Service Interval Reset
kats20t
Australia
H11-NRRT
Hi New Member here and apologise if this has been covered elsewhere.
Vehicle is a 2016 SQ5 (Australian diesel version) and I cannot reset the SRI.
I've tried from the main screen and via adaptations ; it acknowledges it.
When the car is started it still chimes 'service due'.
Need help.
Thanks Michael.
kats20t
Australia
H11-NRRT
Saturday,08,May,2021,17:06:10:28944
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4543.4
Workshop Code: 444 29511 000000
VIN: WAUZZZ8R8GA140822   License Plate:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3C 42 44 46 47 52 53
          56 5F 62 69 6C 6D 72 A9 AC C0
VIN: WAUZZZ8R8GA140822   Mileage: 76120km-47298miles
Address 01: Engine (J623-CVUB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589 C    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0008
   Revision: 54H23---
   Coding: 2A2A4032257603030000
   Shop #: WSC 29511 444 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589C 001010
   ROD: EV_ECM30BTD0118K5907589C.rod
   VCID: 41DF4163A10EDB03C0D-8014
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Fault Frequency: 21
                    Mileage: 76043 km
                    Date: 2021.05.05
                    Time: 16:07:02
                    Engine RPM: 0.00 /min
                    Coolant temperature: 79 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 12.080 V
                    ACC specified acceleration: 0.007 m/s²
                    ACC control module: received status-Bits 0-7: 7
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
   Part No SW: 8R0 927 158 AR    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1006
   Revision: --H19---
   VCID: 0D47AD53ADD64F63F45-8058
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 BF    HW: 8R0 907 379 BF
   Component: ESP8 quattro  H09 0020
   Coding: 35DD0C01
   Shop #: WSC 06335 123 12345
   VCID: 05579573F5263723BC5-8050
   Part No SW: 8K0 907 064 KR    HW: 8K0 907 064 KR
   Component: BCM2 2.0      H15 0711
   Coding: 05B54000000000000000
   Shop #: WSC 06335 000 00000
   VCID: 0A4DA64FDC38585BD17-805E
   Part No SW: 8K2 820 043 AP    HW: 8K2 820 043 AP
   Revision: D0000000    Serial number: 01150420160528
   Coding: 3625628080
   VCID: 77ABEFBBBFCA55B3BE9-8022
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00001330882601
   Coding: 260000108074AFE2018140C000001D0D0F9DE70827090201000008004401010200020034000000
   VCID: 7AADF68F8CD848DBC17-802E
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 160331  H13 0050
   Serial number: 90243015160225105720
   Coding: 01DD13
   Serial number: 61663627
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000804161616
   Subsystem 4 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 4172573900PAG0MUFU03
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0110
   Coding: 008190
   VCID: 372B2FBBFF4A95B37E9-8062
                    Reset counter: 177
                    Mileage: 76043 km
                    Date: 2021.05.05
                    Time: 16:06:58
                    Temperature: 32.0°C
                    Voltage: 12.03 V
                    Hex Value: 0x005D
                    Lateral Accel.: 0.00 m/s^2
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003JPDD24J6I
   Coding: 304A3531313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C95C478234EA4B073-801C
   Serial number: 6334MSME56782C7EY
   Serial number: 6344MSME56784C0FV
   Serial number: 6352QSME716B3C62P
   Serial number: 6362QSME4D6B3E7A3
   Serial number: 63732SME4F541F7CJ
   Serial number: 63832SME2E54025C1
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372PDG0009X
   Coding: 00003F
   VCID: 44D14877BE9CCE2BEBB-8010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 G    HW: 8R0 920 931 G
   Component: KOMBIINSTR.   H35 0567
   Revision: 00300000    Serial number: 03G26GD4H
   Coding: B3A722000F010008010000
   VCID: 392F2983C95E83C388D-806C
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z16331011C
   Coding: 80CD07FF00
   VCID: 7EA5FA9F90F064FBFDF-802A
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 6514999803
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 16098002909011200410
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02022064747464545425363E00
   VCID: 7CA1F09786EC76EBD3B-8028
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000193867814
   Coding: 01781B00000000000000
   VCID: 42DD4E6FA488C01BD97-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H07 0071
   Serial number: 0401543435
   Coding: 010312
   Shop #: WSC 06334 000 00000
   VCID: 3FDB479BD7FAADF3B69-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H07 0071
   Serial number: 0401584843
   Coding: 010312
   Component: TSG FA        H03 0511
   Revision:             Serial number: 0000195435664
   Coding: 011D13215E01440004
   VCID: 4FFB775B67DA3D73469-801A
                    Fault Status: 01101100
                    Reset counter: 182
                    Mileage: 76043 km
                    Date: 2021.05.05
                    Time: 16:11:40
   Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
   Component: RCevo         H54 0702
   Revision: 00000001    Serial number: 0000840821
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: 46D5527F8820FC3BF5F-8012
   Revision: 00002001    Serial number: 0399571281
   Coding: 01000E3A20B930958720053680040047
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Revision: 00005001    Serial number: 94813058250107
   VCID: 2D070DD30D162F63145-8078
   Component: TSG BF        H03 0511
   Revision:             Serial number: 0000195663439
   VCID: 4EC56A5F60D0347B4DF-801A
   Component: EPB-4         H03 0005
   Revision: --------    Serial number: 00000001798622
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D368FCCD888DB817-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109D$0G2545386
   Coding: 040103010000000001
   VCID: 2B0303CB330221530A1-807E
   Part No SW: 8R2 035 764 L    HW: 8R2 035 764 J
   Component: H-BNT-RW      H50 0946
   Revision: --------    Serial number: 521D-0G7515644
   Coding: 1A0A01060205A9EF75808B4E000004035C0000000000000000
   VCID: 41DF4163A18EDB03C0D-8014
   Subsystem 1 - Part No: 8R0 060 884 DJ
   Component: ROW 2016  0806
   Component: DU7 High  H42 0104
   Serial number: A130DZ0G3561497
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002513696
   Component: CD-Database  6890
   Component: TSG HL        H02 0510
   Revision:             Serial number: 0000195695296
   Coding: 010C13204001240004
   VCID: 46D5527F88A0FC3BF5F-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Component: Anhaenger     H12 0100
   Revision: 1G001001    Serial number: 00000440290371
   Coding: 0300000000000000
   VCID: 353725B3E54667A36C5-8060
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H11---    Serial number: 525PA8-JB2A0T4
   Coding: 1030010
   VCID: 343118B7E23C7EAB5BB-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D273D93DD76BFE3A45-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H02 0510
   Revision:             Serial number: 0000195695424
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 160308200481
   VCID: 79AFE983895E43C3C8D-802C
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 160910040
   ROD: EV_RDCMA00100.rod
   VCID: 2F3B17DB079A5D73269-807A
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160 A    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H10 0008
   Serial number: 160402200198
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 323D1EAF14A8709B497-8066
End----------(Elapsed Time: 02:29, VBatt start/end: 12.1V/12.1V)-----------
The fault codes in 01 engine , 13 auto dist control relate to a recent fitting of a Westfalia trailer control module to an existing Hayman Reese towbar.
There was an old post and with Uwe's recommendation I think the 13 auto dist control has been correctly coded from 008190 to 008189; haven't checked yet.
The 42 driver door fault keeps popping up after codes are cleared.
I haven't been able to reset SRI on this car well before these modifications.
Thanks Michael.
@kats20t: hi- thanks for posting the auto-scan. Have you viewed Ross-Tech's excellent SRI-reset video below?
Since the hex17 module in your car is a UDS type - ignore the first part of the video (start @ 1.5 minutes)
kats20t
Australia
H11-NRRT
Don,
I notice you're from Aust. are our cars a little different?
Thanks for the advice nut I've tried the UDS method ; my window is slightly different; when you click the drop down box it offers a whole lot of other choices other than Reset ESI/OIL....... or RESET FIX&ESI/INSP...... I've selected diiferent choices and performed them ; VCDS says done but when you start the car up again it still says "service due".
Could it have anything to do with I have changed the oil interval via the cars MMI; doesn't allow service to be reset via MMI.
Thanks Michael.
@kats20t:
Michael-Hi.
"our cars" do have Antipodean peculiarities, but in respect of SRI reset they are pretty much the same as cars in other markets.
Changing the "oil interval via the car's MMI" shouldn't affect the reset procedure (I guess unless you entered zero kms - maybe?).
If you are still having problems, I suggest that you post-up an adaptation channel map for the instrument module @ address hex17. Not sure if you are aware of these- they are often abbreviated to the term "admap" and they provide a full listing of all the adaptation channels in a module including the values.
You will find instructions about how to create admaps HERE. I suggest that you choose the following options when presented with the maps dialogue box:
But instead of "09" (which is the address for the BCM) - in your case, the address will be 17
Once the process is complete, look in the sub directory C:\Ross-Tech\VCDS\Logs and you should find a new file starting with the name admap-17-. Start a new post and select </> from the top row of commands on the forum screen. Copy-and-past the contents of the admap file into the box presented and then just follow the prompts
Let's see what you've done.
Please go back to [SRI Reset]. Allow VCDS to read the SRI-relevant channels, then click [Add to logfile] and post the resulting log here.
Done, where do you get that idea?
This is not UDS!
hmm.......... oops my bad
As my doctor keeps telling me - the first place that someone goes blind is in the eyes!!
kats20t
Australia
H11-NRRT
Sunday,16,May,2021,17:52:44:28944
Mileage: 76500km-47534mi   Repair Order:
VCDS Release 21.3.0:  SRI Reset
Control Module Part Number: 8R0 920 931 G       Labels:  .8R0-920-xxx-17.clb
Component:KOMBIINSTR.   H35 0567, Coding:B3A722000F010008010000
Operation: Flexible Oil Service Reset (LongLife/Rest of World/Diesel)
Channel      Description                                           Unit          Current val.      New val.
02           Service Reminder Status                                             1                 0
40           Distance since Service                                km x100       2                 ---
41           Time since Service                                    Days          4                 ---
42           Minimum Distance to Service                           km x100       150               150
43           Maximum Distance to Service                           km x100       300               300
44           Maximum Time to Service                               Days          730               730
45           Oil Quality                                                         2                 2
47           Soot Quantity                                         DIST x100     3                 ---
48           Thermal Load                                          DIST x100     3                 ---
49           Minimum Time to Service                               Days          365               730
50           Basic Distance Value for Oil Change                   km x100       150               ---
51           Basic Time Value for Oil Change                       Days          365               ---
52           Basic Distance Value for Inspection                   km x100       150               ---
53           Distance since Inspection                             km x100       275               ---
54           Basic Time Value for Inspection                       Days          730               ---
55           Time since Inspection                                 Days          4                 ---
56           Day Counter                                           Days          1847              ---
45           Oil Quality                                                         2                 2
Address 17,8R0 920 931 G,channel 2,adapted from,1,to,00000,
Address 17,8R0 920 931 G,channel 45,adapted from,2,to,00002,
Address 17,8R0 920 931 G,channel 42,adapted from,150,to,00150,
Address 17,8R0 920 931 G,channel 43,adapted from,300,to,00300,
Address 17,8R0 920 931 G,channel 44,adapted from,730,to,00730,
Address 17,8R0 920 931 G,channel 49,adapted from,365,to,00730,
02           Service Reminder Status                                             0                 ---
40           Distance since Service                                km x100       0                 ---
41           Time since Service                                    Days          0                 ---
42           Minimum Distance to Service                           km x100       150               ---
43           Maximum Distance to Service                           km x100       300               ---
44           Maximum Time to Service                               Days          730               ---
45           Oil Quality                                                         2                 ---
47           Soot Quantity                                         DIST x100     0                 ---
48           Thermal Load                                          DIST x100     0                 ---
49           Minimum Time to Service                               Days          730               ---
Uwe I think this is what you're after (above)
Don I have the admap 17 but couldn't paste it in its entirety:
adpmap-17-8R0-920-931-G_WAUZZZ8R8GA140822-20210516-1744
I see the problem:
Since the value in 53 is greater than the value in 52, the reminder will remain on no mater what you do with an oil change.
In the pull-down, you should be able to select "Mileage based Service Reset (Rest of World)" and then [Perform SRI]
In addition,
Needs to be zero'd out.
kats20t
Australia
H11-NRRT
Uwe,
What is the sequence?
Do I need to go to 02 Service Reminder Status and zero it out first ?
Is this done manually via adaptations?
Then do I select drop down Mileage based Service Reset (Rest of World)
Thanks Michael.
I do not think it matters which you do first.
It can be done manually via Adaptation Channels, but it should work just as well if you follow my instructions two posts above.
