Tried to change some settings on a '2019 MQB platform model in 09 Central Electronics module through Adaptation menu but received a fault message due to my WSC being with null figures on equipment value (WSC 00020 999 00000). This WSC is common to all modules in my car and believe to just be the factory default code for this car.
I of course get the following message:
"This appears to be an uninitialized module; valid WSC/Importer/Equipment data may be required.
Click [yes] for VCDS to use default values of 12345/123/12345.
Click [no] for VCDS to try the values currently in the module
Click [cancel] to go back and manually edit the values."
Having heard bad stories (setting not accepted, setting accepted but no change, no way of getting back to initial setting etc...) from people entering any values or using default 12345/123/12345 (most certainly with unofficial interface), I still wonder which option to choose. On other module with same message I selected "No" and all went fine, on this one it does not work.
I have 2 options left:
Select "yes" with 12435/123/12345
Select "Cancel" and going back to previous screen, VCDS allows me to change equipment value from "00000" to any number (I would most certainly change it to "00200" which also seems to be factory default on several other cars I checked (with different shop and region code though).
I want my option to be as stealth as possible and that it does not create any issues as above, not brick the module, still being able to go back and change settings. So help is needed because when it's coded it's hard coded and no way of changing it later.
Help! Thx, Phil
Help! Thx, Phil
