GOLF MK8 16777018 - Control unit for information electronics 1
   #21
So that problem is now solved... However, having driven the or 4 or 5 miles, as expected all the faults reset themselves, so the dashboard now shows no faults and everything is working completely as it should. I re-scanned after clearing all dtc's and it is still showing a range of errors, (still no errors on dashboard). Latest scan below... Any ideas?
Gggrrrr........ another auto-scan where the date/time stamp on DTC's is "less-than-accurate" (maybe the creeping contagion is COVID)!!
This is not a facetious question - but has anyone actually seen an auto-scan for a Golf mk8 that isn't DTC rich (I've had a quick look HERE)?
@invernesspl: I'm reminded of the African adage "the best way to eat an elephant is one bite at a time"!! Maybe deal with the hex75 module first, then try clearing DTCs again and start with a fresh auto-scan (noting any responses to my question above- of course)
   #22
HMC
C?ID=28246
I had an independent specialist come out today who had access to the VW main dealer tech. He programmed the used online services module and sorted out a few other issues which all went fine. However, the car still would not start! Scratched heads for quite some time but could not find a reason.
The fuel level had been low, but it said 30 miles remaining, so on the off chance I put 10L of fuel in and low and behold it started first touch of the button! So for some reason it had run out of fuel, even though the gauge said 30Miles range.
Wednesday,19,May,2021,19:56:22:41168
VIN: WVWZZZCDZLW037882   License Plate:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 75 A5 D6 D7
          8107
VIN: WVWZZZCDZLW037882   Mileage: 5484km-3407miles
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DPBA)       Labels: None
   Part No SW: 05E 906 012     HW: 05E 907 309 D
   Component: R4 1.5l TFS   H20 9971
   Revision: 8AH20000
   Coding: 011900322364150830080000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906012 002009
   ROD: EV_ECM15TFS01105E906012.rod
   VCID: 5CE1971896A18AEBB3B-8008
17156 - Databus
          U1123 00 [036] - Received Error Message
                    Mileage: 5484 km
                    Date: 2021.02.24
                    Time: 02:06:00
                    Engine RPM: 958.00 /min
                    Normed load value: 26.7 %
                    Coolant temperature: 97 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 13.320 V
                    Drive train coordinator irreversible switch off conditions: 0
                    Drive train coordinator reversible switch off conditions: 2164269056
                    Drivetrain coordinator: brake fault status: 0
34193 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
                    Mileage: 5476 km
                    Date: 2021.02.23
                    Time: 20:39:03
                    Engine RPM: 0.00 /min
                    Coolant temperature: 15 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 12.040 V
                    Drive train coordinator reversible switch off conditions: 2172682240
                    Drivetrain coordinator: brake fault status: 517
23765 - Control unit for information electronics 1
          U1054 00 [032] - No Communication
          [Information electronics control module 1No Communication]
                    Mileage: 5476 km
                    Date: 2021.02.23
                    Time: 20:39:03
                    Outside temperature: 18 °C
                    Absolute intake pressure: 101 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 6.0 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
4178 - Fuel Injection Malfunction
          P0148 00 [101] - -
                    Mileage: 5476 km
                    Date: 2021.02.23
                    Time: 22:36:01
                    Engine RPM: 782.00 /min
                    Normed load value: 89.4 %
                    Coolant temperature: 16 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.100 V
                    High fuel pressure: specified value: 14.036 MPa
                    Fuel high-pressure: actual value: 0.500 MPa
                    High fuel pressure: regulator output value: 15.2220 MPa
                    Low fuel pressure: specified value: 531.2 kPa
                    Fuel pump: specified value: 60.219 %
                    Low fuel pressure adaptation value for EFP: modeled: 120.0 kPa
                    Fuel: tank fill level: 13.0 l
Readiness: 0010 0001
   Part No SW: 5WA 614 517 AG    HW: 5WA 614 517 A
   Component: ESC           H09 0013
   Serial number: 60680000000600a
   Coding: 34FC2C9022234473527F900809C561862DB458F042D067C0019CA231218FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 007045
   ROD: EV_Brake1ESCEPBMQB37W_007_VW38.rod
   VCID: 0D47AA5C1DDB5363F45-8058
8519 - Implausible Data Received from Cruise Control Front Distance Range Sensor
          U0433 00 [040] - -
          [CCan_ACC_Anhalteweg_inv]
                    Reset counter: 0
                    Mileage: 5484 km
                    Date: 2021.02.24
                    Time: 02:06:01
8563 - Power Steering Control Module
          U101D 00 [040] - No Communication
          [CCan_EPS_BLW_QBit]
                    Reset counter: 2
                    Mileage: 5476 km
                    Date: 2021.02.23
                    Time: 20:39:04
          C1146 02 [040] - Signal Failure
          [DemSigIntegy]
                    Reset counter: 2
                    Mileage: 5476 km
                    Date: 2021.02.23
                    Time: 20:39:13
0294 - Steering Angle Sensor
          B1168 F2 [096] - Not Initialized
          [Swa_init_fail]
                    Reset counter: 2
                    Mileage: 5476 km
                    Date: 2021.02.23
                    Time: 20:39:03
4178 - Unknown Error Code
          U1657 00 [046] - -
          [Var_bmc_coding_timeout]
                    Reset counter: 0
                    Mileage: 5484 km
                    Date: 2021.02.24
                    Time: 02:20:26
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 5WA 959 436 B    HW: 5WA 959 436 B
   Component: Kessy IOBOX   070 0662
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003019
   ROD: EV_Kessy37w.rod
   VCID: 53F37C24FB7F4593621-8006
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 727 S    HW: 5WA 907 727 S
   Component: Climatronic   H01 0240
   Coding: 002100010211000000000000101010010000011000000000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005062
   ROD: EV_ACClimaBHBVW38X_VW38.rod
   VCID: 6099A3E8BAC9AE0BEF3-8034
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001310320230546502
   Part No SW: 5WA 937 086 Q    HW: 5WA 937 086 J
   Component: BCM 37W BOSCH 016 0136
   Serial number: BXJ53F030320940
   ASAM Dataset: EV_BCM37w 005001
   ROD: EV_BCM37w_005_VW38.rod
   VCID: 5F9BA01487B791F3D69-800A
   Subsystem 1 - Part No SW: 5H2 955 119     HW: 5H2 955 119
   Component: FWISCHER_MYJT  003 0041
   Serial number: 907353F0402003401820
   Subsystem 2 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS            054 0206
   Serial number: S5Y20M06D30H19M19S16
   Subsystem 3 - Part No SW: 5H0 941 193 AF    HW: 5H0 941 193 AF
   Component: LiSi           H05 0007
   Serial number: 92471TFG000NN
   Subsystem 4 - Part No SW: 5H0 925 200 P    HW: 5H0 925 200 P
   Component: DiETa          H06 0007
   Serial number: 92471TCI000XJ
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000001071666
   Subsystem 6 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA    005 0316
   Serial number: 000000000ZY201350VM3
   Subsystem 7 - Part No SW: 5H0 959 561 H    HW: 5H0 959 561 H
   Component: DACHKONSOLE    006 0006
   Serial number: 92413TF300329-------
   Steering Column Switch:
   Subsystem 8 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000019062004221646
   Part No SW: 5WA 919 294 A    HW: 5WA 919 294
   Component: PDC 08 Kanal  H04 0022
   Serial number: 000005032094630
   Coding: 0040010001
   ASAM Dataset: EV_EPHBO18VW3800000 002028
   ROD: EV_EPHBO18VW3800000_VW38.rod
   VCID: 50F97328CA693E8B5F3-8004
   Part No SW: 5WA 907 572 A    HW: 5WA 907 572
   Component: ACC Bosch MQB H10 0246
   Coding: 010310750007404512474000000040054E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
   ROD: EV_FRONTRADARBOSCHVW380_003.rod
   VCID: 4CC1675826411A6B23B-8018
1560 - Databus
          U1122 00 [044] - Implausible Message
          [FAULT_VMM_INCONSISTENCY_ACC]
                    Mileage: 5484 km
                    Date: 2021.02.24
                    Time: 02:13:43
   Part No SW: 5WA 959 655 A    HW: 5WA 959 655 A
   Component: AirbagVW40    007 0523
   Serial number: 000000003C0DKR6
   Coding: 88CC000000C0C000000000000000000051540000205400004000F68000930065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001028
   ROD: EV_AirbaVW40SMEVW38X_VW38.rod
   VCID: 55F7823CF58B5BA38C5-8000
   Subsystem 1 - Part No SW: -----------    HW: 480 400 406 20
   Component: SideSensor_Dr  002 6149
   Serial number: 351000110636E893546W
   Subsystem 2 - Part No SW: -----------    HW: 480 400 406 20
   Component: SideSensor_Pr  002 6149
   Serial number: 352000110636E892A1E%
   Subsystem 3 - Part No SW: -----------    HW: 480 000 303 20
   Serial number: 3570000000089385C54Q
   Subsystem 4 - Part No SW: -----------    HW: 480 000 403 20
   Serial number: 358000000007FB5D264-
   Subsystem 5 - Part No SW: -----------    HW: 480 400 206 20
   Component: FrontSensor_D  002 614A
   Serial number: 35500011E62FB985D49P
   Part No SW: 5H0 920 340     HW: 5H0 920 340
   Component: KOMBI         237 1400
   Coding: 24A4000063840600018062032000080800300800
   ASAM Dataset: EV_DashBoardVDDMQB37W 002029
   ROD: EV_DashBoardVDDMQB37W_002_VW38.rod
   Part No SW: 5WA 907 530 C    HW: 5WA 907 530 C
   Component: GW2020 High   752 7070
   Revision: --------    Serial number: 150160900253139
   Coding: 0000808D0F00000000000000010301315301600900000300030100000001010000000000000000000000000000000000
   ASAM Dataset: EV_GatewMQB2020 004003
   ROD: EV_GatewMQB2020_VW38.rod
   VCID: 48C95B483239F64B073-801C
   Generator:
   Component: 2-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 9441964305
   Subsystem 3 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036038203530
2097338 - Unknown Error Code
          U1646 00 [044] - -
          [Antenna_control_module_1_no_communication_vlan]
                    Mileage: 5484 km
                    Date: 2021.02.24
                    Time: 02:20:07
   Part No SW: 5WA 909 059 E    HW: 3Q0 909 059 A
   Component: EBKV          H06 0092
   Serial number: BPA085070320013
   Coding: 1002C140730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 011021
   ROD: EV_BrakeBoostG2BoschVW37W_011_VW38.rod
   VCID: 52FD7920C4654C9B697-8006
16 Faults Found:
106576 - Control Module for Brake Electronics
          U0129 00 [032] - No Communication
          [ComScl_ESC_50_Timeout]
106592 - Control Module for Brake Electronics
          [ComScl_ESC_51_Timeout]
106608 - Brake Control Module
          U12DC 00 [032] - Received Malfunction Message
          [Scl_ESC_51_ESC_aktBr_Volumenstrom_Error]
106752 - Brake Control Module
          [Scl_ESC_51_ESC_Bremsdruck_02_Error]
106816 - Brake Control Module
          [Scl_ESC_50_ESC_Raddruck_max_Invalid]
106832 - Brake Control Module
          [Scl_ESC_50_ESC_Raddruck_max_Error]
107584 - Control Module for Brake Electronics
          [ComScl_ESP_21_Timeout]
107600 - Brake Control Module
          [Scl_ESP_21_ESP_v_Signal_Error]
107616 - Brake Control Module
          [Scl_ESP_21_ESP_v_Signal_Invalid]
108336 - Brake Control Module
          [Scl_ESC_50_EPB_Status_02_Error]
172048 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
          [RBNET_Undervoltage_Replacement]
                    Reset counter: 36
                    Mileage: 5476 km
                    Date: 2021.02.23
                    Time: 22:32:02
172400 - System Voltage
          P0562 00 [032] - Too Low
          [PSCUnderVoltageLevel1]
172416 - System Voltage
          [PSCUnderVoltageLevel2]
172544 - System Voltage
          [PSCUnderVoltageShutDownLevel]
369232 - Control Module Improper Shut Down
          U3001 00 [047] - -
435568 - Unknown Error Code
          P06B8 00 [044] - -
          [Not_ShutDown_Right_NvMWriteError]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H08 0040
   Serial number: 20000075674011
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 323D19A0A4A56C9B497-8066
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TBJ1172E
   Coding: 003B02208001040000001000
   VCID: 49CF5E4C29330F4318D-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 C    HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000038968373
   Coding: 0D0000
   Part No SW: 5WA 907 144 H    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  101 1030
   Serial number: 00087955
   Coding: 0000000000000000000102010100010000000101010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 006037
   ROD: EV_SteerAssisBASGEN1MQB37_006.rod
   VCID: 4EC56D50D05D287B4DF-801A
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TBH14667
   Coding: 003B00208C01040000801000
   Subsystem 1 - Part No SW: 5Q0 959 408 C    HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000039029901
   Coding: 150000
   Part No SW: 5H0 035 816     HW: 5H0 035 816
   Component: MU-O-ND-EU    H56 1664
   Serial number: WG8LGM190220000
   Coding: 23800008000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_VW38.rod
   VCID: 6491AFF8AED1B22B0BB-8030
   No subsystems:
   Subsystem 2 - Part No SW: V03 959 806 MG    HW: -----------
   Component: EU 2019/30     --- 202
   Part No SW: 5WA 035 284 A    HW: 5WA 035 284 A
   Component: OCU3HMQB37W   H12 0067
   Serial number: 0000000912VIVR4
   Coding: 023800009068A8209405460071002607
   ASAM Dataset: EV_OCU3HMQB37W 001039
   ROD: EV_OCU3HMQB37W_001_VW38.rod
   VCID: 44D14F780E11D22BEBB-8010
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H05 3127
   Serial number: E26735111201700
   Coding: 0000090821484040409E00001020002000018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005039
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   VCID: 4DC76A5CDD5B1363345-8018
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 992 941 591 BE    HW: 992 941 591 B
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 6889BBC852F9D64B273-803C
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H08 9202
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 A    HW: 5WA 035 741 A
   Component: TrxModulHigh  H10 0068
   Serial number: 0000000004VILZ2
   Coding: 02380011040080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: 42DD49601405DC1BD97-8016
End----------(Elapsed Time: 01:13, VBatt start/end: 12.3V/12.3V)-----------
I suspect start up for the next journey was blocked to stop air getting into the injection system, how long had the low fuel warning been on?
Regards HMC
   #23
invernesspl
C?ID=345478
Regards HMC
The fuel was low when I got the car, it said 30miles remaining.
It was driving fine and just cut out on the way to get fuel. Wouldn't restart. I put 5L in at first, and it still wouldn't start.
It only started when I put a further 10Litres in.
No idea why it would say there was 30 miles remaining. And if this is a characteristic of the new golf, I suspect it will catch a number of people out. Especially because most people would only have a 5L fuel can which won't be enough to start the car.
   #24
HMC
C?ID=28246
" suddenly it's now decided that it will not start" and " so on the off chance I put 10L of fuel in and low and behold it started first touch " .
Exactly what happened is crucial to anyone trying to assist in any thread. Many times I have seen pages of responses only to find that information provided at the end could have resolved the issue at the start.
I am not having a go at you just hoping that everyone are concise in their postings.
Regards HMC
p.s. Ford used to make the engine management "shake " the car when fuel was getting critical.
