2010 Q5 3.2 SAI pressure sensor test
TheMadAngler
Sacramento, CA, USA
C?ID=437208
Does anyone know the procedure on how to test if the SAI pressure sensor is working properly? I'm assuming doing an ohm check or signal check but I don't know what values to look for and I am not finding a procedure in erWin unless am not looking in right place for it.
Any advice is much appreciated.
South Molton, UK
Since we have no idea what car you are working on it's pretty difficult (virtually impossible) to answer your question.
The solution? - post a full unedited VCDS Auto-Scan of your car :thumbs:
Actually, it's in the thread title, "2010 Q5 3.2", but an Auto-Scan would show us exactly what ECU and engine management it uses. :)
South Molton, UK
That's what happens when I type a reply before I've had my first coffee in the morning :cool:
TBH, I've also occasionally missed stuff that was in the tile rather than the body of the post.
TheMadAngler
Sacramento, CA, USA
C?ID=437208
Here you go. I am working on the P0491/0492 codes. I have already cleaned the carbon out of the cylinder heads. The pump is putting out plenty of airflow all the way to each combi valve.. Manually activated the combi valves with a vacuum pump and they appear to be working fine. Still getting insufficient airflow codes.
I am sure you'll be able to tell, but this scan was done while the car was in service ready position. This was after I had cleaned out the cylinder head carbon, performed readiness check, and got the codes again, so I parked it and tore it back down.
Wednesday,17,March,2021,20:28:05:09997
Data version: 20210226 DS325
VIN: WA1LKAFP5AA080984   License Plate:
Mileage: 181630km-112859mi   Repair Order:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
          6D 72 77
VIN: WA1LKAFP5AA080984   Mileage: 181630km-112859miles
Address 01: Engine (J623-CALB)       Labels:| 06E-907-559-CAL.clb
   Part No SW: 8R0 907 559 G    HW: 8F0 907 559 A
   Component: 3.2 SIMOS8.2  H06 0004
   Revision: --------
   Coding: 0121000A190F0121
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
   ROD: EV_ECM32FSI0218R0907559G.rod
   VCID: 44D14665FE19AFFBEBB-8010
6122 - Fuel/Air Mixture Cylinder 1
          P219C 00 [040] - Unbalanced
                    Mileage: 181594 km
                    Date: 2021.03.12
                    Time: 19:46:30
                    Engine RPM: 705.00 /min
                    Normed load value: 22.4 %
                    Coolant temperature: 89 °C
                    Intake air temperature: 63 °C
                    Voltage terminal 30: 13.710 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 103.49411 mg/stroke
                    Coolant temperature (unfiltered): 93.0 °C
                    Engine: operating status: IS
                    Engine load: 19.140625 %
                    Vehicle speed: actual: 0 km/h
8931 - Secondary Air Injection System: Bank 1
          P0491 00 [232] - Insufficient Flow
                    Mileage: 181600 km
                    Date: 2021.03.13
                    Time: 09:40:15
                    Engine RPM: 1327.00 /min
                    Normed load value: 32.9 %
                    Coolant temperature: 8 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 13.101 V
                    Engine speed: actual: 1312 /min
                    MAF_ENVD: 272.35293 mg/stroke
                    Coolant temperature (unfiltered): 9.8 °C
                    Battery voltage: 12.898438 V
                    STATE_LS_ENVD[1]: 2
8932 - Secondary Air Injection System: Bank 2
          P0492 00 [232] - Insufficient Flow
                    Mileage: 181600 km
                    Date: 2021.03.13
                    Time: 09:40:15
                    STATE_LS_ENVD[1]: 2
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8R0 927 158 F    HW: 0B6 927 156
   Component: 0B6 32 FSIUSA H05 0005
   Revision: --H05---
   Coding: 001012
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 40D94A75EA01B3DBCF3-8014
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
   Component: ESP8 quattro  H06 0020
   Coding: 041D18
   VCID: 4ACD685DDCBD798B117-801E
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 169
                    Mileage: 181594 km
                    Date: 2021.03.12
                    Time: 19:54:49
                    Hex Value: 0x00C0
                    Hex Value: 0x4782
                    Hex Value: 0x0016
                    Hex Value: 0x02A7
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
   Component: BCM2 1.1      H02 0327
   Coding: 090500
   VCID: 04518665BE196FFBABB-8050
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0510000003165003
   Serial number: 0210000010861013
   Part No SW: 8T1 820 043 AK    HW: 8T1 820 043 AK
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01080220100137
   Coding: 46012000
   VCID: 7AADF89DCCDD290BC17-802E
                    Reset counter: 164
                    Mileage: 181480 km
                    Date: 2021.02.14
                    Time: 22:23:29
                    Reset counter: 72
                    Mileage: 151747 km
                    Date: 2019.04.13
                    Time: 20:38:37
                    Temperature: 28.0°C
                    Fault Status: 01101000
                    Reset counter: 164
                    Mileage: 181480 km
                    Date: 2021.02.14
                    Time: 22:23:29
                    Temperature: 12.0°C
                    Reset counter: 204
                    Mileage: 181498 km
                    Date: 2021.03.09
                    Time: 08:33:33
                    Temperature: 11.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 0.0 bar
                    RPM: 1320 /min
                    Current: 0.000 A
                    Temperature: 7.0°C
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000459834
   Coding: 26001091063CAF010000080300001D0D0F1C460802010161000000
   VCID: 3C213E858669D73B93B-8068
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 100203  H10 0041
   Serial number: 90243014100202015344
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10779436
   Coding: 024D25
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000402101833
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
8 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 00101100
                    Reset counter: 192
                    Mileage: 181498 km
                    Date: 2021.03.08
                    Time: 18:19:00
                    Reset counter: 192
                    Mileage: 181498 km
                    Date: 2021.03.08
                    Time: 18:19:00
                    Reset counter: 197
                    Mileage: 181483 km
                    Date: 2021.03.07
                    Time: 23:10:00
                    Reset counter: 196
                    Mileage: 181483 km
                    Date: 2021.03.07
                    Time: 23:10:00
01853 - Heated Seat; Left Front (Z45)
                    Fault Status: 01101100
                    Reset counter: 13
                    Mileage: 178541 km
                    Date: 2020.11.18
                    Time: 17:28:00
03020 - Local databus 2
                    Reset counter: 195
                    Mileage: 181518 km
                    Date: 2021.03.09
                    Time: 13:25:00
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 164
                    Mileage: 181481 km
                    Date: 2021.03.07
                    Time: 22:52:00
                    Reset counter: 155
                    Mileage: 151747 km
                    Date: 2019.04.13
                    Time: 20:38:00
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 D    HW: 8R0 959 655 D
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003FRD059MDL
   Coding: 303633313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 45D75B61F52396F3FC5-8010
   Subsystem 1 - Part No SW: 8R0 959 339     HW: 8R0 959 339
   Serial number: 5810000R0900005VEQ
   Serial number: 6334MSME4F443332B
   Serial number: 6344MSME5114193B9
   Serial number: 6352QSME3D4E4C3E1
   Serial number: 6362QSME4E4E0834T
   Serial number: 63732SME144F4A04+
   Serial number: 63832SME514E532E5
9443859 - Driver's Front Airbag Crash Sensor
          B101A 15 [136] - Open or Short to Plus
                    Mileage: 181480 km
                    Date: 2021.02.14
                    Time: 22:23:26
9444115 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [136] - Open or Short to Plus
                    Mileage: 181480 km
                    Date: 2021.02.14
                    Time: 22:23:26
   Revision: --------    Serial number: 90315JB8000DN
   Coding: 000017
   VCID: 3D2733819D73DE33A45-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 950 B    HW: 8R0 920 950 B
   Component: KOMBIINSTR.   H11 0255
   Revision: 00100000    Serial number: CJE41T02A
   Coding: 8B1622000300D705020000
   VCID: 35372BA1A54306736C5-8060
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0105
   Revision: GB600050    Serial number: 5000G102028288
   Coding: 00C303
   VCID: 50F97A353AE1435B5F3-8004
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140971878
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0280
   Revision: 00000000
   Coding: 020302
   VCID: 392F2791895BE21388D-806C
   Part No SW: 8R0 959 760 B    HW: 8R0 959 760 B
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001010071528
   Coding: 00581300000044440000
   VCID: 40D94A75EA81B3DBCF3-8014
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000010098423
   Coding: 011D03205E00440004
   VCID: 45D75B61F5A396F3FC5-8010
   Revision: 00002001    Serial number: 0126474748
   Coding: 0126023A207A749404B0053200000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000219709
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H01 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H01 0220
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
   Component: DSP STD       H11 0440
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 2F3B19C9471F3CA3269-807A
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000010100010
   VCID: 44D14665FE99AFFBEBB-8010
                    Fault Frequency: 22
                    Reset counter: 161
                    Mileage: 174896 km
                    Date: 2020.09.04
                    Time: 11:24:43
   Revision: 00000003    Serial number: 10000000430797
   VCID: 343116A5AE391F7B5BB-8060
                    Fault Status: 11101101
                    Reset counter: 149
                    Mileage: 181480 km
                    Date: 2021.02.14
                    Time: 22:23:27
                    Voltage: 12.10 V
                    Count: 80
                    Hex Value: 0x02E0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No: 8K0 907 357 B
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 343116A5A2391F7B5BB-8060
                    Fault Status: 00101010
                    Reset counter: 189
                    Mileage: 181480 km
                    Date: 2021.03.07
                    Time: 16:18:58
                    Reset counter: 192
                    Mileage: 181480 km
                    Date: 2021.03.07
                    Time: 16:18:58
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H06 0351
   Revision: 00000008    Serial number: AUZ5Z6J1350808
   Coding: 040200020105850043D9070800
   VCID: 46D55C6DC8A59DEBF5F-8012
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
                    Fault Frequency: 12
                    Reset counter: 209
                    Mileage: 179730 km
                    Date: 2020.12.21
                    Time: 08:14:51
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Reset counter: 155
                    Mileage: 154801 km
                    Date: 2019.06.28
                    Time: 15:18:33
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000102854164
   Coding: 010C03204000240004
   VCID: 42DD407DE48DA1CBD97-8016
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H27 0300
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B233D998367D0039A1-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H27 0300
   Serial number: 8R0827852B
   Revision:             Serial number: 0000102854139
   Part No SW: 8T0 862 336 D    HW: 8T0 862 336 D
   Component: FSE_256x BT     H39 0600
   Revision: 00000000    Serial number: 00000005069511
   Coding: 0010370
   VCID: 3C213E858A69D73B93B-8068
End----------(Elapsed Time: 02:00, VBatt start/end: 14.6V/14.6V)-----------
I'm not finding anything for such a sensor in the data for that ECU... :confused:
All I've come across is the Basic Setting:
IDE00747 -- Secondary air injection system check
...but given the fault code you've got there, I assume that test will fail.
