Need fault code interpretation for a 15 Q7 (ECS, TPMS, ABS fault)
TheAudiGuy
Houston, TX, USA
C?ID=222387
I had started a thread on AudiWorld about the situation. Need some help interpreting the fault codes. Have ESC, ABS, TPMS, and Brake light on. I suspect battery since voltage draws seem to be low to modules especially the wheel speed sensor? This may be the first or second time in 5 years using a scan on the vehicle. Had been mostly using scans on my A6 C6 platform vehicle.
Friday,14,May,2021,13:53:39:06855
VCDS Version: 21.3.0.0 (x64)
VIN: WA1WMAFEXFD015639 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72
VIN: WA1WMAFEXFD015639 Mileage: 65690km-40817miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI EDC17 H23 0007
Revision: 54H23--- Serial number:
Coding: 2A2A4012253600050000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L2910401A 001008
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 224BF69535D5369BF5-8076
5453 - Starter Relay
P3088 00 [096] - Electrical Malfunction
5456 - Starter Will Not Turn
P3054 00 [096] - Jammed or Electrical Malfunction
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [044] - -
Mileage: 63869 km
Date: 2021.04.16
Time: 19:34:00
Engine RPM: 0.00 /min
Coolant temperature: 12 °C
Intake air temperature: 14 °C
Voltage terminal 30: 10.920 V
Cruise Control System (CCS): status-Bits 0-7: 47
selected gear-Bits 0-7: 0
17262 - Terminal 30
U140A 00 [032] - Open Circuit
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 002 2454
Coding: 001378
Shop #: WSC 03206 002 1048576
ASAM Dataset: EV_TCMAL991031 002114
ROD: EV_TCMAL991031_002.rod
VCID: 7BF5EBF1F2FFA75396-802E
12835 - Implausible Data Received from ABS Control Module
U0415 00 [008] - -
Reset counter: 197
Date: 2013.02.27
Time: 00:00:11
Engine RPM: 1410.0 /min
Transmission input speed: 1020 /min
Transmission output speed: 360 /min
Engine torque: 104 Nm
ATF temperature: 78 °C
Accelerator pedal position: 19.6 %
Clutch_C1: closed
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
EOP target revolution: 65534 /min
EOP actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
EOP failure status with EOP without HV 1: Motor normal stop
EOP target current: 65278 mA
12837 - Implausible Data Received from ABS Control Module
U0415 00 [008] - -
Reset counter: 197
Date: 2013.02.27
Time: 00:00:11
Engine RPM: 810.0 /min
Transmission input speed: 780 /min
Engine torque: 32 Nm
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099441
VCID: 346700CD5721A82B17-8060
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 33
Mileage: 63869 km
Count: 192
Count: 833
Count: 38
Count: 39424
Reset counter: 32
Mileage: 63869 km
Date: 2021.04.16
Time: 19:34:00
Count: 192
Count: 833
Count: 128
Count: 38912
Fault Status: 00100011
Reset counter: 39
Mileage: 65124 km
Date: 2021.05.14
Time: 07:42:30
Count: 8195
Count: 75
Count: 50432
Reset counter: 254
Mileage: 64060 km
Count: 192
Count: 833
Count: 86
Count: 41984
Reset counter: 254
Mileage: 65124 km
Date: 2021.05.14
Time: 07:35:39
Count: 320
Count: 8259
Count: 73
Count: 47104
00814 - Solenoid for Brake Pressure (N247)
Fault Status: 01101100
Reset counter: 254
Mileage: 61603 km
Count: 128
Count: 833
Count: 99
Count: 40192
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902184301
Coding: 0000135
VCID: 2541ED89ECFBC1A390-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H05 0020
Component: FBSAUDIC6 KSG H03 0020
00191 - Passenger's Door Handle Touch Sensor (G416)
Fault Status: 00110111
Reset counter: 38
Reset counter: 38
Mileage: 64036 km
Date: 2021.05.13
Time: 15:42:47
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Revision: 00---031 Serial number: 00000000461021
Coding: 0304A036
VCID: 2541ED892CFBC1A390-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0132731213
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0132730159
Coding: 070000
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Coding: 0133123
VCID: 6ED3D2A5798DC2FB21-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931501600240
Coding: 29011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 346700CD9F21A82B17-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD90HCLN
Coding: 0014131
VCID: 2B551BB18A1FF7D346-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME514C1462A
Subsystem 3 - Serial number: 6342QSME544C4874O
Subsystem 4 - Serial number: 6352QSME154D0E56P
Subsystem 5 - Serial number: 6362QSME514C0948L
Subsystem 6 - Serial number: 63734SME7C4B5358D
Subsystem 7 - Serial number: 63834SME7C4B307CF
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026143570090
Coding: 0012142
VCID: 285FE4BD9BE9DCCBAB-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2S02EV1G
Coding: 8BD664040900CF05020205
VCID: 428B5615DD95169B95-8016
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M151250664
Coding: 00C303
VCID: 3F8D5FE1AE677B73FA-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 42014N47244121322106
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Revision: 00---011 Serial number: 00000030368670
Coding: 0000006
VCID: 68DFA4BD5B691CCB6B-803C
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000130217561
Coding: 00581B00000011110000
VCID: 326B06D56D35A61B05-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E5312A5B90D82FB61-807A
Component: J0770_SWA_Slave_H03 0050
Subsystem 3 - Serial number: 5F22.01.1500H03000AMS14246ÿ
Subsystem 4 - Serial number: S14246ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000134179191
Coding: 011F57205E40440004
VCID: 489F443DFBA93CCB4B-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82009800020000
Coding: 3569949
VCID: 387F34FD4B494C4B3B-806C
Reset counter: 28
Mileage: 63321 km
Date: 2021.04.11
Time: 13:04:20
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000067934
Coding: 030000
VCID: 2959E1B940E3E5C3B4-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191084064
Coding: 0758477
VCID: 2345F391E2CF3F93FE-8076
01679 - ABS Wheel Speed Signal; Front Left
Fault Status: 11101100
Reset counter: 245
Mileage: 63114 km
Date: 2021.04.11
Time: 11:08:01
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0007
Voltage: 14.60 V
Temperature: 13.0°C
(no units): 54.0
01680 - ABS Wheel Speed Signal; Front Right
Fault Status: 00101100
Reset counter: 29
Mileage: 63711 km
Date: 2021.04.11
Time: 17:21:29
Hex Value: 0x8000
Hex Value: 0x0000
Hex Value: 0x005F
Voltage: 14.10 V
Temperature: 18.0°C
(no units): 112.0
Fault Status: 00101101
Reset counter: 39
Mileage: 63108 km
Date: 2021.04.11
Time: 09:52:31
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 11.10 V
Temperature: 10.0°C
(no units): 0.0
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000210845
Coding: 0012001
VCID: 5EB38265892D527B91-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000134188175
VCID: 479D4701F6B733B342-8012
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Coding: 0000031
Reset counter: 254
Mileage: 65666 km
Date: 2021.05.14
Time: 13:03:37
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156AZ0F8186611
Coding: 020007010000000000
VCID: 2447F08D27C138AB87-8070
Part No SW: 4L2 035 746 G HW: 4L2 035 746 G
Component: H-BNT-NA H42 0901
Revision: -------- Serial number: 513AT0F7509241
Coding: 180200060004E3EF510023456F632003140000000100000000
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Component: DU7 High H42 0104
Serial number: A130AQ0F3245664
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002226323
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000134983521
Coding: 010E57204040230004
VCID: 46834A05F1BD2ABBB9-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000358613333
Coding: 0200000000000000
VCID: 316909D968339D037C-8064
Reset counter: 29
Mileage: 63367 km
Date: 2021.04.11
Time: 13:39:26
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0199717
Coding: 020C010001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6ED3D2A5B18DC2FB21-803A
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD7D8AD4F9130EB0F-8038
Subsystem 3 - Serial number: RD26.01.15--H58001001B0183ÿ
Subsystem 4 - Serial number: 1B0183ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0135020915----
Coding: 0003595
VCID: 2643EA8591FDCABB99-8072
Component: J_245_EE16_SKB10H15 0220
Component: J_394_EE16_SKB10H15 0220
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000134983315
End-------------------------(Elapsed Time: 04:02)--------------------------
I waited a day after the trip and drove a couple of miles and next day, here are the current codes being shown.
Saturday,15,May,2021,11:13:12:06855
VIN: WA1WMAFEXFD015639   Mileage: 65700km-40824miles
          U1017 00 [036] - -
                    Mileage: 65701 km
                    Date: 2021.05.14
                    Time: 22:17:45
                    Engine RPM: 1166.50 /min
                    Normed load value: 23.5 %
                    Vehicle speed: 33 km/h
                    Coolant temperature: 69 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.900 V
                    Limitation: accelerator pedal: 51.3 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    selected gear-Bits 0-7: 4
Readiness: 0 0 0 1 1
   Coding: 001378
          U0415 00 [008] - -
                    Reset counter: 195
                    Date: 2013.02.27
                    Time: 00:00:11
                    Engine RPM: 1140.0 /min
                    Transmission input speed: 1140 /min
                    Transmission output speed: 780 /min
                    Engine torque: 12 Nm
                    ATF temperature: 66 °C
                    Accelerator pedal position: 6.4 %
                    Clutch_C1: closed
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: closed
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: closed
   Revision: 00H02001
   Coding: 0099441
                    Reset counter: 254
                    Mileage: 65699 km
                    Date: 2021.05.14
                    Time: 21:52:39
                    Count: 320
                    Count: 8529
                    Count: 73
                    Count: 50688
                    Reset counter: 254
                    Mileage: 65699 km
                    Count: 192
                    Count: 833
                    Count: 99
                    Count: 37888
   Coding: 0000135
   Component: FBSAUDIC6 IDG   H01 0053
                    Reset counter: 38
                    Mileage: 65699 km
                    Date: 2021.05.14
                    Time: 21:06:24
   Coding: 0304A036
   Coding: 070000
   Coding: 070000
   Coding: 0133123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 29011F
   Coding: 0014131
   Coding: 0012142
   Coding: 00C303
02001 - Data-Bus Automatic Distance Regulation
                    Reset counter: 39
                    Mileage: 65701 km
                    Date: 2021.05.14
                    Time: 23:10:58
                    Bin. Bits:    10111
                    Voltage: 11.70 V
                    Count: 7
                    Bin. Bits:    10011
   Coding: 0000006
   Coding: 0010001
   Coding: 3569949
   Coding: 030000
   Coding: 0758477
                    Reset counter: 254
                    Mileage: 65700 km
                    Date: 2021.05.14
                    Time: 22:15:23
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 13.70 V
                    Temperature: 25.0°C
                    (no units): 45.0
                    Fault Status: 11101101
                    Reset counter: 254
                    Mileage: 65699 km
                    Date: 2021.05.14
                    Time: 21:38:21
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 11.90 V
                    Temperature: 25.0°C
                    (no units): 0.0
   Coding: 0012001
   Coding: 0000031
   Coding: 0003595
End-------------------------(Elapsed Time: 04:05)--------------------------
Hmm... First scan shows the ABS module unhappy with all the wheel speed sensors. Newer scan only shows it unhappy with one. My gut says, "failing ABS module", but before condemning it I suggest a carefully checking all associated wiring, connectors, power supply & ground leads, and of course fuses.
TheAudiGuy
Houston, TX, USA
C?ID=222387
I ended up taking it to the dealer and they diagnosed the issue to be the wheel speed sensor, specifically at the left rear (driver rear side) needs to be replaced. I asked him if it was the ABS module after showing him the codes and the technician thinks it's unlikely but I sure hope that's the case. He has indicated that while he replaced the wheel speed sensor, he test drove it and it came up with a "new" code for the solenoid brake booster. This was already shown on the second scan that was done and was surprised they didn't see that code during the initial diagnosis. I'm pleased that lots of faults are gone but still confused as to why the wheel speed sensor for "front left" is throwing code? Was that not detected by technician? He commented the TPMS is on in instrument cluster due to the brake booster sensor, so I assumed the ESC was also on due to this.
Here is the code after I brought it back from the dealer:
Saturday,15,May,2021,16:34:25:06855
VIN: WA1WMAFEXFD015639   Mileage: 65760km-40861miles
   Coding: 001378
   Revision: 00H02001
   Coding: 0099441
                    Reset counter: 0
                    Mileage: 65738 km
                    Count: 128
                    Count: 833
                    Count: 99
                    Count: 45312
   Coding: 0000135
   Coding: 0304A036
   Coding: 070000
   Coding: 070000
   Coding: 0133123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 29011F
   Coding: 0014131
   Coding: 0012142
   Coding: 00C303
   Coding: 0000006
   Coding: 0010001
   Coding: 3569949
   Coding: 030000
   Coding: 0758477
                    Reset counter: 254
                    Mileage: 65739 km
                    Date: 2021.05.15
                    Time: 15:59:41
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 14.00 V
                    Temperature: 25.0°C
                    (no units): 60.0
                    Reset counter: 39
                    Mileage: 65738 km
                    Date: 2021.05.15
                    Time: 15:45:17
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 12.20 V
                    Temperature: 25.0°C
                    (no units): 0.0
   Coding: 0012001
   Coding: 0000031
   Coding: 0003595
Is that Wheel speed sensor fault a concern? Was this not detected during the diagnosis because this was already showing on the previous scans?
Here are the service inspection sheet and comments from the dealer:
I see no wheel speed sensor fault codes in your latest scan. Fault codes don't go away by themselves unless they are explicitly cleared, or many driving cycles have occurred without the fault condition being detected again.
TheAudiGuy
Houston, TX, USA
C?ID=222387
Yes, been driving the vehicle so far and no other codes are showing up at least as of now other than the solonoid brake booster sensor fault. They must have cleared them while at the shop. Regarding the wheel speed sensor, I thought the error code in the tire pressure II was the wheel speed, but it says "wheel speed signal - Front Left". Is this just related to the brake booster sensor?
I'm not sure what's up with your 4C-Tire Pressure II module. Normally that's a virtual address that's actually inside the ABS or another module, but in this case, looking at the HW part number, it seems to be stand-alone...?
TheAudiGuy
Houston, TX, USA
C?ID=222387
I usually assumed that the TPMS would have it's own module but never new that it was part of the ABS Module and would communicate the ABS module vice-versa. I do notice that there is an ABS module Fault in the 4C TP II. I'm trying to think if it's triggered by that brake booster sensor. Looking at the HW, it seems it is a standalone module that seems to fit 2011-15 Q7 vehicles (some C6 2011 platform vehicles as well).
That's generally true when it's a "direct" TPMS that measures actual tire pressure via sensors in the wheels at the valve stems. However, even then, the functionality has been know to be integrated in other modules (but in in ABS).
Now with "indirect" TPMS systems, which detect tire pressure issued by monitoring and analyzing wheel speeds, the TPMS functionality is basically in the ABS, although it seems some cars have a "phantom" module at 4C, presumably for data-routing purposes.
TheAudiGuy
Houston, TX, USA
C?ID=222387
Ahh this makes so much sense. Really appreciate this information. Will update that just took the trip back, 400 miles into the journey, the esc fault went away. Infact all Faults are gone except the tpms. Faults have not shown themselves which is a good sign. I also realized that if I cruise at designated speed, after a while the Fault goes away. It only activates after I press on the brakes. Sometimes it just goes away on its own. This would confirm that brake booster sensor issue. I'll get that sorted out in a day or two. I have not done a scan yet to see what it shows now but will do sometime today. Just glad it wasn't something like the ABS module being the cause even though I shouldn't brush it off as the way it handled these wheel speed sensors show me that it could go bad so something to watch out for. Really once again thank you for all the help. Learning more and more from you geniuses!
