01580,Right Daytime Running Lamp and Parking Light Lamp-Activation,not coded/not installed,
IDE08376-MAS01737,Right Daytime Running Lamp and Parking Light Lamp-Diagnosis,not coded/not installed,
IDE08376-MAS12621,Right Daytime Running Lamp and Parking Light Lamp-Current draw (effective value),not coded/not installed,
IDE08377-MAS01580,Left daytime running lamp and position lamp bulb-Activation,not coded/not installed,
IDE08377-MAS01737,Left daytime running lamp and position lamp bulb-Diagnosis,not coded/not installed,
IDE08377-MAS12621,Left daytime running lamp and position lamp bulb-Current draw (effective value),not coded/not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded/not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded/not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded/not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded/not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded/not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded/not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded/not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded/not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded/not installed,
IDE08382-MAS01580,Right Front Side Marker Light-Activation,not coded/not installed,
IDE08382-MAS01737,Right Front Side Marker Light-Diagnosis,not coded/not installed,
IDE08382-MAS12621,Right Front Side Marker Light-Current draw (effective value),not coded/not installed,
IDE08383-MAS01580,Left Front Side Marker Light-Activation,not coded/not installed,
IDE08383-MAS01737,Left Front Side Marker Light-Diagnosis,not coded/not installed,
IDE08383-MAS12621,Left Front Side Marker Light-Current draw (effective value),not coded/not installed,
IDE08384-MAS01580,Right daytime running light lamp-Activation,not coded/not installed,
IDE08384-MAS01737,Right daytime running light lamp-Diagnosis,not coded/not installed,
IDE08384-MAS12621,Right daytime running light lamp-Current draw (effective value),not coded/not installed,
IDE08385-MAS01580,Left daytime running light lamp-Activation,not coded/not installed,
IDE08385-MAS01737,Left daytime running light lamp-Diagnosis,not coded/not installed,
IDE08385-MAS12621,Left daytime running light lamp-Current draw (effective value),not coded/not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,100.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,No malfunction,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),787, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,100.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,No malfunction,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),787, mA
IDE08388-MAS01580,Right high beam headlamp-Activation,not coded/not installed,
IDE08388-MAS01737,Right high beam headlamp-Diagnosis,not coded/not installed,
IDE08388-MAS12621,Right high beam headlamp-Current draw (effective value),not coded/not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded/not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded/not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded/not installed,
IDE08390-MAS01580,Right fog light lamp-Activation,not coded/not installed,
IDE08390-MAS01737,Right fog light lamp-Diagnosis,not coded/not installed,
IDE08390-MAS12621,Right fog light lamp-Current draw (effective value),not coded/not installed,
IDE08391-MAS01580,Left fog light lamp-Activation,not coded/not installed,
IDE08391-MAS01737,Left fog light lamp-Diagnosis,not coded/not installed,
IDE08391-MAS12621,Left fog light lamp-Current draw (effective value),not coded/not installed,
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded/not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded/not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded/not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded/not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,100, %
IDE08396-MAS01737,Headlights right: supply-Diagnosis,No malfunction,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),738, mA
IDE08397-MAS01580,Headlights left: supply-Activation,100, %
IDE08397-MAS01737,Headlights left: supply-Diagnosis,No malfunction,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),714, mA
IDE08402-IDE05742,Light switch-Light switch position,Not available,
IDE08402-IDE07956,Light switch-redundant signal line,OFF,
IDE08402-MAS03866,Light switch-Head-Up-Display button,Not available,
IDE08402-MAS03868,Light switch-Position of the Eyebox,Not available,
IDE08402-MAS06887,Light switch-Light switch position on CAN,Malfunction,
IDE08402-MAS06888,Light switch-Fog light button,Not available,
IDE08402-MAS06889,Light switch-Rear fog light button,Not available,
IDE08402-MAS06890,Light switch-Night vision system button,Not available,
IDE08402-MAS06891,Light switch-Control for Eyebox position,Not available,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,On,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,On,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,1.00, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,25.50, °C
IDE08408,Hood contact,closed,
IDE08408-MAS14040,Hood contact-Voltage ratio,98, %
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded/not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded/not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded/not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded/not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded/not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,OFF,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,OFF,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,OFF,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,OFF,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,OFF,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,OFF,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,OFF,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,not active,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,not active,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0, mA
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0, mA
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,not coded/not installed,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,not coded/not installed,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,not coded/not installed,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,not coded/not installed,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,not coded/not installed,
IDE08502-MAS01580,A/C compressor regulator valve-Activation,not coded/not installed,
IDE08502-MAS09777,A/C compressor regulator valve-Target current,not coded/not installed,
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,not coded/not installed,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),not coded/not installed,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,Measuring value not available,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,Measuring value not available,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,Measuring value not available,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measuring value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08543-MAS00370,Garage door opener: last programming-Vehicle speed,below threshold,
IDE08543-MAS01240,Garage door opener: last programming-Programming status,04,
IDE08543-MAS02246,Garage door opener: last programming-Timeout,Not reached,
IDE08543-MAS02949,Garage door opener: last programming-Frequency,05 F3 70,
IDE08543-MAS03159,Garage door opener: last programming-Manufacturer,81,
IDE08543-MAS04184,Garage door opener: last programming-Canceled by user,No,
IDE08543-MAS06670,Garage door opener: last programming-Channel,Channel 1,
IDE08543-MAS09308,Garage door opener: last programming-Error status and modulation,01000000 ,
IDE08543-MAS10442,Garage door opener: last programming-Programming antenna,External antenna,
IDE08544-MAS00370,Garage door opener: second-to-last progr.-Vehicle speed,below threshold,
IDE08544-MAS01240,Garage door opener: second-to-last progr.-Programming status,06,
IDE08544-MAS02246,Garage door opener: second-to-last progr.-Timeout,Not reached,
IDE08544-MAS02949,Garage door opener: second-to-last progr.-Frequency,05 F3 70,
IDE08544-MAS03159,Garage door opener: second-to-last progr.-Manufacturer,81,
IDE08544-MAS04184,Garage door opener: second-to-last progr.-Canceled by user,No,
IDE08544-MAS06670,Garage door opener: second-to-last progr.-Channel,Channel 1,
IDE08544-MAS09308,Garage door opener: second-to-last progr.-Error status and modulation,01000000 ,
IDE08544-MAS10442,Garage door opener: second-to-last progr.-Programming antenna,External antenna,
IDE08545-MAS00370,Garage door opener: third-to-last progr.-Vehicle speed,below threshold,
IDE08545-MAS01240,Garage door opener: third-to-last progr.-Programming status,06,
IDE08545-MAS02246,Garage door opener: third-to-last progr.-Timeout,Not reached,
IDE08545-MAS02949,Garage door opener: third-to-last progr.-Frequency,05 F3 70,
IDE08545-MAS03159,Garage door opener: third-to-last progr.-Manufacturer,81,
IDE08545-MAS04184,Garage door opener: third-to-last progr.-Canceled by user,No,
IDE08545-MAS06670,Garage door opener: third-to-last progr.-Channel,Channel 1,
IDE08545-MAS09308,Garage door opener: third-to-last progr.-Error status and modulation,01000000 ,
IDE08545-MAS10442,Garage door opener: third-to-last progr.-Programming antenna,External antenna,
IDE08622,Garage door opener: supply voltage,14.43, V
IDE08774-MAS01453,Fresh air blower: error status-Blocking detection,not active,
IDE08774-MAS01478,Fresh air blower: error status-insufficient voltage,not active,
IDE08774-MAS01479,Fresh air blower: error status-Excessive voltage,not active,
IDE08774-MAS01480,Fresh air blower: error status-excessive temperature,not active,
IDE08774-MAS01575,Fresh air blower: error status-Internal malfunction,not active,
IDE08774-MAS01807,Fresh air blower: error status-Short circuit,not active,
IDE08774-MAS07627,Fresh air blower: error status-Over current string,not active,
IDE08774-MAS07628,Fresh air blower: error status-Over current phase,not active,
IDE08774-MAS07629,Fresh air blower: error status-Error current offset,not active,
IDE08774-MAS07630,Fresh air blower: error status-error temperature sensor,not active,
IDE08774-MAS07631,Fresh air blower: error status-Error bridge driver,not active,
IDE08774-MAS07632,Fresh air blower: error status-Excess temp. bridge driver,not active,
IDE08795-MAS06614,Rear shade button-Variant,not coded/not installed,
IDE08795-MAS07693,Rear shade button-Button Status,not coded/not installed,
IDE08795-MAS07694,Rear shade button-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,Not moving,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,was not local active,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,1289,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,2158,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,Not operated,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,Not operated,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,Not operated,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,Not operated,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,Not operated,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),0.00, A
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),0.00, A
IDE08953,Garage door opener: country code,North America,
IDE08957-MAS01632,Supply for power outlets-Status,On,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,14.37, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,3.00, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,45.35, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),2, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,operational,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control unit 2 for driving and convenience functions,operational,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,not installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,not installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,not installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,not installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Variant,not coded/not installed,
IDE08979-MAS07693,Valet parking lock button-Button Status,not coded/not installed,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator lamp activation,not coded/not installed,
IDE08980-MAS06614,Button for rear spoiler adjustment-Variant,not coded/not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded/not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator lamp activation,not coded/not installed,
IDE08981-MAS06614,Front display open/close button-Variant,not coded/not installed,
IDE08981-MAS07693,Front display open/close button-Button Status,not coded/not installed,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Initialization/not installed,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Variant,not coded/not installed,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,not coded/not installed,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator lamp activation,not coded/not installed,
IDE08983-MAS06614,Driving profile selection button 2-Variant,Local data bus: operating unit 1,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,Not operated,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Not operated,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,too Low,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,normal,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,not coded/not installed,
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,not coded/not installed,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),not coded/not installed,
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,not coded/not installed,
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,not coded/not installed,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),not coded/not installed,
IDE09234-MAS01580,Subfloor lighting-Activation,not coded/not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded/not installed,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded/not installed,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded/not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded/not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09920-MAS06614,Special vehicle control module-Variant,not coded/not installed,
IDE09920-MAS06992,Special vehicle control module-Request wiping,not coded/not installed,
IDE09920-MAS06993,Special vehicle control module-Request signal horn,not coded/not installed,
IDE09920-MAS09569,Special vehicle control module-Remote control status,not coded/not installed,
IDE09920-MAS09570,Special vehicle control module-Parking light request,not coded/not installed,
IDE09920-MAS09571,Special vehicle control module-Low beam request,not coded/not installed,
IDE09920-MAS09572,Special vehicle control module-Intermittent high beam request,not coded/not installed,
IDE09920-MAS09573,Special vehicle control module-Footwell illumination request,not coded/not installed,
IDE09920-MAS09574,Special vehicle control module-Interior illumination request,not coded/not installed,
IDE09920-MAS09575,Special vehicle control module-High beam request,not coded/not installed,
IDE09920-MAS09576,Special vehicle control module-Wash request,not coded/not installed,
IDE09920-MAS09577,Special vehicle control module-Rear interval wash request,not coded/not installed,
IDE09920-MAS09586,Special vehicle control module-Headlight flasher request,not coded/not installed,
IDE09920-MAS09588,Special vehicle control module-Emerg. sig. flasher request,not coded/not installed,
IDE09920-MAS09589,Special vehicle control module-Daytime running light deactivation req.,not coded/not installed,
IDE09920-MAS09590,Special vehicle control module-Suppression of interior illumination request,not coded/not installed,
IDE09922-MAS01448,Static headlamp range control-Target value,not coded/not installed,
IDE09922-MAS09527,Static headlamp range control-Activation voltage: act. value,not coded/not installed,
IDE09922-MAS10074,Static headlamp range control-Supply voltage: actual value,not coded/not installed,
IDE09922-MAS10075,Static headlamp range control-Activation voltage/supply voltage ratio,not coded/not installed,
IDE09922-MAS12621,Static headlamp range control-Current draw (effective value),not coded/not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Selector lever in position P,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Unknown (9),
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded/not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded/not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded/not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded/not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded/not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded/not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded/not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded/not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded/not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded/not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded/not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded/not installed,
IDE09955-MAS07693,Automatic dimming interior mirror-Button Status,Not operated,
IDE09955-MAS09651,Automatic dimming interior mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Automatic dimming interior mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Automatic dimming interior mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09958-MAS01737,Right low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09958-MAS12621,Right low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE09959-MAS01580,Left low beam headlamp reflector motor-Activation,not coded/not installed,
IDE09959-MAS01737,Left low beam headlamp reflector motor-Diagnosis,not coded/not installed,
IDE09959-MAS12621,Left low beam headlamp reflector motor-Current draw (effective value),not coded/not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,55, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,55,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,Not available,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,55.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,No malfunction,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,55.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,No malfunction,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),Not available,
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),Not available,
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),not coded/not installed,
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,50, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,55, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),21, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),32, mA
IDE10124-MAS07052,Front left seat heating-Setting,OFF,
IDE10124-MAS07921,Front left seat heating-Balance setting,Neutral,
IDE10124-MAS07951,Front left seat heating-Automatic down-shift,not active,
IDE10124-MAS15417,Front left seat heating-Area heating adjustment,OFF,
IDE10125-MAS07052,Front right seat heating-Setting,OFF,
IDE10125-MAS07921,Front right seat heating-Balance setting,Neutral,
IDE10125-MAS07951,Front right seat heating-Automatic down-shift,not active,
IDE10125-MAS15417,Front right seat heating-Area heating adjustment,OFF,
IDE10126-MAS07052,Rear left seat heating-Setting,not coded/not installed,
IDE10126-MAS07921,Rear left seat heating-Balance setting,not coded/not installed,
IDE10126-MAS07951,Rear left seat heating-Automatic down-shift,not coded/not installed,
IDE10126-MAS15417,Rear left seat heating-Area heating adjustment,not coded/not installed,
IDE10127-MAS07052,Rear right seat heating-Setting,not coded/not installed,
IDE10127-MAS07921,Rear right seat heating-Balance setting,not coded/not installed,
IDE10127-MAS07951,Rear right seat heating-Automatic down-shift,not coded/not installed,
IDE10127-MAS15417,Rear right seat heating-Area heating adjustment,not coded/not installed,
IDE10128-MAS01632,Front left seat cushion heating-Status,not active,
IDE10128-MAS05945,Front left seat cushion heating-Target temperature,OFF,
IDE10128-MAS05946,Front left seat cushion heating-Actual temp.,27.00, °C
IDE10128-MAS07929,Front left seat cushion heating-Power quota setting by energy management,0,
IDE10128-MAS12066,Front left seat cushion heating-Cancellation status,Heating process interrupted,
IDE10128-MAS14067,Front left seat cushion heating-Actuation specified value,0, %
IDE10129-MAS01632,Seat backrest heater: left front-Status,not coded/not installed,
IDE10129-MAS05945,Seat backrest heater: left front-Target temperature,not coded/not installed,
IDE10129-MAS05946,Seat backrest heater: left front-Actual temp.,not coded/not installed,
IDE10129-MAS07929,Seat backrest heater: left front-Power quota setting by energy management,not coded/not installed,
IDE10129-MAS12066,Seat backrest heater: left front-Cancellation status,not coded/not installed,
IDE10129-MAS14067,Seat backrest heater: left front-Actuation specified value,not coded/not installed,
IDE10130-MAS01632,Front right seat cushion heating-Status,not active,
IDE10130-MAS05945,Front right seat cushion heating-Target temperature,OFF,
IDE10130-MAS05946,Front right seat cushion heating-Actual temp.,26.00, °C
IDE10130-MAS07929,Front right seat cushion heating-Power quota setting by energy management,0,
IDE10130-MAS12066,Front right seat cushion heating-Cancellation status,Heating process interrupted,
IDE10130-MAS14067,Front right seat cushion heating-Actuation specified value,0, %
IDE10131-MAS01632,Seat backrest heater: right front-Status,not coded/not installed,
IDE10131-MAS05945,Seat backrest heater: right front-Target temperature,not coded/not installed,
IDE10131-MAS05946,Seat backrest heater: right front-Actual temp.,not coded/not installed,
IDE10131-MAS07929,Seat backrest heater: right front-Power quota setting by energy management,not coded/not installed,
IDE10131-MAS12066,Seat backrest heater: right front-Cancellation status,not coded/not installed,
IDE10131-MAS14067,Seat backrest heater: right front-Actuation specified value,not coded/not installed,
IDE10132-MAS01632,Rear left seat cushion heating-Status,not coded/not installed,
IDE10132-MAS05945,Rear left seat cushion heating-Target temperature,not coded/not installed,
IDE10132-MAS05946,Rear left seat cushion heating-Actual temp.,not coded/not installed,
IDE10132-MAS07929,Rear left seat cushion heating-Power quota setting by energy management,not coded/not installed,
IDE10132-MAS12066,Rear left seat cushion heating-Cancellation status,not coded/not installed,
IDE10132-MAS14067,Rear left seat cushion heating-Actuation specified value,not coded/not installed,
IDE10133-MAS01632,Seat backrest heater: left rear-Status,not coded/not installed,
IDE10133-MAS05945,Seat backrest heater: left rear-Target temperature,not coded/not installed,
IDE10133-MAS05946,Seat backrest heater: left rear-Actual temp.,not coded/not installed,
IDE10133-MAS07929,Seat backrest heater: left rear-Power quota setting by energy management,not coded/not installed,
IDE10133-MAS12066,Seat backrest heater: left rear-Cancellation status,not coded/not installed,
IDE10133-MAS14067,Seat backrest heater: left rear-Actuation specified value,not coded/not installed,
IDE10134-MAS01632,Rear right seat cushion heating-Status,not coded/not installed,
IDE10134-MAS05945,Rear right seat cushion heating-Target temperature,not coded/not installed,
IDE10134-MAS05946,Rear right seat cushion heating-Actual temp.,not coded/not installed,
IDE10134-MAS07929,Rear right seat cushion heating-Power quota setting by energy management,not coded/not installed,
IDE10134-MAS12066,Rear right seat cushion heating-Cancellation status,not coded/not installed,
IDE10134-MAS14067,Rear right seat cushion heating-Actuation specified value,not coded/not installed,
IDE10135-MAS01632,Seat backrest heater: right rear-Status,not coded/not installed,
IDE10135-MAS05945,Seat backrest heater: right rear-Target temperature,not coded/not installed,
IDE10135-MAS05946,Seat backrest heater: right rear-Actual temp.,not coded/not installed,
IDE10135-MAS07929,Seat backrest heater: right rear-Power quota setting by energy management,not coded/not installed,
IDE10135-MAS12066,Seat backrest heater: right rear-Cancellation status,not coded/not installed,
IDE10135-MAS14067,Seat backrest heater: right rear-Actuation specified value,not coded/not installed,
IDE10136-MAS01632,Front left door area heating-Status,not coded/not installed,
IDE10136-MAS05945,Front left door area heating-Target temperature,not coded/not installed,
IDE10136-MAS05946,Front left door area heating-Actual temp.,not coded/not installed,
IDE10136-MAS07929,Front left door area heating-Power quota setting by energy management,not coded/not installed,
IDE10136-MAS12066,Front left door area heating-Cancellation status,not coded/not installed,
IDE10136-MAS14067,Front left door area heating-Actuation specified value,not coded/not installed,
IDE10138-MAS01632,Front right door area heating-Status,not coded/not installed,
IDE10138-MAS05945,Front right door area heating-Target temperature,not coded/not installed,
IDE10138-MAS05946,Front right door area heating-Actual temp.,not coded/not installed,
IDE10138-MAS07929,Front right door area heating-Power quota setting by energy management,not coded/not installed,
IDE10138-MAS12066,Front right door area heating-Cancellation status,not coded/not installed,
IDE10138-MAS14067,Front right door area heating-Actuation specified value,not coded/not installed,
IDE10140-MAS01632,Rear left door area heating-Status,not coded/not installed,
IDE10140-MAS05945,Rear left door area heating-Target temperature,not coded/not installed,
IDE10140-MAS05946,Rear left door area heating-Actual temp.,not coded/not installed,
IDE10140-MAS07929,Rear left door area heating-Power quota setting by energy management,not coded/not installed,
IDE10140-MAS12066,Rear left door area heating-Cancellation status,not coded/not installed,
IDE10140-MAS14067,Rear left door area heating-Actuation specified value,not coded/not installed,
IDE10142-MAS01632,Rear right door area heating-Status,not coded/not installed,
IDE10142-MAS05945,Rear right door area heating-Target temperature,not coded/not installed,
IDE10142-MAS05946,Rear right door area heating-Actual temp.,not coded/not installed,
IDE10142-MAS07929,Rear right door area heating-Power quota setting by energy management,not coded/not installed,
IDE10142-MAS12066,Rear right door area heating-Cancellation status,not coded/not installed,
IDE10142-MAS14067,Rear right door area heating-Actuation specified value,not coded/not installed,
IDE10144-MAS01632,Front center arm rest heating-Status,not coded/not installed,
IDE10144-MAS05945,Front center arm rest heating-Target temperature,not coded/not installed,
IDE10144-MAS05946,Front center arm rest heating-Actual temp.,not coded/not installed,
IDE10144-MAS07929,Front center arm rest heating-Power quota setting by energy management,not coded/not installed,
IDE10144-MAS12066,Front center arm rest heating-Cancellation status,not coded/not installed,
IDE10144-MAS14067,Front center arm rest heating-Actuation specified value,not coded/not installed,
IDE10145-MAS01632,Rear center arm rest heating-Status,not coded/not installed,
IDE10145-MAS05945,Rear center arm rest heating-Target temperature,not coded/not installed,
IDE10145-MAS05946,Rear center arm rest heating-Actual temp.,not coded/not installed,
IDE10145-MAS07929,Rear center arm rest heating-Power quota setting by energy management,not coded/not installed,
IDE10145-MAS12066,Rear center arm rest heating-Cancellation status,not coded/not installed,
IDE10145-MAS14067,Rear center arm rest heating-Actuation specified value,not coded/not installed,
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Target value,not coded/not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded/not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cup holder with heating and cooling element-Status,not coded/not installed,
IDE10327-MAS01968,Cup holder with heating and cooling element-Fan,not coded/not installed,
IDE10327-MAS02819,Cup holder with heating and cooling element-CURRENT temperature,not coded/not installed,
IDE10327-MAS02832,Cup holder with heating and cooling element-Malfunction status,not coded/not installed,
IDE10327-MAS10303,Cup holder with heating and cooling element-Heating function indicator lamp,not coded/not installed,
IDE10327-MAS10304,Cup holder with heating and cooling element-Cooling function indicator lamp,not coded/not installed,
IDE10327-MAS10305,Cup holder with heating and cooling element-Light for residual heat display,not coded/not installed,
IDE10327-MAS10333,Cup holder with heating and cooling element-Heat function button,not coded/not installed,
IDE10327-MAS10334,Cup holder with heating and cooling element-Cooling function button,not coded/not installed,
IDE10327-MAS10336,Cup holder with heating and cooling element-Peltier element,not coded/not installed,
IDE10327-MAS10337,Cup holder with heating and cooling element-Peltier element: PWM value,not coded/not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,Initialization,
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,Initialization,
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,14.10, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,27, °C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,60, °C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10434,Roof electronics control module: dim. value-Indicator lamps,10, %
IDE10343-MAS10497,Roof electronics control module: dim. value-Ceiling contour lights: dim. value,0, %
IDE10343-MAS10498,Roof electronics control module: dim. value-Ceiling contour lights: diagnosis,No malfunction,
IDE10343-MAS14264,Roof electronics control module: dim. value-Front search illumination,0, %
IDE10343-MAS14268,Roof electronics control module: dim. value-Left rear interior lamp: dimming value,0, %
IDE10343-MAS14269,Roof electronics control module: dim. value-Left rear interior light: diagnostics,No malfunction,
IDE10343-MAS14270,Roof electronics control module: dim. value-Right rear interior lamp: dimming value,0, %
IDE10343-MAS14271,Roof electronics control module: dim. value-Right rear interior lamp: diagnostics,No malfunction,
IDE10343-MAS15403,Roof electronics control module: dim. value-Front passenger airbag indicator lamp,10, %
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-IDE01097,Roof electronics control module: indicator lights-Front passenger airbag -disabled- indicator lamp,On,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,On,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10346-MAS14279,Roof electronics control module: indicator lights-Indicator lamp for emergency call: green,On,
IDE10346-MAS14280,Roof electronics control module: indicator lights-Indicator lamp for emergency call: red,OFF,
IDE10346-MAS15376,Roof electronics control module: indicator lights-Front passenger airbag indicator lamp on,OFF,
IDE10346-MAS15377,Roof electronics control module: indicator lights-Front passenger airbag lettering,On,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded/not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded/not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded/not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,6.75, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.17, kOhm
IDE10361-MAS07003,Driver information sensor-Engine Coolant Level Sensor 2,not coded/not installed,
IDE10482-MAS01632,Activation for external systems-Status,not coded/not installed,
IDE10482-MAS07929,Activation for external systems-Power quota setting by energy management,not coded/not installed,
IDE10482-MAS10746,Activation for external systems-Installation info.: external system,no system,
IDE10602-MAS01632,Reclining seat: lower leg support heating-Status,not coded/not installed,
IDE10602-MAS05945,Reclining seat: lower leg support heating-Target temperature,not coded/not installed,
IDE10602-MAS05946,Reclining seat: lower leg support heating-Actual temp.,not coded/not installed,
IDE10602-MAS07929,Reclining seat: lower leg support heating-Power quota setting by energy management,not coded/not installed,
IDE10602-MAS12066,Reclining seat: lower leg support heating-Cancellation status,not coded/not installed,
IDE10602-MAS14067,Reclining seat: lower leg support heating-Actuation specified value,not coded/not installed,
IDE10603-MAS01632,Reclining seat: foot sole heating-Status,not coded/not installed,
IDE10603-MAS05945,Reclining seat: foot sole heating-Target temperature,not coded/not installed,
IDE10603-MAS05946,Reclining seat: foot sole heating-Actual temp.,not coded/not installed,
IDE10603-MAS07929,Reclining seat: foot sole heating-Power quota setting by energy management,not coded/not installed,
IDE10603-MAS12066,Reclining seat: foot sole heating-Cancellation status,not coded/not installed,
IDE10603-MAS14067,Reclining seat: foot sole heating-Actuation specified value,not coded/not installed,
IDE10662-MAS00530,Light switch (button module)-Rear fog light indicator lamp,OFF,
IDE10662-MAS01632,Light switch (button module)-Status,operational,
IDE10662-MAS05451,Light switch (button module)-Low beam indicator lamp,OFF,
IDE10662-MAS06614,Light switch (button module)-Variant,Variant 1,
IDE10662-MAS06732,Light switch (button module)-Status local activity,not active,
IDE10662-MAS06888,Light switch (button module)-Fog light button,Not operated,
IDE10662-MAS06889,Light switch (button module)-Rear fog light button,not installed,
IDE10662-MAS07055,Light switch (button module)-Response error,not active,
IDE10662-MAS07376,Light switch (button module)-Terminal 58xd,55,
IDE10662-MAS09817,Light switch (button module)-Terminal 58xs,55, %
IDE10662-MAS09820,Light switch (button module)-Terminal 58xt,55, %
IDE10662-MAS12385,Light switch (button module)-Automatic driving light control indicator lamp,On,
IDE10662-MAS12415,Light switch (button module)-Parking lamp indicator lamp,OFF,
IDE10662-MAS12416,Light switch (button module)-Daytime running lamp indicator lamp,OFF,
IDE10662-MAS12417,Light switch (button module)-Fog lights indicator lights,OFF,
IDE10662-MAS12419,Light switch (button module)-Side light button,not installed,
IDE10662-MAS12420,Light switch (button module)-Low-beam light button,not installed,
IDE10662-MAS12421,Light switch (button module)-Proximity sensor,no approach,
IDE10662-MAS14302,Light switch (button module)-Automatic high beam button/exterior lighting button,Not operated,
IDE10808-MAS06614,Directional stabilization assistance button-Variant,not coded/not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded/not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator lamp activation,not coded/not installed,
IDE10809-MAS06993,Driver assistance systems control module-Request signal horn,not coded/not installed,
IDE10809-MAS13254,Driver assistance systems control module-Active parking function,not coded/not installed,
IDE10810-MAS06614,Button for side view camera-Variant,not coded/not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded/not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE10945-MAS01580,Shut-off valve 1 for refrigerant-Activation,not coded/not installed,
IDE10945-MAS12621,Shut-off valve 1 for refrigerant-Current draw (effective value),not coded/not installed,
IDE10946-MAS01580,Shut-off valve 2 for refrigerant-Activation,not coded/not installed,
IDE10946-MAS12621,Shut-off valve 2 for refrigerant-Current draw (effective value),not coded/not installed,
IDE10964-MAS06614,Button for instrument panel vents-Variant,not coded/not installed,
IDE10964-MAS07693,Button for instrument panel vents-Button Status,not coded/not installed,
IDE10964-MAS07694,Button for instrument panel vents-Button status on CAN,Initialization/not installed,
IDE10964-MAS07699,Button for instrument panel vents-Status indicator light on CAN,OFF,
IDE10964-MAS08062,Button for instrument panel vents-Indicator lamp activation,not coded/not installed,
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded/not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded/not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded/not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded/not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded/not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded/not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded/not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded/not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,not coded/not installed,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,not coded/not installed,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,not coded/not installed,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,not coded/not installed,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11348,Variable left front lighting: actual position,Measuring value not available,
IDE11349,Variable right front lighting: actual position,Measuring value not available,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,0, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,0, W/m²
IDE11361-MAS06732,Control unit for windshield washer pump-Status local activity,not coded/not installed,
IDE11361-MAS12606,Control unit for windshield washer pump-Status of windshield wiper pump,not coded/not installed,
IDE11361-MAS12607,Control unit for windshield washer pump-Status of wiper arm heater,not coded/not installed,
IDE11361-MAS12608,Control unit for windshield washer pump-Activ. of windsh. wiper pump: direction of upper change pos.,not coded/not installed,
IDE11361-MAS12609,Control unit for windshield washer pump-Activ. of windsh. wiper pump: direction of lower change pos.,not coded/not installed,
IDE11361-MAS12610,Control unit for windshield washer pump-Activation of wiper arm heater,not coded/not installed,
IDE11551-IDE01078,Status of identification data query on LIN-Bus-Fresh air blower: front,Data complete but not secured,
IDE11551-IDE06163,Status of identification data query on LIN-Bus-Humidity sensor: exterior,Data complete but not secured,
IDE11551-IDE11361,Status of identification data query on LIN-Bus-Control unit for windshield washer pump,not coded/not installed,
IDE11551-IDE11719,Status of identification data query on LIN-Bus-Fan 1 for left rear seat backrest,not coded/not installed,
IDE11551-IDE11720,Status of identification data query on LIN-Bus-Fan 1 for left rear seat cushion,not coded/not installed,
IDE11551-IDE11721,Status of identification data query on LIN-Bus-Fan 1 for right rear seat backrest,not coded/not installed,
IDE11551-IDE11722,Status of identification data query on LIN-Bus-Fan 1 for right rear seat cushion,not coded/not installed,
IDE11551-IDE11723,Status of identification data query on LIN-Bus-Fan 2 for left rear seat backrest,not coded/not installed,
IDE11551-IDE11724,Status of identification data query on LIN-Bus-Fan 2 for left rear seat cushion,not coded/not installed,
IDE11551-IDE11725,Status of identification data query on LIN-Bus-Fan 2 for right rear seat backrest,not coded/not installed,
IDE11551-IDE11726,Status of identification data query on LIN-Bus-Fan 2 for right rear seat cushion,not coded/not installed,
IDE11551-IDE11794,Status of identification data query on LIN-Bus-Fragrance diffuser system control module,not coded/not installed,
IDE11551-IDE12358,Status of identification data query on LIN-Bus-Roof electronics control module 2,not coded/not installed,
IDE11551-MAS00746,Status of identification data query on LIN-Bus-Wiper motor control module,Data complete but not secured,
IDE11551-MAS00747,Status of identification data query on LIN-Bus-Rain/Light Recognition Sensor,Data complete but not secured,
IDE11551-MAS00748,Status of identification data query on LIN-Bus-Light switch,Data complete but not secured,
IDE11551-MAS00749,Status of identification data query on LIN-Bus-Garage door opener control module,Data complete but not secured,
IDE11551-MAS00750,Status of identification data query on LIN-Bus-Garage door opener control head,not coded/not installed,
IDE11551-MAS00762,Status of identification data query on LIN-Bus-Automatic dimming interior mirror,Data complete but not secured,
IDE11551-MAS01562,Status of identification data query on LIN-Bus-Air quality sensor,not coded/not installed,
IDE11551-MAS08026,Status of identification data query on LIN-Bus-Control head for driving and comfort functions,Data complete but not secured,
IDE11551-MAS08027,Status of identification data query on LIN-Bus-Control unit 2 for driving and convenience functions,Data complete but not secured,
IDE11551-MAS10760,Status of identification data query on LIN-Bus-Coolant expansion valve: A/C,not coded/not installed,
IDE11551-MAS12901,Status of identification data query on LIN-Bus-Roof electronics control module,Data complete but not secured,
IDE11551-MAS12902,Status of identification data query on LIN-Bus-Adjustable Steering Column Control Module,Data complete but not secured,
IDE11551-MAS12903,Status of identification data query on LIN-Bus-Right Neck Heating Control Module,not coded/not installed,
IDE11551-MAS12904,Status of identification data query on LIN-Bus-Left Neck Heating Control Module,not coded/not installed,
IDE11551-MAS12905,Status of identification data query on LIN-Bus-Blower 1 for left front backrest,not coded/not installed,
IDE11551-MAS12906,Status of identification data query on LIN-Bus-Blower 2 for left front backrest,not coded/not installed,
IDE11551-MAS12907,Status of identification data query on LIN-Bus-Blower 1 for left front seat cushion,not coded/not installed,
IDE11551-MAS12908,Status of identification data query on LIN-Bus-Blower 2 for left front seat cushion,not coded/not installed,
IDE11551-MAS12909,Status of identification data query on LIN-Bus-Blower 1 for right front backrest,not coded/not installed,
IDE11551-MAS12910,Status of identification data query on LIN-Bus-Blower 2 for right front backrest,not coded/not installed,
IDE11551-MAS12911,Status of identification data query on LIN-Bus-Blower 1 for right front seat cushion,not coded/not installed,
IDE11551-MAS12912,Status of identification data query on LIN-Bus-Blower 2 for right front seat cushion,not coded/not installed,
IDE11551-MAS12913,Status of identification data query on LIN-Bus-Valve block 1 in front seat driver side,not coded/not installed,
IDE11551-MAS12914,Status of identification data query on LIN-Bus-Valve block 1 in front seat passenger side,not coded/not installed,
IDE11551-MAS12915,Status of identification data query on LIN-Bus-Cup holder with heating and cooling element,not coded/not installed,
IDE11551-MAS12916,Status of identification data query on LIN-Bus-Humidity sensor: interior,not coded/not installed,
IDE11551-MAS14926,Status of identification data query on LIN-Bus-Sensor for carbon dioxide content in the interior,not coded/not installed,
IDE11551-MAS14927,Status of identification data query on LIN-Bus-Rear A/C control and display head,Data complete but not secured,
IDE11551-MAS15174,Status of identification data query on LIN-Bus-Front A/C display control head,not coded/not installed,
IDE11551-MAS15185,Status of identification data query on LIN-Bus-Sensor for particulate matter content in the A/C,not coded/not installed,
IDE11551-MAS16271,Status of identification data query on LIN-Bus-Sensor for visibility distance measurement,not coded/not installed,
IDE11551-SFT09759,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor,not coded/not installed,
IDE11551-SFT09776,Status of identification data query on LIN-Bus-Ionization,not coded/not installed,
IDE11551-SFT09878,Status of identification data query on LIN-Bus-Rear A/C Control Head 6,not coded/not installed,
IDE11551-SFT09902,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor 2,not coded/not installed,
IDE11551-SFT09903,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor 3,not coded/not installed,
IDE11551-SFT09929,Status of identification data query on LIN-Bus-Rear A/C Control Head 1,not coded/not installed,
IDE11551-SFT09930,Status of identification data query on LIN-Bus-Rear A/C Control Head 2,not coded/not installed,
IDE11551-SFT09931,Status of identification data query on LIN-Bus-Rear A/C Control Head 3,not coded/not installed,
IDE11551-SFT09932,Status of identification data query on LIN-Bus-Rear A/C Control Head 4,not coded/not installed,
IDE11551-SFT09933,Status of identification data query on LIN-Bus-Rear A/C Control Head 5,not coded/not installed,
IDE11551-SFT10027,Status of identification data query on LIN-Bus-Control module for heating element 1,not coded/not installed,
IDE11551-SFT10028,Status of identification data query on LIN-Bus-Control module for heating element 2,not coded/not installed,
IDE11551-SFT10029,Status of identification data query on LIN-Bus-Control module for heating element 3,not coded/not installed,
IDE11551-SFT10030,Status of identification data query on LIN-Bus-Control module for heating element 4,not coded/not installed,
IDE11619-MAS13023,Photo sensors for solar radiation (discrete)-Front left sunlight intensity,not coded/not installed,
IDE11619-MAS13024,Photo sensors for solar radiation (discrete)-Front right sunlight intensity,not coded/not installed,
IDE11619-MAS13025,Photo sensors for solar radiation (discrete)-Rear left sunlight intensity,not coded/not installed,
IDE11619-MAS13026,Photo sensors for solar radiation (discrete)-Rear right sunlight intensity,not coded/not installed,
IDE11619-MAS13077,Photo sensors for solar radiation (discrete)-Sunlight photo sensor,not coded/not installed,
IDE11619-MAS13078,Photo sensors for solar radiation (discrete)-Sunlight photo sensor 2,not coded/not installed,
IDE11619-MAS13079,Photo sensors for solar radiation (discrete)-Rear sunlight photo sensor,not coded/not installed,
IDE11619-MAS13080,Photo sensors for solar radiation (discrete)-Rear sunlight photo sensor 2,not coded/not installed,
IDE11637,Outside air temperature internally calculated: climate,23.69, °C
IDE11641-MAS01632,Supply voltage for A/C actuators-Status,On,
IDE11641-MAS12621,Supply voltage for A/C actuators-Current draw (effective value),230, mA
IDE11642-MAS01632,Supply voltage 2 for A/C actuators-Status,On,
IDE11642-MAS12621,Supply voltage 2 for A/C actuators-Current draw (effective value),99, mA
IDE11643-MAS01632,Voltage supply for climate sensor system-Status,On,
IDE11643-MAS04121,Voltage supply for climate sensor system-Voltage,4.98, V
IDE11654-MAS05030,Evaporator temperature sensor-Resistance,2.55, kOhm
IDE11654-MAS13081,Evaporator temperature sensor-Air temperature downstream of evaporator,26.63, °C
IDE11655-MAS05030,Left footwell vent temperature sensor-Resistance,9.47, kOhm
IDE11655-MAS13082,Left footwell vent temperature sensor-Left footwell vent temperature,26.81, °C
IDE11656-MAS05030,Right footwell vent temperature sensor-Resistance,9.45, kOhm
IDE11656-MAS13083,Right footwell vent temperature sensor-Right footwell vent temperature,26.81, °C
IDE11657-MAS05030,Left rear upper body vent temperature sensor-Resistance,9.36, kOhm
IDE11657-MAS13084,Left rear upper body vent temperature sensor-Left rear vent temperature,26.69, °C
IDE11658-MAS05030,Right rear upper body vent temperature sensor-Resistance,9.42, kOhm
IDE11658-MAS13085,Right rear upper body vent temperature sensor-Right rear vent temperature,26.56, °C
IDE11659-MAS05030,Left rear footwell vent temperature sensor-Resistance,9.20, kOhm
IDE11659-MAS13086,Left rear footwell vent temperature sensor-Left rear footwell vent temperature,27.25, °C
IDE11660-MAS05030,Right rear footwell vent temperature sensor-Resistance,9.47, kOhm
IDE11660-MAS13087,Right rear footwell vent temperature sensor-Right rear footwell vent temperature,26.50, °C
IDE11692-MAS00359,Temperature sensor after heat exchanger-Coolant temperature,not coded/not installed,
IDE11692-MAS05030,Temperature sensor after heat exchanger-Resistance,not coded/not installed,
IDE11693-MAS05030,Left side air outlet temperature sensor-Resistance,9.40, kOhm
IDE11693-MAS13110,Left side air outlet temperature sensor-Left side air outlet temperature,26.63, °C
IDE11694-MAS05030,Right side air outlet temperature sensor-Resistance,9.45, kOhm
IDE11694-MAS13111,Right side air outlet temperature sensor-Right side air outlet temperature,26.50, °C
IDE11695-MAS05030,Left central air outlet temperature sensor-Resistance,not coded/not installed,
IDE11695-MAS13112,Left central air outlet temperature sensor-Left center air outlet temperature,not coded/not installed,
IDE11696-MAS05030,Right central air outlet temperature sensor-Resistance,not coded/not installed,
IDE11696-MAS13113,Right central air outlet temperature sensor-Right center air outlet temperature,not coded/not installed,
IDE11697-MAS05030,Front defrost flap air outlet temperature sensor-Resistance,not coded/not installed,
IDE11697-MAS13114,Front defrost flap air outlet temperature sensor-Defrosting air outlet temperature,not coded/not installed,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,not coded/not installed,
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,not coded/not installed,
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,26.81, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,9.29, kOhm
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,26.38, °C
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,9.42, kOhm
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,26.25, °C
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,9.45, kOhm
IDE11774-IDE01290,Assembly position of users at local data bus 9-Recirculation flap motor,0,
IDE11774-IDE01292,Assembly position of users at local data bus 9-Left side vent motor,5,
IDE11774-IDE01293,Assembly position of users at local data bus 9-Right side vent motor,12,
IDE11774-IDE01294,Assembly position of users at local data bus 9-Left footwell flap motor,2,
IDE11774-IDE01295,Assembly position of users at local data bus 9-Right footwell flap motor,13,
IDE11774-IDE01296,Assembly position of users at local data bus 9-Left center vent motor,7,
IDE11774-IDE01297,Assembly position of users at local data bus 9-Right center vent motor,9,
IDE11774-IDE01300,Assembly position of users at local data bus 9-Rear temperature door motor,0,
IDE11774-IDE01301,Assembly position of users at local data bus 9-Rear air quantity motor,0,
IDE11774-IDE01304,Assembly position of users at local data bus 9-Left Rear Upper Body Vent Motor,0,
IDE11774-IDE01305,Assembly position of users at local data bus 9-Right Rear Upper Body Vent Motor,0,
IDE11774-IDE01422,Assembly position of users at local data bus 9-Defroster flap motor,8,
IDE11774-IDE01423,Assembly position of users at local data bus 9-Left temperature flap positioning motor,6,
IDE11774-IDE01424,Assembly position of users at local data bus 9-Right temperature flap positioning motor,15,
IDE11774-IDE02432,Assembly position of users at local data bus 9-Left rear temperature door motor,4,
IDE11774-IDE02435,Assembly position of users at local data bus 9-Right rear temperature door motor,11,
IDE11774-IDE02753,Assembly position of users at local data bus 9-Temperature flap motor,0,
IDE11774-IDE02833,Assembly position of users at local data bus 9-Fresh air door motor,0,
IDE11774-IDE07267,Assembly position of users at local data bus 9-Rear left air distribution servomotor,1,
IDE11774-IDE07268,Assembly position of users at local data bus 9-Rear right air distribution servomotor,14,
IDE11774-MAS07679,Assembly position of users at local data bus 9-Air distribution door motor,0,
IDE11774-MAS07681,Assembly position of users at local data bus 9-Left footwell temperature door motor,0,
IDE11774-MAS07682,Assembly position of users at local data bus 9-Right footwell temperature door motor,0,
IDE11774-MAS07683,Assembly position of users at local data bus 9-Left side window defroster door motor,0,
IDE11774-MAS07684,Assembly position of users at local data bus 9-Right side window defroster door motor,0,
IDE11774-MAS07685,Assembly position of users at local data bus 9-Rear air distribution door motor,0,
IDE11774-MAS07686,Assembly position of users at local data bus 9-Left B-pillar/footwell shut-off flap motor,0,
IDE11774-MAS07687,Assembly position of users at local data bus 9-Right B-pillar/footwell shut-off flap motor,0,
IDE11774-MAS07688,Assembly position of users at local data bus 9-Rear recirc. flap motor,0,
IDE11774-MAS11831,Assembly position of users at local data bus 9-Ctrl. motor for instrument panel vents,0,
IDE11775-IDE01290,Assembly position of users at local data bus 10-Recirculation flap motor,2,
IDE11775-IDE01292,Assembly position of users at local data bus 10-Left side vent motor,0,
IDE11775-IDE01293,Assembly position of users at local data bus 10-Right side vent motor,0,
IDE11775-IDE01294,Assembly position of users at local data bus 10-Left footwell flap motor,0,
IDE11775-IDE01295,Assembly position of users at local data bus 10-Right footwell flap motor,0,
IDE11775-IDE01296,Assembly position of users at local data bus 10-Left center vent motor,0,
IDE11775-IDE01297,Assembly position of users at local data bus 10-Right center vent motor,0,
IDE11775-IDE01300,Assembly position of users at local data bus 10-Rear temperature door motor,0,
IDE11775-IDE01301,Assembly position of users at local data bus 10-Rear air quantity motor,0,
IDE11775-IDE01304,Assembly position of users at local data bus 10-Left Rear Upper Body Vent Motor,0,
IDE11775-IDE01305,Assembly position of users at local data bus 10-Right Rear Upper Body Vent Motor,0,
IDE11775-IDE01422,Assembly position of users at local data bus 10-Defroster flap motor,0,
IDE11775-IDE01423,Assembly position of users at local data bus 10-Left temperature flap positioning motor,0,
IDE11775-IDE01424,Assembly position of users at local data bus 10-Right temperature flap positioning motor,0,
IDE11775-IDE02432,Assembly position of users at local data bus 10-Left rear temperature door motor,0,
IDE11775-IDE02435,Assembly position of users at local data bus 10-Right rear temperature door motor,0,
IDE11775-IDE02753,Assembly position of users at local data bus 10-Temperature flap motor,0,
IDE11775-IDE02833,Assembly position of users at local data bus 10-Fresh air door motor,1,
IDE11775-IDE07267,Assembly position of users at local data bus 10-Rear left air distribution servomotor,0,
IDE11775-IDE07268,Assembly position of users at local data bus 10-Rear right air distribution servomotor,0,
IDE11775-MAS07679,Assembly position of users at local data bus 10-Air distribution door motor,0,
IDE11775-MAS07681,Assembly position of users at local data bus 10-Left footwell temperature door motor,0,
IDE11775-MAS07682,Assembly position of users at local data bus 10-Right footwell temperature door motor,0,
IDE11775-MAS07683,Assembly position of users at local data bus 10-Left side window defroster door motor,0,
IDE11775-MAS07684,Assembly position of users at local data bus 10-Right side window defroster door motor,0,
IDE11775-MAS07685,Assembly position of users at local data bus 10-Rear air distribution door motor,0,
IDE11775-MAS07686,Assembly position of users at local data bus 10-Left B-pillar/footwell shut-off flap motor,0,
IDE11775-MAS07687,Assembly position of users at local data bus 10-Right B-pillar/footwell shut-off flap motor,0,
IDE11775-MAS07688,Assembly position of users at local data bus 10-Rear recirc. flap motor,0,
IDE11775-MAS11831,Assembly position of users at local data bus 10-Ctrl. motor for instrument panel vents,0,
IDE11776-IDE01290,Assembly position of users at local data bus 11-Recirculation flap motor,0,
IDE11776-IDE01292,Assembly position of users at local data bus 11-Left side vent motor,0,
IDE11776-IDE01293,Assembly position of users at local data bus 11-Right side vent motor,0,
IDE11776-IDE01294,Assembly position of users at local data bus 11-Left footwell flap motor,0,
IDE11776-IDE01295,Assembly position of users at local data bus 11-Right footwell flap motor,0,
IDE11776-IDE01296,Assembly position of users at local data bus 11-Left center vent motor,0,
IDE11776-IDE01297,Assembly position of users at local data bus 11-Right center vent motor,0,
IDE11776-IDE01300,Assembly position of users at local data bus 11-Rear temperature door motor,0,
IDE11776-IDE01301,Assembly position of users at local data bus 11-Rear air quantity motor,0,
IDE11776-IDE01304,Assembly position of users at local data bus 11-Left Rear Upper Body Vent Motor,0,
IDE11776-IDE01305,Assembly position of users at local data bus 11-Right Rear Upper Body Vent Motor,0,
IDE11776-IDE01422,Assembly position of users at local data bus 11-Defroster flap motor,0,
IDE11776-IDE01423,Assembly position of users at local data bus 11-Left temperature flap positioning motor,0,
IDE11776-IDE01424,Assembly position of users at local data bus 11-Right temperature flap positioning motor,0,
IDE11776-IDE02432,Assembly position of users at local data bus 11-Left rear temperature door motor,0,
IDE11776-IDE02435,Assembly position of users at local data bus 11-Right rear temperature door motor,0,
IDE11776-IDE02753,Assembly position of users at local data bus 11-Temperature flap motor,0,
IDE11776-IDE02833,Assembly position of users at local data bus 11-Fresh air door motor,0,
IDE11776-IDE07267,Assembly position of users at local data bus 11-Rear left air distribution servomotor,0,
IDE11776-IDE07268,Assembly position of users at local data bus 11-Rear right air distribution servomotor,0,
IDE11776-MAS07679,Assembly position of users at local data bus 11-Air distribution door motor,0,
IDE11776-MAS07681,Assembly position of users at local data bus 11-Left footwell temperature door motor,0,
IDE11776-MAS07682,Assembly position of users at local data bus 11-Right footwell temperature door motor,0,
IDE11776-MAS07683,Assembly position of users at local data bus 11-Left side window defroster door motor,0,
IDE11776-MAS07684,Assembly position of users at local data bus 11-Right side window defroster door motor,0,
IDE11776-MAS07685,Assembly position of users at local data bus 11-Rear air distribution door motor,0,
IDE11776-MAS07686,Assembly position of users at local data bus 11-Left B-pillar/footwell shut-off flap motor,1,
IDE11776-MAS07687,Assembly position of users at local data bus 11-Right B-pillar/footwell shut-off flap motor,2,
IDE11776-MAS07688,Assembly position of users at local data bus 11-Rear recirc. flap motor,0,
IDE11776-MAS11831,Assembly position of users at local data bus 11-Ctrl. motor for instrument panel vents,0,
IDE11777-IDE01290,Assembly position of users at local data bus 12-Recirculation flap motor,0,
IDE11777-IDE01292,Assembly position of users at local data bus 12-Left side vent motor,0,
IDE11777-IDE01293,Assembly position of users at local data bus 12-Right side vent motor,0,
IDE11777-IDE01294,Assembly position of users at local data bus 12-Left footwell flap motor,0,
IDE11777-IDE01295,Assembly position of users at local data bus 12-Right footwell flap motor,0,
IDE11777-IDE01296,Assembly position of users at local data bus 12-Left center vent motor,0,
IDE11777-IDE01297,Assembly position of users at local data bus 12-Right center vent motor,0,
IDE11777-IDE01300,Assembly position of users at local data bus 12-Rear temperature door motor,0,
IDE11777-IDE01301,Assembly position of users at local data bus 12-Rear air quantity motor,0,
IDE11777-IDE01304,Assembly position of users at local data bus 12-Left Rear Upper Body Vent Motor,0,
IDE11777-IDE01305,Assembly position of users at local data bus 12-Right Rear Upper Body Vent Motor,0,
IDE11777-IDE01422,Assembly position of users at local data bus 12-Defroster flap motor,0,
IDE11777-IDE01423,Assembly position of users at local data bus 12-Left temperature flap positioning motor,0,
IDE11777-IDE01424,Assembly position of users at local data bus 12-Right temperature flap positioning motor,0,
IDE11777-IDE02432,Assembly position of users at local data bus 12-Left rear temperature door motor,0,
IDE11777-IDE02435,Assembly position of users at local data bus 12-Right rear temperature door motor,0,
IDE11777-IDE02753,Assembly position of users at local data bus 12-Temperature flap motor,0,
IDE11777-IDE02833,Assembly position of users at local data bus 12-Fresh air door motor,0,
IDE11777-IDE07267,Assembly position of users at local data bus 12-Rear left air distribution servomotor,0,
IDE11777-IDE07268,Assembly position of users at local data bus 12-Rear right air distribution servomotor,0,
IDE11777-MAS07679,Assembly position of users at local data bus 12-Air distribution door motor,0,
IDE11777-MAS07681,Assembly position of users at local data bus 12-Left footwell temperature door motor,0,
IDE11777-MAS07682,Assembly position of users at local data bus 12-Right footwell temperature door motor,0,
IDE11777-MAS07683,Assembly position of users at local data bus 12-Left side window defroster door motor,0,
IDE11777-MAS07684,Assembly position of users at local data bus 12-Right side window defroster door motor,0,
IDE11777-MAS07685,Assembly position of users at local data bus 12-Rear air distribution door motor,0,
IDE11777-MAS07686,Assembly position of users at local data bus 12-Left B-pillar/footwell shut-off flap motor,0,
IDE11777-MAS07687,Assembly position of users at local data bus 12-Right B-pillar/footwell shut-off flap motor,0,
IDE11777-MAS07688,Assembly position of users at local data bus 12-Rear recirc. flap motor,0,
IDE11777-MAS11831,Assembly position of users at local data bus 12-Ctrl. motor for instrument panel vents,0,
IDE11789-MAS11878,Air quality in the interior-Degree of contamination,Unknown (255),
IDE11790,Carbon dioxide content in the interior,Initialization,
IDE11936-MAS06614,Button for defrost function-Variant,Local data bus: operating unit 1,
IDE11936-MAS07693,Button for defrost function-Button Status,Not operated,
IDE11936-MAS07694,Button for defrost function-Button status on CAN,Not operated,
IDE11936-MAS07699,Button for defrost function-Status indicator light on CAN,OFF,
IDE11936-MAS08062,Button for defrost function-Indicator lamp activation,OFF,
IDE11939-MAS06614,Button for auxiliary water heater-Variant,not coded/not installed,
IDE11939-MAS07693,Button for auxiliary water heater-Button Status,not coded/not installed,
IDE11939-MAS07694,Button for auxiliary water heater-Button status on CAN,Not operated,
IDE11939-MAS14852,Button for auxiliary water heater-Auxiliary coolant heater indicator lamp activation,not coded/not installed,
IDE11939-MAS14853,Button for auxiliary water heater-Activation of indicator lamp for auxiliary coolant heater timer,not coded/not installed,
IDE11939-MAS14854,Button for auxiliary water heater-Status off indicator lamp for auxiliary coolant heater on CAN,OFF,
IDE12151-MAS01580,Left LED headlamp power output module: supply-Activation,100, %
IDE12151-MAS01737,Left LED headlamp power output module: supply-Diagnosis,No malfunction,
IDE12151-MAS12621,Left LED headlamp power output module: supply-Current draw (effective value),1508, mA
IDE12152-MAS01580,Right LED headlamp power output module: supply-Activation,100, %
IDE12152-MAS01737,Right LED headlamp power output module: supply-Diagnosis,No malfunction,
IDE12152-MAS12621,Right LED headlamp power output module: supply-Current draw (effective value),1514, mA
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded/not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded/not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded/not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded/not installed,
IDE12340-MAS10485,Roof electronics control module: reading lights left-Left front reading lamp: dim. value,100, %
IDE12340-MAS10489,Roof electronics control module: reading lights left-Left rear reading lamp: dim. value,0, %
IDE12340-MAS10490,Roof electronics control module: reading lights left-Left rear reading lamp: diagnosis,No malfunction,
IDE12340-MAS10493,Roof electronics control module: reading lights left-Left read. lamp: 3rd seat row: dim. value,0, %
IDE12340-MAS10494,Roof electronics control module: reading lights left-Left read. lamp: 3rd seat row: diagnosis,No malfunction,
IDE12340-MAS14272,Roof electronics control module: reading lights left-Left rear reading lamp 2: dimming value,0, %
IDE12340-MAS14273,Roof electronics control module: reading lights left-Left rear reading lamp 2: diagnostic,No malfunction,
IDE12341-MAS10487,Roof electronics control module: reading lights right-Right front reading lamp: dim. value,0, %
IDE12341-MAS10491,Roof electronics control module: reading lights right-Right rear reading lamp: dim. value,0, %
IDE12341-MAS10492,Roof electronics control module: reading lights right-Right rear reading lamp: diagnosis,No malfunction,
IDE12341-MAS10495,Roof electronics control module: reading lights right-Right read. lamp: 3rd seat row: dim. value,0, %
IDE12341-MAS10496,Roof electronics control module: reading lights right-Right read. lamp: 3rd seat row: diagnosis,No malfunction,
IDE12341-MAS14274,Roof electronics control module: reading lights right-Right rear reading lamp 2: dim. value,0, %
IDE12341-MAS14276,Roof electronics control module: reading lights right-Right rear reading lamp 2: diagnosis,No malfunction,
IDE12342-MAS06614,Button engine sound generation-Variant,not coded/not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded/not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,OFF,
IDE12342-MAS08062,Button engine sound generation-Indicator lamp activation,not coded/not installed,
IDE12343-MAS07693,Automated driving button-Button Status,not coded/not installed,
IDE12343-MAS07694,Automated driving button-Button status on CAN,Initialization/not installed,
IDE12343-MAS14277,Automated driving button-Indicator lamp activation: color,not coded/not installed,
IDE12343-MAS14278,Automated driving button-Indicator lamp activation: mode,normal,
IDE12432-MAS00043,Operating and display unit: rear A/C: supply voltages-Terminal 30 power supply,14.30, V
IDE12432-MAS06838,Operating and display unit: rear A/C: supply voltages-Supply voltage: terminal 30 left,0.00, V
IDE12432-MAS06839,Operating and display unit: rear A/C: supply voltages-Supply voltage terminal 30 right,0.00, V
IDE12433-MAS01538,Operating and display unit: rear A/C: button operation-Left air distribution,Not operated,
IDE12433-MAS01539,Operating and display unit: rear A/C: button operation-Right air distribution,Not operated,
IDE12433-MAS01545,Operating and display unit: rear A/C: button operation-AUTO left,Not operated,
IDE12433-MAS01546,Operating and display unit: rear A/C: button operation-AUTO right,Not operated,
IDE12433-MAS01554,Operating and display unit: rear A/C: button operation-Left heated seat,Not operated,
IDE12433-MAS01555,Operating and display unit: rear A/C: button operation-Left seat ventilation,Not operated,
IDE12433-MAS01556,Operating and display unit: rear A/C: button operation-Right heated seat,Not operated,
IDE12433-MAS01557,Operating and display unit: rear A/C: button operation-Right seat ventilation,Not operated,
IDE12433-MAS01560,Operating and display unit: rear A/C: button operation-OFF,Not operated,
IDE12433-MAS03830,Operating and display unit: rear A/C: button operation-Footwell air distribution,Not operated,
IDE12433-MAS03831,Operating and display unit: rear A/C: button operation-Upper body vent air distribution,Not operated,
IDE12433-MAS03832,Operating and display unit: rear A/C: button operation-Air distribution up,Not operated,
IDE12433-MAS14438,Operating and display unit: rear A/C: button operation-Temperature left +,Not operated,
IDE12433-MAS14439,Operating and display unit: rear A/C: button operation-Temperature left -,Not operated,
IDE12433-MAS14440,Operating and display unit: rear A/C: button operation-Temperature right +,Not operated,
IDE12433-MAS14441,Operating and display unit: rear A/C: button operation-Temperature right -,Not operated,
IDE12433-MAS14442,Operating and display unit: rear A/C: button operation-Temperature +,Not operated,
IDE12433-MAS14443,Operating and display unit: rear A/C: button operation-Temperature -,Not operated,
IDE12433-MAS14444,Operating and display unit: rear A/C: button operation-Air quantity left +,Not operated,
IDE12433-MAS14445,Operating and display unit: rear A/C: button operation-Air quantity left -,Not operated,
IDE12433-MAS14446,Operating and display unit: rear A/C: button operation-Air quantity right +,Not operated,
IDE12433-MAS14447,Operating and display unit: rear A/C: button operation-Air quantity right -,Not operated,
IDE12433-MAS14448,Operating and display unit: rear A/C: button operation-Setting area for temperature: left,Not operated,
IDE12433-MAS14449,Operating and display unit: rear A/C: button operation-Setting area for temperature: right,Not operated,
IDE12433-MAS14450,Operating and display unit: rear A/C: button operation-Setting area for air volume: left,Not operated,
IDE12433-MAS14451,Operating and display unit: rear A/C: button operation-Setting area for air volume: right,Not operated,
IDE12433-MAS14452,Operating and display unit: rear A/C: button operation-Resistive sensors for activation recognition,not installed,
IDE12606-MAS06526,Installation information multicolor ambient and contour lighting 2-Local data bus 5,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
IDE12606-MAS06527,Installation information multicolor ambient and contour lighting 2-Local data bus 6,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
IDE12606-MAS14771,Installation information multicolor ambient and contour lighting 2-Local data bus 7,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded/not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12882-MAS06614,Rear window shade button 2-Variant,not coded/not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded/not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE12945-MAS01632,Door surface heating 2: left front-Status,not coded/not installed,
IDE12945-MAS05945,Door surface heating 2: left front-Target temperature,not coded/not installed,
IDE12945-MAS05946,Door surface heating 2: left front-Actual temp.,not coded/not installed,
IDE12945-MAS07929,Door surface heating 2: left front-Power quota setting by energy management,not coded/not installed,
IDE12945-MAS12066,Door surface heating 2: left front-Cancellation status,not coded/not installed,
IDE12945-MAS14067,Door surface heating 2: left front-Actuation specified value,not coded/not installed,
IDE12946-MAS01632,Door surface heater 2: right front-Status,not coded/not installed,
IDE12946-MAS05945,Door surface heater 2: right front-Target temperature,not coded/not installed,
IDE12946-MAS05946,Door surface heater 2: right front-Actual temp.,not coded/not installed,
IDE12946-MAS07929,Door surface heater 2: right front-Power quota setting by energy management,not coded/not installed,
IDE12946-MAS12066,Door surface heater 2: right front-Cancellation status,not coded/not installed,
IDE12946-MAS14067,Door surface heater 2: right front-Actuation specified value,not coded/not installed,
IDE12947-MAS01632,Door surface heater 2: left rear-Status,not coded/not installed,
IDE12947-MAS05945,Door surface heater 2: left rear-Target temperature,not coded/not installed,
IDE12947-MAS05946,Door surface heater 2: left rear-Actual temp.,not coded/not installed,
IDE12947-MAS07929,Door surface heater 2: left rear-Power quota setting by energy management,not coded/not installed,
IDE12947-MAS12066,Door surface heater 2: left rear-Cancellation status,not coded/not installed,
IDE12947-MAS14067,Door surface heater 2: left rear-Actuation specified value,not coded/not installed,
IDE12948-MAS01632,Door surface heater 2: right rear-Status,not coded/not installed,
IDE12948-MAS05945,Door surface heater 2: right rear-Target temperature,not coded/not installed,
IDE12948-MAS05946,Door surface heater 2: right rear-Actual temp.,not coded/not installed,
IDE12948-MAS07929,Door surface heater 2: right rear-Power quota setting by energy management,not coded/not installed,
IDE12948-MAS12066,Door surface heater 2: right rear-Cancellation status,not coded/not installed,
IDE12948-MAS14067,Door surface heater 2: right rear-Actuation specified value,not coded/not installed,
IDE12950-MAS07052,Foot level heating-Setting,not coded/not installed,
IDE14245-MAS19730,Component protection configuration-Configuration bit 1,not configured,
IDE14245-MAS19731,Component protection configuration-Configuration bit 0,activated,
IDE14245-MAS19732,Component protection configuration-Configuration bit 2,not configured,
IDE14245-MAS19733,Component protection configuration-Configuration bit 3,not configured,
IDE14245-MAS19734,Component protection configuration-Configuration bit 4,not configured,
IDE14245-MAS19735,Component protection configuration-Configuration bit 5,not configured,
IDE14245-MAS19736,Component protection configuration-Configuration bit 6,not configured,
IDE14245-MAS19737,Component protection configuration-Configuration bit 7,not configured,
IDE14245-MAS19738,Component protection configuration-Configuration bit 8,not configured,
IDE14245-MAS19739,Component protection configuration-Configuration bit 9,not configured,
IDE14245-MAS19740,Component protection configuration-Configuration bit 10,not configured,
IDE14245-MAS19741,Component protection configuration-Configuration bit 11,not configured,
IDE14245-MAS19742,Component protection configuration-Configuration bit 12,not configured,
IDE14245-MAS19743,Component protection configuration-Configuration bit 13,not configured,
IDE14245-MAS19744,Component protection configuration-Configuration bit 14,not configured,
IDE14245-MAS19745,Component protection configuration-Configuration bit 15,not configured,
IDE14648-IDE06260,Integrated toll charge module-ID number,JMATH3AY3,
IDE14694-MAS01580,Projection module in left matrix headlamp: supply-Activation,not coded/not installed,
IDE14694-MAS01737,Projection module in left matrix headlamp: supply-Diagnosis,not coded/not installed,
IDE14694-MAS12621,Projection module in left matrix headlamp: supply-Current draw (effective value),not coded/not installed,
IDE14695-MAS01580,Projection module in right matrix headlamp: supply-Activation,not coded/not installed,
IDE14695-MAS01737,Projection module in right matrix headlamp: supply-Diagnosis,not coded/not installed,
IDE14695-MAS12621,Projection module in right matrix headlamp: supply-Current draw (effective value),not coded/not installed,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06997,Head area heater-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Head area heater-Head area heater left: release,not coded/not installed,
IDE80251-MAS09638,Head area heater-Head area heater right: release,not coded/not installed,
IDE80251-MAS09639,Head area heater-Head area heater left: output DTM,not coded/not installed,
IDE80251-MAS09640,Head area heater-Head area heater right: output DTM,not coded/not installed,
IDE80251-MAS09641,Head area heater-Inside temperature,Temp. sensor not installed,
IDE80251-MAS09642,Head area heater-Adaptation vent temperature,not coded/not installed,
IDE80251-MAS09643,Head area heater-Adaptation fan speed,not coded/not installed,
IDE80251-MAS09646,Head area heater-Occupation status not available,not coded/not installed,
IDE80251-MAS09778,Head area heater-Convert. top open and locked,not coded/not installed,
IDE80251-MAS09779,Head area heater-Convert. top closed and locked,not coded/not installed,
MAS02311-MAS06614,Steering wheel heating button-Variant,not coded/not installed,
MAS02311-MAS07693,Steering wheel heating button-Button Status,not coded/not installed,
MAS02311-MAS07694,Steering wheel heating button-Button status on CAN,Initialization/not installed,
MAS02311-MAS07699,Steering wheel heating button-Status indicator light on CAN,OFF,
MAS02311-MAS08062,Steering wheel heating button-Indicator lamp activation,not coded/not installed,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,available.,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0B 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,7,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
SFT00032-MAS01632,High beam assistant-Status,not coded/not installed,
SFT00032-MAS02832,High beam assistant-Malfunction status,not coded/not installed,
SFT00032-MAS09580,High beam assistant-Sensor status,not coded/not installed,
SFT00032-MAS09581,High beam assistant-PWM specs.,not coded/not installed,
SFT00032-MAS09582,High beam assistant-Status on combi,not coded/not installed,
SFT00032-MAS09583,High beam assistant-error status on combi,not coded/not installed,
SFT00032-MAS09584,High beam assistant-Sensor status on combi,not coded/not installed,
SFT00032-MAS09585,High beam assistant-Turn up headlights request,not coded/not installed,
ENG26468-ENG30676,Aftermarket_auxiliary_heater-Counter_of_activation_of_child_lock,0,
ENG26468-ENG32740,Aftermarket_auxiliary_heater-State_of_child_lock,Unknown (255),
ENG02609,average_Voltage_terminals,14.20, V
ENG128341-ENG110385,Climate_OBD-Channel,0,
ENG128341-ENG02514,Climate_OBD-Comma,not active,
ENG128341-ENG99000,Climate_OBD-Value,-9999,
ENG26644-ENG30703,Data_Definitions-Data_Definition_BAP_Climate_Master,DF34,
ENG26644-ENG30704,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,DF72,
ENG26644-ENG30705,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,DF72,
ENG26644-ENG30706,Data_Definitions-Data_Definition_BAP_Clock,DF42,
ENG26644-ENG30707,Data_Definitions-Data_Definition_BAP_ExteriorLight,DF55,
ENG26644-ENG30708,Data_Definitions-Data_Definition_BAP_InteriorLight,DF57,
ENG26644-ENG30709,Data_Definitions-Data_Definition_BAP_Parkheater,DF44,
ENG26644-ENG30710,Data_Definitions-Data_Definition_BAP_PDC,DF47,
ENG26644-ENG30711,Data_Definitions-Data_Definition_BAP_SeatPneumatic,DF31,
ENG26644-ENG30712,Data_Definitions-Data_Definition_BAP_TrailorAssist,DF33,
ENG26644-ENG30713,Data_Definitions-Data_Definition_BAP_Wiper,DF33,
ENG26644-ENG30714,Data_Definitions-Data_Definition_CAN_Frontlight,1.14F,
ENG26644-ENG30715,Data_Definitions-Data_Definition_CAN_Komfort,08.13.00F,
ENG26644-ENG30716,Data_Definitions-Data_Definition_LIN_1,08.13.00F,
ENG26644-ENG30717,Data_Definitions-Data_Definition_LIN_10,08.13.00F,
ENG26644-ENG30718,Data_Definitions-Data_Definition_LIN_11,08.11.00F,
ENG26644-ENG30719,Data_Definitions-Data_Definition_LIN_12,08.13.00F,
ENG26644-ENG30720,Data_Definitions-Data_Definition_LIN_2,08.11.01F,
ENG26644-ENG30721,Data_Definitions-Data_Definition_LIN_3,08.12.00F,
ENG26644-ENG30722,Data_Definitions-Data_Definition_LIN_4,08.13.00F,
ENG26644-ENG30723,Data_Definitions-Data_Definition_LIN_5,08.07.00F,
ENG26644-ENG30724,Data_Definitions-Data_Definition_LIN_6,08.07.00F,
ENG26644-ENG30725,Data_Definitions-Data_Definition_LIN_7,08.08.00F,
ENG26644-ENG30726,Data_Definitions-Data_Definition_LIN_8,08.13.00F,
ENG26644-ENG30727,Data_Definitions-Data_Definition_LIN_9,08.11.00F,
ENG02611-ENG02852,EVLS-block_counter_axial_in,2,
ENG02611-ENG02851,EVLS-block_counter_axial_out,3,
ENG02611-ENG02850,EVLS-block_counter_vertically_down,3,
ENG02611-ENG02849,EVLS-block_counter_vertically_up,2,
ENG02611-ENG02847,EVLS-drivers_door_open,Open,
ENG02611-ENG02856,EVLS-Electrically_adjustable_steering_column_BCM1_down,not active,
ENG02611-ENG02858,EVLS-Electrically_adjustable_steering_column_BCM1_in,not active,
ENG02611-ENG02857,EVLS-Electrically_adjustable_steering_column_BCM1_out,not active,
ENG02611-ENG02855,EVLS-Electrically_adjustable_steering_column_BCM1_up,not active,
ENG02611-ENG02845,EVLS-Electrically_adjustable_steering_column_error,00000000 00000000 ,
ENG02611-ENG02853,EVLS-Electrically_adjustable_steering_column_response_error,No malfunction,
ENG02611-ENG02848,EVLS-Electrically_adjustable_steering_column_state,00000001 ,
ENG02611-ENG02844,EVLS-Electrically_adjustable_steering_column_state_HV,00000000 11000001 ,
ENG02611-ENG02843,EVLS-Electrically_adjustable_steering_column_state_LV,00000000 11000001 ,
ENG02611-ENG02842,EVLS-FS_MMB_global_stop_mode,no_global_break_off,
ENG02611-ENG02838,EVLS-FS_MMB_storage_mode,no_assignation,
ENG02611-ENG02841,EVLS-FS_MMB_store_mode,no_storage,
ENG02611-ENG02840,EVLS-FS_MMB_tap_mode,no_button_mode,
ENG02611-ENG02839,EVLS-FS_MMB_tip_mode,no_tip_mode,
ENG02611-ENG02846,EVLS-LSV_EE_switch,operated,
ENG02611-ENG02854,EVLS-motor_start_stopp_restart,not active,
ENG48509-MAS17268,FoD_slave_operating_state-Functions which can be activated: connection error counter,02,
ENG48830-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,available.,
ENG48830-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,invalid,
ENG48830-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,10 02 0B 00,
ENG48830-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,available.,
ENG48830-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,OK,
ENG48830-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition not met,
ENG48830-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,No,
ENG48830-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition met,
ENG48830-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,7,
ENG48830-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG101323,Headlight leveling control state,static,
ENG02610,interior_temperature,26.50, °C
ENG116001-ENG116135,itm_toll_modul-itm_event_acknowledge,no_event,
ENG116001-ENG116125,itm_toll_modul-ITM_number_of_occupants,single_driver,
ENG116001-ENG116101,itm_toll_modul-itm_on_off,itm_off,
ENG107365,Left dynamic cornering light value,Measuring value not available,
ENG107366,Left headlight leveling motor position,Unknown,
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,active,
ENG116804-ENG121664,Light sensor parameter-night_mode,not active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,135,
ENG116804-ENG03606,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG03607,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG03608,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG03609,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,135,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,45,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,68,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG03603,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG03605,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG03604,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG03602,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,93,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,11, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,90,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,0, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,0, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,0,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG02672-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG02672-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG02672-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG02672-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG02672-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,2,
ENG02672-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,255,
ENG02672-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG02672-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,182,
ENG02672-ENG03611,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,141,
ENG02672-ENG03610,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,139,
ENG02672-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,0,
ENG02672-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG02672-ENG121645,Rain_sensor_parameters-rub_LengthCounter,6,
ENG02672-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG02672-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG02672-ENG121646,Rain_sensor_parameters-rub_PulseCounter,1,
ENG02672-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG02672-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG02672-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,32664,
ENG02672-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,661,
ENG108468,Right dynamic cornering light value,Measuring value not available,
ENG108469,Right headlight leveling motor position,Unknown,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,12,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Incline,2,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG27168-ENG32809,sw_history-sw_version_1,----,
ENG27168-ENG32810,sw_history-sw_version_2,----,
ENG27168-ENG32811,sw_history-sw_version_3,----,
ENG27168-ENG32812,sw_history-sw_version_4,----,
ENG27168-ENG32813,sw_history-sw_version_5,----,
ENG03700-ENG109174,sw_version_integration_afs-SW_VERSION,I688,
ENG03704-ENG109174,sw_version_integration_alm-SW_VERSION,l700,
ENG03703-ENG109174,sw_version_integration_ara-SW_VERSION,A688,
ENG03703-ENG32814,sw_version_integration_ara-sw_version_camera,A708,
ENG27169-ENG32815,sw_version_integration_klima-sw_version_climate_control,7088,
ENG27169-ENG32816,sw_version_integration_klima-sw_version_preh_uif,0000,
ENG27169-ENG32817,sw_version_integration_klima-sw_version_psd,P688,
ENG27169-ENG32818,sw_version_integration_klima-sw_version_ssb,0000,
ENG27170-ENG109174,sw_version_integration_sufk-SW_VERSION,H680,
ENG116032-ENG116128,tki_runtime-tki_runtime_100ms_max_1,2028, µs
ENG116032-ENG116113,tki_runtime-tki_runtime_100ms_max_2,4357, µs
ENG116032-ENG121530,tki_runtime-tki_runtime_100ms_max_3,1853, µs
ENG116032-ENG116119,tki_runtime-tki_runtime_10ms_max_1,1721, µs
ENG116032-ENG116133,tki_runtime-tki_runtime_10ms_max_2,1366, µs
ENG116032-ENG116089,tki_runtime-tki_runtime_20ms_max_1,4102, µs
ENG116032-ENG116141,tki_runtime-tki_runtime_overruns,0, µs
ENG116032-ENG116118,tki_runtime-tki_runtime_s0,6471, µs
ENG116032-ENG116110,tki_runtime-tki_runtime_s1,2835, µs
ENG116032-ENG116093,tki_runtime-tki_runtime_s2,6358, µs
ENG116032-ENG116122,tki_runtime-tki_runtime_s3,4532, µs
ENG116032-ENG116095,tki_runtime-tki_runtime_s4,6369, µs
ENG116032-ENG116121,tki_runtime-tki_runtime_s5,7022, µs
ENG116032-ENG116084,tki_runtime-tki_runtime_s6,6490, µs
ENG116032-ENG116117,tki_runtime-tki_runtime_s7,4486, µs
ENG116032-ENG116090,tki_runtime-tki_runtime_s8,6411, µs
ENG116032-ENG116102,tki_runtime-tki_runtime_s9,2832, µs
ENG116032-ENG116127,tki_runtime-tki_runtime_slotcycle_max,50783, µs
ENG121359-ENG127696,Washer_counter_pump1-Counter_1,0,
ENG121359-ENG127697,Washer_counter_pump1-Counter_2,18,
ENG121359-ENG127700,Washer_counter_pump1-Counter_3,0,
ENG121359-ENG127699,Washer_counter_pump1-Counter_4,18,
ENG121359-ENG127698,Washer_counter_pump1-Counter_5,2,
ENG121359-ENG127701,Washer_counter_pump1-Counter_6,35.10, s
ENG121360-ENG127696,Washer_counter_sra-Counter_1,0,
ENG121360-ENG127697,Washer_counter_sra-Counter_2,1,
ENG121360-ENG127700,Washer_counter_sra-Counter_3,0,
ENG121360-ENG127699,Washer_counter_sra-Counter_4,1,
ENG121360-ENG127698,Washer_counter_sra-Counter_5,12,
ENG121360-ENG127701,Washer_counter_sra-Counter_6,6.70, s
Elapsed Time: 03:46
blockmap-13-4KE-907-561-E_WA1AAAGE8MB028917-20210516-1202.CSV
;SW:4KE-907-561-E   HW:4K0-907-561 ---  Auto Dist. Reg
;Component:LRR4R         H12 0500, Coding:FF64875458082C00000080200000003A4A1246494401409E25
;EV_ACCBOSCHAU65X,002031,EV_ACCBOSCHAU65X_AU58.rod
;Sunday,16,May,2021,12:02:23:36589
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210508 DS325.1
;VCID: 45D75838652908F3FC5-8010
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,14.2, V
IDE00075,Vehicle speed,0.00, m/s
IDE00102,Control Module temperature,48, °C
IDE00391,Adaptive distance regulation: status,ACC_StandBy,
IDE00973,Outside temperature,25.00, °C
IDE01788,Heated lens control signal,0.00, %
IDE01985-MAS06855,FAZIT identification test sum-Test sum,8D AE 7C 30,
IDE03008-MAS12557,Stop process prevented-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,not active,
IDE03008-MAS12559,Stop process prevented-Vehicle ahead starts driving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Vehicle ahead starts driving: ACC off,not active,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead starts driving: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead starts driving: ACC off,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead starts driving: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead starts driving: ACC off,0,
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE03208,Software version for suppliers,1037607928;SYSB_PLUS_PF_R340_MLBevo_CB_0500_KW36_I0.3;0;Compiled by gzu2bp on Tue Sep  8 18:17:14 2020$!,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08768,Mirror deviation: horizontal,-0.210, °
IDE08769,Mirror deviation: vertical,-0.109, °
IDE08770-MAS01466,Adjustment of screw top left-Direction of rotation,none,
IDE08770-MAS02559,Adjustment of screw top left-Rotations,0.00,
IDE08771-MAS01466,Adjustment of screw top right-Direction of rotation,none,
IDE08771-MAS02559,Adjustment of screw top right-Rotations,0.00,
IDE08772-MAS01466,Adjustment of screw bottom left-Direction of rotation,none,
IDE08772-MAS02559,Adjustment of screw bottom left-Rotations,0.00,
IDE08773-MAS01466,Adjustment of screw bottom right-Direction of rotation,none,
IDE08773-MAS02559,Adjustment of screw bottom right-Rotations,0.00,
IDE08936,Misalignment angle: horiz,0.125, °
IDE08937,Misalignment angle: horiz: fast algorithm,0.001, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,00,
IDE09380-MAS00107,Performed adjustment-Month,01,
IDE09380-MAS00108,Performed adjustment-Day,01,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,0.00, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,0.00, °
IDE09380-MAS08806,Performed adjustment-Number of successful adjustment attempts,0,
IDE09380-MAS08807,Performed adjustment-Number of failed adjustment attempts,0,
IDE09906,Vertical deadjustment,0.360, °
IDE13392,Congestion pilot: status,OFF,
IDE13863,Sensor blindness: radar,no blindness detected,
ENG55046,ACSF_Identifier_01,ACSF_B2_TJP_1.0,
ENG26467,adjustment_calculation,On,
ENG00926,Number_of_boost_function_active,0,
ENG00927,Number_of_deactivation_ASR_active,0,
ENG00928,Number_of_deactivation_ESC_active,0,
ENG00913,Number_of_Emergency_steer_assist,0,
ENG00914,Number_of_Turn_off_assistant_intervention,0,
ENG107928,Operating_time_ACC,2, min
ENG00919,Operating_time_ACC_active_driving_programm_auto,2, min
ENG00918,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG00917,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG00920,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG00921,Operating_time_ACC_active_timegap_1,0, min
ENG00922,Operating_time_ACC_active_timegap_2,0, min
ENG00923,Operating_time_ACC_active_timegap_3,2, min
ENG00924,Operating_time_ACC_active_timegap_4,0, min
ENG00925,Operating_time_ACC_active_timegap_5,0, min
ENG00929,Operating_time_ACC_active_v-delta_0,2, min
ENG00932,Operating_time_ACC_active_v-delta_large,0, min
ENG00931,Operating_time_ACC_active_v-delta_medium,0, min
ENG00930,Operating_time_ACC_active_v-delta_small,0, min
ENG26208-ENG98502,Steering_angle-Data,-40.000, °
ENG119266-ENG98502,Yaw_rate-Data,0.000, rad/s
Elapsed Time: 00:07
blockmap-15-4KE-959-655-J_WA1AAAGE8MB028917-20210516-1202.CSV
;SW:4KE-959-655-J   HW:4KE-959-655-J ---  Airbags
;Component:AirbagVW32    H02 3303, Coding:BFCCFCC000300000A200003FFA0D410000C5
;EV_AirbaVW31SMEAU65x,001044,EV_AirbaVW31SMEAU65x.rod
;Sunday,16,May,2021,12:02:46:36589
;VCID: 55F788789589B8738C5-8000
IDE00821,Seat belt switch 2nd row driver's side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Seat belt switch 2nd row center,not installed,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.1, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01099,Driver side airbag igniter 2 ohm value,no measured value present,
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.1, Ohm
IDE01102,Driver thorax airbag igniter ohm value,2.3, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.3, Ohm
IDE01104,driver side rear airbag igniter ohm value,too large,
IDE01105,Ft. pass.side rear airbag igniter ohm value,too large,
IDE01106,Driver side head curtain airbag igniter ohm value,2.5, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.4, Ohm
IDE01108,Driver side knee airbag igniter ohm value,2.3, Ohm
IDE01109,Frt.pass. side knee airbag igniter ohm value,2.4, Ohm
IDE01110,Driver side belt tensioner igniter ohm value,2.3, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,2.3, Ohm
IDE01115,side belt force limiter igniter ohm value,2.3, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,2.6, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.5, Ohm
IDE01118,Rear center belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01120,Driver side active head restraint igniter ohm value,too large,
IDE01121,Passenger side active head restraint igniter ohm value,too large,
IDE01193,Driver belt tensioner ohm value,412.0, Ohm
IDE01194,Frt.pass. belt tensioner ohm value,412.0, Ohm
IDE01195,Front passenger side seat occupancy detection: Ohm value,too large,
IDE01197,Key switch contact 1 ohm value,too large,
IDE01198,Key switch contact 2 ohm value,too large,
IDE01200,Driver seat position sensor current value,5.8, mA
IDE01201,Frt.pass. seat position sensor current value,5.8, mA
IDE01204,Center rear seat occupied recognition ohm value,232.0, Ohm
IDE01205,Safety belt switch 2nd row driver side ohm value,too large,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,too large,
IDE01207,Safety belt switch center 2nd row ohm value,too large,
IDE01208,Seat belt switch 3rd row driver side ohm value,too large,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,too large,
IDE01271,Number of rollover bar deployments,0,
IDE01357,Left pedestrian protection igniter,not installed,
IDE01358,Right pedestrian protection igniter,not installed,
IDE01359,Front pedestrian protection trigger,not installed,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,2097151,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,1023,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,131071,
IDE01555,Number of frontal crashes,0,
IDE01560,Number of activations of active head restraint,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,too large,
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,too large,
IDE01636,Pedestrian protection trigger: front ohmic value,too large,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,correct,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,2.8, Ohm
IDE03730,Driver airbag release valve igniter ohm value,3.1, Ohm
IDE03731,Igniter for frt.pass. side air bag release valve: ohm value,2.2, Ohm
IDE03800,Driver airbag release valve igniter,correct,
IDE03801,Frt.pass. airbag release valve igniter,correct,
IDE03870,Seat occupied recognition malfunction status,0,
IDE03870,Seat occupied recognition malfunction status,00,
IDE05726-MAS09976,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'off': frt. pass. side,no measured value present,
IDE05726-MAS09977,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'on': frt. pass. side,no measured value present,
IDE05726-MAS09978,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'text': frt. pass. side,no measured value present,
IDE06034,Rollover protection trigger: driver side,cannot be measured currently,
IDE06035,Rollover protection trigger: front passenger side,cannot be measured currently,
IDE06036,Rollover protection trigger: driver side ohm value,no measured value present,
IDE06038,Rollover protection trigger: frt.pass. side ohm value,no measured value present,
IDE06110,Right belt tensioner supply voltage,correct,
IDE06118,Right belt tensioner current consumption,0.0, A
IDE06119,Left belt tensioner tensioning cycles charac. curve 1,0,
IDE06120,Left belt tensioner tensioning cycles charac. curve 2,0,
IDE06121,Left belt tensioner tensioning cycles charac. curve 3,0,
IDE06122,Left belt tensioner tensioning cycles charac. curve 4,76,
IDE06123,Right belt tensioner tensioning cycles charac. curve 1,0,
IDE06124,Right belt tensioner tensioning cycles charac. curve 2,0,
IDE06125,Right belt tensioner tensioning cycles charac. curve 3,0,
IDE06126,Right belt tensioner tensioning cycles charac. curve 4,24,
IDE06128,Left belt tensioner temperature,34.0, °C
IDE06129,Right belt tensioner temperature,34.0, °C
IDE06130,Left belt tensioner supply voltage,correct,
IDE06131,Left belt tensioner current consumption,0.0, A
IDE06525,Left belt tensioner error status,00,
IDE06525,Left belt tensioner error status,0,
IDE06526,Right belt tensioner error status,0,
IDE06526,Right belt tensioner error status,00,
IDE06959,Seat occupant detection: diagnosis signal,36.5, %
IDE06960,Seat occupant detection: msmt. signal,2.5, %
IDE06961,Seat occupant detection: ref. signal,0.0, %
IDE07190,Igniter for battery open circuit 2nd battery,not installed,
IDE07191,2nd Battery open circuit igniter ohm value,too large,
IDE07192,Thorax airbag igniter,cannot be measured currently,
IDE07193,Igniter for window airbag Ohm-value,no measured value present,
IDE08436,Driver side seat belt tensioner igniter 3,cannot be measured currently,
IDE08437,Front passenger side third row seat belt tensioner igniter,cannot be measured currently,
IDE08438,Driver side seat belt tensioner igniter 3rd row ohm value,no measured value present,
IDE08439,Frt.pass. side seat belt tensioner igniter 3rd row ohm value,no measured value present,
IDE10187,Supply voltage [V],14.2, V
IDE10188,Left belt tensioner supply voltage [V],14.3, V
IDE10189,Right belt tensioner supply voltage [V],14.3, V
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,cannot be measured currently,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,cannot be measured currently,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,too large,
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,too large,
IDE12158-MAS01632,Front pedestrian protection trigger 2-Status,not installed,
IDE12158-MAS05030,Front pedestrian protection trigger 2-Resistance,too large,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,0,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,0,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,0,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,0,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,0,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,0,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,too large,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,too large,
IDE14239-MAS01632,Igniter for high-voltage battery 2 open circuit-Status,correct,
IDE14239-MAS05030,Igniter for high-voltage battery 2 open circuit-Resistance,2.6, Ohm
IDE14240-MAS01632,Driver side seat occupancy detection-Status,assigned,
IDE14240-MAS05030,Driver side seat occupancy detection-Resistance,104.0, Ohm
IDE80003,Analysis 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80004,Analysis 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80005,Analysis 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80006,Analysis 6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00001,Driver airbag igniter,correct,
MAS00002,Driver's Airbag Igniter 2,cannot be measured currently,
MAS00003,Front passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,not installed,
MAS00008,Passenger side rear thorax airbag igniter,not installed,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,correct,
MAS00012,Front passenger knee airbag igniter,correct,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver's Safety Belt Tensioner Igniter 2,correct,
MAS00016,Front passenger seat belt tensioner igniter 2,correct,
MAS00017,Driver's Belt Force Limiter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear seat belt tensioner igniter,correct,
MAS00021,Center rear seat belt tensioner igniter,cannot be measured currently,
MAS00022,Battery Interrupt Igniter,cannot be measured currently,
MAS00023,Driver side active head restraint igniter,not installed,
MAS00024,Igniter for active head restraint on frt. passenger side,not installed,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00038,Seat occupied recognition: driver side: rear,not installed,
MAS00039,Seat occupied recognition: passenger side: rear,not installed,
MAS00040,Seat occupied recognition: center: rear,Unknown (7),
MAS01634,Supply voltage,correct,
ENG114480-IDE13284,Enhanced_Passenger_Presence_Sensor_Diagnosis-Seat-occupied recognition: 3rd row driver side,0,
ENG114480-IDE13586,Enhanced_Passenger_Presence_Sensor_Diagnosis-Seat-occupied recognition: 3rd row front passenger side,0,
ENG114480-IDE14240,Enhanced_Passenger_Presence_Sensor_Diagnosis-Driver side seat occupancy detection,0,
ENG114480-MAS00038,Enhanced_Passenger_Presence_Sensor_Diagnosis-Seat occupied recognition: driver side: rear,0,
ENG114480-MAS00039,Enhanced_Passenger_Presence_Sensor_Diagnosis-Seat occupied recognition: passenger side: rear,0,
ENG114480-MAS00040,Enhanced_Passenger_Presence_Sensor_Diagnosis-Seat occupied recognition: center: rear,0,
ENG114480-MAS00231,Enhanced_Passenger_Presence_Sensor_Diagnosis-Seat occupied recognition passenger side,0,
ENG114480-MAS00478,Enhanced_Passenger_Presence_Sensor_Diagnosis-Reserved,0,
Elapsed Time: 00:27
blockmap-16-4N0-907-129-KF_WA1AAAGE8MB028917-20210516-1203.CSV
;SW:4N0-907-129-KF   HW:4N0-907-129-KF ---  Steering wheel
;Component:Lenks.Modul   H03 0009, Coding:
;EV_SMLSKLOAU736,007012,EV_SMLSKLOAU736_AU58.rod
;Sunday,16,May,2021,12:03:34:36589
;VCID: 7F5B0AD047759223F69-802A
IDE00333,Driver assistance systems button,Not operated,
IDE00333-MAS00243,Driver assistance systems button-Buttons for driver assistance systems: status,No malfunction detected,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,On,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,Cruise control switch with ACC,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS04523,Cruise Control System (CCS): switch position-Tap acceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,8 positions,
IDE00356-MAS05360,Cruise Control System (CCS): switch position-Discreet wire,High-level,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS10720,Cruise Control System (CCS): switch position-Speed limiter,not installed,
IDE00356-MAS13642,Cruise Control System (CCS): switch position-Button for cruise control system,not installed,
IDE02068-MAS00106,Time stamp-Year,2021, yr
IDE02068-MAS00107,Time stamp-Month,2, m
IDE02068-MAS00108,Time stamp-Day,9, d
IDE02068-MAS00109,Time stamp-Hours,15, H
IDE02068-MAS00110,Time stamp-Minutes,50, min
IDE02068-MAS00111,Time stamp-Seconds,54, s
IDE02068-MAS00711,Time stamp-Odometer reading,0, km
IDE02068-MAS02543,Time stamp-VIN determined during calibration,57 41 31 41 41 41 47 45 38 4D 42 30 32 38 39 31 37,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,Not operated,
IDE02693-IDE08189,Turn signals and parking lights-Malfunction status flasher,No malfunction detected,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Not operated,
IDE02695-IDE11269,Front wiping: front washing-Front windshield wiper error status,No malfunction detected,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 2,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,Not operated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear wiper,Not operated,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,Not operated,
IDE02743-IDE05742,High Beam-Light switch position,Not operated,
IDE02744-MAS02201,Steering wheel heating-Temperature,26, °C
IDE02744-MAS02323,Steering wheel heating-Voltage at switch,Low-level,
IDE02744-MAS02324,Steering wheel heating-Voltage at sensor,0.00, V
IDE02744-MAS03746,Steering wheel heating-Current: actual value,0.00, A
IDE02744-MAS04457,Steering wheel heating-PWM pulse duty factor,0, %
IDE03504-MAS03692,Personalized settings-Key 1,detected,
IDE03504-MAS03693,Personalized settings-Key 2,not detected,
IDE03504-MAS03694,Personalized settings-Key 3,not detected,
IDE03504-MAS03695,Personalized settings-Key 4,not detected,
IDE03504-MAS11282,Personalized settings-Status steering wheel heater key 1,OFF,
IDE03504-MAS11283,Personalized settings-Status steering wheel heater key 2,OFF,
IDE03504-MAS11284,Personalized settings-Status steering wheel heater key 3,OFF,
IDE03504-MAS11285,Personalized settings-Status steering wheel heater key 4,OFF,
IDE03680-IDE00019,Supply voltages-Voltage terminal 30,14385.94, mV
IDE03680-IDE00618,Supply voltages-5V voltage supply,4935.94, mV
IDE03680-MAS00125,Supply voltages-Cruise control system,12424.22, mV
IDE05725-IDE01763,Dimmer terminal 58xs-Dimming,37,
IDE05725-MAS03873,Dimmer terminal 58xs-Duty cycle,47, %
IDE08696-IDE02219,Steerg. wheel angle sens.-Steering wheel angle: sign,Negative,
IDE08696-MAS00037,Steerg. wheel angle sens.-Calibration status,calibrated,
IDE08696-MAS00370,Steerg. wheel angle sens.-Vehicle speed,in correct range,
IDE08696-MAS02125,Steerg. wheel angle sens.-Steering wheel angle speed,0, °/s
IDE08696-MAS02126,Steerg. wheel angle sens.-Steering angle sensor: status,not initialized,
IDE08696-MAS02128,Steerg. wheel angle sens.-Q bit: steering wheel angle,valid,
IDE08696-MAS02357,Steerg. wheel angle sens.-Vehicle identification,detected,
IDE08696-MAS02358,Steerg. wheel angle sens.-Calibration angle,outside permissible range,
IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value,41.0, °
IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset,1.0, °
IDE08696-MAS02832,Steerg. wheel angle sens.-Malfunction status,No malfunction,
IDE08696-MAS02983,Steerg. wheel angle sens.-Steering wheel angle,40.0, °
IDE08696-MAS04474,Steerg. wheel angle sens.-Left front wheel speed,0.00, km/h
IDE08696-MAS04475,Steerg. wheel angle sens.-Right front wheel speed,0.00, km/h
IDE08696-MAS04476,Steerg. wheel angle sens.-Left rear wheel speed,0.00, km/h
IDE08696-MAS04477,Steerg. wheel angle sens.-Right rear wheel speed,0.00, km/h
IDE08696-MAS07727,Steerg. wheel angle sens.-Steering wheel angle: prefix internal value,Negative,
IDE08696-MAS07728,Steerg. wheel angle sens.-Steering wheel angle offset: prefix,Negative,
IDE08696-MAS07729,Steerg. wheel angle sens.-Steering wheel speed: prefix,Positive,
IDE09381-IDE02219,Steering angle sensor calibration status-Steering wheel angle: sign,Negative,
IDE09381-MAS00037,Steering angle sensor calibration status-Calibration status,calibrated,
IDE09381-MAS00370,Steering angle sensor calibration status-Vehicle speed,in correct range,
IDE09381-MAS02126,Steering angle sensor calibration status-Steering angle sensor: status,not initialized,
IDE09381-MAS02357,Steering angle sensor calibration status-Vehicle identification,detected,
IDE09381-MAS02358,Steering angle sensor calibration status-Calibration angle,outside permissible range,
IDE09381-MAS02406,Steering angle sensor calibration status-Steering wheel angle: internal value,41.0, °
IDE09381-MAS02832,Steering angle sensor calibration status-Malfunction status,No malfunction,
IDE09381-MAS02983,Steering angle sensor calibration status-Steering wheel angle,40.0, °
IDE09381-MAS04121,Steering angle sensor calibration status-Voltage,in correct range,
IDE09381-MAS07727,Steering angle sensor calibration status-Steering wheel angle: prefix internal value,Negative,
IDE09381-MAS08808,Steering angle sensor calibration status-Maximal allowed offset angle,0.0, °
IDE09381-MAS08809,Steering angle sensor calibration status-Maximal allowed offset angle: sign,Positive,
IDE09381-MAS08810,Steering angle sensor calibration status-Minimum allowed offset angle,0.0, °
IDE09381-MAS08811,Steering angle sensor calibration status-Minimum allowed offset angle: sign,Positive,
Elapsed Time: 00:06
blockmap-19-4KL-907-468-C_WA1AAAGE8MB028917-20210516-1151.CSV
;SW:4KL-907-468-C   HW:4K1-907-468-C ---  CAN Gateway
;Component:Gateway       H09 0602, Coding:02030001000100C000810000005901329C8A0047180000000900009F00000000
;EV_Gatew31xAU65x,003220,EV_Gatew31xAU65x_AU58.rod
;Sunday,16,May,2021,11:51:50:36589
;VCID: 50F9796CAA6BDD5B5F3-8004
IDE00009,Date of manufacture,21 01 21,
IDE00010,Serial number,F0665943901031,
IDE00019,Voltage terminal 30,14.30, V
IDE00020-MAS00044,Terminal 15 status-Terminal 15 power supply,14.00, V
IDE00020-MAS03680,Terminal 15 status-Terminal 15 status measured,On,
IDE00020-MAS05562,Terminal 15 status-Terminal 15 resulting,On,
IDE00020-MAS07720,Terminal 15 status-Terminal 15 via CAN,On,
IDE00020-MAS08946,Terminal 15 status-Terminal 15 via comparator,On,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00*00000**,
IDE00057,History data 2,000*2000-01-01-00:00*0000.0*000*00000*0000*00*00000**,
IDE00057,History data 2,000*2000-01-01-00:00*0000.0*000*00000*0000*00**,
IDE00058,History data 3,063*2021-03-17-02:13*T*0*0*099*054*001C*0*00.0*00.0**,
IDE00058,History data 3,062*2021-03-17-02:01*T*0*0*092*050*001C*0*00.0*00.0**,
IDE00058,History data 3,060*2021-03-17-01:15*T*0*0*089*048*0010*0*00.0*00.0**,
IDE00058,History data 3,058*2021-03-13-15:49*T*0*0*087*043*0000*0*00.0*00.0**,
IDE00058,History data 3,061*2021-03-17-01:59*T*0*0*091*049*009C*0*00.0*00.0**,
IDE00058,History data 3,059*2021-03-17-01:01*T*0*0*085*046*0090*0*00.0*00.0**,
IDE00058,History data 3,064*2021-03-17-23:19*T*0*0*093*050*001C*0*00.0*00.0**,
IDE00059,History data 4,000*2000-01-01-00:00*00*000*00*000*0000000000*00000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,002*2021-02-09-08:14*01*068*01*VAO*610126Q0G4*10008*00469*000.0*000.0*000.0**,
IDE00060,History data 5,000*2000-01-01-00:00*0*000000*0000*00.0*000*00*-00.0*00000*00000*0000*00000000*000*00.0*00.0*0000.0**,
IDE00061,History data 6,196*2021-05-13-17:16*048*+31*+002.8*0000*00*00.30**,
IDE00061,History data 6,198*2021-05-14-11:14*055*+27*+001.0*0000*00*00.23**,
IDE00061,History data 6,200*2021-05-14-17:31*054*+34*+001.8*0000*00*00.35**,
IDE00061,History data 6,197*2021-05-14-08:25*055*+27*+001.3*0000*00*00.31**,
IDE00061,History data 6,193*2021-05-12-14:30*043*+26*+007.4*0000*00*00.30**,
IDE00061,History data 6,194*2021-05-12-16:37*051*+29*+007.4*0000*00*00.56**,
IDE00061,History data 6,195*2021-05-13-08:22*033*+30*+008.9*0000*00*00.28**,
IDE00061,History data 6,186*2021-05-09-13:29*032*+33*+003.7*0000*00*00.10**,
IDE00061,History data 6,184*2021-05-08-12:32*054*+32*+000.8*0000*00*00.70**,
IDE00061,History data 6,199*2021-05-14-12:14*054*+28*+000.8*0000*00*00.16**,
IDE00061,History data 6,185*2021-05-09-12:43*027*+32*+005.0*0000*00*00.10**,
IDE00061,History data 6,190*2021-05-09-16:29*040*+36*+000.2*0000*00*00.00**,
IDE00061,History data 6,192*2021-05-10-17:35*048*+36*+004.0*0000*00*00.28**,
IDE00061,History data 6,189*2021-05-09-16:07*040*+35*+006.1*0000*00*00.35**,
IDE00061,History data 6,191*2021-05-10-08:10*035*+32*+007.9*0000*00*00.23**,
IDE00062,History data 7,190*2021-05-09-16:29*026*-011.0*00.0*04.5*0003.2**,
IDE00062,History data 7,199*2021-05-14-12:24*050*-000.7*00.0*00.0*0005.0**,
IDE00062,History data 7,194*2021-05-12-17:11*021*-010.8*00.0*04.7*0003.4**,
IDE00062,History data 7,198*2021-05-14-11:28*051*-000.5*00.0*00.0*0000.7**,
IDE00062,History data 7,192*2021-05-10-17:53*031*-014.5*00.0*08.4*0020.6**,
IDE00062,History data 7,195*2021-05-13-08:39*045*-001.0*00.0*00.0*0008.5**,
IDE00062,History data 7,183*2021-05-08-10:45*051*-000.8*00.0*01.5*0001.6**,
IDE00062,History data 7,191*2021-05-10-08:24*042*-000.9*00.0*00.0*0009.1**,
IDE00062,History data 7,185*2021-05-09-12:49*026*-000.6*00.0*00.0*0000.5**,
IDE00062,History data 7,197*2021-05-14-08:45*050*-000.6*00.0*00.0*0002.4**,
IDE00062,History data 7,196*2021-05-13-17:34*050*-001.2*00.0*00.0*0014.7**,
IDE00062,History data 7,193*2021-05-12-14:48*041*-000.5*00.0*00.0*0001.7**,
IDE00062,History data 7,189*2021-05-09-16:29*040*-000.1*00.0*00.0*0000.0**,
IDE00062,History data 7,186*2021-05-09-13:36*029*-001.1*00.1*00.7*0000.6**,
IDE00062,History data 7,184*2021-05-08-13:14*020*-016.4*00.0*06.5*0006.4**,
IDE00063,History data 8,000*2000-01-01-00:00*0*+00.0*00.0*000*+00**,
IDE00063,History data 8,000*2000-01-01-00:00*0*+00.0*00.0*000*+00*00*00*00*00*00*00*000*000*00**,
IDE00064,History data 9,000*2000-01-01-00:00*000*000*000*000*00000*00.0*+00*02.0*00.0*00000*00000**,
IDE00064,History data 9,105*2021-04-08-17:51*096*096*077*040*00084*03.6*+24*14.6*12.6*00000*00000**,
IDE00064,History data 9,192*2021-05-12-14:29*100*100*056*029*00394*02.8*+26*14.6*12.6*00000*00000**,
IDE00065,History data 10,000*2000-01-01-00:00*0*000*000*+00*00*00*+00*04.0*0**,
IDE00065,History data 10,000*2000-01-01-00:00*00**,
IDE00065,History data 10,000*2000-01-01-00:00*00*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00065,History data 10,000*2000-01-01-00:00*0*000*000*+00*00*00*+00*04.0*0*00000*00000*00000**,
IDE00066,History data 11,000*2000-01-01-00:00*000*000*000*000*0000*000*00.0*00.0*000*000*000*000*00**,
IDE00066,History data 11,000*2000-01-01-00:00*000*000*000*000*0000*000*00.0*00.0*000*000*000*000*00*00000*00000*00000*00000*00000**,
IDE00067,History data 12,163*2021-05-05-08:14*0051*12*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,185*2021-05-09-12:43*0051*14*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,191*2021-05-10-08:10*0051*15*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,195*2021-05-13-08:22*0051*16*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,171*2021-05-07-08:15*0051*13*00*0000*00*00*0000*00*00**,
IDE00068,History data 13,167*2021-05-05-20:32*7*00.00*000*000*000*000*000*000*045**,
IDE00068,History data 13,166*2021-05-05-20:02*7*00.00*000*000*000*000*000*000*044**,
IDE00068,History data 13,158*2021-05-02-17:22*7*00.00*000*000*000*000*000*000*043**,
IDE00068,History data 13,199*2021-05-14-12:14*7*00.00*000*000*000*000*000*000*046**,
IDE00068,History data 13,148*2021-04-26-20:57*7*00.00*000*000*000*000*000*000*042**,
IDE00069,History data 14,000*2000-01-01-00:00*0*00.00*000*000*000*000*000*000*000**,
IDE00070,History data 15,000*2000-01-01-00:00*0*000*00.00*000*000*000**,
IDE00071,History data 16,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE00102,Control Module temperature,38, °C
IDE00725,Manufacturer test stand number,9439,
IDE00726,Component group and serial number,0103,
IDE00767-ENG05080,No. of unscheduled ECU resets-KL30_Reset_Counter,0,
IDE00767-ENG05081,No. of unscheduled ECU resets-Last_Main_Controller_Reset_Reason,00 0A,
IDE00767-ENG05078,No. of unscheduled ECU resets-Last_WD_Reset_Reason,00,
IDE00767-ENG05082,No. of unscheduled ECU resets-Main_Controller_Reset_Counter,3,
IDE00767-ENG05079,No. of unscheduled ECU resets-Wd_Reset_Counter,1,
IDE00767-ENG33384,No. of unscheduled ECU resets-Z0_Reset_Counter,0,
IDE01215,Dimmer terminal 58d,Measuring value not available,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,-98470135,
IDE01712-MAS01780,GPS Position-Width,29452375,
IDE01712-MAS02230,GPS Position-Height,220, m
IDE01803,History data 17,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE01804,History data 18,199*2021-05-14-12:23*2*000*00.16*000020*067*122*070**,
IDE01804,History data 18,199*2021-05-14-12:15*3*000*00.13*000040*066*121*070**,
IDE01804,History data 18,199*2021-05-14-12:22*1*000*00.15*000014*067*121*070**,
IDE01804,History data 18,200*2021-05-14-17:38*1*001*00.35*000014*068*122*070**,
IDE01804,History data 18,199*2021-05-14-12:15*2*000*00.01*000020*066*121*069**,
IDE01805,History data 19,036*2021-02-09-16:30*0010*0025.5*0000.5*0011.0*0000*000720FF*000*000*001**,
IDE01805,History data 19,042*2021-02-09-17:53*0010*0052.0*0000.1*0049.1*0000*000720A0*000*000*002**,
IDE01805,History data 19,000*2000-01-01-00:00*0000*0000.0*0000.0*0000.0*0000*00000000*000*000*000**,
IDE01806,History data 20,000*2000-01-01-00:00*0000*000*000*+0000000*+0000000**,
IDE01807,History data 21,00079*00035*00004*00044**,
IDE01807,History data 21,00109*00049*00004**,
IDE01807,History data 21,00001*00000*00000*00000*00000**,
IDE01807,History data 21,00000*00000*00000*00000**,
IDE01807,History data 21,00076*00334*00088*01681**,
IDE01807,History data 21,000921**,
IDE01807,History data 21,00007*00000*00000**,
IDE01807,History data 21,00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01807,History data 21,00131*00042*00018*00007*00001**,
IDE01807,History data 21,00000*00000*00000**,
IDE01807,History data 21,00000*00000*00000*00000*00000**,
IDE01807,History data 21,00130*00017*00007**,
IDE01807,History data 21,00007*00332*00008*00055**,
IDE01807,History data 21,00174*00009*00008*00005**,
IDE01808,History data 22,192*2021-05-11-23:44*1*0*009*010*027*042*0*00017*00002**,
IDE01808,History data 22,000*2000-01-01-00:00*0*0*000*000*000*000*0**,
IDE01808,History data 22,184*2021-05-09-10:51*1*0*008*010*028*043*0**,
IDE01809,History data 23,000*2000-01-01-00:00*0*00000*00000**,
IDE01810,History data 24,000*2000-01-01-00:00*0*0000*0000*0000*00000*00000*00000**,
IDE01811,History data 25,000*2000-01-01-00:00*000.0*000*000*000**,
IDE01811,History data 25,000*2000-01-01-00:00*000.0*000*000*000*00000*000.0*000*000*000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01813,History data 27,000*2000-01-01-00:00*0000**,
IDE01813,History data 27,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01816,History data 30,000*2000-00-00-00:00*0*0*0*0*0*000.00*000.00*-40**,
IDE01817,History data 31,                                                        ,
IDE01817,History data 31,,
IDE01817,History data 31,Nur für BEV                                             ,
IDE01818,History data 32,195*2021-05-13-08:22*4*004*001*02.2*01.5*000*000*00.0*00.0*00000**,
IDE01818,History data 32,191*2021-05-10-08:10*4*003*001*02.2*01.5*000*000*00.0*00.0*00000**,
IDE01818,History data 32,185*2021-05-09-12:43*4*003*001*02.0*01.5*000*000*00.0*00.0*00000**,
IDE01818,History data 32,191*2021-05-10-08:11*4*012*001*01.9*01.5*000*000*00.0*00.0*00000**,
IDE01818,History data 32,185*2021-05-09-12:44*4*043*001*02.0*01.5*000*000*00.0*00.0*00000**,
IDE01819,History data 33,000*2000-00-00-00:00*0*000*000*000*000*00000*00000**,
IDE01820,History data 34,202*2021-05-16-10:50*1*0*027*000.0*00.0*00.0*151.9*25.4**,
IDE01820,History data 34,192*2021-05-11-23:35*3*3*002*000.0*00.0*00.0*000.0*00.0**,
IDE01820,History data 34,200*2021-05-14-17:52*4*0*051*008.1*00.0*00.0*000.2*12.7**,
IDE01820,History data 34,200*2021-05-14-17:52*2*0*102*000.0*00.0*00.0*000.0*00.1**,
IDE01821,History data 35,008*2021-02-09-14:08*1*014*007*000*000*000*000*000*000*000*000**,
IDE01821,History data 35,007*2021-02-09-00:59*1*016*006*000*000*000*000*000*000*000*000**,
IDE01821,History data 35,005*2021-02-09-02:41*1*016*004*000*000*000*000*000*000*000*000**,
IDE01821,History data 35,002*2017-09-07-00:00*1*014*001*000*000*000*000*000*000*000*000**,
IDE01821,History data 35,006*2021-02-09-00:57*1*016*005*000*000*000*000*000*000*000*000**,
IDE01821,History data 35,009*2021-02-09-14:09*1*014*008*000*000*000*000*000*000*000*000**,
IDE01821,History data 35,004*2021-02-09-00:00*1*016*003*000*000*000*000*000*000*000*000**,
IDE01821,History data 35,003*2021-02-09-00:04*1*016*002*000*000*000*000*000*000*000*000**,
IDE01822,History data 36,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01822,History data 36,148*2021-04-26-20:56*3*000*001*000*000*000*000*001*001*000*001**,
IDE01822,History data 36,010*2021-02-09-14:09*1*124*001*000*000*000*000*000*001*000*001**,
IDE01823,History data 37,006*2021-02-09-00:57*2*0*1*0*1*1*0*0*1**,
IDE01823,History data 37,006*2021-02-09-00:59*2*0*1*0*1*1*0*0*1**,
IDE01823,History data 37,004*2021-02-09-02:41*2*0*1*0*1*1*0*0*1**,
IDE01823,History data 37,007*2021-02-09-00:59*2*0*1*0*1*1*0*0*1**,
IDE01823,History data 37,004*2021-02-09-00:01*2*0*1*0*1*1*0*0*0**,
IDE01823,History data 37,005*2021-02-09-02:41*2*0*1*0*1*1*0*0*1**,
IDE01823,History data 37,004*2021-02-09-00:00*2*0*1*0*1*1*0*0*0**,
IDE01824,History data 38,000*2000-01-01-00:00*0*+000*000*0**,
IDE01825,History data 39,000*2000-01-01-00:00*000*000*000**,
IDE01825,History data 39,,
IDE01826,History data 40,000*2000-01-01-00:00*0*0*0*0*0*000.00*000.00*+00**,
IDE01827,Specified generator voltage,10.6, V
IDE01833-MAS06105,Battery version-Rated battery capacity,68, Ah
IDE01833-MAS06106,Battery version-Battery technology,Fleece,
IDE01833-MAS06107,Battery version-Battery manufacturer,Varta,
IDE01834,Battery voltage,14.390, V
IDE01836,Battery current,2.478, A
IDE01837,Temperature of battery sensor,25, °C
IDE01838,Battery temperature,25, °C
IDE01839,Battery charge level,92, %
IDE01841,Battery internal resistance,3.2, mOhm
IDE01842,Usable battery charge,53, Ah
IDE01843,Battery voltage at rest,12.7, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847-MAS01577,Auxiliary heater activation restriction request-Parking heater,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,1.80, Ah
IDE01849,Previous journey duration,0.35, H
IDE01850,Overall energy balance,10009.10, Ah
IDE01851,Entire energy throughput,469.6, Ah
IDE01852,Static current measurement: result,10, mA
IDE01853,Static current measurement: status,Cancel,
IDE01854-MAS09891,Energy reclamation request-recuperation active,not active,
IDE01854-MAS09892,Energy reclamation request-Charge contingent for feedback,0, As
IDE01855,Generator current,0.0, A
IDE01864-MAS03179,Status of current bus communication-Local data bus 2,active: local wakeup event,
IDE01864-MAS03180,Status of current bus communication-Local data bus,active: local wakeup event,
IDE01864-MAS05972,Status of current bus communication-Local data bus 3,active: local wakeup event,
IDE01864-MAS10445,Status of current bus communication-Data bus CAN 1,active,
IDE01864-MAS10446,Status of current bus communication-Data bus CAN 2,active: local wakeup event,
IDE01864-MAS10447,Status of current bus communication-Data bus CAN 3,active: local wakeup event,
IDE01864-MAS10448,Status of current bus communication-Data bus CAN 4,active: local wakeup event,
IDE01864-MAS10449,Status of current bus communication-Data bus CAN 5,active: local wakeup event,
IDE01864-MAS10450,Status of current bus communication-Data bus CAN 6,active: local wakeup event,
IDE01864-MAS11107,Status of current bus communication-Data bus CAN 7,active: local wakeup event,
IDE01864-MAS11108,Status of current bus communication-FlexRay star 3,active,
IDE01864-MAS11244,Status of current bus communication-FlexRay star 1,active,
IDE01864-MAS11245,Status of current bus communication-FlexRay star 2,active,
IDE01864-MAS17841,Status of current bus communication-Data bus CAN 8,active: local wakeup event,
IDE01864-MAS17947,Status of current bus communication-FlexRay star 4,not installed,
IDE01948,Battery internal resistance not normed,3.2, mOhm
IDE01971,Lowest recorded control module temperature,-7, °C
IDE01972,Highest recorded control module temperature,55, °C
IDE01985-MAS06855,FAZIT identification test sum-Test sum,10 20 EA 95,
IDE01992-IDE14867,Installation list: current installations-Subgateway as firewall control module,Not available,
IDE01992-IDE15844,Installation list: current installations-Fuel cell drive control module,Not available,
IDE01992-SFT00001,Installation list: current installations-Engine Electronics,available.,
IDE01992-SFT00002,Installation list: current installations-Transmission Electronics,Not available,
IDE01992-SFT00003,Installation list: current installations-Brake electronics,available.,
IDE01992-SFT00006,Installation list: current installations-Seat adjustment: passenger's side,Not available,
IDE01992-SFT00007,Installation list: current installations-Display/control head,Not available,
IDE01992-SFT00008,Installation list: current installations-Climate Control Module,Not available,
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,available.,
IDE01992-SFT00012,Installation list: current installations-Rear Axle Steering 2,Not available,
IDE01992-SFT00017,Installation list: current installations-Engine electronics 2,Not available,
IDE01992-SFT00019,Installation list: current installations-Distance Regulation,available.,
IDE01992-SFT00021,Installation list: current installations-Airbag,available.,
IDE01992-SFT00022,Installation list: current installations-Steering column electronics systems,available.,
IDE01992-SFT00023,Installation list: current installations-Instrument cluster,available.,
IDE01992-SFT00024,Installation list: current installations-Auxiliary/parking heating,Not available,
IDE01992-SFT00025,Installation list: current installations-Data Bus OBD Interface,available.,
IDE01992-SFT00027,Installation list: current installations-Active Steering,Not available,
IDE01992-SFT00032,Installation list: current installations-High beam assistant,Not available,
IDE01992-SFT00033,Installation list: current installations-Battery management 2,Not available,
IDE01992-SFT00034,Installation list: current installations-All-wheel drive electronics,Not available,
IDE01992-SFT00035,Installation list: current installations-Brake Boost,Not available,
IDE01992-SFT00038,Installation list: current installations-Convertible top operation,Not available,
IDE01992-SFT00039,Installation list: current installations-Display/operating unit rear,Not available,
IDE01992-SFT00040,Installation list: current installations-Rear A/C control head,Not available,
IDE01992-SFT00042,Installation list: current installations-Control module for wireless charging,Not available,
IDE01992-SFT00043,Installation list: current installations-Steering column lock,available.,
IDE01992-SFT00048,Installation list: current installations-Special Function 2,Not available,
IDE01992-SFT00050,Installation list: current installations-Differential lock electronics,Not available,
IDE01992-SFT00054,Installation list: current installations-Seat adjustment: driver side,available.,
IDE01992-SFT00060,Installation list: current installations-Lane change assistance,available.,
IDE01992-SFT00061,Installation list: current installations-Special Function,Not available,
IDE01992-SFT00066,Installation list: current installations-Driver's door electronics,available.,
IDE01992-SFT00067,Installation list: current installations-Brake Electronics 2,Not available,
IDE01992-SFT00068,Installation list: current installations-Power steering,available.,
IDE01992-SFT00070,Installation list: current installations-Comfort system central control module,Not available,
IDE01992-SFT00070,Installation list: current installations-Comfort system central control module,available.,
IDE01992-SFT00072,Installation list: current installations-Seat adjustment: rear driver's side,Not available,
IDE01992-SFT00080,Installation list: current installations-Seat adjustment 3. seat row,Not available,
IDE01992-SFT00081,Installation list: current installations-Electric drive,Not available,
IDE01992-SFT00081,Installation list: current installations-Electric drive,available.,
IDE01992-SFT00082,Installation list: current installations-Passenger's door electronics,available.,
IDE01992-SFT00090,Installation list: current installations-Automated longitudinal control,Not available,
IDE01992-SFT00091,Installation list: current installations-Seat adjustment: rear passenger side,Not available,
IDE01992-SFT00095,Installation list: current installations-Information electronics 1,available.,
IDE01992-SFT00101,Installation list: current installations-Tire Pressure Monitoring System (TPMS),Not available,
IDE01992-SFT00105,Installation list: current installations-Trailer Function,Not available,
IDE01992-SFT00107,Installation list: current installations-Aerodynamic control module,Not available,
IDE01992-SFT00108,Installation list: current installations-Rear view camera system,Not available,
IDE01992-SFT00109,Installation list: current installations-Rear lid electronics,available.,
IDE01992-SFT00116,Installation list: current installations-Chassis Control,available.,
IDE01992-SFT00117,Installation list: current installations-Emergency call module and communication unit,available.,
IDE01992-SFT00118,Installation list: current installations-Parking aid,Not available,
IDE01992-SFT00128,Installation list: current installations-Battery control additional memory 1,Not available,
IDE01992-SFT00129,Installation list: current installations-Selector lever,available.,
IDE01992-SFT00130,Installation list: current installations-Head-Up-Display,Not available,
IDE01992-SFT00132,Installation list: current installations-Night vision system,Not available,
IDE01992-SFT00139,Installation list: current installations-Distance regulation 2,Not available,
IDE01992-SFT00140,Installation list: current installations-Hybrid Battery Management,available.,
IDE01992-SFT00165,Installation list: current installations-Front sensor for drivers assistant systems,available.,
IDE01992-SFT00166,Installation list: current installations-Microphone control module,Not available,
IDE01992-SFT00169,Installation list: current installations-Structure-borne sound actuator,Not available,
IDE01992-SFT00172,Installation list: current installations-Reducing Agent Metering System,Not available,
IDE01992-SFT00186,Installation list: current installations-Subframe mount,Not available,
IDE01992-SFT00192,Installation list: current installations-Actuator For Exterior Noise,available.,
IDE01992-SFT00195,Installation list: current installations-Electric drive 3,Not available,
IDE01992-SFT00196,Installation list: current installations-Voltage converter,Not available,
IDE01992-SFT00197,Installation list: current installations-Thermal management,available.,
IDE01992-SFT00198,Installation list: current installations-High-voltage battery charger,available.,
IDE01992-SFT00203,Installation list: current installations-Rear Axle Steering,Not available,
IDE01992-SFT00205,Installation list: current installations-Laser for adaptive cruise control,Not available,
IDE01992-SFT00206,Installation list: current installations-Electric drive 2,available.,
IDE01992-SFT00206,Installation list: current installations-Electric drive 2,Not available,
IDE01992-SFT00207,Installation list: current installations-Lane Change Assistant 2,available.,
IDE01992-SFT00208,Installation list: current installations-Front Axle Lift System,Not available,
IDE01992-SFT00219,Installation list: current installations-Front Corner Radar 1,Not available,
IDE01992-SFT00220,Installation list: current installations-Front Corner Radar 2,Not available,
IDE01992-SFT00221,Installation list: current installations-Sunroof control module 2,Not available,
IDE01992-SFT33028,Installation list: current installations-High voltage converter,available.,
IDE01992-SFT33031,Installation list: current installations-Antenna module,Not available,
IDE01992-SFT33032,Installation list: current installations-Control unit for hood ornament,Not available,
IDE01992-SFT33041,Installation list: current installations-Right exterior rear view mirror,Not available,
IDE01992-SFT33042,Installation list: current installations-Left exterior rear view mirror,Not available,
IDE01992-SFT33043,Installation list: current installations-HV battery charging unit 2,Not available,
IDE01992-SFT33044,Installation list: current installations-High voltage converter 2,Not available,
IDE01992-SFT33045,Installation list: current installations-Remote Multifunction Module,Not available,
IDE01992-SFT33232,Installation list: current installations-Central control for digital matrix light,Not available,
IDE01992-SFT09760,Installation list: current installations-Sunroof control module,available.,
IDE01993-IDE14867,Control module reference number-Subgateway as firewall control module,49,
IDE01993-IDE15844,Control module reference number-Fuel cell drive control module,B5,
IDE01993-SFT00001,Control module reference number-Engine Electronics,76,
IDE01993-SFT00002,Control module reference number-Transmission Electronics,77,
IDE01993-SFT00003,Control module reference number-Brake electronics,05,
IDE01993-SFT00003,Control module reference number-Brake electronics,13,
IDE01993-SFT00006,Control module reference number-Seat adjustment: passenger's side,4D,
IDE01993-SFT00007,Control module reference number-Display/control head,8E,
IDE01993-SFT00008,Control module reference number-Climate Control Module,46,
IDE01993-SFT00009,Control module reference number-Electronic central electric,0E,
IDE01993-SFT00012,Control module reference number-Rear Axle Steering 2,61,
IDE01993-SFT00017,Control module reference number-Engine electronics 2,78,
IDE01993-SFT00019,Control module reference number-Distance Regulation,57,
IDE01993-SFT00021,Control module reference number-Airbag,15,
IDE01993-SFT00021,Control module reference number-Airbag,06,
IDE01993-SFT00022,Control module reference number-Steering column electronics systems,0C,
IDE01993-SFT00023,Control module reference number-Instrument cluster,14,
IDE01993-SFT00024,Control module reference number-Auxiliary/parking heating,6A,
IDE01993-SFT00025,Control module reference number-Data Bus OBD Interface,10,
IDE01993-SFT00027,Control module reference number-Active Steering,16,
IDE01993-SFT00032,Control module reference number-High beam assistant,30,
IDE01993-SFT00033,Control module reference number-Battery management 2,9C,
IDE01993-SFT00034,Control module reference number-All-wheel drive electronics,0F,
IDE01993-SFT00035,Control module reference number-Brake Boost,3B,
IDE01993-SFT00038,Control module reference number-Convertible top operation,2D,
IDE01993-SFT00039,Control module reference number-Display/operating unit rear,93,
IDE01993-SFT00040,Control module reference number-Rear A/C control head,00,
IDE01993-SFT00042,Control module reference number-Control module for wireless charging,8F,
IDE01993-SFT00043,Control module reference number-Steering column lock,31,
IDE01993-SFT00048,Control module reference number-Special Function 2,2B,
IDE01993-SFT00050,Control module reference number-Differential lock electronics,1E,
IDE01993-SFT00054,Control module reference number-Seat adjustment: driver side,4C,
IDE01993-SFT00060,Control module reference number-Lane change assistance,4E,
IDE01993-SFT00060,Control module reference number-Lane change assistance,08,
IDE01993-SFT00061,Control module reference number-Special Function,2C,
IDE01993-SFT00066,Control module reference number-Driver's door electronics,4A,
IDE01993-SFT00067,Control module reference number-Brake Electronics 2,C8,
IDE01993-SFT00068,Control module reference number-Power steering,12,
IDE01993-SFT00070,Control module reference number-Comfort system central control module,8B,
IDE01993-SFT00070,Control module reference number-Comfort system central control module,00,
IDE01993-SFT00072,Control module reference number-Seat adjustment: rear driver's side,87,
IDE01993-SFT00080,Control module reference number-Seat adjustment 3. seat row,95,
IDE01993-SFT00081,Control module reference number-Electric drive,03,
IDE01993-SFT00081,Control module reference number-Electric drive,7C,
IDE01993-SFT00082,Control module reference number-Passenger's door electronics,4B,
IDE01993-SFT00090,Control module reference number-Automated longitudinal control,94,
IDE01993-SFT00091,Control module reference number-Seat adjustment: rear passenger side,88,
IDE01993-SFT00095,Control module reference number-Information electronics 1,F5,
IDE01993-SFT00095,Control module reference number-Information electronics 1,F2,
IDE01993-SFT00095,Control module reference number-Information electronics 1,73,
IDE01993-SFT00101,Control module reference number-Tire Pressure Monitoring System (TPMS),0B,
IDE01993-SFT00105,Control module reference number-Trailer Function,47,
IDE01993-SFT00107,Control module reference number-Aerodynamic control module,24,
IDE01993-SFT00108,Control module reference number-Rear view camera system,69,
IDE01993-SFT00109,Control module reference number-Rear lid electronics,23,
IDE01993-SFT00116,Control module reference number-Chassis Control,80,
IDE01993-SFT00117,Control module reference number-Emergency call module and communication unit,67,
IDE01993-SFT00117,Control module reference number-Emergency call module and communication unit,F0,
IDE01993-SFT00117,Control module reference number-Emergency call module and communication unit,F6,
IDE01993-SFT00118,Control module reference number-Parking aid,00,
IDE01993-SFT00128,Control module reference number-Battery control additional memory 1,AE,
IDE01993-SFT00129,Control module reference number-Selector lever,53,
IDE01993-SFT00130,Control module reference number-Head-Up-Display,1B,
IDE01993-SFT00130,Control module reference number-Head-Up-Display,F7,
IDE01993-SFT00132,Control module reference number-Night vision system,27,
IDE01993-SFT00139,Control module reference number-Distance regulation 2,00,
IDE01993-SFT00140,Control module reference number-Hybrid Battery Management,7B,
IDE01993-SFT00165,Control module reference number-Front sensor for drivers assistant systems,F1,
IDE01993-SFT00165,Control module reference number-Front sensor for drivers assistant systems,4F,
IDE01993-SFT00165,Control module reference number-Front sensor for drivers assistant systems,04,
IDE01993-SFT00166,Control module reference number-Microphone control module,63,
IDE01993-SFT00169,Control module reference number-Structure-borne sound actuator,1C,
IDE01993-SFT00172,Control module reference number-Reducing Agent Metering System,2A,
IDE01993-SFT00186,Control module reference number-Subframe mount,2E,
IDE01993-SFT00192,Control module reference number-Actuator For Exterior Noise,64,
IDE01993-SFT00195,Control module reference number-Electric drive 3,43,
IDE01993-SFT00196,Control module reference number-Voltage converter,41,
IDE01993-SFT00197,Control module reference number-Thermal management,42,
IDE01993-SFT00198,Control module reference number-High-voltage battery charger,44,
IDE01993-SFT00203,Control module reference number-Rear Axle Steering,60,
IDE01993-SFT00205,Control module reference number-Laser for adaptive cruise control,89,
IDE01993-SFT00206,Control module reference number-Electric drive 2,01,
IDE01993-SFT00206,Control module reference number-Electric drive 2,B8,
IDE01993-SFT00207,Control module reference number-Lane Change Assistant 2,8A,
IDE01993-SFT00207,Control module reference number-Lane Change Assistant 2,07,
IDE01993-SFT00208,Control module reference number-Front Axle Lift System,59,
IDE01993-SFT00219,Control module reference number-Front Corner Radar 1,9D,
IDE01993-SFT00220,Control module reference number-Front Corner Radar 2,9E,
IDE01993-SFT00221,Control module reference number-Sunroof control module 2,A0,
IDE01993-SFT33028,Control module reference number-High voltage converter,B7,
IDE01993-SFT33031,Control module reference number-Antenna module,BA,
IDE01993-SFT33032,Control module reference number-Control unit for hood ornament,00,
IDE01993-SFT33041,Control module reference number-Right exterior rear view mirror,C5,
IDE01993-SFT33042,Control module reference number-Left exterior rear view mirror,C4,
IDE01993-SFT33043,Control module reference number-HV battery charging unit 2,C6,
IDE01993-SFT33044,Control module reference number-High voltage converter 2,C7,
IDE01993-SFT33045,Control module reference number-Remote Multifunction Module,00,
IDE01993-SFT33232,Control module reference number-Central control for digital matrix light,F3,
IDE01993-SFT09760,Control module reference number-Sunroof control module,84,
IDE02384-IDE14867,Status of event memory-Subgateway as firewall control module,OK,
IDE02384-IDE15844,Status of event memory-Fuel cell drive control module,OK,
IDE02384-SFT00001,Status of event memory-Engine Electronics,Malfunction,
IDE02384-SFT00002,Status of event memory-Transmission Electronics,OK,
IDE02384-SFT00003,Status of event memory-Brake electronics,Malfunction,
IDE02384-SFT00006,Status of event memory-Seat adjustment: passenger's side,OK,
IDE02384-SFT00007,Status of event memory-Display/control head,OK,
IDE02384-SFT00008,Status of event memory-Climate Control Module,OK,
IDE02384-SFT00009,Status of event memory-Electronic central electric,Malfunction,
IDE02384-SFT00012,Status of event memory-Rear Axle Steering 2,OK,
IDE02384-SFT00017,Status of event memory-Engine electronics 2,OK,
IDE02384-SFT00019,Status of event memory-Distance Regulation,Malfunction,
IDE02384-SFT00021,Status of event memory-Airbag,OK,
IDE02384-SFT00022,Status of event memory-Steering column electronics systems,OK,
IDE02384-SFT00023,Status of event memory-Instrument cluster,OK,
IDE02384-SFT00024,Status of event memory-Auxiliary/parking heating,OK,
IDE02384-SFT00025,Status of event memory-Data Bus OBD Interface,Malfunction,
IDE02384-SFT00027,Status of event memory-Active Steering,OK,
IDE02384-SFT00032,Status of event memory-High beam assistant,OK,
IDE02384-SFT00033,Status of event memory-Battery management 2,OK,
IDE02384-SFT00034,Status of event memory-All-wheel drive electronics,OK,
IDE02384-SFT00035,Status of event memory-Brake Boost,OK,
IDE02384-SFT00038,Status of event memory-Convertible top operation,OK,
IDE02384-SFT00039,Status of event memory-Display/operating unit rear,OK,
IDE02384-SFT00040,Status of event memory-Rear A/C control head,OK,
IDE02384-SFT00042,Status of event memory-Control module for wireless charging,OK,
IDE02384-SFT00043,Status of event memory-Steering column lock,OK,
IDE02384-SFT00048,Status of event memory-Special Function 2,OK,
IDE02384-SFT00050,Status of event memory-Differential lock electronics,OK,
IDE02384-SFT00054,Status of event memory-Seat adjustment: driver side,OK,
IDE02384-SFT00060,Status of event memory-Lane change assistance,OK,
IDE02384-SFT00061,Status of event memory-Special Function,OK,
IDE02384-SFT00066,Status of event memory-Driver's door electronics,OK,
IDE02384-SFT00067,Status of event memory-Brake Electronics 2,OK,
IDE02384-SFT00068,Status of event memory-Power steering,OK,
IDE02384-SFT00070,Status of event memory-Comfort system central control module,OK,
IDE02384-SFT00070,Status of event memory-Comfort system central control module,Malfunction,
IDE02384-SFT00072,Status of event memory-Seat adjustment: rear driver's side,OK,
IDE02384-SFT00080,Status of event memory-Seat adjustment 3. seat row,OK,
IDE02384-SFT00081,Status of event memory-Electric drive,OK,
IDE02384-SFT00082,Status of event memory-Passenger's door electronics,OK,
IDE02384-SFT00090,Status of event memory-Automated longitudinal control,OK,
IDE02384-SFT00091,Status of event memory-Seat adjustment: rear passenger side,OK,
IDE02384-SFT00095,Status of event memory-Information electronics 1,Malfunction,
IDE02384-SFT00101,Status of event memory-Tire Pressure Monitoring System (TPMS),OK,
IDE02384-SFT00105,Status of event memory-Trailer Function,OK,
IDE02384-SFT00107,Status of event memory-Aerodynamic control module,OK,
IDE02384-SFT00108,Status of event memory-Rear view camera system,OK,
IDE02384-SFT00109,Status of event memory-Rear lid electronics,OK,
IDE02384-SFT00116,Status of event memory-Chassis Control,OK,
IDE02384-SFT00117,Status of event memory-Emergency call module and communication unit,OK,
IDE02384-SFT00118,Status of event memory-Parking aid,OK,
IDE02384-SFT00128,Status of event memory-Battery control additional memory 1,OK,
IDE02384-SFT00129,Status of event memory-Selector lever,OK,
IDE02384-SFT00130,Status of event memory-Head-Up-Display,OK,
IDE02384-SFT00132,Status of event memory-Night vision system,OK,
IDE02384-SFT00139,Status of event memory-Distance regulation 2,OK,
IDE02384-SFT00140,Status of event memory-Hybrid Battery Management,Malfunction,
IDE02384-SFT00165,Status of event memory-Front sensor for drivers assistant systems,OK,
IDE02384-SFT00165,Status of event memory-Front sensor for drivers assistant systems,Malfunction,
IDE02384-SFT00166,Status of event memory-Microphone control module,OK,
IDE02384-SFT00169,Status of event memory-Structure-borne sound actuator,OK,
IDE02384-SFT00172,Status of event memory-Reducing Agent Metering System,OK,
IDE02384-SFT00186,Status of event memory-Subframe mount,OK,
IDE02384-SFT00192,Status of event memory-Actuator For Exterior Noise,OK,
IDE02384-SFT00195,Status of event memory-Electric drive 3,OK,
IDE02384-SFT00196,Status of event memory-Voltage converter,OK,
IDE02384-SFT00197,Status of event memory-Thermal management,OK,
IDE02384-SFT00198,Status of event memory-High-voltage battery charger,Malfunction,
IDE02384-SFT00203,Status of event memory-Rear Axle Steering,OK,
IDE02384-SFT00205,Status of event memory-Laser for adaptive cruise control,OK,
IDE02384-SFT00206,Status of event memory-Electric drive 2,OK,
IDE02384-SFT00207,Status of event memory-Lane Change Assistant 2,OK,
IDE02384-SFT00208,Status of event memory-Front Axle Lift System,OK,
IDE02384-SFT00219,Status of event memory-Front Corner Radar 1,OK,
IDE02384-SFT00220,Status of event memory-Front Corner Radar 2,OK,
IDE02384-SFT00221,Status of event memory-Sunroof control module 2,OK,
IDE02384-SFT33028,Status of event memory-High voltage converter,OK,
IDE02384-SFT33031,Status of event memory-Antenna module,OK,
IDE02384-SFT33032,Status of event memory-Control unit for hood ornament,OK,
IDE02384-SFT33041,Status of event memory-Right exterior rear view mirror,OK,
IDE02384-SFT33042,Status of event memory-Left exterior rear view mirror,OK,
IDE02384-SFT33043,Status of event memory-HV battery charging unit 2,OK,
IDE02384-SFT33044,Status of event memory-High voltage converter 2,OK,
IDE02384-SFT33045,Status of event memory-Remote Multifunction Module,OK,
IDE02384-SFT33232,Status of event memory-Central control for digital matrix light,OK,
IDE02384-SFT09760,Status of event memory-Sunroof control module,OK,
IDE02578-IDE05118,Play protection status-Counter for function calls,0,
IDE02578-MAS02040,Play protection status-Anti-play protection,not active,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Not operated,
IDE02744-MAS09775,Steering wheel heating-Steering wheel temp.,76, °C
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04059,Stop process prevented-Battery temperature,not active,
IDE03008-MAS04060,Stop process prevented-Other reasons active,not active,
IDE03008-MAS04061,Stop process prevented-Idle increase active,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS09832,Stop process prevented-Intermittent mode,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04055,Start process requested-Withdrawable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS04060,Start process requested-Other reasons active,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04055,Number of prevented stop processes-Withdrawable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,0,
IDE03010-MAS04059,Number of prevented stop processes-Battery temperature,0,
IDE03010-MAS04060,Number of prevented stop processes-Other reasons active,0,
IDE03010-MAS04061,Number of prevented stop processes-Idle increase active,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,0,
IDE03010-MAS06001,Number of prevented stop processes-Energy management special veto,0,
IDE03010-MAS09832,Number of prevented stop processes-Intermittent mode,0,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04055,Number of requested start processes-Withdrawable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,0,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,0,
IDE03011-MAS04060,Number of requested start processes-Other reasons active,0,
IDE03011-MAS06003,Number of requested start processes-Charge contingency,0,
IDE03011-MAS06004,Number of requested start processes-Special start request,0,
IDE03150-IDE14867,Readiness for bus sleep mode-Subgateway as firewall control module,Bus sleep mode,
IDE03150-IDE15844,Readiness for bus sleep mode-Fuel cell drive control module,Bus sleep mode,
IDE03150-SFT00001,Readiness for bus sleep mode-Engine Electronics,active,
IDE03150-SFT00002,Readiness for bus sleep mode-Transmission Electronics,Bus sleep mode,
IDE03150-SFT00003,Readiness for bus sleep mode-Brake electronics,Bus sleep mode,
IDE03150-SFT00003,Readiness for bus sleep mode-Brake electronics,active,
IDE03150-SFT00006,Readiness for bus sleep mode-Seat adjustment: passenger's side,Bus sleep mode,
IDE03150-SFT00007,Readiness for bus sleep mode-Display/control head,Bus sleep mode,
IDE03150-SFT00008,Readiness for bus sleep mode-Climate Control Module,Bus sleep mode,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,active,
IDE03150-SFT00012,Readiness for bus sleep mode-Rear Axle Steering 2,Bus sleep mode,
IDE03150-SFT00017,Readiness for bus sleep mode-Engine electronics 2,Bus sleep mode,
IDE03150-SFT00019,Readiness for bus sleep mode-Distance Regulation,Bus sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,Bus sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,active,
IDE03150-SFT00022,Readiness for bus sleep mode-Steering column electronics systems,active,
IDE03150-SFT00023,Readiness for bus sleep mode-Instrument cluster,active,
IDE03150-SFT00024,Readiness for bus sleep mode-Auxiliary/parking heating,Bus sleep mode,
IDE03150-SFT00025,Readiness for bus sleep mode-Data Bus OBD Interface,active,
IDE03150-SFT00027,Readiness for bus sleep mode-Active Steering,Bus sleep mode,
IDE03150-SFT00032,Readiness for bus sleep mode-High beam assistant,Bus sleep mode,
IDE03150-SFT00033,Readiness for bus sleep mode-Battery management 2,Bus sleep mode,
IDE03150-SFT00034,Readiness for bus sleep mode-All-wheel drive electronics,Bus sleep mode,
IDE03150-SFT00035,Readiness for bus sleep mode-Brake Boost,Bus sleep mode,
IDE03150-SFT00038,Readiness for bus sleep mode-Convertible top operation,Bus sleep mode,
IDE03150-SFT00039,Readiness for bus sleep mode-Display/operating unit rear,Bus sleep mode,
IDE03150-SFT00040,Readiness for bus sleep mode-Rear A/C control head,Bus sleep mode,
IDE03150-SFT00042,Readiness for bus sleep mode-Control module for wireless charging,Bus sleep mode,
IDE03150-SFT00043,Readiness for bus sleep mode-Steering column lock,active,
IDE03150-SFT00048,Readiness for bus sleep mode-Special Function 2,Bus sleep mode,
IDE03150-SFT00050,Readiness for bus sleep mode-Differential lock electronics,Bus sleep mode,
IDE03150-SFT00054,Readiness for bus sleep mode-Seat adjustment: driver side,Bus sleep mode,
IDE03150-SFT00060,Readiness for bus sleep mode-Lane change assistance,Bus sleep mode,
IDE03150-SFT00060,Readiness for bus sleep mode-Lane change assistance,active,
IDE03150-SFT00061,Readiness for bus sleep mode-Special Function,Bus sleep mode,
IDE03150-SFT00066,Readiness for bus sleep mode-Driver's door electronics,active,
IDE03150-SFT00067,Readiness for bus sleep mode-Brake Electronics 2,Bus sleep mode,
IDE03150-SFT00068,Readiness for bus sleep mode-Power steering,active,
IDE03150-SFT00070,Readiness for bus sleep mode-Comfort system central control module,Bus sleep mode,
IDE03150-SFT00070,Readiness for bus sleep mode-Comfort system central control module,active,
IDE03150-SFT00072,Readiness for bus sleep mode-Seat adjustment: rear driver's side,Bus sleep mode,
IDE03150-SFT00080,Readiness for bus sleep mode-Seat adjustment 3. seat row,Bus sleep mode,
IDE03150-SFT00081,Readiness for bus sleep mode-Electric drive,active,
IDE03150-SFT00081,Readiness for bus sleep mode-Electric drive,Bus sleep mode,
IDE03150-SFT00082,Readiness for bus sleep mode-Passenger's door electronics,active,
IDE03150-SFT00090,Readiness for bus sleep mode-Automated longitudinal control,Bus sleep mode,
IDE03150-SFT00091,Readiness for bus sleep mode-Seat adjustment: rear passenger side,Bus sleep mode,
IDE03150-SFT00095,Readiness for bus sleep mode-Information electronics 1,active,
IDE03150-SFT00101,Readiness for bus sleep mode-Tire Pressure Monitoring System (TPMS),Bus sleep mode,
IDE03150-SFT00105,Readiness for bus sleep mode-Trailer Function,Bus sleep mode,
IDE03150-SFT00107,Readiness for bus sleep mode-Aerodynamic control module,Bus sleep mode,
IDE03150-SFT00108,Readiness for bus sleep mode-Rear view camera system,Bus sleep mode,
IDE03150-SFT00109,Readiness for bus sleep mode-Rear lid electronics,active,
IDE03150-SFT00116,Readiness for bus sleep mode-Chassis Control,active,
IDE03150-SFT00117,Readiness for bus sleep mode-Emergency call module and communication unit,active,
IDE03150-SFT00118,Readiness for bus sleep mode-Parking aid,Bus sleep mode,
IDE03150-SFT00128,Readiness for bus sleep mode-Battery control additional memory 1,Bus sleep mode,
IDE03150-SFT00129,Readiness for bus sleep mode-Selector lever,active,
IDE03150-SFT00130,Readiness for bus sleep mode-Head-Up-Display,Bus sleep mode,
IDE03150-SFT00132,Readiness for bus sleep mode-Night vision system,Bus sleep mode,
IDE03150-SFT00139,Readiness for bus sleep mode-Distance regulation 2,Bus sleep mode,
IDE03150-SFT00140,Readiness for bus sleep mode-Hybrid Battery Management,active,
IDE03150-SFT00165,Readiness for bus sleep mode-Front sensor for drivers assistant systems,active,
IDE03150-SFT00165,Readiness for bus sleep mode-Front sensor for drivers assistant systems,Bus sleep mode,
IDE03150-SFT00166,Readiness for bus sleep mode-Microphone control module,Bus sleep mode,
IDE03150-SFT00169,Readiness for bus sleep mode-Structure-borne sound actuator,Bus sleep mode,
IDE03150-SFT00172,Readiness for bus sleep mode-Reducing Agent Metering System,Bus sleep mode,
IDE03150-SFT00186,Readiness for bus sleep mode-Subframe mount,Bus sleep mode,
IDE03150-SFT00192,Readiness for bus sleep mode-Actuator For Exterior Noise,Bus sleep mode,
IDE03150-SFT00195,Readiness for bus sleep mode-Electric drive 3,Bus sleep mode,
IDE03150-SFT00196,Readiness for bus sleep mode-Voltage converter,Bus sleep mode,
IDE03150-SFT00197,Readiness for bus sleep mode-Thermal management,active,
IDE03150-SFT00198,Readiness for bus sleep mode-High-voltage battery charger,active,
IDE03150-SFT00203,Readiness for bus sleep mode-Rear Axle Steering,Bus sleep mode,
IDE03150-SFT00205,Readiness for bus sleep mode-Laser for adaptive cruise control,Bus sleep mode,
IDE03150-SFT00206,Readiness for bus sleep mode-Electric drive 2,active,
IDE03150-SFT00206,Readiness for bus sleep mode-Electric drive 2,Bus sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Lane Change Assistant 2,Bus sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Lane Change Assistant 2,active,
IDE03150-SFT00208,Readiness for bus sleep mode-Front Axle Lift System,Bus sleep mode,
IDE03150-SFT00219,Readiness for bus sleep mode-Front Corner Radar 1,Bus sleep mode,
IDE03150-SFT00220,Readiness for bus sleep mode-Front Corner Radar 2,Bus sleep mode,
IDE03150-SFT00221,Readiness for bus sleep mode-Sunroof control module 2,Bus sleep mode,
IDE03150-SFT33028,Readiness for bus sleep mode-High voltage converter,active,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,Bus sleep mode,
IDE03150-SFT33032,Readiness for bus sleep mode-Control unit for hood ornament,Bus sleep mode,
IDE03150-SFT33041,Readiness for bus sleep mode-Right exterior rear view mirror,Bus sleep mode,
IDE03150-SFT33042,Readiness for bus sleep mode-Left exterior rear view mirror,Bus sleep mode,
IDE03150-SFT33043,Readiness for bus sleep mode-HV battery charging unit 2,Bus sleep mode,
IDE03150-SFT33044,Readiness for bus sleep mode-High voltage converter 2,Bus sleep mode,
IDE03150-SFT33045,Readiness for bus sleep mode-Remote Multifunction Module,Bus sleep mode,
IDE03150-SFT33232,Readiness for bus sleep mode-Central control for digital matrix light,Bus sleep mode,
IDE03150-SFT09760,Readiness for bus sleep mode-Sunroof control module,active,
IDE03205,Manufacturer code,BX1,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,Not available,
IDE03477-MAS00106,GPS time-Year,Not available,
IDE03477-MAS00107,GPS time-Month,Not available,
IDE03477-MAS00108,GPS time-Day,Not available,
IDE03477-MAS00109,GPS time-Hours,Not available,
IDE03477-MAS00110,GPS time-Minutes,Not available,
IDE03477-MAS00111,GPS time-Seconds,Not available,
IDE03477-MAS01632,GPS time-Status,invalid,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,No malfunction,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,No malfunction,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,No malfunction,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,No malfunction,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,No malfunction,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,No malfunction,
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,10 00 03 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,available.,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,OK,
IDE04329-MAS02934,Status of all SWaP functions-Preconditions met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,No,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,89 C6 D6 0D 9F AF 2B A1 02 07 C8 53 7F 2C A9 D9 3B D1 A1 D1 16 08 48 FE BC 47 C5 F5 A8 F3 87 8C 9F 44 BE 42 1D 70 30 F2 E8 D1 6D 94 83 99 E9 0F 20 5C 63 C0 A6 EF 54 5A F5 96 0B 45 B5 85 41 F0 9B 53 B9 25 BE 45 C4 9B 06 32 DD E4 D2 77 0D 4D AD 26 E8 D3 91 F7 90 AA C3 B7 C2 10 56 6C C2 DC 2E 81 19 D2 C5 F4 67 7F 19 50 B4 76 B9 C8 C9 D2 80 2F 74 96 1C 83 81 27 4E 92 37 9F 79 5F 0D 70 A3 DD 9C 0C FE 9C 04 E6 26 5C 76 14 16 32 7E 42 06 7E BF 66 95 FA B8 CD D1 07 69 93 03 1C 52 C1,
IDE04343-IDE14867,Bus identification-Subgateway as firewall control module,Data bus Sensor/Hybrid,
IDE04343-IDE15844,Bus identification-Fuel cell drive control module,Data bus Sensor/Hybrid,
IDE04343-SFT00001,Bus identification-Engine Electronics,Data bus Flexray A,
IDE04343-SFT00002,Bus identification-Transmission Electronics,Data bus Flexray A,
IDE04343-SFT00003,Bus identification-Brake electronics,FlexRay B data bus,
IDE04343-SFT00003,Bus identification-Brake electronics,Data bus Flexray A,
IDE04343-SFT00006,Bus identification-Seat adjustment: passenger's side,Comfort data bus,
IDE04343-SFT00007,Bus identification-Display/control head,Infotainment data bus,
IDE04343-SFT00008,Bus identification-Climate Control Module,Comfort CAN bus 2,
IDE04343-SFT00009,Bus identification-Electronic central electric,Comfort CAN bus 2,
IDE04343-SFT00012,Bus identification-Rear Axle Steering 2,Data bus Flexray A,
IDE04343-SFT00017,Bus identification-Engine electronics 2,Data bus Flexray A,
IDE04343-SFT00019,Bus identification-Distance Regulation,FlexRay B data bus,
IDE04343-SFT00021,Bus identification-Airbag,Data bus Flexray A,
IDE04343-SFT00021,Bus identification-Airbag,FlexRay B data bus,
IDE04343-SFT00022,Bus identification-Steering column electronics systems,Data bus Flexray A,
IDE04343-SFT00023,Bus identification-Instrument cluster,Combi/dashboard data bus,
IDE04343-SFT00024,Bus identification-Auxiliary/parking heating,Extended data bus,
IDE04343-SFT00025,Bus identification-Data Bus OBD Interface,Bus master,
IDE04343-SFT00027,Bus identification-Active Steering,Data bus Flexray A,
IDE04343-SFT00032,Bus identification-High beam assistant,Extended data bus,
IDE04343-SFT00033,Bus identification-Battery management 2,Data bus Sensor/Hybrid,
IDE04343-SFT00034,Bus identification-All-wheel drive electronics,Data bus Flexray A,
IDE04343-SFT00035,Bus identification-Brake Boost,Data bus Flexray A,
IDE04343-SFT00038,Bus identification-Convertible top operation,Comfort data bus,
IDE04343-SFT00039,Bus identification-Display/operating unit rear,Infotainment data bus,
IDE04343-SFT00040,Bus identification-Rear A/C control head,Unknown,
IDE04343-SFT00042,Bus identification-Control module for wireless charging,Data bus Sensor/Hybrid,
IDE04343-SFT00043,Bus identification-Steering column lock,Comfort data bus,
IDE04343-SFT00048,Bus identification-Special Function 2,Comfort data bus,
IDE04343-SFT00050,Bus identification-Differential lock electronics,Data bus Flexray A,
IDE04343-SFT00054,Bus identification-Seat adjustment: driver side,Comfort data bus,
IDE04343-SFT00060,Bus identification-Lane change assistance,Extended data bus,
IDE04343-SFT00060,Bus identification-Lane change assistance,FlexRay B data bus,
IDE04343-SFT00061,Bus identification-Special Function,Comfort data bus,
IDE04343-SFT00066,Bus identification-Driver's door electronics,Comfort data bus,
IDE04343-SFT00067,Bus identification-Brake Electronics 2,Data bus Flexray A,
IDE04343-SFT00068,Bus identification-Power steering,Data bus Flexray A,
IDE04343-SFT00070,Bus identification-Comfort system central control module,Comfort data bus,
IDE04343-SFT00070,Bus identification-Comfort system central control module,Unknown,
IDE04343-SFT00072,Bus identification-Seat adjustment: rear driver's side,Comfort data bus,
IDE04343-SFT00080,Bus identification-Seat adjustment 3. seat row,Comfort data bus,
IDE04343-SFT00081,Bus identification-Electric drive,Data bus Sensor/Hybrid,
IDE04343-SFT00081,Bus identification-Electric drive,Data bus Flexray A,
IDE04343-SFT00082,Bus identification-Passenger's door electronics,Comfort data bus,
IDE04343-SFT00090,Bus identification-Automated longitudinal control,Data bus Flexray A,
IDE04343-SFT00091,Bus identification-Seat adjustment: rear passenger side,Comfort data bus,
IDE04343-SFT00095,Bus identification-Information electronics 1,Infotainment data bus,
IDE04343-SFT00095,Bus identification-Information electronics 1,VLAN_Infotainment,
IDE04343-SFT00095,Bus identification-Information electronics 1,VLAN_Internet,
IDE04343-SFT00101,Bus identification-Tire Pressure Monitoring System (TPMS),Extended data bus,
IDE04343-SFT00105,Bus identification-Trailer Function,Comfort data bus,
IDE04343-SFT00107,Bus identification-Aerodynamic control module,Comfort data bus,
IDE04343-SFT00108,Bus identification-Rear view camera system,Extended data bus,
IDE04343-SFT00109,Bus identification-Rear lid electronics,Comfort data bus,
IDE04343-SFT00116,Bus identification-Chassis Control,Data bus Flexray A,
IDE04343-SFT00117,Bus identification-Emergency call module and communication unit,Data bus connect,
IDE04343-SFT00117,Bus identification-Emergency call module and communication unit,VLAN_Internet,
IDE04343-SFT00117,Bus identification-Emergency call module and communication unit,VLAN_Connect,
IDE04343-SFT00118,Bus identification-Parking aid,Unknown,
IDE04343-SFT00128,Bus identification-Battery control additional memory 1,Data bus Sensor/Hybrid,
IDE04343-SFT00129,Bus identification-Selector lever,Combi/dashboard data bus,
IDE04343-SFT00130,Bus identification-Head-Up-Display,Combi/dashboard data bus,
IDE04343-SFT00130,Bus identification-Head-Up-Display,VLAN_Komfort,
IDE04343-SFT00132,Bus identification-Night vision system,Extended data bus,
IDE04343-SFT00139,Bus identification-Distance regulation 2,Unknown,
IDE04343-SFT00140,Bus identification-Hybrid Battery Management,Data bus Sensor/Hybrid,
IDE04343-SFT00165,Bus identification-Front sensor for drivers assistant systems,FlexRay B data bus,
IDE04343-SFT00165,Bus identification-Front sensor for drivers assistant systems,Data bus Flexray A,
IDE04343-SFT00165,Bus identification-Front sensor for drivers assistant systems,VLAN_FAS,
IDE04343-SFT00166,Bus identification-Microphone control module,Infotainment data bus,
IDE04343-SFT00169,Bus identification-Structure-borne sound actuator,Extended data bus,
IDE04343-SFT00172,Bus identification-Reducing Agent Metering System,Extended data bus,
IDE04343-SFT00186,Bus identification-Subframe mount,Extended data bus,
IDE04343-SFT00192,Bus identification-Actuator For Exterior Noise,Extended data bus,
IDE04343-SFT00195,Bus identification-Electric drive 3,Data bus Flexray A,
IDE04343-SFT00196,Bus identification-Voltage converter,Data bus Sensor/Hybrid,
IDE04343-SFT00197,Bus identification-Thermal management,Data bus Sensor/Hybrid,
IDE04343-SFT00198,Bus identification-High-voltage battery charger,Data bus Sensor/Hybrid,
IDE04343-SFT00203,Bus identification-Rear Axle Steering,Data bus Flexray A,
IDE04343-SFT00205,Bus identification-Laser for adaptive cruise control,FlexRay B data bus,
IDE04343-SFT00206,Bus identification-Electric drive 2,Data bus Flexray A,
IDE04343-SFT00207,Bus identification-Lane Change Assistant 2,FlexRay B data bus,
IDE04343-SFT00207,Bus identification-Lane Change Assistant 2,Extended data bus,
IDE04343-SFT00208,Bus identification-Front Axle Lift System,Comfort CAN bus 2,
IDE04343-SFT00219,Bus identification-Front Corner Radar 1,FlexRay B data bus,
IDE04343-SFT00220,Bus identification-Front Corner Radar 2,FlexRay B data bus,
IDE04343-SFT00221,Bus identification-Sunroof control module 2,Comfort data bus,
IDE04343-SFT33031,Bus identification-Antenna module,Infotainment data bus,
IDE04343-SFT33032,Bus identification-Control unit for hood ornament,Unknown,
IDE04343-SFT33041,Bus identification-Right exterior rear view mirror,Comfort CAN bus 2,
IDE04343-SFT33042,Bus identification-Left exterior rear view mirror,Comfort CAN bus 2,
IDE04343-SFT33043,Bus identification-HV battery charging unit 2,Data bus Sensor/Hybrid,
IDE04343-SFT33044,Bus identification-High voltage converter 2,Data bus Sensor/Hybrid,
IDE04343-SFT33232,Bus identification-Central control for digital matrix light,VLAN_FAS,
IDE04343-SFT09760,Bus identification-Sunroof control module,Comfort data bus,
IDE04806-MAS10929,Driving profile selection button-Button for load profile selection,Not operated,
IDE04806-MAS10937,Driving profile selection button-Driving profile selection button 1,Not operated,
IDE04806-MAS10938,Driving profile selection button-Driving profile selection button 2,Not operated,
IDE04806-MAS10939,Driving profile selection button-Drive profile selection rotary switch,no function,
IDE05583-IDE09851,Break recommendation-Function active,No,
IDE05583-MAS03095,Break recommendation-Function status,not installed,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No display,
IDE05583-MAS13273,Break recommendation-deactivation status,Switched off: not installed,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG05007,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG05008,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG05009,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG05010,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG05011,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG05012,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG05013,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG05014,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,52 58 D7 58 12,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,no entry,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,Engine Control Module,
IDE06007-MAS00106,Driving profile history data 1-Year,2000, yr
IDE06007-MAS00107,Driving profile history data 1-Month,0, m
IDE06007-MAS00108,Driving profile history data 1-Day,0, d
IDE06007-MAS00109,Driving profile history data 1-Hours,0, H
IDE06007-MAS00110,Driving profile history data 1-Minutes,0, min
IDE06007-MAS00111,Driving profile history data 1-Seconds,0, s
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initialization,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,no entry,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,Transmission Control Module (TCM),
IDE06008-MAS00106,Driving profile history data 2-Year,2000, yr
IDE06008-MAS00107,Driving profile history data 2-Month,0, m
IDE06008-MAS00108,Driving profile history data 2-Day,0, d
IDE06008-MAS00109,Driving profile history data 2-Hours,0, H
IDE06008-MAS00110,Driving profile history data 2-Minutes,0, min
IDE06008-MAS00111,Driving profile history data 2-Seconds,0, s
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initialization,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,no entry,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,no entry,
IDE06009-MAS00106,Driving profile history data 3-Year,2000, yr
IDE06009-MAS00107,Driving profile history data 3-Month,0, m
IDE06009-MAS00108,Driving profile history data 3-Day,0, d
IDE06009-MAS00109,Driving profile history data 3-Hours,0, H
IDE06009-MAS00110,Driving profile history data 3-Minutes,0, min
IDE06009-MAS00111,Driving profile history data 3-Seconds,0, s
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initialization,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,no entry,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,no entry,
IDE06010-MAS00106,Driving profile history data 4-Year,2000, yr
IDE06010-MAS00107,Driving profile history data 4-Month,0, m
IDE06010-MAS00108,Driving profile history data 4-Day,0, d
IDE06010-MAS00109,Driving profile history data 4-Hours,0, H
IDE06010-MAS00110,Driving profile history data 4-Minutes,0, min
IDE06010-MAS00111,Driving profile history data 4-Seconds,0, s
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initialization,
IDE06011-ENG04999,Selected driving profile-driving_profile_1,Profile 7,
IDE06011-ENG05000,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG05001,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG05002,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG05003,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG05004,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG05005,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG05006,Selected driving profile-driving_profile_8,no function,
IDE06165-ENG118695,Driving profile selection statistics-Profile_1,58, min
IDE06165-ENG126249,Driving profile selection statistics-profile_10,0, min
IDE06165-ENG126250,Driving profile selection statistics-profile_11,0, min
IDE06165-ENG127921,Driving profile selection statistics-profile_12,0, min
IDE06165-ENG04216,Driving profile selection statistics-profile_13,0, min
IDE06165-ENG04217,Driving profile selection statistics-profile_14,0, min
IDE06165-ENG04218,Driving profile selection statistics-profile_15,0, min
IDE06165-ENG118696,Driving profile selection statistics-Profile_2,340, min
IDE06165-ENG118697,Driving profile selection statistics-Profile_3,182, min
IDE06165-ENG118698,Driving profile selection statistics-Profile_4,27, min
IDE06165-ENG118699,Driving profile selection statistics-Profile_5,10, min
IDE06165-ENG118700,Driving profile selection statistics-Profile_6,0, min
IDE06165-ENG118701,Driving profile selection statistics-Profile_7,1194, min
IDE06165-ENG118702,Driving profile selection statistics-Profile_8,0, min
IDE06165-ENG126248,Driving profile selection statistics-profile_9,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2000, yr
IDE06230-MAS00107,Break recommend.: last message-Month,1, m
IDE06230-MAS00108,Break recommend.: last message-Day,1, d
IDE06230-MAS00109,Break recommend.: last message-Hours,0, H
IDE06230-MAS00110,Break recommend.: last message-Minutes,0, min
IDE06230-MAS00111,Break recommend.: last message-Seconds,0, s
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,no warning,
IDE06264-IDE09057,Deep discharge protection-HV battery charge state,79.50, %
IDE06264-MAS04721,Deep discharge protection-Minimum charge level,4.00, %
IDE06264-MAS13070,Deep discharge protection-High-voltage energy management shut-down stage,not active,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,1,
IDE06307-MAS00108,Stop prevention history data-Day,1,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,1,
IDE06308-MAS00108,Start request history data-Day,1,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE06577,Supplier Identification,--------------------------------,
IDE06805-MAS09523,Status of voltage freedom-Transformer for electrical drive,High voltage power off not recognized,
IDE06805-MAS09524,Status of voltage freedom-Hybrid Battery Management,High voltage power off not recognized,
IDE06805-MAS09525,Status of voltage freedom-Control module for wireless charging,Initialization,
IDE06805-MAS09526,Status of voltage freedom-High-voltage battery charger,High voltage power off not recognized,
IDE06805-MAS11874,Status of voltage freedom-Overall status,High voltage power off not recognized,
IDE06805-SFT00195,Status of voltage freedom-Electric drive 3,Initialization,
IDE06805-SFT00206,Status of voltage freedom-Electric drive 2,High voltage power off not recognized,
IDE06805-SFT33043,Status of voltage freedom-HV battery charging unit 2,Initialization,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,08,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,0,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,0,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,0,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,0,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,0,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,9,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Act.val.,0,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,engaged,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,14,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,OK,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Act.val.,2,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,engaged,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,28,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Act.val.,0,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,engaged,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,8,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,OK,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Act.val.,2,
IDE07431-IDE04447,Status: driving mode selection for AFS & headlamp range control-Function status,not engaged,
IDE07431-IDE06260,Status: driving mode selection for AFS & headlamp range control-ID number,0,
IDE07431-MAS01156,Status: driving mode selection for AFS & headlamp range control-Communication status,OK,
IDE07431-MAS01447,Status: driving mode selection for AFS & headlamp range control-Act.val.,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,not engaged,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,0,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,OK,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Act.val.,0,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,engaged,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,0,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Act.val.,0,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,engaged,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,26,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,OK,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Act.val.,0,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,not engaged,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,0,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,OK,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Act.val.,0,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,Malfunction,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,5, A
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,14.3, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,536, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,695, A
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,Initialization,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,10.70, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,10.70, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,Malfunction,
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,Malfunction,
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Comfort,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,AUTO,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Dynamic,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,Offroad,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,ECONOMY,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,Lift,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,INDIVIDUAL,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,Range,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,Not Used,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Not Used,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07873-MAS08879,Driving mode selection activated profiles-Profile 13,Not Used,
IDE07873-MAS08880,Driving mode selection activated profiles-Profile 14,Not Used,
IDE07873-MAS08881,Driving mode selection activated profiles-Profile 15,Not Used,
IDE08343,Immobilizer Challenge,AE 25 E3 F5,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,not engaged,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,0,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,OK,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Act.val.,0,
IDE08490,Activation of diagnosis via ethernet,not active,
IDE08530-MAS00106,Connection status online basic services-Year,2030, yr
IDE08530-MAS00107,Connection status online basic services-Month,5, m
IDE08530-MAS00108,Connection status online basic services-Day,5, d
IDE08530-MAS00109,Connection status online basic services-Hours,16, H
IDE08530-MAS00110,Connection status online basic services-Minutes,16, min
IDE08530-MAS00111,Connection status online basic services-Seconds,48, s
IDE08530-MAS07130,Connection status online basic services-Number of ID steps,14,
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,0,
IDE08531-MAS00106,Connection status online license services-Year,Not available,
IDE08531-MAS00107,Connection status online license services-Month,Not available,
IDE08531-MAS00108,Connection status online license services-Day,Not available,
IDE08531-MAS00109,Connection status online license services-Hours,Not available,
IDE08531-MAS00110,Connection status online license services-Minutes,Not available,
IDE08531-MAS07132,Connection status online license services-Code status,7000,
IDE08531-MAS07133,Connection status online license services-No. of license serv.,14,
IDE08531-MAS07134,Connection status online license services-ID services,290,
IDE08531-MAS07135,Connection status online license services-Activation status,Not available,
IDE08531-MAS07136,Connection status online license services-Exp. year,Not available,
IDE08531-MAS07137,Connection status online license services-Exp. month,Not available,
IDE08531-MAS07138,Connection status online license services-Exp. day,Not available,
IDE08600-IDE04447,Status drive profile selec. for rear-wheel drive-Function status,not engaged,
IDE08600-IDE06260,Status drive profile selec. for rear-wheel drive-ID number,0,
IDE08600-MAS01156,Status drive profile selec. for rear-wheel drive-Communication status,OK,
IDE08600-MAS01447,Status drive profile selec. for rear-wheel drive-Act.val.,0,
IDE08601-IDE04447,Drive profile selection for actuator for exterior noise-Function status,engaged,
IDE08601-IDE06260,Drive profile selection for actuator for exterior noise-ID number,0,
IDE08601-MAS01156,Drive profile selection for actuator for exterior noise-Communication status,OK,
IDE08601-MAS01447,Drive profile selection for actuator for exterior noise-Act.val.,0,
IDE08602-IDE04447,Status drive profile selec. for active steering-Function status,not engaged,
IDE08602-IDE06260,Status drive profile selec. for active steering-ID number,0,
IDE08602-MAS01156,Status drive profile selec. for active steering-Communication status,OK,
IDE08602-MAS01447,Status drive profile selec. for active steering-Act.val.,0,
IDE08605-IDE04447,Status drive profile for level control system-Function status,engaged,
IDE08605-IDE06260,Status drive profile for level control system-ID number,254,
IDE08605-MAS01156,Status drive profile for level control system-Communication status,OK,
IDE08605-MAS01447,Status drive profile for level control system-Act.val.,2,
IDE08611-IDE04447,Status drive profile for stabilizer-Function status,engaged,
IDE08611-IDE06260,Status drive profile for stabilizer-ID number,0,
IDE08611-MAS01156,Status drive profile for stabilizer-Communication status,OK,
IDE08611-MAS01447,Status drive profile for stabilizer-Act.val.,0,
IDE08614-IDE04447,Status drive profile for engine operating conditions-Function status,not engaged,
IDE08614-IDE06260,Status drive profile for engine operating conditions-ID number,0,
IDE08614-MAS01156,Status drive profile for engine operating conditions-Communication status,OK,
IDE08614-MAS01447,Status drive profile for engine operating conditions-Act.val.,0,
IDE08687-IDE04447,Status: driving profile select. for brake ctrl. sys.-Function status,engaged,
IDE08687-IDE06260,Status: driving profile select. for brake ctrl. sys.-ID number,0,
IDE08687-MAS01156,Status: driving profile select. for brake ctrl. sys.-Communication status,OK,
IDE08687-MAS01447,Status: driving profile select. for brake ctrl. sys.-Act.val.,2,
IDE08796-IDE04447,Status: driving profile selec. for hill descent control-Function status,engaged,
IDE08796-IDE06260,Status: driving profile selec. for hill descent control-ID number,0,
IDE08796-MAS01156,Status: driving profile selec. for hill descent control-Communication status,OK,
IDE08796-MAS01447,Status: driving profile selec. for hill descent control-Act.val.,2,
IDE08798-IDE04447,Status: drive profile for Matrix-Beam-Function status,engaged,
IDE08798-IDE06260,Status: drive profile for Matrix-Beam-ID number,44,
IDE08798-MAS01156,Status: drive profile for Matrix-Beam-Communication status,OK,
IDE08798-MAS01447,Status: drive profile for Matrix-Beam-Act.val.,2,
IDE08799-IDE04447,Status: driv. profile selec. for rear spoiler-Function status,not engaged,
IDE08799-IDE06260,Status: driv. profile selec. for rear spoiler-ID number,0,
IDE08799-MAS01156,Status: driv. profile selec. for rear spoiler-Communication status,OK,
IDE08799-MAS01447,Status: driv. profile selec. for rear spoiler-Act.val.,0,
IDE08804-IDE04447,Status: driv. profile selec. for ctr. differential-Function status,not engaged,
IDE08804-IDE06260,Status: driv. profile selec. for ctr. differential-ID number,0,
IDE08804-MAS01156,Status: driv. profile selec. for ctr. differential-Communication status,OK,
IDE08804-MAS01447,Status: driv. profile selec. for ctr. differential-Act.val.,0,
IDE08956-MAS08051,H-V power distro-Power allocation thermal management,10700, W
IDE08956-MAS08052,H-V power distro-Power quota: 12 V electrical system,1500, W
IDE08956-MAS08054,H-V power distro-Power quota: comfort loads,300, W
IDE08956-MAS13094,H-V power distro-Power allocation by engine electronics,25450, W
IDE08956-MAS13095,H-V power distro-Power allocation by high-voltage battery charger,8750, W
IDE08956-MAS13096,H-V power distro-Power allocation by hybrid battery management,12650, W
IDE08956-MAS13097,H-V power distro-Power drawn by voltage transformer for electric drive,340, W
IDE08956-MAS13098,H-V power distro-Power drawn by thermal management,0, W
IDE09074-MAS01078,Vehicle properties-Vehicle model,Electric vehicle,
IDE09074-MAS08256,Vehicle properties-Max energy content,15650,
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),23.00,
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,10.00, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,21.00,
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,69.00, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,620, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,6.00,
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.00, l/100km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,0, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,283, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,56, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,283, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,0, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,283, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,Malfunction,
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,176, km
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,176, km
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,not installed,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,10.00, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,10.00, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,10.00, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,10.00, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,10.00, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,10.00, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.00, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,16.00,
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,16.00,
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,18.00,
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,15.00,
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,16.00,
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,21.00,
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.00,
IDE09080-MAS12005,Energy storage unit-Tank capacity with conventional fuel for range calculation,0.00, l
IDE09080-MAS12006,Energy storage unit-Energy content of HV battery for range calculation,325,
IDE09080-MAS12007,Energy storage unit-Tank capacity with CNG for range calculation,0.00, l
IDE09080-MAS12008,Energy storage unit-Tank capacity with LPG for range calculation,0.00, l
IDE09467,MAC address,48 16 93 38 66 1D,
IDE09468-MAS01390,IPv4 address-Block 1,169,
IDE09468-MAS01391,IPv4 address-Block 2,254,
IDE09468-MAS01392,IPv4 address-Block 3,30,
IDE09468-MAS01393,IPv4 address-Block 4,102,
IDE09469-MAS01390,IPv6 address-Block 1,00 00,
IDE09469-MAS01391,IPv6 address-Block 2,00 00,
IDE09469-MAS01392,IPv6 address-Block 3,00 00,
IDE09469-MAS01393,IPv6 address-Block 4,00 00,
IDE09469-MAS01394,IPv6 address-Block 5,00 00,
IDE09469-MAS01395,IPv6 address-Block 6,00 00,
IDE09469-MAS01396,IPv6 address-Block 7,00 00,
IDE09469-MAS01397,IPv6 address-Block 8,00 00,
IDE09891-SFT00081,Voltage converter for electric drive: status of electric drive-Electric drive,No malfunction detected,
IDE09891-SFT00195,Voltage converter for electric drive: status of electric drive-Electric drive 3,No malfunction detected,
IDE09891-SFT00206,Voltage converter for electric drive: status of electric drive-Electric drive 2,No malfunction detected,
IDE09892-MAS02832,Hybrid battery management: status of electric drive-Malfunction status,No malfunction detected,
IDE09892-MAS03001,Hybrid battery management: status of electric drive-Mode,HV mains activ.,
IDE09893-MAS02832,High voltage battery charger: status of electric drive-Malfunction status,No malfunction detected,
IDE09893-MAS03001,High voltage battery charger: status of electric drive-Mode,not active,
IDE09893-MAS17068,High voltage battery charger: status of electric drive-High-voltage battery charger 2: actual status,Standby-mode,
IDE09893-MAS17070,High voltage battery charger: status of electric drive-High-voltage battery charger 2: error status,No malfunction detected,
IDE09893-MAS17071,High voltage battery charger: status of electric drive-High-voltage charging management: current mode,not active,
IDE09893-MAS17072,High voltage battery charger: status of electric drive-High-voltage charging management: error status,No malfunction detected,
IDE09894-MAS13356,Thermal management: status of electric drive-Error status additional air heating,No malfunction detected,
IDE09894-MAS13357,Thermal management: status of electric drive-Mode additional air heating,Control active,
IDE09894-MAS13358,Thermal management: status of electric drive-Error status A/C compressor,No malfunction detected,
IDE09894-MAS13359,Thermal management: status of electric drive-Mode A/C compressor,Control active,
IDE09895-MAS13099,Engine electronics: status of electric drive-Error status electric drive,No malfunction detected,
IDE09895-MAS13100,Engine electronics: status of electric drive-Electric drive mode,Engine start,
IDE09895-MAS13101,Engine electronics: status of electric drive-Error status of electric machine,No malfunction detected,
IDE09895-MAS13102,Engine electronics: status of electric drive-Electric machine mode,20,
IDE09896-MAS02832,Ctrl. module for contactless charging: status of electric drive-Malfunction status,No malfunction detected,
IDE09896-MAS03001,Ctrl. module for contactless charging: status of electric drive-Mode,not active,
IDE09897-MAS02246,Volt. converter for elec. drive: high-volt. activ. restrict.-Timeout,not active,
IDE09897-MAS09518,Volt. converter for elec. drive: high-volt. activ. restrict.-Safety line,not active,
IDE09897-MAS09519,Volt. converter for elec. drive: high-volt. activ. restrict.-Message error,not active,
IDE09897-MAS09542,Volt. converter for elec. drive: high-volt. activ. restrict.-Error status init. error,not active,
IDE09897-MAS09544,Volt. converter for elec. drive: high-volt. activ. restrict.-No component function,not active,
IDE09897-MAS09546,Volt. converter for elec. drive: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09897-MAS12345,Volt. converter for elec. drive: high-volt. activ. restrict.-Active discharge fault,not active,
IDE09898-MAS02246,Hybrid batt. management:  H-V activ. restriction-Timeout,not active,
IDE09898-MAS03123,Hybrid batt. management:  H-V activ. restriction-Reduced performance,not active,
IDE09898-MAS09513,Hybrid batt. management:  H-V activ. restriction-Insulation test stage 1 failed,not active,
IDE09898-MAS09514,Hybrid batt. management:  H-V activ. restriction-Insulation test stage 2 failed,not active,
IDE09898-MAS09518,Hybrid batt. management:  H-V activ. restriction-Safety line,not active,
IDE09898-MAS09519,Hybrid batt. management:  H-V activ. restriction-Message error,not active,
IDE09898-MAS09520,Hybrid batt. management:  H-V activ. restriction-Safety connector,not active,
IDE09898-MAS09541,Hybrid batt. management:  H-V activ. restriction-Act. mode init. error,not active,
IDE09898-MAS09542,Hybrid batt. management:  H-V activ. restriction-Error status init. error,not active,
IDE09898-MAS09543,Hybrid batt. management:  H-V activ. restriction-Operating mode error,not active,
IDE09898-MAS09544,Hybrid batt. management:  H-V activ. restriction-No component function,not active,
IDE09898-MAS09545,Hybrid batt. management:  H-V activ. restriction-Sequence error,not active,
IDE09898-MAS09546,Hybrid batt. management:  H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09898-MAS12351,Hybrid batt. management:  H-V activ. restriction-HV voltage measurement error,not active,
IDE09898-MAS13068,Hybrid batt. management:  H-V activ. restriction-HV voltage measurement initialization error,not active,
IDE09899-MAS02246,Eng. electronics: H-V activ. restriction-Timeout,not active,
IDE09899-MAS09519,Eng. electronics: H-V activ. restriction-Message error,not active,
IDE09899-MAS09541,Eng. electronics: H-V activ. restriction-Act. mode init. error,not active,
IDE09899-MAS09545,Eng. electronics: H-V activ. restriction-Sequence error,not active,
IDE09899-MAS09547,Eng. electronics: H-V activ. restriction-Error status drive motor: init. error,not active,
IDE09899-MAS09548,Eng. electronics: H-V activ. restriction-Error status drive: init. error,not active,
IDE09899-MAS09549,Eng. electronics: H-V activ. restriction-Drive condition: init. error,not active,
IDE09899-MAS09550,Eng. electronics: H-V activ. restriction-Safety line power electronics,not active,
IDE09899-MAS09551,Eng. electronics: H-V activ. restriction-Part. oper.,not active,
IDE09899-MAS09552,Eng. electronics: H-V activ. restriction-HV shut-down due to operating strategy,not active,
IDE09899-MAS09553,Eng. electronics: H-V activ. restriction-no component function drive motor,not active,
IDE09899-MAS09554,Eng. electronics: H-V activ. restriction-no component function drive,not active,
IDE09900-MAS02246,H-V batt. charger H-V activ. restriction-Timeout,not active,
IDE09900-MAS09519,H-V batt. charger H-V activ. restriction-Message error,not active,
IDE09900-MAS09546,H-V batt. charger H-V activ. restriction-Voltage disconnect. init. error,not active,
IDE09901-MAS02246,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Timeout,not active,
IDE09901-MAS09518,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Safety line,not active,
IDE09901-MAS09519,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Message error,not active,
IDE09901-MAS09541,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09901-MAS09542,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Error status init. error,not active,
IDE09901-MAS09543,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Operating mode error,not active,
IDE09901-MAS09544,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-No component function,not active,
IDE09901-MAS09546,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-Voltage disconnect. init. error,not active,
IDE09901-MAS12351,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09901-MAS13068,Ctrl. unit for contactless charg.: high-volt. activ. restrict.-HV voltage measurement initialization error,not active,
IDE09902-MAS02246,A/C compressor: H-V activ. restriction-Timeout,not active,
IDE09902-MAS09518,A/C compressor: H-V activ. restriction-Safety line,not active,
IDE09902-MAS09519,A/C compressor: H-V activ. restriction-Message error,not active,
IDE09902-MAS09541,A/C compressor: H-V activ. restriction-Act. mode init. error,not active,
IDE09902-MAS09542,A/C compressor: H-V activ. restriction-Error status init. error,not active,
IDE09902-MAS09544,A/C compressor: H-V activ. restriction-No component function,not active,
IDE09902-MAS09545,A/C compressor: H-V activ. restriction-Sequence error,not active,
IDE09902-MAS12351,A/C compressor: H-V activ. restriction-HV voltage measurement error,not active,
IDE09903-MAS02246,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Timeout,not active,
IDE09903-MAS09518,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Safety line,not active,
IDE09903-MAS09519,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Message error,not active,
IDE09903-MAS09541,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Act. mode init. error,not active,
IDE09903-MAS09542,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Error status init. error,not active,
IDE09903-MAS09544,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-No component function,not active,
IDE09903-MAS09545,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-Sequence error,not active,
IDE09903-MAS12351,Ctrl. unit for auxil. heater: high-volt. activ. restrict.-HV voltage measurement error,not active,
IDE09904-MAS00799,Airbag: H-V activ. restriction-Airbag control module,not active,
IDE09904-MAS02246,Airbag: H-V activ. restriction-Timeout,not active,
IDE09904-MAS09519,Airbag: H-V activ. restriction-Message error,not active,
IDE09904-MAS09521,Airbag: H-V activ. restriction-Light accident detected,not active,
IDE09904-MAS09522,Airbag: H-V activ. restriction-Severe accident detected,not active,
IDE09905-IDE08968,H-V activ. restriction-HV charge management,not active,
IDE09905-IDE16541,H-V activ. restriction-High-voltage charge booster: high-voltage activation prohibitions,not active,
IDE09905-MAS00799,H-V activ. restriction-Airbag control module,not active,
IDE09905-MAS08044,H-V activ. restriction-Thermal management,not active,
IDE09905-MAS09516,H-V activ. restriction-Engine Electronics,not active,
IDE09905-MAS09523,H-V activ. restriction-Transformer for electrical drive,not active,
IDE09905-MAS09524,H-V activ. restriction-Hybrid Battery Management,not active,
IDE09905-MAS09525,H-V activ. restriction-Control module for wireless charging,not active,
IDE09905-MAS09526,H-V activ. restriction-High-voltage battery charger,not active,
IDE09905-MAS09555,H-V activ. restriction-HV activation prohibited due to accident,not active,
IDE09905-MAS09557,H-V activ. restriction-HV activation prohibited due to de-activation,not active,
IDE09905-MAS09558,H-V activ. restriction-HV activation prohibited due to blocking,not active,
IDE09905-MAS12352,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 1,not active,
IDE09905-MAS12353,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 2,not active,
IDE09905-MAS17064,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 3,not active,
IDE09905-MAS17065,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 4,not active,
IDE09905-MAS17066,H-V activ. restriction-HV activation prohibited due to open circuit: wiring circuit 5,not active,
IDE09905-SFT00195,H-V activ. restriction-Electric drive 3,not active,
IDE09905-SFT00206,H-V activ. restriction-Electric drive 2,not active,
IDE09905-SFT33043,H-V activ. restriction-HV battery charging unit 2,not active,
IDE10084-MAS03950,Hybrid drive operating mode-Combustion engine: status,Engine off,
IDE10084-MAS09828,Hybrid drive operating mode-Status of drive readiness hybrid,not active,
IDE10084-MAS09829,Hybrid drive operating mode-Engine start in start-stop mode active,not active,
IDE10084-MAS09830,Hybrid drive operating mode-Engine stop in start-stop mode active,not active,
IDE10084-MAS09831,Hybrid drive operating mode-Engine running or driver readiness at engine stop,not active,
IDE10341-SFT09757,Install. list of subsystems: act. install.-Generator,Not available,
IDE10341-SFT09777,Install. list of subsystems: act. install.-Multifunction steering wheel control module,available.,
IDE10341-SFT09783,Install. list of subsystems: act. install.-Battery Monitoring Control Module,available.,
IDE10341-SFT09833,Install. list of subsystems: act. install.-Inverter for electrical outlet,Not available,
IDE10341-SFT09960,Install. list of subsystems: act. install.-Starter generator,Not available,
IDE10341-SFT10046,Install. list of subsystems: act. install.-Steering Wheel Touch Recognition Control Module,available.,
IDE10342-IDE02068,Standard - ambient data 1: status-Time stamp,Up-to-date,
IDE10342-MAS00711,Standard - ambient data 1: status-Odometer reading,Up-to-date,
IDE10365-MAS10445,Message mirroring: bus allocation-Data bus CAN 1,Comfort data bus,
IDE10365-MAS10446,Message mirroring: bus allocation-Data bus CAN 2,Instrument cluster data bus,
IDE10365-MAS10447,Message mirroring: bus allocation-Data bus CAN 3,Data bus Sensor/Hybrid,
IDE10365-MAS10448,Message mirroring: bus allocation-Data bus CAN 4,Infotainment data bus,
IDE10365-MAS10449,Message mirroring: bus allocation-Data bus CAN 5,Extended data bus,
IDE10365-MAS10450,Message mirroring: bus allocation-Data bus CAN 6,Data bus diagnostics,
IDE10365-MAS11107,Message mirroring: bus allocation-Data bus CAN 7,Comfort CAN bus 2,
IDE10365-MAS17841,Message mirroring: bus allocation-Data bus CAN 8,Data bus connect,
IDE10505,History data 45,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE10506,History data 46,000*2000-01-01-00:00*0*000*+0000*00.00*000.00*00.00*00.00*00.00*00.00*0000.00*00000**,
IDE10510-MAS00106,History data 50-Year,2021,
IDE10510-MAS00107,History data 50-Month,2,
IDE10510-MAS00108,History data 50-Day,9,
IDE10510-MAS00109,History data 50-Hours,18, H
IDE10510-MAS00110,History data 50-Minutes,46, min
IDE10510-MAS01632,History data 50-Status,activated,
IDE10510-ENG05061,History data 50-Activation_Bus_Knock_Out,activated,
IDE10510-ENG05062,History data 50-Activation_Cluster_Sleep,activated,
IDE10510-ENG05063,History data 50-Activation_Cluster_Start,activated,
IDE10510-ENG05064,History data 50-Activation_FUNC_Monitoring,activated,
IDE10510-ENG05058,History data 50-Activation_Keeping_Awake,activated,
IDE10510-ENG05059,History data 50-Activation_Logical_Wakeup,activated,
IDE10510-ENG05060,History data 50-Activation_Physical_Wakeup,activated,
IDE10510-ENG05065,History data 50-Activation_Subbus_Monitoring,activated,
IDE10510-ENG06839,History data 50-Aktivitaetsstatus_Busaktivitaet,activated,
IDE10510-ENG118680,History data 50-Cycle_Counter,160,
IDE10510-ENG06840,History data 50-Status_Activation_Car_Wake_Up,activated,
IDE10510-ENG118681,History data 50-Time_Since_Clamp_15_Off,0.00, H
IDE10510-ENG05057,History data 50-Total_Cycle_Counter,203,
IDE10511-MAS03174,History data 51-Comfort data bus,0.40, H
IDE10511-MAS03175,History data 51-Extended data bus,0.00, H
IDE10511-MAS03177,History data 51-Infotainment data bus,173.50, H
IDE10511-MAS03179,History data 51-Local data bus 2,0.00, H
IDE10511-MAS03180,History data 51-Local data bus,0.00, H
IDE10511-MAS03181,History data 51-Flexray databus,173.10, H
IDE10511-MAS05686,History data 51-Data bus diagnostics,0.00, H
IDE10511-MAS05972,History data 51-Local data bus 3,0.00, H
IDE10511-MAS07380,History data 51-Data bus Sensor/Hybrid,0.00, H
IDE10511-MAS10036,History data 51-Data bus diagnosis 2,173.10, H
IDE10511-MAS12183,History data 51-Comfort CAN bus 2,0.40, H
IDE10511-MAS14086,History data 51-Instrument cluster data bus,0.00, H
IDE10511-MAS16912,History data 51-VLAN_FAS,0.00, H
IDE10511-MAS16913,History data 51-VLAN_Infotainment,1.00, H
IDE10511-MAS16915,History data 51-VLAN_Komfort,0.00, H
IDE10511-MAS17153,History data 51-Data bus connect,2.50, H
IDE10511-MAS18934,History data 51-VLAN_Connect,2.30, H
IDE10511-MAS18935,History data 51-VLAN_Gateway,173.50, H
IDE10511-MAS18936,History data 51-VLAN_Internet,1.00, H
IDE10511-MAS20669,History data 51-VLAN_Remote_FC,0.00, H
IDE10511-MAS22338,History data 51-VLAN Connect 3,0.00, H
IDE10511-ENG118679,History data 51-Total_Bus_Active,173.70, H
IDE10512-MAS03174,History data 52-Comfort data bus,1375,
IDE10512-MAS03175,History data 52-Extended data bus,16,
IDE10512-MAS03177,History data 52-Infotainment data bus,1016,
IDE10512-MAS03179,History data 52-Local data bus 2,0,
IDE10512-MAS03180,History data 52-Local data bus,0,
IDE10512-MAS03181,History data 52-Flexray databus,88,
IDE10512-MAS05686,History data 52-Data bus diagnostics,0,
IDE10512-MAS05972,History data 52-Local data bus 3,0,
IDE10512-MAS07380,History data 52-Data bus Sensor/Hybrid,3352,
IDE10512-MAS10036,History data 52-Data bus diagnosis 2,0,
IDE10512-MAS12183,History data 52-Comfort CAN bus 2,481,
IDE10512-MAS14086,History data 52-Instrument cluster data bus,25,
IDE10512-MAS16912,History data 52-VLAN_FAS,558,
IDE10512-MAS16913,History data 52-VLAN_Infotainment,74,
IDE10512-MAS16915,History data 52-VLAN_Komfort,0,
IDE10512-MAS17153,History data 52-Data bus connect,3,
IDE10512-MAS18934,History data 52-VLAN_Connect,2075,
IDE10512-MAS18935,History data 52-VLAN_Gateway,0,
IDE10512-MAS18936,History data 52-VLAN_Internet,2169,
IDE10512-MAS20669,History data 52-VLAN_Remote_FC,0,
IDE10512-MAS22338,History data 52-VLAN Connect 3,0,
IDE10513-MAS03174,History data 53-Comfort data bus,458,
IDE10513-MAS03175,History data 53-Extended data bus,32,
IDE10513-MAS03177,History data 53-Infotainment data bus,55,
IDE10513-MAS03179,History data 53-Local data bus 2,2,
IDE10513-MAS03180,History data 53-Local data bus,0,
IDE10513-MAS03181,History data 53-Flexray databus,63,
IDE10513-MAS05686,History data 53-Data bus diagnostics,82,
IDE10513-MAS05972,History data 53-Local data bus 3,0,
IDE10513-MAS07380,History data 53-Data bus Sensor/Hybrid,10,
IDE10513-MAS10036,History data 53-Data bus diagnosis 2,63,
IDE10513-MAS12183,History data 53-Comfort CAN bus 2,336,
IDE10513-MAS14086,History data 53-Instrument cluster data bus,1624,
IDE10513-MAS16912,History data 53-VLAN_FAS,51,
IDE10513-MAS16913,History data 53-VLAN_Infotainment,12,
IDE10513-MAS16915,History data 53-VLAN_Komfort,34,
IDE10513-MAS17153,History data 53-Data bus connect,40,
IDE10513-MAS18934,History data 53-VLAN_Connect,53,
IDE10513-MAS18935,History data 53-VLAN_Gateway,53,
IDE10513-MAS18936,History data 53-VLAN_Internet,73,
IDE10513-MAS20669,History data 53-VLAN_Remote_FC,0,
IDE10513-MAS22338,History data 53-VLAN Connect 3,0,
IDE10514-MAS03174,History data 54-Comfort data bus,1868,
IDE10514-MAS03175,History data 54-Extended data bus,0,
IDE10514-MAS03177,History data 54-Infotainment data bus,0,
IDE10514-MAS03179,History data 54-Local data bus 2,0,
IDE10514-MAS03180,History data 54-Local data bus,0,
IDE10514-MAS03181,History data 54-Flexray databus,0,
IDE10514-MAS05686,History data 54-Data bus diagnostics,0,
IDE10514-MAS05972,History data 54-Local data bus 3,0,
IDE10514-MAS07380,History data 54-Data bus Sensor/Hybrid,1679,
IDE10514-MAS10036,History data 54-Data bus diagnosis 2,0,
IDE10514-MAS12183,History data 54-Comfort CAN bus 2,571,
IDE10514-MAS14086,History data 54-Instrument cluster data bus,1549,
IDE10514-MAS16912,History data 54-VLAN_FAS,0,
IDE10514-MAS16913,History data 54-VLAN_Infotainment,0,
IDE10514-MAS16915,History data 54-VLAN_Komfort,0,
IDE10514-MAS17153,History data 54-Data bus connect,0,
IDE10514-MAS18934,History data 54-VLAN_Connect,0,
IDE10514-MAS18935,History data 54-VLAN_Gateway,0,
IDE10514-MAS18936,History data 54-VLAN_Internet,0,
IDE10514-MAS20669,History data 54-VLAN_Remote_FC,0,
IDE10514-MAS22338,History data 54-VLAN Connect 3,0,
IDE10515-MAS03174,History data 55-Comfort data bus,0,
IDE10515-MAS03175,History data 55-Extended data bus,66,
IDE10515-MAS03177,History data 55-Infotainment data bus,0,
IDE10515-MAS03179,History data 55-Local data bus 2,0,
IDE10515-MAS03180,History data 55-Local data bus,0,
IDE10515-MAS03181,History data 55-Flexray databus,19,
IDE10515-MAS05686,History data 55-Data bus diagnostics,0,
IDE10515-MAS05972,History data 55-Local data bus 3,0,
IDE10515-MAS07380,History data 55-Data bus Sensor/Hybrid,33,
IDE10515-MAS10036,History data 55-Data bus diagnosis 2,0,
IDE10515-MAS12183,History data 55-Comfort CAN bus 2,0,
IDE10515-MAS14086,History data 55-Instrument cluster data bus,25,
IDE10515-MAS16912,History data 55-VLAN_FAS,0,
IDE10515-MAS16913,History data 55-VLAN_Infotainment,0,
IDE10515-MAS16915,History data 55-VLAN_Komfort,0,
IDE10515-MAS17153,History data 55-Data bus connect,0,
IDE10515-MAS18934,History data 55-VLAN_Connect,0,
IDE10515-MAS18935,History data 55-VLAN_Gateway,0,
IDE10515-MAS18936,History data 55-VLAN_Internet,0,
IDE10515-MAS20669,History data 55-VLAN_Remote_FC,0,
IDE10515-MAS22338,History data 55-VLAN Connect 3,0,
IDE10516-ENG05046,History data 56-Cluster_1_Start_Error_Counter,3507,
IDE10516-ENG30616,History data 56-Cluster_10_Counter,179,
IDE10516-ENG30617,History data 56-Cluster_10_Sleep_Error_Counter,0,
IDE10516-ENG30618,History data 56-Cluster_10_Start_Error_Counter,0,
IDE10516-ENG115136,History data 56-Cluster_11_Counter,1314,
IDE10516-ENG114934,History data 56-Cluster_11_Sleep_Error_Counter,0,
IDE10516-ENG115145,History data 56-Cluster_11_Start_Error_Counter,0,
IDE10516-ENG114928,History data 56-Cluster_12_Counter,1314,
IDE10516-ENG115123,History data 56-Cluster_12_Sleep_Error_Counter,0,
IDE10516-ENG115108,History data 56-Cluster_12_Start_Error_Counter,0,
IDE10516-ENG114947,History data 56-Cluster_13_Counter,1314,
IDE10516-ENG114959,History data 56-Cluster_13_Sleep_Error_Counter,0,
IDE10516-ENG115194,History data 56-Cluster_13_Start_Error_Counter,0,
IDE10516-ENG115200,History data 56-Cluster_14_Counter,1314,
IDE10516-ENG115069,History data 56-Cluster_14_Sleep_Error_Counter,0,
IDE10516-ENG115061,History data 56-Cluster_14_Start_Error_Counter,0,
IDE10516-ENG115196,History data 56-Cluster_15_Counter,1314,
IDE10516-ENG114963,History data 56-Cluster_15_Sleep_Error_Counter,0,
IDE10516-ENG115117,History data 56-Cluster_15_Start_Error_Counter,0,
IDE10516-ENG115075,History data 56-Cluster_16_Counter,1314,
IDE10516-ENG115066,History data 56-Cluster_16_Sleep_Error_Counter,0,
IDE10516-ENG115209,History data 56-Cluster_16_Start_Error_Counter,0,
IDE10516-ENG115168,History data 56-Cluster_17_Counter,1314,
IDE10516-ENG115078,History data 56-Cluster_17_Sleep_Error_Counter,0,
IDE10516-ENG115049,History data 56-Cluster_17_Start_Error_Counter,0,
IDE10516-ENG115202,History data 56-Cluster_18_Counter,1314,
IDE10516-ENG115182,History data 56-Cluster_18_Sleep_Error_Counter,0,
IDE10516-ENG115181,History data 56-Cluster_18_Start_Error_Counter,0,
IDE10516-ENG115148,History data 56-Cluster_19_Counter,1134,
IDE10516-ENG115081,History data 56-Cluster_19_Sleep_Error_Counter,0,
IDE10516-ENG114961,History data 56-Cluster_19_Start_Error_Counter,0,
IDE10516-ENG05047,History data 56-Cluster_2_Sleep_Error_Counter,0,
IDE10516-ENG115191,History data 56-Cluster_20_Counter,1110,
IDE10516-ENG114944,History data 56-Cluster_20_Sleep_Error_Counter,0,
IDE10516-ENG115156,History data 56-Cluster_20_Start_Error_Counter,0,
IDE10516-ENG115175,History data 56-Cluster_21_Counter,503,
IDE10516-ENG115208,History data 56-Cluster_21_Sleep_Error_Counter,0,
IDE10516-ENG115043,History data 56-Cluster_21_Start_Error_Counter,0,
IDE10516-ENG115023,History data 56-Cluster_22_Counter,630,
IDE10516-ENG115076,History data 56-Cluster_22_Sleep_Error_Counter,0,
IDE10516-ENG115151,History data 56-Cluster_22_Start_Error_Counter,0,
IDE10516-ENG115133,History data 56-Cluster_23_Counter,550,
IDE10516-ENG115042,History data 56-Cluster_23_Sleep_Error_Counter,0,
IDE10516-ENG115135,History data 56-Cluster_23_Start_Error_Counter,0,
IDE10516-ENG115019,History data 56-Cluster_24_Counter,1110,
IDE10516-ENG115080,History data 56-Cluster_24_Sleep_Error_Counter,0,
IDE10516-ENG115055,History data 56-Cluster_24_Start_Error_Counter,0,
IDE10516-ENG05048,History data 56-Cluster_3_Counter,920,
IDE10516-ENG05050,History data 56-Cluster_3_Sleep_Error_Counter,0,
IDE10516-ENG05049,History data 56-Cluster_3_Start_Error_Counter,926,
IDE10516-ENG05051,History data 56-Cluster_4_Counter,1987,
IDE10516-ENG05053,History data 56-Cluster_4_Sleep_Error_Counter,0,
IDE10516-ENG05052,History data 56-Cluster_4_Start_Error_Counter,11371,
IDE10516-ENG05054,History data 56-Cluster_5_Counter,2231,
IDE10516-ENG05056,History data 56-Cluster_5_Sleep_Error_Counter,0,
IDE10516-ENG05055,History data 56-Cluster_5_Start_Error_Counter,3782,
IDE10516-ENG30619,History data 56-Cluster_6_Counter,3590,
IDE10516-ENG30620,History data 56-Cluster_6_Sleep_Error_Counter,0,
IDE10516-ENG30621,History data 56-Cluster_6_Start_Error_Counter,0,
IDE10516-ENG30622,History data 56-Cluster_7_Counter,1337,
IDE10516-ENG30623,History data 56-Cluster_7_Sleep_Error_Counter,0,
IDE10516-ENG30624,History data 56-Cluster_7_Start_Error_Counter,0,
IDE10516-ENG30625,History data 56-Cluster_8_Counter,1876,
IDE10516-ENG30626,History data 56-Cluster_8_Sleep_Error_Counter,0,
IDE10516-ENG30627,History data 56-Cluster_8_Start_Error_Counter,0,
IDE10516-ENG30628,History data 56-Cluster_9_Counter,1197,
IDE10516-ENG30629,History data 56-Cluster_9_Sleep_Error_Counter,0,
IDE10516-ENG30630,History data 56-Cluster_9_Start_Error_Counter,0,
IDE10516-ENG05045,History data 56-Cluster_Sleep_1_Error_Counter,0,
IDE10516-ENG05043,History data 56-Cluster_Start_1_Counter,534,
IDE10516-ENG05044,History data 56-Cluster_Start_1_Error_Counter,1019,
IDE10516-ENG06838,History data 56-Cluster_Start_2_Counter,3391,
IDE10517-MAS00106,History data 57-Year,2021, yr
IDE10517-MAS00107,History data 57-Month,5, m
IDE10517-MAS00108,History data 57-Day,16, d
IDE10517-MAS00109,History data 57-Hours,11, H
IDE10517-MAS00110,History data 57-Minutes,47, min
IDE10517-ENG20570,History data 57-Bus_1,Unknown (0),
IDE10517-ENG20572,History data 57-Bus_2,Unknown (0),
IDE10517-ENG20574,History data 57-Bus_3,Unknown (0),
IDE10517-ENG20576,History data 57-Bus_4,Unknown (0),
IDE10517-ENG20578,History data 57-Bus_5,Unknown (0),
IDE10517-ENG20571,History data 57-Bus_Active_Time_1,0.00, H
IDE10517-ENG20573,History data 57-Bus_Active_Time_2,0.00, H
IDE10517-ENG20575,History data 57-Bus_Active_Time_3,0.00, H
IDE10517-ENG20577,History data 57-Bus_Active_Time_4,0.00, H
IDE10517-ENG20579,History data 57-Bus_Active_Time_5,0.00, H
IDE10517-ENG118680,History data 57-Cycle_Counter,159,
IDE10517-ENG118681,History data 57-Time_Since_Clamp_15_Off,0.00, H
IDE10518-ENG28832,History data 58-Awake_Time_ECU_1,0.00, H
IDE10518-ENG28835,History data 58-Awake_Time_ECU_2,0.00, H
IDE10518-ENG28838,History data 58-Awake_Time_ECU_3,0.00, H
IDE10518-ENG28841,History data 58-Awake_Time_ECU_4,0.00, H
IDE10518-ENG28844,History data 58-Awake_Time_ECU_5,0.00, H
IDE10518-ENG28833,History data 58-Bus_ECU_1,0,
IDE10518-ENG28836,History data 58-Bus_ECU_2,0,
IDE10518-ENG28839,History data 58-Bus_ECU_3,0,
IDE10518-ENG28842,History data 58-Bus_ECU_4,0,
IDE10518-ENG28845,History data 58-Bus_ECU_5,0,
IDE10518-ENG28834,History data 58-Cluster_ECU_1,00 00 00,
IDE10518-ENG28837,History data 58-Cluster_ECU_2,00 00 00,
IDE10518-ENG28840,History data 58-Cluster_ECU_3,00 00 00,
IDE10518-ENG28843,History data 58-Cluster_ECU_4,00 00 00,
IDE10518-ENG28846,History data 58-Cluster_ECU_5,00 00 00,
IDE10518-ENG118680,History data 58-Cycle_Counter,159,
IDE10518-ENG106038,History data 58-ECU_1,0,
IDE10518-ENG106039,History data 58-ECU_2,0,
IDE10518-ENG28620,History data 58-ECU_3,0,
IDE10518-ENG106040,History data 58-ECU_4,0,
IDE10518-ENG106041,History data 58-ECU_5,0,
IDE10518-ENG28618,History data 58-Repeat_Counter_ECU_1,0,
IDE10518-ENG28619,History data 58-Repeat_Counter_ECU_2,0,
IDE10518-ENG28621,History data 58-Repeat_Counter_ECU_3,0,
IDE10518-ENG28622,History data 58-Repeat_Counter_ECU_4,0.00,
IDE10518-ENG28623,History data 58-Repeat_Counter_ECU_5,0,
IDE10519-ENG28833,History data 59-Bus_ECU_1,29,
IDE10519-ENG28836,History data 59-Bus_ECU_2,25,
IDE10519-ENG28839,History data 59-Bus_ECU_3,15,
IDE10519-ENG28842,History data 59-Bus_ECU_4,15,
IDE10519-ENG28845,History data 59-Bus_ECU_5,28,
IDE10519-ENG28834,History data 59-Cluster_ECU_1,00 00 00,
IDE10519-ENG28837,History data 59-Cluster_ECU_2,00 00 00,
IDE10519-ENG28840,History data 59-Cluster_ECU_3,00 00 00,
IDE10519-ENG28843,History data 59-Cluster_ECU_4,00 00 00,
IDE10519-ENG28846,History data 59-Cluster_ECU_5,00 00 00,
IDE10519-ENG118680,History data 59-Cycle_Counter,159,
IDE10519-ENG106038,History data 59-ECU_1,241,
IDE10519-ENG106039,History data 59-ECU_2,14,
IDE10519-ENG28620,History data 59-ECU_3,49,
IDE10519-ENG106040,History data 59-ECU_4,74,
IDE10519-ENG106041,History data 59-ECU_5,103,
IDE10519-ENG28847,History data 59-Logical_Wakeup_ECU_1,2,
IDE10519-ENG28848,History data 59-Logical_Wakeup_ECU_2,1,
IDE10519-ENG28849,History data 59-Logical_Wakeup_ECU_3,1,
IDE10519-ENG28850,History data 59-Logical_Wakeup_ECU_4,1,
IDE10519-ENG28851,History data 59-Logical_Wakeup_ECU_5,1,
IDE10520-ENG28833,History data 60-Bus_ECU_1,15,
IDE10520-ENG28836,History data 60-Bus_ECU_2,31,
IDE10520-ENG28839,History data 60-Bus_ECU_3,0,
IDE10520-ENG28842,History data 60-Bus_ECU_4,0,
IDE10520-ENG28845,History data 60-Bus_ECU_5,0,
IDE10520-ENG28834,History data 60-Cluster_ECU_1,00 00 28,
IDE10520-ENG28837,History data 60-Cluster_ECU_2,00 00 00,
IDE10520-ENG28840,History data 60-Cluster_ECU_3,00 00 00,
IDE10520-ENG28843,History data 60-Cluster_ECU_4,00 00 00,
IDE10520-ENG28846,History data 60-Cluster_ECU_5,00 00 00,
IDE10520-ENG118680,History data 60-Cycle_Counter,159,
IDE10520-ENG106038,History data 60-ECU_1,139,
IDE10520-ENG106039,History data 60-ECU_2,255,
IDE10520-ENG28620,History data 60-ECU_3,0,
IDE10520-ENG106040,History data 60-ECU_4,0,
IDE10520-ENG106041,History data 60-ECU_5,0,
IDE10520-ENG28852,History data 60-Physical_Wakeup_ECU_1,2,
IDE10520-ENG28853,History data 60-Physical_Wakeup_ECU_2,1,
IDE10520-ENG28854,History data 60-Physical_Wakeup_ECU_3,0,
IDE10520-ENG28855,History data 60-Physical_Wakeup_ECU_4,0,
IDE10520-ENG28856,History data 60-Physical_Wakeup_ECU_5,0,
IDE10521-ENG28833,History data 61-Bus_ECU_1,0,
IDE10521-ENG28836,History data 61-Bus_ECU_2,0,
IDE10521-ENG28839,History data 61-Bus_ECU_3,0,
IDE10521-ENG28842,History data 61-Bus_ECU_4,0,
IDE10521-ENG28845,History data 61-Bus_ECU_5,0,
IDE10521-ENG28857,History data 61-Bus_Knock_Out_ECU_1,0,
IDE10521-ENG30432,History data 61-Bus_Knock_Out_ECU_2,0,
IDE10521-ENG28858,History data 61-Bus_Knock_Out_ECU_3,0,
IDE10521-ENG28859,History data 61-Bus_Knock_Out_ECU_4,0,
IDE10521-ENG28860,History data 61-Bus_Knock_Out_ECU_5,0,
IDE10521-ENG118680,History data 61-Cycle_Counter,159,
IDE10521-ENG106038,History data 61-ECU_1,0,
IDE10521-ENG106039,History data 61-ECU_2,0,
IDE10521-ENG28620,History data 61-ECU_3,0,
IDE10521-ENG106040,History data 61-ECU_4,0,
IDE10521-ENG106041,History data 61-ECU_5,0,
IDE10522-ENG28833,History data 62-Bus_ECU_1,25,
IDE10522-ENG28836,History data 62-Bus_ECU_2,16,
IDE10522-ENG28839,History data 62-Bus_ECU_3,15,
IDE10522-ENG28842,History data 62-Bus_ECU_4,15,
IDE10522-ENG28845,History data 62-Bus_ECU_5,15,
IDE10522-ENG28861,History data 62-Car_Wake_Up_Counter_ECU_1,3,
IDE10522-ENG28863,History data 62-Car_Wake_Up_Counter_ECU_2,2,
IDE10522-ENG28865,History data 62-Car_Wake_Up_Counter_ECU_3,2,
IDE10522-ENG28867,History data 62-Car_Wake_Up_Counter_ECU_4,1,
IDE10522-ENG28869,History data 62-Car_Wake_Up_Counter_ECU_5,1,
IDE10522-ENG28862,History data 62-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10522-ENG28864,History data 62-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10522-ENG28866,History data 62-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10522-ENG28868,History data 62-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10522-ENG28870,History data 62-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10522-ENG118680,History data 62-Cycle_Counter,159,
IDE10522-ENG106038,History data 62-ECU_1,14,
IDE10522-ENG106039,History data 62-ECU_2,68,
IDE10522-ENG28620,History data 62-ECU_3,74,
IDE10522-ENG106040,History data 62-ECU_4,49,
IDE10522-ENG106041,History data 62-ECU_5,76,
IDE10523-ENG28833,History data 63-Bus_ECU_1,15,
IDE10523-ENG28836,History data 63-Bus_ECU_2,28,
IDE10523-ENG28839,History data 63-Bus_ECU_3,32,
IDE10523-ENG28842,History data 63-Bus_ECU_4,25,
IDE10523-ENG28845,History data 63-Bus_ECU_5,29,
IDE10523-ENG28871,History data 63-Cluster_Sleep_ECU_1,3,
IDE10523-ENG28872,History data 63-Cluster_Sleep_ECU_2,3,
IDE10523-ENG28873,History data 63-Cluster_Sleep_ECU_3,3,
IDE10523-ENG28874,History data 63-Cluster_Sleep_ECU_4,2,
IDE10523-ENG28875,History data 63-Cluster_Sleep_ECU_5,1,
IDE10523-ENG118680,History data 63-Cycle_Counter,159,
IDE10523-ENG106038,History data 63-ECU_1,74,
IDE10523-ENG106039,History data 63-ECU_2,103,
IDE10523-ENG28620,History data 63-ECU_3,246,
IDE10523-ENG106040,History data 63-ECU_4,14,
IDE10523-ENG106041,History data 63-ECU_5,241,
IDE10524-ENG28833,History data 64-Bus_ECU_1,15,
IDE10524-ENG28836,History data 64-Bus_ECU_2,15,
IDE10524-ENG28839,History data 64-Bus_ECU_3,3908,
IDE10524-ENG28842,History data 64-Bus_ECU_4,75,
IDE10524-ENG28845,History data 64-Bus_ECU_5,158,
IDE10524-ENG28876,History data 64-Cluster_1_Start,0,
IDE10524-ENG28877,History data 64-Cluster_2_Start,0,
IDE10524-ENG28878,History data 64-Cluster_3_Start,0,
IDE10524-ENG28879,History data 64-Cluster_4_Start,0,
IDE10524-ENG28880,History data 64-Cluster_5_Start,0,
IDE10524-ENG28881,History data 64-Cluster_Start_ECU_1,8,
IDE10524-ENG28882,History data 64-Cluster_Start_ECU_2,3,
IDE10524-ENG28883,History data 64-Cluster_Start_ECU_3,3,
IDE10524-ENG28884,History data 64-Cluster_Start_ECU_4,528,
IDE10524-ENG28885,History data 64-Cluster_Start_ECU_5,527,
IDE10524-ENG118680,History data 64-Cycle_Counter,159,
IDE10524-ENG106038,History data 64-ECU_1,76,
IDE10524-ENG106039,History data 64-ECU_2,35,
IDE10524-ENG28620,History data 64-ECU_3,132,
IDE10524-ENG106040,History data 64-ECU_4,0,
IDE10524-ENG106041,History data 64-ECU_5,0,
IDE10525-ENG28887,History data 65-Awake_Time_FUNC_1,0.00, H
IDE10525-ENG28890,History data 65-Awake_Time_FUNC_2,0.00, H
IDE10525-ENG28893,History data 65-Awake_Time_FUNC_3,0.00, H
IDE10525-ENG28896,History data 65-Awake_Time_FUNC_4,0.00, H
IDE10525-ENG28899,History data 65-Awake_Time_FUNC_5,0.00, H
IDE10525-ENG118680,History data 65-Cycle_Counter,159,
IDE10525-ENG28886,History data 65-FUNC_1,2,
IDE10525-ENG28889,History data 65-FUNC_2,17,
IDE10525-ENG28892,History data 65-FUNC_3,19,
IDE10525-ENG28895,History data 65-FUNC_4,25,
IDE10525-ENG28898,History data 65-FUNC_5,7,
IDE10525-ENG28888,History data 65-Physical_Wakeup_FUNC_1,2,
IDE10525-ENG28891,History data 65-Physical_Wakeup_FUNC_2,2,
IDE10525-ENG28894,History data 65-Physical_Wakeup_FUNC_3,2,
IDE10525-ENG28897,History data 65-Physical_Wakeup_FUNC_4,2,
IDE10525-ENG28900,History data 65-Physical_Wakeup_FUNC_5,1,
IDE10526-MAS00106,History data 66-Year,2021,
IDE10526-MAS00107,History data 66-Month,4,
IDE10526-MAS00108,History data 66-Day,30,
IDE10526-MAS00109,History data 66-Hours,4, H
IDE10526-MAS00110,History data 66-Minutes,46, min
IDE10526-ENG28832,History data 66-Awake_Time_ECU_1,0.30, H
IDE10526-ENG28835,History data 66-Awake_Time_ECU_2,0.00, H
IDE10526-ENG28838,History data 66-Awake_Time_ECU_3,0.00, H
IDE10526-ENG28841,History data 66-Awake_Time_ECU_4,0.00, H
IDE10526-ENG28844,History data 66-Awake_Time_ECU_5,0.00, H
IDE10526-ENG28833,History data 66-Bus_ECU_1,28,
IDE10526-ENG28836,History data 66-Bus_ECU_2,0,
IDE10526-ENG28839,History data 66-Bus_ECU_3,0,
IDE10526-ENG28842,History data 66-Bus_ECU_4,0,
IDE10526-ENG28845,History data 66-Bus_ECU_5,0,
IDE10526-ENG28834,History data 66-Cluster_ECU_1,00 00 00,
IDE10526-ENG28837,History data 66-Cluster_ECU_2,00 00 00,
IDE10526-ENG28840,History data 66-Cluster_ECU_3,00 00 00,
IDE10526-ENG28843,History data 66-Cluster_ECU_4,00 00 00,
IDE10526-ENG28846,History data 66-Cluster_ECU_5,00 00 00,
IDE10526-ENG118680,History data 66-Cycle_Counter,111,
IDE10526-ENG106038,History data 66-ECU_1,103,
IDE10526-ENG106039,History data 66-ECU_2,0,
IDE10526-ENG28620,History data 66-ECU_3,0,
IDE10526-ENG106040,History data 66-ECU_4,0,
IDE10526-ENG106041,History data 66-ECU_5,0,
IDE10526-ENG28618,History data 66-Repeat_Counter_ECU_1,0,
IDE10526-ENG28619,History data 66-Repeat_Counter_ECU_2,0,
IDE10526-ENG28621,History data 66-Repeat_Counter_ECU_3,0,
IDE10526-ENG28622,History data 66-Repeat_Counter_ECU_4,0,
IDE10526-ENG28623,History data 66-Repeat_Counter_ECU_5,0,
IDE10526-ENG118681,History data 66-Time_Since_Clamp_15_Off,32.60, H
IDE10527-MAS00106,History data 67-Year,2021,
IDE10527-MAS00107,History data 67-Month,5,
IDE10527-MAS00108,History data 67-Day,12,
IDE10527-MAS00109,History data 67-Hours,14, H
IDE10527-MAS00110,History data 67-Minutes,30, min
IDE10527-ENG28833,History data 67-Bus_ECU_1,28,
IDE10527-ENG28836,History data 67-Bus_ECU_2,18,
IDE10527-ENG28839,History data 67-Bus_ECU_3,0,
IDE10527-ENG28842,History data 67-Bus_ECU_4,0,
IDE10527-ENG28845,History data 67-Bus_ECU_5,0,
IDE10527-ENG28834,History data 67-Cluster_ECU_1,00 00 00,
IDE10527-ENG28837,History data 67-Cluster_ECU_2,00 00 02,
IDE10527-ENG28840,History data 67-Cluster_ECU_3,00 00 00,
IDE10527-ENG28843,History data 67-Cluster_ECU_4,00 00 00,
IDE10527-ENG28846,History data 67-Cluster_ECU_5,00 00 00,
IDE10527-ENG118680,History data 67-Cycle_Counter,149,
IDE10527-ENG106038,History data 67-ECU_1,103,
IDE10527-ENG106039,History data 67-ECU_2,115,
IDE10527-ENG28620,History data 67-ECU_3,0,
IDE10527-ENG106040,History data 67-ECU_4,0,
IDE10527-ENG106041,History data 67-ECU_5,0,
IDE10527-ENG28847,History data 67-Logical_Wakeup_ECU_1,255,
IDE10527-ENG28848,History data 67-Logical_Wakeup_ECU_2,89,
IDE10527-ENG28849,History data 67-Logical_Wakeup_ECU_3,0,
IDE10527-ENG28850,History data 67-Logical_Wakeup_ECU_4,0,
IDE10527-ENG28851,History data 67-Logical_Wakeup_ECU_5,0,
IDE10527-ENG118681,History data 67-Time_Since_Clamp_15_Off,0.80, H
IDE10528-MAS00106,History data 68-Year,2021,
IDE10528-MAS00107,History data 68-Month,5,
IDE10528-MAS00108,History data 68-Day,12,
IDE10528-MAS00109,History data 68-Hours,14, H
IDE10528-MAS00110,History data 68-Minutes,30, min
IDE10528-ENG28833,History data 68-Bus_ECU_1,26,
IDE10528-ENG28836,History data 68-Bus_ECU_2,32,
IDE10528-ENG28839,History data 68-Bus_ECU_3,0,
IDE10528-ENG28842,History data 68-Bus_ECU_4,0,
IDE10528-ENG28845,History data 68-Bus_ECU_5,0,
IDE10528-ENG28834,History data 68-Cluster_ECU_1,00 01 00,
IDE10528-ENG28837,History data 68-Cluster_ECU_2,00 00 00,
IDE10528-ENG28840,History data 68-Cluster_ECU_3,00 00 00,
IDE10528-ENG28843,History data 68-Cluster_ECU_4,00 00 00,
IDE10528-ENG28846,History data 68-Cluster_ECU_5,00 00 00,
IDE10528-ENG118680,History data 68-Cycle_Counter,149,
IDE10528-ENG106038,History data 68-ECU_1,20,
IDE10528-ENG106039,History data 68-ECU_2,255,
IDE10528-ENG28620,History data 68-ECU_3,0,
IDE10528-ENG106040,History data 68-ECU_4,0,
IDE10528-ENG106041,History data 68-ECU_5,0,
IDE10528-ENG28852,History data 68-Physical_Wakeup_ECU_1,255,
IDE10528-ENG28853,History data 68-Physical_Wakeup_ECU_2,14,
IDE10528-ENG28854,History data 68-Physical_Wakeup_ECU_3,0,
IDE10528-ENG28855,History data 68-Physical_Wakeup_ECU_4,0,
IDE10528-ENG28856,History data 68-Physical_Wakeup_ECU_5,0,
IDE10528-ENG118681,History data 68-Time_Since_Clamp_15_Off,0.80, H
IDE10529-MAS00106,History data 69-Year,2021,
IDE10529-MAS00107,History data 69-Month,5,
IDE10529-MAS00108,History data 69-Day,12,
IDE10529-MAS00109,History data 69-Hours,14, H
IDE10529-MAS00110,History data 69-Minutes,30, min
IDE10529-ENG28833,History data 69-Bus_ECU_1,26,
IDE10529-ENG28836,History data 69-Bus_ECU_2,0,
IDE10529-ENG28839,History data 69-Bus_ECU_3,0,
IDE10529-ENG28842,History data 69-Bus_ECU_4,0,
IDE10529-ENG28845,History data 69-Bus_ECU_5,0,
IDE10529-ENG28857,History data 69-Bus_Knock_Out_ECU_1,5,
IDE10529-ENG30432,History data 69-Bus_Knock_Out_ECU_2,0,
IDE10529-ENG28858,History data 69-Bus_Knock_Out_ECU_3,0,
IDE10529-ENG28859,History data 69-Bus_Knock_Out_ECU_4,0,
IDE10529-ENG28860,History data 69-Bus_Knock_Out_ECU_5,0,
IDE10529-ENG118680,History data 69-Cycle_Counter,149,
IDE10529-ENG106038,History data 69-ECU_1,83,
IDE10529-ENG106039,History data 69-ECU_2,0,
IDE10529-ENG28620,History data 69-ECU_3,0,
IDE10529-ENG106040,History data 69-ECU_4,0,
IDE10529-ENG106041,History data 69-ECU_5,0,
IDE10529-ENG118681,History data 69-Time_Since_Clamp_15_Off,0.80, H
IDE10530-MAS00106,History data 70-Year,2021,
IDE10530-MAS00107,History data 70-Month,5,
IDE10530-MAS00108,History data 70-Day,12,
IDE10530-MAS00109,History data 70-Hours,14, H
IDE10530-MAS00110,History data 70-Minutes,30, min
IDE10530-ENG28833,History data 70-Bus_ECU_1,26,
IDE10530-ENG28836,History data 70-Bus_ECU_2,16,
IDE10530-ENG28839,History data 70-Bus_ECU_3,0,
IDE10530-ENG28842,History data 70-Bus_ECU_4,0,
IDE10530-ENG28845,History data 70-Bus_ECU_5,0,
IDE10530-ENG28861,History data 70-Car_Wake_Up_Counter_ECU_1,255,
IDE10530-ENG28863,History data 70-Car_Wake_Up_Counter_ECU_2,255,
IDE10530-ENG28865,History data 70-Car_Wake_Up_Counter_ECU_3,0,
IDE10530-ENG28867,History data 70-Car_Wake_Up_Counter_ECU_4,0,
IDE10530-ENG28869,History data 70-Car_Wake_Up_Counter_ECU_5,0,
IDE10530-ENG28862,History data 70-Car_Wake_Up_Time_ECU_1,0.00, H
IDE10530-ENG28864,History data 70-Car_Wake_Up_Time_ECU_2,0.00, H
IDE10530-ENG28866,History data 70-Car_Wake_Up_Time_ECU_3,0.00, H
IDE10530-ENG28868,History data 70-Car_Wake_Up_Time_ECU_4,0.00, H
IDE10530-ENG28870,History data 70-Car_Wake_Up_Time_ECU_5,0.00, H
IDE10530-ENG118680,History data 70-Cycle_Counter,149,
IDE10530-ENG106038,History data 70-ECU_1,20,
IDE10530-ENG106039,History data 70-ECU_2,68,
IDE10530-ENG28620,History data 70-ECU_3,0,
IDE10530-ENG106040,History data 70-ECU_4,0,
IDE10530-ENG106041,History data 70-ECU_5,0,
IDE10530-ENG118681,History data 70-Time_Since_Clamp_15_Off,0.80, H
IDE10531-MAS00106,History data 71-Year,2021,
IDE10531-MAS00107,History data 71-Month,5,
IDE10531-MAS00108,History data 71-Day,15,
IDE10531-MAS00109,History data 71-Hours,15, H
IDE10531-MAS00110,History data 71-Minutes,50, min
IDE10531-ENG28833,History data 71-Bus_ECU_1,28,
IDE10531-ENG28836,History data 71-Bus_ECU_2,32,
IDE10531-ENG28839,History data 71-Bus_ECU_3,0,
IDE10531-ENG28842,History data 71-Bus_ECU_4,0,
IDE10531-ENG28845,History data 71-Bus_ECU_5,0,
IDE10531-ENG28871,History data 71-Cluster_Sleep_ECU_1,255,
IDE10531-ENG28872,History data 71-Cluster_Sleep_ECU_2,255,
IDE10531-ENG28873,History data 71-Cluster_Sleep_ECU_3,0,
IDE10531-ENG28874,History data 71-Cluster_Sleep_ECU_4,0,
IDE10531-ENG28875,History data 71-Cluster_Sleep_ECU_5,0,
IDE10531-ENG118680,History data 71-Cycle_Counter,157,
IDE10531-ENG106038,History data 71-ECU_1,103,
IDE10531-ENG106039,History data 71-ECU_2,246,
IDE10531-ENG28620,History data 71-ECU_3,0,
IDE10531-ENG106040,History data 71-ECU_4,0,
IDE10531-ENG106041,History data 71-ECU_5,0,
IDE10531-ENG118681,History data 71-Time_Since_Clamp_15_Off,1.80, H
IDE10532-MAS00106,History data 72-Year,2021,
IDE10532-MAS00107,History data 72-Month,5,
IDE10532-MAS00108,History data 72-Day,12,
IDE10532-MAS00109,History data 72-Hours,14, H
IDE10532-MAS00110,History data 72-Minutes,30, min
IDE10532-ENG28833,History data 72-Bus_ECU_1,16,
IDE10532-ENG28836,History data 72-Bus_ECU_2,15,
IDE10532-ENG28839,History data 72-Bus_ECU_3,0,
IDE10532-ENG28842,History data 72-Bus_ECU_4,0,
IDE10532-ENG28845,History data 72-Bus_ECU_5,0,
IDE10532-ENG28876,History data 72-Cluster_1_Start,0,
IDE10532-ENG28877,History data 72-Cluster_2_Start,0,
IDE10532-ENG28878,History data 72-Cluster_3_Start,0,
IDE10532-ENG28879,History data 72-Cluster_4_Start,0,
IDE10532-ENG28880,History data 72-Cluster_5_Start,0,
IDE10532-ENG28834,History data 72-Cluster_ECU_1,0,
IDE10532-ENG28837,History data 72-Cluster_ECU_2,0,
IDE10532-ENG28840,History data 72-Cluster_ECU_3,0,
IDE10532-ENG28843,History data 72-Cluster_ECU_4,0,
IDE10532-ENG28846,History data 72-Cluster_ECU_5,0,
IDE10532-ENG28881,History data 72-Cluster_Start_ECU_1,255,
IDE10532-ENG28882,History data 72-Cluster_Start_ECU_2,23,
IDE10532-ENG28883,History data 72-Cluster_Start_ECU_3,0,
IDE10532-ENG28884,History data 72-Cluster_Start_ECU_4,0,
IDE10532-ENG28885,History data 72-Cluster_Start_ECU_5,0,
IDE10532-ENG118680,History data 72-Cycle_Counter,149,
IDE10532-ENG106038,History data 72-ECU_1,68,
IDE10532-ENG106039,History data 72-ECU_2,76,
IDE10532-ENG28620,History data 72-ECU_3,0,
IDE10532-ENG106040,History data 72-ECU_4,0,
IDE10532-ENG106041,History data 72-ECU_5,0,
IDE10532-ENG118681,History data 72-Time_Since_Clamp_15_Off,0.80, H
IDE10533-MAS00106,History data 73-Year,2000,
IDE10533-MAS00107,History data 73-Month,1,
IDE10533-MAS00108,History data 73-Day,1,
IDE10533-MAS00109,History data 73-Hours,0, H
IDE10533-MAS00110,History data 73-Minutes,0, min
IDE10533-ENG28907,History data 73-Activetime_MIB,0.00, H
IDE10533-ENG28904,History data 73-Activetime_MOST,0.00, H
IDE10533-ENG28901,History data 73-Activetime_MU,0.00, H
IDE10533-ENG118680,History data 73-Cycle_Counter,0,
IDE10533-ENG28903,History data 73-State_MMI,3,
IDE10533-ENG28906,History data 73-State_MOST,1,
IDE10533-ENG118681,History data 73-Time_Since_Clamp_15_Off,0.00, H
IDE10533-ENG28905,History data 73-WakeUps_MOST,1,
IDE10533-ENG28902,History data 73-WakeUps_MU,1,
IDE10534-MAS00106,History data 74-Year,2021,
IDE10534-MAS00107,History data 74-Month,4,
IDE10534-MAS00108,History data 74-Day,30,
IDE10534-MAS00109,History data 74-Hours,8, H
IDE10534-MAS00110,History data 74-Minutes,24, min
IDE10534-ENG28887,History data 74-Awake_Time_FUNC_1,25.50, H
IDE10534-ENG28890,History data 74-Awake_Time_FUNC_2,25.50, H
IDE10534-ENG28893,History data 74-Awake_Time_FUNC_3,25.50, H
IDE10534-ENG28896,History data 74-Awake_Time_FUNC_4,0.00, H
IDE10534-ENG28899,History data 74-Awake_Time_FUNC_5,0.00, H
IDE10534-ENG118680,History data 74-Cycle_Counter,111,
IDE10534-ENG28886,History data 74-FUNC_1,2,
IDE10534-ENG28889,History data 74-FUNC_2,7,
IDE10534-ENG28892,History data 74-FUNC_3,17,
IDE10534-ENG28895,History data 74-FUNC_4,0,
IDE10534-ENG28898,History data 74-FUNC_5,0,
IDE10534-ENG28888,History data 74-Physical_Wakeup_FUNC_1,4,
IDE10534-ENG28891,History data 74-Physical_Wakeup_FUNC_2,3,
IDE10534-ENG28894,History data 74-Physical_Wakeup_FUNC_3,3,
IDE10534-ENG28897,History data 74-Physical_Wakeup_FUNC_4,0,
IDE10534-ENG28900,History data 74-Physical_Wakeup_FUNC_5,0,
IDE10534-ENG118681,History data 74-Time_Since_Clamp_15_Off,32.60, H
IDE10535-MAS03174,History data 75-Comfort data bus,0,
IDE10535-MAS03175,History data 75-Extended data bus,0,
IDE10535-MAS03177,History data 75-Infotainment data bus,0,
IDE10535-MAS03179,History data 75-Local data bus 2,0,
IDE10535-MAS03180,History data 75-Local data bus,0,
IDE10535-MAS03181,History data 75-Flexray databus,0,
IDE10535-MAS05686,History data 75-Data bus diagnostics,0,
IDE10535-MAS05972,History data 75-Local data bus 3,0,
IDE10535-MAS07380,History data 75-Data bus Sensor/Hybrid,0,
IDE10535-MAS10036,History data 75-Data bus diagnosis 2,0,
IDE10535-MAS12183,History data 75-Comfort CAN bus 2,0,
IDE10535-MAS14086,History data 75-Instrument cluster data bus,0,
IDE10535-MAS16912,History data 75-VLAN_FAS,0,
IDE10535-MAS16913,History data 75-VLAN_Infotainment,0,
IDE10535-MAS16915,History data 75-VLAN_Komfort,0,
IDE10535-MAS17153,History data 75-Data bus connect,0,
IDE10535-MAS18934,History data 75-VLAN_Connect,0,
IDE10535-MAS18935,History data 75-VLAN_Gateway,0,
IDE10535-MAS18936,History data 75-VLAN_Internet,0,
IDE10535-MAS20669,History data 75-VLAN_Remote_FC,0,
IDE10535-MAS22338,History data 75-VLAN Connect 3,0,
IDE10623-IDE04447,Status drive profile for roll stabilization-Function status,engaged,
IDE10623-IDE06260,Status drive profile for roll stabilization-ID number,0,
IDE10623-MAS01156,Status drive profile for roll stabilization-Communication status,OK,
IDE10623-MAS01447,Status drive profile for roll stabilization-Act.val.,0,
IDE10624-IDE04447,Status: driving profile selection for sport differential-Function status,engaged,
IDE10624-IDE06260,Status: driving profile selection for sport differential-ID number,0,
IDE10624-MAS01156,Status: driving profile selection for sport differential-Communication status,OK,
IDE10624-MAS01447,Status: driving profile selection for sport differential-Act.val.,0,
IDE10625-IDE04447,Stat.driv.profile select.for warn.in case of. risk of collision-Function status,not engaged,
IDE10625-IDE06260,Stat.driv.profile select.for warn.in case of. risk of collision-ID number,0,
IDE10625-MAS01156,Stat.driv.profile select.for warn.in case of. risk of collision-Communication status,OK,
IDE10625-MAS01447,Stat.driv.profile select.for warn.in case of. risk of collision-Act.val.,2,
IDE10626-IDE04447,Stat.driv.profile select.for warn.in case of risk of collision with pedestrian-Function status,not engaged,
IDE10626-IDE06260,Stat.driv.profile select.for warn.in case of risk of collision with pedestrian-ID number,0,
IDE10626-MAS01156,Stat.driv.profile select.for warn.in case of risk of collision with pedestrian-Communication status,OK,
IDE10626-MAS01447,Stat.driv.profile select.for warn.in case of risk of collision with pedestrian-Act.val.,2,
IDE10627-IDE04447,Status driving profile selection for hybrid battery management-Function status,engaged,
IDE10627-IDE06260,Status driving profile selection for hybrid battery management-ID number,0,
IDE10627-MAS01156,Status driving profile selection for hybrid battery management-Communication status,OK,
IDE10627-MAS01447,Status driving profile selection for hybrid battery management-Act.val.,0,
IDE10628-IDE04447,Status: driving profile selection for emerg. brake assistance-Function status,not engaged,
IDE10628-IDE06260,Status: driving profile selection for emerg. brake assistance-ID number,0,
IDE10628-MAS01156,Status: driving profile selection for emerg. brake assistance-Communication status,OK,
IDE10628-MAS01447,Status: driving profile selection for emerg. brake assistance-Act.val.,0,
IDE10629-IDE04447,Status: driving profile select. for rear axle differential lock-Function status,not engaged,
IDE10629-IDE06260,Status: driving profile select. for rear axle differential lock-ID number,0,
IDE10629-MAS01156,Status: driving profile select. for rear axle differential lock-Communication status,OK,
IDE10629-MAS01447,Status: driving profile select. for rear axle differential lock-Act.val.,0,
IDE10644-MAS06193,Driving profile selection: statistics distance driven-Profile 1,2, km
IDE10644-MAS06194,Driving profile selection: statistics distance driven-Profile 2,101, km
IDE10644-MAS06195,Driving profile selection: statistics distance driven-Profile 3,25, km
IDE10644-MAS06196,Driving profile selection: statistics distance driven-Profile 4,4, km
IDE10644-MAS06197,Driving profile selection: statistics distance driven-Profile 5,2, km
IDE10644-MAS06198,Driving profile selection: statistics distance driven-Profile 6,0, km
IDE10644-MAS06199,Driving profile selection: statistics distance driven-Profile 7,764, km
IDE10644-MAS06200,Driving profile selection: statistics distance driven-Profile 8,0, km
IDE10644-MAS08875,Driving profile selection: statistics distance driven-Profile 9,0, km
IDE10644-MAS08876,Driving profile selection: statistics distance driven-Profile 10,0, km
IDE10644-MAS08877,Driving profile selection: statistics distance driven-Profile 11,0, km
IDE10644-MAS08878,Driving profile selection: statistics distance driven-Profile 12,0, km
IDE10644-MAS08879,Driving profile selection: statistics distance driven-Profile 13,0, km
IDE10644-MAS08880,Driving profile selection: statistics distance driven-Profile 14,0, km
IDE10644-MAS08881,Driving profile selection: statistics distance driven-Profile 15,0, km
IDE10655-MAS00106,Pause recommendation: hist. data-Year,2021, yr
IDE10655-MAS00107,Pause recommendation: hist. data-Month,5, m
IDE10655-MAS00108,Pause recommendation: hist. data-Day,14, d
IDE10655-MAS00109,Pause recommendation: hist. data-Hours,17, H
IDE10655-MAS00110,Pause recommendation: hist. data-Minutes,52, min
IDE10655-MAS00111,Pause recommendation: hist. data-Seconds,59, s
IDE10655-MAS03401,Pause recommendation: hist. data-Parameter 1,0.40,
IDE10655-MAS03402,Pause recommendation: hist. data-Parameter 2,1.00,
IDE10655-MAS03403,Pause recommendation: hist. data-Parameter 3,1.09,
IDE10655-MAS03404,Pause recommendation: hist. data-Parameter 4,4.20,
IDE10655-MAS03405,Pause recommendation: hist. data-Parameter 5,0, %
IDE10655-MAS10985,Pause recommendation: hist. data-Overall drive duration,14, min
IDE10655-MAS10986,Pause recommendation: hist. data-Drive duration in active speed range,7, min
IDE10655-MAS10987,Pause recommendation: hist. data-Drive duration with warning readiness,0, min
IDE10655-MAS10988,Pause recommendation: hist. data-No. of warnings issued,00,
IDE10655-MAS14091,Pause recommendation: hist. data-Travel duration until first warning,0, min
IDE10656-MAS10989,Pause recommended: use-No. of drives with activated pause recommendation,00 00,
IDE10656-MAS10990,Pause recommended: use-No. of drives with deactivated pause recommendation,00 2A,
IDE10738-IDE04447,Status driving profile selection for electronic brake booster-Function status,engaged,
IDE10738-IDE06260,Status driving profile selection for electronic brake booster-ID number,0,
IDE10738-MAS01156,Status driving profile selection for electronic brake booster-Communication status,OK,
IDE10738-MAS01447,Status driving profile selection for electronic brake booster-Act.val.,0,
IDE10927-MAS11760,Total static current-current total quiescent current,0, mA
IDE10927-MAS11761,Total static current-Total time quiescent current exceeded,0.0, H
IDE10973,Generator voltage,10.6, V
IDE10974,12-Volt Vehicle electrical system: malfunction status,No malfunction,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11191-MAS12370,Open circuit detection: H-V lines-Wiring circuit 1,not active,
IDE11191-MAS12371,Open circuit detection: H-V lines-Wiring circuit 2,not active,
IDE11191-MAS17061,Open circuit detection: H-V lines-Wiring circuit 3,not active,
IDE11191-MAS17062,Open circuit detection: H-V lines-Wiring circuit 4,Mode not active,
IDE11191-MAS17063,Open circuit detection: H-V lines-Wiring circuit 5,Mode not active,
IDE11284-MAS00106,Sending status of online functions: history data-Year,2255, yr
IDE11284-MAS00107,Sending status of online functions: history data-Month,15, m
IDE11284-MAS00108,Sending status of online functions: history data-Day,31, d
IDE11284-MAS00109,Sending status of online functions: history data-Hours,31, H
IDE11284-MAS00110,Sending status of online functions: history data-Minutes,63, min
IDE11284-MAS00111,Sending status of online functions: history data-Seconds,63, s
IDE11284-MAS07134,Sending status of online functions: history data-ID services,ID_OTV,
IDE11284-MAS12545,Sending status of online functions: history data-Send attempt: status,not OK,
IDE11485-MAS02832,HV voltage converter: status for electric drive-Malfunction status,No malfunction detected,
IDE11485-MAS03001,HV voltage converter: status for electric drive-Mode,Step-down mode,
IDE11486-MAS02246,HV battery charge management: HV activation restriction-Timeout,not active,
IDE11486-MAS09518,HV battery charge management: HV activation restriction-Safety line,not active,
IDE11486-MAS09519,HV battery charge management: HV activation restriction-Message error,not active,
IDE11486-MAS09541,HV battery charge management: HV activation restriction-Act. mode init. error,not active,
IDE11486-MAS09542,HV battery charge management: HV activation restriction-Error status init. error,not active,
IDE11486-MAS09543,HV battery charge management: HV activation restriction-Operating mode error,not active,
IDE11486-MAS09544,HV battery charge management: HV activation restriction-No component function,not active,
IDE11486-MAS09545,HV battery charge management: HV activation restriction-Sequence error,not active,
IDE11486-MAS12351,HV battery charge management: HV activation restriction-HV voltage measurement error,not active,
IDE11486-MAS13068,HV battery charge management: HV activation restriction-HV voltage measurement initialization error,not active,
IDE11586-IDE04447,Status drive profile selection for integral steering-Function status,not engaged,
IDE11586-IDE06260,Status drive profile selection for integral steering-ID number,0,
IDE11586-MAS01156,Status drive profile selection for integral steering-Communication status,OK,
IDE11586-MAS01447,Status drive profile selection for integral steering-Act.val.,0,
IDE11661-IDE06930,Autonomous operation states-Voltage converter: status: Status,Step-down mode,
IDE11661-IDE08958,Autonomous operation states-H-V system: start request,not active,
IDE11661-MAS07605,Autonomous operation states-charging request,not active,
IDE11661-MAS08040,Autonomous operation states-Automatic recharging of starter battery,not active,
IDE11661-MAS13088,Autonomous operation states-Preconditioning of the interior,not requested,
IDE11661-MAS13089,Autonomous operation states-High-voltage vehicle electrical system: status,active,
IDE11662-MAS13090,H-V power distribution-Energy allocation thermal management,12650, Wh
IDE11662-MAS13091,H-V power distribution-Energy allocation12-volt electrical system,102250, Wh
IDE11662-MAS13092,H-V power distribution-Energy content of the high-voltage battery,65850, Wh
IDE11663,H-V energy management mode,HV charging,
IDE11664,Requirement to recharge the H-V battery charging management,not active,
IDE11671-MAS02246,H-V power transformers: prohibition on turning-on H-V-Timeout,not active,
IDE11671-MAS09518,H-V power transformers: prohibition on turning-on H-V-Safety line,not active,
IDE11671-MAS09519,H-V power transformers: prohibition on turning-on H-V-Message error,not active,
IDE11671-MAS09541,H-V power transformers: prohibition on turning-on H-V-Act. mode init. error,not active,
IDE11671-MAS09542,H-V power transformers: prohibition on turning-on H-V-Error status init. error,not active,
IDE11671-MAS09543,H-V power transformers: prohibition on turning-on H-V-Operating mode error,not active,
IDE11671-MAS09544,H-V power transformers: prohibition on turning-on H-V-No component function,not active,
IDE11671-MAS09545,H-V power transformers: prohibition on turning-on H-V-Sequence error,not active,
IDE11671-MAS12351,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement error,not active,
IDE11671-MAS13068,H-V power transformers: prohibition on turning-on H-V-HV voltage measurement initialization error,not active,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11675-MAS02246,Roll stabilization: prohibition on turning-on 48V-Timeout,not active,
IDE11675-MAS09519,Roll stabilization: prohibition on turning-on 48V-Message error,not active,
IDE11675-MAS09541,Roll stabilization: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11675-MAS09542,Roll stabilization: prohibition on turning-on 48V-Error status init. error,not active,
IDE11675-MAS09543,Roll stabilization: prohibition on turning-on 48V-Operating mode error,not active,
IDE11675-MAS09544,Roll stabilization: prohibition on turning-on 48V-No component function,not active,
IDE11675-MAS09545,Roll stabilization: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11676-MAS18704,Airbag: prohibition on turning-on 48V-History of minor accident,not active,
IDE11676-MAS18705,Airbag: prohibition on turning-on 48V-History of serious accident,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11682-IDE04447,Status of driving profile selection for exhaust flaps-Function status,not engaged,
IDE11682-IDE06260,Status of driving profile selection for exhaust flaps-ID number,0,
IDE11682-MAS01156,Status of driving profile selection for exhaust flaps-Communication status,OK,
IDE11682-MAS01447,Status of driving profile selection for exhaust flaps-Act.val.,0,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,Initialization,
IDE11683-MAS13708,Engine electronics: status of 48V network-Error status of electrical compressor,Initialization,
IDE11683-MAS13715,Engine electronics: status of 48V network-Electro compressor mode,Initialization,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,Initialization,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,Initialization,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,255,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11686-MAS02832,Anti-roll stabilization: status for 48V power-Malfunction status,Initialization,
IDE11686-MAS03001,Anti-roll stabilization: status for 48V power-Mode,Initialization,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,good: link available,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,no link,
IDE11732,Ethernet signal quality: branch 5,no link,
IDE11733,Ethernet signal quality: branch 6,no link,
IDE11734,Ethernet signal quality: branch 7,no link,
IDE11735,Ethernet signal quality: branch 8,no link,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,0,
IDE11739,Ethernet counter connection interruptions: branch 4,0,
IDE11740,Ethernet counter connection interruptions: branch 5,0,
IDE11741,Ethernet counter connection interruptions: branch 6,0,
IDE11742,Ethernet counter connection interruptions: branch 7,0,
IDE11743,Ethernet counter connection interruptions: branch 8,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11750,Ethernet counter checksum error: branch 7,0,
IDE11751,Ethernet counter checksum error: branch 8,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 10,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05,
IDE11755-MAS14856,IP network: VLANs-VLAN,7,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,48 16 93 38 66 1B,
IDE11869-IDE09467,IP network: NDP cache-MAC address,28 63 BD 01 93 E8,
IDE11869-IDE09469,IP network: NDP cache-IPv6 address,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,
IDE11869-MAS14856,IP network: NDP cache-VLAN,3,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11911-SFT09769,48V activation restriction-Auxiliary Air Heater Control Module/PTC,not active,
IDE11911-SFT09997,48V activation restriction-Electrical compressor,not active,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,F8 E8 77 29 26 7A,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,28 63 BD 01 93 E8,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,28 63 BD 05 0E 5E,
IDE12084-MAS14046,Component protection participant status-Node address of the immobilizer master,00 8B,
IDE12084-MAS14047,Component protection participant status-Generation of the immobilizer master,Generation 2,
IDE12084-MAS14048,Component protection participant status-Authentication status of the immobilizer master,valid authentication,
IDE12084-MAS14053,Component protection participant status-Status of start authentication,switched on,
IDE12084-MAS14054,Component protection participant status-Start authentication can be deactivated,No,
IDE12084-MAS14055,Component protection participant status-Immobilizer master sends authentication request,Yes,
IDE12084-MAS14056,Component protection participant status-Status of the IKA key for immobilizer master,IKA key stored,
IDE12084-MAS14059,Component protection participant status-Node address of the component protection participant,00 27,
IDE12084-MAS14060,Component protection participant status-Prioritized participant,Yes,
IDE12084-MAS14061,Component protection participant status-Authentication status of the component protection participant,incompletely authenticated,
IDE12084-MAS14062,Component protection participant status-Participant extended start authentication,No,
IDE12084-MAS14063,Component protection participant status-Component protection participant sends authentication request,No,
IDE12084-MAS14064,Component protection participant status-Status of the IKA key for component protection participants,no IKA key stored,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,4,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,3,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,2,
IDE12238,I network: discarded messages counter,0,
IDE12239-IDE09469,IP network: test feedback value of communications relationships-IPv6 address,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67,
IDE12239-MAS05584,IP network: test feedback value of communications relationships-Result,Test not yet carried out,
IDE12581-ENG28833,History data 76-Bus_ECU_1,23,
IDE12581-ENG28836,History data 76-Bus_ECU_2,0,
IDE12581-ENG28839,History data 76-Bus_ECU_3,16,
IDE12581-ENG28842,History data 76-Bus_ECU_4,23,
IDE12581-ENG28845,History data 76-Bus_ECU_5,26,
IDE12581-ENG118680,History data 76-Cycle_Counter,159,
IDE12581-ENG106038,History data 76-ECU_1,184,
IDE12581-ENG106039,History data 76-ECU_2,199,
IDE12581-ENG28620,History data 76-ECU_3,183,
IDE12581-ENG106040,History data 76-ECU_4,124,
IDE12581-ENG106041,History data 76-ECU_5,20,
IDE12581-ENG30992,History data 76-ECU_Knock_Out_ECU_1,15, min
IDE12581-ENG30993,History data 76-ECU_Knock_Out_ECU_2,15, min
IDE12581-ENG30994,History data 76-ECU_Knock_Out_ECU_3,15, min
IDE12581-ENG30995,History data 76-ECU_Knock_Out_ECU_4,15, min
IDE12581-ENG30996,History data 76-ECU_Knock_Out_ECU_5,15, min
IDE12581-ENG31201,History data 76-Fkt_Ausloesung_ECU_1,0,
IDE12581-ENG31202,History data 76-Fkt_Ausloesung_ECU_2,0,
IDE12581-ENG31203,History data 76-Fkt_Ausloesung_ECU_3,0,
IDE12581-ENG31204,History data 76-Fkt_Ausloesung_ECU_4,0,
IDE12581-ENG31205,History data 76-Fkt_Ausloesung_ECU_5,0,
IDE12581-ENG32787,History data 76-Sub_System_Aktiv_ECU_1,0,
IDE12581-ENG32788,History data 76-Sub_System_Aktiv_ECU_2,0,
IDE12581-ENG32789,History data 76-Sub_System_Aktiv_ECU_3,0,
IDE12581-ENG32790,History data 76-Sub_System_Aktiv_ECU_4,0,
IDE12581-ENG32791,History data 76-Sub_System_Aktiv_ECU_5,0,
IDE12581-ENG33300,History data 76-Veto_Aktiv_ECU_1,0,
IDE12581-ENG33301,History data 76-Veto_Aktiv_ECU_2,0,
IDE12581-ENG33302,History data 76-Veto_Aktiv_ECU_3,0,
IDE12581-ENG33303,History data 76-Veto_Aktiv_ECU_4,0,
IDE12581-ENG33304,History data 76-Veto_Aktiv_ECU_5,0,
IDE12583-MAS00106,History data 77-Year,2000, yr
IDE12583-MAS00107,History data 77-Month,1, m
IDE12583-MAS00108,History data 77-Day,1, d
IDE12583-MAS00109,History data 77-Hours,0, H
IDE12583-MAS00110,History data 77-Minutes,0, min
IDE12583-ENG28833,History data 77-Bus_ECU_1,0,
IDE12583-ENG28836,History data 77-Bus_ECU_2,0,
IDE12583-ENG28839,History data 77-Bus_ECU_3,0,
IDE12583-ENG28842,History data 77-Bus_ECU_4,0,
IDE12583-ENG28845,History data 77-Bus_ECU_5,0,
IDE12583-ENG118680,History data 77-Cycle_Counter,0,
IDE12583-ENG106038,History data 77-ECU_1,0,
IDE12583-ENG106039,History data 77-ECU_2,0,
IDE12583-ENG28620,History data 77-ECU_3,0,
IDE12583-ENG106040,History data 77-ECU_4,0,
IDE12583-ENG106041,History data 77-ECU_5,0,
IDE12583-ENG30992,History data 77-ECU_Knock_Out_ECU_1,0, min
IDE12583-ENG30993,History data 77-ECU_Knock_Out_ECU_2,0, min
IDE12583-ENG30994,History data 77-ECU_Knock_Out_ECU_3,0, min
IDE12583-ENG30995,History data 77-ECU_Knock_Out_ECU_4,0, min
IDE12583-ENG30996,History data 77-ECU_Knock_Out_ECU_5,0, min
IDE12583-ENG31201,History data 77-Fkt_Ausloesung_ECU_1,0,
IDE12583-ENG31202,History data 77-Fkt_Ausloesung_ECU_2,0,
IDE12583-ENG31203,History data 77-Fkt_Ausloesung_ECU_3,0,
IDE12583-ENG31204,History data 77-Fkt_Ausloesung_ECU_4,0,
IDE12583-ENG31205,History data 77-Fkt_Ausloesung_ECU_5,0,
IDE12583-ENG32787,History data 77-Sub_System_Aktiv_ECU_1,0,
IDE12583-ENG32788,History data 77-Sub_System_Aktiv_ECU_2,0,
IDE12583-ENG32789,History data 77-Sub_System_Aktiv_ECU_3,0,
IDE12583-ENG32790,History data 77-Sub_System_Aktiv_ECU_4,0,
IDE12583-ENG32791,History data 77-Sub_System_Aktiv_ECU_5,0,
IDE12583-ENG118681,History data 77-Time_Since_Clamp_15_Off,0.00, H
IDE12583-ENG33300,History data 77-Veto_Aktiv_ECU_1,0,
IDE12583-ENG33301,History data 77-Veto_Aktiv_ECU_2,0,
IDE12583-ENG33302,History data 77-Veto_Aktiv_ECU_3,0,
IDE12583-ENG33303,History data 77-Veto_Aktiv_ECU_4,0,
IDE12583-ENG33304,History data 77-Veto_Aktiv_ECU_5,0,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,0,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,0,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,0,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,not touching,
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13018-MAS02246,Electrical drive 2: high-voltage switch on prevention-Timeout,not active,
IDE13018-MAS09518,Electrical drive 2: high-voltage switch on prevention-Safety line,not active,
IDE13018-MAS09519,Electrical drive 2: high-voltage switch on prevention-Message error,not active,
IDE13018-MAS09542,Electrical drive 2: high-voltage switch on prevention-Error status init. error,not active,
IDE13018-MAS09544,Electrical drive 2: high-voltage switch on prevention-No component function,not active,
IDE13018-MAS09546,Electrical drive 2: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13018-MAS12345,Electrical drive 2: high-voltage switch on prevention-Active discharge fault,not active,
IDE13019-MAS02246,Electrical drive 3: high-voltage switch on prevention-Timeout,not active,
IDE13019-MAS09518,Electrical drive 3: high-voltage switch on prevention-Safety line,not active,
IDE13019-MAS09519,Electrical drive 3: high-voltage switch on prevention-Message error,not active,
IDE13019-MAS09542,Electrical drive 3: high-voltage switch on prevention-Error status init. error,not active,
IDE13019-MAS09544,Electrical drive 3: high-voltage switch on prevention-No component function,not active,
IDE13019-MAS09546,Electrical drive 3: high-voltage switch on prevention-Voltage disconnect. init. error,not active,
IDE13019-MAS12345,Electrical drive 3: high-voltage switch on prevention-Active discharge fault,not active,
IDE13033-MAS15531,Communication status of emergency call module: analysis-Components 1,Not available,
IDE13033-MAS15532,Communication status of emergency call module: analysis-Components 2,Not available,
IDE13033-MAS15533,Communication status of emergency call module: analysis-Components 3,Not available,
IDE13033-MAS15534,Communication status of emergency call module: analysis-Components 4,available.,
IDE13033-MAS15535,Communication status of emergency call module: analysis-Components 5,available.,
IDE13057-MAS15615,Lithium ions starter battery-Battery: fault status,No malfunction,
IDE13057-MAS15620,Lithium ions starter battery-Battery cut-out element: fault status,No malfunction,
IDE13140,History data 78,0000402*2021-04-26-20:56:43*000*19*1*1*0*0*143*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0**************************,
IDE13140,History data 78,,
IDE13140,History data 78,0000000*2000-01-01-00:00:00*000*00*0*0*0*0*000*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*******************************************************************************,
IDE13140,History data 78,0000402*2021-04-26-20:56:43*000*19*1*1*0*0*143*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0************************************************************************************************************,
IDE13141,History data 79,0000000*2000-01-01-00:00:00**,
IDE13142,History data 80,0000577*2021-05-05-08:36:03*000*10*0*0*1*0*131*00*00*10*47*01*00*02*05*00*35*00*01*00*00*00*53*01*00*00*00*00*00*00*00*00*00*00*02*4*32*3E800*753000****************************,
IDE13142,History data 80,0000402*2021-04-26-20:56:43*000*19*1*1*0*0*143*00*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0*0************************************************************************************************************,
IDE13142,History data 80,,
IDE13398-MAS11501,Driving profile history data 5-Charging,0, min
IDE13398-MAS13105,Driving profile history data 5-Electrical travel,0, min
IDE13398-MAS13106,Driving profile history data 5-Hybrid driving,0, min
IDE13398-MAS20668,Driving profile history data 5-Battery hold mode,0, min
IDE13402-MAS06193,Driving profile history data 6-Profile 1,0, km
IDE13402-MAS06194,Driving profile history data 6-Profile 2,0, km
IDE13402-MAS06195,Driving profile history data 6-Profile 3,0, km
IDE13402-MAS06196,Driving profile history data 6-Profile 4,0, km
IDE13754-MAS03095,Diagnosis filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,20, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,hood open,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755,Diagnosis filter: history data,0000529*2021-05-02-12:01:05*1*,
IDE13755,Diagnosis filter: history data,0000921*2021-05-15-16:01:58*1*,
IDE13755,Diagnosis filter: history data,0000000*2017-09-07-00:00:45*6*,
IDE13755,Diagnosis filter: history data,0000773*2021-05-09-13:47:43*1*,
IDE13755,Diagnosis filter: history data,0000000*2000-01-01-00:00:00*0*,
IDE13848-MAS06568,Onboard network components: medium-voltage-Auxiliary Heater,not installed,
IDE13848-MAS10933,Onboard network components: medium-voltage-Roll stabilization,not installed,
IDE13848-MAS11243,Onboard network components: medium-voltage-Battery Management 48V,not installed,
IDE13848-MAS16949,Onboard network components: medium-voltage-Active setup verification,not installed,
IDE13848-MAS16953,Onboard network components: medium-voltage-Belt driven starter generator 48V,not installed,
IDE13848-MAS17010,Onboard network components: medium-voltage-48V Vehicle Electrical System Storage Capacitor,not installed,
IDE13848-SFT00196,Onboard network components: medium-voltage-Voltage converter,not installed,
IDE13848-SFT09997,Onboard network components: medium-voltage-Electrical compressor,not installed,
IDE13849-IDE12114,Onboard network diagnosis 48V 1-48V vehicle electrical system diagnosis,requested,
IDE13849-MAS01867,Onboard network diagnosis 48V 1-Measurement,OK,
IDE13849-MAS15721,Onboard network diagnosis 48V 1-Battery management 48V power supply battery,Initialization,
IDE13850-MAS01867,Onboard network diagnosis 48V 2-Measurement,OK,
IDE13850-MAS06864,Onboard network diagnosis 48V 2-Generator actual voltage,Initialization,
IDE13850-MAS15119,Onboard network diagnosis 48V 2-48-Volt vehicle electrical system,not active,
IDE13850-MAS15722,Onboard network diagnosis 48V 2-Battery management 48V: actual voltage,Initialization,
IDE13850-MAS16957,Onboard network diagnosis 48V 2-Electrically driven compressor: current voltage,Initialization,
IDE13850-MAS16958,Onboard network diagnosis 48V 2-Voltage converter: current voltage,Initialization,
IDE13850-MAS16959,Onboard network diagnosis 48V 2-Roll stabilization front axis current voltage,Initialization,
IDE13850-MAS16960,Onboard network diagnosis 48V 2-Roll stabilization rear axis current voltage,Initialization,
IDE13850-MAS16961,Onboard network diagnosis 48V 2-Active setup verification front axle current voltage,Initialization,
IDE13850-MAS16962,Onboard network diagnosis 48V 2-Active setup verification rear axle current voltage,Initialization,
IDE13862-MAS02246,High-voltage battery charger 2: do not turn on high voltage-Timeout,not active,
IDE13862-MAS09518,High-voltage battery charger 2: do not turn on high voltage-Safety line,not active,
IDE13862-MAS09519,High-voltage battery charger 2: do not turn on high voltage-Message error,not active,
IDE13862-MAS09542,High-voltage battery charger 2: do not turn on high voltage-Error status init. error,not active,
IDE13862-MAS09544,High-voltage battery charger 2: do not turn on high voltage-No component function,not active,
IDE13862-MAS09546,High-voltage battery charger 2: do not turn on high voltage-Voltage disconnect. init. error,not active,
IDE13862-MAS12351,High-voltage battery charger 2: do not turn on high voltage-HV voltage measurement error,not active,
IDE13862-MAS13068,High-voltage battery charger 2: do not turn on high voltage-HV voltage measurement initialization error,not active,
IDE13948-MAS17220,Stack memory-Stack memory extract,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14133-MAS01364,48V electrical system: reduced network operation-Stage 1,not active,
IDE14133-MAS01365,48V electrical system: reduced network operation-Stage 2,not active,
IDE14133-MAS02246,48V electrical system: reduced network operation-Timeout,active,
IDE14133-MAS02832,48V electrical system: reduced network operation-Malfunction status,7,
IDE14133-MAS03123,48V electrical system: reduced network operation-Reduced performance,not active,
IDE14133-MAS17920,48V electrical system: reduced network operation-timeout 2,active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,0,
IDE14151-MAS14375,Route-based range calculation-Cycle counter,1,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not activated,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,27.00, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,20.00, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,15.00, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,16.00, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,18.00, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,20.00, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,22.00, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,23.00, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,27.00, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,26.00, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,30.00, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,15.00, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,16.00, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,18.00, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,23.00, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,21.00, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,19.00, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,23.00, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,23.00, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,26.00, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,0,
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,Initialization,
IDE14151-MAS17928,Route-based range calculation-Maximum range,Initialization,
IDE14151-MAS17929,Route-based range calculation-Total coverage,2046,
IDE14151-MAS17930,Route-based range calculation-Range from destination,2046,
IDE14151-MAS17931,Route-based range calculation-Route-based range,0,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14162-MAS17987,High-voltage electrical system: target installation-High-voltage battery,not requested,
IDE14162-ENG30825,High-voltage electrical system: target installation-desired_value_02,not requested,
IDE14162-ENG30826,High-voltage electrical system: target installation-desired_value_03,not requested,
IDE14162-ENG30827,High-voltage electrical system: target installation-desired_value_04,not requested,
IDE14162-ENG30828,High-voltage electrical system: target installation-desired_value_05,not requested,
IDE14162-ENG30829,High-voltage electrical system: target installation-desired_value_06,not requested,
IDE14162-ENG30830,High-voltage electrical system: target installation-desired_value_07,not requested,
IDE14162-ENG30831,High-voltage electrical system: target installation-desired_value_08,not requested,
IDE14162-ENG30832,High-voltage electrical system: target installation-desired_value_09,not requested,
IDE14162-ENG30833,High-voltage electrical system: target installation-desired_value_10,not requested,
IDE14162-ENG30834,High-voltage electrical system: target installation-desired_value_11,not requested,
IDE14162-ENG30835,High-voltage electrical system: target installation-desired_value_12,not requested,
IDE14162-ENG30836,High-voltage electrical system: target installation-desired_value_13,not requested,
IDE14162-ENG30837,High-voltage electrical system: target installation-desired_value_14,not requested,
IDE14162-ENG30838,High-voltage electrical system: target installation-desired_value_15,not requested,
IDE14162-ENG30839,High-voltage electrical system: target installation-desired_value_16,not requested,
IDE14162-ENG30840,High-voltage electrical system: target installation-desired_value_17,not requested,
IDE14162-ENG30841,High-voltage electrical system: target installation-desired_value_18,not requested,
IDE14162-ENG30842,High-voltage electrical system: target installation-desired_value_19,not requested,
IDE14162-ENG30843,High-voltage electrical system: target installation-desired_value_20,not requested,
IDE14162-ENG30844,High-voltage electrical system: target installation-desired_value_21,not requested,
IDE14162-ENG30845,High-voltage electrical system: target installation-desired_value_22,not requested,
IDE14162-ENG30846,High-voltage electrical system: target installation-desired_value_23,not requested,
IDE14162-ENG30847,High-voltage electrical system: target installation-desired_value_24,not requested,
IDE14163-MAS17986,MV electrical system: target installation-Medium-voltage battery,not requested,
IDE14163-ENG30825,MV electrical system: target installation-desired_value_02,not requested,
IDE14163-ENG30826,MV electrical system: target installation-desired_value_03,not requested,
IDE14163-ENG30827,MV electrical system: target installation-desired_value_04,not requested,
IDE14163-ENG30828,MV electrical system: target installation-desired_value_05,not requested,
IDE14163-ENG30829,MV electrical system: target installation-desired_value_06,not requested,
IDE14163-ENG30830,MV electrical system: target installation-desired_value_07,not requested,
IDE14163-ENG30831,MV electrical system: target installation-desired_value_08,not requested,
IDE14163-ENG30832,MV electrical system: target installation-desired_value_09,not requested,
IDE14163-ENG30833,MV electrical system: target installation-desired_value_10,not requested,
IDE14163-ENG30834,MV electrical system: target installation-desired_value_11,not requested,
IDE14163-ENG30835,MV electrical system: target installation-desired_value_12,not requested,
IDE14163-ENG30836,MV electrical system: target installation-desired_value_13,not requested,
IDE14163-ENG30837,MV electrical system: target installation-desired_value_14,not requested,
IDE14163-ENG30838,MV electrical system: target installation-desired_value_15,not requested,
IDE14163-ENG30839,MV electrical system: target installation-desired_value_16,not requested,
IDE14163-ENG30840,MV electrical system: target installation-desired_value_17,not requested,
IDE14163-ENG30841,MV electrical system: target installation-desired_value_18,not requested,
IDE14163-ENG30842,MV electrical system: target installation-desired_value_19,not requested,
IDE14163-ENG30843,MV electrical system: target installation-desired_value_20,not requested,
IDE14163-ENG30844,MV electrical system: target installation-desired_value_21,not requested,
IDE14163-ENG30845,MV electrical system: target installation-desired_value_22,not requested,
IDE14163-ENG30846,MV electrical system: target installation-desired_value_23,not requested,
IDE14163-ENG30847,MV electrical system: target installation-desired_value_24,not requested,
IDE14164-MAS00478,Low-voltage electrical system: target installation-Reserved,not requested,
IDE14164-MAS17988,Low-voltage electrical system: target installation-LV battery,not requested,
IDE14164-ENG30828,Low-voltage electrical system: target installation-desired_value_05,not requested,
IDE14165-MAS00478,Actual installation of high-voltage electrical system-Reserved,detected,
IDE14165-MAS00478,Actual installation of high-voltage electrical system-Reserved,not detected,
IDE14165-MAS17987,Actual installation of high-voltage electrical system-High-voltage battery,detected,
IDE14166-MAS17986,Actual installation of MV electrical system-Medium-voltage battery,not detected,
IDE14166-ENG30271,Actual installation of MV electrical system-actual_value_02,not detected,
IDE14166-ENG30272,Actual installation of MV electrical system-actual_value_03,not detected,
IDE14166-ENG30273,Actual installation of MV electrical system-actual_value_04,not detected,
IDE14166-ENG30274,Actual installation of MV electrical system-actual_value_05,not detected,
IDE14166-ENG30275,Actual installation of MV electrical system-actual_value_06,not detected,
IDE14166-ENG30276,Actual installation of MV electrical system-actual_value_07,not detected,
IDE14166-ENG30277,Actual installation of MV electrical system-actual_value_08,not detected,
IDE14166-ENG30278,Actual installation of MV electrical system-actual_value_09,not detected,
IDE14166-ENG30279,Actual installation of MV electrical system-actual_value_10,not detected,
IDE14166-ENG30280,Actual installation of MV electrical system-actual_value_11,not detected,
IDE14166-ENG30281,Actual installation of MV electrical system-actual_value_12,not detected,
IDE14166-ENG30282,Actual installation of MV electrical system-actual_value_13,not detected,
IDE14166-ENG30283,Actual installation of MV electrical system-actual_value_14,not detected,
IDE14166-ENG30284,Actual installation of MV electrical system-actual_value_15,not detected,
IDE14166-ENG30285,Actual installation of MV electrical system-actual_value_16,not detected,
IDE14166-ENG30286,Actual installation of MV electrical system-actual_value_17,not detected,
IDE14166-ENG30287,Actual installation of MV electrical system-actual_value_18,not detected,
IDE14166-ENG30288,Actual installation of MV electrical system-actual_value_19,not detected,
IDE14166-ENG30289,Actual installation of MV electrical system-actual_value_20,not detected,
IDE14166-ENG30290,Actual installation of MV electrical system-actual_value_21,not detected,
IDE14166-ENG30291,Actual installation of MV electrical system-actual_value_22,not detected,
IDE14166-ENG30292,Actual installation of MV electrical system-actual_value_23,not detected,
IDE14166-ENG30293,Actual installation of MV electrical system-actual_value_24,not detected,
IDE14167-MAS00478,Actual installation of low-voltage electrical system-Reserved,not detected,
IDE14167-MAS00478,Actual installation of low-voltage electrical system-Reserved,detected,
IDE14167-MAS17988,Actual installation of low-voltage electrical system-LV battery,not detected,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,2021, yr
IDE14236-MAS00107,Authentic time: last confirmed time-Month,5, m
IDE14236-MAS00108,Authentic time: last confirmed time-Day,13, d
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,22, H
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,16, min
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,35, s
IDE14236-MAS03617,Authentic time: last confirmed time-Time zone,0.00, H
IDE14237-MAS00106,Authentic time: actual time-Year,2021, yr
IDE14237-MAS00107,Authentic time: actual time-Month,5, m
IDE14237-MAS00108,Authentic time: actual time-Day,16, d
IDE14237-MAS00109,Authentic time: actual time-Hours,16, H
IDE14237-MAS00110,Authentic time: actual time-Minutes,53, min
IDE14237-MAS00111,Authentic time: actual time-Seconds,39, s
IDE14237-MAS03617,Authentic time: actual time-Time zone,0.00, H
IDE14292,Ethernet status: electrical error: branch 1,No malfunction,
IDE14293,Ethernet status: electrical error: branch 2,No malfunction,
IDE14294,Ethernet status: electrical error: branch 3,No malfunction,
IDE14295,Ethernet status: electrical error: branch 4,No malfunction,
IDE14296,Ethernet status: electrical error: branch 5,No malfunction,
IDE14297,Ethernet status: electrical error: branch 6,No malfunction,
IDE14298,Ethernet status: electrical error: branch 7,No malfunction,
IDE14299,Ethernet status: electrical error: branch 8,No malfunction,
IDE14334,Authentic time: number of maximum deviation exceeded,0,
IDE14918-MAS05494,Event information air interface history-Cause 1,0,
IDE14918-MAS05495,Event information air interface history-Cause 2,0,
IDE14918-MAS05496,Event information air interface history-Cause 3,0,
IDE14918-MAS05497,Event information air interface history-Cause 4,0,
IDE14918-MAS05498,Event information air interface history-Cause 5,0,
IDE14918-MAS05499,Event information air interface history-Cause 6,0,
IDE14918-MAS05793,Event information air interface history-Cause 7,0,
IDE14918-MAS05794,Event information air interface history-Cause 8,0,
IDE14918-MAS19597,Event information air interface history-Cause 9,0,
IDE14918-MAS19598,Event information air interface history-Cause 10,0,
IDE14918-MAS19599,Event information air interface history-Cause 11,0,
IDE14918-MAS19600,Event information air interface history-Cause 12,0,
IDE14918-MAS19601,Event information air interface history-Cause 13,0,
IDE14918-MAS19602,Event information air interface history-Cause 14,0,
IDE14918-MAS19603,Event information air interface history-Cause 15,0,
IDE14918-MAS19604,Event information air interface history-Cause 16,0,
IDE14919-MAS05494,Event information Certificate Update-Cause 1,not active,
IDE14919-MAS05495,Event information Certificate Update-Cause 2,not active,
IDE14919-MAS05496,Event information Certificate Update-Cause 3,not active,
IDE14919-MAS05497,Event information Certificate Update-Cause 4,not active,
IDE14919-MAS05498,Event information Certificate Update-Cause 5,not active,
IDE14919-MAS05499,Event information Certificate Update-Cause 6,not active,
IDE14919-MAS05793,Event information Certificate Update-Cause 7,not active,
IDE14919-MAS05794,Event information Certificate Update-Cause 8,not active,
IDE14919-MAS19597,Event information Certificate Update-Cause 9,not active,
IDE14919-MAS19598,Event information Certificate Update-Cause 10,not active,
IDE14919-MAS19599,Event information Certificate Update-Cause 11,not active,
IDE14919-MAS19600,Event information Certificate Update-Cause 12,not active,
IDE14919-MAS19601,Event information Certificate Update-Cause 13,not active,
IDE14919-MAS19602,Event information Certificate Update-Cause 14,not active,
IDE14919-MAS19603,Event information Certificate Update-Cause 15,not active,
IDE14919-MAS19604,Event information Certificate Update-Cause 16,not active,
IDE14920-MAS05494,Event information communication charger-Cause 1,not active,
IDE14920-MAS05495,Event information communication charger-Cause 2,not active,
IDE14920-MAS05496,Event information communication charger-Cause 3,not active,
IDE14920-MAS05497,Event information communication charger-Cause 4,not active,
IDE14920-MAS05498,Event information communication charger-Cause 5,not active,
IDE14920-MAS05499,Event information communication charger-Cause 6,not active,
IDE14920-MAS05793,Event information communication charger-Cause 7,not active,
IDE14920-MAS05794,Event information communication charger-Cause 8,not active,
IDE14920-MAS19597,Event information communication charger-Cause 9,not active,
IDE14920-MAS19598,Event information communication charger-Cause 10,not active,
IDE14920-MAS19599,Event information communication charger-Cause 11,not active,
IDE14920-MAS19600,Event information communication charger-Cause 12,not active,
IDE14920-MAS19601,Event information communication charger-Cause 13,not active,
IDE14920-MAS19602,Event information communication charger-Cause 14,not active,
IDE14920-MAS19603,Event information communication charger-Cause 15,not active,
IDE14920-MAS19604,Event information communication charger-Cause 16,not active,
IDE14921-MAS05494,Event information communication charger history-Cause 1,0,
IDE14921-MAS05495,Event information communication charger history-Cause 2,0,
IDE14921-MAS05496,Event information communication charger history-Cause 3,0,
IDE14921-MAS05497,Event information communication charger history-Cause 4,0,
IDE14921-MAS05498,Event information communication charger history-Cause 5,0,
IDE14921-MAS05499,Event information communication charger history-Cause 6,0,
IDE14921-MAS05793,Event information communication charger history-Cause 7,0,
IDE14921-MAS05794,Event information communication charger history-Cause 8,0,
IDE14921-MAS19597,Event information communication charger history-Cause 9,0,
IDE14921-MAS19598,Event information communication charger history-Cause 10,0,
IDE14921-MAS19599,Event information communication charger history-Cause 11,0,
IDE14921-MAS19600,Event information communication charger history-Cause 12,0,
IDE14921-MAS19601,Event information communication charger history-Cause 13,0,
IDE14921-MAS19602,Event information communication charger history-Cause 14,0,
IDE14921-MAS19603,Event information communication charger history-Cause 15,0,
IDE14921-MAS19604,Event information communication charger history-Cause 16,0,
IDE14922-MAS05494,Event information air interface-Cause 1,not active,
IDE14922-MAS05495,Event information air interface-Cause 2,not active,
IDE14922-MAS05496,Event information air interface-Cause 3,not active,
IDE14922-MAS05497,Event information air interface-Cause 4,not active,
IDE14922-MAS05498,Event information air interface-Cause 5,not active,
IDE14922-MAS05499,Event information air interface-Cause 6,not active,
IDE14922-MAS05793,Event information air interface-Cause 7,not active,
IDE14922-MAS05794,Event information air interface-Cause 8,not active,
IDE14922-MAS19597,Event information air interface-Cause 9,not active,
IDE14922-MAS19598,Event information air interface-Cause 10,not active,
IDE14922-MAS19599,Event information air interface-Cause 11,not active,
IDE14922-MAS19600,Event information air interface-Cause 12,not active,
IDE14922-MAS19601,Event information air interface-Cause 13,not active,
IDE14922-MAS19602,Event information air interface-Cause 14,not active,
IDE14922-MAS19603,Event information air interface-Cause 15,not active,
IDE14922-MAS19604,Event information air interface-Cause 16,not active,
IDE14923-MAS05494,Event information Certificate update history-Cause 1,0,
IDE14923-MAS05495,Event information Certificate update history-Cause 2,0,
IDE14923-MAS05496,Event information Certificate update history-Cause 3,0,
IDE14923-MAS05497,Event information Certificate update history-Cause 4,0,
IDE14923-MAS05498,Event information Certificate update history-Cause 5,0,
IDE14923-MAS05499,Event information Certificate update history-Cause 6,0,
IDE14923-MAS05793,Event information Certificate update history-Cause 7,0,
IDE14923-MAS05794,Event information Certificate update history-Cause 8,0,
IDE14923-MAS19597,Event information Certificate update history-Cause 9,0,
IDE14923-MAS19598,Event information Certificate update history-Cause 10,0,
IDE14923-MAS19599,Event information Certificate update history-Cause 11,0,
IDE14923-MAS19600,Event information Certificate update history-Cause 12,0,
IDE14923-MAS19601,Event information Certificate update history-Cause 13,0,
IDE14923-MAS19602,Event information Certificate update history-Cause 14,0,
IDE14923-MAS19603,Event information Certificate update history-Cause 15,0,
IDE14923-MAS19604,Event information Certificate update history-Cause 16,0,
MAS00464-MAS00106,Standard - ambient data 1-Year,2021,
MAS00464-MAS00107,Standard - ambient data 1-Month,5,
MAS00464-MAS00108,Standard - ambient data 1-Day,16,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,53,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,46,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,47,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,921, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,3,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,Audi,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Unknown (0),
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Unknown (0),
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,1,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS01758-IDE00500,Date / time-Hour,16, H
MAS01758-IDE00501,Date / time-Minute,53, min
MAS01758-IDE00502,Date / time-Year,2021, yr
MAS01758-IDE00503,Date / time-Month,5, m
MAS01758-IDE00504,Date / time-Day,16, d
MAS01758-MAS00111,Date / time-Seconds,49, s
MAS01758-MAS02238,Date / time-Up-to-date,Winter time,
MAS01758-MAS03617,Date / time-Time zone,0.00, H
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Not available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,invalid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 03 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,available.,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition not met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition not met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,37,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,FF,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,available.,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,FF FF FF FF FF FF FF FF,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,60 22 40 C0,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,10,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,0,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,118,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 01,
MAS17833,Remaining period of test activation,4294967295, s
MAS18461-MAS18462,FoD product list-Number of function IDs,0,
MAS18461-MAS18463,FoD product list-Product number,0,
MAS18461-MAS18464,FoD product list-Function ID,,
MAS18461-MAS18465,FoD product list-Import regulation,No Info,
MAS18461-MAS18471,FoD product list-Product regulation,No Info,
MAS18461-MAS18474,FoD product list-Change information regulation,No Info,
MAS18461-MAS18477,FoD product list-Notification control,No Info,
MAS18461-MAS18481,FoD product list-Activate regulation,No Info,
MAS18461-MAS18484,FoD product list-Deactivate regulation,No Info,
MAS18461-MAS18487,FoD product list-Warning interval,0,
MAS18461-MAS18488,FoD product list-additional meta info 1,00,
MAS18461-MAS18489,FoD product list-additional meta info 2,00,
MAS18490-IDE06260,Read FoD assignment products on FSIDs-ID number,00 00 00 00,
MAS18490-MAS18463,Read FoD assignment products on FSIDs-Product number,0,
MAS18490-MAS18491,Read FoD assignment products on FSIDs-Number of assignments,0,
MAS20269-MAS20270,ORU unflashed control modules-ORU action numbers,--------,
MAS20269-MAS20271,ORU unflashed control modules-Address of unflashed control modules,00 00,
MAS20269,ORU unflashed control modules,45,
MAS20349-MAS04394,DoIP connection status-Connection status,active,
MAS20349-MAS13793,DoIP connection status-Control module identification,67,
ENG06732-ENG06827,12V_zustart_prohibition-12V_start_system_error,00 00,
ENG06732-ENG06826,12V_zustart_prohibition-12V_zustart_prohibition_on_drive,00 00,
ENG06732-ENG06825,12V_zustart_prohibition-12V_zustart_prohibition_on_stop,00 00,
ENG08764-MAS01867,48V_overvoltage_check-Measurement,OK,
ENG08764-ENG09344,48V_overvoltage_check-Bms_48V_actual_voltage,Initialization,
ENG08764-ENG09345,48V_overvoltage_check-Bms_48V_Soc,Initialization,
ENG08769-MAS11874,48V_Zero_potential_status-Overall status,Initialization,
ENG55049-ENG56272,Authentic_time_current_counter_kl15_since_last_sync-Current_counter_kl15_since_last_sync,7,
ENG55051-ENG56247,Authentic_time_last_client_response-Counter_kl15_since_last_sync,7,
ENG55051-ENG56597,Authentic_time_last_client_response-Current_time_used,2021-05-16T16:47:51Z,
ENG55051-ENG55667,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2021-05-13T22:16:35Z,
ENG04784,Break_Recommendation_Index,1.00,
ENG04785-ENG126257,Break_Recommendation_TTNR-TTNR_DS,0,
ENG04785-ENG126256,Break_Recommendation_TTNR-TTNR_SW,60053,
ENG06743,Challenge_KS,1D D6 20 B1,
ENG06744-MAS06854,Checksumme_KS-Version,81,
ENG06744-MAS06855,Checksumme_KS-Test sum,10 20 EA 95,
ENG08767-ENG09366,coldstart_requirement_engine-requirement_12V_start,not active,
ENG08767-ENG09367,coldstart_requirement_engine-requirement_48V_start,not active,
ENG118784-ENG05030,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Active_Body_Control,not active,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG05036,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Autonomous_Emergency_Breaking,not active,
ENG118784-ENG05035,Driv._Prof._Sel._Coord._Retry_State-Retry_State_battery_management,not active,
ENG118784-ENG118738,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Beam_Control,not active,
ENG118784-ENG05018,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG05023,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Centre_and_rear_axle_differential,not active,
ENG118784-ENG118735,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Climatronic,not active,
ENG118784-ENG05029,Driv._Prof._Sel._Coord._Retry_State-Retry_State_corner_assist,not active,
ENG118784-ENG05032,Driv._Prof._Sel._Coord._Retry_State-Retry_State_cruise_control,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG05024,Driv._Prof._Sel._Coord._Retry_State-Retry_State_e_quattro,not active,
ENG118784-ENG05031,Driv._Prof._Sel._Coord._Retry_State-Retry_State_E_Sound,not active,
ENG118784-ENG05038,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Differential_Lock,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG05037,Driv._Prof._Sel._Coord._Retry_State-Retry_State_engine_operating_state,not active,
ENG118784-ENG05021,Driv._Prof._Sel._Coord._Retry_State-Retry_State_exhaust_gas_flaps,not active,
ENG118784-ENG05039,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Objects,not active,
ENG118784-ENG05040,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Forward_Collision_Warning_Pedestrian,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG05041,Driv._Prof._Sel._Coord._Retry_State-Retry_State_integral_steering,not active,
ENG118784-ENG05034,Driv._Prof._Sel._Coord._Retry_State-Retry_State_lift_control_unit,not active,
ENG118784-ENG05025,Driv._Prof._Sel._Coord._Retry_State-Retry_State_matrixbeam,not active,
ENG118784-ENG05022,Driv._Prof._Sel._Coord._Retry_State-Retry_State_middle_differential,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG05015,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Rear_Axle_Differential,not active,
ENG118784-ENG05027,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_axle_steering,not active,
ENG118784-ENG05017,Driv._Prof._Sel._Coord._Retry_State-Retry_State_ride-height_control_system,not active,
ENG118784-ENG118740,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Routing_Adaption,not active,
ENG118784-ENG05020,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sailing_suggestion,not active,
ENG118784-ENG05033,Driv._Prof._Sel._Coord._Retry_State-Retry_State_servo_tronic,not active,
ENG118784-ENG05019,Driv._Prof._Sel._Coord._Retry_State-Retry_State_sidepanel_seat,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG05026,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Spoiler_Control_Unit,not active,
ENG118784-ENG05028,Driv._Prof._Sel._Coord._Retry_State-Retry_State_stabilisation_control_unit,not active,
ENG118784-ENG118731,Driv._Prof._Sel._Coord._Retry_State-Retry_State_StartStop,not active,
ENG118784-ENG05016,Driv._Prof._Sel._Coord._Retry_State-Retry_State_steering_control_unit,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118786-ENG05042,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile_BMA,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,3,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG06742-MAS02832,eABC_48V_status-Malfunction status,Initialization,
ENG06742-MAS03001,eABC_48V_status-Mode,Initialization,
ENG04786-ENG05075,Ehr_segment_load-attribute_pool,3.50,
ENG04786-ENG05074,Ehr_segment_load-segment_pool,3.50,
ENG04786-ENG05076,Ehr_segment_load-speedlimit_pool,0.00,
ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,468.9, Ah
ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,497.1, Ah
ENG04782,EM_bdm_error_state,0,
ENG106123,EM_blAlternator On,OFF,
ENG26761,EM_Current_Control,not active,
ENG118437,EM_IAlternatorReserve,0.0, A
ENG118434,EM_LoadResponse Time,6, s
ENG106154,EM_PAltMechanical,0, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,99, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,99, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,No enabling,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,No enabling,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,No enabling,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,No enabling,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,No enabling,
ENG118780-ENG04973,EM_Recuperation_Precondition-battery_disconnected,No enabling,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,No enabling,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,No enabling,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,No enabling,
ENG118780-ENG30744,EM_Recuperation_Precondition-dc_source_activity,Release,
ENG118780-ENG30745,EM_Recuperation_Precondition-dc_source_diagnosis,No enabling,
ENG118780-ENG118444,EM_Recuperation_Precondition-generator_workload,No enabling,
ENG118780-ENG31832,EM_Recuperation_Precondition-hv_cutoff_level,No enabling,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,No enabling,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,No enabling,
ENG118780-ENG32123,EM_Recuperation_Precondition-mv_cutoff_level,No enabling,
ENG118780-ENG102605,EM_Recuperation_Precondition-outside_temperature,No enabling,
ENG118780-ENG104256,EM_Recuperation_Precondition-production_mode,No enabling,
ENG118780-ENG04974,EM_Recuperation_Precondition-trailer_dedection,Release,
ENG118780-ENG111086,EM_Recuperation_Precondition-Transport_Mode,No enabling,
ENG106169,EM_valHlkLevelRequirement,Stage 1,
ENG106169,EM_valHlkLevelRequirement,950, W
ENG06717,EM_vehicle_bus_state,01 07 7C FF,
ENG04777,EM_vehicle_state,02 5C,
ENG04779-ENG04996,EM_voltage_control_state-EM_das_control_state,1,
ENG04779-ENG04995,EM_voltage_control_state-EM_gas_control_state,0,
ENG04779-ENG04997,EM_voltage_control_state-EM_ras_control_state,0,
ENG04779-ENG04998,EM_voltage_control_state-EM_Ureg_control_state,1,
ENG04776,EMZ_state,4,
ENG04775,engine_identifier,3,
ENG04780,freewheel_info,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,250100,
ENG118782-ENG05091,Gateway app. software identification-software_version_cGW,------,
ENG118782-ENG05083,Gateway app. software identification-software_version_cha,360201,
ENG118782-ENG05090,Gateway app. software identification-software_version_eHorizont,200100,
ENG118782-ENG05085,Gateway app. software identification-software_version_HvEm,------,
ENG118782-ENG05086,Gateway app. software identification-software_version_HvK,------,
ENG118782-ENG05092,Gateway app. software identification-software_version_MvEM,------,
ENG118782-ENG05093,Gateway app. software identification-software_version_MVK,------,
ENG118782-ENG05084,Gateway app. software identification-software_version_NvEm,240302,
ENG118782-ENG05087,Gateway app. software identification-software_version_ObDc,------,
ENG118782-ENG05088,Gateway app. software identification-software_version_PE,066510,
ENG118782-ENG05089,Gateway app. software identification-software_version_range,200304,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,120300,
ENG04773-ENG120608,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x01,00 00 00,
ENG04773-ENG120609,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x02,00 00 00,
ENG04773-ENG04886,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x03,00 00 00,
ENG04773-ENG31556,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x04,00 00 00,
ENG04773-ENG31557,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x05,00 00 00,
ENG04773-ENG31558,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x06,00 00 00,
ENG04773-ENG31559,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x07,00 00 00,
ENG04773-ENG31560,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x08,00 00 00,
ENG04773-ENG04887,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0A,00 00 00,
ENG04773-ENG04888,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0B,00 00 00,
ENG04773-ENG04889,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0C,00 00 00,
ENG04773-ENG04890,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0E,00 00 00,
ENG04773-ENG04891,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x0F,00 00 00,
ENG04773-ENG04892,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x12,00 00 00,
ENG04773-ENG04893,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x13,00 00 00,
ENG04773-ENG04894,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x14,00 00 00,
ENG04773-ENG04895,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x15,00 00 00,
ENG04773-ENG04896,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x16,00 00 00,
ENG04773-ENG04897,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1A,00 00 00,
ENG04773-ENG04898,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1B,00 00 00,
ENG04773-ENG04899,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1C,00 00 00,
ENG04773-ENG04900,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x1E,00 00 00,
ENG04773-ENG04901,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x23,10 00 00,
ENG04773-ENG04902,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x24,00 00 00,
ENG04773-ENG04903,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x27,04 00 00,
ENG04773-ENG04904,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2A,00 00 00,
ENG04773-ENG04905,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2B,00 00 00,
ENG04773-ENG04906,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2C,00 00 00,
ENG04773-ENG04907,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2D,00 00 00,
ENG04773-ENG04908,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x2E,00 00 00,
ENG04773-ENG04909,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x30,00 00 00,
ENG04773-ENG04910,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x31,00 00 00,
ENG04773-ENG04912,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x3B,00 00 00,
ENG04773-ENG04913,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x41,00 00 00,
ENG04773-ENG04914,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x42,00 00 00,
ENG04773-ENG31561,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x43,00 00 00,
ENG04773-ENG04915,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x44,00 01 00,
ENG04773-ENG04916,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x46,00 00 00,
ENG04773-ENG04917,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x47,02 00 00,
ENG04773-ENG116879,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x49,00 00 00,
ENG04773-ENG04918,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4A,00 00 00,
ENG04773-ENG04919,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4B,01 00 00,
ENG04773-ENG04920,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4C,08 00 00,
ENG04773-ENG04921,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4D,08 00 00,
ENG04773-ENG04922,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4E,00 00 00,
ENG04773-ENG04923,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x4F,00 00 00,
ENG04773-ENG04924,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x53,00 00 00,
ENG04773-ENG04925,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x56,00 00 00,
ENG04773-ENG04926,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x57,00 00 00,
ENG04773-ENG31562,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x59,00 00 00,
ENG04773-ENG04928,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x60,00 00 00,
ENG04773-ENG31563,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x61,00 00 00,
ENG04773-ENG04929,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x63,00 00 00,
ENG04773-ENG04930,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x64,00 00 00,
ENG04773-ENG120610,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x67,00 00 00,
ENG04773-ENG04931,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x69,00 00 00,
ENG04773-ENG04932,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x6A,00 00 00,
ENG04773-ENG04933,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x73,00 00 00,
ENG04773-ENG04934,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x76,00 00 00,
ENG04773-ENG04935,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x77,00 00 00,
ENG04773-ENG04936,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x78,00 00 00,
ENG04773-ENG04937,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7B,00 00 00,
ENG04773-ENG04938,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x7C,00 00 00,
ENG04773-ENG04939,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x80,00 00 00,
ENG04773-ENG04940,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x84,10 00 00,
ENG04773-ENG04941,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x87,08 00 00,
ENG04773-ENG04942,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x88,08 00 00,
ENG04773-ENG31564,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x89,00 00 00,
ENG04773-ENG04943,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8A,00 00 00,
ENG04773-ENG04944,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8B,00 00 00,
ENG04773-ENG120611,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8C,00 00 00,
ENG04773-ENG04945,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8E,00 00 00,
ENG04773-ENG04946,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x8F,00 00 00,
ENG04773-ENG04947,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x93,00 00 00,
ENG04773-ENG04948,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x94,00 00 00,
ENG04773-ENG04949,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x95,08 00 00,
ENG04773-ENG04951,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9C,00 00 00,
ENG04773-ENG04952,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9D,00 00 00,
ENG04773-ENG04953,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0x9E,00 00 00,
ENG04773-ENG04954,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xA0,10 00 00,
ENG04773-ENG31565,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xAE,00 00 00,
ENG04773-ENG00603,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xB5,00 00 00,
ENG04773-ENG120612,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xB7,00 00 00,
ENG04773-ENG31566,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xB8,00 00 00,
ENG04773-ENG120613,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xBA,00 00 00,
ENG04773-ENG120614,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC3,00 00 00,
ENG04773-ENG120615,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC4,00 00 00,
ENG04773-ENG120616,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC5,00 00 00,
ENG04773-ENG120617,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC6,00 01 00,
ENG04773-ENG120618,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC7,00 01 00,
ENG04773-ENG120619,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xC8,00 00 00,
ENG04773-ENG120620,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF0,00 00 00,
ENG04773-ENG120621,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF1,00 00 00,
ENG04773-ENG120622,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF2,00 00 00,
ENG04773-ENG116981,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF3,00 00 00,
ENG04773-ENG00604,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF5,00 00 00,
ENG04773-ENG00605,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF6,00 00 00,
ENG04773-ENG00606,Gateway_Component_List_Cluster Bits-Gateway_Component_List_Cluster Bits_Node_0xF7,00 00 00,
ENG04772-ENG120623,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x01,0,
ENG04772-ENG120624,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x02,0,
ENG04772-ENG04819,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x03,0,
ENG04772-ENG04833,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x1E,0,
ENG04772-ENG04878,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x93,0,
ENG04772-ENG04879,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x94,0,
ENG04772-ENG04880,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x95,0,
ENG04772-ENG04882,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Node_0x9C,0,
ENG04772-ENG31568,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x04,2,
ENG04772-ENG31569,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x05,2,
ENG04772-ENG31570,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x06,2,
ENG04772-ENG31571,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x07,0,
ENG04772-ENG31572,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x08,0,
ENG04772-ENG04820,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0A,0,
ENG04772-ENG04821,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0B,0,
ENG04772-ENG04822,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0C,2,
ENG04772-ENG04823,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0E,2,
ENG04772-ENG04824,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x0F,0,
ENG04772-ENG04825,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x12,2,
ENG04772-ENG04826,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x13,2,
ENG04772-ENG04827,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x14,2,
ENG04772-ENG04828,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x15,2,
ENG04772-ENG04829,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x16,0,
ENG04772-ENG04830,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1A,0,
ENG04772-ENG04831,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1B,0,
ENG04772-ENG04832,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x1C,0,
ENG04772-ENG04834,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x23,2,
ENG04772-ENG06781,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x24,0,
ENG04772-ENG04835,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x27,0,
ENG04772-ENG04836,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2A,0,
ENG04772-ENG04837,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2B,0,
ENG04772-ENG04838,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2C,0,
ENG04772-ENG04839,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2D,0,
ENG04772-ENG04840,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x2E,0,
ENG04772-ENG04841,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x30,0,
ENG04772-ENG04842,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x31,2,
ENG04772-ENG04844,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x3B,0,
ENG04772-ENG04845,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x41,0,
ENG04772-ENG04846,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x42,2,
ENG04772-ENG31573,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x43,0,
ENG04772-ENG04847,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x44,2,
ENG04772-ENG04848,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x46,0,
ENG04772-ENG04849,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x47,0,
ENG04772-ENG116935,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x49,0,
ENG04772-ENG04850,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4A,2,
ENG04772-ENG04851,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4B,2,
ENG04772-ENG04852,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4C,2,
ENG04772-ENG04853,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4D,0,
ENG04772-ENG04854,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4E,2,
ENG04772-ENG31574,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x4F,2,
ENG04772-ENG04856,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x53,2,
ENG04772-ENG04857,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x56,0,
ENG04772-ENG04858,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x57,0,
ENG04772-ENG31575,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x59,0,
ENG04772-ENG04860,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x60,0,
ENG04772-ENG31576,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x61,0,
ENG04772-ENG06782,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x63,0,
ENG04772-ENG04861,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x64,0,
ENG04772-ENG120625,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x67,2,
ENG04772-ENG04862,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x69,0,
ENG04772-ENG04863,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x6A,0,
ENG04772-ENG04864,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x73,2,
ENG04772-ENG04865,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x76,2,
ENG04772-ENG04866,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x77,0,
ENG04772-ENG04867,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x78,0,
ENG04772-ENG04868,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7B,2,
ENG04772-ENG04869,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x7C,2,
ENG04772-ENG04870,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x80,2,
ENG04772-ENG04871,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x84,2,
ENG04772-ENG04872,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x87,0,
ENG04772-ENG04873,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x88,0,
ENG04772-ENG31577,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x89,0,
ENG04772-ENG04874,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8A,2,
ENG04772-ENG04875,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8B,2,
ENG04772-ENG120626,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8C,0,
ENG04772-ENG04876,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8E,0,
ENG04772-ENG04877,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x8F,0,
ENG04772-ENG04883,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9D,0,
ENG04772-ENG04884,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0x9E,0,
ENG04772-ENG04885,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xA0,0,
ENG04772-ENG31578,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xAE,0,
ENG04772-ENG00607,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB5,0,
ENG04772-ENG120627,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB7,2,
ENG04772-ENG31579,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xB8,2,
ENG04772-ENG120628,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xBA,0,
ENG04772-ENG120629,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC3,0,
ENG04772-ENG120630,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC4,0,
ENG04772-ENG120631,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC5,0,
ENG04772-ENG120632,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC6,0,
ENG04772-ENG120633,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC7,0,
ENG04772-ENG120634,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xC8,0,
ENG04772-ENG120635,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF0,2,
ENG04772-ENG120636,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF1,0,
ENG04772-ENG120637,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF2,2,
ENG04772-ENG117001,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF3,0,
ENG04772-ENG00608,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF5,2,
ENG04772-ENG00609,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF6,2,
ENG04772-ENG00610,Gateway_Component_List_Supply_Typ-Gateway_Component_List_Supply_Typ_Node_0xF7,0,
ENG55095-ENG55684,GW_component_failure_01-EEPROM_failure,TestComplete_PASS,
ENG55095-ENG56255,GW_component_failure_01-GW_component_failure,TestComplete_PASS,
ENG55095-ENG55931,GW_component_failure_01-RAM_failure,TestComplete_PASS,
ENG55095-ENG55804,GW_component_failure_01-ROM_failure,TestComplete_PASS,
ENG55095-ENG56627,GW_component_failure_01-WD_failure,TestComplete_PASS,
ENG55095-ENG56336,GW_component_failure_01-xx_failure,TestComplete_PASS,
ENG114576-ENG115215,hvk_Electrical_component_error-eem_component_01,0,
ENG114576-ENG115086,hvk_Electrical_component_error-eem_component_02,0,
ENG114576-ENG115120,hvk_Electrical_component_error-eem_component_03,0,
ENG114576-ENG115092,hvk_Electrical_component_error-eem_component_04,0,
ENG114576-ENG115192,hvk_Electrical_component_error-eem_component_05,0,
ENG114576-ENG114919,hvk_Electrical_component_error-eem_component_06,0,
ENG114576-ENG114932,hvk_Electrical_component_error-eem_component_07,0,
ENG114576-ENG115054,hvk_Electrical_component_error-eem_component_08,0,
ENG114576-ENG115197,hvk_Electrical_component_error-eem_component_09,0,
ENG114576-ENG115157,hvk_Electrical_component_error-eem_component_10,0,
ENG114576-ENG115128,hvk_Electrical_component_error-eem_component_11,0,
ENG114576-ENG115153,hvk_Electrical_component_error-eem_component_12,0,
ENG114576-ENG115002,hvk_Electrical_component_error-eem_component_13,0,
ENG114576-ENG114953,hvk_Electrical_component_error-eem_component_14,0,
ENG114576-ENG114956,hvk_Electrical_component_error-eem_component_15,0,
ENG114576-ENG114984,hvk_Electrical_component_error-eem_component_16,0,
ENG06145-ENG06200,hvk_high_voltag_total_discharge_prevention-dcdc_target_mode,2,
ENG06145-ENG06199,hvk_high_voltag_total_discharge_prevention-hvk_total_discharge_prevention_state,0,
ENG06145-ENG06201,hvk_high_voltag_total_discharge_prevention-tme_ekk_target_mode,1,
ENG06145-ENG06202,hvk_high_voltag_total_discharge_prevention-tme_hvptc_target_mode,1,
ENG06144-ENG30377,hvk_high_voltage_zero_potential-awc_zero_potential,0,
ENG06144-ENG06195,hvk_high_voltage_zero_potential-bms_failure_state,0,
ENG06144-ENG06192,hvk_high_voltage_zero_potential-bms_zero_potential,2,
ENG06144-ENG06194,hvk_high_voltage_zero_potential-em1_zero_potential,2,
ENG06144-ENG39278,hvk_high_voltage_zero_potential-em2_zero_potential,2,
ENG06144-ENG39279,hvk_high_voltage_zero_potential-em3_zero_potential,0,
ENG06144-ENG39295,hvk_high_voltage_zero_potential-Flexray_status,1,
ENG06144-ENG39330,hvk_high_voltage_zero_potential-HCAN_status,1,
ENG06144-ENG06198,hvk_high_voltage_zero_potential-hvk_total_zero_potential,2,
ENG06144-ENG06196,hvk_high_voltage_zero_potential-hvlm_connector_plug_state,3,
ENG06144-ENG39358,hvk_high_voltage_zero_potential-lad_2_zero_potential,0,
ENG06144-ENG06193,hvk_high_voltage_zero_potential-lad_zero_potential,2,
ENG26975-ENG30888,MFLe_LIN-DI_Emblem,OFF,
ENG26975-ENG46163,MFLe_LIN-DI_KL_50xs,55,
ENG26975-ENG46164,MFLe_LIN-DI_KL_58xt,55,
ENG26975-ENG30921,MFLe_LIN-Dimmung_01_gueltig,valid,
ENG26975-ENG31890,MFLe_LIN-Klemme_15_MFL,On,
ENG26975-ENG31892,MFLe_LIN-KLR_Modusanforderung,Debug_mode,
ENG26975-ENG31980,MFLe_LIN-LR_HZG_Freigabe,no_restriction,
ENG26975-ENG31981,MFLe_LIN-LR_HZG_on_off,OFF,
ENG26975-ENG32052,MFLe_LIN-MFLe_Anzeige_LaunchControl,display_off,
ENG26975-ENG32053,MFLe_LIN-MFLe_Anzeige_MAP,OFF,
ENG26975-ENG32054,MFLe_LIN-MFLe_Anzeige_Sport,display_off,
ENG26975-ENG32055,MFLe_LIN-MFLe_Anzeige_Sport_Plus,display_off,
ENG26975-ENG32056,MFLe_LIN-MFLe_Tastencode_alt_neu,apply_keycode_new,
ENG26975-ENG32226,MFLe_LIN-P_Mode_MFL,OFF,
ENG06740,MVEM_dc_current_Mv,204.0, A
ENG06739,MVEM_dc_power_desired,0, W
ENG06734,MVEM_DC_voltage_desired,63.50, V
ENG06741,MVEM_dc_voltage_Mv,63.25, V
ENG06736-ENG09198,MVEM_Derating_voltage-Derating_group_A,63.50, V
ENG06736-ENG09199,MVEM_Derating_voltage-Derating_group_B,63.50, V
ENG06736-ENG09200,MVEM_Derating_voltage-Derating_group_C,63.50, V
ENG06736-ENG09337,MVEM_Derating_voltage-Derating_Umax_feedback,63.5, V
ENG06738,MVEM_EMG_level_of_capacity,0.025, %
ENG06737,MVEM_Emg_voltage_desired,63.50, V
ENG06733,MVEM_Mv_current,-11, A
ENG08763-ENG09342,MVEM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG08763-ENG09343,MVEM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG08762-ENG09338,MVEM_release-12V_coldstart_release,No enabling,
ENG08762-ENG09339,MVEM_release-12V_warmstart_release,No enabling,
ENG08762-ENG09340,MVEM_release-48V_coldstart_release,No enabling,
ENG08762-ENG09341,MVEM_release-start_stopp_support_release,No enabling,
ENG06735,MVEM_RSG_maximal_current,508, A
ENG08761-ENG09336,MVEM_RSG_maximal_voltage-RSG_maximal_voltage,63.50, V
ENG06718-ENG120644,NVEM_12Vrsg_input_parameter-rsg_cutoff_rotation_speed,3000, /min
ENG06718-ENG06798,NVEM_12Vrsg_input_parameter-rsg_exciter current_limit,16.0, A
ENG06718-ENG06800,NVEM_12Vrsg_input_parameter-rsg_load_response_time,3, s
ENG06718-ENG06801,NVEM_12Vrsg_input_parameter-rsg_target_mode,0,
ENG06718-ENG06797,NVEM_12Vrsg_input_parameter-rsg_voltage_desired,10.6, V
ENG04778-ENG55511,NVEM_Hlr_release-Release_FlHz_hl,No enabling,
ENG04778-ENG55512,NVEM_Hlr_release-Release_FlHz_hr,No enabling,
ENG04778-ENG55513,NVEM_Hlr_release-Release_FlHz_rest_seat,No enabling,
ENG04778-ENG55514,NVEM_Hlr_release-Release_FlHz_vl,No enabling,
ENG04778-ENG55515,NVEM_Hlr_release-Release_FlHz_vr,No enabling,
ENG04778-ENG04987,NVEM_Hlr_release-Release_FSH,OFF,
ENG04778-ENG04986,NVEM_Hlr_release-Release_HSH,No enabling,
ENG04778-ENG04989,NVEM_Hlr_release-Release_KRH_vl,No enabling,
ENG04778-ENG04988,NVEM_Hlr_release-Release_KRH_vr,No enabling,
ENG04778-ENG04990,NVEM_Hlr_release-Release_LRH,No enabling,
ENG04778-ENG04991,NVEM_Hlr_release-Release_PTC,No enabling,
ENG04778-ENG04992,NVEM_Hlr_release-Release_PTC_linear,0, W
ENG04778-ENG04975,NVEM_Hlr_release-Release_SIH_Fond,Release,
ENG04778-ENG04979,NVEM_Hlr_release-Release_SIH_hl,No enabling,
ENG04778-ENG04978,NVEM_Hlr_release-Release_SIH_hr,No enabling,
ENG04778-ENG04977,NVEM_Hlr_release-Release_SIH_vl,No enabling,
ENG04778-ENG04976,NVEM_Hlr_release-Release_SIH_vr,No enabling,
ENG04778-ENG04983,NVEM_Hlr_release-Release_SIL_hl,No enabling,
ENG04778-ENG04982,NVEM_Hlr_release-Release_SIL_hr,No enabling,
ENG04778-ENG04981,NVEM_Hlr_release-Release_SIL_vl,No enabling,
ENG04778-ENG04980,NVEM_Hlr_release-Release_SIL_vr,No enabling,
ENG04778-ENG04985,NVEM_Hlr_release-Release_Sp_heatin_codriver,No enabling,
ENG04778-ENG04984,NVEM_Hlr_release-Release_Sp_heatin_driver,No enabling,
ENG04778-ENG32447,NVEM_Hlr_release-Release_TCH,No enabling,
ENG06723,NVEM_Hv_DcDc_curren_nv,25, A
ENG06725,NVEM_Hv_DcDc_current_reserve_nv,183, A
ENG06724,NVEM_Hv_DcDc_level_of_capacity,12.8, %
ENG06726,NVEM_Hv_DcDc_voltage_desired_nv,14.4, V
ENG06722,NVEM_Hv_DcDc_voltage_nv,14.4, V
ENG04783,NVEM_hybrid_info,0,
ENG06730,NVEM_Mv_DcDc_voltage_desired_nv,10.6, V
ENG04774-ENG06796,NVEM_Voltage_Request-Voltage_Request_BCM,not active,
ENG04774-ENG04969,NVEM_Voltage_Request-Voltage_Request_ClimatControl,not active,
ENG04774-ENG04968,NVEM_Voltage_Request-Voltage_Request_engine,not active,
ENG04774-ENG04966,NVEM_Voltage_Request-Voltage_Request_EPS,not active,
ENG04774-ENG04967,NVEM_Voltage_Request-Voltage_Request_ESP,not active,
ENG04774-ENG04970,NVEM_Voltage_Request-Voltage_Request_GearControl,not active,
ENG04774-ENG04971,NVEM_Voltage_Request-Voltage_Request_Reduction_Alternator_Load,not active,
ENG55147-ENG56699,OBD_CALID-CALID,GW4KL468C-0602--,
ENG55148-ENG55422,OBD_CVN-CVN,02 0D D2 19,
ENG04788-ENG98667,operation_hours-Kilometers,291,
ENG08771-ENG09431,Stack_Size_Max-Stack_Size_Max_ISR,6, %
ENG08771-ENG09408,Stack_Size_Max-Stack_Size_Max_Task_01,30, %
ENG08771-ENG09409,Stack_Size_Max-Stack_Size_Max_Task_02,43, %
ENG08771-ENG09410,Stack_Size_Max-Stack_Size_Max_Task_03,32, %
ENG08771-ENG09411,Stack_Size_Max-Stack_Size_Max_Task_04,36, %
ENG08771-ENG09412,Stack_Size_Max-Stack_Size_Max_Task_05,28, %
ENG08771-ENG09413,Stack_Size_Max-Stack_Size_Max_Task_06,68, %
ENG08771-ENG09414,Stack_Size_Max-Stack_Size_Max_Task_07,65, %
ENG08771-ENG09415,Stack_Size_Max-Stack_Size_Max_Task_08,40, %
ENG08771-ENG09416,Stack_Size_Max-Stack_Size_Max_Task_09,24, %
ENG08771-ENG09417,Stack_Size_Max-Stack_Size_Max_Task_10,10, %
ENG08771-ENG09418,Stack_Size_Max-Stack_Size_Max_Task_11,71, %
ENG08771-ENG09419,Stack_Size_Max-Stack_Size_Max_Task_12,31, %
ENG08771-ENG09420,Stack_Size_Max-Stack_Size_Max_Task_13,31, %
ENG08771-ENG09421,Stack_Size_Max-Stack_Size_Max_Task_14,0, %
ENG08771-ENG09422,Stack_Size_Max-Stack_Size_Max_Task_15,0, %
ENG08771-ENG09423,Stack_Size_Max-Stack_Size_Max_Task_16,0, %
ENG08771-ENG09424,Stack_Size_Max-Stack_Size_Max_Task_17,0, %
ENG08771-ENG09425,Stack_Size_Max-Stack_Size_Max_Task_18,0, %
ENG08771-ENG09426,Stack_Size_Max-Stack_Size_Max_Task_19,0, %
ENG08771-ENG09427,Stack_Size_Max-Stack_Size_Max_Task_20,0, %
ENG08771-ENG09428,Stack_Size_Max-Stack_Size_Max_Task_21,0, %
ENG08771-ENG09429,Stack_Size_Max-Stack_Size_Max_Task_22,0, %
ENG08771-ENG09430,Stack_Size_Max-Stack_Size_Max_Task_23,0, %
ENG04781,StartStop_info,0,
ENG08770-ENG09376,State_Dataset_AuxFunktions-Datensatz_0,valid,
ENG08770-ENG09377,State_Dataset_AuxFunktions-Datensatz_1,valid,
ENG08770-ENG09392,State_Dataset_AuxFunktions-Datensatz_10,valid,
ENG08770-ENG09393,State_Dataset_AuxFunktions-Datensatz_11,valid,
ENG08770-ENG09394,State_Dataset_AuxFunktions-Datensatz_12,valid,
ENG08770-ENG09395,State_Dataset_AuxFunktions-Datensatz_13,valid,
ENG08770-ENG09396,State_Dataset_AuxFunktions-Datensatz_14,valid,
ENG08770-ENG09397,State_Dataset_AuxFunktions-Datensatz_15,valid,
ENG08770-ENG09398,State_Dataset_AuxFunktions-Datensatz_16,valid,
ENG08770-ENG09399,State_Dataset_AuxFunktions-Datensatz_17,valid,
ENG08770-ENG09400,State_Dataset_AuxFunktions-Datensatz_18,valid,
ENG08770-ENG09401,State_Dataset_AuxFunktions-Datensatz_19,valid,
ENG08770-ENG09402,State_Dataset_AuxFunktions-Datensatz_1A,valid,
ENG08770-ENG09403,State_Dataset_AuxFunktions-Datensatz_1B,valid,
ENG08770-ENG09404,State_Dataset_AuxFunktions-Datensatz_1C,valid,
ENG08770-ENG09405,State_Dataset_AuxFunktions-Datensatz_1D,valid,
ENG08770-ENG09406,State_Dataset_AuxFunktions-Datensatz_1E,valid,
ENG08770-ENG09407,State_Dataset_AuxFunktions-Datensatz_1F,valid,
ENG08770-ENG09378,State_Dataset_AuxFunktions-Datensatz_2,valid,
ENG08770-ENG09379,State_Dataset_AuxFunktions-Datensatz_3,valid,
ENG08770-ENG09380,State_Dataset_AuxFunktions-Datensatz_4,valid,
ENG08770-ENG09381,State_Dataset_AuxFunktions-Datensatz_5,valid,
ENG08770-ENG09382,State_Dataset_AuxFunktions-Datensatz_6,valid,
ENG08770-ENG09383,State_Dataset_AuxFunktions-Datensatz_7,valid,
ENG08770-ENG09384,State_Dataset_AuxFunktions-Datensatz_8,valid,
ENG08770-ENG09385,State_Dataset_AuxFunktions-Datensatz_9,valid,
ENG08770-ENG09386,State_Dataset_AuxFunktions-Datensatz_A,valid,
ENG08770-ENG09387,State_Dataset_AuxFunktions-Datensatz_B,valid,
ENG08770-ENG09388,State_Dataset_AuxFunktions-Datensatz_C,valid,
ENG08770-ENG09389,State_Dataset_AuxFunktions-Datensatz_D,valid,
ENG08770-ENG09390,State_Dataset_AuxFunktions-Datensatz_E,valid,
ENG08770-ENG09391,State_Dataset_AuxFunktions-Datensatz_F,valid,
ENG06146-MAS00106,Status_to_a_agree_a_appointment_online-Year,2000,
ENG06146-MAS00107,Status_to_a_agree_a_appointment_online-Month,0,
ENG06146-MAS00108,Status_to_a_agree_a_appointment_online-Day,0,
ENG06146-MAS00109,Status_to_a_agree_a_appointment_online-Hours,0,
ENG06146-MAS00110,Status_to_a_agree_a_appointment_online-Minutes,0,
ENG06146-MAS00111,Status_to_a_agree_a_appointment_online-Seconds,0,
ENG06146-ENG28929,Status_to_a_agree_a_appointment_online-Status_OTV_remind_Flag,no_Set,
ENG06146-ENG28928,Status_to_a_agree_a_appointment_online-Status_OTV_Trigger,no_Set,
ENG08634-ENG120595,Transportmode_Status-Transport_Protection,not activated,
ENG08634-ENG98982,Transportmode_Status-Transportmode,not activated,
ENG27267-ENG05094,Voltage_Comfort_2_CAN-Voltage_CAN_High,2.40, V
ENG27267-ENG05095,Voltage_Comfort_2_CAN-Voltage_CAN_Low,0.00, V
ENG04789-ENG05094,Voltage_Comfort_CAN-Voltage_CAN_High,2.46, V
ENG04789-ENG05095,Voltage_Comfort_CAN-Voltage_CAN_Low,0.00, V
ENG55183-ENG05094,Voltage_Connect_CAN-Voltage_CAN_High,2.32, V
ENG55183-ENG05095,Voltage_Connect_CAN-Voltage_CAN_Low,0.00, V
ENG27268-ENG05094,Voltage_Dashboard_CAN-Voltage_CAN_High,2.44, V
ENG27268-ENG05095,Voltage_Dashboard_CAN-Voltage_CAN_Low,0.00, V
ENG04792-ENG05094,Voltage_Extended_CAN-Voltage_CAN_High,2.42, V
ENG04792-ENG05095,Voltage_Extended_CAN-Voltage_CAN_Low,0.00, V
ENG04790-ENG05094,Voltage_Hybrid_CAN-Voltage_CAN_High,2.44, V
ENG04790-ENG05095,Voltage_Hybrid_CAN-Voltage_CAN_Low,0.00, V
ENG04791-ENG05094,Voltage_Infotainment_CAN-Voltage_CAN_High,2.36, V
ENG04791-ENG05095,Voltage_Infotainment_CAN-Voltage_CAN_Low,0.00, V
ENG55196,Wakelocks,not activated,
ENG55196,Wakelocks,activated,
Elapsed Time: 02:51
blockmap-2B-3Q0-905-861-C_WA1AAAGE8MB028917-20210516-1203.CSV
;SW:3Q0-905-861-C   HW:3Q0-905-861-C ---  Steer. Col. Lock
;Component:ELV-MLBevo    H06 0020, Coding:8800000000000000
;EV_ELVMarqMQBA0,002004,EV_ELVMarqMQBA0_VW53.rod
;Sunday,16,May,2021,12:03:44:36589
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210508 DS325.1
;VCID: 343115FC3EB3817B5BB-8060
Group,Description,Actual
IDE00019,Voltage terminal 30,14.2,
IDE00021,Engine RPM,0.00, /min
IDE00021-MAS00058,Engine RPM-Implausible,No,
IDE00021-MAS00103,Engine RPM-invalid,No,
IDE00021-MAS02239,Engine RPM-outdated,No,
IDE00021-MAS02246,Engine RPM-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,OK,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,2,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,152,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,For,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine RPM,Condition met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS08251,Locking requirements-Communication status signal ESP_21,Condition met,
IDE06746-MAS08252,Locking requirements-Communication status signal Klemmenstatus_01,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Cyclical Reception Signal ESP_21,Condition met,
IDE06746-MAS08792,Locking requirements-Cyclical Reception Signal ESP_10,Condition met,
IDE06746-MAS08794,Locking requirements-Cyclical Reception Signal Terminal Status_01,Condition met,
IDE06746-MAS11697,Locking requirements-Communication status signal ESP_10,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2021,
MAS00464-MAS00107,Standard - ambient data 1-Month,5,
MAS00464-MAS00108,Standard - ambient data 1-Day,16,
MAS00464-MAS00109,Standard - ambient data 1-Hours,12,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,3,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,27,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,47,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,921, km
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG31613,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG31614,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,255,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Confirmed,
Elapsed Time: 00:04
blockmap-36-4M6-959-760_WA1AAAGE8MB028917-20210516-1203.CSV
;SW:4M6-959-760   HW:4M4-959-760 ---  Seat Mem. Drvr
;Component:MEM-FS        009 0064, Coding:015C1A400000B4010003010101010000000000000000000000000000004000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_VW38.rod
;Sunday,16,May,2021,12:03:54:36589
;VCID: 7BA3FEC0536D8E03DA1-802E
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,14.30, V
IDE00102,Control Module temperature,51,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,33550,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32405,
IDE06510-MAS02282,Adjustment for backrest angle-Position,32807,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,20,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,21,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Norming,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1145,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,33346,
IDE06511-MAS01391,Seat height adjustment-Block 2,32770,
IDE06511-MAS02282,Seat height adjustment-Position,33095,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,35,
IDE06511-MAS04160,Seat height adjustment-Load change,69,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Norming,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,576,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,32901,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32242,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,32901,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,0,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,363,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Norming,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,659,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,33041,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32767,
IDE06683-MAS02282,Seat inclination adjustment-Position,32883,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,19,
IDE06683-MAS04160,Seat inclination adjustment-Load change,44,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,274,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,not normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,not normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,32806,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,32956,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,32525,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,32767,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,32806,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,33096,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,32793,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,32883,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,32806,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,33149,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,32838,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,32767,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,32806,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,33096,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,32901,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,32883,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,32806,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,33096,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,32793,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,32883,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Norming,not normed,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Norming,not normed,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Paddle,Not operated,
IDE09082,Massage button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not normed,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not normed,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not normed,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not normed,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not normed,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not normed,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not normed,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not normed,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Norming,not normed,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Norming,not normed,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Norming,not normed,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,not normed,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,not normed,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG08879-IDE06510,Account_1-Adjustment for backrest angle,32806,
ENG08879-IDE06511,Account_1-Seat height adjustment,33149,
ENG08879-IDE06512,Account_1-Adjustment for seat forward/back position,32838,
ENG08879-IDE06683,Account_1-Seat inclination adjustment,32767,
ENG08879-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG08879-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG08879-IDE08989,Account_1-Seat depth adjustment,0,
ENG08879-IDE08990,Account_1-Backrest top adjustment,0,
ENG08879-IDE08991,Account_1-Belt height adjustment,0,
ENG08879-IDE11024,Account_1-Headrest height adjustment,0,
ENG08880-IDE06510,Account_2-Adjustment for backrest angle,32806,
ENG08880-IDE06511,Account_2-Seat height adjustment,33096,
ENG08880-IDE06512,Account_2-Adjustment for seat forward/back position,32901,
ENG08880-IDE06683,Account_2-Seat inclination adjustment,32883,
ENG08880-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG08880-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG08880-IDE08989,Account_2-Seat depth adjustment,0,
ENG08880-IDE08990,Account_2-Backrest top adjustment,0,
ENG08880-IDE08991,Account_2-Belt height adjustment,0,
ENG08880-IDE11024,Account_2-Headrest height adjustment,0,
ENG08881-IDE06510,Account_3-Adjustment for backrest angle,32806,
ENG08881-IDE06511,Account_3-Seat height adjustment,33096,
ENG08881-IDE06512,Account_3-Adjustment for seat forward/back position,32793,
ENG08881-IDE06683,Account_3-Seat inclination adjustment,32883,
ENG08881-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG08881-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG08881-IDE08989,Account_3-Seat depth adjustment,0,
ENG08881-IDE08990,Account_3-Backrest top adjustment,0,
ENG08881-IDE08991,Account_3-Belt height adjustment,0,
ENG08881-IDE11024,Account_3-Headrest height adjustment,0,
ENG08882-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG08882-IDE06511,Account_4-Seat height adjustment,0,
ENG08882-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG08882-IDE06683,Account_4-Seat inclination adjustment,0,
ENG08882-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG08882-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG08882-IDE08989,Account_4-Seat depth adjustment,0,
ENG08882-IDE08990,Account_4-Backrest top adjustment,0,
ENG08882-IDE08991,Account_4-Belt height adjustment,0,
ENG08882-IDE11024,Account_4-Headrest height adjustment,0,
ENG08883-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG08883-IDE06511,Account_5-Seat height adjustment,0,
ENG08883-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG08883-IDE06683,Account_5-Seat inclination adjustment,0,
ENG08883-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG08883-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG08883-IDE08989,Account_5-Seat depth adjustment,0,
ENG08883-IDE08990,Account_5-Backrest top adjustment,0,
ENG08883-IDE08991,Account_5-Belt height adjustment,0,
ENG08883-IDE11024,Account_5-Headrest height adjustment,0,
ENG08884-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG08884-IDE06511,Account_6-Seat height adjustment,0,
ENG08884-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG08884-IDE06683,Account_6-Seat inclination adjustment,0,
ENG08884-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG08884-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG08884-IDE08989,Account_6-Seat depth adjustment,0,
ENG08884-IDE08990,Account_6-Backrest top adjustment,0,
ENG08884-IDE08991,Account_6-Belt height adjustment,0,
ENG08884-IDE11024,Account_6-Headrest height adjustment,0,
ENG08885-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG08885-IDE06511,Account_7-Seat height adjustment,0,
ENG08885-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG08885-IDE06683,Account_7-Seat inclination adjustment,0,
ENG08885-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG08885-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG08885-IDE08989,Account_7-Seat depth adjustment,0,
ENG08885-IDE08990,Account_7-Backrest top adjustment,0,
ENG08885-IDE08991,Account_7-Belt height adjustment,0,
ENG08885-IDE11024,Account_7-Headrest height adjustment,0,
ENG08878-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG08878-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG08878-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG08878-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG08878-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG08878-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG08878-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG08878-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG08878-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG08878-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG08878-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG08878-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG08878-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG08878-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG08878-ENG09596,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG08878-ENG09597,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG08878-ENG09595,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG05253-ENG101098,crash_precrash-Crash,not active,
ENG05253-ENG00891,crash_precrash-Precrash,not active,
ENG05258-ENG05268,Entnormierursache-Axis_1,Normierroutine,
ENG05258-ENG05277,Entnormierursache-Axis_10,Achse decodiert,
ENG05258-ENG05269,Entnormierursache-Axis_2,Normierroutine,
ENG05258-ENG05270,Entnormierursache-Axis_3,Normierroutine,
ENG05258-ENG05271,Entnormierursache-Axis_4,Normierroutine,
ENG05258-ENG05272,Entnormierursache-Axis_5,Achse decodiert,
ENG05258-ENG05273,Entnormierursache-Axis_6,Achse decodiert,
ENG05258-ENG05274,Entnormierursache-Axis_7,Achse decodiert,
ENG05258-ENG05275,Entnormierursache-Axis_8,Achse decodiert,
ENG05258-ENG05276,Entnormierursache-Axis_9,Achse decodiert,
ENG116729-ENG117054,info_developer-ax_da,80 85 7D F2 80 85 00 07 80 27 7E 95 83 0E 00 07 81 47 80 02 82 42 00 07 80 73 7F FF 81 11 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG116729-ENG117006,info_developer-gl_lo,34 4D 36 39 35 39 37 36 30 20 20 00 00 00 00 00 30 30 36 32 00 00 00 00 32 35 33 35 00 00 00 00 53 43 58 58 58 43 38 42 41 53 49 53 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116875,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 06 00 00 03 03 04 04 04 00 00 00 00,
ENG116729-ENG117035,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116729-ENG116968,info_developer-so_deb,00 00 00 00 00 00 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG05278-ENG05354,key_memory_activated-mmi_key_memory_activated,active,
ENG26210-ENG30378,Maximum travel-Axis_1_current,659,
ENG26210-ENG30379,Maximum travel-Axis_1_last,0,
ENG26210-ENG30380,Maximum travel-Axis_10_current,65535,
ENG26210-ENG30381,Maximum travel-Axis_10_last,0,
ENG26210-ENG30382,Maximum travel-Axis_2_current,1145,
ENG26210-ENG30383,Maximum travel-Axis_2_last,0,
ENG26210-ENG30384,Maximum travel-Axis_3_current,576,
ENG26210-ENG30385,Maximum travel-Axis_3_last,0,
ENG26210-ENG30386,Maximum travel-Axis_4_current,274,
ENG26210-ENG30387,Maximum travel-Axis_4_last,0,
ENG26210-ENG30388,Maximum travel-Axis_5_current,65535,
ENG26210-ENG30389,Maximum travel-Axis_5_last,0,
ENG26210-ENG30390,Maximum travel-Axis_6_current,65535,
ENG26210-ENG30391,Maximum travel-Axis_6_last,0,
ENG26210-ENG30392,Maximum travel-Axis_7_current,65535,
ENG26210-ENG30393,Maximum travel-Axis_7_last,0,
ENG26210-ENG30394,Maximum travel-Axis_8_current,65535,
ENG26210-ENG30395,Maximum travel-Axis_8_last,0,
ENG26210-ENG30396,Maximum travel-Axis_9_current,65535,
ENG26210-ENG30397,Maximum travel-Axis_9_last,0,
ENG05251-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG05251-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG05251-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG05251-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG05251-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG05251-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG05251-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG05251-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG05252-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG05252-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,active,
ENG05252-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,active,
ENG05252-ENG09278,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG05252-ENG05263,Memory_ID_CAN_2-Hardware_onoff,active,
ENG05252-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG05252-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG05252-ENG116986,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG26976-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG26976-ENG116860,missing_pre_conditions-_reserviert,0,
ENG26976-ENG30399,missing_pre_conditions-backrest_locked,active,
ENG26976-ENG30400,missing_pre_conditions-backrest_unlocked,active,
ENG26976-ENG30434,missing_pre_conditions-button_pressed,not active,
ENG26976-ENG30644,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG26976-ENG32216,missing_pre_conditions-other_adjustment_already_active,not active,
ENG26976-ENG100589,missing_pre_conditions-Reserviert 2,0,
ENG26976-ENG32451,missing_pre_conditions-reset_problem,not active,
ENG26976-ENG32661,missing_pre_conditions-speed_above_5kmh,not active,
ENG26976-ENG28397,missing_pre_conditions-Voltage_supply,not active,
ENG27030-ENG30602,personalization_last_function-cause_of_termination,0,
ENG27030,personalization_last_function,none,
ENG27030-ENG99298,personalization_last_function-State,none,
ENG05256-ENG05265,pwm_generator-pwm_generator_group_1_overload,not active,
ENG05256-ENG05266,pwm_generator-pwm_generator_group_2_overload,not active,
ENG05254-ENG99389,Resets-Resetcounter,16,
ENG05257-ENG05267,sbc-sbc_overload,not active,
ENG05279-ENG05366,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG05279-ENG05362,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG05279-ENG05369,Seat_Actual_Positions-Current_Position_kks,32768,
ENG05279-ENG05365,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG05279-ENG05359,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG05279-ENG05364,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG05279-ENG05363,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG05279-ENG05361,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG05279-ENG05356,Seat_Actual_Positions-Current_Position_lnv,32807,
ENG05279-ENG05367,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG05279-ENG05368,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG05279-ENG05357,Seat_Actual_Positions-Current_Position_shv,33095,
ENG05279-ENG05355,Seat_Actual_Positions-Current_Position_slv,32901,
ENG05279-ENG05358,Seat_Actual_Positions-Current_Position_snv,32883,
ENG05279-ENG05360,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG05349,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG05350,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG05351,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG05352,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG05353,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,Key 1,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,Key 1,
ENG123053-ENG05345,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG05340,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG05346,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG05343,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG05348,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG05347,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG05344,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG05341,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG05342,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG05339,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG27116-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG27116-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG27116-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG27116-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG27116-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG27116-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG27116-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG27116-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG27116-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG27116-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG27117-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG27117-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG27117-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG27117-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG27117-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG27117-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG27117-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG27117-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG27117-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG27117-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG27118-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG27118-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG27118-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG27118-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG27118-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG27118-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG27118-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG27118-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG27118-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG27118-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG05255-ENG116986,Source_Last_Reset-Low_Voltage,not active,
ENG05255-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,active,
ENG05255-ENG123072,Source_Last_Reset-Power_On_Reset,not active,
ENG05255-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG05255-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG05255-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:22
blockmap-3C-4N0-907-566-L_WA1AAAGE8MB028917-20210516-1204.CSV
;SW:4N0-907-566-L   HW:4N0-907-566-A ---  Lane Change
;Component:MRR_HR H14 0487, Coding:0FDC00
;EV_RearRadarS1DelphAU651,001022,EV_RearRadarS1DelphAU651.rod
;Sunday,16,May,2021,12:04:38:36589
;VCID: 3FDB4AD007F55223B69-806A
IDE00010,Serial number,21002000790208,
IDE00018,Voltage terminal 15,Measuring value not available,
IDE00019,Voltage terminal 30,14.10, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,62, °C
IDE00104-ENG46733,DTC-Reset_1,101,
IDE00104-ENG46734,DTC-Reset_1_data,no_additional_data,
IDE00104-ENG46735,DTC-Reset_2,no_reset,
IDE00104-ENG46736,DTC-Reset_2_data,no_additional_data,
IDE00767,No. of unscheduled ECU resets,00 00,
IDE00925,Yaw rate,0.00, °/s
IDE01352,Temperature unit,°C,
IDE01763,Dimming,Very dark,
IDE02049,Trailer detected,Towing recognition control module not coded,
IDE02057,Dynamic calibration: status,active,
IDE02389,Ambient brightness,11, %
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,0,
IDE03197-MAS02477,Rain/Light Recognition Sensor-Front brightness,2,
IDE03197-ENG09275,Rain/Light Recognition Sensor-Brightness_forwards_Textual,numerical value: no text,
IDE03201-MAS00037,Date of last calibration-Calibration status,Calibration successfully completed,
IDE03201-MAS02356,Date of last calibration-Type of calibration,Short trip,
IDE03201-MAS11921,Date of last calibration-Malfunction cause,Correct result,
IDE03505-IDE12792,Personalized settings dimming-Personalization of user account 1,2,
IDE03505-IDE12794,Personalized settings dimming-Personalization of user account 2,2,
IDE03505-IDE12796,Personalized settings dimming-Personalization of user account 3,2,
IDE03505-IDE12798,Personalized settings dimming-Personalization of user account 4,2,
IDE03505-IDE12800,Personalized settings dimming-Personalization of user account 5,2,
IDE03505-IDE12802,Personalized settings dimming-Personalization of user account 6,2,
IDE03505-IDE12804,Personalized settings dimming-Personalization of user account 7,2,
IDE05068,Driver side warning light flashing cycle,OFF,
IDE05069,Frt.pass. side warning light flashing cycle,OFF,
IDE05070,Curve radius,Straight line running,
IDE05071,Lane change assistance button,not installed,
IDE05073,Dimming value of driver side warning light,0, %
IDE05074,Dimming value of frt.pass. side warning light,0, %
IDE05075,Status of driver side warning light,OFF,
IDE05076,Status of frt.pass. side warning light,OFF,
IDE05393,Currently used key,Personalization of user account 2,
IDE07159-MAS01155,Control module switch-off: counter-Control module,Initial value,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,Initial value,
IDE08221-MAS03385,Personalization settings key 1-Lane change assistance,On,
IDE08221-MAS15693,Personalization settings key 1-Exit warning,On,
IDE08221-MAS15695,Personalization settings key 1-Turning assistance,On,
IDE08221-MAS15696,Personalization settings key 1-Rear cross traffic assistant,On,
IDE08221-MAS16112,Personalization settings key 1-Rear cross traffic assistant: autonomous braking,On,
IDE08221-MAS16113,Personalization settings key 1-Pre sense: rear,On,
IDE08222-MAS03385,Personalization settings key 2-Lane change assistance,On,
IDE08222-MAS15693,Personalization settings key 2-Exit warning,On,
IDE08222-MAS15695,Personalization settings key 2-Turning assistance,On,
IDE08222-MAS15696,Personalization settings key 2-Rear cross traffic assistant,On,
IDE08222-MAS16112,Personalization settings key 2-Rear cross traffic assistant: autonomous braking,On,
IDE08222-MAS16113,Personalization settings key 2-Pre sense: rear,On,
IDE08223-MAS03385,Personalization settings key 3-Lane change assistance,On,
IDE08223-MAS15693,Personalization settings key 3-Exit warning,On,
IDE08223-MAS15695,Personalization settings key 3-Turning assistance,On,
IDE08223-MAS15696,Personalization settings key 3-Rear cross traffic assistant,On,
IDE08223-MAS16112,Personalization settings key 3-Rear cross traffic assistant: autonomous braking,On,
IDE08223-MAS16113,Personalization settings key 3-Pre sense: rear,On,
IDE08224-MAS03385,Personalization settings key 4-Lane change assistance,On,
IDE08224-MAS15693,Personalization settings key 4-Exit warning,On,
IDE08224-MAS15695,Personalization settings key 4-Turning assistance,On,
IDE08224-MAS15696,Personalization settings key 4-Rear cross traffic assistant,On,
IDE08224-MAS16112,Personalization settings key 4-Rear cross traffic assistant: autonomous braking,On,
IDE08224-MAS16113,Personalization settings key 4-Pre sense: rear,On,
IDE09780,System condition ctrl. mod.,Terminal 15 on,
IDE09781,Syst. condition lane change assistance,available.,
IDE09782,System condition rear cross traffic assistant,available.,
IDE09784,Functional status of lane change assist.,passive,
IDE09785,Function condition rear cross traffic assistant,passive,
IDE10587,Exit warning: function condition,active,
IDE10588,Exit warning: system condition,Terminal 15 on,
IDE12747,Measured receiving power,0, %
IDE12747,Measured receiving power,not detected,
IDE12792-MAS03385,Personalization of user account 1-Lane change assistance,On,
IDE12792-MAS15693,Personalization of user account 1-Exit warning,On,
IDE12792-MAS15695,Personalization of user account 1-Turning assistance,On,
IDE12792-MAS15696,Personalization of user account 1-Rear cross traffic assistant,On,
IDE12792-MAS16112,Personalization of user account 1-Rear cross traffic assistant: autonomous braking,On,
IDE12792-MAS16113,Personalization of user account 1-Pre sense: rear,On,
IDE12794-MAS03385,Personalization of user account 2-Lane change assistance,On,
IDE12794-MAS15693,Personalization of user account 2-Exit warning,On,
IDE12794-MAS15695,Personalization of user account 2-Turning assistance,On,
IDE12794-MAS15696,Personalization of user account 2-Rear cross traffic assistant,On,
IDE12794-MAS16112,Personalization of user account 2-Rear cross traffic assistant: autonomous braking,On,
IDE12794-MAS16113,Personalization of user account 2-Pre sense: rear,On,
IDE12796-MAS03385,Personalization of user account 3-Lane change assistance,On,
IDE12796-MAS15693,Personalization of user account 3-Exit warning,On,
IDE12796-MAS15695,Personalization of user account 3-Turning assistance,On,
IDE12796-MAS15696,Personalization of user account 3-Rear cross traffic assistant,On,
IDE12796-MAS16112,Personalization of user account 3-Rear cross traffic assistant: autonomous braking,On,
IDE12796-MAS16113,Personalization of user account 3-Pre sense: rear,On,
IDE12798-MAS03385,Personalization of user account 4-Lane change assistance,On,
IDE12798-MAS15693,Personalization of user account 4-Exit warning,On,
IDE12798-MAS15695,Personalization of user account 4-Turning assistance,On,
IDE12798-MAS15696,Personalization of user account 4-Rear cross traffic assistant,On,
IDE12798-MAS16112,Personalization of user account 4-Rear cross traffic assistant: autonomous braking,On,
IDE12798-MAS16113,Personalization of user account 4-Pre sense: rear,On,
IDE12800-MAS03385,Personalization of user account 5-Lane change assistance,On,
IDE12800-MAS15693,Personalization of user account 5-Exit warning,On,
IDE12800-MAS15695,Personalization of user account 5-Turning assistance,On,
IDE12800-MAS15696,Personalization of user account 5-Rear cross traffic assistant,On,
IDE12800-MAS16112,Personalization of user account 5-Rear cross traffic assistant: autonomous braking,On,
IDE12800-MAS16113,Personalization of user account 5-Pre sense: rear,On,
IDE12802-MAS03385,Personalization of user account 6-Lane change assistance,On,
IDE12802-MAS15693,Personalization of user account 6-Exit warning,On,
IDE12802-MAS15695,Personalization of user account 6-Turning assistance,On,
IDE12802-MAS15696,Personalization of user account 6-Rear cross traffic assistant,On,
IDE12802-MAS16112,Personalization of user account 6-Rear cross traffic assistant: autonomous braking,On,
IDE12802-MAS16113,Personalization of user account 6-Pre sense: rear,On,
IDE12804-MAS03385,Personalization of user account 7-Lane change assistance,On,
IDE12804-MAS15693,Personalization of user account 7-Exit warning,On,
IDE12804-MAS15695,Personalization of user account 7-Turning assistance,On,
IDE12804-MAS15696,Personalization of user account 7-Rear cross traffic assistant,On,
IDE12804-MAS16112,Personalization of user account 7-Rear cross traffic assistant: autonomous braking,On,
IDE12804-MAS16113,Personalization of user account 7-Pre sense: rear,On,
IDE13062,Assistance system monitor: version,0F 00,
IDE13096,Rear cross traffic assistant: left warning level,none,
IDE13107,Rear cross traffic assistant: right warning level,none,
IDE13109,Short distance calibration: status,not active,
IDE13109-MAS15813,Short distance calibration: status-Short distance calibration: progress,0, %
IDE13109-MAS16462,Short distance calibration: status-Short distance calibration: completed counter,00 00,
IDE13109-MAS16463,Short distance calibration: status-Short distance calibration: successfully completed counter,00 A6,
IDE13128,Measured angle,-0.23, °
IDE13129,Measured angle: end of line,Initial value,
IDE13130,Measured angle: customer service,Initial value,
IDE13131,Static angle offset,-0.23, °
IDE13132,Dynamic angle offset,-0.07, °
IDE13133,Measured angle: short distance,-0.23, °
IDE13158,Dynamic angle of set in the current terminal 15 cycle,-0.07, °
IDE13187-MAS03385,Personalization settings key 5-Lane change assistance,On,
IDE13187-MAS15693,Personalization settings key 5-Exit warning,On,
IDE13187-MAS15695,Personalization settings key 5-Turning assistance,On,
IDE13187-MAS15696,Personalization settings key 5-Rear cross traffic assistant,On,
IDE13187-MAS16112,Personalization settings key 5-Rear cross traffic assistant: autonomous braking,On,
IDE13187-MAS16113,Personalization settings key 5-Pre sense: rear,On,
IDE13188-MAS03385,Personalization settings key 6-Lane change assistance,On,
IDE13188-MAS15693,Personalization settings key 6-Exit warning,On,
IDE13188-MAS15695,Personalization settings key 6-Turning assistance,On,
IDE13188-MAS15696,Personalization settings key 6-Rear cross traffic assistant,On,
IDE13188-MAS16112,Personalization settings key 6-Rear cross traffic assistant: autonomous braking,On,
IDE13188-MAS16113,Personalization settings key 6-Pre sense: rear,On,
IDE13189-MAS03385,Personalization settings key 7-Lane change assistance,On,
IDE13189-MAS15693,Personalization settings key 7-Exit warning,On,
IDE13189-MAS15695,Personalization settings key 7-Turning assistance,On,
IDE13189-MAS15696,Personalization settings key 7-Rear cross traffic assistant,On,
IDE13189-MAS16112,Personalization settings key 7-Rear cross traffic assistant: autonomous braking,On,
IDE13189-MAS16113,Personalization settings key 7-Pre sense: rear,On,
IDE13872,Manual calibration,Initial value,
IDE13982,Active user account,Personalization of user account 2,
IDE14217-IDE00906,Doppler Position-Object distance,Initial value,
IDE14217-IDE13128,Doppler Position-Measured angle,Initial value,
ENG00952,RADAR_DATA_CAPTURE_FAULT,00 00 00 00 00 00 00 00 00 00 00 00,
Elapsed Time: 00:08
blockmap-42-4M0-959-793-N_WA1AAAGE8MB028917-20210516-1204.CSV
;SW:4M0-959-793-N   HW:4M0-959-793-N ---  Door Elect, Driver
;Component:TSG FS        011 0390, Coding:0014CB0052001480A001A032
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW38.rod
;Sunday,16,May,2021,12:04:55:36589
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210508 DS325.1
;VCID: 49CF54084931EC9318D-801C
Group,Description,Actual
IDE00310,Outside temperature,25.50, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Driver Side Door Control Module,
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.20, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,not installed,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,45, %
IDE04539-MAS02229,Mirror memory-Y coordinate,55, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,Not available,
IDE04581,Dimming for interior ambient lighting,Not available,
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,On,
IDE05071-MAS07693,Lane change assistance button-Button Status,Not operated,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,55, %
IDE05726,Dimmer terminal 58xd,2, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,Not operated,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,Not operated,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,Not operated,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,35, °C
IDE07543,Vehicle speed,0.00, km/h
IDE08061,Child safety lock button 2,Not operated,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not active,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,0, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Not available,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
MAS01872,Rear lid remote control lock switch,Not operated,
MAS02099,Switch for inside door handle,Not operated,
MAS02100,Switch for outside door handle,Not operated,
MAS02101,Child safety lock,not active,
MAS06010,Ambient light,Not available,
Elapsed Time: 00:08
blockmap-44-4N0-909-144-E_WA1AAAGE8MB028917-20210516-1205.CSV
;SW:4N0-909-144-E   HW:4N0-909-144-C ---  Steering Assist
;Component:EPS_MLBEVO2BS H22 0505, Coding:B4000101010001
;EV_EPSVWBSAU426,010017,EV_EPSVWBSAU426_010.rod
;Sunday,16,May,2021,12:05:10:36589
;VCID: 323D13E4C4A78F4B497-8066
IDE00102-IDE00655,Control Module temperature-Temperature of processor circuit board,24.71, °C
IDE00102-IDE04181,Control Module temperature-Rotor temperature,24.49, °C
IDE00102-MAS02955,Control Module temperature-Engine temperature,24.70, °C
IDE00102-MAS04448,Control Module temperature-Output stage temperature,24.81, °C
IDE00609-IDE10203,Communication status of data bus 1-Audi drive select: drive program,Communication,
IDE00609-MAS00772,Communication status of data bus 1-Battery Monitoring Control Module,Communication,
IDE00609-MAS00795,Communication status of data bus 1-Data Bus On Board Diagnostic Interface,Communication,
IDE00609-MAS00796,Communication status of data bus 1-Engine Control Module,Communication,
IDE00609-MAS00802,Communication status of data bus 1-Control module for distance control,Communication,
IDE00609-MAS00805,Communication status of data bus 1-Lane assistance control module,Communication,
IDE00609-MAS00807,Communication status of data bus 1-Parallel parking assistance control module,Not coded,
IDE00609-MAS00811,Communication status of data bus 1-Active steering control module,Not coded,
IDE00609-MAS00821,Communication status of data bus 1-Central ctrl. unit for comfort system,Communication,
IDE00609-MAS00824,Communication status of data bus 1-Steering column electronic systems control module,Communication,
IDE00609-MAS00830,Communication status of data bus 1-Trailer recognition control module,No communication,
IDE00609-MAS01172,Communication status of data bus 1-Development messages,No communication,
IDE00609-MAS08787,Communication status of data bus 1-Maneuvering assistant,Not coded,
IDE00609-MAS11240,Communication status of data bus 1-ABS Control Module,Communication,
IDE00609-MAS13015,Communication status of data bus 1-Routing assistant with park-steering system,Not coded,
IDE00609-MAS13019,Communication status of data bus 1-Chassis Control,Communication,
IDE00924-MAS02125,Steering angle-Steering wheel angle speed,0, °/s
IDE00924-MAS02126,Steering angle-Steering angle sensor: status,System OK,
IDE00924-MAS02961,Steering angle-Engine angle,104.74, °
IDE00924-MAS02981,Steering angle-Overlay angle,0.00, °
IDE00924-MAS02983,Steering angle-Steering wheel angle,-40.00, °
IDE00924-MAS02984,Steering angle-Steering angle speed,0.88, °/s
IDE00924-MAS13060,Steering angle-Steering pinion angle: offset corrected,-39.24, °
IDE02068-MAS00106,Time stamp-Year,2021, yr
IDE02068-MAS00107,Time stamp-Month,5, m
IDE02068-MAS00108,Time stamp-Day,16, d
IDE02068-MAS00109,Time stamp-Hours,12, H
IDE02068-MAS00110,Time stamp-Minutes,4, min
IDE02068-MAS00111,Time stamp-Seconds,50, s
IDE02068-MAS00711,Time stamp-Odometer reading,921, km
IDE03008-MAS05361,Stop process prevented-Manual steering torque too high,active,
IDE03008-MAS05409,Stop process prevented-Calculated steering angle too large,active,
IDE03008-MAS14902,Stop process prevented-Limp home mode active,active,
IDE03010-MAS05361,Number of prevented stop processes-Manual steering torque too high,0,
IDE03010-MAS05409,Number of prevented stop processes-Calculated steering angle too large,0,
IDE03010-MAS14902,Number of prevented stop processes-Limp home mode active,0,
IDE03011-ENG31516,Number of requested start processes-Frequency_counter_value_Restart,0,
IDE03471-IDE10940,Vehicle configuration-Steering assist. without eng. running,not active,
IDE03471-MAS01172,Vehicle configuration-Development messages,not active,
IDE03471-MAS01891,Vehicle configuration-Lane assist,coded,
IDE03471-MAS02145,Vehicle configuration-ESP ADS coding,Initialization,
IDE03471-MAS02672,Vehicle configuration-Start-stop,Not coded,
IDE03471-MAS03400,Vehicle configuration-Audi drive select,coded,
IDE03471-MAS03504,Vehicle configuration-XCP,not active,
IDE03471-MAS08071,Vehicle configuration-Hybrid drive,coded,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Not coded,
IDE03471-MAS08786,Vehicle configuration-Parallel Parking Assistance,Not coded,
IDE03471-MAS08940,Vehicle configuration-Collision warning,coded,
IDE03471-MAS12072,Vehicle configuration-Active Steering,Not coded,
IDE03471-MAS12200,Vehicle configuration-Steering recommendation,coded,
IDE03471-MAS12217,Vehicle configuration-Constant steering ratio,Not coded,
IDE03471-MAS12218,Vehicle configuration-Variable steering ratio,coded,
IDE03471-MAS12579,Vehicle configuration-Maneuvering assistant,Not coded,
IDE03471-MAS13015,Vehicle configuration-Routing assistant with park-steering system,Not coded,
IDE03471-MAS13016,Vehicle configuration-Parking assistant with cross-parking function,Not coded,
IDE03471-MAS13017,Vehicle configuration-Traffic jam assistant,coded,
IDE03471-MAS15107,Vehicle configuration-Drivetrain actuation,Not coded,
IDE03471-MAS15537,Vehicle configuration-Congestion pilot,Not coded,
IDE03471-MAS15637,Vehicle configuration-Dynamic all wheel drive,Not coded,
IDE03471-ENG110582,Vehicle configuration-Activation_update_programming_without_rest_bus_simulation,not active,
IDE03471-ENG55870,Vehicle configuration-Assistenz_System_Monitor_message,not active,
IDE03471-ENG22723,Vehicle configuration-deactivation_characteristic_curves_flash_via_data_set,not active,
IDE03471-ENG29829,Vehicle configuration-Power_class_2,Not coded,
IDE03471-ENG36875,Vehicle configuration-Torsion_Bar_Stiffness,Torsion_Bar_Stiffness_1_active,
IDE03471-ENG110616,Vehicle configuration-Update_programming_without_bus_simulation,not active,
IDE03471-ENG110746,Vehicle configuration-V_limit_kL30_disconnect,18.00, km/h
IDE03471-ENG36895,Vehicle configuration-Variable_steering_ratio_12_2,Not coded,
IDE03471-ENG36675,Vehicle configuration-Variable_steering_ratio_14_6,Not coded,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,14.37, V
IDE03680-MAS02953,Supply voltages-Battery status,connected,
IDE03680-MAS03838,Supply voltages-Output stage voltage,14.38, V
IDE03680-MAS03839,Supply voltages-GDU status,Unknown (0),
IDE03681-MAS01853,Wheel speed-Left front,0.00, km/h
IDE03681-MAS01854,Wheel speed-Right front,0.00, km/h
IDE03681-MAS01855,Wheel speed-Left rear,0.00, km/h
IDE03681-MAS01856,Wheel speed-Right rear,0.00, km/h
IDE03682-MAS00371,motor position sensor-Engine RPM,9, °/s
IDE03682-MAS02282,motor position sensor-Position,0.58, °
IDE03682-MAS02961,motor position sensor-Engine angle,104.74, °
IDE03682-MAS03083,motor position sensor-Cosine signal,2.32, °
IDE03682-MAS03211,motor position sensor-Sine signal,1.65, °
IDE03682-MAS03840,motor position sensor-Engine position test value,0.85, V
IDE03682-ENG55413,motor position sensor-Resolver_excitation,4.02, V
IDE03723-MAS11513,End stops for steering-End stop left,Adapted,
IDE03723-MAS11514,End stops for steering-End stop right,Adapted,
IDE03723-MAS13021,End stops for steering-Permissible deviation of the calculated offset,OK,
IDE03723-MAS13061,End stops for steering-calculated rack position in right mechanical end-stop,-67.66, mm
IDE03723-MAS13062,End stops for steering-calculated rack position in right mechanical end-stop,68.30, mm
IDE03723-MAS13063,End stops for steering-calculated engine angle in the right mechanical end-stop,116.54, °
IDE03723-MAS13064,End stops for steering-calculated engine angle in the left mechanical end-stop,107.23, °
IDE03723-MAS15438,End stops for steering-LWI fine synchronization,not performed,
IDE03724-MAS02998,Straight line running-Angle value offset,-0.75, °
IDE03724-MAS03528,Straight line running-Long term adaptation value,-0.75, °
IDE03724-MAS03529,Straight line running-Short term adaptation value,0.00, °
IDE03725-IDE09693,Steering Assistance-Charisma driving program: system status,available.,
IDE03725-MAS02974,Steering Assistance-Target force,149, N
IDE03725-MAS03002,Steering Assistance-Driving program,Program 2,
IDE03726-MAS02974,Parallel Parking Assistance-Target force,0, N
IDE03726-MAS05631,Parallel Parking Assistance-System status,0,
IDE03726-MAS12323,Parallel Parking Assistance-Steering wheel angle control: P-term,0.00, °/s
IDE03726-MAS12324,Parallel Parking Assistance-Steering wheel angle control: I-term,0.00, °/s
IDE03726-MAS12326,Parallel Parking Assistance-Park. steer. funct.: reason for abort,0,
IDE03734-MAS02965,Support power-Performance percentage,0.00, %
IDE03734-MAS12809,Support power-Power reduction factor: low voltage,100.00, %
IDE03734-MAS12810,Support power-Power reduction factor: temperature,100.00, %
IDE03735-MAS02961,Steering torque-Engine angle,104.74, °
IDE03735-MAS03841,Steering torque-Engine steering torque: limited required torque,0.00, Nm
IDE03735-MAS03842,Steering torque-Engine steering torque: setpoint,0.00, Nm
IDE03735-MAS04735,Steering torque-Current engine torques (ACTUAL),0.00, Nm
IDE04561-MAS00370,Switch-on and shut-off conditions-Vehicle speed,0.00, km/h
IDE04561-MAS00371,Switch-on and shut-off conditions-Engine RPM,0.00, /min
IDE04561-MAS03680,Switch-on and shut-off conditions-Terminal 15 status measured,On,
IDE04561-MAS06982,Switch-on and shut-off conditions-Terminal 15 status signal,On,
IDE04561-MAS09828,Switch-on and shut-off conditions-Status of drive readiness hybrid,not ready to drive,
IDE04562-MAS02976,Steering torque sensor-Sensor 1 supply,4.98, V
IDE04562-MAS02978,Steering torque sensor-Steering torque sensor 1,0.13, Nm
IDE04562-MAS02979,Steering torque sensor-Steering torque sensor 2,0.12, Nm
IDE04562-MAS03791,Steering torque sensor-Actual steering torque value,0.12, Nm
IDE04562-MAS03844,Steering torque sensor-Engine steering torque sensor: model value,0.00, Nm
IDE04562-MAS03845,Steering torque sensor-Engine steering torque sensor: average value,0.12, Nm
IDE04562-ENG50779,Steering torque sensor-Power_Supply_DME2_OV_state,System OK,
IDE04562-ENG50780,Steering torque sensor-Power_Supply_DME2_UV_state,System OK,
IDE05963-MAS09952,ASSY part number-Part Number,-----------,
IDE05963-MAS11961,ASSY part number-Serial number,-----------,
IDE05963-ENG36854,ASSY part number-Steering_generation_status,--------,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Calculated steering angle too large,
IDE06307,Stop prevention history data,Limp home mode active,
IDE06307,Stop prevention history data,Manual steering torque too high,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Manual steering torque too high,
IDE11509-MAS03401,Cutoff 1-Parameter 1,FF FF,
IDE11509-MAS03402,Cutoff 1-Parameter 2,FF FF,
IDE11509-MAS03403,Cutoff 1-Parameter 3,FF FF,
IDE11509-MAS03404,Cutoff 1-Parameter 4,FF FF,
IDE11509-MAS03405,Cutoff 1-Parameter 5,FF FF,
IDE11509-MAS03406,Cutoff 1-Parameter 6,FF FF,
IDE11509-MAS03407,Cutoff 1-Parameter 7,FF FF,
IDE11509-MAS03408,Cutoff 1-Parameter 8,FF FF,
IDE11509-MAS03409,Cutoff 1-Parameter 9,FF FF,
IDE11509-MAS03410,Cutoff 1-Parameter 10,FF,
IDE11509-MAS03411,Cutoff 1-Parameter 11,FF,
IDE11510-MAS03401,Cutoff 2-Parameter 1,FF FF,
IDE11510-MAS03402,Cutoff 2-Parameter 2,FF FF,
IDE11510-MAS03403,Cutoff 2-Parameter 3,FF FF,
IDE11510-MAS03404,Cutoff 2-Parameter 4,FF FF,
IDE11510-MAS03405,Cutoff 2-Parameter 5,FF FF,
IDE11510-MAS03406,Cutoff 2-Parameter 6,FF FF,
IDE11510-MAS03407,Cutoff 2-Parameter 7,FF FF,
IDE11510-MAS03408,Cutoff 2-Parameter 8,FF FF,
IDE11510-MAS03409,Cutoff 2-Parameter 9,FF FF,
IDE11510-MAS03410,Cutoff 2-Parameter 10,FF,
IDE11510-MAS03411,Cutoff 2-Parameter 11,FF,
IDE11511-MAS03401,Cutoff 3-Parameter 1,FF FF,
IDE11511-MAS03402,Cutoff 3-Parameter 2,FF FF,
IDE11511-MAS03403,Cutoff 3-Parameter 3,FF FF,
IDE11511-MAS03404,Cutoff 3-Parameter 4,FF FF,
IDE11511-MAS03405,Cutoff 3-Parameter 5,FF FF,
IDE11511-MAS03406,Cutoff 3-Parameter 6,FF FF,
IDE11511-MAS03407,Cutoff 3-Parameter 7,FF FF,
IDE11511-MAS03408,Cutoff 3-Parameter 8,FF FF,
IDE11511-MAS03409,Cutoff 3-Parameter 9,FF FF,
IDE11511-MAS03410,Cutoff 3-Parameter 10,FF,
IDE11511-MAS03411,Cutoff 3-Parameter 11,FF,
IDE11887-MAS00976,Mechanical load: status-Counter,2A FF,
IDE11887-MAS13728,Mechanical load: status-Resetting the load counter: status,00,
IDE11887-MAS16824,Mechanical load: status-Load counter end stops,00 00,
IDE11887-MAS16825,Mechanical load: status-Aggregate load counter,00 00 00 4E,
IDE13384-MAS16374,Driving assistant steering requisition-Congestion assistant status,active,
IDE13384-MAS16375,Driving assistant steering requisition-Congestion assistant steering rack position,-4.54, mm
IDE13384-MAS16378,Driving assistant steering requisition-Power steering congestion assistant status,Congestion pilot functionally ready,
IDE13384-MAS16403,Driving assistant steering requisition-Release congestion pilot,No,
IDE13384-MAS16404,Driving assistant steering requisition-Power steering: control variable,0, %
IDE13384-MAS16405,Driving assistant steering requisition-Power steering: control variable sign,Positive,
IDE13384-ENG36700,Driving assistant steering requisition-BVS_suppression,00,
IDE13389-IDE00490,Driving assistant torque-Status directional stabilization assistance,operational,
IDE13389-MAS16408,Driving assistant torque-Emergency steer assistant status,operational,
IDE13389-MAS16409,Driving assistant torque-Power steering lane assist status,operational,
IDE13389-ENG55838,Driving assistant torque-DRS_state,Request for rejected fault,
IDE13389-ENG36721,Driving assistant torque-EPA_state_DSR,operational,
IDE13389-ENG36723,Driving assistant torque-EPS_state_AWA,operational,
IDE13413-ENG36722,Steering stroke-EPS_end_stop_state,Expansion,
IDE13413-ENG36727,Steering stroke-FA_levelVAL,7F,
IDE13413-ENG36728,Steering stroke-FA_levelVAR 2,7F,
IDE13413-ENG36828,Steering stroke-NR_controller_state,Unknown (0),
IDE13414-ENG55810,calculated steering angle: synchronization-BLW_Synchronising_State,coarse_Synchronising,
IDE13414-ENG36693,calculated steering angle: synchronization-BLW_Synchronising_State_error,No malfunction,
IDE13414-ENG36694,calculated steering angle: synchronization-BLW_Synchronising_State_Init,Default,
IDE13415-ENG36852,Rack position-Steering_gear_rack_position_sign,Negative,
IDE13415-ENG46649,Rack position-Steering_gear_rack_position_value,5.12, mm
IDE13415-ENG56587,Rack position-Valid_bit_Steering_gear_rack_position,Initial value,
IDE13851-ENG36840,Software bypass-SFS_Switch_State,ARS_on,
IDE13851-ENG36850,Software bypass-Software_module_state,ARS_active,
Elapsed Time: 00:17
blockmap-46-8W1-907-064-BH_WA1AAAGE8MB028917-20210516-1205.CSV
;SW:8W1-907-064-BH   HW:8W1-907-064-H ---  Central Conv.
;Component:BCM2 MLBevo   044 0565, Coding:017400004FB100C1650FA0046C01880200004000810426582F0400000F04823F001E0681010F37
;EV_BCM2HellaAU736,018017,EV_BCM2HellaAU736_018.rod
;Sunday,16,May,2021,12:05:47:36589
;VCID: 0451853C2E93F1FBABB-8050
IDE00027-MAS04423,Status of brake signals-Automatic braking signal via CAN,not active,
IDE00027-MAS04424,Status of brake signals-Driver brakes signal via CAN,not active,
IDE00027-MAS06469,Status of brake signals-Brake light signal,not active,
IDE00027-MAS06470,Status of brake signals-Brake light signal via CAN,not active,
IDE00027-MAS06471,Status of brake signals-Request emergency brake display,OFF,
IDE00027-MAS15241,Status of brake signals-Brake light signal from brake booster control module,not active,
IDE00096-MAS00364,Selector lever position-Shift lever / selector lever position,Selector lever in position P,
IDE00096-MAS06480,Selector lever position-Transmission park selector switch,not coded/not installed,
IDE00306-MAS02227,Fuel Level Sensor 1-Quality,not coded/not installed,
IDE00306-MAS06614,Fuel Level Sensor 1-Variant,not coded/not installed,
IDE00306-MAS06615,Fuel Level Sensor 1-Soiling resistance,not coded/not installed,
IDE00306-MAS06621,Fuel Level Sensor 1-Raw value 1,not coded/not installed,
IDE00306-MAS06622,Fuel Level Sensor 1-Raw value 2,not coded/not installed,
IDE00306-MAS06623,Fuel Level Sensor 1-Sensor including soiling resistance,not coded/not installed,
IDE00306-MAS06624,Fuel Level Sensor 1-Sensor without soiling resistance,not coded/not installed,
IDE00306-MAS06643,Fuel Level Sensor 1-Resistance 1: measurable value,not coded/not installed,
IDE00306-MAS06644,Fuel Level Sensor 1-Resistance 2: measurable value,not coded/not installed,
IDE00307-MAS02227,Fuel Level Sensor 2-Quality,not coded/not installed,
IDE00307-MAS06614,Fuel Level Sensor 2-Variant,not coded/not installed,
IDE00307-MAS06615,Fuel Level Sensor 2-Soiling resistance,not coded/not installed,
IDE00307-MAS06621,Fuel Level Sensor 2-Raw value 1,not coded/not installed,
IDE00307-MAS06622,Fuel Level Sensor 2-Raw value 2,not coded/not installed,
IDE00307-MAS06623,Fuel Level Sensor 2-Sensor including soiling resistance,not coded/not installed,
IDE00307-MAS06624,Fuel Level Sensor 2-Sensor without soiling resistance,not coded/not installed,
IDE00307-MAS06643,Fuel Level Sensor 2-Resistance 1: measurable value,not coded/not installed,
IDE00307-MAS06644,Fuel Level Sensor 2-Resistance 2: measurable value,not coded/not installed,
IDE00308-MAS02227,Fuel Level Sensor 3-Quality,not coded/not installed,
IDE00308-MAS06614,Fuel Level Sensor 3-Variant,not coded/not installed,
IDE00308-MAS06615,Fuel Level Sensor 3-Soiling resistance,not coded/not installed,
IDE00308-MAS06621,Fuel Level Sensor 3-Raw value 1,not coded/not installed,
IDE00308-MAS06622,Fuel Level Sensor 3-Raw value 2,not coded/not installed,
IDE00308-MAS06623,Fuel Level Sensor 3-Sensor including soiling resistance,not coded/not installed,
IDE00308-MAS06624,Fuel Level Sensor 3-Sensor without soiling resistance,not coded/not installed,
IDE00308-MAS06643,Fuel Level Sensor 3-Resistance 1: measurable value,not coded/not installed,
IDE00308-MAS06644,Fuel Level Sensor 3-Resistance 2: measurable value,not coded/not installed,
IDE00309-MAS02227,Fuel Level Sensor 4-Quality,not coded/not installed,
IDE00309-MAS06614,Fuel Level Sensor 4-Variant,not coded/not installed,
IDE00309-MAS06615,Fuel Level Sensor 4-Soiling resistance,not coded/not installed,
IDE00309-MAS06621,Fuel Level Sensor 4-Raw value 1,not coded/not installed,
IDE00309-MAS06622,Fuel Level Sensor 4-Raw value 2,not coded/not installed,
IDE00309-MAS06623,Fuel Level Sensor 4-Sensor including soiling resistance,not coded/not installed,
IDE00309-MAS06624,Fuel Level Sensor 4-Sensor without soiling resistance,not coded/not installed,
IDE00309-MAS06643,Fuel Level Sensor 4-Resistance 1: measurable value,not coded/not installed,
IDE00309-MAS06644,Fuel Level Sensor 4-Resistance 2: measurable value,not coded/not installed,
IDE00767-MAS01478,No. of unscheduled ECU resets-insufficient voltage,0,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01464-MAS01580,Rear window defogger-Activation,OFF,
IDE01464-MAS06528,Rear window defogger-Release status,No enabling,
IDE01464-MAS06996,Rear window defogger-Validity of filtered outside temperature,valid,
IDE01464-MAS06997,Rear window defogger-Outside temperature: filtered,25.5, °C
IDE01464-MAS09460,Rear window defogger-Release status: convert. top ctrl. mod.,not coded/not installed,
IDE01464-MAS13453,Rear window defogger-Load requirement of 12 V energy management,no request,
IDE01537-MAS01581,Front windshield heater-Power consumption,not coded/not installed,
IDE01537-MAS01737,Front windshield heater-Diagnosis,not coded/not installed,
IDE01537-MAS04737,Front windshield heater-Indicator lamp,not coded/not installed,
IDE01537-MAS05030,Front windshield heater-Resistance,not coded/not installed,
IDE01537-MAS05851,Front windshield heater-Current power consumption,not coded/not installed,
IDE01537-MAS06535,Front windshield heater-Resistance: lower limit value,not coded/not installed,
IDE01537-MAS06536,Front windshield heater-Resistance: upper limit value,not coded/not installed,
IDE01537-MAS06537,Front windshield heater-Power consumption: target value,not coded/not installed,
IDE01537-MAS06726,Front windshield heater-Hardware / software version,not coded/not installed,
IDE01537-MAS06732,Front windshield heater-Status local activity,not coded/not installed,
IDE01985-MAS06854,FAZIT identification test sum-Version,85,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,C4 E9 9D 58,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote control lock switch,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,For,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,For,
IDE02092-MAS09072,Tailgate condition-Locking mechanism button in the rear lid,Not operated,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not active,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,No,
IDE02711-MAS01580,Rear wiper-Activation,not active,
IDE02711-MAS07731,Rear wiper-No. of wisher cycles,354,
IDE02711-MAS07732,Rear wiper-Number of recognized blockings,0,
IDE02711-MAS07733,Rear wiper-Requirements rear window wiper,OFF,
IDE02711-MAS07939,Rear wiper-Rear window wiper motor diagnostic,No malfunction,
IDE02711-MAS07940,Rear wiper-Contact switch for rear window wiper end shelf,Open,
IDE02711-MAS07965,Rear wiper-Contact switch for rear window wiper end shelf diagnostic,No malfunction,
IDE03008-MAS09566,Stop process prevented-Key not in vehicle,not active,
IDE03010-MAS09566,Number of prevented stop processes-Key not in vehicle,0,
IDE03527-MAS12075,CAN signals-Keyless entry and start authorization: driver info,0,
IDE03659-MAS03834,Roller test bench mode-Emergency signal flashing,not active,
IDE03659-MAS06320,Roller test bench mode-Status rolling mode,not active,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,14.484, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,14.470, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,14.457, V
IDE04254-MAS00215,Play protection for central locking-Fuel filler lid,not active,
IDE04254-MAS00222,Play protection for central locking-Rear lid,not active,
IDE04254-MAS02444,Play protection for central locking-Central locking system,not active,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not active,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,No,
IDE05824-MAS04583,DWA Vehicle inclination sensor: angle-Reference angle: X-axis,-0.8, °
IDE05824-MAS04584,DWA Vehicle inclination sensor: angle-Reference angle: Y-axis,9.1, °
IDE05824-MAS04585,DWA Vehicle inclination sensor: angle-Reference angle: Z-axis,Implausible,
IDE05824-MAS04586,DWA Vehicle inclination sensor: angle-Angle difference: X-axis,0.0, °
IDE05824-MAS04587,DWA Vehicle inclination sensor: angle-Angle difference: Y-axis,0.0, °
IDE05824-MAS04588,DWA Vehicle inclination sensor: angle-Angle difference: Z-axis,Implausible,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS00976,DWA History data for alarm triggering-Counter,3,
IDE05828-MAS02545,DWA History data for alarm triggering-Last,Activation by external system,
IDE05828-MAS02546,DWA History data for alarm triggering-Second to last,Activation by external system,
IDE05828-MAS02547,DWA History data for alarm triggering-Third to last,Activation by external system,
IDE05828-MAS02548,DWA History data for alarm triggering-Fourth to last,No alarm,
IDE05832,DWA Number of alarms triggered in anti-theft warn.system sensor,0,
IDE06307,Stop prevention history data,Key not in vehicle,
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,Not operated,
IDE06324-MAS01580,Tank cap lock-Activation,not coded/not installed,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06324-MAS10861,Tank cap lock-Fuel tank cap unlocked via ECM,not coded/not installed,
IDE06644-MAS00145,Vehicle positioning system-Starter lock,not coded/not installed,
IDE06644-MAS04968,Vehicle positioning system-Vehicle positioning alarm,not coded/not installed,
IDE06926-MAS00106,History memory: reset counter-Year,2000,
IDE06926-MAS00107,History memory: reset counter-Month,0,
IDE06926-MAS00108,History memory: reset counter-Day,0,
IDE06926-MAS00109,History memory: reset counter-Hours,0,
IDE06926-MAS00110,History memory: reset counter-Minutes,0,
IDE06926-MAS00111,History memory: reset counter-Seconds,0,
IDE06926,History memory: reset counter,insufficient voltage,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,not coded/not installed,
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,not coded/not installed,
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,not coded/not installed,
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,not coded/not installed,
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,not coded/not installed,
IDE07293-IDE00500,History data of panic alarm-Hour,20,
IDE07293-IDE00501,History data of panic alarm-Minute,53,
IDE07293-MAS00107,History data of panic alarm-Month,3,
IDE07293-MAS00108,History data of panic alarm-Day,23,
IDE07293-MAS04478,History data of panic alarm-Cause for alarm activation,Panic button,
IDE08162-MAS06256,TSG driver side: signals for central locking-Status door lock,unlocked,
IDE08162-MAS06266,TSG driver side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08162-MAS06431,TSG driver side: signals for central locking-Door contact switch,Open,
IDE08162-MAS06432,TSG driver side: signals for central locking-Button for interior lock,Not operated,
IDE08162-MAS06433,TSG driver side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08163-MAS06256,TSG frt.pass.side: signals for central locking-Status door lock,unlocked,
IDE08163-MAS06266,TSG frt.pass.side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08163-MAS06431,TSG frt.pass.side: signals for central locking-Door contact switch,closed,
IDE08163-MAS06432,TSG frt.pass.side: signals for central locking-Button for interior lock,Not operated,
IDE08163-MAS06433,TSG frt.pass.side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Button for interior lock,Not operated,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Button for interior lock,Not operated,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08176,History data doors,11100001 ,
IDE08177-MAS06456,Central locking system-Auto lock,not active,
IDE08177-MAS06740,Central locking system-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking system-Status exterior skin,Open,
IDE08177-MAS09895,Central locking system-Act. condition: Status central locking locked,active,
IDE08177-MAS09896,Central locking system-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking system-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking system-Act. condition: Status central locking safe,not active,
IDE08177-MAS09899,Central locking system-Act. condition: Status central locking individual door unlocked,not active,
IDE08177-MAS09900,Central locking system-Spec. condition: Status central lock,unlocked,
IDE08177-MAS16237,Central locking system-Outside door handles,Initialization,
IDE08178-MAS06437,Valet parking service-Valet parking lock button,Not operated,
IDE08178-MAS06438,Valet parking service-Valet parking indicator lamp,OFF,
IDE08180-IDE00500,History data central locking: last event-Hour,17,
IDE08180-IDE00501,History data central locking: last event-Minute,38,
IDE08180-MAS00106,History data central locking: last event-Year,not known,
IDE08180-MAS00107,History data central locking: last event-Month,5,
IDE08180-MAS00108,History data central locking: last event-Day,14,
IDE08180-MAS00111,History data central locking: last event-Seconds,15,
IDE08180-MAS01551,History data central locking: last event-Key number,1,
IDE08180-MAS06441,History data central locking: last event-Control-section / cause,Auto lock,
IDE08181-IDE00500,History data central locking: second-to-last event-Hour,17,
IDE08181-IDE00501,History data central locking: second-to-last event-Minute,38,
IDE08181-MAS00106,History data central locking: second-to-last event-Year,not known,
IDE08181-MAS00107,History data central locking: second-to-last event-Month,5,
IDE08181-MAS00108,History data central locking: second-to-last event-Day,14,
IDE08181-MAS00111,History data central locking: second-to-last event-Seconds,15,
IDE08181-MAS01551,History data central locking: second-to-last event-Key number,1,
IDE08181-MAS06441,History data central locking: second-to-last event-Control-section / cause,No data available,
IDE08182-IDE00500,History data central locking: third-to-last event-Hour,12,
IDE08182-IDE00501,History data central locking: third-to-last event-Minute,25,
IDE08182-MAS00106,History data central locking: third-to-last event-Year,not known,
IDE08182-MAS00107,History data central locking: third-to-last event-Month,5,
IDE08182-MAS00108,History data central locking: third-to-last event-Day,14,
IDE08182-MAS00111,History data central locking: third-to-last event-Seconds,15,
IDE08182-MAS01551,History data central locking: third-to-last event-Key number,2,
IDE08182-MAS06441,History data central locking: third-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE08183-IDE00500,History data central locking: fourth-to-last event-Hour,12,
IDE08183-IDE00501,History data central locking: fourth-to-last event-Minute,16,
IDE08183-MAS00106,History data central locking: fourth-to-last event-Year,not known,
IDE08183-MAS00107,History data central locking: fourth-to-last event-Month,5,
IDE08183-MAS00108,History data central locking: fourth-to-last event-Day,14,
IDE08183-MAS00111,History data central locking: fourth-to-last event-Seconds,0,
IDE08183-MAS01551,History data central locking: fourth-to-last event-Key number,1,
IDE08183-MAS06441,History data central locking: fourth-to-last event-Control-section / cause,Auto lock,
IDE08184-IDE00500,History data central locking: fifth-to-last event-Hour,12,
IDE08184-IDE00501,History data central locking: fifth-to-last event-Minute,15,
IDE08184-MAS00106,History data central locking: fifth-to-last event-Year,not known,
IDE08184-MAS00107,History data central locking: fifth-to-last event-Month,5,
IDE08184-MAS00108,History data central locking: fifth-to-last event-Day,14,
IDE08184-MAS00111,History data central locking: fifth-to-last event-Seconds,45,
IDE08184-MAS01551,History data central locking: fifth-to-last event-Key number,1,
IDE08184-MAS06441,History data central locking: fifth-to-last event-Control-section / cause,No data available,
IDE08187-MAS02362,Request direction flashing-Flashing: right,not active,
IDE08187-MAS02363,Request direction flashing-Flashing: left,not active,
IDE08189-MAS04309,Malfunction status flasher-Turn signal front left,No malfunction,
IDE08189-MAS04310,Malfunction status flasher-Turn signal front right,No malfunction,
IDE08189-MAS04311,Malfunction status flasher-Left rear turn signal,No malfunction,
IDE08189-MAS04312,Malfunction status flasher-Turn signal rear right,No malfunction,
IDE08190-MAS01281,Request exterior illumination-Back-up lamp,OFF,
IDE08190-MAS03836,Request exterior illumination-Rear fog lamp,OFF,
IDE08190-MAS06466,Request exterior illumination-Parking light left,OFF,
IDE08190-MAS06467,Request exterior illumination-Parking light right,OFF,
IDE08190-MAS06468,Request exterior illumination-Tail lamp,On,
IDE08194-MAS06982,Signals vehicle electrical system control module-Terminal 15 status signal,On,
IDE08194-MAS07716,Signals vehicle electrical system control module-Last status: terminal 15,On,
IDE08195-MAS06483,Access/Start Authorization Button-Access/start authorization button: contact 1,Not operated,
IDE08195-MAS06484,Access/Start Authorization Button-Access/start authorization button: contact 2,Not operated,
IDE08195-MAS06485,Access/Start Authorization Button-Access/start authorization button: contact 3,Not operated,
IDE08195-MAS06486,Access/Start Authorization Button-Access/start authorization button: contact 4,Not operated,
IDE08196-IDE12848,Terminal activation-Remote start relay or preconditioning,not active,
IDE08196-MAS06982,Terminal activation-Terminal 15 status signal,active,
IDE08196-MAS07383,Terminal activation-Terminal 15 on CAN,active,
IDE08196-MAS07386,Terminal activation-Terminal 50 on CAN,not active,
IDE08196-MAS07715,Terminal activation-Activation: terminal 15,active,
IDE08196-MAS07716,Terminal activation-Last status: terminal 15,active,
IDE08196-MAS07719,Terminal activation-Terminal 50 status,not active,
IDE08197-IDE02666,Alarm horn for anti-theft warning system-Convertible top status,not coded/not installed,
IDE08197-MAS06495,Alarm horn for anti-theft warning system-Engine hood contact switch,closed,
IDE08197-MAS06507,Alarm horn for anti-theft warning system-Trailer disconnected,not coded/not installed,
IDE08197-MAS07350,Alarm horn for anti-theft warning system-Left headlamp,not coded/not installed,
IDE08197-MAS07351,Alarm horn for anti-theft warning system-Right headlamp,not coded/not installed,
IDE08197-MAS11121,Alarm horn for anti-theft warning system-Glass breakage sensor or glove box,not interrupted / closed,
IDE08199-IDE00500,History data anti-theft protection: last event-Hour,0,
IDE08199-IDE00501,History data anti-theft protection: last event-Minute,0,
IDE08199-MAS00106,History data anti-theft protection: last event-Year,2000,
IDE08199-MAS00107,History data anti-theft protection: last event-Month,0,
IDE08199-MAS00108,History data anti-theft protection: last event-Day,0,
IDE08199-MAS04478,History data anti-theft protection: last event-Cause for alarm activation,No alarm,
IDE08200-IDE00500,History data anti-theft protection: second-to-last event-Hour,0,
IDE08200-IDE00501,History data anti-theft protection: second-to-last event-Minute,0,
IDE08200-MAS00106,History data anti-theft protection: second-to-last event-Year,2000,
IDE08200-MAS00107,History data anti-theft protection: second-to-last event-Month,0,
IDE08200-MAS00108,History data anti-theft protection: second-to-last event-Day,0,
IDE08200-MAS04478,History data anti-theft protection: second-to-last event-Cause for alarm activation,No alarm,
IDE08201-IDE00500,History data anti-theft protection: third-to-last event-Hour,0,
IDE08201-IDE00501,History data anti-theft protection: third-to-last event-Minute,0,
IDE08201-MAS00106,History data anti-theft protection: third-to-last event-Year,2000,
IDE08201-MAS00107,History data anti-theft protection: third-to-last event-Month,0,
IDE08201-MAS00108,History data anti-theft protection: third-to-last event-Day,0,
IDE08201-MAS04478,History data anti-theft protection: third-to-last event-Cause for alarm activation,No alarm,
IDE08202-IDE00500,History data anti-theft protection: fourth-to-last event-Hour,0,
IDE08202-IDE00501,History data anti-theft protection: fourth-to-last event-Minute,0,
IDE08202-MAS00106,History data anti-theft protection: fourth-to-last event-Year,2000,
IDE08202-MAS00107,History data anti-theft protection: fourth-to-last event-Month,0,
IDE08202-MAS00108,History data anti-theft protection: fourth-to-last event-Day,0,
IDE08202-MAS04478,History data anti-theft protection: fourth-to-last event-Cause for alarm activation,No alarm,
IDE08203-MAS05851,Rear shades-Current power consumption,not coded/not installed,
IDE08203-MAS06258,Rear shades-Left child safety,not coded/not installed,
IDE08203-MAS06259,Rear shades-Right child safety,not coded/not installed,
IDE08203-MAS06513,Rear shades-Driver side rear window shade button,not coded/not installed,
IDE08203-MAS06514,Rear shades-assenger side rear window shade button,not coded/not installed,
IDE08203-MAS06515,Rear shades-Rear shade button,not coded/not installed,
IDE08203-MAS06516,Rear shades-Rear window shade status,not coded/not installed,
IDE08203-MAS06517,Rear shades-Rear spoiler counter,not coded/not installed,
IDE08204-MAS06520,Rear Lid Closed Sensor-Rear lid -closed- sensor 1,not coded/not installed,
IDE08204-MAS06521,Rear Lid Closed Sensor-Rear lid -closed- sensor 2,not coded/not installed,
IDE08204-MAS06522,Rear Lid Closed Sensor-Rear lid: Status,not coded/not installed,
IDE08206-MAS06714,Local data bus: bus level malfunction-Local data bus: malfunction status,No malfunction,
IDE08206-MAS06715,Local data bus: bus level malfunction-Local data bus 2: malfunction status,No malfunction,
IDE08206-MAS06716,Local data bus: bus level malfunction-Local data bus 3: malfunction status,No malfunction,
IDE08206-MAS06717,Local data bus: bus level malfunction-Local data bus 4: malfunction status,not coded/not installed,
IDE08206-MAS06718,Local data bus: bus level malfunction-Local data bus 5: malfunction status,not coded/not installed,
IDE08206-MAS06719,Local data bus: bus level malfunction-Local data bus 6: malfunction status,not coded/not installed,
IDE08206-MAS06720,Local data bus: bus level malfunction-Local data bus: malfunction counter,0,
IDE08206-MAS06721,Local data bus: bus level malfunction-Local data bus 2: malfunction counter,0,
IDE08206-MAS06722,Local data bus: bus level malfunction-Local data bus 3: malfunction counter,0,
IDE08206-MAS06723,Local data bus: bus level malfunction-Local data bus 4: malfunction counter,not coded/not installed,
IDE08206-MAS06724,Local data bus: bus level malfunction-Local data bus 5: malfunction counter,not coded/not installed,
IDE08206-MAS06725,Local data bus: bus level malfunction-Local data bus 6: malfunction counter,not coded/not installed,
IDE08208-MAS06528,Rear lid opener control module-Release status,No enabling,
IDE08208-MAS06529,Rear lid opener control module-Trailer recognition,no approach,
IDE08208-MAS06532,Rear lid opener control module-Foot gestic recognition,No foot gestic,
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,F8,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,F8,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,No,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,No,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,00000000 ,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,00000000 ,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,00000000 ,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,00000000 ,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,00000000 ,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,00000000 ,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,00000000 ,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,20 AC D5 E3,
IDE08240,Transponder ID Key 2,20 AF 3A 06,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,02 58 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00,
IDE08251-MAS06850,Configuration immobilizer-Supported power class 2,00,
IDE08251-MAS06851,Configuration immobilizer-Supported power class 3,00,
IDE08251-MAS06852,Configuration immobilizer-Supported power class 4,00,
IDE08251-MAS06853,Configuration immobilizer-Supported power class 5,00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,FD AC D2 57,
IDE08343,Immobilizer Challenge,59 7A 23 CF,
IDE08479,Signal type,no flashing function active,
IDE08631,Received Signal Strength Indicator (RSSI),124,
IDE09133-MAS01580,Output 1 for exterior lighting-Activation,Output not used,
IDE09133-MAS05851,Output 1 for exterior lighting-Current power consumption,Output not used,
IDE09133-MAS08347,Output 1 for exterior lighting-Assigned event code,Output not used,
IDE09133-MAS08349,Output 1 for exterior lighting-Type of connected lamp,Output not used,
IDE09134-MAS01580,Output 2 for exterior lighting-Activation,Output not used,
IDE09134-MAS05851,Output 2 for exterior lighting-Current power consumption,Output not used,
IDE09134-MAS08347,Output 2 for exterior lighting-Assigned event code,Output not used,
IDE09134-MAS08349,Output 2 for exterior lighting-Type of connected lamp,Output not used,
IDE09135-MAS01580,Output 3 for exterior lighting-Activation,0.0, %
IDE09135-MAS05851,Output 3 for exterior lighting-Current power consumption,0, mA
IDE09135-MAS08347,Output 3 for exterior lighting-Assigned event code,B133300,
IDE09135-MAS08349,Output 3 for exterior lighting-Type of connected lamp,LED,
IDE09136-MAS01580,Output 4 for exterior lighting-Activation,0.0, %
IDE09136-MAS05851,Output 4 for exterior lighting-Current power consumption,0, mA
IDE09136-MAS08347,Output 4 for exterior lighting-Assigned event code,B133500,
IDE09136-MAS08349,Output 4 for exterior lighting-Type of connected lamp,LED,
IDE09137-MAS01580,Output 5 for exterior lighting-Activation,100.0, %
IDE09137-MAS05851,Output 5 for exterior lighting-Current power consumption,882, mA
IDE09137-MAS08347,Output 5 for exterior lighting-Assigned event code,B16D600,
IDE09137-MAS08349,Output 5 for exterior lighting-Type of connected lamp,LED,
IDE09138-MAS01580,Output 6 for exterior lighting-Activation,Output not used,
IDE09138-MAS05851,Output 6 for exterior lighting-Current power consumption,Output not used,
IDE09138-MAS08347,Output 6 for exterior lighting-Assigned event code,Output not used,
IDE09138-MAS08349,Output 6 for exterior lighting-Type of connected lamp,Output not used,
IDE09139-MAS01580,Output 7 for exterior lighting-Activation,Output not used,
IDE09139-MAS05851,Output 7 for exterior lighting-Current power consumption,Output not used,
IDE09139-MAS08347,Output 7 for exterior lighting-Assigned event code,Output not used,
IDE09139-MAS08349,Output 7 for exterior lighting-Type of connected lamp,Output not used,
IDE09140-MAS01580,Output 8 for exterior lighting-Activation,Output not used,
IDE09140-MAS05851,Output 8 for exterior lighting-Current power consumption,Output not used,
IDE09140-MAS08347,Output 8 for exterior lighting-Assigned event code,Output not used,
IDE09140-MAS08349,Output 8 for exterior lighting-Type of connected lamp,Output not used,
IDE09141-MAS01580,Output 9 for exterior lighting-Activation,Output not used,
IDE09141-MAS05851,Output 9 for exterior lighting-Current power consumption,Output not used,
IDE09141-MAS08347,Output 9 for exterior lighting-Assigned event code,Output not used,
IDE09141-MAS08349,Output 9 for exterior lighting-Type of connected lamp,Output not used,
IDE09142-MAS01580,Output 10 for exterior lighting-Activation,0.0, %
IDE09142-MAS05851,Output 10 for exterior lighting-Current power consumption,0, mA
IDE09142-MAS08347,Output 10 for exterior lighting-Assigned event code,B133400,
IDE09142-MAS08349,Output 10 for exterior lighting-Type of connected lamp,LED,
IDE09143-MAS01580,Output 11 for exterior lighting-Activation,100.0, %
IDE09143-MAS05851,Output 11 for exterior lighting-Current power consumption,729, mA
IDE09143-MAS08347,Output 11 for exterior lighting-Assigned event code,B188B00,
IDE09143-MAS08349,Output 11 for exterior lighting-Type of connected lamp,LED,
IDE09144-MAS01580,Output 12 for exterior lighting-Activation,Output not used,
IDE09144-MAS05851,Output 12 for exterior lighting-Current power consumption,Output not used,
IDE09144-MAS08347,Output 12 for exterior lighting-Assigned event code,Output not used,
IDE09144-MAS08349,Output 12 for exterior lighting-Type of connected lamp,Output not used,
IDE09145-MAS01580,Output 13 for exterior lighting-Activation,0.0, %
IDE09145-MAS05851,Output 13 for exterior lighting-Current power consumption,0, mA
IDE09145-MAS08347,Output 13 for exterior lighting-Assigned event code,B121500,
IDE09145-MAS08349,Output 13 for exterior lighting-Type of connected lamp,LED,
IDE09146-MAS01580,Output 14 for exterior lighting-Activation,0.0, %
IDE09146-MAS05851,Output 14 for exterior lighting-Current power consumption,0, mA
IDE09146-MAS08347,Output 14 for exterior lighting-Assigned event code,B133600,
IDE09146-MAS08349,Output 14 for exterior lighting-Type of connected lamp,LED,
IDE09147-MAS01580,Output 15 for exterior lighting-Activation,100.0, %
IDE09147-MAS05851,Output 15 for exterior lighting-Current power consumption,887, mA
IDE09147-MAS08347,Output 15 for exterior lighting-Assigned event code,B16D400,
IDE09147-MAS08349,Output 15 for exterior lighting-Type of connected lamp,LED,
IDE09148-MAS01580,Output 16 for exterior lighting-Activation,Output not used,
IDE09148-MAS05851,Output 16 for exterior lighting-Current power consumption,Output not used,
IDE09148-MAS08347,Output 16 for exterior lighting-Assigned event code,Output not used,
IDE09148-MAS08349,Output 16 for exterior lighting-Type of connected lamp,Output not used,
IDE09149-MAS01580,Output 17 for exterior lighting-Activation,0.0, %
IDE09149-MAS05851,Output 17 for exterior lighting-Current power consumption,0, mA
IDE09149-MAS08347,Output 17 for exterior lighting-Assigned event code,B12C600,
IDE09149-MAS08349,Output 17 for exterior lighting-Type of connected lamp,LED,
IDE09150-MAS01580,Output 18 for exterior lighting-Activation,Output not used,
IDE09150-MAS05851,Output 18 for exterior lighting-Current power consumption,Output not used,
IDE09150-MAS08347,Output 18 for exterior lighting-Assigned event code,Output not used,
IDE09150-MAS08349,Output 18 for exterior lighting-Type of connected lamp,Output not used,
IDE09151-MAS01580,Output 19 for exterior lighting-Activation,Output not used,
IDE09151-MAS05851,Output 19 for exterior lighting-Current power consumption,Output not used,
IDE09151-MAS08347,Output 19 for exterior lighting-Assigned event code,Output not used,
IDE09151-MAS08349,Output 19 for exterior lighting-Type of connected lamp,Output not used,
IDE09153-MAS01580,Output 20 for exterior lighting-Activation,Output not used,
IDE09153-MAS05851,Output 20 for exterior lighting-Current power consumption,Output not used,
IDE09153-MAS08347,Output 20 for exterior lighting-Assigned event code,Output not used,
IDE09153-MAS08349,Output 20 for exterior lighting-Type of connected lamp,Output not used,
IDE09157-MAS01580,Output 21 for exterior lighting-Activation,Output not used,
IDE09157-MAS05851,Output 21 for exterior lighting-Current power consumption,Output not used,
IDE09157-MAS08347,Output 21 for exterior lighting-Assigned event code,Output not used,
IDE09157-MAS08349,Output 21 for exterior lighting-Type of connected lamp,Output not used,
IDE09218-MAS06793,Key information-Number of adapted keys,2,
IDE09218-MAS07008,Key information-Number of keys to be adapted,2,
IDE09218-MAS08428,Key information-Number of the active key,1,
IDE09220-MAS01551,Information of last change code error-Key number,255,
IDE09220-MAS08433,Information of last change code error-Last OK counter status control module,FF FF FF FF,
IDE09220-MAS08434,Information of last change code error-Last OK counter status control module: redundant,FF FF FF FF,
IDE09220-MAS08435,Information of last change code error-Last OK counter status key,FF FF FF FF,
IDE09220-MAS08436,Information of last change code error-Counter status control module at error event,FF FF FF FF,
IDE09220-MAS08437,Information of last change code error-Counter status control module at error event: redundant,FF FF FF FF,
IDE09220-MAS08438,Information of last change code error-Counter status key at error event,FF FF FF FF,
IDE09220-MAS08460,Information of last change code error-Time between last OK recognition and error event,6553.500, s
IDE09221-MAS03692,Change code counter status-Key 1,00 00 05 9D,
IDE09221-MAS03693,Change code counter status-Key 2,00 00 09 17,
IDE09221-MAS03694,Change code counter status-Key 3,Not adapted,
IDE09221-MAS03695,Change code counter status-Key 4,Not adapted,
IDE09221-MAS03696,Change code counter status-Key 5,Not adapted,
IDE09221-MAS03697,Change code counter status-Key 6,Not adapted,
IDE09221-MAS03698,Change code counter status-Key 7,Not adapted,
IDE09221-MAS03699,Change code counter status-Key 8,Not adapted,
IDE09250-MAS08462,Key search in vehicle interior-Authenticated key in search area,00000001 ,
IDE09250-MAS08463,Key search in vehicle interior-Authenticated key,00000001 ,
IDE09250-MAS08464,Key search in vehicle interior-Recognized key,00000001 ,
IDE09252-MAS08462,Key search in luggage compartment-Authenticated key in search area,00000000 ,
IDE09252-MAS08463,Key search in luggage compartment-Authenticated key,00000001 ,
IDE09252-MAS08464,Key search in luggage compartment-Recognized key,00000001 ,
IDE09253-MAS08462,Key search in left area-Authenticated key in search area,00000000 ,
IDE09253-MAS08463,Key search in left area-Authenticated key,00000001 ,
IDE09253-MAS08464,Key search in left area-Recognized key,00000001 ,
IDE09254-MAS08462,Key search in right area-Authenticated key in search area,00000000 ,
IDE09254-MAS08463,Key search in right area-Authenticated key,00000001 ,
IDE09254-MAS08464,Key search in right area-Recognized key,00000001 ,
IDE09255-MAS08462,Key search in rear area-Authenticated key in search area,00000000 ,
IDE09255-MAS08463,Key search in rear area-Authenticated key,00000001 ,
IDE09255-MAS08464,Key search in rear area-Recognized key,00000001 ,
IDE09401-IDE00500,History data central locking: sixth-to-last event-Hour,11,
IDE09401-IDE00501,History data central locking: sixth-to-last event-Minute,29,
IDE09401-MAS00106,History data central locking: sixth-to-last event-Year,not known,
IDE09401-MAS00107,History data central locking: sixth-to-last event-Month,5,
IDE09401-MAS00108,History data central locking: sixth-to-last event-Day,14,
IDE09401-MAS00111,History data central locking: sixth-to-last event-Seconds,30,
IDE09401-MAS01551,History data central locking: sixth-to-last event-Key number,2,
IDE09401-MAS06441,History data central locking: sixth-to-last event-Control-section / cause,Outside door handle sens.: frt. right,
IDE09402-IDE00500,History data central locking: seventh-to-last event-Hour,11,
IDE09402-IDE00501,History data central locking: seventh-to-last event-Minute,29,
IDE09402-MAS00106,History data central locking: seventh-to-last event-Year,not known,
IDE09402-MAS00107,History data central locking: seventh-to-last event-Month,5,
IDE09402-MAS00108,History data central locking: seventh-to-last event-Day,14,
IDE09402-MAS00111,History data central locking: seventh-to-last event-Seconds,15,
IDE09402-MAS01551,History data central locking: seventh-to-last event-Key number,2,
IDE09402-MAS06441,History data central locking: seventh-to-last event-Control-section / cause,Outside door handle sens.: frt. right,
IDE09403-IDE00500,History data central locking: eighth-to-last event-Hour,11,
IDE09403-IDE00501,History data central locking: eighth-to-last event-Minute,29,
IDE09403-MAS00106,History data central locking: eighth-to-last event-Year,not known,
IDE09403-MAS00107,History data central locking: eighth-to-last event-Month,5,
IDE09403-MAS00108,History data central locking: eighth-to-last event-Day,14,
IDE09403-MAS00111,History data central locking: eighth-to-last event-Seconds,15,
IDE09403-MAS01551,History data central locking: eighth-to-last event-Key number,2,
IDE09403-MAS06441,History data central locking: eighth-to-last event-Control-section / cause,Outside door handle sens.: frt. right,
IDE09404-IDE00500,History data central locking: ninth-to-last event-Hour,11,
IDE09404-IDE00501,History data central locking: ninth-to-last event-Minute,29,
IDE09404-MAS00106,History data central locking: ninth-to-last event-Year,not known,
IDE09404-MAS00107,History data central locking: ninth-to-last event-Month,5,
IDE09404-MAS00108,History data central locking: ninth-to-last event-Day,14,
IDE09404-MAS00111,History data central locking: ninth-to-last event-Seconds,15,
IDE09404-MAS01551,History data central locking: ninth-to-last event-Key number,2,
IDE09404-MAS06441,History data central locking: ninth-to-last event-Control-section / cause,Outside door handle sens.: frt. right,
IDE09405-IDE00500,History data central locking: tenth-to-last event-Hour,11,
IDE09405-IDE00501,History data central locking: tenth-to-last event-Minute,14,
IDE09405-MAS00106,History data central locking: tenth-to-last event-Year,not known,
IDE09405-MAS00107,History data central locking: tenth-to-last event-Month,5,
IDE09405-MAS00108,History data central locking: tenth-to-last event-Day,14,
IDE09405-MAS00111,History data central locking: tenth-to-last event-Seconds,30,
IDE09405-MAS01551,History data central locking: tenth-to-last event-Key number,1,
IDE09405-MAS06441,History data central locking: tenth-to-last event-Control-section / cause,Auto lock,
IDE09406-IDE00500,History data central locking: eleventh-to-last event-Hour,11,
IDE09406-IDE00501,History data central locking: eleventh-to-last event-Minute,14,
IDE09406-MAS00106,History data central locking: eleventh-to-last event-Year,not known,
IDE09406-MAS00107,History data central locking: eleventh-to-last event-Month,5,
IDE09406-MAS00108,History data central locking: eleventh-to-last event-Day,14,
IDE09406-MAS00111,History data central locking: eleventh-to-last event-Seconds,30,
IDE09406-MAS01551,History data central locking: eleventh-to-last event-Key number,1,
IDE09406-MAS06441,History data central locking: eleventh-to-last event-Control-section / cause,No data available,
IDE09407-IDE00500,History data central locking: twelfth-to-last event-Hour,11,
IDE09407-IDE00501,History data central locking: twelfth-to-last event-Minute,13,
IDE09407-MAS00106,History data central locking: twelfth-to-last event-Year,not known,
IDE09407-MAS00107,History data central locking: twelfth-to-last event-Month,5,
IDE09407-MAS00108,History data central locking: twelfth-to-last event-Day,14,
IDE09407-MAS00111,History data central locking: twelfth-to-last event-Seconds,45,
IDE09407-MAS01551,History data central locking: twelfth-to-last event-Key number,2,
IDE09407-MAS06441,History data central locking: twelfth-to-last event-Control-section / cause,Outside door handle sens.: frt. left,
IDE09408-IDE00500,History data central locking: thirteenth-to-last event-Hour,8,
IDE09408-IDE00501,History data central locking: thirteenth-to-last event-Minute,46,
IDE09408-MAS00106,History data central locking: thirteenth-to-last event-Year,not known,
IDE09408-MAS00107,History data central locking: thirteenth-to-last event-Month,5,
IDE09408-MAS00108,History data central locking: thirteenth-to-last event-Day,14,
IDE09408-MAS00111,History data central locking: thirteenth-to-last event-Seconds,0,
IDE09408-MAS01551,History data central locking: thirteenth-to-last event-Key number,2,
IDE09408-MAS06441,History data central locking: thirteenth-to-last event-Control-section / cause,Outside door handle sens.: frt. right,
IDE09409-IDE00500,History data central locking: fourteenth-to-last event-Hour,8,
IDE09409-IDE00501,History data central locking: fourteenth-to-last event-Minute,27,
IDE09409-MAS00106,History data central locking: fourteenth-to-last event-Year,not known,
IDE09409-MAS00107,History data central locking: fourteenth-to-last event-Month,5,
IDE09409-MAS00108,History data central locking: fourteenth-to-last event-Day,14,
IDE09409-MAS00111,History data central locking: fourteenth-to-last event-Seconds,15,
IDE09409-MAS01551,History data central locking: fourteenth-to-last event-Key number,1,
IDE09409-MAS06441,History data central locking: fourteenth-to-last event-Control-section / cause,Auto lock,
IDE09410-IDE00500,History data central locking: fifteenth-to-last event-Hour,8,
IDE09410-IDE00501,History data central locking: fifteenth-to-last event-Minute,27,
IDE09410-MAS00106,History data central locking: fifteenth-to-last event-Year,not known,
IDE09410-MAS00107,History data central locking: fifteenth-to-last event-Month,5,
IDE09410-MAS00108,History data central locking: fifteenth-to-last event-Day,14,
IDE09410-MAS00111,History data central locking: fifteenth-to-last event-Seconds,15,
IDE09410-MAS01551,History data central locking: fifteenth-to-last event-Key number,1,
IDE09410-MAS06441,History data central locking: fifteenth-to-last event-Control-section / cause,No data available,
IDE09411-IDE00500,History data central locking: sixteenth-to-last event-Hour,17,
IDE09411-IDE00501,History data central locking: sixteenth-to-last event-Minute,20,
IDE09411-MAS00106,History data central locking: sixteenth-to-last event-Year,not known,
IDE09411-MAS00107,History data central locking: sixteenth-to-last event-Month,5,
IDE09411-MAS00108,History data central locking: sixteenth-to-last event-Day,13,
IDE09411-MAS00111,History data central locking: sixteenth-to-last event-Seconds,0,
IDE09411-MAS01551,History data central locking: sixteenth-to-last event-Key number,1,
IDE09411-MAS06441,History data central locking: sixteenth-to-last event-Control-section / cause,Auto lock,
IDE09412-IDE00500,History data central locking: seventeenth-to-last event-Hour,17,
IDE09412-IDE00501,History data central locking: seventeenth-to-last event-Minute,19,
IDE09412-MAS00106,History data central locking: seventeenth-to-last event-Year,not known,
IDE09412-MAS00107,History data central locking: seventeenth-to-last event-Month,5,
IDE09412-MAS00108,History data central locking: seventeenth-to-last event-Day,13,
IDE09412-MAS00111,History data central locking: seventeenth-to-last event-Seconds,45,
IDE09412-MAS01551,History data central locking: seventeenth-to-last event-Key number,1,
IDE09412-MAS06441,History data central locking: seventeenth-to-last event-Control-section / cause,No data available,
IDE09413-IDE00500,History data central locking: eighteenth-to-last event-Hour,17,
IDE09413-IDE00501,History data central locking: eighteenth-to-last event-Minute,14,
IDE09413-MAS00106,History data central locking: eighteenth-to-last event-Year,not known,
IDE09413-MAS00107,History data central locking: eighteenth-to-last event-Month,5,
IDE09413-MAS00108,History data central locking: eighteenth-to-last event-Day,13,
IDE09413-MAS00111,History data central locking: eighteenth-to-last event-Seconds,0,
IDE09413-MAS01551,History data central locking: eighteenth-to-last event-Key number,2,
IDE09413-MAS06441,History data central locking: eighteenth-to-last event-Control-section / cause,Outside door handle sens.: frt. right,
IDE09414-IDE00500,History data central locking: nineteenth-to-last event-Hour,8,
IDE09414-IDE00501,History data central locking: nineteenth-to-last event-Minute,43,
IDE09414-MAS00106,History data central locking: nineteenth-to-last event-Year,not known,
IDE09414-MAS00107,History data central locking: nineteenth-to-last event-Month,5,
IDE09414-MAS00108,History data central locking: nineteenth-to-last event-Day,13,
IDE09414-MAS00111,History data central locking: nineteenth-to-last event-Seconds,15,
IDE09414-MAS01551,History data central locking: nineteenth-to-last event-Key number,2,
IDE09414-MAS06441,History data central locking: nineteenth-to-last event-Control-section / cause,Outside door handle sens.: frt. right,
IDE09415-IDE00500,History data central locking: twentieth-to-last event-Hour,8,
IDE09415-IDE00501,History data central locking: twentieth-to-last event-Minute,41,
IDE09415-MAS00106,History data central locking: twentieth-to-last event-Year,not known,
IDE09415-MAS00107,History data central locking: twentieth-to-last event-Month,5,
IDE09415-MAS00108,History data central locking: twentieth-to-last event-Day,13,
IDE09415-MAS00111,History data central locking: twentieth-to-last event-Seconds,0,
IDE09415-MAS01551,History data central locking: twentieth-to-last event-Key number,2,
IDE09415-MAS06441,History data central locking: twentieth-to-last event-Control-section / cause,Outside door handle sens.: frt. right,
IDE09416,Control line for dynamic turn signal,not active,
IDE09840-MAS09380,CU for tailgate opener: counter readings-proximity detected,00 8A,
IDE09840-MAS09381,CU for tailgate opener: counter readings-Foot gestic detected,00 8A,
IDE09840-MAS09382,CU for tailgate opener: counter readings-De-activation,01 6C,
IDE09840-MAS09383,CU for tailgate opener: counter readings-Play protection activation,00 00,
IDE09841-MAS09384,CU for tailgate opener: sensor status-Proximity detected: sensor 1,No,
IDE09841-MAS09385,CU for tailgate opener: sensor status-Proximity detected: sensor 2,No,
IDE09841-MAS09386,CU for tailgate opener: sensor status-Sensor module connected,Yes,
IDE09917-MAS03692,Last change code counter status-Key 1,00 00 05 79,
IDE09917-MAS03693,Last change code counter status-Key 2,00 00 09 14,
IDE09917-MAS03694,Last change code counter status-Key 3,Not adapted,
IDE09917-MAS03695,Last change code counter status-Key 4,Not adapted,
IDE09917-MAS03696,Last change code counter status-Key 5,Not adapted,
IDE09917-MAS03697,Last change code counter status-Key 6,Not adapted,
IDE09917-MAS03698,Last change code counter status-Key 7,Not adapted,
IDE09917-MAS03699,Last change code counter status-Key 8,Not adapted,
IDE10096-MAS01551,Radio remote control: last radio shot-Key number,1,
IDE10096-MAS06879,Radio remote control: last radio shot-Checksum,OK,
IDE10096-MAS08411,Radio remote control: last radio shot-Button for vehicle locking,Not operated,
IDE10096-MAS08412,Radio remote control: last radio shot-Button for vehicle unlocking,Not operated,
IDE10096-MAS08413,Radio remote control: last radio shot-Button for luggage compartment unlocking,operated,
IDE10096-MAS08414,Radio remote control: last radio shot-Panic button,Not operated,
IDE10096-MAS08415,Radio remote control: last radio shot-Battery status,New,
IDE10096-MAS08419,Radio remote control: last radio shot-Key condition,OK,
IDE10096-MAS08421,Radio remote control: last radio shot-Transponder ID: Byte 1,D5,
IDE10096-MAS08422,Radio remote control: last radio shot-Cryptography,OK,
IDE10096-MAS08423,Radio remote control: last radio shot-Rolling code information,Detection area 1,
IDE10096-MAS08427,Radio remote control: last radio shot-Time since last radio shot,255, s
IDE10096-MAS13216,Radio remote control: last radio shot-Front windshield remote unlocking button,Not operated,
IDE10096-MAS13230,Radio remote control: last radio shot-Freely assignable button,Not operated,
IDE10097-IDE01442,Comfort closing convert. top/rear lid-Pressing a button,no key actuated,
IDE10097-MAS06528,Comfort closing convert. top/rear lid-Release status,not enabled,
IDE10097-MAS08432,Comfort closing convert. top/rear lid-Requirement,No,
IDE10097-MAS09907,Comfort closing convert. top/rear lid-Key search,not active,
IDE10097-MAS09908,Comfort closing convert. top/rear lid-Key within reach,No,
IDE10097-MAS09909,Comfort closing convert. top/rear lid-Number of key searches,0,
IDE10097-MAS09910,Comfort closing convert. top/rear lid-Number of key responses,0,
IDE10098-MAS09911,Zone and area information key 1 - 4-Key 1: Zone information,not installed,
IDE10098-MAS09912,Zone and area information key 1 - 4-Key 1: Area information,not installed,
IDE10098-MAS09913,Zone and area information key 1 - 4-Key 2: Zone information,not installed,
IDE10098-MAS09914,Zone and area information key 1 - 4-Key 2: Area information,not installed,
IDE10098-MAS09915,Zone and area information key 1 - 4-Key 3: Zone information,Not adapted,
IDE10098-MAS09916,Zone and area information key 1 - 4-Key 3: Area information,Not adapted,
IDE10098-MAS09917,Zone and area information key 1 - 4-Key 4: Zone information,Not adapted,
IDE10098-MAS09918,Zone and area information key 1 - 4-Key 4: Area information,Not adapted,
IDE10099-MAS09919,Zone and area information key 5 - 8-Key 5: Zone information,Not adapted,
IDE10099-MAS09920,Zone and area information key 5 - 8-Key 5: Area information,Not adapted,
IDE10099-MAS09921,Zone and area information key 5 - 8-Key 6: Zone information,Not adapted,
IDE10099-MAS09922,Zone and area information key 5 - 8-Key 6: Area information,Not adapted,
IDE10099-MAS09923,Zone and area information key 5 - 8-Key 7: Zone information,Not adapted,
IDE10099-MAS09924,Zone and area information key 5 - 8-Key 7: Area information,Not adapted,
IDE10099-MAS09925,Zone and area information key 5 - 8-Key 8: Zone information,Not adapted,
IDE10099-MAS09926,Zone and area information key 5 - 8-Key 8: Area information,Not adapted,
IDE10100-MAS09931,Individual activation of antennae for access and start system-Access/start system antenna 1 in vehicle interior,180,
IDE10100-MAS09932,Individual activation of antennae for access and start system-Access/start system antenna in luggage compartment,104,
IDE10100-MAS09933,Individual activation of antennae for access and start system-Left Access/Start Authorization Antenna,88,
IDE10100-MAS09934,Individual activation of antennae for access and start system-Right Access/Start Authorization Antenna,88,
IDE10100-MAS09935,Individual activation of antennae for access and start system-Access/start system antenna 2 in vehicle interior,254,
IDE10159-MAS09936,Outside door handle sens.: frt. left-Unlocking sensor: proximity detected,No,
IDE10159-MAS09937,Outside door handle sens.: frt. left-Locking sensor: proximity detected,No,
IDE10159-MAS09938,Outside door handle sens.: frt. left-Unlocking sensor: activation detected,No,
IDE10159-MAS09939,Outside door handle sens.: frt. left-Locking sensor: activation detected,No,
IDE10159-MAS09951,Outside door handle sens.: frt. left-Receiving wakeup signal,No,
IDE10160-MAS09936,Outside door handle sens.: frt. right-Unlocking sensor: proximity detected,No,
IDE10160-MAS09937,Outside door handle sens.: frt. right-Locking sensor: proximity detected,No,
IDE10160-MAS09938,Outside door handle sens.: frt. right-Unlocking sensor: activation detected,No,
IDE10160-MAS09939,Outside door handle sens.: frt. right-Locking sensor: activation detected,No,
IDE10160-MAS09951,Outside door handle sens.: frt. right-Receiving wakeup signal,No,
IDE10161-MAS09936,Outside door handle sens.: left rear-Unlocking sensor: proximity detected,No,
IDE10161-MAS09937,Outside door handle sens.: left rear-Locking sensor: proximity detected,No,
IDE10161-MAS09938,Outside door handle sens.: left rear-Unlocking sensor: activation detected,No,
IDE10161-MAS09939,Outside door handle sens.: left rear-Locking sensor: activation detected,No,
IDE10161-MAS09951,Outside door handle sens.: left rear-Receiving wakeup signal,No,
IDE10162-MAS09936,Outside door handle sens.: right rear-Unlocking sensor: proximity detected,No,
IDE10162-MAS09937,Outside door handle sens.: right rear-Locking sensor: proximity detected,No,
IDE10162-MAS09938,Outside door handle sens.: right rear-Unlocking sensor: activation detected,No,
IDE10162-MAS09939,Outside door handle sens.: right rear-Locking sensor: activation detected,No,
IDE10162-MAS09951,Outside door handle sens.: right rear-Receiving wakeup signal,No,
IDE10190-MAS02040,Left front outside door handle sens.: status-Anti-play protection,not active,
IDE10190-MAS06517,Left front outside door handle sens.: status-Rear spoiler counter,0,
IDE10190-MAS08440,Left front outside door handle sens.: status-Activity,active,
IDE10191-MAS02040,Right front outside door handle sens.: status-Anti-play protection,not active,
IDE10191-MAS06517,Right front outside door handle sens.: status-Rear spoiler counter,0,
IDE10191-MAS08440,Right front outside door handle sens.: status-Activity,active,
IDE10192-MAS02040,Left rear outside door handle sens.: status-Anti-play protection,not active,
IDE10192-MAS06517,Left rear outside door handle sens.: status-Rear spoiler counter,0,
IDE10192-MAS08440,Left rear outside door handle sens.: status-Activity,active,
IDE10193-MAS02040,Right rear outside door handle sens.: status-Anti-play protection,not active,
IDE10193-MAS06517,Right rear outside door handle sens.: status-Rear spoiler counter,0,
IDE10193-MAS08440,Right rear outside door handle sens.: status-Activity,active,
IDE10262-MAS08462,Key search in vehicle interior (scan)-Authenticated key in search area,00000001 ,
IDE10262-MAS08463,Key search in vehicle interior (scan)-Authenticated key,00000001 ,
IDE10262-MAS08464,Key search in vehicle interior (scan)-Recognized key,00000001 ,
IDE10263-MAS03692,Transponder IDs found during last key search-Key 1,FF FF FF FF,
IDE10263-MAS03693,Transponder IDs found during last key search-Key 2,FF FF FF FF,
IDE10263-MAS03694,Transponder IDs found during last key search-Key 3,FF FF FF FF,
IDE10263-MAS03695,Transponder IDs found during last key search-Key 4,FF FF FF FF,
IDE10263-MAS03696,Transponder IDs found during last key search-Key 5,FF FF FF FF,
IDE10263-MAS03697,Transponder IDs found during last key search-Key 6,FF FF FF FF,
IDE10263-MAS03698,Transponder IDs found during last key search-Key 7,FF FF FF FF,
IDE10263-MAS03699,Transponder IDs found during last key search-Key 8,FF FF FF FF,
IDE10263-MAS10077,Transponder IDs found during last key search-Number of repeated searches,00,
IDE10263-MAS10078,Transponder IDs found during last key search-Number of keys found,00,
IDE10284-MAS03692,Number of "Key battery dead" recognitions-Key 1,0,
IDE10284-MAS03693,Number of "Key battery dead" recognitions-Key 2,0,
IDE10284-MAS03694,Number of "Key battery dead" recognitions-Key 3,Not adapted,
IDE10284-MAS03695,Number of "Key battery dead" recognitions-Key 4,Not adapted,
IDE10284-MAS03696,Number of "Key battery dead" recognitions-Key 5,Not adapted,
IDE10284-MAS03697,Number of "Key battery dead" recognitions-Key 6,Not adapted,
IDE10284-MAS03698,Number of "Key battery dead" recognitions-Key 7,Not adapted,
IDE10284-MAS03699,Number of "Key battery dead" recognitions-Key 8,Not adapted,
IDE10285-MAS02447,Release of rear lid exterior button-Release,Enabled,
IDE10306-MAS10178,Rear window heater test: measures voltage differences-Pulse 1,0.000, V
IDE10306-MAS10179,Rear window heater test: measures voltage differences-Pulse 2,0.000, V
IDE10306-MAS10180,Rear window heater test: measures voltage differences-Pulse 3,0.000, V
IDE10306-MAS10181,Rear window heater test: measures voltage differences-Pulse 4,0.000, V
IDE10306-MAS10182,Rear window heater test: measures voltage differences-Pulse 5,0.000, V
IDE10306-MAS10183,Rear window heater test: measures voltage differences-Pulse 6,0.000, V
IDE10306-MAS10184,Rear window heater test: measures voltage differences-Pulse 7,0.000, V
IDE10306-MAS10185,Rear window heater test: measures voltage differences-Pulse 8,0.000, V
IDE10306-MAS10186,Rear window heater test: measures voltage differences-Pulse 9,0.000, V
IDE10306-MAS10187,Rear window heater test: measures voltage differences-Pulse 10,0.000, V
IDE10306-MAS10188,Rear window heater test: measures voltage differences-Pulse 11,0.000, V
IDE10306-MAS10189,Rear window heater test: measures voltage differences-Pulse 12,0.000, V
IDE10306-MAS10190,Rear window heater test: measures voltage differences-Pulse 13,0.000, V
IDE10306-MAS10191,Rear window heater test: measures voltage differences-Pulse 14,0.000, V
IDE10306-MAS10192,Rear window heater test: measures voltage differences-Pulse 15,0.000, V
IDE10306-MAS10193,Rear window heater test: measures voltage differences-Mean value,0.000, V
IDE10348,Trip distance data,31 00 00 00 00 00 00 00 00 00 46 14 00 00 01 57 41 31 41 41 41 47 45 38 4D 42 30 32 38 39 31 37 5B 44 4F 39 3D DE 07 1C 00 C0 00 01 00 98 03 00 00 55 5D 1C 86 99 03 00 00 55 5D 1D 3B 00 00 00 FF FF FF FF FF 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00 FF FF FF FF FF 02 A6 0F 00 C0 0A 00 54 92 F1 B4 01 42 B3 01 FF FF 00 55 60 B4 2B,
IDE10681,Blocked keys,00,
IDE10682-MAS00106,Historical data blocked keys-Year,2021,
IDE10682-MAS00107,Historical data blocked keys-Month,2,
IDE10682-MAS00108,Historical data blocked keys-Day,9,
IDE10682-MAS00109,Historical data blocked keys-Hours,14,
IDE10682-MAS00110,Historical data blocked keys-Minutes,10,
IDE10682-MAS00111,Historical data blocked keys-Seconds,59,
IDE10682-MAS01551,Historical data blocked keys-Key number,1,
IDE10682-MAS11095,Historical data blocked keys-Cause,0,
IDE10683-IDE00500,Historical data unsuccessful automatic cut-off terminal 15-Hour,13,
IDE10683-IDE00501,Historical data unsuccessful automatic cut-off terminal 15-Minute,47,
IDE10683-MAS00107,Historical data unsuccessful automatic cut-off terminal 15-Month,5,
IDE10683-MAS00108,Historical data unsuccessful automatic cut-off terminal 15-Day,9,
IDE10683-MAS08075,Historical data unsuccessful automatic cut-off terminal 15-Reason for shut-off attempt,Timeout,
IDE10683-MAS08080,Historical data unsuccessful automatic cut-off terminal 15-Failure reason,255,
IDE10683-MAS08081,Historical data unsuccessful automatic cut-off terminal 15-Reason for timer stop,01101111 ,
IDE10684-IDE00500,Historical data unsuccessful switch-on attempt term 15-Hour,17,
IDE10684-IDE00501,Historical data unsuccessful switch-on attempt term 15-Minute,22,
IDE10684-MAS00107,Historical data unsuccessful switch-on attempt term 15-Month,4,
IDE10684-MAS00108,Historical data unsuccessful switch-on attempt term 15-Day,18,
IDE10684-MAS08080,Historical data unsuccessful switch-on attempt term 15-Failure reason,1,
IDE10685-IDE00500,Historical data automatic cut-off terminal 15-Hour,17,
IDE10685-IDE00501,Historical data automatic cut-off terminal 15-Minute,32,
IDE10685-IDE04105,Historical data automatic cut-off terminal 15-Freeze frame conditions,00000000 00000000 ,
IDE10685-MAS00107,Historical data automatic cut-off terminal 15-Month,5,
IDE10685-MAS00108,Historical data automatic cut-off terminal 15-Day,7,
IDE10685-MAS08082,Historical data automatic cut-off terminal 15-Reason for shut-off,Exiting the vehicle,
IDE10685-MAS08087,Historical data automatic cut-off terminal 15-Shut-off due to locking of vehicle: control section,Remote control,
IDE10685-MAS08091,Historical data automatic cut-off terminal 15-State before shut-off,00001111 ,
IDE10686-IDE00500,Historical data switch-on source terminal 15-Hour,11,
IDE10686-IDE00501,Historical data switch-on source terminal 15-Minute,47,
IDE10686-MAS00107,Historical data switch-on source terminal 15-Month,5,
IDE10686-MAS00108,Historical data switch-on source terminal 15-Day,16,
IDE10686-MAS11095,Historical data switch-on source terminal 15-Cause,Actuation of button for access and start authorization,
IDE10696-IDE00500,Histor.data switch-off terminal 15 by means of actuat. button-Hour,11,
IDE10696-IDE00501,Histor.data switch-off terminal 15 by means of actuat. button-Minute,16,
IDE10696-IDE04105,Histor.data switch-off terminal 15 by means of actuat. button-Freeze frame conditions,00000000 00000000 ,
IDE10696-MAS00107,Histor.data switch-off terminal 15 by means of actuat. button-Month,5,
IDE10696-MAS00108,Histor.data switch-off terminal 15 by means of actuat. button-Day,16,
IDE10696-MAS08082,Histor.data switch-off terminal 15 by means of actuat. button-Reason for shut-off,Normal shut-off,
IDE10696-MAS08091,Histor.data switch-off terminal 15 by means of actuat. button-State before shut-off,00001111 ,
IDE10750,Anti-theft warn. interior monitoring: version of parameter set,22 01,
IDE11484,Rear spoiler: position,not coded/not installed,
IDE11487-MAS12819,Trunk emergency release-Button for trunk emergency unlocking system,not coded/not installed,
IDE11487-MAS12820,Trunk emergency release-Luggage compartment emergency release button,not coded/not installed,
IDE11487-MAS12821,Trunk emergency release-Button for unlocking hood,not coded/not installed,
IDE11487-MAS12822,Trunk emergency release-Hood release motor,not coded/not installed,
IDE11487-MAS12823,Trunk emergency release-Enabling trunk emergency unlocking,not coded/not installed,
IDE11487-MAS12824,Trunk emergency release-Enabling trunk emerg. unlocking: reversed,Unknown (3),
IDE11487-MAS12825,Trunk emergency release-Error display in instrument panel cluster,not coded/not installed,
IDE11487-MAS17287,Trunk emergency release-Indicator lamp for luggage compartment emergency release,OFF,
IDE11487-MAS19653,Trunk emergency release-Indicator lamp for trunk emergency unlock: front,OFF,
IDE11778-MAS09936,Engine hood unlocking mechanism sensor-Unlocking sensor: proximity detected,not coded/not installed,
IDE11778-MAS09937,Engine hood unlocking mechanism sensor-Locking sensor: proximity detected,not coded/not installed,
IDE11778-MAS09938,Engine hood unlocking mechanism sensor-Unlocking sensor: activation detected,not coded/not installed,
IDE11778-MAS09939,Engine hood unlocking mechanism sensor-Locking sensor: activation detected,not coded/not installed,
IDE11778-MAS09951,Engine hood unlocking mechanism sensor-Receiving wakeup signal,not coded/not installed,
IDE11779-MAS02040,Engine hood unlocking mechanism sensor: status-Anti-play protection,not coded/not installed,
IDE11779-MAS06517,Engine hood unlocking mechanism sensor: status-Rear spoiler counter,not coded/not installed,
IDE11779-MAS08440,Engine hood unlocking mechanism sensor: status-Activity,not coded/not installed,
IDE11780-MAS09936,Rear hood unlocking mechanism sensor-Unlocking sensor: proximity detected,not coded/not installed,
IDE11780-MAS09937,Rear hood unlocking mechanism sensor-Locking sensor: proximity detected,not coded/not installed,
IDE11780-MAS09938,Rear hood unlocking mechanism sensor-Unlocking sensor: activation detected,not coded/not installed,
IDE11780-MAS09939,Rear hood unlocking mechanism sensor-Locking sensor: activation detected,not coded/not installed,
IDE11780-MAS09951,Rear hood unlocking mechanism sensor-Receiving wakeup signal,not coded/not installed,
IDE11781-MAS02040,Rear hood unlocking mechanism sensor: status-Anti-play protection,not coded/not installed,
IDE11781-MAS06517,Rear hood unlocking mechanism sensor: status-Rear spoiler counter,not coded/not installed,
IDE11781-MAS08440,Rear hood unlocking mechanism sensor: status-Activity,not coded/not installed,
IDE11938-IDE02021,Piloted parking and vehicle stopping function-Comfort closing,not coded/not installed,
IDE11938-MAS00829,Piloted parking and vehicle stopping function-Access/start authorization,no request,
IDE11938-MAS02362,Piloted parking and vehicle stopping function-Flashing: right,not coded/not installed,
IDE11938-MAS02363,Piloted parking and vehicle stopping function-Flashing: left,not coded/not installed,
IDE11938-MAS02444,Piloted parking and vehicle stopping function-Central locking system,not coded/not installed,
IDE11938-MAS09388,Piloted parking and vehicle stopping function-Engine run,no request,
IDE11938-MAS09907,Piloted parking and vehicle stopping function-Key search,no request,
IDE11938-MAS13254,Piloted parking and vehicle stopping function-Active parking function,not coded/not installed,
IDE11938-MAS13454,Piloted parking and vehicle stopping function-Comfort closing: convertible top,not coded/not installed,
IDE11938-MAS13462,Piloted parking and vehicle stopping function-Hazard lights of emergency assistant,Not available,
IDE11938-MAS13469,Piloted parking and vehicle stopping function-Vehicle stopping function,not coded/not installed,
IDE11938-MAS14248,Piloted parking and vehicle stopping function-Unlocking by vehicle halt function,no request,
IDE11938-MAS14250,Piloted parking and vehicle stopping function-Radio key LED,no request,
IDE11938-MAS14251,Piloted parking and vehicle stopping function-Driver information,no request,
IDE11938-MAS14253,Piloted parking and vehicle stopping function-Confirmation flashing,not coded/not installed,
IDE11980-MAS01156,Windshield defroster relay-Communication status,not coded/not installed,
IDE11980-MAS01478,Windshield defroster relay-insufficient voltage,not coded/not installed,
IDE11980-MAS01479,Windshield defroster relay-Excessive voltage,not coded/not installed,
IDE11980-MAS01580,Windshield defroster relay-Activation,not coded/not installed,
IDE11980-MAS08432,Windshield defroster relay-Requirement,not coded/not installed,
IDE11980-MAS13674,Windshield defroster relay-Windshield defogger button,not coded/not installed,
IDE11980-MAS13675,Windshield defroster relay-Windshield defogger indicator lamp,not coded/not installed,
IDE11980-MAS13676,Windshield defroster relay-Power quota,not coded/not installed,
IDE11980-MAS13720,Windshield defroster relay-Error qualification,not coded/not installed,
IDE11980-MAS13724,Windshield defroster relay-Status of self-monitoring,not coded/not installed,
IDE11984-MAS10178,Result of checking relay for heated windshield-Pulse 1,0.000, V
IDE11984-MAS10179,Result of checking relay for heated windshield-Pulse 2,0.000, V
IDE11984-MAS10180,Result of checking relay for heated windshield-Pulse 3,0.000, V
IDE11984-MAS10181,Result of checking relay for heated windshield-Pulse 4,0.000, V
IDE11984-MAS10182,Result of checking relay for heated windshield-Pulse 5,0.000, V
IDE11984-MAS10183,Result of checking relay for heated windshield-Pulse 6,0.000, V
IDE11984-MAS10184,Result of checking relay for heated windshield-Pulse 7,0.000, V
IDE11984-MAS10185,Result of checking relay for heated windshield-Pulse 8,0.000, V
IDE11984-MAS10186,Result of checking relay for heated windshield-Pulse 9,0.000, V
IDE11984-MAS10187,Result of checking relay for heated windshield-Pulse 10,0.000, V
IDE11984-MAS10188,Result of checking relay for heated windshield-Pulse 11,0.000, V
IDE11984-MAS10189,Result of checking relay for heated windshield-Pulse 12,0.000, V
IDE11984-MAS10190,Result of checking relay for heated windshield-Pulse 13,0.000, V
IDE11984-MAS10191,Result of checking relay for heated windshield-Pulse 14,0.000, V
IDE11984-MAS10192,Result of checking relay for heated windshield-Pulse 15,0.000, V
IDE11984-MAS10193,Result of checking relay for heated windshield-Mean value,0.000, V
IDE11996-MAS13729,Sunshade 2-Button for rear sunshade in operat. and numb. for A/C sys:rear,not coded/not installed,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,Yes,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,00,
IDE12262-MAS18563,Virtual radio key: status-Smartcard active,No,
IDE12263,Virtual radio key: vehicle ID,D7 10 11 94 0F 74 C7 DA A5 C0 DD 8A E0 FE E9 0D,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,73 C5 2F FB,
IDE12304-IDE00500,Separation monitoring radio key to rear lid: history-Hour,not known,
IDE12304-IDE00501,Separation monitoring radio key to rear lid: history-Minute,not known,
IDE12304-MAS00111,Separation monitoring radio key to rear lid: history-Seconds,not known,
IDE12304-MAS14238,Separation monitoring radio key to rear lid: history-Key found in Zone 1,00001111 ,
IDE12304-MAS14239,Separation monitoring radio key to rear lid: history-Key found in Zone 2,00001111 ,
IDE12304-MAS14240,Separation monitoring radio key to rear lid: history-Key found in Zone 3,00001111 ,
IDE12304-MAS14241,Separation monitoring radio key to rear lid: history-Key found in Zone 4,00001111 ,
IDE12304-MAS15180,Separation monitoring radio key to rear lid: history-Part function carried out,00001111 ,
IDE12304-MAS15181,Separation monitoring radio key to rear lid: history-Cause of cancellation:,00001111 ,
IDE12466-IDE00500,Unlocking central locking system history data-Hour,17,
IDE12466-IDE00501,Unlocking central locking system history data-Minute,52,
IDE12466-MAS00106,Unlocking central locking system history data-Year,2021,
IDE12466-MAS00107,Unlocking central locking system history data-Month,5,
IDE12466-MAS00108,Unlocking central locking system history data-Day,14,
IDE12466-MAS00111,Unlocking central locking system history data-Seconds,51,
IDE12466-MAS01551,Unlocking central locking system history data-Key number,1,
IDE12466-MAS06441,Unlocking central locking system history data-Control-section / cause,Auto unlock,
IDE12549-IDE00500,History data NFC authentication-Hour,not known,
IDE12549-IDE00501,History data NFC authentication-Minute,not known,
IDE12549-MAS00106,History data NFC authentication-Year,not known,
IDE12549-MAS00107,History data NFC authentication-Month,not known,
IDE12549-MAS00108,History data NFC authentication-Day,not known,
IDE12549-MAS00111,History data NFC authentication-Seconds,not known,
IDE12549-MAS14763,History data NFC authentication-Authentication type,FF,
IDE12549-MAS14764,History data NFC authentication-Authentication event,FF,
IDE12549-MAS14765,History data NFC authentication-Key number of NFC device,255,
IDE12549-MAS14766,History data NFC authentication-Authentication location,15,
IDE12834-MAS07359,Relay for preconditioning-via discreet wire,not coded/not installed,
IDE12834-MAS07360,Relay for preconditioning-via data bus,not coded/not installed,
IDE12834-MAS15268,Relay for preconditioning-Requirement from Climatronic control module,not coded/not installed,
IDE13345-MAS16268,Current Secure Element-Secure Element,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13345-MAS16269,Current Secure Element-Secure Element is contained in ticket table,No,
IDE13345-MAS16270,Current Secure Element-Secure element is authenticated,No,
IDE13403-IDE08980,Rear spoiler control module: input signals-Button for rear spoiler adjustment,not coded/not installed,
IDE13403-IDE13404,Rear spoiler control module: input signals-Locking by keyless access authorization: driver door,not coded/not installed,
IDE13403-MAS00370,Rear spoiler control module: input signals-Vehicle speed,not coded/not installed,
IDE13403-MAS01443,Rear spoiler control module: input signals-Request by Engine Control Module,not coded/not installed,
IDE13403-MAS01468,Rear spoiler control module: input signals-Terminal 15,not coded/not installed,
IDE13403-MAS06253,Rear spoiler control module: input signals-Static current measuring mode,not coded/not installed,
IDE13403-MAS06429,Rear spoiler control module: input signals-Transport protection,not coded/not installed,
IDE13403-MAS16413,Rear spoiler control module: input signals-Unlock driver lock cylinder contact switch,not coded/not installed,
IDE13403-MAS16414,Rear spoiler control module: input signals-Lock driver lock cylinder contact switch,not coded/not installed,
IDE13405-IDE08980,Rear spoiler control module: output signals-Button for rear spoiler adjustment,not coded/not installed,
IDE13405-MAS01478,Rear spoiler control module: output signals-insufficient voltage,not coded/not installed,
IDE13405-MAS01479,Rear spoiler control module: output signals-Excessive voltage,not coded/not installed,
IDE13405-MAS02040,Rear spoiler control module: output signals-Anti-play protection,not coded/not installed,
IDE13405-MAS02590,Rear spoiler control module: output signals-Red warning light,not coded/not installed,
IDE13405-MAS02591,Rear spoiler control module: output signals-Yellow warning light,not coded/not installed,
IDE13405-MAS04737,Rear spoiler control module: output signals-Indicator lamp,not coded/not installed,
IDE13405-MAS16466,Rear spoiler control module: output signals-Rear spoiler positioning button: status,not coded/not installed,
IDE13405-MAS16467,Rear spoiler control module: output signals-Stop position retracted,not coded/not installed,
IDE13405-MAS16470,Rear spoiler control module: output signals-Stop position extended,not coded/not installed,
IDE13405-MAS16471,Rear spoiler control module: output signals-Rear spoiler positioning: status,not coded/not installed,
IDE13405-MAS16472,Rear spoiler control module: output signals-Rear spoiler positioning motor: status,not coded/not installed,
IDE13405-MAS16473,Rear spoiler control module: output signals-Rear spoiler: malfunction status,not coded/not installed,
IDE13405-MAS16474,Rear spoiler control module: output signals-Manual operation blocked,not coded/not installed,
IDE13405-MAS16475,Rear spoiler control module: output signals-BAP signals,not coded/not installed,
IDE13870-MAS08462,Key search at charging socket 1-Authenticated key in search area,00000000 ,
IDE13870-MAS08463,Key search at charging socket 1-Authenticated key,00000001 ,
IDE13870-MAS08464,Key search at charging socket 1-Recognized key,00000001 ,
IDE13871-MAS08462,Key search at charging socket 2-Authenticated key in search area,00000000 ,
IDE13871-MAS08463,Key search at charging socket 2-Authenticated key,00000001 ,
IDE13871-MAS08464,Key search at charging socket 2-Recognized key,00000001 ,
IDE14071-MAS04361,Central locking system actuation counter-Counter 1,0,
IDE14071-MAS04362,Central locking system actuation counter-Counter 2,0,
IDE14071-MAS04363,Central locking system actuation counter-Counter 3,0,
IDE14071-MAS04364,Central locking system actuation counter-Counter 4,0,
IDE14071-MAS17381,Central locking system actuation counter-Interface 1: counter 1,0,
IDE14071-MAS17382,Central locking system actuation counter-Interface 2: counter 1,0,
IDE14071-MAS17383,Central locking system actuation counter-Interface 3: counter 1,0,
IDE14071-MAS17384,Central locking system actuation counter-Interface 1: counter 2,0,
IDE14071-MAS17385,Central locking system actuation counter-Interface 2: counter 2,0,
IDE14071-MAS17386,Central locking system actuation counter-Interface 3: counter 2,0,
IDE14071-MAS17387,Central locking system actuation counter-Interface 1: counter 3,0,
IDE14071-MAS17388,Central locking system actuation counter-Interface 2: counter 3,0,
IDE14071-MAS17389,Central locking system actuation counter-Interface 3: counter 3,0,
IDE14071-MAS17390,Central locking system actuation counter-Interface 1: counter 4,0,
IDE14071-MAS17391,Central locking system actuation counter-Interface 2: counter 4,0,
IDE14071-MAS17392,Central locking system actuation counter-Interface 3: counter 4,0,
IDE14245-MAS19730,Component protection configuration-Configuration bit 1,not configured,
IDE14245-MAS19731,Component protection configuration-Configuration bit 0,not activated,
IDE14245-MAS19732,Component protection configuration-Configuration bit 2,not configured,
IDE14245-MAS19733,Component protection configuration-Configuration bit 3,not configured,
IDE14245-MAS19734,Component protection configuration-Configuration bit 4,not configured,
IDE14245-MAS19735,Component protection configuration-Configuration bit 5,not configured,
IDE14245-MAS19736,Component protection configuration-Configuration bit 6,not configured,
IDE14245-MAS19737,Component protection configuration-Configuration bit 7,not configured,
IDE14245-MAS19738,Component protection configuration-Configuration bit 8,not configured,
IDE14245-MAS19739,Component protection configuration-Configuration bit 9,not configured,
IDE14245-MAS19740,Component protection configuration-Configuration bit 10,not configured,
IDE14245-MAS19741,Component protection configuration-Configuration bit 11,not configured,
IDE14245-MAS19742,Component protection configuration-Configuration bit 12,not configured,
IDE14245-MAS19743,Component protection configuration-Configuration bit 13,not configured,
IDE14245-MAS19744,Component protection configuration-Configuration bit 14,not configured,
IDE14245-MAS19745,Component protection configuration-Configuration bit 15,not configured,
IDE80001-MAS01483,Analysis 1-Software version,N173,
IDE80001-MAS06973,Analysis 1-Target hardware version BCM2,    ,
IDE80001-MAS06974,Analysis 1-HF building block: hardware version,0023,
IDE80001-MAS06975,Analysis 1-HF building block: firmware version,0000,
IDE80001-MAS06976,Analysis 1-LF building block: hardware version,0034,
IDE80001-MAS06977,Analysis 1-LF building block: firmware version,2407,
IDE80001-MAS06978,Analysis 1-LF building block: version configuration data,0000,
IDE80001-MAS06979,Analysis 1-Version CDD_LF,0024,
IDE80001-MAS06980,Analysis 1-Version CDD_RF,0021,
MAS00077-MAS02345,Immobilizer-Current condition,Adapted,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,C2,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-MAS10132,Immobilizer-Configuration Kessy coded,Yes,
MAS00077-MAS10133,Immobilizer-Configuration E vehicle,Yes,
MAS00077-MAS10134,Immobilizer-Configuration SHE,Yes,
MAS00077-MAS14181,Immobilizer-Configuration of virtual radio key ready,Yes,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 03 01 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,2,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
ENG98397-ENG13709,Airbag-seat_belt_lock_driver_side,2,
ENG98397-ENG46648,Airbag-seat_occupied_driver_side,0,
ENG12918,antenna_freeze_frame,01010010 00000000 00000000 01010100 ,
ENG12884-ENG13852,Breaking_light_operating_mode-Intern_operating_mode,Driving_mode,
ENG12884-ENG13853,Breaking_light_operating_mode-Transition_operating_mode,04,
ENG12916,can_lin_communication_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12857-MAS06439,central_locking_crash_status-Crash status,not active,
ENG12857-MAS06440,central_locking_crash_status-Precrash status,not active,
ENG12860-MAS00314,clutch_pedal_status-Clutch Pedal Switch,not coded/not installed,
ENG12860-MAS00363,clutch_pedal_status-Clutch pedal position,numerical value: no text,
ENG12860-MAS06475,clutch_pedal_status-Clutch Pedal Switch for Engine Start,not coded/not installed,
ENG12886-IDE01442,Comfort_close_convertible_top_and_trunk_lid-Pressing a button,no key actuated,
ENG12886-ENG13854,Comfort_close_convertible_top_and_trunk_lid-Key_search,No,
ENG12886-ENG13855,Comfort_close_convertible_top_and_trunk_lid-Key_within_reach,No,
ENG12886-ENG13857,Comfort_close_convertible_top_and_trunk_lid-Number_of_key_responses,0,
ENG12886-ENG13856,Comfort_close_convertible_top_and_trunk_lid-Number_of_key_searches,0,
ENG12905-ENG14003,communication_state_fbs-latest_job_number,52,
ENG12905-ENG14002,communication_state_fbs-latest_job_request_confirmation,0B,
ENG12905-ENG14001,communication_state_fbs-latest_job_request_job_number,52,
ENG12905-ENG14004,communication_state_fbs-latest_job_result,01,
ENG12905-ENG14007,communication_state_fbs-latest_key_info_authentication,01,
ENG12905-ENG14005,communication_state_fbs-latest_key_info_job_number,52,
ENG12905-ENG14006,communication_state_fbs-latest_key_info_key_line,00,
ENG12905-ENG14008,communication_state_fbs-latest_key_info_position,01,
ENG12847-MAS04188,cutoff_levels-Transport mode,not active,
ENG12847-MAS06253,cutoff_levels-Static current measuring mode,not active,
ENG12847-MAS06428,cutoff_levels-Static current shut-off stage,Deactivation stage 0,
ENG12847-MAS06429,cutoff_levels-Transport protection,not active,
ENG114468-ENG109174,Cycle_data_flash_history-SW_VERSION,0565,
ENG12904-ENG13995,debug_fbs-debug_1,00000000 00000000 00000000 00000000 ,
ENG12904-ENG13996,debug_fbs-debug_2,00000000 00000000 00000000 00000000 ,
ENG12904-ENG13997,debug_fbs-debug_3,11111111 11111111 11110100 10010010 ,
ENG12904-ENG13998,debug_fbs-debug_4,11111111 11111111 11111001 00100011 ,
ENG12904-ENG13999,debug_fbs-debug_5,11111111 11111111 11111111 11111111 ,
ENG12904-ENG14000,debug_fbs-debug_6,00000000 00000000 00000000 00000000 ,
ENG12917,defect_fusi_voltage_error_freeze_frame,00000000 00000000 00001000 00000000 ,
ENG12903-ENG98504,diagnose_01_message-Day,16,
ENG12903-ENG98653,diagnose_01_message-Hour,12,
ENG12903-ENG98667,diagnose_01_message-Kilometers,921,
ENG12903-ENG98739,diagnose_01_message-Minute,6,
ENG12903-ENG98748,diagnose_01_message-Month,5,
ENG12903-ENG102365,diagnose_01_message-Second,22,
ENG12903-ENG99063,diagnose_01_message-Year,2021,
ENG12881-MAS11095,Diagnosis_data_sbc-Cause,0,
ENG12861-ENG13706,elv_01-elv_clamp_enabling,No enabling,
ENG12861-ENG13707,elv_01-elv_interruption_request_clamp_enabling,no_interruption,
ENG12861-ENG13704,elv_01-elv_locked,Not_Locked,
ENG12861-ENG13705,elv_01-elv_unlocked,unlocked,
ENG12843-MAS00371,Engine_status-Engine RPM,0.00, /min
ENG12843-MAS04447,Engine_status-Engine running status,Engine not running,
ENG12843-MAS06149,Engine_status-Terminal 75,active,
ENG12843-MAS06150,Engine_status-Terminal 50,not active,
ENG12843-MAS06712,Engine_status-Status drive readiness hybrid,Not ready,
ENG12843-ENG13701,Engine_status-restart_lock,not active,
ENG12843-ENG13702,Engine_status-start_from_msg,2,
ENG12843-ENG13700,Engine_status-start_stop_driver_command,Initialization,
ENG12843-ENG13699,Engine_status-start_stop_engine_stop,not active,
ENG12843-ENG114851,Engine_status-Start_Stop_Restart,not active,
ENG12843-ENG121476,Engine_status-Start_Stop_status,system_not_available_at_this_kl15_cycle,
ENG122522-ENG99298,EPB_01-State,1,
ENG12890-ENG13891,Error_counter_keyless-lf_antenna_error,0,
ENG12890-ENG13893,Error_counter_keyless-Retries,0,
ENG12890-ENG13892,Error_counter_keyless-unsuccessfully_entry_exit_activities,251,
ENG12888-ENG13882,Error_counter_lf_hf_communication-Checksum_error_hf,6,
ENG12888-ENG13884,Error_counter_lf_hf_communication-cryptology_error,0,
ENG12888-ENG13883,Error_counter_lf_hf_communication-Data_error_hf,23,
ENG12919,exterior_handle_sensor_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12882-ENG13849,External_light_defect_reasons-Break_light,00000000 ,
ENG12882-ENG13851,External_light_defect_reasons-Other_reasons,00000000 00000000 ,
ENG12882-ENG13659,External_light_defect_reasons-Tail_light,00000000 ,
ENG12882-ENG13850,External_light_defect_reasons-Turn_signal_light,00000000 00000000 ,
ENG48509-ENG49940,FoD_slave_operating_state-FoD_slave_state,02,
ENG12920,fuel_sender_freeze_frame,00000010 00000000 00000000 00000000 ,
ENG48830-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,Not available,
ENG48830-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,invalid,
ENG48830-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,10 03 01 00,
ENG48830-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,available.,
ENG48830-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,OK,
ENG48830-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition not met,
ENG48830-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,No,
ENG48830-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition not met,
ENG48830-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,2,
ENG48830-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG12911-ENG14036,general_additional_freeze_frame-Ambient_temperature_not_filtered,25.5, °C
ENG12911-ENG14040,general_additional_freeze_frame-coprocessor_spi_status,00000001 ,
ENG12911-ENG14039,general_additional_freeze_frame-dataflash_status,00000000 ,
ENG12911-ENG02610,general_additional_freeze_frame-interior_temperature,27.0, °C
ENG12911-ENG13636,general_additional_freeze_frame-Operating_Status,00000001 00000000 ,
ENG12911-ENG104256,general_additional_freeze_frame-production_mode,not active,
ENG12911-ENG14038,general_additional_freeze_frame-reset_cause,00011101 ,
ENG12911-ENG108452,general_additional_freeze_frame-Reset_counter,0,
ENG12911-ENG13694,general_additional_freeze_frame-Stall_current_cutoff_level,Deactivation stage 0,
ENG12911-ENG13635,general_additional_freeze_frame-Stall_Current_Measuring_Mode,not active,
ENG12911-ENG14037,general_additional_freeze_frame-subnetwork_status,00000001 00000000 ,
ENG12911-ENG14035,general_additional_freeze_frame-terminal_control_intern_status,1B 01 0A 10 00 E0,
ENG12911-ENG111086,general_additional_freeze_frame-Transport_Mode,not active,
ENG12911-ENG99010,general_additional_freeze_frame-Vehicle speed,0.00, km/h
ENG12859,hazard_warning_switch,Not operated,
ENG12858,hdsg_opening_acknowledge,not active,
ENG12910-ENG127696,HF_LF_Counters-Counter_1,0,
ENG12910-ENG14012,HF_LF_Counters-Counter_10,0,
ENG12910-ENG14013,HF_LF_Counters-Counter_11,0,
ENG12910-ENG14014,HF_LF_Counters-Counter_12,0,
ENG12910-ENG14015,HF_LF_Counters-Counter_13,0,
ENG12910-ENG14016,HF_LF_Counters-Counter_14,0,
ENG12910-ENG14017,HF_LF_Counters-Counter_15,0,
ENG12910-ENG14018,HF_LF_Counters-Counter_16,8,
ENG12910-ENG14019,HF_LF_Counters-Counter_17,0,
ENG12910-ENG14020,HF_LF_Counters-Counter_18,0,
ENG12910-ENG14021,HF_LF_Counters-Counter_19,0,
ENG12910-ENG127697,HF_LF_Counters-Counter_2,0,
ENG12910-ENG14022,HF_LF_Counters-Counter_20,1,
ENG12910-ENG14023,HF_LF_Counters-Counter_21,4,
ENG12910-ENG14024,HF_LF_Counters-Counter_22,40,
ENG12910-ENG14025,HF_LF_Counters-Counter_23,0,
ENG12910-ENG14026,HF_LF_Counters-Counter_24,0,
ENG12910-ENG14027,HF_LF_Counters-Counter_25,0,
ENG12910-ENG14028,HF_LF_Counters-Counter_26,0,
ENG12910-ENG14029,HF_LF_Counters-Counter_27,0,
ENG12910-ENG14030,HF_LF_Counters-Counter_28,0,
ENG12910-ENG14031,HF_LF_Counters-Counter_29,0,
ENG12910-ENG127700,HF_LF_Counters-Counter_3,0,
ENG12910-ENG14032,HF_LF_Counters-Counter_30,0,
ENG12910-ENG14033,HF_LF_Counters-Counter_31,0,
ENG12910-ENG14034,HF_LF_Counters-Counter_32,1,
ENG12910-ENG127699,HF_LF_Counters-Counter_4,0,
ENG12910-ENG127698,HF_LF_Counters-Counter_5,0,
ENG12910-ENG127701,HF_LF_Counters-Counter_6,0,
ENG12910-ENG14009,HF_LF_Counters-Counter_7,2,
ENG12910-ENG14010,HF_LF_Counters-Counter_8,0,
ENG12910-ENG14011,HF_LF_Counters-Counter_9,0,
ENG12883-ENG98842,ignition_switch_pag-Position,not coded/not installed,
ENG12921,Immobilizer_freeze_frame_1,00000000 00000000 00000000 00000000 ,
ENG12930,Immobilizer_freeze_frame_10,00000000 00000000 00000000 00000000 ,
ENG12931,Immobilizer_freeze_frame_11,00000000 00000000 00000000 00000000 ,
ENG12932,Immobilizer_freeze_frame_12,00000000 00000000 00000000 00000000 ,
ENG12933,Immobilizer_freeze_frame_13,00000000 00000000 00000000 00000000 ,
ENG12934,Immobilizer_freeze_frame_14,00000000 00000000 00000000 00000000 ,
ENG13201,Immobilizer_freeze_frame_15,00000000 00000000 00000000 00000000 ,
ENG12922,Immobilizer_freeze_frame_2,00000000 00000000 00000000 00000000 ,
ENG12923,Immobilizer_freeze_frame_3,00000000 00000000 00000000 00000000 ,
ENG12924,Immobilizer_freeze_frame_4,00000000 00000000 00000000 00000000 ,
ENG12925,Immobilizer_freeze_frame_5,00000000 00000000 00000000 00000000 ,
ENG12926,Immobilizer_freeze_frame_6,00000000 00000000 00000000 00000000 ,
ENG12927,Immobilizer_freeze_frame_7,00000000 00000000 00000000 00000000 ,
ENG12928,Immobilizer_freeze_frame_8,00000000 00000000 00000000 00000000 ,
ENG12929,Immobilizer_freeze_frame_9,00000000 00000000 00000000 00000000 ,
ENG13196-ENG14609,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte1,00000000 11111111 ,
ENG13196-ENG14610,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte2,00000000 10111001 ,
ENG13196-ENG14611,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte3,00000000 11000000 ,
ENG13196-ENG14612,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte4,00000000 11000000 ,
ENG13196-ENG14613,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte5,00000000 11100000 ,
ENG13196-ENG14614,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte6,00000000 10001000 ,
ENG13196-ENG14615,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte7,00000000 00000010 ,
ENG13196-ENG14616,intelligent_tail_light_signals_LIN-BCM2_SBBR_01_byte8,00000000 11111111 ,
ENG13196-ENG14617,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte1,00000000 11111111 ,
ENG13196-ENG14618,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte2,00000000 01111111 ,
ENG13196-ENG14619,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte3,00000000 00000000 ,
ENG13196-ENG14620,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte4,00000000 00000000 ,
ENG13196-ENG14621,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte5,00000000 11111110 ,
ENG13196-ENG14622,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte6,00000000 11111111 ,
ENG13196-ENG14623,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte7,00000000 11111111 ,
ENG13196-ENG14624,intelligent_tail_light_signals_LIN-SHL_li1s_01_byte8,00000000 11111111 ,
ENG13196-ENG14625,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte1,00000000 11111111 ,
ENG13196-ENG14626,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte2,00000000 01111111 ,
ENG13196-ENG14627,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte3,00000000 00000000 ,
ENG13196-ENG14628,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte4,00000000 00000000 ,
ENG13196-ENG14629,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte5,00000000 11111110 ,
ENG13196-ENG14630,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte6,00000000 11111111 ,
ENG13196-ENG14631,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte7,00000000 11111111 ,
ENG13196-ENG14632,intelligent_tail_light_signals_LIN-SHL_li2s_01_byte8,00000000 11111111 ,
ENG13196-ENG14633,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte1,00000000 11111111 ,
ENG13196-ENG14634,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte2,00000000 01111111 ,
ENG13196-ENG14635,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte3,00000000 00000000 ,
ENG13196-ENG14636,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte4,00000000 00000000 ,
ENG13196-ENG14637,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte5,00000000 11111110 ,
ENG13196-ENG14638,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte6,00000000 11111111 ,
ENG13196-ENG14639,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte7,00000000 11111111 ,
ENG13196-ENG14640,intelligent_tail_light_signals_LIN-SHL_re1s_01_byte8,00000000 11111111 ,
ENG13196-ENG14641,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte1,00000000 11111111 ,
ENG13196-ENG14642,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte2,00000000 01111111 ,
ENG13196-ENG14643,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte3,00000000 00000000 ,
ENG13196-ENG14644,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte4,00000000 00000000 ,
ENG13196-ENG14645,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte5,00000000 11111110 ,
ENG13196-ENG14646,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte6,00000000 11111111 ,
ENG13196-ENG14647,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte7,00000000 11111111 ,
ENG13196-ENG14648,intelligent_tail_light_signals_LIN-SHL_re2s_01_byte8,00000000 11111111 ,
ENG12889-ENG13886,Intern_conditions_advanced_key-Active_advanced_key_priority,254,
ENG12889-ENG13885,Intern_conditions_advanced_key-Aktive_activity,5E,
ENG12889-ENG13889,Intern_conditions_advanced_key-IDG_line_Luki,0,
ENG12889-ENG13890,Intern_conditions_advanced_key-IDG_line_VLuki,1,
ENG12889-ENG13887,Intern_conditions_advanced_key-Next_advanced_key_Activity,5E,
ENG12889-ENG13888,Intern_conditions_advanced_key-Next_advanced_key_priority,254,
ENG26920-ENG30365,IRUE_NGS_deactivation_via_mmi-ASG_Aktivation_State,3,
ENG26920-ENG31533,IRUE_NGS_deactivation_via_mmi-FSG_Aktivation_State,3,
ENG12912,key_error_freeze_frame,11001101 11111111 11111111 11111111 ,
ENG12909-MAS00106,Life_cycle_data_failed_keyless_search-Year,2021,
ENG12909-MAS00107,Life_cycle_data_failed_keyless_search-Month,5,
ENG12909-MAS00108,Life_cycle_data_failed_keyless_search-Day,15,
ENG12909-MAS00109,Life_cycle_data_failed_keyless_search-Hours,12,
ENG12909-MAS00110,Life_cycle_data_failed_keyless_search-Minutes,36,
ENG12909-MAS00111,Life_cycle_data_failed_keyless_search-Seconds,8,
ENG12909-ENG28817,Life_cycle_data_failed_keyless_search-Error_description,00000000 ,
ENG12909-ENG13626,Life_cycle_data_failed_keyless_search-Trigger,37,
ENG12907-MAS00106,Life_cycle_data_keyless_entry_exit_search-Year,2021,
ENG12907-MAS00107,Life_cycle_data_keyless_entry_exit_search-Month,5,
ENG12907-MAS00108,Life_cycle_data_keyless_entry_exit_search-Day,16,
ENG12907-MAS00109,Life_cycle_data_keyless_entry_exit_search-Hours,11,
ENG12907-MAS00110,Life_cycle_data_keyless_entry_exit_search-Minutes,47,
ENG12907-MAS00111,Life_cycle_data_keyless_entry_exit_search-Seconds,23,
ENG12907-ENG28815,Life_cycle_data_keyless_entry_exit_search-Operating_point,00001000 ,
ENG12907-ENG28814,Life_cycle_data_keyless_entry_exit_search-Search_result,00001000 ,
ENG12908-MAS00106,Life_cycle_data_keyless_event_search-Year,2021,
ENG12908-MAS00107,Life_cycle_data_keyless_event_search-Month,5,
ENG12908-MAS00108,Life_cycle_data_keyless_event_search-Day,15,
ENG12908-MAS00109,Life_cycle_data_keyless_event_search-Hours,15,
ENG12908-MAS00110,Life_cycle_data_keyless_event_search-Minutes,50,
ENG12908-MAS00111,Life_cycle_data_keyless_event_search-Seconds,26,
ENG12908-MAS00370,Life_cycle_data_keyless_event_search-Vehicle speed,0, km/h
ENG12908-ENG28816,Life_cycle_data_keyless_event_search-Search_cycle,01100000 ,
ENG12908-ENG28814,Life_cycle_data_keyless_event_search-Search_result,00000001 ,
ENG12908-ENG13626,Life_cycle_data_keyless_event_search-Trigger,2,
ENG12906-MAS00106,Life_cycle_data_keyless_go_search-Year,2021,
ENG12906-MAS00107,Life_cycle_data_keyless_go_search-Month,5,
ENG12906-MAS00108,Life_cycle_data_keyless_go_search-Day,16,
ENG12906-MAS00109,Life_cycle_data_keyless_go_search-Hours,11,
ENG12906-MAS00110,Life_cycle_data_keyless_go_search-Minutes,47,
ENG12906-MAS00111,Life_cycle_data_keyless_go_search-Seconds,50,
ENG12906-ENG28814,Life_cycle_data_keyless_go_search-Search_result,00001000 ,
ENG12906-ENG13626,Life_cycle_data_keyless_go_search-Trigger,00010000 ,
ENG12877-MAS00106,Life_cycle_data_reset_reasons_coprocessor-Year,2000,
ENG12877-MAS00107,Life_cycle_data_reset_reasons_coprocessor-Month,0,
ENG12877-MAS00108,Life_cycle_data_reset_reasons_coprocessor-Day,0,
ENG12877-MAS00109,Life_cycle_data_reset_reasons_coprocessor-Hours,0,
ENG12877-MAS00110,Life_cycle_data_reset_reasons_coprocessor-Minutes,0,
ENG12877-MAS00111,Life_cycle_data_reset_reasons_coprocessor-Seconds,0,
ENG12877-MAS11095,Life_cycle_data_reset_reasons_coprocessor-Cause,0,
ENG12879-MAS00106,Life_cycle_data_reset_reasons_main_processor-Year,2000,
ENG12879-MAS00107,Life_cycle_data_reset_reasons_main_processor-Month,0,
ENG12879-MAS00108,Life_cycle_data_reset_reasons_main_processor-Day,0,
ENG12879-MAS00109,Life_cycle_data_reset_reasons_main_processor-Hours,0,
ENG12879-MAS00110,Life_cycle_data_reset_reasons_main_processor-Minutes,0,
ENG12879-MAS00111,Life_cycle_data_reset_reasons_main_processor-Seconds,0,
ENG12879-MAS11095,Life_cycle_data_reset_reasons_main_processor-Cause,0,
ENG12914,light_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG117002-ENG13752,MFG-mfg_signals_CAN,not coded/not installed,
ENG12863-ENG13712,NVEM-request_kl15_deactivation,0,
ENG12874-ENG13836,Outputs_for_exterior_lighting-Output_1,Output not used,
ENG12874-ENG120566,Outputs_for_exterior_lighting-Output_10,not active,
ENG12874-ENG120567,Outputs_for_exterior_lighting-Output_11,active,
ENG12874-ENG120568,Outputs_for_exterior_lighting-Output_12,Output not used,
ENG12874-ENG120561,Outputs_for_exterior_lighting-Output_13,not active,
ENG12874-ENG120562,Outputs_for_exterior_lighting-Output_14,not active,
ENG12874-ENG120563,Outputs_for_exterior_lighting-Output_15,active,
ENG12874-ENG120564,Outputs_for_exterior_lighting-Output_16,Output not used,
ENG12874-ENG120557,Outputs_for_exterior_lighting-Output_17,not active,
ENG12874-ENG120558,Outputs_for_exterior_lighting-Output_18,Output not used,
ENG12874-ENG120559,Outputs_for_exterior_lighting-Output_19,Output not used,
ENG12874-ENG13837,Outputs_for_exterior_lighting-Output_2,Output not used,
ENG12874-ENG120560,Outputs_for_exterior_lighting-Output_20,Output not used,
ENG12874-ENG120553,Outputs_for_exterior_lighting-Output_21,Output not used,
ENG12874-ENG13838,Outputs_for_exterior_lighting-Output_3,not active,
ENG12874-ENG13839,Outputs_for_exterior_lighting-Output_4,not active,
ENG12874-ENG13840,Outputs_for_exterior_lighting-Output_5,active,
ENG12874-ENG13841,Outputs_for_exterior_lighting-Output_6,Output not used,
ENG12874-ENG13842,Outputs_for_exterior_lighting-Output_7,Output not used,
ENG12874-ENG13843,Outputs_for_exterior_lighting-Output_8,Output not used,
ENG12874-ENG13844,Outputs_for_exterior_lighting-Output_9,Output not used,
ENG12869-ENG13749,park_heating_and_air_conditioning-auxiliary_ventilation_CAN,not active,
ENG12869-ENG02610,park_heating_and_air_conditioning-interior_temperature,27.0, °C
ENG12869-ENG13748,park_heating_and_air_conditioning-park_heating_CAN,not active,
ENG12869-ENG13750,park_heating_and_air_conditioning-solar_fan_CAN,not active,
ENG126653-IDE00500,Personalized_Account_Key_History-Hour,15,
ENG126653-IDE00501,Personalized_Account_Key_History-Minute,49,
ENG126653-MAS00107,Personalized_Account_Key_History-Month,5,
ENG126653-MAS00108,Personalized_Account_Key_History-Day,15,
ENG126653-MAS00111,Personalized_Account_Key_History-Seconds,6,
ENG126653-ENG29120,Personalized_Account_Key_History-Account_number,1,
ENG126653-ENG29858,Personalized_Account_Key_History-Device_number,1,
ENG12943-MAS03692,Personalized_key_setting-Key 1,0,
ENG12943-MAS03693,Personalized_key_setting-Key 2,0,
ENG12943-MAS03694,Personalized_key_setting-Key 3,0,
ENG12943-MAS03695,Personalized_key_setting-Key 4,0,
ENG12943-MAS03696,Personalized_key_setting-Key 5,0,
ENG12943-MAS03697,Personalized_key_setting-Key 6,0,
ENG12943-MAS03698,Personalized_key_setting-Key 7,0,
ENG12943-MAS03699,Personalized_key_setting-Key 8,0,
ENG126654-IDE00500,Personalized_Signals-Hour,20,
ENG126654-IDE00501,Personalized_Signals-Minute,56,
ENG126654-MAS00107,Personalized_Signals-Month,4,
ENG126654-MAS00108,Personalized_Signals-Day,26,
ENG126654-MAS00111,Personalized_Signals-Seconds,48,
ENG126654-ENG29120,Personalized_Signals-Account_number,2,
ENG126654-ENG98351,Personalized_Signals-active,active,
ENG126654-ENG29121,Personalized_Signals-Contol_mode,0,
ENG126654-ENG29122,Personalized_Signals-Control_parameter,0,
ENG126654-ENG29124,Personalized_Signals-Enabling_adjustment,Release,
ENG126654-ENG29123,Personalized_Signals-Position_of_actuation,Initialization,
ENG126654-ENG99298,Personalized_Signals-State,not active,
ENG121948-ENG121879,Rear_Lid_Opening_Sender_Cycle_Data-trace_1,10,
ENG121948-ENG121888,Rear_Lid_Opening_Sender_Cycle_Data-trace_10,10,
ENG121948-ENG121889,Rear_Lid_Opening_Sender_Cycle_Data-trace_11,01,
ENG121948-ENG121890,Rear_Lid_Opening_Sender_Cycle_Data-trace_12,01,
ENG121948-ENG121891,Rear_Lid_Opening_Sender_Cycle_Data-trace_13,01,
ENG121948-ENG121892,Rear_Lid_Opening_Sender_Cycle_Data-trace_14,01,
ENG121948-ENG121893,Rear_Lid_Opening_Sender_Cycle_Data-trace_15,01,
ENG121948-ENG121894,Rear_Lid_Opening_Sender_Cycle_Data-trace_16,01,
ENG121948-ENG121895,Rear_Lid_Opening_Sender_Cycle_Data-trace_17,01,
ENG121948-ENG121896,Rear_Lid_Opening_Sender_Cycle_Data-trace_18,10,
ENG121948-ENG121897,Rear_Lid_Opening_Sender_Cycle_Data-trace_19,01,
ENG121948-ENG121880,Rear_Lid_Opening_Sender_Cycle_Data-trace_2,10,
ENG121948-ENG121898,Rear_Lid_Opening_Sender_Cycle_Data-trace_20,01,
ENG121948-ENG121881,Rear_Lid_Opening_Sender_Cycle_Data-trace_3,10,
ENG121948-ENG121882,Rear_Lid_Opening_Sender_Cycle_Data-trace_4,10,
ENG121948-ENG121883,Rear_Lid_Opening_Sender_Cycle_Data-trace_5,01,
ENG121948-ENG121884,Rear_Lid_Opening_Sender_Cycle_Data-trace_6,01,
ENG121948-ENG121885,Rear_Lid_Opening_Sender_Cycle_Data-trace_7,01,
ENG121948-ENG121886,Rear_Lid_Opening_Sender_Cycle_Data-trace_8,01,
ENG121948-ENG121887,Rear_Lid_Opening_Sender_Cycle_Data-trace_9,01,
ENG121949,Rear_Lid_Opening_Sender_ROM-Parameter_Version,09 10,
ENG12878-ENG108452,Reset_counter_coprocessor-Reset_counter,1,
ENG12880-ENG108452,Reset_counter_main_processor-Reset_counter,0,
ENG12897-ENG13902,service_key_counter_datagroup-datagroup_1,97,
ENG12897-ENG13903,service_key_counter_datagroup-datagroup_2,109,
ENG12897-ENG13904,service_key_counter_datagroup-datagroup_3,89,
ENG12897-ENG13905,service_key_counter_datagroup-datagroup_4,231,
ENG12899-ENG13914,service_key_intern_conditions-conditions,00000011 ,
ENG12899-ENG13916,service_key_intern_conditions-mq_states,00,
ENG12899-ENG13918,service_key_intern_conditions-obdc_changed_datagroup,00 00,
ENG12899-ENG13915,service_key_intern_conditions-obdc_interface_states,00000010 ,
ENG12899-ENG13917,service_key_intern_conditions-obdc_request_timeout_counter,30,
ENG12899-ENG13626,service_key_intern_conditions-Trigger,00000001 ,
ENG12901-ENG13983,service_key_key_store_counter-all_key_counter,764,
ENG12901-ENG13894,service_key_key_store_counter-key1_counter,222,
ENG12901-ENG13895,service_key_key_store_counter-key2_counter,527,
ENG12901-ENG13896,service_key_key_store_counter-key3_counter,Not adapted,
ENG12901-ENG13897,service_key_key_store_counter-key4_counter,Not adapted,
ENG12901-ENG13898,service_key_key_store_counter-key5_counter,Not adapted,
ENG12901-ENG13899,service_key_key_store_counter-key6_counter,Not adapted,
ENG12901-ENG13900,service_key_key_store_counter-key7_counter,Not adapted,
ENG12901-ENG13901,service_key_key_store_counter-key8_counter,Not adapted,
ENG12902-ENG13894,service_key_key_store_counter_per_day-key1_counter,20,
ENG12902-ENG13895,service_key_key_store_counter_per_day-key2_counter,20,
ENG12902-ENG13896,service_key_key_store_counter_per_day-key3_counter,Not adapted,
ENG12902-ENG13897,service_key_key_store_counter_per_day-key4_counter,Not adapted,
ENG12902-ENG13898,service_key_key_store_counter_per_day-key5_counter,Not adapted,
ENG12902-ENG13899,service_key_key_store_counter_per_day-key6_counter,Not adapted,
ENG12902-ENG13900,service_key_key_store_counter_per_day-key7_counter,Not adapted,
ENG12902-ENG13901,service_key_key_store_counter_per_day-key8_counter,Not adapted,
ENG12898-ENG13913,service_key_store_conditions-debounce_kilometer,15,
ENG12898-ENG13621,service_key_store_conditions-Distance,20,
ENG12898-ENG13911,service_key_store_conditions-hazard_warning_switch_delay_time,10,
ENG12898-ENG13908,service_key_store_conditions-retry_request_obdc,3,
ENG12898-ENG13906,service_key_store_conditions-service_key_coded,Yes,
ENG12898-ENG13907,service_key_store_conditions-timeout_request_obdc,30,
ENG12898-ENG13912,service_key_store_conditions-write_data_delay_time,40,
ENG12898-ENG13910,service_key_store_conditions-write_delay_speed,20,
ENG12898-ENG13909,service_key_store_conditions-write_delay_time,20,
ENG12900-ENG13920,service_key_store_time-key1_day,9,
ENG12900-ENG13919,service_key_store_time-key1_kilometer,788,
ENG12900-ENG13921,service_key_store_time-key1_month,5,
ENG12900-ENG13922,service_key_store_time-key1_year,2021,
ENG12900-ENG13924,service_key_store_time-key2_day,14,
ENG12900-ENG13923,service_key_store_time-key2_kilometer,905,
ENG12900-ENG13925,service_key_store_time-key2_month,5,
ENG12900-ENG13926,service_key_store_time-key2_year,2021,
ENG12900-ENG13928,service_key_store_time-key3_day,Not adapted,
ENG12900-ENG13927,service_key_store_time-key3_kilometer,Not adapted,
ENG12900-ENG13929,service_key_store_time-key3_month,Not adapted,
ENG12900-ENG13930,service_key_store_time-key3_year,Not adapted,
ENG12900-ENG13932,service_key_store_time-key4_day,Not adapted,
ENG12900-ENG13931,service_key_store_time-key4_kilometer,Not adapted,
ENG12900-ENG13933,service_key_store_time-key4_month,Not adapted,
ENG12900-ENG13934,service_key_store_time-key4_year,Not adapted,
ENG12900-ENG13936,service_key_store_time-key5_day,Not adapted,
ENG12900-ENG13935,service_key_store_time-key5_kilometer,Not adapted,
ENG12900-ENG13937,service_key_store_time-key5_month,Not adapted,
ENG12900-ENG13938,service_key_store_time-key5_year,Not adapted,
ENG12900-ENG13940,service_key_store_time-key6_day,Not adapted,
ENG12900-ENG13939,service_key_store_time-key6_kilometer,Not adapted,
ENG12900-ENG13941,service_key_store_time-key6_month,Not adapted,
ENG12900-ENG13942,service_key_store_time-key6_year,Not adapted,
ENG12900-ENG13944,service_key_store_time-key7_day,Not adapted,
ENG12900-ENG13943,service_key_store_time-key7_kilometer,Not adapted,
ENG12900-ENG13945,service_key_store_time-key7_month,Not adapted,
ENG12900-ENG13946,service_key_store_time-key7_year,Not adapted,
ENG12900-ENG13948,service_key_store_time-key8_day,Not adapted,
ENG12900-ENG13947,service_key_store_time-key8_kilometer,Not adapted,
ENG12900-ENG13949,service_key_store_time-key8_month,Not adapted,
ENG12900-ENG13950,service_key_store_time-key8_year,Not adapted,
ENG12885,Software_version_fbs,M310805:SW_C2.6.N173_MLB_EVO_FBS,
ENG12856-MAS06262,sun_blind_power_limit_status-Roof blind 1,not active,
ENG12856-MAS06263,sun_blind_power_limit_status-Roof Blind 2,not coded/not installed,
ENG12850-MAS06262,sun_blind_standardization_status-Roof blind 1,standardized,
ENG12850-MAS06263,sun_blind_standardization_status-Roof Blind 2,not coded/not installed,
ENG12853-MAS06262,sun_blind_thermal_protection_status-Roof blind 1,not active,
ENG12853-MAS06263,sun_blind_thermal_protection_status-Roof Blind 2,not coded/not installed,
ENG12942-ENG14150,sun_roof_position-MD1_position,0, %
ENG12942-ENG14151,sun_roof_position-MD3_position,0, %
ENG12942-ENG14152,sun_roof_position-Sun_roof_2_position,not coded/not installed,
ENG12855-MAS06260,sun_roof_power_limit_status-Sunroof 1,not active,
ENG12855-MAS06261,sun_roof_power_limit_status-Sunroof 2,not coded/not installed,
ENG12870-ENG13754,sunroof_control_unit-sunroof_control_unit_signals_CAN,not coded/not installed,
ENG12849-MAS06260,sunroof_standardization_status-Sunroof 1,standardized,
ENG12849-MAS06261,sunroof_standardization_status-Sunroof 2,not coded/not installed,
ENG12852-MAS06260,sunroof_thermal_protection_status-Sunroof 1,not active,
ENG12852-MAS06261,sunroof_thermal_protection_status-Sunroof 2,not coded/not installed,
ENG12875-ENG13846,sw_version_in_house_development-Software_version_central_locking,00 00 00 00,
ENG12875-ENG13845,sw_version_in_house_development-Software_version_clamp_control,10 05 02 1F,
ENG12875-ENG13847,sw_version_in_house_development-Software_version_reserve_1,,
ENG12875-ENG13848,sw_version_in_house_development-Software_version_reserve_2,,
ENG12876,System_load,01,
ENG12862-ENG13711,systeminfo_01-diagnostics_active,active,
ENG12913,terminal_control_freeze_frame,00000000 00000000 00000000 00000000 ,
ENG12864-ENG13717,terminal_control_intern_conditions-restart_information,no_restart_detected,
ENG12864-ENG13716,terminal_control_intern_conditions-start_stop_information,start_stop_not_coded,
ENG12864-ENG13714,terminal_control_intern_conditions-terminal_control_status,state_S3,
ENG12864-ENG13715,terminal_control_intern_conditions-terminal_control_status_terminals,00000011 ,
ENG12867-ENG13743,terminal_control_intern_signals-customer_request,00000000 ,
ENG12867-ENG13738,terminal_control_intern_signals-diagnostic_routine_kl15,00000000 ,
ENG12867-ENG13740,terminal_control_intern_signals-elv,00000011 ,
ENG12867-ENG13736,terminal_control_intern_signals-engine_brake_gearshift,00000001 ,
ENG12867-ENG13745,terminal_control_intern_signals-kl15_counter,203,
ENG12867-ENG13742,terminal_control_intern_signals-kl15_shut_off,00010001 ,
ENG12867-ENG13741,terminal_control_intern_signals-leave_concept,00000000 ,
ENG12867-ENG13739,terminal_control_intern_signals-p_mode,00000000 ,
ENG12867-ENG13737,terminal_control_intern_signals-sst,00000000 ,
ENG12867-ENG13744,terminal_control_intern_signals-start_trials,0,
ENG12865-ENG13719,terminal_control_klemmen_status_01-bz,11,
ENG12865-ENG13718,terminal_control_klemmen_status_01-crc,80,
ENG12865-ENG13723,terminal_control_klemmen_status_01-kst_driver_note_1,not active,
ENG12865-ENG13724,terminal_control_klemmen_status_01-kst_driver_note_2,not active,
ENG12865-ENG13725,terminal_control_klemmen_status_01-kst_driver_note_3,not active,
ENG12865-ENG13726,terminal_control_klemmen_status_01-kst_driver_note_4,not active,
ENG12865-ENG13727,terminal_control_klemmen_status_01-kst_driver_note_5,not active,
ENG12865-ENG13728,terminal_control_klemmen_status_01-kst_driver_note_6,not active,
ENG12865-ENG13721,terminal_control_klemmen_status_01-kst_warn_p1_zst_def,No malfunction,
ENG12865-ENG13722,terminal_control_klemmen_status_01-kst_warn_p2_zst_def,No malfunction,
ENG12865-ENG09864,terminal_control_klemmen_status_01-remote_start,not active,
ENG12865-ENG13627,terminal_control_klemmen_status_01-terminal_15,active,
ENG12865-ENG13629,terminal_control_klemmen_status_01-terminal_50,not active,
ENG12865-ENG13720,terminal_control_klemmen_status_01-terminal_infotainment,active,
ENG12865-ENG13628,terminal_control_klemmen_status_01-terminal_S,active,
ENG12865-ENG13637,terminal_control_klemmen_status_01-terminal_x,not active,
ENG12866-ENG13719,terminal_control_klemmen_steuerung_01-bz,3,
ENG12866-ENG13718,terminal_control_klemmen_steuerung_01-crc,111,
ENG12866-ENG13731,terminal_control_klemmen_steuerung_01-kst_anf_klemmenfreigabe_elv,not_requested,
ENG12866-ENG13735,terminal_control_klemmen_steuerung_01-kst_aut_abschaltung_zuendung,not active,
ENG12866-ENG13732,terminal_control_klemmen_steuerung_01-kst_elv_trigger_entriegelung,not_requested,
ENG12866-ENG13729,terminal_control_klemmen_steuerung_01-kst_txt_p_gang,OFF,
ENG12866-ENG13730,terminal_control_klemmen_steuerung_01-kst_txt_panikabschaltung,OFF,
ENG12866-ENG13734,terminal_control_klemmen_steuerung_01-kst_unterdr_zuendungsmeldung,not active,
ENG12866-ENG13733,terminal_control_klemmen_steuerung_01-kst_zat_betaetigt,Not operated,
ENG12868-ENG13746,terminal_control_task_state-clamp_state_1,10000111 ,
ENG12868-ENG13747,terminal_control_task_state-clamp_state_2,00000000 ,
ENG100973-MAS00370,Vehicle_speed-Vehicle speed,0.00, km/h
ENG100973-MAS05849,Vehicle_speed-Vehicle speed validity from bus,valid,
ENG12871-ENG13756,virtual_pedal_signals_LIN-vipe_01_byte1,00000000 00000000 ,
ENG12871-ENG13757,virtual_pedal_signals_LIN-vipe_01_byte2,00000000 00000000 ,
ENG12871-ENG13758,virtual_pedal_signals_LIN-vipe_01_byte3,00000000 00000000 ,
ENG12871-ENG13759,virtual_pedal_signals_LIN-vipe_01_byte4,0, %
ENG12871-ENG13760,virtual_pedal_signals_LIN-vipe_01_byte5,0,
ENG12871-ENG13761,virtual_pedal_signals_LIN-vipe_01_byte6,00000000 00000000 ,
ENG12871-ENG13762,virtual_pedal_signals_LIN-vipe_01_byte7,00000000 00000000 ,
ENG12871-ENG13763,virtual_pedal_signals_LIN-vipe_01_byte8,00000000 00000000 ,
ENG12871-ENG13764,virtual_pedal_signals_LIN-vips_01_byte1,00000000 00000000 ,
ENG12871-ENG13765,virtual_pedal_signals_LIN-vips_01_byte2,00000000 00000000 ,
ENG12871-ENG13766,virtual_pedal_signals_LIN-vips_01_byte3,00000000 00000000 ,
ENG12871-ENG13767,virtual_pedal_signals_LIN-vips_01_byte4,0,
ENG12871-ENG13768,virtual_pedal_signals_LIN-vips_01_byte5,00000000 00000000 ,
ENG12871-ENG13769,virtual_pedal_signals_LIN-vips_01_byte6,00000000 00000000 ,
ENG12871-ENG13770,virtual_pedal_signals_LIN-vips_01_byte7,00000000 00000000 ,
ENG12871-ENG13771,virtual_pedal_signals_LIN-vips_01_byte8,00000000 00000000 ,
ENG12887-ENG13880,wakepattern-Active_wakepattern,1E 8C B7 CF,
ENG12887-ENG13881,wakepattern-Next_wakepattern,FF FF FF FF,
ENG12891-ENG13894,wcs_counter-key1_counter,10,
ENG12891-ENG13895,wcs_counter-key2_counter,10,
ENG12891-ENG13896,wcs_counter-key3_counter,255,
ENG12891-ENG13897,wcs_counter-key4_counter,255,
ENG12891-ENG13898,wcs_counter-key5_counter,255,
ENG12891-ENG13899,wcs_counter-key6_counter,255,
ENG12891-ENG13900,wcs_counter-key7_counter,255,
ENG12891-ENG13901,wcs_counter-key8_counter,255,
ENG12854-MAS00218,window_lift_power_limit_status-Driver door,not active,
ENG12854-MAS00219,window_lift_power_limit_status-Front Passenger Door,not active,
ENG12854-MAS02555,window_lift_power_limit_status-driver side rear,not active,
ENG12854-MAS02556,window_lift_power_limit_status-passenger side rear,not active,
ENG12848-MAS00218,window_lift_standardization_status-Driver door,standardized,
ENG12848-MAS00219,window_lift_standardization_status-Front Passenger Door,standardized,
ENG12848-MAS02555,window_lift_standardization_status-driver side rear,standardized,
ENG12848-MAS02556,window_lift_standardization_status-passenger side rear,standardized,
ENG12851-MAS00218,window_lift_thermal_protection_status-Driver door,not active,
ENG12851-MAS00219,window_lift_thermal_protection_status-Front Passenger Door,not active,
ENG12851-MAS02555,window_lift_thermal_protection_status-driver side rear,not active,
ENG12851-MAS02556,window_lift_thermal_protection_status-passenger side rear,not active,
ENG110126-MAS00218,Window_Lifter_Position-Driver door,0.0, %
ENG110126-MAS00219,Window_Lifter_Position-Front Passenger Door,0.0, %
ENG110126-MAS02555,Window_Lifter_Position-driver side rear,0.0, %
ENG110126-MAS02556,Window_Lifter_Position-passenger side rear,0.0, %
ENG12915,zv_engine_lwr_rear_wiper_freeze_frame,11111000 11111111 11111111 11111111 ,
Elapsed Time: 01:40
Jeffy210
Texas, USA
HC?ID=249125
blockmap-51-0EF-907-080-E_WA1AAAGE8MB028917-20210516-1208.CSV
;SW:0EF-907-080-E   HW:0EF-907-080-E ---  Electric Drive
;Component:CUFZD68540AD0 H06 1002, Coding:01000000000000000000
;EV_DMCMHITACAU516,003009,EV_DMCM2HITACAU516_003.rod
;Sunday,16,May,2021,12:08:55:36589
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210508 DS325.1
;VCID: 382921CC22DB651B773-806C
Group,Description,Actual
IDE00445,Unlearning counter according OBD,0,
IDE00613,Phase current phase U,-0.55, A
IDE00614,Phase current phase V,0.00, A
IDE00615,Phase current phase W,-2.20, A
IDE00619,RPM of electric machine,0, /min
IDE00626,Temperature of electric machine,25.63, °C
IDE00635,Intermediate circuit current,0.10, A
IDE00637,DC link voltage,429.50, V
IDE00643,Minimum torque of electric machine,-309.00, Nm
IDE00644,Maximum torque of electric machine,309.00, Nm
IDE00651,Specified RPM of electric machine,0, /min
IDE00655,Temperature of processor circuit board,28.70, °C
IDE00938,Calculated actual torque of electric machine,0.00, Nm
IDE00952,Availability of high voltage,active,
IDE05249,Regulation due to excessive temperature,not active,
IDE05250,Drive control condition,8,
IDE05419,Intermediate circuit current maximum limit,510, A
IDE05421,Torque: current value,0.00, Nm
IDE06352,Basic frequency of pulse-controlled inverter,10000, Hz
IDE06356,Pulse-controlled inverter temperature,28, °C
IDE06373,Rotor position of drive motor for electric drive,145.72, °
IDE06377,Supply voltage of high-side output stages,5.04, V
IDE06378,Supply voltage of low-side output stages,5.03, V
IDE06379,Drive motor windings: active: short-circuited,OFF,
IDE06400,Internal voltage supply 3V,3.34, V
IDE06401,Internal voltage supply 5V,5.01, V
IDE06402,Internal voltage supply 15V,3.34, V
IDE06805,Status of voltage freedom,High voltage power off not recognized,
IDE07472,Initialization cycle: status,1,
IDE07660,Minimum permissible torque of e-machine,-250.00, Nm
IDE07661,Maximum permissible torque of e-machine,315.00, Nm
IDE09102,E-machine effective current,0.70, A
IDE09103,E-machine stator temperature,25.00, °C
IDE09106,Power electronics: internal power supply 1,5.04, V
IDE09107,Power electronics: internal power supply 2,5.03, V
IDE09109,Power electronics voltage terminal 30: channel 1,14.25, V
IDE09111,Power electronics gate driver status,not active,
IDE09112,Power electronics: status,01,
IDE09120,Rotor position sen.: sine track,2.04, V
IDE09121,Rotor position sen.: cosine track,1.82, V
IDE09126,Vehicle switch-off time,28, min
IDE09127,Status: switch-off time,1,
IDE10300,OBD Driving Cycle detected,active,
IDE11082,Special software: status,00,
IDE11083,Special software: name,ORIGINAL A2L,
IDE11240,Electric drive control module: internal supply voltages,3.01, V
IDE11261,Elec. drive motor: d-value of current: spec. value,0.20, A
IDE11262,Elec. drive motor: q-value of current: spec. value,0.00, A
IDE11264,Elec. drive motor: d-value of current: act. value,0.30, A
IDE11265,Elec. drive motor: q-value of current: act. value,0.10, A
IDE14352,Rotor position sensor: supply voltage,3.36, V
IDE14435,Current maximum temperature: IGBT connections,17.72, °C
IDE15367-MAS20448,Temperature range switching-Stator temperature 1: initialization range switching complete,completed,
IDE15367-MAS20449,Temperature range switching-Stator temperature 1: range switching error status,No malfunction,
IDE15367-MAS20450,Temperature range switching-Stator temperature 2: initialization range switching complete,completed,
IDE15367-MAS20451,Temperature range switching-Stator temperature 2: range switching error status,No malfunction,
IDE15367-MAS20452,Temperature range switching-EM coolant temperature: initialization range switching complete,completed,
IDE15367-MAS20453,Temperature range switching-EM coolant temperature: range switching error status,No malfunction,
MAS09947,Cond. of interm. circuit discharging circuit,not requested,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,available.,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,valid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 07 01 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Condition not met,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,Yes,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,1,
ENG115977,AB_Deaktivierung_HV,0,
ENG00814,AKS/FW Select Bit 1 for LV2,0,
ENG00815,AKS/FW Select Bit 2 for LV2,0,
ENG00816,AKS_FW_Selection_BIT1,0,
ENG00817,AKS_FW_Selection_BIT2,0,
ENG00797,Ambient_temperature,25.50, °C
ENG00819,BMS State Number,256,
ENG115978,Buseigendiagnose Xsets,00 00,
ENG115978,Buseigendiagnose Xsets,40 00,
ENG114458,CPLD_Fault_Clear_Judgement,No fault clear request,
ENG114461,Current_offset_phase_U,-1.65,
ENG114462,Current_offset_phase_V,-2.20,
ENG114463,Current_offset_phase_W,-2.20,
ENG114465,Current_Phase_U_Analog_to_Digital,2.50, V
ENG114466,Current_Phase_V_Analog_to_Digital,2.49, V
ENG114467,Current_Phase_W_Analog_to_Digital,2.49, V
ENG00826,Derating state judgment flag,0,
ENG00833,Electric_drive_control_unit_inflow_coolant_temperature_SnapShot,20.14, °C
ENG00799,Electric_motor_rotor_temperatur_modelled,26.00, °C
ENG00835,EXECTIME_1ms_Sample5,250, µs
ENG00835,EXECTIME_1ms_Sample5,390, µs
ENG00835,EXECTIME_1ms_Sample5,290, µs
ENG00836,EXECTIME_5ms_Sample5,500, µs
ENG115991,EXECTIME_C0_1ms_Sample5,200, µs
ENG00837,EXECTIME_C0_5ms_Sample_5,54, µs
ENG00837,EXECTIME_C0_5ms_Sample_5,53, µs
ENG115992,EXECTIME_C0_5ms_Sample5,1200, µs
ENG115992,EXECTIME_C0_5ms_Sample5,1300, µs
ENG00838,EXECTIME_Fast_Sample5,54, µs
ENG00838,EXECTIME_Fast_Sample5,53, µs
ENG00841,fCrash,0,
ENG00842,fERR_LV1,OFF,
ENG00843,fERR_LV2,OFF,
ENG00844,fH_W_TMP_DO_Sw,1,
ENG00845,fH_W_TMP_Short,1,
ENG00846,fHMOT_DO_Sw2,0,
ENG00847,fHMOT_Short2,1,
ENG124827,FIBEX_Integration_Step,V8.14.00F,
ENG115993,fShtOfPth_Tst_End,1,
ENG00850,fshutoffPath_PASS,1,
ENG00852,GATE_CHK_H_FP,normal,
ENG00853,GATE_CHK_L_FP,normal,
ENG00885,HV voltage AD Value,2.74, V
ENG00801,HV_voltage,344.00, V
ENG00887,HvV_LV2,429.50, V
ENG00888,ImmobilizerSnapShot,00,
ENG00890,Inhibition_due_to_Immobilizer_Lib,1,
ENG00894,Inverter initialization State Flag,256,
ENG116002,iu_LV2,-0.55, A
ENG116003,iu_Sample5,0.00, A
ENG116003,iu_Sample5,0.55, A
ENG116003,iu_Sample5,-1.10, A
ENG116003,iu_Sample5,-0.55, A
ENG116004,iv_LV2,-0.55, A
ENG116005,iv_Sample5,0.55, A
ENG116005,iv_Sample5,0.00, A
ENG116005,iv_Sample5,-0.55, A
ENG116006,iw_LV2,-1.10, A
ENG116007,iw_Sample5,-1.10, A
ENG116007,iw_Sample5,-2.20, A
ENG116007,iw_Sample5,0.00, A
ENG116007,iw_Sample5,0.55, A
ENG00908,KL15_AD_value,2.39, V
ENG00909,Low voltage battery voltage AD value,2.34, V
ENG00925,MO_ErwGrenzen_Anf Flag,0,
ENG00926,Modulation_factor,0.00,
ENG00927,MonOutIf_bsBusRxQly,6592,
ENG00928,MonOutIf_bSigQly_ti5,0,
ENG00929,MonOutIf_bSigQly_tiPwm1,64,
ENG00930,MonOutIf_bsSigQly,0,
ENG00931,MonOutIf_tqActQly_ti1,1,
ENG00932,MonOutIf_tqMonQly_ti1,0,
ENG120765,Motor_Temperature_AD,1.30, V
ENG114610,Motor_Temperature_NTC,25.75, °C
ENG00933,Motor_temperature_NTC_pre-value,26.50, °C
ENG114612,Motor_Temperature_Sensor_Short_Detection,On,
ENG114613,Motor_Temperature_Sensor_Switch,OFF,
ENG00934,Motoring Current Limit_ShrtDyn,530.00, A
ENG00935,Motoring_Current Limit_Dyn,530.00, A
ENG00936,Motoring_Current Limit_Pred,530.00, A
ENG00937,Next_PWM_cycle_time,1,
ENG00940,OBD_Type,0,
ENG00800,Overcurrent_AC_detected,normal,
ENG00941,Overvoltage_DC_detected,normal,
ENG114620,PCB_Temperature_Analog_to_digital,2611, V
ENG116018,PECInIf_tqMaxDsbcMon_VW,375.00, Nm
ENG00946,PECOutIf_bShOff_vVehPlaus_VW,0,
ENG00947,PECOutIf_bShOffPth_VW,0,
ENG00948,PECOutIf_stReqModPwrs_VW,1,
ENG116020,PECOutIf_tqDesDsbc_VW,0.00, Nm
ENG00950,Power_Factor,0.00, %
ENG114628,Power_Supply_hold_signal,Hold,
ENG00953,real_IM_Sample5,0.20, A
ENG00954,real_IT_Sample5,0.10, A
ENG00955,Redundant HV Voltage Analog-to-digital value,2253,
ENG00956,Regenerative Current Limit_ShrtDyn,530.00, A
ENG00957,Regenerative_Current Limit_Dyn,530.00, A
ENG00958,Regenerative_Current Limit_Pred,530.00, A
ENG00959,Resolver_EXC_signal frequency,10208, Hz
ENG00960,Resolver_IC_error_code,0,
ENG00961,Resolver_IC_error_hold signal,0,
ENG00965,Signal quality_PECInIf_tElmCo_VW,0,
ENG00966,Signal_quality_PECInIf_tSttrSens_2_VW,0,
ENG00967,Signal_quality_PECInIf_tSttrSens_VW,0,
ENG116026,sitaaddress_Sample5,144, °
ENG12985,State ignition,1,
ENG114658,State_Ignition_Level2,On,
ENG00986,Stator_Temperature Switching,1,
ENG00987,Stator_Temperature Switching_1,0,
ENG00990,Supply_voltage_KL30_internal_SnapShot,14.25, V
ENG114671,Temperature_AC_Connector_worst,25.77, °C
ENG116033,TME_Temp_KM_Vor_LE,25.50, °C
ENG01009,vAN_MOT_LV2,145.55, rad
ENG01010,vC_DC_Hi_LV2_AD,2.50, V
ENG116035,vC_DC_INV_LV2_Sample5,0, A
ENG116036,vC_DC_Lo_LV2_AD,2.49, rad/s
ENG01011,vC_ID_Diff,0,
ENG01012,vC_IQ_Diff,0,
ENG116037,vCnt_KL30OpenRst_FS,0,
ENG116038,vCnt_uCFaultyRst_EVR_FS,0,
ENG116753,vCnt_uCFaultyRst_PORST_FS,0,
ENG116039,vCnt_uCFaultyRst_SMU_FS,0,
ENG116040,vCnt_uCFaultyRst_SW_FS,0,
ENG116041,Vd_Ref,0.00, V
ENG01015,vfAPS,0.00, Hz
ENG01016,vFL_GH_A_MON,0.00, %
ENG01017,vFL_GH_B_MON,0.00, %
ENG01018,vFL_GH_C_MON,0.00, %
ENG01019,vFL_GL_A_MON,0.00, %
ENG01020,vFL_GL_B_MON,0.00, %
ENG01021,vFL_GL_C_MON,0.00, %
ENG116042,vFL_PMAC_Temp,30.50, °C
ENG01022,vFL_TOTALloss,12.22, W
ENG116044,vFL_Tw_out,25.54, °C
ENG116045,vFL_Ycap_Temp,31.00, °C
ENG116046,vFLC_DC_Hi_INV_Calc_LV2,0.00, A
ENG116047,vFLC_DC_Hi_INV_Flt_Plaus_LV2,0.00, A
ENG116048,vH_Transmission_Sump,-40, °C
ENG01024,vH_W_TMP_AD,3.73, V
ENG01025,vH_W_TMP_NTC_zN,26.38, °C
ENG116049,vHIGBTDuty,43.21, %
ENG01026,vHMOT_2_NTC_zN,25.50, °C
ENG01027,vHMOT_NTC_zN,25.75, °C
ENG01028,vHMOT2_AD,1077,
ENG01029,vHMOT2_NTC_Pre,25.50, °C
ENG116051,vID_L2_FFD,00 00,
ENG116054,vNMOT_LV2,0, /min
ENG114697,Voltage_Difference_Nside_case,193.63, V
ENG114698,Voltage_Difference_Pside_case,237.38, V
ENG114699,Voltage_offset_HVDC,2.21, V
ENG116055,vOPR,8,
ENG116056,Vq_Ref,0.00, V
ENG01030,vSEQNO_INTERNAL_Sample4,35.00, V
ENG116057,vSEQNO_Sample5,8,
ENG116058,vShtOfPth_Tst_FFD,FE,
ENG116059,vSig_FnctnalRstrctn_Trggr,0,
ENG116060,vSTAT_Sig_Rx_Implaus,0,
ENG01031,vTME_EMx_IstVolumenstrom,2.50, /min
ENG116064,vTMRQ,0.00, Nm
ENG116065,vUC_CPLD_Cntl_LV2_Sample5,0,
ENG116065,vUC_CPLD_Cntl_LV2_Sample5,00,
ENG01032,vVDC_LV2,429.88, V
ENG116066,vVDC_Sample5,427.50, V
ENG01033,vVVB_LV2,14.25, V
ENG120774,X_Con_temperature_calculated_value,28.27, °C
ENG116068,ZAS_KL_15_LV2,1,
Elapsed Time: 00:31
blockmap-52-4M0-959-792-N_WA1AAAGE8MB028917-20210516-1209.CSV
;SW:4M0-959-792-N   HW:4M0-959-792-N ---  Door Elect, Pass.
;Component:TSG BFS       011 0390, Coding:0014CB005E001480A001A030
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_VW38.rod
;Sunday,16,May,2021,12:09:48:36589
;VCID: 48C9510C523B159B073-801C
IDE00310,Outside temperature,25.50, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Passenger Door Control Module,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,14.30, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,50, %
IDE04539-MAS02229,Mirror memory-Y coordinate,50, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE04580,Dimming of inside door handle lighting,Not available,
IDE04581,Dimming for interior ambient lighting,Not available,
IDE04586,Mirror fold-in activation,not active,
IDE05725,Dimmer terminal 58xs,55, %
IDE05726,Dimmer terminal 58xd,2, %
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06872,Front passenger power window button,Not operated,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,35, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not active,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,0, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Not available,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
MAS02099,Switch for inside door handle,Not operated,
MAS02100,Switch for outside door handle,Not operated,
MAS06010,Ambient light,Not available,
Elapsed Time: 00:06
blockmap-5F-4M2-035-092-A_WA1AAAGE8MB028917-20210516-1210.CSV
;SW:4M2-035-092-A   HW:4M2-035-092 ---  Information Electr.
;Component:MU-TP-NS-US   042 3385, Coding:15161030804000000000000000000000000000000000000000
;EV_MUTI,001010,EV_MUTI_AU27.rod
;Sunday,16,May,2021,12:10:03:36589
;VCID: 270BF2B0FF65FAE3EE9-8072
IDE00019,Voltage terminal 30,14.30, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine RPM,0.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,59, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-5, °C
IDE00655-MAS02238,Temperature of processor circuit board-Up-to-date,57, °C
IDE00767,No. of unscheduled ECU resets,2,
IDE00916-ENG118373,Speaker status-loudspeaker_config_channel_1,Right rear speaker,
IDE00916-ENG118408,Speaker status-loudspeaker_config_channel_10,Not available,
IDE00916-ENG118446,Speaker status-loudspeaker_config_channel_11,Not available,
IDE00916-ENG118414,Speaker status-loudspeaker_config_channel_12,Not available,
IDE00916-ENG118269,Speaker status-loudspeaker_config_channel_13,Not available,
IDE00916-ENG118335,Speaker status-loudspeaker_config_channel_14,Not available,
IDE00916-ENG118384,Speaker status-loudspeaker_config_channel_15,Not available,
IDE00916-ENG118443,Speaker status-loudspeaker_config_channel_16,Not available,
IDE00916-ENG118435,Speaker status-loudspeaker_config_channel_17,Not available,
IDE00916-ENG118380,Speaker status-loudspeaker_config_channel_18,Not available,
IDE00916-ENG118394,Speaker status-loudspeaker_config_channel_19,Not available,
IDE00916-ENG118383,Speaker status-loudspeaker_config_channel_2,Right front speaker,
IDE00916-ENG118362,Speaker status-loudspeaker_config_channel_20,Not available,
IDE00916-ENG118344,Speaker status-loudspeaker_config_channel_21,Not available,
IDE00916-ENG118455,Speaker status-loudspeaker_config_channel_22,Not available,
IDE00916-ENG118417,Speaker status-loudspeaker_config_channel_23,Not available,
IDE00916-ENG118448,Speaker status-loudspeaker_config_channel_24,Not available,
IDE00916-ENG124966,Speaker status-loudspeaker_config_channel_25,Not available,
IDE00916-ENG118216,Speaker status-loudspeaker_config_channel_3,Left front speaker,
IDE00916-ENG118437,Speaker status-loudspeaker_config_channel_4,Left rear speaker,
IDE00916-ENG118290,Speaker status-loudspeaker_config_channel_5,Subwoofer speaker,
IDE00916-ENG118419,Speaker status-loudspeaker_config_channel_6,Center speaker,
IDE00916-ENG118338,Speaker status-loudspeaker_config_channel_7,Not available,
IDE00916-ENG118268,Speaker status-loudspeaker_config_channel_8,Not available,
IDE00916-ENG118398,Speaker status-loudspeaker_config_channel_9,Not available,
IDE00916-ENG118339,Speaker status-loudspeaker_state_channel_1,OK,
IDE00916-ENG118357,Speaker status-loudspeaker_state_channel_10,Measuring value not available,
IDE00916-ENG118392,Speaker status-loudspeaker_state_channel_11,Measuring value not available,
IDE00916-ENG118379,Speaker status-loudspeaker_state_channel_12,Measuring value not available,
IDE00916-ENG118364,Speaker status-loudspeaker_state_channel_13,Measuring value not available,
IDE00916-ENG118375,Speaker status-loudspeaker_state_channel_14,Measuring value not available,
IDE00916-ENG118354,Speaker status-loudspeaker_state_channel_15,Measuring value not available,
IDE00916-ENG118245,Speaker status-loudspeaker_state_channel_16,Measuring value not available,
IDE00916-ENG118456,Speaker status-loudspeaker_state_channel_17,Measuring value not available,
IDE00916-ENG118420,Speaker status-loudspeaker_state_channel_18,Measuring value not available,
IDE00916-ENG118337,Speaker status-loudspeaker_state_channel_19,Measuring value not available,
IDE00916-ENG118233,Speaker status-loudspeaker_state_channel_2,OK,
IDE00916-ENG118363,Speaker status-loudspeaker_state_channel_20,Measuring value not available,
IDE00916-ENG118345,Speaker status-loudspeaker_state_channel_21,Measuring value not available,
IDE00916-ENG118332,Speaker status-loudspeaker_state_channel_22,Measuring value not available,
IDE00916-ENG118247,Speaker status-loudspeaker_state_channel_23,Measuring value not available,
IDE00916-ENG118336,Speaker status-loudspeaker_state_channel_24,Measuring value not available,
IDE00916-ENG124967,Speaker status-loudspeaker_state_channel_25,Measuring value not available,
IDE00916-ENG118218,Speaker status-loudspeaker_state_channel_3,OK,
IDE00916-ENG118240,Speaker status-loudspeaker_state_channel_4,OK,
IDE00916-ENG118231,Speaker status-loudspeaker_state_channel_5,OK,
IDE00916-ENG118327,Speaker status-loudspeaker_state_channel_6,OK,
IDE00916-ENG118436,Speaker status-loudspeaker_state_channel_7,Measuring value not available,
IDE00916-ENG118263,Speaker status-loudspeaker_state_channel_8,Measuring value not available,
IDE00916-ENG118310,Speaker status-loudspeaker_state_channel_9,Measuring value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01351,Terminal 75 status,OFF,
IDE01712-MAS01779,GPS Position-Length,098°28'12.12"W,
IDE01712-MAS01780,GPS Position-Width,029°27'07.91"N,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,16,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,59, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,46, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,System visually not OK,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,24 50 A1 B4,
IDE01992-MAS00076,Installation list: current installations-Instrument cluster control module,installed,
IDE01992-MAS00839,Installation list: current installations-TV Tuner,not installed,
IDE01992-MAS00844,Installation list: current installations-Radio,not installed,
IDE01992-MAS00847,Installation list: current installations-Digital Sound System Control Module,not installed,
IDE01992-MAS00849,Installation list: current installations-Information electronics control module 1,installed,
IDE01992-MAS00850,Installation list: current installations-Information electronics control module 2,not installed,
IDE01992-MAS04300,Installation list: current installations-DVD changer,not installed,
IDE01992-MAS14306,Installation list: current installations-Windshield projection head up display control module,not installed,
IDE01992-SFT00078,Installation list: current installations-Display/operating unit rear right,not installed,
IDE01992-SFT00094,Installation list: current installations-Display/operating unit rear left,not installed,
IDE01992-SFT00200,Installation list: current installations-Auxiliary display/control head 2,not installed,
IDE01992-SFT00222,Installation list: current installations-charging device 1 for mobile end device,not installed,
IDE01992-SFT00223,Installation list: current installations-charging device 2 for mobile end device,not installed,
IDE01992-SFT00224,Installation list: current installations-Auxiliary display/control head 1,not installed,
IDE01992-SFT09799,Installation list: current installations-Multimedia system control head,not installed,
IDE01993-MAS00478,Control module reference number-Reserved,00,
IDE01993-MAS14306,Control module reference number-Windshield projection head up display control module,04,
IDE01993-SFT00014,Control module reference number-Media Player 1,70,
IDE01993-SFT00023,Control module reference number-Instrument cluster,02,
IDE01993-SFT00071,Control module reference number-Sound System,6F,
IDE01993-SFT00078,Control module reference number-Display/operating unit rear right,A7,
IDE01993-SFT00086,Control module reference number-Radio,18,
IDE01993-SFT00087,Control module reference number-TV Tuner,6D,
IDE01993-SFT00094,Control module reference number-Display/operating unit rear left,A8,
IDE01993-SFT00095,Control module reference number-Information electronics 1,73,
IDE01993-SFT00127,Control module reference number-Information electronics 2,01,
IDE01993-SFT00200,Control module reference number-Auxiliary display/control head 2,AB,
IDE01993-SFT00222,Control module reference number-charging device 1 for mobile end device,A5,
IDE01993-SFT00223,Control module reference number-charging device 2 for mobile end device,A6,
IDE01993-SFT00224,Control module reference number-Auxiliary display/control head 1,AA,
IDE01993-SFT33032,Control module reference number-Control unit for hood ornament,C3,
IDE01993-SFT09799,Control module reference number-Multimedia system control head,03,
IDE01995-ENG16990,Control module protocol information-Ethernet,No,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE02178-MAS01167,Status remote control-Actuation time,0 s,
IDE02178-ENG39349,Status remote control-IoReached Status,Output diagnostic test not active,
IDE02179-MAS01167,Remote control for selecting the audio source-Actuation time,0 s,
IDE02179-ENG39349,Remote control for selecting the audio source-IoReached Status,Output diagnostic test not active,
IDE02180-MAS01167,Remote control for FM frequency selection-Actuation time,0 s,
IDE02180-ENG39349,Remote control for FM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02181-MAS01167,Remote control for AM frequency selection-Actuation time,0 s,
IDE02181-ENG39349,Remote control for AM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02182-MAS01167,Remote control for volume-Actuation time,0 s,
IDE02182-ENG39349,Remote control for volume-IoReached Status,Output diagnostic test not active,
IDE02326-MAS17347,GPS signal strength-Satellite 1: identification,9,
IDE02326-MAS17348,GPS signal strength-Satellite 1: signal strength,40, dBµV
IDE02326-MAS17349,GPS signal strength-Satellite 2: signal strength,36, dBµV
IDE02326-MAS17350,GPS signal strength-Satellite 3: signal strength,32, dBµV
IDE02326-MAS17351,GPS signal strength-Satellite 4: signal strength,28, dBµV
IDE02326-MAS17352,GPS signal strength-Satellite 2: identification,7,
IDE02326-MAS17353,GPS signal strength-Satellite 3: identification,1,
IDE02326-MAS17354,GPS signal strength-Satellite 4: identification,14,
IDE02384-MAS00076,Status of event memory-Instrument cluster control module,OK,
IDE02384-MAS00839,Status of event memory-TV Tuner,OK,
IDE02384-MAS00844,Status of event memory-Radio,OK,
IDE02384-MAS00847,Status of event memory-Digital Sound System Control Module,OK,
IDE02384-MAS00849,Status of event memory-Information electronics control module 1,OK,
IDE02384-MAS00850,Status of event memory-Information electronics control module 2,OK,
IDE02384-MAS04300,Status of event memory-DVD changer,OK,
IDE02384-MAS14306,Status of event memory-Windshield projection head up display control module,OK,
IDE02384-SFT00078,Status of event memory-Display/operating unit rear right,OK,
IDE02384-SFT00094,Status of event memory-Display/operating unit rear left,OK,
IDE02384-SFT00200,Status of event memory-Auxiliary display/control head 2,OK,
IDE02384-SFT00222,Status of event memory-charging device 1 for mobile end device,OK,
IDE02384-SFT00223,Status of event memory-charging device 2 for mobile end device,OK,
IDE02384-SFT00224,Status of event memory-Auxiliary display/control head 1,OK,
IDE02384-SFT09799,Status of event memory-Multimedia system control head,OK,
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE02449-MAS01167,Remote control for satellite radio station selection-Actuation time,0 s,
IDE02449-ENG39349,Remote control for satellite radio station selection-IoReached Status,Output diagnostic test not active,
IDE02452-IDE02451,Satellite radio tuner status-Satellite radio antenna status,electrically OK,
IDE02452-IDE02453,Satellite radio tuner status-Channel selection for satellite radio,0,
IDE02452-MAS01765,Satellite radio tuner status-Audio Signal,available.,
IDE02452-MAS01808,Satellite radio tuner status-Antenna current,149, mA
IDE02452-MAS02573,Satellite radio tuner status-Reception quality,Good signal,
IDE02452-MAS13343,Satellite radio tuner status-Satellite radio tuner: pre-activation status,factory_activation_successful,
IDE02452-MAS13344,Satellite radio tuner status-Satellite radio tuner: pre-activation value,05,
IDE02454-MAS01167,Remote control for digital radio service selection (DSB)-Actuation time,0 s,
IDE02454-ENG39349,Remote control for digital radio service selection (DSB)-IoReached Status,Output diagnostic test not active,
IDE02470-MAS01167,Remote control frequency selection digital radio (band III)-Actuation time,0 s,
IDE02470-ENG39349,Remote control frequency selection digital radio (band III)-IoReached Status,Output diagnostic test not active,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,0 s,
IDE02475-ENG39349,Acoustic check of loudspeakers-IoReached Status,Output diagnostic test not active,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,0 s,
IDE02476-ENG39349,Electrical test of speakers-IoReached Status,Output diagnostic test not active,
IDE02501-MAS01167,Remote control for voice operation-Actuation time,0 s,
IDE02501-ENG39349,Remote control for voice operation-IoReached Status,Output diagnostic test not active,
IDE02766,Malfunction status,00 00,
IDE02766-ENG118228,Malfunction status-amount_communication_errors,0,
IDE03150-MAS00076,Readiness for bus sleep mode-Instrument cluster control module,Wake,
IDE03150-MAS00839,Readiness for bus sleep mode-TV Tuner,sleep,
IDE03150-MAS00844,Readiness for bus sleep mode-Radio,sleep,
IDE03150-MAS00847,Readiness for bus sleep mode-Digital Sound System Control Module,sleep,
IDE03150-MAS00849,Readiness for bus sleep mode-Information electronics control module 1,Wake,
IDE03150-MAS00850,Readiness for bus sleep mode-Information electronics control module 2,sleep,
IDE03150-MAS04300,Readiness for bus sleep mode-DVD changer,sleep,
IDE03150-MAS14306,Readiness for bus sleep mode-Windshield projection head up display control module,sleep,
IDE03150-SFT00078,Readiness for bus sleep mode-Display/operating unit rear right,sleep,
IDE03150-SFT00094,Readiness for bus sleep mode-Display/operating unit rear left,sleep,
IDE03150-SFT00200,Readiness for bus sleep mode-Auxiliary display/control head 2,sleep,
IDE03150-SFT00222,Readiness for bus sleep mode-charging device 1 for mobile end device,sleep,
IDE03150-SFT00223,Readiness for bus sleep mode-charging device 2 for mobile end device,sleep,
IDE03150-SFT00224,Readiness for bus sleep mode-Auxiliary display/control head 1,sleep,
IDE03150-SFT09799,Readiness for bus sleep mode-Multimedia system control head,sleep,
IDE03150-ENG16256,Readiness for bus sleep mode-Sleep Bit 0,sleep,
IDE03150-ENG45492,Readiness for bus sleep mode-Sleep Bit 1,sleep,
IDE03150-ENG45491,Readiness for bus sleep mode-Sleep Bit 2,sleep,
IDE03150-ENG45490,Readiness for bus sleep mode-Sleep Bit 3,sleep,
IDE03150-ENG45489,Readiness for bus sleep mode-Sleep Bit 4,sleep,
IDE03150-ENG45488,Readiness for bus sleep mode-Sleep Bit 5,sleep,
IDE03150-ENG21675,Readiness for bus sleep mode-Sleep Bit 6,sleep,
IDE03150-ENG16255,Readiness for bus sleep mode-Sleep Bit 7,sleep,
IDE03477-MAS00106,GPS time-Year,2021,
IDE03477-MAS00107,GPS time-Month,5,
IDE03477-MAS00108,GPS time-Day,16,
IDE03477-MAS00109,GPS time-Hours,17,
IDE03477-MAS00110,GPS time-Minutes,9,
IDE03477-MAS00111,GPS time-Seconds,52,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,Not available,
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,Not available,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,95,
IDE03880-MAS03425,MOST address-Physical address,1024,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,22, min
IDE04317-MAS00108,Total system run time-Day,3, d
IDE04317-MAS00109,Total system run time-Hours,7, H
IDE04317-MAS00110,Total system run time-Minutes,3, min
IDE04329-IDE04332,Status of all SWaP functions-Release code for a SWaP function,Not available,
IDE04329-IDE05814,Status of all SWaP functions-Individualization characteristic,invalid,
IDE04329-IDE06260,Status of all SWaP functions-ID number,00 00 00 00,
IDE04329-MAS01340,Status of all SWaP functions-Functions,Not available,
IDE04329-MAS01903,Status of all SWaP functions-Configuration,not OK,
IDE04329-MAS02934,Status of all SWaP functions-Preconditions met,Condition not met,
IDE04329-MAS05616,Status of all SWaP functions-Cancellation,Yes,
IDE04329-MAS05617,Status of all SWaP functions-Authentication,Condition not met,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG20542,Bus identification-Bus Identifier,Bus master,
IDE04484,Regional codes,FE,
IDE04484,Regional codes,Not available,
IDE04484-MAS01632,Regional codes-Status,not active,
IDE04484-MAS03230,Regional codes-Optical drive,0,
IDE04543-MAS00866,Authorization level for protection of minors-system origin,0,
IDE04543-MAS03778,Authorization level for protection of minors-Active media source,Not available,
IDE04546-IDE00301,Calibration of navigation-Mileage,24.55, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,not calibrated,
IDE04640,Over-temperature protection for amplifier,0,
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,2760, /min
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE05106-MAS01167,Diagnostic connection for external audio sources-Actuation time,0 s,
IDE05106-ENG39349,Diagnostic connection for external audio sources-IoReached Status,Output diagnostic test not active,
IDE05107-MAS01167,Test image display unit 1 for multimedia system-Actuation time,0 s,
IDE05107-ENG39349,Test image display unit 1 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05108-MAS01167,Test image display unit 2 for multimedia system-Actuation time,0 s,
IDE05108-ENG39349,Test image display unit 2 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05109-MAS01167,Test image display unit 3 for multimedia system-Actuation time,0 s,
IDE05109-ENG39349,Test image display unit 3 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05277-MAS04210,Available changes in regional codes-Available changes DVD,5,
IDE05277-MAS04211,Available changes in regional codes-Available changes Blue-Ray,5,
IDE05277-MAS04285,Available changes in regional codes-Regional codes DVD,1,
IDE05277-MAS04286,Available changes in regional codes-Blue-ray regional codes,1,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,Not available,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,NOT-DEFINED,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,OFF,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,NOT-DEFINED,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,NOT-DEFINED,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,NOT-DEFINED,
IDE05596-MAS00106,Last time GPS position outside map-Year,Not available,
IDE05596-MAS00107,Last time GPS position outside map-Month,NOT-DEFINED,
IDE05596-MAS00108,Last time GPS position outside map-Day,OFF,
IDE05596-MAS00109,Last time GPS position outside map-Hours,NOT-DEFINED,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,NOT-DEFINED,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,NOT-DEFINED,
IDE05700-MAS01456,USB connection-Speed,High speed,
IDE05700-MAS01632,USB connection-Status,OK,
IDE05700-MAS03159,USB connection-Manufacturer,1500,
IDE05700-MAS04393,USB connection-USB device class,8,
IDE05700-MAS04394,USB connection-Connection status,connected,
IDE05700-MAS04436,USB connection-USB device sub-class,6,
IDE05700-MAS06173,USB connection-Protocol,Not available,
IDE05700-MAS06174,USB connection-Product ID,51037,
IDE05704-MAS02646,Key for digital transmission protection (DTCP)-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,0,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,0,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05726,Dimmer terminal 58xd,21.73, %
IDE05814,Individualization characteristic,5E 41 8C 82 04,
IDE06028-MAS02317,Control head button operation-Button code 1,Not available,
IDE06028-MAS02318,Control head button operation-Button code 2,Not available,
IDE06028-MAS04151,Control head button operation-Joystick,Not available,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,Not available,
IDE06028-MAS04414,Control head button operation-Volume control,Not available,
IDE06516-MAS01424,Temperature: optical drive-max.value,Not available,
IDE06516-MAS01425,Temperature: optical drive-min.value,Not available,
IDE06516-MAS02238,Temperature: optical drive-Up-to-date,Not available,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,0, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,0, °C
IDE06517-MAS02238,Temperature: audio amplifier-Up-to-date,0, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,52, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-4, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Up-to-date,50, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,50, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,24, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Up-to-date,45, °C
IDE06857-IDE00668,Microphone for vehicle noise-Microphone voltage consumption,0.00, mA
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,E1,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07839-MAS01424,Processor temperature-max.value,63, °C
IDE07839-MAS01425,Processor temperature-min.value,1, °C
IDE07839-MAS02238,Processor temperature-Up-to-date,59, °C
IDE09544-MAS01167,Locking information electronic 1 operation-Actuation time,0 s,
IDE09544-ENG39349,Locking information electronic 1 operation-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,not active,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10481-MAS01167,Interface for external media: diagnosis-Actuation time,0 s,
IDE10481-ENG39349,Interface for external media: diagnosis-IoReached Status,Output diagnostic test not active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10843-MAS01482,Function module: identification-Hardware version,1,
IDE10843-MAS04326,Function module: identification-Device name,INIC:0                           ,
IDE10843-MAS11354,Function module: identification-Bootloader version,00 00 00 02,
IDE10843-MAS11355,Function module: identification-Application version,00 00 00 00,
IDE10843-MAS11356,Function module: identification-Module Name,FLASH                            ,
IDE11034-MAS01482,Satellite radio: module information-Hardware version,0          ,
IDE11034-MAS11961,Satellite radio: module information-Serial number,A9MNNDH3,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 9E 00 41 39 4D 4E 4E 44 48 33 00 02 98 05 8A 38 64 68 F5 31 71 89 CD BF 18 05 CD 23 99 3B 03 BE 23 7A 44 DF 03 41 00 66 03 41 00 07 00 66 00 07,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,11.46.1    ,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,SXE_DL_V1.3,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,-----------,
IDE11034-MAS11966,Satellite radio: module information-Database Version,3.1.22     ,
IDE11034-ENG118382,Satellite radio: module information-apogee_traffic,-----------,
IDE11034-ENG118254,Satellite radio: module information-canadian_fuel,-----------,
IDE11034-ENG118272,Satellite radio: module information-channel_arts,-----------,
IDE11034-ENG118219,Satellite radio: module information-ev_stations,-----------,
IDE11034-ENG118418,Satellite radio: module information-fuel_stations,-----------,
IDE11034-ENG118421,Satellite radio: module information-internal_sxm,1.6.6.5    ,
IDE11034-ENG118296,Satellite radio: module information-movies,-----------,
IDE11034-ENG118196,Satellite radio: module information-Parking,-----------,
IDE11034-ENG118386,Satellite radio: module information-phonetics,-----------,
IDE11034-ENG118424,Satellite radio: module information-safety_alerts,-----------,
IDE11034-ENG45748,Satellite radio: module information-States,-----------,
IDE11034-ENG118391,Satellite radio: module information-stocks,-----------,
IDE11034-ENG118359,Satellite radio: module information-sxm_pics,-----------,
IDE11034-ENG118427,Satellite radio: module information-tabular_weather,-----------,
IDE11034-ENG118395,Satellite radio: module information-weather_alerts,-----------,
IDE11504,Satellite radio tuner: pre-activated subscription,Yes,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,FF 14 00 00 00 00 00 00 00 00 00 00 00 04 00 00,
IDE11755-MAS14856,IP network: VLANs-VLAN,3,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,28 63 BD 01 93 E8,
IDE11869-IDE09467,IP network: NDP cache-MAC address,48 16 93 38 66 1C,
IDE11869-IDE09469,IP network: NDP cache-IPv6 address,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10,
IDE11869-MAS14856,IP network: NDP cache-VLAN,3,
IDE12238,I network: discarded messages counter,74,
IDE12239-IDE09469,IP network: test feedback value of communications relationships-IPv6 address,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10,
IDE12239-MAS05584,IP network: test feedback value of communications relationships-Result,Test not yet carried out,
IDE12277-MAS01632,External optical drive (USB): status-Status,Open circuit,
IDE12625,IP network: current link deceleration: branch 1,65535, ns
IDE12633,IP Network maximum correction of the synchronized clock,0, ns
IDE12806-MAS00076,Diagnostic capability of the bus interface-Instrument cluster control module,Control module/bus interface diagnostics capable,
IDE12806-MAS00839,Diagnostic capability of the bus interface-TV Tuner,Control module/bus interface not diagnostics capable,
IDE12806-MAS00844,Diagnostic capability of the bus interface-Radio,Control module/bus interface not diagnostics capable,
IDE12806-MAS00847,Diagnostic capability of the bus interface-Digital Sound System Control Module,Control module/bus interface not diagnostics capable,
IDE12806-MAS00849,Diagnostic capability of the bus interface-Information electronics control module 1,Control module/bus interface diagnostics capable,
IDE12806-MAS00850,Diagnostic capability of the bus interface-Information electronics control module 2,Control module/bus interface not diagnostics capable,
IDE12806-MAS04300,Diagnostic capability of the bus interface-DVD changer,Control module/bus interface not diagnostics capable,
IDE12806-MAS14306,Diagnostic capability of the bus interface-Windshield projection head up display control module,Control module/bus interface not diagnostics capable,
IDE12806-SFT00078,Diagnostic capability of the bus interface-Display/operating unit rear right,Control module/bus interface not diagnostics capable,
IDE12806-SFT00094,Diagnostic capability of the bus interface-Display/operating unit rear left,Control module/bus interface not diagnostics capable,
IDE12806-SFT00200,Diagnostic capability of the bus interface-Auxiliary display/control head 2,Control module/bus interface not diagnostics capable,
IDE12806-SFT00222,Diagnostic capability of the bus interface-charging device 1 for mobile end device,Control module/bus interface not diagnostics capable,
IDE12806-SFT00223,Diagnostic capability of the bus interface-charging device 2 for mobile end device,Control module/bus interface not diagnostics capable,
IDE12806-SFT00224,Diagnostic capability of the bus interface-Auxiliary display/control head 1,Control module/bus interface not diagnostics capable,
IDE12806-SFT09799,Diagnostic capability of the bus interface-Multimedia system control head,Control module/bus interface not diagnostics capable,
IDE12844-ENG20451,Installation list of the 10 bit node addresses-ECU ID,TNF 167462,
IDE12844-ENG20480,Installation list of the 10 bit node addresses-ECU Name,Information electronics 1,
IDE12844-ENG124114,Installation list of the 10 bit node addresses-Node address,00 73,
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,0 s,
IDE13344-ENG39349,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
IDE13420-MAS01159,Navigation data bank: status-Version number,00 1A,
IDE13420-MAS01632,Navigation data bank: status-Status,valid,
IDE13420-MAS10892,Navigation data bank: status-Country Code,00 09 3A,
IDE13623-MAS01632,Interface for external media 2: status-Status,OK,
IDE13939-MAS01167,Display unit test image in the Instrument cluster control module-Actuation time,0 s,
IDE13939-ENG39349,Display unit test image in the Instrument cluster control module-IoReached Status,Output diagnostic test not active,
IDE13940-MAS17168,Multimedia display unit 1 operating sensors-Touchscreen: touch recognition,not detected,
IDE13940-MAS17169,Multimedia display unit 1 operating sensors-Touchscreen: activation,Not operated,
IDE14045-MAS17168,Multimedia display unit 2 operating sensors-Touchscreen: touch recognition,not detected,
IDE14045-MAS17169,Multimedia display unit 2 operating sensors-Touchscreen: activation,Not operated,
IDE14128-MAS01167,Activation for blower housing status-Actuation time,0 s,
IDE14128-ENG39349,Activation for blower housing status-IoReached Status,Output diagnostic test not active,
IDE14142-IDE09193,External sound amplifier: temperature status-Temperature sensor 1,Measured value not available or parameter outside measur.range,
IDE14142-IDE09194,External sound amplifier: temperature status-Temperature sensor 2,Measured value not available or parameter outside measur.range,
IDE14142-IDE09195,External sound amplifier: temperature status-Temperature sensor 3,Measured value not available or parameter outside measur.range,
IDE14142-IDE09196,External sound amplifier: temperature status-Temperature sensor 4,Measured value not available or parameter outside measur.range,
IDE14142-IDE09197,External sound amplifier: temperature status-Temperature sensor 5,Measured value not available or parameter outside measur.range,
IDE14142-MAS17875,External sound amplifier: temperature status-Function level,Not available,
IDE14142-MAS17876,External sound amplifier: temperature status-Temperature sensor 6,Measured value not available or parameter outside measur.range,
IDE14142-MAS17877,External sound amplifier: temperature status-Temperature sensor 7,Measured value not available or parameter outside measur.range,
IDE14142-MAS17878,External sound amplifier: temperature status-Temperature sensor 8,Measured value not available or parameter outside measur.range,
IDE14143,External sound amplifier: supply voltage,Not available,
IDE14144-MAS00849,Automotive audio bus (A2B): protocol version-Information electronics control module 1,ÿÿÿ,
IDE14144-MAS17874,Automotive audio bus (A2B): protocol version-External sound amplifier,ÿÿÿ,
IDE14145-MAS17168,Multimedia display unit 3 operating sensors-Touchscreen: touch recognition,not detected,
IDE14145-MAS17169,Multimedia display unit 3 operating sensors-Touchscreen: activation,Not operated,
IDE14146-MAS01159,Digital Transmission Content Protection (DTCP) device certificate-Version number,0,
IDE14146-MAS01779,Digital Transmission Content Protection (DTCP) device certificate-Length,0,
IDE14146-MAS06742,Digital Transmission Content Protection (DTCP) device certificate-Certificate type,0,
IDE14146-MAS18364,Digital Transmission Content Protection (DTCP) device certificate-SRM ID (System Renewability Message),0,
IDE14344-MAS19021,Automotive audio bus (A2B): status-Master activation status,activated,
IDE14344-MAS19042,Automotive audio bus (A2B): status-Startup behavior,optimized,
IDE14344-MAS19046,Automotive audio bus (A2B): status-Master bus status,electrically OK,
IDE14344-MAS19050,Automotive audio bus (A2B): status-Master Versions ID,Deactivated,
IDE14344-MAS19051,Automotive audio bus (A2B): status-Slave 1 Name,Emergency call module and communication unit,
IDE14344-MAS19052,Automotive audio bus (A2B): status-Slave 2 Name,Deactivated,
IDE14344-MAS19053,Automotive audio bus (A2B): status-Slave 3 Name,Deactivated,
IDE14344-MAS19054,Automotive audio bus (A2B): status-Slave 4 Name,Deactivated,
IDE14344-MAS19055,Automotive audio bus (A2B): status-Slave 5 Name,Deactivated,
IDE14344-MAS19056,Automotive audio bus (A2B): status-Slave 6 Name,Deactivated,
IDE14344-MAS19057,Automotive audio bus (A2B): status-Slave 7 Name,Deactivated,
IDE14344-MAS19058,Automotive audio bus (A2B): status-Slave 8 Name,Deactivated,
IDE14344-MAS19059,Automotive audio bus (A2B): status-Slave 9 Name,Deactivated,
IDE14344-MAS19060,Automotive audio bus (A2B): status-Slave 1 Status,Not available,
IDE14344-MAS19061,Automotive audio bus (A2B): status-Slave 2 Status,Deactivated,
IDE14344-MAS19062,Automotive audio bus (A2B): status-Slave 3 Status,Deactivated,
IDE14344-MAS19063,Automotive audio bus (A2B): status-Slave 4 Status,Deactivated,
IDE14344-MAS19064,Automotive audio bus (A2B): status-Slave 5 Status,Deactivated,
IDE14344-MAS19065,Automotive audio bus (A2B): status-Slave 6 Status,Deactivated,
IDE14344-MAS19066,Automotive audio bus (A2B): status-Slave 7 Status,Deactivated,
IDE14344-MAS19067,Automotive audio bus (A2B): status-Slave 8 Status,Deactivated,
IDE14344-MAS19068,Automotive audio bus (A2B): status-Slave 9 Status,Deactivated,
IDE14344-MAS19069,Automotive audio bus (A2B): status-Slave 1 Versions ID,Deactivated,
IDE14344-MAS19070,Automotive audio bus (A2B): status-Slave 2 Versions ID,Deactivated,
IDE14344-MAS19071,Automotive audio bus (A2B): status-Slave 3 Versions ID,Deactivated,
IDE14344-MAS19072,Automotive audio bus (A2B): status-Slave 4 Versions ID,Deactivated,
IDE14344-MAS19073,Automotive audio bus (A2B): status-Slave 5 Versions ID,Deactivated,
IDE14344-MAS19074,Automotive audio bus (A2B): status-Slave 6 Versions ID,Deactivated,
IDE14344-MAS19075,Automotive audio bus (A2B): status-Slave 7 Versions ID,Deactivated,
IDE14344-MAS19076,Automotive audio bus (A2B): status-Slave 8 Versions ID,Deactivated,
IDE14344-MAS19077,Automotive audio bus (A2B): status-Slave 9 Versions ID,Deactivated,
IDE14715-MAS18871,Acoustic test of loudspeakers: status-Current channel,OFF,
IDE14715-MAS18921,Acoustic test of loudspeakers: status-Current loudspeaker,Not available,
IDE14733-MAS00106,SDARS subscription status-Year,2000,
IDE14733-MAS00107,SDARS subscription status-Month,0, Months
IDE14733-MAS00108,SDARS subscription status-Day,Not available,
IDE14733-MAS00109,SDARS subscription status-Hours,0, H
IDE14733-MAS00110,SDARS subscription status-Minutes,0, min
IDE14733-MAS00111,SDARS subscription status-Seconds,0, s
IDE14733-MAS10690,SDARS subscription status-Activation condition,active,
IDE14733-MAS19035,SDARS subscription status-Procedure status,not expired,
IDE14733-MAS19036,SDARS subscription status-Expiration warning,0,
IDE14734-MAS01766,SDARS Service Status-Traffic data,freely available (free to air),
IDE14734-MAS19037,SDARS Service Status-Audio Service,active,
IDE14734-MAS19040,SDARS Service Status-Travel link,freely available (free to air),
IDE15385-MAS06854,Patch version for information electronics-Version,0000,
IDE15386-MAS20717,Time stamp for software update-Update 1,no update started,
IDE15386-MAS20723,Time stamp for software update-Update start date,--.--.---,
IDE15386-MAS20723,Time stamp for software update-Update start date,--.--.----,
IDE15386-MAS20723,Time stamp for software update-Update start date,-.------:-,
IDE15386-MAS20724,Time stamp for software update-Update start time,--:--:--,
IDE15386-MAS20724,Time stamp for software update-Update start time,---:--:-,
IDE15386-MAS20724,Time stamp for software update-Update start time,-:----.,
IDE15386-MAS20725,Time stamp for software update-Update end date,---.--.---,
IDE15386-MAS20725,Time stamp for software update-Update end date,--.--.----,
IDE15386-MAS20725,Time stamp for software update-Update end date,--.------:,
IDE15386-MAS20725,Time stamp for software update-Update end date,--.Ý,
IDE15386-MAS20725,Time stamp for software update-Update end date,--.---.---,
IDE15386-MAS20726,Time stamp for software update-Update end time,--:--:--,
IDE15386-MAS20726,Time stamp for software update-Update end time,---:--:-,
IDE15386-MAS20726,Time stamp for software update-Update end time,öb,
IDE15386-MAS20726,Time stamp for software update-Update end time,--:----.,
IDE15386-MAS20727,Time stamp for software update-Update 2,no update started,
IDE15386-MAS20728,Time stamp for software update-Update 3,no update started,
IDE15386-MAS20729,Time stamp for software update-Update 4,no update started,
IDE15386-MAS20730,Time stamp for software update-Update 5,no update started,
IDE15386-MAS20731,Time stamp for software update-Update 6,no update started,
IDE15386-MAS20732,Time stamp for software update-Update 7,no update started,
IDE15386-MAS20733,Time stamp for software update-Update 8,no update started,
IDE15386-MAS20734,Time stamp for software update-Update 9,no update started,
IDE15386-MAS20735,Time stamp for software update-Update 10,no update started,
IDE15386-MAS20736,Time stamp for software update-Update 11,no update started,
IDE15386-MAS20737,Time stamp for software update-Update 12,no update started,
IDE15386-MAS20738,Time stamp for software update-Update 13,no update started,
IDE15386-MAS20739,Time stamp for software update-Update 14,no update started,
IDE15386-MAS20740,Time stamp for software update-Update 15,no update started,
IDE15386-MAS20741,Time stamp for software update-Update 16,no update started,
IDE15386-MAS20742,Time stamp for software update-Update 17,no update started,
IDE15386-MAS20743,Time stamp for software update-Update 18,no update started,
IDE15386-MAS20744,Time stamp for software update-Update 19,no update started,
IDE15386-MAS20745,Time stamp for software update-Update 20,no update started,
IDE15386-MAS20746,Time stamp for software update-Update 21,no update started,
IDE15386-MAS20747,Time stamp for software update-Update 22,no update started,
IDE15386-MAS20748,Time stamp for software update-Update 23,no update started,
IDE15386-MAS20749,Time stamp for software update-Update 24,no update started,
IDE15386-MAS20750,Time stamp for software update-Update 25,no update started,
IDE15386-MAS20751,Time stamp for software update-Update 26,no update started,
IDE15386-MAS20752,Time stamp for software update-Update 27,no update started,
IDE15386-MAS20753,Time stamp for software update-Update 28,no update started,
IDE15386-MAS20754,Time stamp for software update-Update 29,Unknown (45),
IDE15386-MAS20755,Time stamp for software update-Update 30,Unknown (45),
IDE15386-MAS20756,Time stamp for software update-Update 31,Unknown (45),
IDE15386-MAS20757,Time stamp for software update-Update 32,Unknown (45),
IDE15386-MAS20758,Time stamp for software update-Update 33,Unknown (45),
IDE15386-MAS20759,Time stamp for software update-Update 34,Unknown (45),
IDE15386-MAS20760,Time stamp for software update-Update 35,Unknown (45),
IDE15386-MAS20761,Time stamp for software update-Update 36,Unknown (45),
IDE15386-MAS20762,Time stamp for software update-Update 37,Unknown (45),
IDE15386-MAS20763,Time stamp for software update-Update 38,Unknown (45),
IDE15386-MAS20764,Time stamp for software update-Update 39,Unknown (45),
IDE15386-MAS20765,Time stamp for software update-Update 40,Unknown (45),
IDE15386-MAS20766,Time stamp for software update-Update 41,Unknown (45),
IDE15386-MAS20767,Time stamp for software update-Update 42,Unknown (45),
IDE15386-MAS20768,Time stamp for software update-Update 43,Unknown (45),
IDE15386-MAS20769,Time stamp for software update-Update 44,Unknown (45),
IDE15386-MAS20770,Time stamp for software update-Update 45,Unknown (45),
IDE15386-MAS20771,Time stamp for software update-Update 46,Unknown (45),
IDE15386-MAS20772,Time stamp for software update-Update 47,Unknown (45),
IDE15386-MAS20773,Time stamp for software update-Update 48,Unknown (45),
IDE15386-MAS20774,Time stamp for software update-Update 49,Unknown (45),
IDE15386-MAS20775,Time stamp for software update-Update 50,Unknown (45),
IDE15507-MAS07130,Container for software application: identification-Number of ID steps,39,
IDE15507,Container for software application: identification,sha256:e99,
IDE15508-MAS07130,Container for software application: detailed information-Number of ID steps,9,
IDE15508-ENG124728,Container for software application: detailed information-image_number,1,
IDE15508-ENG125095,Container for software application: detailed information-patch_build,00 00,
IDE15508-ENG124150,Container for software application: detailed information-Service_ID,/carapp_osp.ef104bd119dd,
IDE15508-ENG98933,Container for software application: detailed information-Status,running_more_10_seconds,
IDE15508-ENG125529,Container for software application: detailed information-version_major,0,
IDE15508-ENG125530,Container for software application: detailed information-version_minor,0,
IDE15942-MAS01167,Left front treble speaker motor: Status-Actuation time,0 s,
IDE15942-ENG39349,Left front treble speaker motor: Status-IoReached Status,Output diagnostic test not active,
IDE15943-MAS01167,Right front treble speaker motor: Status-Actuation time,0 s,
IDE15943-ENG39349,Right front treble speaker motor: Status-IoReached Status,Output diagnostic test not active,
IDE15951,Joker button: function assignment,32497601164241262,
IDE15974,Joker button 2: function assignment,31084431849909859,
MAS00775-IDE03619,Multimedia System 2-System condition,On,
MAS00775-IDE05228,Multimedia System 2-Operating hour counter,32, H
MAS00775-MAS00110,Multimedia System 2-Minutes,21, min
MAS00775-MAS01634,Multimedia System 2-Supply voltage,14.30, V
MAS00775-MAS02200,Multimedia System 2-Highest measured temperature,55, °C
MAS00775-MAS02201,Multimedia System 2-Temperature,29, °C
MAS00775-MAS03691,Multimedia System 2-Dimming,100, %
MAS00778-IDE03619,Multimedia System 1-System condition,On,
MAS00778-IDE05228,Multimedia System 1-Operating hour counter,32, H
MAS00778-MAS00110,Multimedia System 1-Minutes,21, min
MAS00778-MAS01634,Multimedia System 1-Supply voltage,14.30, V
MAS00778-MAS02200,Multimedia System 1-Highest measured temperature,68, °C
MAS00778-MAS02201,Multimedia System 1-Temperature,29, °C
MAS00778-MAS03691,Multimedia System 1-Dimming,100, %
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Digital,
MAS01760-MAS02949,Radio Tuner 1-Frequency,105.30, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,49,
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,45,
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),Not available,
MAS01760-MAS19025,Radio Tuner 1-IBOC fault rate,Not available,
MAS01760-MAS19026,Radio Tuner 1-IBOC audio signal:,available.,
MAS01760-MAS19028,Radio Tuner 1-IBOC DRM Service,Unknown (1),
MAS01760-MAS19030,Radio Tuner 1-IBOC DRM counter,2,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,40,
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS17268,Functions which can be activated: connection error counter,1,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,available.,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,00 04 01 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,12,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG20107,Error_code_external_optical_usb_drive,Not available,
ENG48509-ENG49940,FoD_slave_operating_state-FoD_slave_state,02,
ENG48830-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,available.,
ENG48830-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,invalid,
ENG48830-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,00 04 01 00,
ENG48830-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,available.,
ENG48830-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,not OK,
ENG48830-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition not met,
ENG48830-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,No,
ENG48830-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition met,
ENG48830-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,12,
ENG48830-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG118089-MAS01167,Operating_Unit_Simulation_Keys_status-Actuation time,15 s,
ENG118089-ENG39349,Operating_Unit_Simulation_Keys_status-IoReached Status,Output diagnostic test not active,
ENG118096-MAS01167,Remote_Seek_Activation_status-Actuation time,0 s,
ENG118096-ENG39349,Remote_Seek_Activation_status-IoReached Status,Output diagnostic test not active,
ENG118097-MAS01167,Remote_Set_AF_status-Actuation time,0 s,
ENG118097-ENG39349,Remote_Set_AF_status-IoReached Status,Output diagnostic test not active,
ENG118099-MAS01167,Remote_Set_DAB_Announcement_status-Actuation time,0 s,
ENG118099-ENG39349,Remote_Set_DAB_Announcement_status-IoReached Status,Output diagnostic test not active,
ENG118100-MAS01167,Remote_Set_DAB_Default_status-Actuation time,0 s,
ENG118100-ENG39349,Remote_Set_DAB_Default_status-IoReached Status,Output diagnostic test not active,
ENG118101-MAS01167,Remote_Set_DAB_Linking_status-Actuation time,0 s,
ENG118101-ENG39349,Remote_Set_DAB_Linking_status-IoReached Status,Output diagnostic test not active,
ENG118102-MAS01167,Remote_Set_DAB_Mute_status-Actuation time,0 s,
ENG118102-ENG39349,Remote_Set_DAB_Mute_status-IoReached Status,Output diagnostic test not active,
ENG118103-MAS01167,Remote_Set_Hidden_Tune_status-Actuation time,0 s,
ENG118103-ENG39349,Remote_Set_Hidden_Tune_status-IoReached Status,Output diagnostic test not active,
ENG118104-MAS01167,Remote_Set_IBOC_Service_status-Actuation time,0 s,
ENG118104-ENG39349,Remote_Set_IBOC_Service_status-IoReached Status,Output diagnostic test not active,
ENG118105-MAS01167,Remote_Set_TP_status-Actuation time,0 s,
ENG118105-ENG39349,Remote_Set_TP_status-IoReached Status,Output diagnostic test not active,
ENG118106-MAS01167,Remote_Shift_Frequency_AM_Activation_status-Actuation time,0 s,
ENG118106-ENG39349,Remote_Shift_Frequency_AM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG118107-MAS01167,Remote_Shift_Frequency_DAB_Activation_status-Actuation time,0 s,
ENG118107-ENG39349,Remote_Shift_Frequency_DAB_Activation_status-IoReached Status,Output diagnostic test not active,
ENG118108-MAS01167,Remote_Shift_Frequency_FM_Activation_status-Actuation time,0 s,
ENG118108-ENG39349,Remote_Shift_Frequency_FM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG118125-MAS01167,set_amfm_measurement_mode_status-Actuation time,0 s,
ENG118125-ENG39349,set_amfm_measurement_mode_status-IoReached Status,Output diagnostic test not active,
ENG118126-MAS01167,set_tuner_mode_status-Actuation time,0 s,
ENG118126-ENG39349,set_tuner_mode_status-IoReached Status,Output diagnostic test not active,
Elapsed Time: 01:35
blockmap-6D-4KE-959-107_WA1AAAGE8MB028917-20210516-1212.CSV
;SW:4KE-959-107   HW:4KE-959-107 ---  Trunk Elect.
;Component:HDSG-Modul    H04 0330, Coding:3320
;EV_DeckLidCONTIAU536,001001,EV_DeckLidCONTIAU536.rod
;Sunday,16,May,2021,12:12:59:36589
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210508 DS325.1
;VCID: 035386202B9DF6C3921-8056
Group,Description,Actual
IDE00019,Voltage terminal 30,12.99, V
IDE00542,Excessive temperature protection,not active,
IDE02019-MAS08993,Position programmable opening stop-Upper end pos.: relative,97, %
IDE02019-MAS08994,Position programmable opening stop-Upper end pos.: absolute,2769,
IDE02049,Trailer detected,Not available,
IDE02093-MAS09014,Status of rear lid lock-pre-latch,closed,
IDE02093-MAS09015,Status of rear lid lock-Main latch,closed,
IDE02093-MAS09016,Status of rear lid lock-Rear lid lock,closed,
IDE02094-MAS09057,Status of closing assist-Limit switch for pull-shut assist.,operated,
IDE02095-MAS01947,Status of pinch protection-Clamping strip 1,Not operated,
IDE02095-MAS01948,Status of pinch protection-Clamping strip 2,Not operated,
IDE02095-MAS01949,Status of pinch protection-Clamping strip 3,Not operated,
IDE02095-MAS01950,Status of pinch protection-Clamping strip 4,Not operated,
IDE03427-MAS08995,Upper end stop: maximum value-Max. upper end position,2849,
IDE03615-MAS02672,Variant-Start-stop,1,
IDE03906-MAS01947,Pinch protection voltage supply status-Clamping strip 1,OFF,
IDE03906-MAS01948,Pinch protection voltage supply status-Clamping strip 2,OFF,
IDE03906-MAS01949,Pinch protection voltage supply status-Clamping strip 3,OFF,
IDE03906-MAS01950,Pinch protection voltage supply status-Clamping strip 4,On,
IDE05229,Reason for cancellation of rear lid procedure,completed successfully,
IDE09491-IDE03434,Lock-in area-Detection area lower,107,
IDE09491-IDE03435,Lock-in area-Detection area upper,107,
IDE09492-MAS06165,Temperatures-Processor,-3276.00, °C
IDE09492-MAS08858,Temperatures-Outside air temperature on CAN,25.50, °C
IDE09492-MAS08996,Temperatures-Internal temp. on CAN,27.00, °C
IDE09492-MAS08997,Temperatures-Output stage for tailgate motor,32.00, °C
IDE09492-MAS08998,Temperatures-Tailgate motor left,25.00, °C
IDE09492-MAS08999,Temperatures-Tailgate motor right,25.00, °C
IDE09492-MAS09001,Temperatures-Closing Assist Motor,Not available,
IDE09492-MAS09051,Temperatures-Output stage for tailgate motor: calculated,250.00, °C
IDE09492-MAS09053,Temperatures-Output stage for closing assist: calculated,Not available,
IDE09492-MAS11205,Temperatures-Luggage compartment cover motor,200.00, °C
IDE09492-MAS11206,Temperatures-Output stage for luggage comp. cover: calc.,250.00, °C
IDE09493,Status of basic tailgate setting,Basic setting ended,
IDE09494-MAS09002,Cancellation reason of basic tailgate setting-Last reason,Unknown (0),
IDE09494-MAS09003,Cancellation reason of basic tailgate setting-second last reasons,Unknown (0),
IDE09494-MAS09004,Cancellation reason of basic tailgate setting-third last reason,Unknown (0),
IDE09494-MAS09005,Cancellation reason of basic tailgate setting-fourth last reason,Unknown (0),
IDE09494-MAS09006,Cancellation reason of basic tailgate setting-fifth last reason,Unknown (0),
IDE09495,Status of tailgate initialization,initialized,
IDE09496-MAS09002,Reason for loss of tailgate initialization-Last reason,Reset,
IDE09496-MAS09003,Reason for loss of tailgate initialization-second last reasons,Reset,
IDE09496-MAS09004,Reason for loss of tailgate initialization-third last reason,Reset,
IDE09496-MAS09005,Reason for loss of tailgate initialization-fourth last reason,Supply voltage error,
IDE09496-MAS09006,Reason for loss of tailgate initialization-fifth last reason,Reset,
IDE09498-MAS01871,Status of control points-Rear lid lock button in luggage compartment,Not operated,
IDE09498-MAS01872,Status of control points-Rear lid remote control lock switch,Not operated,
IDE09498-MAS06265,Status of control points-Release button in rear lid handle,Not operated,
IDE09498-MAS06446,Status of control points-Remote radio control: button for luggage compartment unlocking,Not operated,
IDE09498-MAS09010,Status of control points-Sensor for rear lid opening,Not operated,
IDE09498-MAS09072,Status of control points-Locking mechanism button in the rear lid,Not operated,
IDE09498-MAS13753,Status of control points-Button 2 for rear lid remote release,Malfunction,
IDE09499-IDE01991,Motors for tailgate: activation-Motor 1 for tailgate: status,OFF,
IDE09499-IDE02012,Motors for tailgate: activation-Motor 2 for tailgate: status,OFF,
IDE09499-MAS09001,Motors for tailgate: activation-Closing Assist Motor,OFF,
IDE09499-MAS11205,Motors for tailgate: activation-Luggage compartment cover motor,not installed,
IDE09500-MAS09012,Motors for tailgate: RPM-Rear lid motor 1,0.00, Hz
IDE09500-MAS09013,Motors for tailgate: RPM-Rear lid motor 2,0.00, Hz
IDE09500-MAS11205,Motors for tailgate: RPM-Luggage compartment cover motor,0.00, Hz
IDE09501-MAS09001,Motors for tailgate: elec. current-Closing Assist Motor,0.00, A
IDE09501-MAS09012,Motors for tailgate: elec. current-Rear lid motor 1,0.00, A
IDE09501-MAS09013,Motors for tailgate: elec. current-Rear lid motor 2,0.00, A
IDE09501-MAS11205,Motors for tailgate: elec. current-Luggage compartment cover motor,0.00, A
IDE09502-IDE02097,Tailgate angle sensor: absolute value-Position Sensor 1,0,
IDE09502-IDE02098,Tailgate angle sensor: absolute value-Position sensor 2,0,
IDE09502-IDE10697,Tailgate angle sensor: absolute value-Luggage compartment cover: position,0,
IDE09503-IDE02017,Tailgate angle sensor: relative value-Rear lid position: relative,0, %
IDE09503-MAS11205,Tailgate angle sensor: relative value-Luggage compartment cover motor,0, %
IDE09504,Status of clutch test,not active,
IDE09505-IDE02078,Tailgate actuation counter-Activations of rear lid closing button,57,
IDE09505-IDE02079,Tailgate actuation counter-Activations of rear lid unlocking button,57,
IDE09505-IDE02080,Tailgate actuation counter-Activations of rear lid remote unlocking switch,4,
IDE09505-IDE02081,Tailgate actuation counter-Activation of remote key button rid lid opening,4,
IDE09505-IDE02082,Tailgate actuation counter-Opening cycle counter,62,
IDE09505-IDE02083,Tailgate actuation counter-Closing cycle counter,66,
IDE09505-IDE02084,Tailgate actuation counter-Counter obstruction detected,4,
IDE09505-IDE02085,Tailgate actuation counter-Counter of selectable opening stop adapted,0,
IDE09505-IDE02087,Tailgate actuation counter-Counter for function limitation due to insufficient voltage,0,
IDE09505-IDE02088,Tailgate actuation counter-Counter for function limitation due to excessive voltage,0,
IDE09505-IDE02090,Tailgate actuation counter-Counter for function limitation due to excessive temperature,0,
IDE09505-IDE02174,Tailgate actuation counter-Counter of flap opening angle basic settings,1,
IDE09505-IDE03774,Tailgate actuation counter-Counter for closing operations canceled by lock-up,0,
IDE09505-MAS08873,Tailgate actuation counter-Resets to hardware watchdog,0,
IDE09505-MAS08874,Tailgate actuation counter-Resets due to software watchdog,0,
IDE09505-MAS09017,Tailgate actuation counter-Counter tailgate lock: implausible,0,
IDE09505-MAS09018,Tailgate actuation counter-Counter pull-shut asst. implausible,0,
IDE09505-MAS09019,Tailgate actuation counter-Play protection counter active,0,
IDE09505-MAS09058,Tailgate actuation counter-Counter Hall sensor in motor 1 for tailgate implausible,0,
IDE09505-MAS09059,Tailgate actuation counter-Counter Hall sensor in motor 2 for tailgate implausible,0,
IDE09505-MAS09060,Tailgate actuation counter-Wake-up events button for closing rear lid in lugg.compartment,20,
IDE09505-MAS09061,Tailgate actuation counter-Wake-up events Hall sensor in motor for tailgate,4,
IDE09505-MAS09062,Tailgate actuation counter-Wake-up events in data bus,2572,
IDE09505-MAS09076,Tailgate actuation counter-Activating tailgate button for locking,6,
IDE09505-MAS09077,Tailgate actuation counter-Activating sensor for tailgate opening,12,
IDE09505-MAS09078,Tailgate actuation counter-Wake-up events button for unlocking tailgate,1,
IDE09505-MAS09482,Tailgate actuation counter-Current limitation active,0,
IDE09505-MAS10783,Tailgate actuation counter-Closing assist.counter: aborted by operating unit,0,
IDE09505-MAS11977,Tailgate actuation counter-Emergency running counter after terminal 30 reset,21,
IDE09505-MAS11978,Tailgate actuation counter-Play protection counter for closing aid active,0,
IDE09505-MAS12517,Tailgate actuation counter-Reset via timeout monitoring watchdog,0,
IDE09505-MAS12518,Tailgate actuation counter-Reset via network management monitoring watchdog,0,
IDE09505-MAS13753,Tailgate actuation counter-Button 2 for rear lid remote release,0,
IDE09506,Rear lid anti-play protection,not active,
IDE09519-MAS09054,Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply,On,
IDE09519-MAS09055,Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply,On,
IDE09519-MAS09066,Status of hall sensor in motor for tailgate-Motor 1: Sensor 1,00000001 ,
IDE09519-MAS09067,Status of hall sensor in motor for tailgate-Motor 1: Sensor 2,00000001 ,
IDE09519-MAS09068,Status of hall sensor in motor for tailgate-Motor 2: Sensor 1,00000001 ,
IDE09519-MAS09069,Status of hall sensor in motor for tailgate-Motor 2: Sensor 2,00000001 ,
IDE09519-MAS11207,Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1,00000000 ,
IDE09519-MAS11209,Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply,OFF,
IDE10697-MAS01471,Luggage compartment cover: position-lower stop,6,
IDE10697-MAS01472,Luggage compartment cover: position-upper stop,-8960,
IDE10697-MAS02282,Luggage compartment cover: position-Position,57,
IDE10698-IDE03774,Luggage compartment cover: counter-Counter for closing operations canceled by lock-up,0,
IDE10698-MAS09020,Luggage compartment cover: counter-Down adjustment,0,
IDE10698-MAS09021,Luggage compartment cover: counter-Up adjustment,0,
IDE10698-MAS09023,Luggage compartment cover: counter-Total number of adjustments,0,
IDE10698-MAS09024,Luggage compartment cover: counter-Shutdowns by excess force limiter,0,
IDE10698-MAS09025,Luggage compartment cover: counter-Blocking bottom mechan. stop,0,
IDE10698-MAS09026,Luggage compartment cover: counter-Blocking upper mechan. stop,0,
IDE10698-MAS09027,Luggage compartment cover: counter-Re-initializationn in bottom mechan. stop,0,
IDE10698-MAS09028,Luggage compartment cover: counter-Re-initialization in upper mechan. stop,0,
IDE10698-MAS09029,Luggage compartment cover: counter-Number of re-initializations,0,
IDE10699-MAS00342,Status of luggage compartment cover initialization-Initialization,not initialized,
IDE10700-MAS09002,Reason for loss of luggage compartment cover initialization-Last reason,Not yet initialized,
IDE10700-MAS09003,Reason for loss of luggage compartment cover initialization-second last reasons,Not yet initialized,
IDE10700-MAS09004,Reason for loss of luggage compartment cover initialization-third last reason,Not yet initialized,
IDE10700-MAS09005,Reason for loss of luggage compartment cover initialization-fourth last reason,Not yet initialized,
IDE10700-MAS09006,Reason for loss of luggage compartment cover initialization-fifth last reason,Not yet initialized,
IDE10804,Easing of rear lid,not active,
IDE11033,Motor for luggage compart. cover: excess. temp: protection,active,
IDE11036,Pull-shut asst.: play protec.,not active,
IDE11868,Indicator lamp for delayed closing,not installed,
IDE13157,Partial network operation counter not available,0,
MAS00972,Decoration variant,2,
Elapsed Time: 00:06
blockmap-74-4KE-907-777-AH_WA1AAAGE8MB028917-20210516-1213.CSV
;SW:4KE-907-777-AH   HW:4KE-907-777-A ---  Chassis Control
;Component:Fahrwerk-SG   H53 2320, Coding:18D8607BDA4020
;EV_ChassContrContiAU651,003018,EV_ChassContrContiAU651_003.rod
;Sunday,16,May,2021,12:13:19:36589
;VCID: 127DB36464E76F4B297-8046
IDE00018,Voltage terminal 15,0.00, V
IDE00019,Voltage terminal 30,13.00, V
IDE00106,Internal DTC,0,
IDE00303-IDE08198,Status: doors/lids 1-Activation status anti-theft warning system,not active,
IDE00303-MAS00218,Status: doors/lids 1-Driver door,Open,
IDE00303-MAS00219,Status: doors/lids 1-Front Passenger Door,closed,
IDE00303-MAS00220,Status: doors/lids 1-Left rear door,closed,
IDE00303-MAS00221,Status: doors/lids 1-Right rear door,closed,
IDE00303-MAS06522,Status: doors/lids 1-Rear lid: Status,closed,
IDE00303-MAS08523,Status: doors/lids 1-All doors and rear lid closed,Condition not met,
IDE00541-IDE02543,Acceleration-Body acceleration sensor,9.85, m/s²
IDE00541-IDE02545,Acceleration-Body acceleration sensor: status,valid,
IDE00767-MAS01478,No. of unscheduled ECU resets-insufficient voltage,Initial value,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,Initial value,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,07 43 1C 96,
IDE02542,Transverse acceleration sensor 2: temperature,-327.68, °C
IDE02544,Body acceleration sensor: temperature,29.74, °C
IDE02547,Roll rate sensor: temperature,32.91, °C
IDE02550,Pitch rate sensor: temperature,29.74, °C
IDE02940-MAS03034,System pressure-Pressure,1.10, bar
IDE02940-MAS10469,System pressure-Raw value,0.52, V
IDE02941,Compressor temperature,28, °C
IDE02946-MAS01374,Status MMI operation-Trailer,not active,
IDE02946-MAS03024,Status MMI operation-Car jack mode,not active,
IDE02946-MAS08486,Status MMI operation-Lift mode,not active,
IDE03008-MAS01746,Stop process prevented-Control active,not active,
IDE03010-MAS01746,Number of prevented stop processes-Control active,0,
IDE03011-MAS01746,Number of requested start processes-Control active,0,
IDE03038,Control position: specified value,Normal level,
IDE03050,Voltage supply for Solen.val. block,13.02, V
IDE03051,Voltage supply for right sensor for level control system,4.98, V
IDE03052,Voltage supply for left sensor for level control system,4.98, V
IDE03053,Voltage supply of sensor for system pressure,4.98, V
IDE03064,Accumulator pressure,16.40, bar
IDE03208-MAS01390,Software version for suppliers-Block 1,7100CAE0,
IDE03208-MAS01391,Software version for suppliers-Block 2,71015704,
IDE03208-MAS01392,Software version for suppliers-Block 3,7102E100,
IDE03208-MAS01393,Software version for suppliers-Block 4,7103E500,
IDE03208-MAS01394,Software version for suppliers-Block 5,7104E300,
IDE03208-MAS01395,Software version for suppliers-Block 6,7105E307,
IDE03208-MAS01396,Software version for suppliers-Block 7,7106C255,
IDE03208-MAS01397,Software version for suppliers-Block 8,7107E301,
IDE03208-MAS01398,Software version for suppliers-Block 9,7108E102,
IDE03208-MAS01399,Software version for suppliers-Block 10,7109E422,
IDE03208-MAS01400,Software version for suppliers-Block 11,7111EH00,
IDE03208-MAS01401,Software version for suppliers-Block 12,7112E300,
IDE03208-MAS01402,Software version for suppliers-Block 13,7113E300,
IDE03208-MAS01403,Software version for suppliers-Block 14,7114E700,
IDE03208-MAS01404,Software version for suppliers-Block 15,----S1E2,
IDE03208-MAS01405,Software version for suppliers-Block 16,7115E902,
IDE03208-MAS01406,Software version for suppliers-Block 17,7116----,
IDE03208-MAS01407,Software version for suppliers-Block 18,7117----,
IDE03208-MAS01408,Software version for suppliers-Block 19,7118----,
IDE03208-MAS01409,Software version for suppliers-Block 20,7119----,
IDE03661-IDE02546,Rotation rate-Roll rate sensor,0.01, rad/s
IDE03661-IDE02548,Rotation rate-Roll rate sensor: status,valid,
IDE03661-IDE02549,Rotation rate-Pitch rate sensor,-0.01, rad/s
IDE03661-IDE02551,Rotation rate-Pitch rate sensor: status,valid,
IDE04018-MAS00106,Pressure test time stamp: current-Year,2021,
IDE04018-MAS00107,Pressure test time stamp: current-Month,5,
IDE04018-MAS00108,Pressure test time stamp: current-Day,16,
IDE04018-MAS00109,Pressure test
