Hi, I have here a 2014MY Seat Leon with a TPMS fault after a few mins of driving on the MFD. There is only one fault in the whole car in ABS, for the switch for the TPMS (which is integrated to the 5F unit). In adaptions of the 5F all options are 'activated' for the TPMS. I customer tells me they have owned the car for 5 years without any issue, and this problem has suddenly appeared (of course I don't belive them ). The car has been to another shop before here and I don't know if any coding has been changed. In the cluster TPMS is set to indirect. Can anyone check if the ABS coding is correct for this? Thanks
Wednesday,05,May,2021,08:59:06:42762
VCDS Version: 21.3.0.0 HEX-NET2 CB: 0.4543.4
VIN: VSSZZZ5FZER018055 License Plate: 2014 LEON TDI MQB
Mileage: 102061km-63417mi Repair Order: TPMS FAULT
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: VSSZZZ5FZER018055 Mileage: 102061km-63417miles
Address 01: Engine (J623-CKFC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5514
Revision: 83H22---
Coding: 01190012032501090000
Shop #: WSC 00049 770 00187
ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79A486BA19532263C8D-802C
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 61583000000102
Coding: 20EE8A92242109740077060541C8240451249000608224F200410060C002
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 4BC80C72034F60F32A1-801E
8342 - Switch for Tire Monitoring System Display
C10C6 29 [009] - Signal Implausible
Reset counter: 120
Mileage: 101550 km
Date: 2021.04.26
Time: 16:37:39
Part No SW: 5F0 907 044 D HW: 5F0 907 044 D
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 00100104200100011005000000101000
Shop #: WSC 00049 770 00106
ASAM Dataset: EV_ACClimaBHBVW37X 003017
VCID: 270090C2BF676493EE9-8072
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011316902046
Coding: 0B000842424102FB0BA44000B10403081008000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 48C2337E12398BEB073-801C
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130604 041 0574
Serial number: 130606161315
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M06D26H17M47S06S1
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY131081RL2
Serial number: 00000000000057164501
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231316300036
Coding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002016
VCID: 3A2659B65CD5E97B817-806E
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 011 0188
Revision: -------- Serial number: 003P4PCA100.
Coding: 98CCC000000000005C0000CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5068A207770C53F69-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 306 13
Serial number: 3576U000000DB0492D0H
Subsystem 2 - Part No SW: ----------- HW: 454 000 606 13
Serial number: 3586U000000368706D09
Subsystem 3 - Part No SW: ----------- HW: 454 801 906 13
Component: SideSensor_Dr 111 0148
Serial number: 3516RC3167C01000000+
Subsystem 4 - Part No SW: ----------- HW: 454 801 906 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R46B67C010000004
Subsystem 5 - Part No SW: ----------- HW: 454 801 705 13
Component: FrontSensor_D 114 0149
Serial number: 3556V0C405E010000000
Part No SW: 5Q0 953 507 AC HW: 5Q0 953 549
Revision: -------- Serial number: 26061308490916
Coding: 9400
VCID: 77A080822F473413BE9-8022
Part No SW: 5F0 920 961 H HW: 5F0 920 961 H
Component: KOMBI 203 2210
Coding: 27A402002180260001082A0C000000
Shop #: WSC 00078 790 12345
ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
VCID: 2E0E65E6909D35DB2DF-807A
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1144
Revision: -------- Serial number: 0000747914
Coding: 030100F40B087600EF000248080F00010001000000000000000000000000
ROD: EV_GatewLear_009.rod
Generator:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0441250513
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051663181
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000065101116
Coding: 00100220C001020000001000
VCID: 0256E156748561BB997-8056
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000295083
Coding: 2D0000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D2C52AA4DFBDE43A45-8068
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000063965147
VCID: 0154EE5A71837AA380D-8054
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000287952
Coding: 350000
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 5F0 035 824 A HW: 5F0 035 824 A
Component: MU-S--ER 040 0407
Serial number: E1E02606131203
Coding: 04730000FF0A000021110001000800002F0106060100010002
ASAM Dataset: EV_MUStd6C3PASE 002029
ROD: EV_MUStd6C3PASE.rod
VCID: 221681D6D44581BBB97-8076
Subsystem 1 - Part No SW: 5F0 919 603 HW: 5F0 919 603
Component: ABTmin_Std_Rd H45 0020
Serial number: SEZ8Z9M55004AP
End----------(Elapsed Time: 01:12, VBatt start/end: 12.2V/12.2V)-----------
