golf mk7 radar calibration
Auke777
C?ID=100107
hi guys
i have a golf mk7 on a 2016 that needs the radar/acc system to be calibrated/setup
it has been disconnected/removed and refitted (by the mechanic when he fitted a new headlight 🤦🏻‍♂️)
so now i have no acc at all
i have tried parking 1.2m at 90degrees from a flat metal door, and then i went into 13(auto dist reg) then i did security access, then i clicked basic settings and then i clicked reset misalignment angle,
it said finished correctly after about 2/3 seconds then said “not running”
does anyone have a link to an exact guide or instructions how to set the acc/radar correctly using vcds on this car?
any help would be greatly appreciated
cheers
Auke777
C?ID=100107
Auke777
C?ID=100107
Sunday,16,May,2021,15:30:57:42405
VCDS Version: 21.3.0.0 (x64)
VIN: WVWZZZAUZGP573156   License Plate: MJ16 AHN
Mileage: 65195km-40510mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZGP573156   Mileage: 65195km-40510miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 J    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00122466050B2000
   Shop #: WSC 00028 028 00074
   ASAM Dataset: EV_ECM20TFS0205G0906259J 001002
   ROD: EV_ECM20TFS0205G0906259F.rod
   VCID: 3565441F94E4D32320-8060
16452 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
                    Mileage: 65154 km
                    Date: 2021.05.10
                    Time: 14:01:03
                    Engine RPM: 0.00 /min
                    Coolant temperature: 11 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 12.050 V
                    Engine: operating status: ES
                    PV: 0.00 %
                    T_IGK: 6.44 s
                    Drivetrain coordinator: brake fault status-ESP system error: No
17185 - Databus
          U1122 00 [032] - Implausible Message
17176 - Databus
17178 - Databus
Readiness: 0010 0001
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4913
   Revision: 06253104    Serial number: TFK01510220838
   Shop #: WSC 00028 028 00067
   ROD: EV_TCMDQ250021.rod
   VCID: 53A11A873A50ED132E-8006
10928 - Main Pressure Adaptation
          P184A 00 [072] - Offset Upper Limit Exceeded
                    Fault Frequency: 20
                    Mileage: 64930 km
                    Date: 2021.05.01
                    Time: 10:26:54
   Revision: 00000000    Serial number: 63165000000098
   Coding: 04FA93A15427296F0778070541C96920C92A94E0E08296F718425078C208
   VCID: 7AFF9723FD7AFC5B8D-802E
0202 - Reverse Gear Info
          C109E 29 [008] - Implausible Signal
                    Reset counter: 19
                    Mileage: 64213 km
                    Date: 2021.04.07
                    Time: 22:27:32
0213 - Vacuum sensor
          C10A3 29 [008] - Signal Implausible
                    Reset counter: 44
                    Mileage: 65154 km
                    Date: 2021.05.10
                    Time: 14:01:03
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 26
                    Mileage: 64427 km
                    Date: 2021.04.16
                    Time: 17:11:34
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 02120024200100011005000000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6ADFA7638DDA4CDB7D-803E
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86581011150413
   Coding: 03501A46C24122F30BA44080B11C07281000000000000000000000000000
   Shop #: WSC 00028 028 00079
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0301EAC78AB0BD93DE-8056
   Component: WWS    150917  042 0551
   Serial number:         151026112112
   Component: RLHS  037 0059
   Serial number: S5Y15M11D16H00M46S42
   Coding: 90A8DD
   Serial number: 000000000ZY152851U80
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033932048
   Sunroof control module:
   Subsystem 5 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000N04H800000
   Coding: 191900
   Roof shade control module:
   Subsystem 6 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST000N04RI00000
   Coding: 191900
   Humidity sensor: interior:
   Revision: --------    Serial number: 39391529601663
   Coding: 0071051011
   VCID: 43812AC7CA307D939E-8016
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 03101504381944
   Coding: 001C1300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A7F5723BDFA3C5BCD-806E
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR17NYX%
   Shop #: WSC 00028 028 00062
   VCID: 7F096637E658D973BA-802A
   Left seat belt tensioner:
   Serial number: 34169677B09111541129
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34169676B11111550119
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 910 15
   Serial number: 35767000000C4398371W
   Subsystem 4 - Part No SW: -----------    HW: 480 002 910 15
   Serial number: 358670000003A381071J
   Subsystem 5 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3516502C51D73C61617A
   Subsystem 6 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3526502AF1D3F98462E.
   Subsystem 7 - Part No SW: -----------    HW: 480 400 511 15
   Serial number: 3556502B31D25F03F34F
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20151117500268
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3F892637A6D81973FA-806A
   Part No SW: 5G1 920 958 A    HW: 5G1 920 958 A
   Component: KOMBI         302 6420
   Coding: 27AD10082F80260001886A011400000000000000
   VCID: 2F69767776B8E9F36A-807A
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 07111510802634
   Coding: 030100043F085900FB00027E1C0F00010001050000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79FD882FF87CF74384-802C
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002519040048433
   Coding: 2DFFFF
   Serial number: 7179358303
   Serial number: HA1-00009.10.15
   Coding: 0001
   VCID: 4A9F07E3ED1AACDB5D-801E
   Component: TSG FS        010 0031
   Serial number: 0000174870516
   Coding: 003F0220D001028000001000
   VCID: 47993ED7FE0851B342-8012
   Serial number: 00000000000002108256
   Coding: 0D0000
65604 - Door Warning Lamp
          B1326 01 [009] - Electrical Failure
                    Fault Frequency: 30
                    Reset counter: 4
                    Mileage: 63394 km
                    Date: 2021.03.26
                    Time: 00:00:44
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   VCID: 397D482FB8FC3743C4-806C
   Component: TSG BFS       010 0031
   Serial number: 0000173846053
   Coding: 003F0020DE01028000801000
   VCID: 468733D3F90248BBB9-8012
   Serial number: 00000000000002516591
   Coding: 050000
   Coding: 06AE01000B000200
   Shop #: WSC 27883 002 1048576
   VCID: 408B25CBDB26668B83-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    H24 0245
   Serial number: VWZAZ2R0623910
   Coding: 02730201FF00000051111101008808001F0207C601200100CF
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 306B750B6B86F60B73-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4060
   Serial number: VWZ6Z9R3140387
   Subsystem 2 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 150925200689
End-------------------------(Elapsed Time: 04:51)--------------------------
Auke777
C?ID=100107
cheers here is image
TFEGpHn
Auke777
C?ID=100107
i just followed the instructions on how to post image from uwe's post and i cannot get images to post for some reason
i know i managed it earlier in the post but i dont actually know how i did that and now i cannot get it to post again tbh
im following the instructions i.e open brackets img then close brackets then img link then /img in brackets
sorry about the hassle etc just really want to work this image thing out
cheers for help
UPDATE: i worked out if you put .gif at the end of the URL link provided by imgur, it works, :-)
@Auke777: Hi.
The good news - @VAG-Dave has addressed your very question on ostensibly the same hex13 module (5Q0 907 572) in your auto-scan HERE (you need to read the entire thread)
The even better news - from the link above:
The physical position of the Radar unit readings are "85" [Vertical angle deviation] & "86" [Horizontal angle deviation] & apparently should be between -0.800 and +0.800. If your readings are outside of this, its a dealer job as the whole "zero point/tare" needs to be reset as the unit is physically "out".​
Compare with the readings in your screenshot.
You appear to have completed some of the processes in the link- but Dave provides other information that might be useful to try - maybe
Auke777
C?ID=100107
gmLjUuC
cheers
i have re-read the entire thread, i have already read his thread but his scenario is not the same as mine as his acc was just greyed out, mine says unavailable.
i did read that he was driving with acc greyed out, but mine doesnt work at all, it says front assist and acc unavailable,
i did also read that his module/sensor wasnt fully clipped in/aligned, i have already checked mine tbh, but i will check again tomorrow.
my readings seem to be within specs so it should be fixeable without going to the dealer hopefully,
my main problem seems to be that in basic settings reset misalignment angle does not seem to work, it just says finished then not running.
I am speculating here, but somehow I doubt that "parking 1.2m at 90degrees from a flat metal door" is an adequate way of doing things. The factory-specified process calls for it to be done on an alignment rack, with targets that are located with literal laser precision. It would not surprise me if the module says, "Pffft!" if isn't happy with the test setup.
Auke777
C?ID=100107
ok ill have to take it to dealer then thanks, was just hoping i could sort myself with vcds,
cheers
