Saturday,21,March,2015,18:34:36:63214
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: WAUZZZ8X0CB238424 License Plate: LAUREN'S A1
Mileage: 66750km-41476mi Repair Order:
Chassis Type: 8X (8U0)
VIN: WAUZZZ8X0CB238424 Mileage: 66750km-41476miles
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 KQ HW: 03L 906 023 KP
Component: 1,6l R4 CR td H63 8535
Revision: --H63--- Serial number:
Coding: 00114016030501080000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM16TDI02103L906023KQ 003010
ROD: EV_ECM16TDI02103L906023KG.rod
VCID: 7F0D36B9E60B92D917A-802A
14355 - Exhaust Gas Temperature Sensor; B1 S3
P242A 00 [032] - Malfunction
7345 - Diesel Particle Filter; Differential Pressure Sensor
P2455 00 [032] - Short to Plus
Mileage: 66443 km
Date: 2015.01.24
Time: 14:24:57
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 330448E9417000BACC2912E482D500920C00
Shop #: WSC 00046 000 00000
VCID: 7F0D36B9EA0B92D917A-802A
Address 08: Auto HVAC Labels: None
Part No SW: 8X0 820 045 HW: 8X0 820 045
Component: J255 Klima Manuell 0140
Revision: 0000707S Serial number: 03030009501524
VCID: 73E5EA891243C6B9632-8026
Reset counter: 202
Mileage: 66432 km
Date: 2015.01.23
Time: 17:14:15
Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
Part No SW: 8X0 907 063 F HW: 8X0 907 063 F
Component: BCM PQ35 B 110 0655
Revision: 00110 AE
Coding: 0E000A2CA805F100201841E00000005443836C0A00CF4122DC0087830041
VCID: 3F8D76B9AE8B52D957A-806A
Subsystem 1 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Address 15: Airbags (J234) Labels: 8X0-959-655.clb
Part No SW: 8X0 959 655 B HW: 8X0 959 655 B
Component: Airbag10.41 H05 0009
Revision: -------- Serial number: 003KZ0015YR$
Coding: 30314539303330303034554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: 49996861E84FEC69F9E-801C
Serial number: 3554VRB405T11D4680I3
Serial number: 3575HRB405H1BEPS3PG9
Serial number: 3585HRB405N1BEPS61BX
Rear Impact Crash Sensor:
Serial number: 3515ZRB405P0OPMM91R-
Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
Part No SW: 8X0 953 501 HW: 5K0 953 569 F
Component: LENKS.MODUL 014 0140
Revision: FF010017 Serial number: 20120404200808
Coding: 1180004000
VCID: 77FDDE99CE3BAA995FA-8022
Address 17: Instruments (J285) Labels: 8X0-920-xxx-17.clb
Part No SW: 8X0 920 950 B HW: 8X0 920 950 B
Component: KOMBI_BASIC H03 0180
Coding: 414200
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
VCID: 3B7502A9B2934EF97B2-806E
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 F HW: 8U0 907 468 F
Component: GAT 5CAN 1LIN H13 0058
Revision: 1Q080032 Serial number: 3241Q124018332
Coding: FB0F105A000100010153
VCID: 45816451CC5708091D6-8010
Subsystem 1 - Part No SW: 8K0 915 181 L HW: 8K0 915 181 L
Component: J367-BDM H08 0181
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Component: IMMO H03 0180
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 B HW: 8X0 959 793 B
Component: TSG FA H09 0409
Coding: 011802200101000100
VCID: 4C975175EF3DF941C28-8019
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F6D26F9EAEBA259C7A-807A
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 B HW: 8X0 959 792 B
Component: TSG BF H09 0409
VCID: 4B955269EA33FE79CB2-801E
Address 56: Radio (R) Labels: None
Part No SW: 8X0 035 180 F HW: 8X0 035 180 E
Component: RMC H52 0775
Serial number: AUZ4Z1M1170564
Coding: 01010000000011070002000003010000010000
VCID: 377D1E9986BB6A999FA-8062
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
End-------------------------(Elapsed Time: 02:03)--------------------------
