Hi.
I purchased a Golf Mk 8 at auction - Stolen / recovered.
The car is immaculate, the only fault was the infotainment system would just say 'loading' and nothing else. The car drove perfectly too.
I carried out an autoscan which revealed 'no communication 16777018 - Control unit for information electronics 1'
The SOS button in the ceiling had also been unplugged, I guess the thief didn't want to be tracked via GPS??
Anyway, I took the dashboard apart and removed the instrument cluster to discover that the infotainment control unit was entirely missing! (it's located behind the instrument cluster) The wires were left hanging behind the dashboard.
No idea why they would want to steal that?!
My question is this! If I purchase a second hand Golf Mk8 control module from the same spec vehicle, will it be a simple plug and play? Or is this thing going to need to be coded? Please don't say its main dealer only!
I'll post the scan below too. Thanks!
Latest:
Thursday,13,May,2021,19:39:56:41168
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WVWZZZCDZLW037882 License Plate:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 75 A5 D6 D7
8107
VIN: WVWZZZCDZLW037882 Mileage: 5473km-3400miles
75-Telematics -- Status: Cannot be reached 0100
8107-Antenna -- Status: Cannot be reached 0100
Address 01: Engine (J623-DPBA) Labels: None
Part No SW: 05E 906 012 HW: 05E 907 309 D
Component: R4 1.5l TFS H20 9971
Revision: 8AH20000
Coding: 011900322364150830080000000000000000000000000000
ASAM Dataset: EV_ECM15TFS01105E906012 002009
ROD: EV_ECM15TFS01105E906012.rod
VCID: 5CE1971896A18AEBB3B-8008
Readiness: 1110 0001
Part No SW: 5WA 614 517 AG HW: 5WA 614 517 A
Component: ESC H09 0013
Serial number: 60680000000600a
Coding: 34FC2C9022234473527F900809C561862DB458F042D067C0019CA231218FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 007045
ROD: EV_Brake1ESCEPBMQB37W_007_VW38.rod
VCID: 0D47AA5C1DDB5363F45-8058
Address 05: Acc/Start Auth. (J518) Labels: None
Part No SW: 5WA 959 436 B HW: 5WA 959 436 B
Component: Kessy IOBOX 070 0662
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 003019
ROD: EV_Kessy37w.rod
VCID: 53F37C24FB7F4593621-8006
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 5WA 907 727 S HW: 5WA 907 727 S
Component: Climatronic H01 0240
Coding: 002100010211000000000000101010010000011000000000000000000000
ASAM Dataset: EV_ACClimaBHBVW38X 005062
ROD: EV_ACClimaBHBVW38X_VW38.rod
VCID: 6099A3E8BAC9AE0BEF3-8034
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00001310320230546502
Part No SW: 5WA 937 086 Q HW: 5WA 937 086 J
Component: BCM 37W BOSCH 016 0136
Serial number: BXJ53F030320940
ASAM Dataset: EV_BCM37w 005001
ROD: EV_BCM37w_005_VW38.rod
VCID: 5F9BA01487B791F3D69-800A
Wiper motor control module:
Subsystem 1 - Part No SW: 5H2 955 119 HW: 5H2 955 119
Component: FWISCHER_MYJT 003 0041
Serial number: 907353F0402003401820
Subsystem 2 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S5Y20M06D30H19M19S16
Subsystem 3 - Part No SW: 5H0 941 193 AF HW: 5H0 941 193 AF
Component: LiSi H05 0007
Serial number: 92471TFG000NN
Control head for driving and comfort functions:
Subsystem 4 - Part No SW: 5H0 925 200 P HW: 5H0 925 200 P
Component: DiETa H06 0007
Serial number: 92471TCI000XJ
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000001071666
Subsystem 6 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY201350VM3
Roof electronics control module:
Subsystem 7 - Part No SW: 5H0 959 561 H HW: 5H0 959 561 H
Component: DACHKONSOLE 006 0006
Serial number: 92413TF300329-------
Steering Column Switch:
Subsystem 8 - Part No SW: 5Q1 953 507 M HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000019062004221646
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 294 A HW: 5WA 919 294
Component: PDC 08 Kanal H04 0022
Serial number: 000005032094630
Coding: 0040010001
ASAM Dataset: EV_EPHBO18VW3800000 002028
ROD: EV_EPHBO18VW3800000_VW38.rod
VCID: 50F97328CA693E8B5F3-8004
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 A HW: 5WA 907 572
Component: ACC Bosch MQB H10 0246
Coding: 010310750007404512474000000040054E4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
ROD: EV_FRONTRADARBOSCHVW380_003.rod
VCID: 4CC1675826411A6B23B-8018
Address 15: Airbags (J234) Labels:* None
Part No SW: 5WA 959 655 A HW: 5WA 959 655 A
Component: AirbagVW40 007 0523
Serial number: 000000003C0DKR6
Coding: 88CC000000C0C000000000000000000051540000205400004000F68000930065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001028
ROD: EV_AirbaVW40SMEVW38X_VW38.rod
VCID: 55F7823CF58B5BA38C5-8000
Subsystem 1 - Part No SW: ----------- HW: 480 400 406 20
Component: SideSensor_Dr 002 6149
Serial number: 351000110636E893546W
Subsystem 2 - Part No SW: ----------- HW: 480 400 406 20
Component: SideSensor_Pr 002 6149
Serial number: 352000110636E892A1E%
Subsystem 3 - Part No SW: ----------- HW: 480 000 303 20
Serial number: 3570000000089385C54Q
Subsystem 4 - Part No SW: ----------- HW: 480 000 403 20
Serial number: 358000000007FB5D264-
Subsystem 5 - Part No SW: ----------- HW: 480 400 206 20
Component: FrontSensor_D 002 614A
Serial number: 35500011E62FB985D49P
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 5H0 920 340 HW: 5H0 920 340
Component: KOMBI 237 1400
Coding: 24A4000063840600018062032000080800300800
ASAM Dataset: EV_DashBoardVDDMQB37W 002029
ROD: EV_DashBoardVDDMQB37W_002_VW38.rod
16777052 - Databus
[TM_01 communication error can_error_timeout]
Reset counter: 170
Mileage: 5473 km
Date: 2021.02.19
Time: 07:22:41
11145220 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Reset counter: 170
Mileage: 5473 km
Date: 2021.02.19
Time: 07:22:44
Part No SW: 5WA 907 530 C HW: 5WA 907 530 C
Component: GW2020 High 752 7070
Revision: -------- Serial number: 150160900253139
Coding: 0000808D0F00000000000000010301315301600900000300030100000001010000000000000000000000000000000000
ASAM Dataset: EV_GatewMQB2020 004003
ROD: EV_GatewMQB2020_VW38.rod
VCID: 48C95B483239F64B073-801C
Generator:
Component: 2-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 9441964305
Subsystem 3 - Part No SW: 3G0 959 442 F HW: 3G0 959 442 F
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440036038203530
2175079 - No Communications with Emergency Call Module
U10E1 00 [047] - -
Reset counter: 40
Mileage: 5473 km
Date: 2021.02.19
Time: 07:22:43
1049254 - Ethernet Databus Branch 6
U1231 00 [047] - No Communication
[Ethernet_databus_no_communication_branch_6_/_port_7]
Reset counter: 40
Mileage: 5473 km
Date: 2021.02.19
Time: 07:22:58
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 E HW: 3Q0 909 059 A
Component: EBKV H06 0092
Serial number: BPA085070320013
Coding: 1002C140730000CE39E79C73000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 011021
ROD: EV_BrakeBoostG2BoschVW37W_011_VW38.rod
VCID: 52FD7920C4654C9B697-8006
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H08 0040
Serial number: 20000075674011
Coding: 0000000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002004
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 323D19A0A4A56C9B497-8066
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0330
Serial number: YE007TBJ1172E
Coding: 003B02208001040000001000
VCID: 49CF5E4C29330F4318D-801C
Subsystem 1 - Part No SW: 5Q0 959 407 C HW: 5Q0 959 163
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000038968373
Coding: 0D0000
Part No SW: 5WA 907 144 H HW: 5WA 907 144 C
Component: BASGEN1MQB37 101 1030
Serial number: 00087955
Coding: 0000000000000000000102010100010000000101010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 006037
ROD: EV_SteerAssisBASGEN1MQB37_006.rod
VCID: 4EC56D50D05D287B4DF-801A
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0330
Serial number: YE007TBH14667
Coding: 003B00208C01040000801000
Subsystem 1 - Part No SW: 5Q0 959 408 C HW: 5Q0 959 164
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000039029901
Coding: 150000
Part No SW: 5H0 035 816 HW: 5H0 035 816
Component: MU-O-ND-EU H56 1664
Serial number: WG8LGM190220000
Coding: 23800008000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_VW38.rod
VCID: 6491AFF8AED1B22B0BB-8030
No subsystems:
Data carrier:
Subsystem 2 - Part No SW: V03 959 806 MG HW: -----------
Component: EU 2019/30 --- 202
Address 75: Telematics
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 5WA 980 653 A HW: 5WA 980 653
Component: MQB MFK 3.0 H05 3127
Serial number: E26735111201700
Coding: 0000090821484040409E00001020002000018000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005039
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: 4DC76A5CDD5B1363345-8018
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 992 941 591 BE HW: 992 941 591 B
Component: LED1L H08 9202
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 6889BBC852F9D64B273-803C
Address D7: Light Ctrl Right 2 (A27) Labels: None
Component: LED1R H08 9202
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
Address 8107: Antenna (J666) Labels:* None
Part No SW: 5WA 035 741 A HW: 5WA 035 741 A
Component: TrxModulHigh H10 0068
Serial number: 0000000004VILZ2
Coding: 02380011040080
ASAM Dataset: EV_TrxMLGEMQB37W 005006
ROD: EV_TrxMLGEMQB37W.rod
VCID: 42DD49601405DC1BD97-8016
End----------(Elapsed Time: 01:06, VBatt start/end: 14.1V/14.2V)-----------
Sunday,16,May,2021,12:54:35:41168
VCDS Version: Release 21.3.0 (x64) Running on Windows 8.1 x64
Address 17: Instruments Labels: None-SRI2
Control Module Part Number: 5H0 920 340 HW: 5H0 920 340
Component and/or Version: KOMBI 237 1400
Software Coding: 24A4000063840600018062032000080800300800
Work Shop Code:
ASAM Dataset: EV_DashBoardVDDMQB37W 002029 (VW38)
U1054 00 [009] - No Communication
[Audio_0x31 communication error bap_error_timeout heartbeat]
Reset counter: 171
Mileage: 5475 km
Date: 2021.02.22
Time: 00:37:25
16777020 - Control unit for information electronics 1
[TEL_0x28 communication error bap_error_timeout heartbeat]
Reset counter: 171
Mileage: 5475 km
Date: 2021.02.22
Time: 00:37:25
16777022 - Control unit for information electronics 1
[NAV_SD_0x32 communication error bap_error_timeout heartbeat]
Reset counter: 171
Mileage: 5475 km
Date: 2021.02.22
Time: 00:37:25
16777052 - Databus
Reset counter: 171
Mileage: 5475 km
Date: 2021.02.22
Time: 00:37:25
U1110 00 [009] - -
Reset counter: 171
Mileage: 5475 km
Date: 2021.02.22
Time: 00:37:28
