clarification on scan meanings
RWDYAUDI
Canada
C?ID=276357
Vehicle scanned is a 2016 touareg. are these codes active or is the meaning "Tested since cleared" mean they been resolved?
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 3C 42 46 52 53 55 56 5F
          62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEF9BPXGD011444   Mileage: 95112km-59099miles
Address 01: Engine (J623-CGRA)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 CQ    HW: 03H 907 309 E
   Component: VR6 3.6l FSI  H17 5598
   Revision: M7H17---
   Coding: 002A0012437600000000
   Shop #: WSC 93363 999 00000
   ASAM Dataset: EV_ECM36FSI01103H906023CQ 002005
   ROD: EV_ECM36FSI01103H906023CQ.rod
   VCID: 73E5A94BDAB50A1E06-8026
4012 - Cold Start Idle Air Control System
          P050A 00 [096] - Malfunction
                    Mileage: 94357 km
                    Date: 2021.03.27
                    Time: 10:12:06
                    Engine speed: 976.00 /min
                    Normed load value: 78.8 %
                    Coolant temperature: 4 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 13.735 V
                    Unlearning counter according OBD: 11
                    Leakage recognition from oxygen sensor control: 0.9690
                    Misfire sum counter: 76
                    Leakage air: 3.2 kg/h
                    Long term adaptation of throttle valve for mass air flow sensor: 0.98010
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
10591 - Cylinder 1
          P0301 00 [096] - Misfire Detected
10595 - Cylinder 5
          P0305 00 [096] - Misfire Detected
10593 - Cylinder 3
          P0303 00 [096] - Misfire Detected
Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
   Part No SW: 0C8 927 755 F    HW: 0C8 927 755
   Component: AL1000 AISIN  130 2885
   Coding: 010200000C008400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 34676A579F3B4D26DF-8060
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 42845441729133
   Coding: 5B7613C349256F54DAF8C89792D6F6607301
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4C9712B7E7CB35E6A7-8018
   Part No SW: 4H0 907 064 GK    HW: 4H0 907 064 GK
   Component: BCM2 2.0      H37 0572
   Coding: 0D860016000000000000
   VCID: 78FF9E67CBD3694633-802C
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3216000000432006
00956 - Key 2
                    Reset counter: 249
                    Mileage: 94892 km
                    Date: 2021.04.17
                    Time: 08:28:51
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CK    HW: 7P6 907 040 CK
   Component: Klima 2 Zonen H23 1507
   Coding: 4686000880
   VCID: 7F0D757BE6FD5E7E72-802A
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 22020001    Serial number: 00001266490201
   Coding: 26000096D63C5D010020480300005D4C431C660822014241000000008040110000000000000000
   VCID: 6ADBB42F857FCBD6B5-803E
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    151125  033 0021
   Serial number: 90243400160108180425
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 80747302
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AC    HW: 7P6 941 431 AC
   Component: E1 - LDS  H02 0040
   Serial number: 00000000002001160547
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28231601207161
   Coding: 318D04
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44873A97CF9BFDA66F-8010
   Part No SW: 7P6 907 561 C    HW: 7P6 907 561
   Component: ACC3          H21 0400
   Coding: 3701010101
   ASAM Dataset: EV_AdaptCruisContrVW526 002012
   ROD: EV_AdaptCruisContrVW526_002.rod
   VCID: 3C774277B76B856617-8068
11264 - Sensor for Automatic Distance Regulation
          C110B 49 [008] - Internal electronic failure
                    Reset counter: 250
                    Mileage: 95006 km
                    Date: 2021.04.20
                    Time: 17:09:03
                    Control Module temperature: 7 °C
                    Voltage terminal 15: 12.985 V
                    Velocity_vehicle_reference: 1.83 m/s
                    Longitudinal_acceleration_vehicle_reference: 2.06 m/s²
92416 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 250
                    Mileage: 95006 km
                    Date: 2021.04.20
                    Time: 17:09:00
                    Voltage terminal 15: 11.966 V
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 F    HW: 7P0 959 655 F
   Component: VW10Airbag029 H10 0044
   Revision: --------    Serial number: 003S8002HWGK
   Coding: 000000000000000000000000000000003239
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R159030NN20
   Serial number: 3575LRB40593O05QB10
   Serial number: 3585LRB405L3NOK0BGOG
   Serial number: 3517ARB40553NM3QF8U-
   Serial number: 3527ARB40553NM3QCHMZ
   Serial number: 3557BRB405T3OFIE496S
   Serial number: 3567BRB405T3OFIE70V5
   Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AJ
   Component: Lenks.Modul   H06 0010
   Revision: --------    Serial number: 01374OLR0002B
   Coding: 000CDD
   VCID: 3D714F73A4718C6E20-8068
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0112770 TRW 20151110
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 883 F    HW: 7P6 920 883 F
   Component: Kombi         H13 0515
   Revision: 13240304    Serial number: 658050116592022
   Coding: 0B0732026F080008020004
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 41893383D089E88E44-8014
   Part No SW: 7P6 907 530 N    HW: 7P6 907 530 G
   Component: GW-CAN-L-FR-M H13 6042
   Revision: --------    Serial number: 00000002101878
   Coding: 0021035600
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 4385398BCA95FA9E56-8016
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 32349J11015701198698
   Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
   Component: SWA Master    H08 0030
   Serial number: 0392792270
   Coding: 030221
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3F8D357BA67D9E7E32-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0030
   Serial number: 0391750646
   Coding: 030221
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H03 0306
   Revision: --------    Serial number: 0000183125154
   Coding: 011D17200000453005080001
   VCID: 7AFB846FF5DF7B5645-802E
   Revision: 00002001    Serial number: 0387262402
   Coding: 0187123A68B9101580B00620210A18000000000000000000000000000000
   Subsystem 2 - Part No SW: 7P0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS30.408  H03 0004
   Serial number: 0000FST000QY92Z00000
   Coding: 191100
   Subsystem 3 - Part No SW: 7P0 959 591 E    HW: 8V3 959 591 A
   Component: J394 PS30.408  H03 0004
   Serial number: 0000FST000QDJ2O00000
   Coding: 191100
   Subsystem 4 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65048813
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H03 0306
   Revision: --------    Serial number: 0000183325226
   Coding: 011D17200000453005080000
   VCID: 489F2EA7FBB3D9C683-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C15C1001116
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 3663505F89475F36E1-8062
   Slave 3:
0051 - No Calibration
          B2010 F0 [008] - Deviation From Expected Range
                    Reset counter: 209
                    Mileage: 95002 km
                    Date: 2021.04.20
                    Time: 13:36:14
                    Voltage: 13.4 V
0052 - Parking Brake Motor; Right
          C10BD 07 [008] - Mechanical Failure
                    Reset counter: 249
                    Mileage: 95002 km
                    Date: 2021.04.20
                    Time: 13:35:36
                    Voltage: 12.6 V
0003 - Function Restriction
          B2008 F0 [008] - due to Over-Temp Protection
                    Reset counter: 249
                    Mileage: 95002 km
                    Date: 2021.04.20
                    Time: 13:36:27
                    Voltage: 13.0 V
   Component: AFS-ECU       H01 0110
   Coding: 012A02010B000400
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B00000
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156AW0G2532636
   Coding: 020007020100000001
   VCID: 24479A1727DBDDA64F-8070
   Part No SW: 7P6 035 664 L    HW: 7P6 035 664 A
   Component: H-BN-NA       H41 0954
   Revision: --------    Serial number: 606A-0G7517461
   Coding: 010200050040E9EF39002B0E00000003F00001030000000000
   VCID: 41893383D889E88E44-8014
   Subsystem 1 - Part No: 7P6 060 884 D
   Component: NAR 2016  1302
   Subsystem 2 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9RGG007YH
   Subsystem 3 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: CD-Database  6890
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H04 0306
   Revision: --------    Serial number: 0000183480452
   Coding: 011C17200000253005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 40000000033676
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   VCID: 45812793C4A1C4AE78-8010
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H20 0160
   Revision: 7C001003    Serial number: 0390121958
   Coding: 0200000200000000
   ROD: EV_TrailFunctGener2Hella_VW52.rod
   VCID: 377D5D5B8E4DA63EFA-8062
   Part No SW: 7P6 980 556     HW: 7P6 980 556
   Component: RVC Compact   H08 0160
   Coding: 0125060123002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAVW526 001001
   ROD: EV_CamSysRVRVCPANAVW526.rod
   VCID: 7EF3887FE1F7577679-802A
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 004600559
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H04 0306
   Revision: --------    Serial number: 0000183485926
   Part No SW: 7P6 907 217 B    HW: 7P6 907 217
   Component: DPC-SG        H26 0035
   Coding: 69020000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 39795B63B859B04E0C-806C
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000007067179_3110
   Part No SW: 7P6 907 541 C    HW: 7P6 907 541
   Coding: 3701010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 002011
   ROD: EV_AdaptCruisContr2VW526_002.rod
   VCID: 3A7B446FBD5FBB5605-806E
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 B    HW: 7P6 907 107
   Component: BV-SG         H33 0035
   Serial number: 005000012212157
   Coding: 0AA118040000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
End-------------------------(Elapsed Time: 06:14)--------------------------
Not really either. "Tested since cleared" means conditions under which this fault can be detected have been met at least once since the last time faults were cleared. That does not imply the fault condition currently exists. In fact, "Intermittent - Not Confirmed" implies it doesn't. I would clear them and watch if or how quickly and under what conditions any of them return.
RWDYAUDI
Canada
C?ID=276357
thanks for the quick reply. i know it just had brakes and coils done. which can explain the brake and engine module codes lingering around. what i was concerned was about the sensor that regulates the distance. i test drove it and didnt see and malfunction warnings. everything did seem normal but im new to the touareg family so might of been looking in the wrong spot. im going back wed. to shuffle through the menu a bit better
Those faults seem to be ubiquitous in the ACC sensors used in Touaregs, but they appear to have no functional detriment. We have a 2015 ourselves, and Dana has a 2016. Both of them have faults in the ACC sensor almost exactly like yours. You can clear those faults, but they will eventually come back, so it seems they are spurious.
MasterTommy
Amsterdam
C?ID=295586
Arent those codes similar to the onces that a radar sensor or front camera on a MQB car stored when the visibility is impaired, for example during heavy rain/snow, or driving through a tunnel with too many reflecting radar signals? In those cases you also get a notice in the dash (but the system will reactivate after driving some time of unimpaired visibility).
