noob with reset problem
quinya3
C?ID=231504
hi
i have had my vcds cable for a few months now. i have done a few scans and resets for myself and friends and found the tool really good to use. i have found this forum useful with lots of info available.
a few days ago i did a fullservice on my audi 1.8tfsi tt. the vehicle was on flexible servicing but because we do less than 5000 miles a year in it i wanted the service schedule changing to fixed servicing.
the oil service indicator indicates a service is due and the inspection service shows it is due in about a year.
i performed the sri reset,
i selected the 'change to fixed servicing great britain', from the drop down menu
'the new values have been saved successfully, sri reset complete ' message appeared
i exited the vcds and disconnected everything and turned ignition off.
when i turn ignition on service due message is still there and when i connect vcds again all the old values are still there.
i have attached the log file for before and after the reset
hope someone can help me reset
thanks
Saturday,11,April,2015,10:45:01:09371
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: License Plate: AUDI TT 1.8TFSI
Mileage: 19172 Repair Order:
VCDS Release 14.10.2: SRI Reset
Control Module Part Number: 8J0 920 980 P Labels: 8J0-920-xxx-17-MY8.clb
Component:KOMBIINSTR. VDO H01 0591, Coding:0260428
Channel Description Unit Current val. New val.
02 Service Reminder Status 2 ---
40 Distance since Service km x100 29 ---
41 Time since Service Days 365 ---
42 Minimum Distance to Service km x100 90 ---
43 Maximum Distance to Service km x100 90 ---
44 Maximum Time to Service Days 365 ---
45 Oil Quality 1 ---
47 Soot Quantity km x100 0 ---
48 Thermal Load km x100 117 ---
49 Minimum Time to Service Days 365 ---
50 Basic Distance Value for Oil Change km x100 144 ---
51 Basic Time Value for Oil Change Days 365 ---
52 Basic Distance Value for Inspection km x100 320 ---
53 Distance since Inspection km x100 29 ---
54 Basic Time Value for Inspection Days 730 ---
55 Time since Inspection Days 365 ---
56 Day Counter Days 1467 ---
Operation: Change to fixed Intervals (Great Britain)
42 Minimum Distance to Service km x100 90 90
43 Maximum Distance to Service km x100 90 90
44 Maximum Time to Service Days 365 365
45 Oil Quality 1 1
49 Minimum Time to Service Days 365 365
50 Basic Distance Value for Oil Change km x100 144 144
51 Basic Time Value for Oil Change Days 365 365
Address 17:8J0 920 980 P channel 42 adapted from 90 to 00090
Address 17:8J0 920 980 P channel 43 adapted from 90 to 00090
Address 17:8J0 920 980 P channel 44 adapted from 365 to 00365
Address 17:8J0 920 980 P channel 45 adapted from 1 to 00001
Address 17:8J0 920 980 P channel 49 adapted from 365 to 00365
Address 17:8J0 920 980 P channel 50 adapted from 144 to 00144
Address 17:8J0 920 980 P channel 51 adapted from 365 to 00365
That channel needs a zero on it. I see nothing that indicates that the actual Service Reset was ever done. Selecting and performing a "Change to..." job does not do a reset . The fact that you still have 2900 km and 365 days since service corroborates it.
"Service Reset" (or something worded very similarly) should be the first job in the pull-down menu of jobs. Select it, then click [Perform SRI].
quinya3
C?ID=231504
hi uwe
thanks for your reply
i reset as you suggested from the drop down list 'flexible oil service reset(longlife/great britain/ gasoline)
this has cleared the service due warning on the dash and new values are in the log file, which i have attached
if i now change in the drop down sri menu to 'change to fixed intervals (great britain) will i get a service due message in 365 days for oil and inspection service in 730 days?
thanks
VIN: License Plate: TT 1.8TFSI
Operation: Flexible Oil Service Reset (LongLife/Great Britain/Gasoline)
02 Service Reminder Status 2 0
41 Time since Service Days 366 ---
42 Minimum Distance to Service km x100 90 145
43 Maximum Distance to Service km x100 90 306
44 Maximum Time to Service Days 365 730
45 Oil Quality 1 2
55 Time since Inspection Days 366 ---
56 Day Counter Days 1468 ---
Why would you do a "Flexible" reset when you want fixed intervals?
Please try "Change to fixed Intervals (Great Britain)" followed by "Fixed Oil Service Reset (Great Britain)"
quinya3
C?ID=231504
hi uwe
i did a flexible reset because i thought that was the service regime the vehicle was on and i had nothing to compare it to.
i have carried out both reset procedures as requested.
the log file is below. could you tell me why the time since inspection service still shows 366 days. i thought this would now read 0.
i thought that once reset to fixed intervals it would be oil service reset after 365 days and 730 days for inspection service.
realise i have lots to learn
thanks again for your help
Sunday,12,April,2015,18:16:57:09371
VIN: License Plate: TT AFTER OIL SERVICE RESET
Operation: Fixed Oil Service Reset (Great Britain)
02 Service Reminder Status 0 0
40 Distance since Service km x100 0 ---
41 Time since Service Days 0 ---
45 Oil Quality 1 1
48 Thermal Load km x100 0 ---
50 Basic Distance Value for Oil Change km x100 144 150
55 Time since Inspection Days 367 ---
Have you done the work that's supposed to be done every two years for the time-based inspection? It's not due for roughly a year. When you do that work, you can selected the job named "Time based Service Reset (Rest of World & Great Britain)".
Nope, there are three independent things happened here. The Oil Service Reset that can be flexible or fixed, which you have now reset. But there's also a time-based inspection that we've already discussed (which is supposed to be done every two years regardless of the mileage). And third, there's a mileage based inspection service that's supposed to be done every 32,000 km (20,000 miles) regardless when other services are due. This is a horrible, nasty, over-complicated scheme that could only have been perpetrated on the world by someone with title "Dr. Dipl. Ing." But I digress. What you have to understand is that any three of those things can make your car turn on the Service Reminder in the instruments, and you then have to look at a whole bunch of channels to see what the car actually wants.
If channel 2 is not zero, then it wants an oil-service. The details of why (type of intervals it's on and the soot or thermal load calculations that influence flexible intervals) are in channels 40-49.
If channel 53 exceeds channel 52, it wants a mileage based service.
If channel 55 exceeds channel 54, it wants a distance based service.
quinya3
C?ID=231504
hi uwe
the service schedule is a little out of sync because the car was purchased from audi a year ago and received a service at that time which is why its still showing a year left before the time based service. i have completed the required work with genuine audi parts. i dont feel there is any point just resetting service indicators if the work hasn't been done.
thanks for taking the time in explaining how it works
really appreciate the help
