Dear all,
I am an A7, 2012MY, having steering stiff and the steering active fault illuminated RED. I got (7341600 - Position Sensor for Motor) DTC stored.
The vehicle always drive on highway, suddenly it illuminated the yellow steering warning light, but after a conner then it illuminated the RED light then the steering became really stiff. No accident involved.
1- We have inspected the wiring and all connections, it all seem to be good, no contamination and no sign of wiring failure.
2- Check the steering movement angle real time on VCDS then it is moving (-,+) correctly according to direction turned.
3- Have tried to clear DTC, but the DTC will not go away.
4- The vehicle is with the owner for one year and never have this kind of sign.
I suspect the active steering module faulty but it will come with a complete gear rack and it is costly to try.
Below is the complete scan, hope to have some distribution from those who experience with this issue.
Wednesday,08,April,2015,11:30:17:52357
VCDS Version: 14.10.2.0
Data version: 20150311
Dealer/Shop Name: PPP AUTO
VIN: WAUSGAFC9CN002829 License Plate: AUDI-A7
Mileage: 74953km-46573mi Repair Order: mr.Pheara
Chassis Type: FC (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 28 36 3B 3C 42 44 46 47
52 53 55 56 5F 62 6C 6D 72 8F 90
VIN: WAUSGAFC9CN002829 Mileage: 74953km-46573miles
Address 01: Engine (J623-CGXB) Labels: 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 A HW: 4G0 907 551 A
Component: 3.0l V6 TFSI H05 0005
Revision: --H05---
Coding: 1A2A0034052600060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551A 002006
ROD: EV_ECM30TFS0214G0907551A.rod
VCID: 275DC6E95E2191190F5-8072
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 E HW: 0BK 927 156 R
Component: 0BK 30TFSIUSA H08 0002
Revision: --H08---
Coding: 001102
ASAM Dataset: EV_TCMAL551211 001014
ROD: EV_TCMAL551211_AU48.rod
VCID: 306F2DB56BEFD6A1DEF-8065
Address 03: ABS Brakes (J104) Labels: 4G0-907-379.clb
Part No SW: 4G0 907 379 HW: 4G0 907 379
Component: ESP PREMIUM H08 0190
Coding: 44A70F0222E5F0405B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: 6ED3F3CDB15B80518C3-803B
0003 - Brake Switch (F)
P0571 00 [008] - Implausible Signal
Reset counter: 82
Mileage: 74699 km
Date: 2015.04.01
Time: 13:27:46
0607 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 86
Mileage: 74741 km
Date: 2015.04.02
Time: 18:35:55
0632 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 91
Mileage: 74857 km
Date: 2015.04.06
Time: 10:17:42
0697 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 53
Mileage: 74952 km
Date: 2015.04.08
Time: 10:13:30
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AR HW: 4H0 907 064 AR
Component: BCM2 2.0 H24 0217
Coding: 0D8A2000000000000000
VCID: 79F9D091F015D7E9291-802C
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H11 0056
Serial number: 03031100040133
Coding: 6603207A08
ASAM Dataset: EV_AirCondiComfoUDS 002029
ROD: EV_AirCondiComfoUDS.rod
VCID: 285FC5D5533F9E6106F-807D
0247 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 82
Mileage: 74699 km
Date: 2015.04.01
Time: 13:27:19
0315 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 72
Mileage: 74546 km
Date: 2015.03.27
Time: 12:02:28
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000000809454
Coding: 02002091163C9FE0C1008884A0003928CF9CD208A2080125800008402000
VCID: 2C5739C54FC7B241E27-8079
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119
Component: WWS57X 110222 H32 0051
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 8K0 959 772 C HW: 8K0 959 772
Component: SLR-B8 H05 0006
Coding: 853000
Subsystem 5 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Reset counter: 72
Mileage: 74546 km
Date: 2015.03.27
Time: 12:01:00
02258 - Door Opener Transmitter
Reset counter: 29
Mileage: 74477 km
Date: 2015.03.25
Time: 17:39:00
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 A HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0470
Revision: 00000006
VCID: 2B553AD94AC9B579EBD-807E
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 J HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0032
Revision: 11001001 Serial number: 55931100404103
Coding: 300104
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000.rod
VCID: 39791091B89517E9691-806C
Address 15: Airbags (J234) Labels: None
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H31 0032
Revision: -------- Serial number: 003D80012L8D
Coding: 303145313131303030314A55304C34473853
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 336522B99AF9EDB9A3D-8066
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y1100002FBS0P
Serial number: 3575HRB404R0G68U40CE
Serial number: 3585HRB404P0G68U38T.
Serial number: 3515JRB405509GGS99BB
Serial number: 3525JRB405509GGSC904
Serial number: 3554VRB404T6PGAKH17A
Serial number: 3564VRB40516PGAKI0Q3
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110307000833
Coding: 000014
VCID: 306F2DB563EFD6A1DEF-8065
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H07 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 981 E HW: 4G8 920 981 E
Component: TBenUsa H34 0309
Revision: 19100073 Serial number: 658140211593025
Coding: 0BE601060B03D705020100
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K.rod
VCID: 35611CA1948DF3898D9-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000108188
Coding: 00C1033000
ROD: EV_GatewUDS_AU57.rod
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650685743
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0056
Serial number: 03031100040456
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 2F6D2EC976D1C959C75-807A
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00001002253942
Coding: C0581B008F002001000001010101102030303232203232
VCID: 387F15958B9F0EE196F-806D
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200F2EV0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: 2D5134C17CDDBB49F59-8078
Address 3C: Lane Change Labels: None
Part No SW: 4G0 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 010 287-01
Coding: 0000007
VCID: 2F6D2EC9BED1C959C75-807A
Subsystem 1 - Part No: 4G0 907 568 C
Component: J770 SWA Slave H01 0020
Subsystem 2 - Serial number: 6PZ 010 287-21
Subsystem 3 - Serial number: 5F27.11.1000H010003CD22612ÿ
Subsystem 4 - Serial number: D22612ÿ
01024 - Rain Sensor (G213)
Reset counter: 72
Mileage: 74546 km
Date: 2015.03.27
Time: 12:02:26
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 C HW: 4G8 959 793 A
Component: TSG FA H04 0210
Coding: 011F57225E00628002000002
Shop #: WSC 02312 785 00200
VCID: 408F7D75D34F46212EF-8015
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 G HW: 4G0 909 144 F
Component: RCEPS H32 0005
Revision: 00001000 Serial number: 0026042050
Coding: 101000010000
ASAM Dataset: EV_RCEPS 005004
ROD: EV_RCEPS.rod
C10AD 29 [008] - Signal Implausible
Reset counter: 93
Mileage: 74925 km
Date: 2015.04.07
Time: 16:11:24
7341570 - Position Sensor for Motor
C10AD 29 [137] - Signal Implausible
Mileage: 74952 km
Date: 2015.04.08
Time: 10:12:54
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0143190818
Coding: 0126023A20FAF48580B00A80020100000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0070
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H07 0006
Coding: 001F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
01403 - Glass-Break Sensors; Rear
Reset counter: 29
Mileage: 74477 km
Date: 2015.03.25
Time: 17:39:33
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
Reset counter: 91
Mileage: 74513 km
Date: 2015.03.26
Time: 14:22:34
00218 - Humidity Sensor (G355)
Reset counter: 72
Mileage: 74546 km
Date: 2015.03.27
Time: 12:02:25
02615 - Fuel Tank Cap; Lock
Fault Status: 00101001
Reset counter: 89
Mileage: 74846 km
Date: 2015.04.05
Time: 14:50:18
Part No SW: 4G0 035 223 A HW: 4G0 035 223 A
Component: BOSE G3 C7 H07 0070
Revision: CJ007000 Serial number: 00000000023730
VCID: 1B35EA191A6945F99BD-804E
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
VCID: 3F8D7E89AEB139D9575-806A
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000047494
ROD: EV_ParkiBrake_AU48.rod
VCID: 2A5B3FDD4D33AC7110B-807F
Address 55: Headlight Range (J431) Labels: 4H4-907-357.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0011
Serial number: 110218-0004-029
Coding: 1223A633701AA400
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
H01 0010
Coding: 3A0000
H01 0010
Coding: 3A0000
0010 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 72
Mileage: 74546 km
Date: 2015.03.27
Time: 12:02:26
Part No SW: 4G0 035 082 A HW: 4G0 035 082
Component: Radio U SIRIU H51 0068
Revision: AB001007 Serial number: 156CW0B7501647
Coding: 020007010000000001
VCID: 1E33E30D097B50D17C3-804B
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 746 HW: 4G0 035 746
Component: H-BNT-NA H48 0294
Revision: -------- Serial number: 031CR0B7502748
Coding: 090200040003E1EF55128B2E000000031000010000000000
VCID: 64C791E567973A01EA7-8031
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Subsystem 3 - Part No SW: 4G1 919 612 L HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0120
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
03787 - Rotation Mechanism for Display Module Front
Reset counter: 90
Mileage: 74889 km
Date: 2015.04.06
Time: 19:52:36
Voltage: 12.50 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F17224000628002000002
VCID: 428B777DDD43543138B-8017
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J12F0JD
Coding: 1020013
VCID: 2541CCE1EC2D83093D9-8070
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G8 959 107 E HW: 4G8 959 107 A
Component: HDSG-Modul H12 0036
Revision: 12012001 Serial number: 044100466
Coding: 0A3205C100
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 377D16A98E8101999F5-8062
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0210
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FEDEEC9B6518959875-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70EFEDB5AB6F96A19EF-8025
End-------------------------(Elapsed Time: 05:44)--------------------------
