Case Study: using VCDS during brake rotor and pads change on 2019 Jetta S with electric brake
macasoft
TN, USA
C?ID=441023
You have to rewind the electric motor, otherwise cannot push back the cylinder
- Be sure the eBrake is NOt engaged
- VCDS, 03-ABS brake system, lower right, Basic functions, select Start lining change. You hear the motor rewinds
Change the pads, push back the cylinder (open the cap, be sure no extra oil coming out), reassemble the brake. DO NOT PUSH on the brake pedal!
- VCDS, 03-ABS brake system, lower right, Basic functions, select End lining change. You hear the motor engaging
On the net I found a video about it, and people do all crazy things to rewind the motor. You have VCDS, use it.
