Help with security access
ColinT
Scotland
C?ID=43234
Good morning from Bonnie Scotland.
Hope you can help with a security access query.
Car is a 2019 Golf R Line TDI 150 DSG. I'm attempting to change the Comfort Indicator setting from 3 to 5.
I have followed to correct steps but after pressing Do it! a pop up tells me security access is required. I know that normally a pop up asks you to enter the security access code before making changes but this is not happening, there is no option to enter the access code.
Not a major issue but I would like to make this change so hoping somebody can help.
Cheers
Colin
Wednesday,19,May,2021,09:45:57:41864
VIN: WVWZZZAUZLW025725   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 75
VIN: WVWZZZAUZLW025725   Mileage: 14769km-9177miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 027 AG    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H26 9530
   Revision: B4H26---
   Coding: 01250412036405082000
   ASAM Dataset: EV_ECM20TDI01104L906027AG 004002
   ROD: EV_ECM20TDI01104L906027AG.rod
   VCID: 70B9DBCE8A292B0B7F3-8024
   Part No SW: 0GC 300 044 E    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V09
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 2A0D09A66C7511DBF17-807E
   No subsystems:
   Part No SW: 5Q0 614 517 ES    HW: 5Q0 614 517 BP
   Component: ESC           H35 0190
   Revision: 00000000    Serial number: 62289000001399
   Coding: 01FA8AA120220971477E060260C82980510490E26006947338625078D2024B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 06559D1698AD15BBB5F-8052
   Part No SW: 5G0 907 426 BH    HW: 5G0 907 426 BH
   Component: AC Manuell    H03 2201
   Revision: 00001K07
   Coding: 001201042001100C1000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004136
   VCID: 72BDD1C68425191B897-8026
   Part No SW: 5Q0 937 084 DF    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H40 0312
   Serial number: 01001923200075
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 7F5B08F2C7774473F69-802A
   Component: WWS    190714  042  0551
   Serial number:         190809080403
   Subsystem 2 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  051  0206
   Serial number: S4Y19M08D11H23M03S26
   Coding: 0008DD
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY19210242Z
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004  0007
   Serial number: 00000000000000526047
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000030071908490181
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058319239
   Coding: 0471051811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 50F97B4E2A690B0B5F3-8004
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3300678151FFC728949C810580400600000000000000000004
   VCID: 44D1471EEE11E7ABEBB-8010
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    008 0403
   Serial number: 003FNR5LA56T
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 1373B442DBFFB013221-8046
   Left seat belt tensioner:
   Serial number: 34169677E26081921425
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676E27081930521
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 708 19
   Serial number: 3570000000047BEC9E33
   Subsystem 4 - Part No SW: -----------    HW: 480 002 708 19
   Serial number: 358000000000386C3F3N
   Subsystem 5 - Part No SW: -----------    HW: 480 402 308 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001C4F240027596X
   Subsystem 6 - Part No SW: -----------    HW: 480 402 708 19
   Component: SideSensor_Pr  004 6149
   Serial number: 35200011C2C83D33053X
   Subsystem 7 - Part No SW: -----------    HW: 480 402 408 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001BEF2926C789BY
   Part No SW: 5G1 920 941 D    HW: 5G1 920 941 D
   Component: KOMBI         211 2700
   Coding: 27A429082780060001886B011401000800000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 16081910520307
   Coding: 030100045F087300FB10005C180F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   Generator:
   Component: 4-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 36190001084500019286
   Coding: 2DFFFF
   Serial number: 4653742305
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0320
   Serial number: YE007SH605276
   Coding: 003B0220D001048000001000
   VCID: 49CF562AC9333AC318D-801C
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000033059167
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1D7DEFE31172B9BB-8020
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0320
   Serial number: YE007SGV07871
   Coding: 003B0020DC01048000001000
   VCID: 48C9532ED239C3CB073-801C
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000032776776
   Coding: 150000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Coding: 02731001FF00000041110101008808001F0506C601200100CE
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 323D11C644A5591B497-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H53 8130
   Serial number: VWZ6ZHW2343785
   Subsystem 2 - Part No SW: 5NA 919 866 H    HW: -----------
   Component: ECE1 2019/20  --- 1115
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 02730001EA42180D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3D2732FA8DFB9663A45-8068
End----------(Elapsed Time: 11:59, VBatt start/end: 12.3V/12.3V)-----------
Derek
UK (ilexa)
C?ID=56983
Hello Colin
What module are you making the change in?
Have you clicked the [Security Access] button and then clicked on the entry box to see if VCDS offers the SA code?
Best regards
Derek
ColinT
Scotland
C?ID=43234
Doh! Thanks Derek, I appear to have made a schoolboy error!
No, I didn't select the Security Access button, I thought the SA entry box came up automatically when I picked Adaption.
Will try again later and let you know how I get on.
Cheers
Colin
Derek
UK (ilexa)
C?ID=56983
Cheers Colin, glad it's sorted
Best regards
Derek
