Audi A4 B9 autohold retrofit ABS coding
Marko_O2
Slovenia
C?ID=297545
Hi all.
I'm trying to enable AUTO HOLD on Audi A4 B9. I already installd the button and enabled it in 09 central electronics. (byte 15, bit 6 from 0 to 1)
Now I have a problem with coding of 03 ABS module. There is no help with long coding for this model.
I found that I should change those two options : byte 18 , bit 6 from 0 to 1 and byte 30, bit 1 from 0 to 1.
I always get "coding rejected"
ABS moule : 8W0 907 379 F (ESP9 Premium H09 0593)
I used suggested security acces : S11820 (i got security accepted)
Can someone please help me with this
Marko_O2
Slovenia
C?ID=297545
This is full scan.
Tuesday,11,May,2021,22:36:34:63817
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WAUZZZF46GA061883   License Plate:
Chassis Type: F4-AU49 (4M2)
Scan: 01 02 03 08 09 13 15 16 17 19 42 44 46 52 5F 6D 81 8B A5 AC
          BB BC
VIN: WAUZZZF46GA061883   Mileage: 227721km-141499miles
Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 AD    HW: 04L 907 309 L
   Component: R4 2.0l TDI   X33 1970
   Revision: B1X33---
   Coding: 0A254032236405083408
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01104L906026AD 001006
   ROD: EV_ECM20TDI01104L906026AD_001.rod
   VCID: 6C9424888772BEEB0F-8038
19226 - Particulate Trap Bank 1
          P2002 00 [101] - Efficiency Below Threshold
                    Mileage: 223707 km
                    Date: 2021.03.14
                    Time: 13:51:53
                    Engine RPM: 2056.00 /min
                    Normed load value: 95.7 %
                    Vehicle speed: 119 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 108 °C
                    Voltage terminal 30: 14.760 V
                    Exhaust mass flow of low-pressure EGR: calculated: 5.952
                    Differential pressure ratio: low-pressure EGR: 41.0 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 90.1 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 86.5 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 65.86 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 59.47 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 100.3 hPa
28419 - Control Circuit for Reductant Heating 3
          P20C4 00 [032] - Short to Plus
19206 - EGR System
          P0401 00 [096] - Insufficient Flow
22397 - Steering Column Control Module
          U0212 00 [032] - No Communications
   Part No SW: 8W0 927 155 G    HW: 0CK 927 156 S
   Component: 0CK 20TDI RdW H06 0006
   Revision: --H06---    Serial number: 0000000818
   ASAM Dataset: EV_TCMDL382021 002021
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 43C6AF34CA6C91939E-8016
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117051160029001057
21015 - Control Module Performance Implausible
          P0607 00 [032] - -
                    Mileage: 226731 km
                    Date: 2021.04.30
                    Time: 11:06:32
                    Engine RPM: 889 /min
                    Driving position: R
                    ATF temperature: 21 °C
                    Transmission output speed: 2 /min
                    Voltage terminal 30: 14.6 V
                    Engine torque: -8 Nm
                    selected gear: N
                    Ctrl. mod.: operating condition: regular operation
                    Auxiliary pump for transmission: requesting function: Fill hydraulic press. accum.
                    Auxiliary hydraulic pump for transmission oil: current: 5 A
                    Oil pressure reservoir: pressure: 16.2 bar
                    Pressure of clutch 1: actual value: 0.0 bar
                    Pressure of clutch 2: actual value: 0.0 bar
                    Clutch status: New
                    Unlearning counter according OBD: 1
                    Occurrence_counter_over_length_of_life: 3
                    Safety_interface_voltage_state-Voltage_supply_1: valid
                    Safety_interface_voltage_state-Voltage_supply_2: valid
                    Safety_interface_voltage_state-Voltage_supply_3: valid
                    Safety_interface_voltage_state-Voltage_supply_speed_sensor: valid
                    Safety_interface_drive_position_sensor_signal_state-Sensor_1: valid
                    Safety_interface_drive_position_sensor_signal_state-Sensor_2: valid
                    Safety_interface_automatic_transmission_shift_position: R
                    Safety_interface_gear_selector_signal_state-Gear_selector_1: valid
                    Safety_interface_gear_selector_signal_state-Gear_selector_2: valid
                    Safety_interface_gear_selector_signal_state-Gear_selector_3: valid
                    Safety_interface_gear_selector_signal_state-Gear_selector_4: valid
                    Safety_interface_vehicle_speed-Data: 0.0 km/h
                    Safety_interface_engine_speed: 889 /min
                    Safety_interface_voltage_supply_1_for_sensors-Data: 4.994 V
                    Safety_interface_voltage_supply_2_for_sensors-Data: 5.009 V
                    Safety_interface_voltage_supply_3_for_sensors-Data: 5.006 V
                    Safety_interface_pressure_regulating_valve_1_actual_current: 167.9 mA
                    Safety_interface_pressure_regulating_valve_2_actual_current: 167.2 mA
                    Safety_interface_gear_selector_1_measured_distance-Data: 9.71 mm
                    Safety_interface_gear_selector_4_measured_distance-Data: -0.05 mm
                    Safety_interface_gear_selector_3_measured_distance-Data: 0.05 mm
                    Safety_interface_gear_selector_2_measured_distance-Data: -2.40 mm
                    Safety_interface_gradient_filtered_vehicle_speed-Data: 0.0 km/h
                    Drive_limiter_cause_signal_plausi: keine Fehler
21024 - No Communications with Steering Angle Sender (G85)
          U0126 00 [032] - -
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 F    HW: 8W0 907 379 D
   Component: ESP9 Premium  H09 0593
   Coding: 0CAA489910A80A9715A64899008052A2E6A59230120850A812004A4567A549
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: 48DCB818F34AB2CB4B-801C
15371776 - Databus
          U1121 00 [032] - Missing Message
          [ComScl:_Signal_Group_SG_AEB_01_-_Timeout_error]
404480 - Databus
          [ComScl:_Signal_Group_SG_FCW_02_-_Timeout_error]
12658176 - No Communications with Steering Angle Sender (G85)
          U0126 00 [032] - -
          [ComScl:_Signal_Group_SG_LWI_01-_Timeout_error]
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0052
   Coding: 241800285544400D02000100800000000000000000000000000000000000
   Shop #: WSC 06325 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 373ECBE48EB4CD3332-8062
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000753812
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: B5D94018000000000001
   Rear A/C control head:
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H34 0050
459028 - Databus
          U1121 00 [024] - Missing Message
                    Reset counter: 67
                    Mileage: 225504 km
                    Date: 2021.04.16
                    Time: 13:12:23
   Part No SW: 8W0 907 063 AC    HW: 8W0 907 063 C
   Component: BCM1 MLBevo   H12 0228
   Coding: 8045394A457900CD01455118582E00B911033100000000000000000020001A200241002B025601
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 7CB414C8F7122E6B9F-8028
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 151218  043 0813
   Serial number: 894353?0401535203526
   Coding: 5BC7F7
   Serial number: 61333766
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 04 12 2015  00169461
   Serial number: GX1CE115121511910235
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
   Component: J528-Dachele  H13 0082
   Serial number: B00069442
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H15 0010
   Serial number: 2615000137173006
65685 - Heated Seat Backrest; Front Righ
          B14E3 15 [009] - Open or Short to Plus
                    Fault Frequency: 12
                    Reset counter: 240
                    Mileage: 221694 km
                    Date: 2021.02.12
                    Time: 08:56:14
                    average_Voltage_terminals: 14.60 V
                    Outside air temperature sensor-Resistance: 2.56 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: -6.50 °C
                    interior_temperature: 9.00 °C
                    Vehicle speed: 5.79 km/h
65689 - Heated Seat Backrest; Front Left
          B14E1 15 [009] - Open or Short to Plus
                    Reset counter: 131
                    Mileage: 212841 km
                    Date: 2020.09.08
                    Time: 04:47:26
                    average_Voltage_terminals: 14.40 V
                    Outside air temperature sensor-Outside air temperature on CAN: 13.50 °C
                    interior_temperature: 19.00 °C
                    Vehicle speed: 11.51 km/h
   Part No SW: 8W0 907 561 B    HW: 8W0 907 561
   Component: LRR4          H08 0220
   Coding: 3473FFE258FFEC0A949C80A0
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3D32D9CCAC88E763E8-8068
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655     HW: 8W0 959 655
   Component: Airbag10.44   H52 0084
   Serial number: 003M6001UUTZ
   Coding: AECCF0C00C800000985400F3C00C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 06407620B9DE64BBF9-8052
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 8W0857705A0040Q01457
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 8W0857706A0044Q00084
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 063 001 16
   Serial number: 3577Y00A91DE13E3C119
   Subsystem 4 - Part No SW: -----------    HW: 442 062 901 16
   Serial number: 3587Y00B71B1C0E3F126
   Subsystem 5 - Part No SW: -----------    HW: 442 0B1 501 16
   Serial number: 3517700C31E4DF11D3EV
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 801 16
   Serial number: 3527700B31E4DF12E0FV
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 701 16
   Serial number: 3557500022947EE9853G
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 701 16
   Serial number: 3567500022947EEA48AO
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 701 16
   Serial number: 2307500082947EE6E62H
   Subsystem 10 - Part No SW: -----------    HW: 442 431 801 16
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00AD1AA1C82E38Y
   Subsystem 11 - Part No SW: -----------    HW: 442 431 801 16
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00AD1AA1C82E2D$
   Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 014A653C90F04383CC-8054
   Part No SW: 8W5 920 790 B    HW: 8W5 920 790 B
   Component: FBenRDW       H12 0275
   Coding: 048D70C06C8000080080EF601000400000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   VCID: 41CAA53CD07083838C-8014
   Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
   Component: Gateway       H13 4079
   Revision: 3C060055    Serial number: 5543C041516127
   Coding: 0301000100000F404400000000590012DC100007000000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002_AU49.rod
   VCID: 3620C6E089BE343B29-8062
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20160128155101 RD759
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 5700509203
   Part No SW: 8W0 959 593 G    HW: 8W0 959 593
   Component: TSG FS        005 0052
   Serial number: 0000187095681
   Coding: 001D1B215000008000001080
   VCID: 4ED08E00112E6CFB01-801A
   Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0407
   Coding: 0D008080008080
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X_002.rod
   VCID: 40CCA038DB7A8A8B83-8014
26368 - Databus
          [KFC_LWI_01_TIMO]
                    Reset counter: 107
                    Mileage: 225504 km
                    Date: 2021.04.16
                    Time: 13:12:16
                    Expanded ambient data 1-Engine running: Engine_not_running
                    Expanded ambient data 1-Supply voltage: 0.00 V
                    Expanded ambient data 1-Temperature: -70 °C
                    Expanded ambient data 1-System status: 4
                    Expanded ambient data 1-driving_direction: 0
                    Expanded ambient data 1-KFA: 0
                    Expanded ambient data 1-KFC: 103
                    Expanded ambient data 1-Ready_To_Drive_Bit: 0
                    Expanded ambient data 1-StartStop Info: 0
                    Expanded ambient data 1-Steering_Angle_Calculated: 0.00 °
                    Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
                    Expanded ambient data 1-Steering_torque: 0 Nm
                    Expanded ambient data 1-Steering_Torque_Sign: 0
                    Expanded ambient data 1-Vehicle speed: 0 km/h
34304 - Databus
          [KFC_HCA_01_TIMO]
                    Reset counter: 107
                    Mileage: 225504 km
                    Date: 2021.04.16
                    Time: 13:12:16
                    Expanded ambient data 1-KFC: 134
37120 - Databus
          [KFC_HCA_02_TIMO]
                    Reset counter: 107
                    Mileage: 225504 km
                    Date: 2021.04.16
                    Time: 13:12:16
                    Expanded ambient data 1-KFC: 145
   Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   016 0344
   Coding: 01340000400000E0638980000E00080031024000004F00502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 7F4EE3C4E6043573BA-802A
   Subsystem 1 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94073071
   Part No SW: 8W0 959 592 G    HW: 8W0 959 592
   Component: TSG BFS       005 0052
   Serial number: 0000186966948
   Coding: 001D1B215C00008000001080
   VCID: 4DD2890C1C2857E378-8018
   Part No SW: 8W0 035 036 R    HW: 8W0 035 036 A
   Component: MU-P-LN-EU    051 0976
   Serial number: A667B0GB009559
   Coding: 01940201FF0A000013110001000B00332F0022E5017001009E
   VCID: 42C8AA30D576989B95-8016
   Subsystem 1 - Part No SW: V03 959 802 TL    HW: -----------
   Component: ECE 2020/2021  --- 0187
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H31 0160
   Serial number: TPO00130011600820684
   Subsystem 3 - Part No SW: 8W0 919 614 P    HW: 8W0 919 614 P
   Component: ControlUnit_H  H22 0139
   Serial number: APVAK123121500030237
   Compact disc data bank:
   Component: Gracenote2  --- 1011
          B201A 00 [009] - -
                    Reset counter: 140
                    Mileage: 208383 km
                    Date: 2020.07.10
                    Time: 15:26:58
                    Voltage terminal 30: 12.2 V
                    Status_Software_Version_Management-module_name: MFC1H49xE/HREU
3086 - Antenna for Telephone Mount
          B1564 01 [008] - Electrical Failure
                    Fault Frequency: 8
                    Reset counter: 149
                    Mileage: 221781 km
                    Date: 2021.02.13
                    Time: 09:27:05
                    Voltage terminal 30: 15.1 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): selected
                    Status of telephone-Handset holder (cradle): connected
   Part No SW: 4M0 959 107     HW: 4M0 959 107
   Component: HDSG-Modul    H12 0143
   Revision: --------    Serial number: 30506548600000
   Coding: 0570
   ASAM Dataset: EV_DeckLidCONTIAU736 001010
   VCID: 70AC30F8AB5A5A0B33-8024
   Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20160204002324
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 3522C1EC94B83F2320-8060
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 B    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 3B36D7D4B29CE953D6-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H13 0042
   Coding: 0404090200000401022023A4A50000FCB0F0C010C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
1123600 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 172
                    Mileage: 218244 km
                    Date: 2020.12.15
                    Time: 14:41:25
                    Control Module temperature: 10 °C
                    Voltage terminal 15: 14.70 V
1123601 - predictive route data
                    Reset counter: 143
                    Mileage: 225733 km
                    Date: 2021.04.20
                    Time: 18:42:46
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 14.60 V
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736_AU49.rod
   VCID: 6E902E80B16E4CFB21-803A
   Part No SW: 8W0 959 595 G    HW: 8W0 959 595
   Component: TSG HFS       005 0052
   Serial number: 0000187312153
   Coding: 000D19200000008000001080
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 50EC90780B1A7A0B13-8004
   Component: TSG HBFS      005 0052
   Serial number: 0000187311952
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
End----------(Elapsed Time: 01:50, VBatt start/end: 12.2V/12.2V)-----------
gorkem33
Turkey
C?ID=94632
Hello, I would like to share my brother's car abs code which is retrofitted 'AUTO HOLD' from factory on Audi A4 B9 Avant.
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 E HW: 8W0 907 379 J
Component: ESP9 Plus H06 0593
Coding: 04AA049910A70A9715A0489900845292F6A5C020200850A812004A496FA503
Shop #: WSC 06334 790 00001
VCID: 47CB5AA16F25FD6F4B3-8012
May be it will help you.
Best.
vastechnics
C?ID=143747
as far as I know this is right codign:
Module 09, Long Coding, Byte 15, Bit 6, from 0 to 1
Module 03
, Long Coding, Byte 18, Bit 6, from 0 to 1
Module 03,
Long Coding, Byte 30, Bit 1, from 0 in 1
