0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
Lars
Norway
C?ID=113210
Hi all good ppl .
Again let me thank you for all previous help .
In the last months my ACC has been misbehaving , sometimes works , sometimes not . Sometimes out for a couple of days and
then working again. Now it is constant faulty , unavailable . Triggering all kind of faults . Please have a look at the attached code .
?? 0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
Where and what sensor is this . Is it something that has come loose ?
The car is a 2015 Passat 2.0 TDI 150 bhp, AreaView and Activeinfo.
You are the best .
-Lars
Thursday,13,May,2021,08:43:49:08594
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4543.4
VIN: WVWZZZ3CZFE454224   License Plate:
Mileage: 175938km-109322mi   Repair Order: Etter Autolakk Mai 2021
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
          69 6C 6D A5 BB BC CA CF
VIN: WVWZZZ3CZFE454224   Mileage: 175938km-109322miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2.0l TDI   X21 1990
   Revision: B5X21---
   Coding: 011D003A04741D083000
   Shop #: WSC 26214 051 00000
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
   ROD: EV_ECM20TDI01104L906026FL.rod
   VCID: 804CFC9E1B22118B43-80D4
17156 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 24
                    Mileage: 175765 km
                    Date: 2021.05.12
                    Time: 09:46:21
                    Engine RPM: 0.00 /min
                    Coolant temperature: 30 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.460 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
17159 - Databus
                    Mileage: 175766 km
                    Date: 2021.05.12
                    Time: 15:41:33
                    Engine RPM: 1635.50 /min
                    Normed load value: 4.3 %
                    Vehicle speed: 24 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 83 °C
                    Voltage terminal 30: 14.480 V
                    Engine status: COENG_RUNNING
   Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4801
   Revision: 03253104    Serial number: TFK01501180602
   Shop #: WSC 05311 115 00086
   ROD: EV_TCMDQ250021.rod
   VCID: 9660BAC669A68F3B89-80C2
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 H    HW: 3Q0 907 379 H
   Component: ESC           0906
   Revision: 00000000    Serial number: 43454000000193
   Coding: 0FEC6A8F34250B700779060241C749F0562CD0E0608292F5B862F078CAA2
   Shop #: WSC 33613 001 104857
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034001
   VCID: BFCE3F62265CAE737A-80EA
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0357960293
   Coding: 000F0F0703
   Shop #: WSC 05311 115 00015
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB.rod
   VCID: F7BE97424EEC563372-80A2
   Part No SW: 5G0 907 044 AK    HW: 5G0 907 044 AK
   Component: Climatronic   H03 Climatronic   H03 10011001
   Revision: 00001K10
   Coding: 12020124204101012115500000101802
   Shop #: WSC 00015 115 08193
   ROD: N/A
   VCID: F0ACAC5E2B82010BB3-80A4
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86581501151000
   Coding: 00971E46C2410AFF53C44004001C57081C80000000000000000000000000
   VCID: FDB2856A6CD07C6328-80A8
   Component: WWS    141015  042 0607
   Serial number:         141017185456
   Component: RLHS  037 0059
   Serial number: S4Y15M01D28H14M30S18
   Coding: 06A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Component: E1 - LDS MQB  H01
   Serial number: 28 11 2014  00000861
No ASAM data for: "Unknown" (VW48)
   Part No SW: 5Q0 919 298 L    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0132
   Serial number: ATW-00114.01.15
   Coding: 0471267151
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_008.rod
   VCID: C8DC24BE7392E9CBCB-809C
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: B32663521A147A138E-80E6
          C1103 00 [009] - -
          [FAULT_ALIGNMENT_NOT_OK]
2172 - Databus
          [FAULT_BRAKINGLIGHT_FAIL]
0862 - Databus
          [FAULT_DIRECTION_OF_TRAVEL_INVALID_SIGNAL]
0935 - Databus
          [FAULT_TRAILOR_LIGHT_DEFECTIVE]
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 224
                    Mileage: 175765 km
                    Date: 2021.05.10
                    Time: 11:15:03
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 13.1 V
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1PQY99CH
   Coding: 98FCC0C0008000005C5400CC000800000065
   Shop #: WSC 05311 000 08193
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 814AF99A102818834C-80D4
   Left seat belt tensioner:
   Serial number: 3G1857705E0028P00758
   Coding: 80000A
   Right seat belt tensioner:
   Serial number: 3G1857706E0028P00138
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 001 701 15
   Serial number: 3576U0000004B0189110
   Subsystem 4 - Part No SW: -----------    HW: 454 001 801 15
   Serial number: 3586U000000036FCD21I
   Subsystem 5 - Part No SW: -----------    HW: 454 801 701 15
   Serial number: 3516R3B3D89050000008
   Subsystem 6 - Part No SW: -----------    HW: 454 801 701 15
   Serial number: 3526R7C3AB505000000A
   Subsystem 7 - Part No SW: -----------    HW: 454 801 801 15
   Serial number: 3556V1E129205000000+
   Part No SW: 3Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150117500554
   Coding: 0C10
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 798 A    HW: 3G0 920 798 A
   Component: KOMBI         018 0450
   Coding: 07E409186F8C00081D886A2B3003000000000000
   Shop #: WSC 00040 218 12345
   ASAM Dataset: EV_DashBoardVDDMQBAB 009041
   VCID: AE107226F13657FBE1-80FA
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   VCID: B6205A4609666F3BA9-80E2
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001074820
   Revision: --------    Serial number: 15011510801157
   Coding: 030300344F017300EF00025E1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: F2A8A656258E331B45-80A6
   Generator:
   Component: E221__MFL-DC1  H16 0040
   Serial number: 36150000004310025021
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 5881435403
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 1301201500010777
   Serial number: 14000318762010
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: F1AAA95A20880803BC-80A4
   Part No SW: 3Q0 907 566 A    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0227
   Revision: --------
   Coding: 14C002
   Shop #: WSC 32887 001 104857
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
1311126 - Control Module for Lane-Change Assist
          C1114 F0 [009] - Automatic Calibration Not Possible
                    Reset counter: 183
                    Mileage: 175765 km
                    Date: 2021.05.10
                    Time: 11:06:53
                    Control Module temperature: 27 °C
                    Voltage terminal 30: Measuring value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measuring value not available
                    Voltage terminal 15: 14.00 V
1192264 - Databus
          [databus error value received - PH_Tongeber_H_verfuegbar]
                    Fault Frequency: 8
                    Reset counter: 223
                    Mileage: 175765 km
                    Date: 2021.05.11
                    Time: 09:05:31
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 11.90 V
   Serial number: 140115BA60530A
   Coding: 003F0B20D000028000001000
   VCID: C2C8369655AEC39B15-8096
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000126999
   Coding: 01010011005000
   Shop #: WSC 00015 115 00015
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: BB364B723244B25356-80EE
   Serial number: 130115BAD08173
   Coding: 003F0120D000028000001000
   VCID: C1CA399A50A8D8830C-8094
   Component: AFS-ECU       H01 0110
   Coding: 039A00004F210200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3G0 035 021 H    HW: 3G0 035 021
   Component: MU-H-TND-EU   H41 1100
   Serial number: A596A0F7500272
   Coding: 02840201FF00000011111201000808101F0100A4012000009E
   VCID: 9D72A5EA8C90DC6348-80C8
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9PU300HTK
   Subsystem 2 - Part No SW: V03 959 800 QR    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Compact disc data bank:
   Component: Gracenote2  --- 1008
   Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
   Component: Anhaenger     H14 0137
   Revision: 8A001001    Serial number: 0358450784
   Coding: 0100000202000000
   VCID: B83C547E0372994BBB-80EC
Address 6C: Back-up Cam. (J123)       Labels:* None
   Part No SW: 5Q0 907 556     HW: 5Q0 907 556
   Component: TopView       H11 0328
   Serial number: C854706JG000568
   Coding: 01840201E70F200000204814
   Shop #: WSC 05311 115 00121
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003011
   ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
   VCID: F6A09A4649E62F3B69-80A2
   Part No SW: 5Q0 959 107 E    HW: 5Q0 959 107 E
   Component: HDSG-Modul    H12 0233
   Revision: --------
   Coding: 0280
   ASAM Dataset: EV_DeckLidCONTIAU736 Unknown
   VCID: BA384E763D7E8B5B4D-80EE
   Part No SW: 3Q0 980 653 C    HW: 3Q0 980 653
   Component: MQB_B_MFK     H08 0061
   Serial number: 19011511P10745
   Coding: 00040802000004010022234FC040A900980084200040
1123187 - Local Data Bus
          U116B 00 [009] - Received Malfunction Value
          [RDR1_Header_FGN_Status]
                    Fault Frequency: 27
                    Reset counter: 184
                    Mileage: 175765 km
                    Date: 2021.05.12
                    Time: 09:40:58
                    Control Module temperature: 55 °C
                    Outside temperature: 18.0 °C
                    System run time: 3133.9 s
                    Voltage terminal 15: 14.3 V
                    mid: 02 BA
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 6
                    Software_Info_2: 0
                    Software_Info_1: 0
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 130115CAC13427
   Coding: 000E01200100028000001000
   VCID: C4C4308E4FBACDAB27-8090
   Component: TSG HBFS      020 0028
   Serial number: 130115CAC13416
   Part No SW: 4M0 907 594 B    HW: 4M0 907 594
   Component: SAD_STG_1     009 0002
   Coding: 608040748202
   VCID: B5225D4A14606423A0-80E0
   Part No SW: 3Q0 907 590 A    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
End----------(Elapsed Time: 05:11, VBatt start/end: 12.6V/12.6V)-----------
it's called "J428" in the WD and it's the radar that's mounted on the center front panel of the car (somewhere) - like this on a Golf mk7
Assuming that the front panel/bumper hasn't been moved or hit - physically eyeball the fixings on the radar unit; is it seated into its correct position? Unfortunately, re-calibration of the radar (officially) is a dealer task because it needs a special aiming device.
That said, there is a DIY tutorial HERE where @VAG-Dave describes how he dealt with the DTC on his MQB platform car
Lars
Norway
C?ID=113210
Thank you for your quick reply. :-)
I had a look at this after some googling. Mine is behind the emblem of the grille. Removed the grille
The sensor is "seated" and snapped into place . The sensor is "Thight" fit. The car is not damaged in the front.
Unplugged it to check for water / moisture in the plugg . Dry as a dessert.
From your picture it seems my front camera is connected to the radar ? For info my front camera is working .
Could it be a faulty radarunit ? If i buy a replacement will it Auto-Calibrate ?
Regards - Lars
Lars
Norway
C?ID=113210
I will have a look at the Tutorial mentioned in the answer from DV52 tomorrow
- Lars
Lars
Norway
C?ID=113210
Hello
Started to look at this now . I can not find "reset misalignment angle" in my -13 13 Auto Dist. Reg..?
I can use 20103 for security access but still no reset misalignment.
When i try 14117 for security code it is refused. I understand from reading the 14117 should make the reset misalignment angle show up ?
How to proceed ?
NEtech
Denmark
C?ID=56995
Different radar, look at last link from Uwe #10
Different [Output Tests-03] has to be used and then adjusting screws on the radar, together with Calibration boards.
Lars
Norway
C?ID=113210
Dont have Calibration Boards. Have to leave it to the shop .
Yet another VW that is to the shop way to often.
Seems as quick as the warrant has expired all sorts of strange faults apear.
But since there has been no damage to the front of the car why is this item suddenly not calibrated.
Another blow to the stumach before the weekend.....
Lars
Norway
C?ID=113210
Can I in some way "simulate" the calibration boards ?
Lars
Norway
C?ID=113210
Look at that :-)
I have a radarsensor in the center of the car behind the grill emblem.
Have used the most of the day on this and i am starting to think thhere is something wrong with the unit/radar.
Parked the car level , about 120 cm from the garage door. The garagedoor is metal so it is reflective.
I opened 03 and started the alignement prossedure.
Measuring :
Missalignement angle horiz, 0.373
Missalignement angle horiz fast algorithm. 0.279
Performed Adjustment missalignment angle 0.45
Performed Adjustment Horizontal alignment angle 1.22
Performed Adjustment Vertical offset . -0.65
None of these numbers change at all, even if i block the radar with a metall plate or with my hands .
I can even take the sensor out of its mount and there is no difference.
When i drive and meassure the values the 2 first ones change slightly.
Am i missing something . Could it be a defective unit. As i mentioned earlier it was intermittent to start with.
Lars
Norway
C?ID=113210
I might get a hold of a Radarunit from a working car . Is there any Component Protection in this unit .
Lars: here is a diagram of the "constellation" for the CP network on MQB platform vehicles:
Alas, as you can see - your problematic "radar unit" is captured by CP
And in any event - the act of removing the old J428 and replacing it with a module from another car will most certainly generate a new set of calibration error messages
Lars
Norway
C?ID=113210
Look at that . More errors might occur . Not unlike a VW :banghead:
Dont missunderstand. I like VW, I have had several never Passat`s , but as soon as warranty run out ,things start to happen.
I predict this will be expensive, sounds like replacing this unit demands FEC ?
Lars
Norway
C?ID=113210
Aha :-)
CP removal possible with VCDS ?
I case not it seems my car is not yet paid for , why shoul i pay the local VW dealership for codes and so
on when i already paid for the car .
If this fault ends at the loclal VW dealer I think i should wear a mic while talking to the person behind the desk :-)
Aha :-)
why should i pay the local VW dealership for codes and soon when i already paid for the car?
Unfortunately, the 2 x word (Latin) answer = caveat emptor
Again, dealer only thing.
I'm not certain about Norway, but I know that in the US, UK, and Germany, it is possible for an independent garage to get signed up with VAG to legitimately use ODIS and have access to the mothership's severs. Of course there are considerable bureaucratic and financial hurdles that must be crossed, but in the end, it isn't necessarily "dealer only".
MasterTommy
Amsterdam
C?ID=295586
Radar sensors that are mounted behind the emblem do not have adjustment screws. However, if you removed any plastic bits around that area in the past, for example the radiator grille, or the headlight/headlight frame, make sure all plastic parts are back in their original position and fully snapped in place.
If that checks out and it keeps throwing errors about misalignment, then (properly) recalibrating seems like the only option. I would first triple check the plastic fairings on the front though. The downside of newer electronics is that you’ll have a lot more situations where you have to go to the dealer. The never-mentioned upside though, is that fault codes are pretty damn accurate nowadays. If the radar sensor only throws a misalignment fault, you can bet money on the fact that in 99 out of 100 cases, it is indeed misaligned, as in: it is not in the same position as it was when it was last calibrated, probably in the factory. Bonus fact: if the sensor is actually physically misaligned, it will usually also refuse to be recalibrated until that is solved.
