Drl light does not work golf mk6
cleo
Norway
C?ID=330917
hi i have some trouble with drl light.
Tried to put on led bulb on cornering light and after that the drl lights disappeared and do not get life in them anymore now?
Wednesday,05,May,2021,17:06:57:36574
VIN:    License Plate: GOLF 6
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 5K0 937 087 M    HW: 5K0 937 087 M
  Component and/or Version: BCM PQ35 H    011 0045
           Software Coding: 23180CB8982D02C04008008074008BE447750008733D2560808020200040
            Work Shop Code: WSC 00066 123 12345
                      VCID: 3FDBBE2A07755113B69-806A
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 182
                    Mileage: 250362 km
                    Date: 2053.14.10
                    Time: 00:21:31
                    Voltage: 13.80 V
                    Reset counter: 182
                    Mileage: 250362 km
                    Date: 2053.14.10
                    Time: 00:21:31
                    Voltage: 13.80 V
Wednesday,05,May,2021,17:23:09:36574
VIN: WVWZZZ1KZBM662266   License Plate: GOLF6
Mileage: 250360km-155566mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 52 55 56 62 69
          72 77
VIN: WVWZZZ1KZBM662266   Mileage: 250360km-155566miles
2E-Media Player 3 -- Status: Sporadic communication error 1000
77-Telephone -- Status: Malfunction 1010
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 AN    HW: 03L 907 309 R
   Component: R4 2.0l TDI   H22 9979
   Revision: 42H22---    Serial number: 00000000000000
   Coding: 0019001A042400080000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018AN 003012
   ROD: EV_ECM20TDI01103L906018AM_003_VW36.rod
   VCID: 76B51B0E684FD05BA5F-8022
4635 - Engine Oil Temp. Sensor (G8)
          P0196 00 [032] - Implausible Signal
                    Mileage: 250116 km
                    Date: 2021.05.02
                    Time: 10:53:17
                    Engine RPM: 1020.00 /min
                    Normed load value: 18.8 %
                    Vehicle speed: 9 km/h
                    Coolant temperature: 79 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 14.080 V
                    Unlearning counter according OBD: 34
                    Fuel consumption: 0.67 l/h
                    Engine oil temperature: 78.7 °C
                    Oil warning threshold: 22.572 mm
                    Control Module temperature: 19.3 °C
                    Oil fill level: 44.936 mm
                    Outside temperature: 10.0 °C
                    Fuel temperature: 22.6 °C
   Revision: 00H31001
   Coding: 143B600D092800FC280D06EA901F0042350000
   Shop #: WSC 00066 000 00000
   VCID: 76B51B0E68CFD05BA5F-8022
02214 - Tire Pressure Warning
                    Reset counter: 191
                    Mileage: 249203 km
                    Date: 2015.08.21
                    Time: 14:38:11
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50690
                    Count: 769
   Part No SW: 5K0 907 044 EC    HW: 5K0 907 044 EC
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00066 000 00148
   VCID: 70B92D160A2BFE6B7F3-8024
   Part No SW: 5K0 937 087 M    HW: 5K0 937 087 M
   Component: BCM PQ35 H    011 0045
   Revision: BE011001
   Shop #: WSC 00066 123 12345
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 23121  26  0512
   Coding: 009795
   Component: RLS 291210 05  54  0403
   Coding: 03302D
                    Reset counter: 182
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 00:22:50
                    Voltage: 13.95 V
                    Reset counter: 182
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 00:22:50
                    Voltage: 13.95 V
                    Fault Status: 00101010
                    Reset counter: 222
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 00:21:31
                    Voltage: 13.80 V
                    Reset counter: 222
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 00:21:31
                    Voltage: 13.80 V
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 1K9 919 475 A    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0004
   Revision: --------    Serial number: 12591035145398
   Coding: 118003
   VCID: 392FD03219517F2388D-806C
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    012 0612
   Serial number: 003G6D03GXW-
   Coding: 00003536
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 323DE71EC4A78C7B497-8066
   Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME5D630459ZZZ
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME370C513DZZZ
   Serial number: 3511HSME59277E24ZZZV
   Serial number: 3521HSME682E7E24ZZZ$
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JKA001HJ
   Coding: 1082140000
   Shop #: WSC 00066 000 00195
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72BD271E0427CC7B897-8026
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0184926
   Coding: 820000
   Part No SW: 5K0 920 871 A    HW: 5K0 920 871 A
   Component: KOMBI         H23 0210
   Revision: X0023007    Serial number:
   Coding: 170F01
   Shop #: WSC 17196 002 1048576
   ASAM Dataset: EV_KombiUDSMM9RM10 A04203
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 2C01F966E683DA8B03B-8078
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 A
   Component: Standheizer     043 4730
   Revision: 00043000    Serial number: 09022127000000
   Coding: 0031012
   Shop #: WSC 80093 222 71269
   VCID: 3333E21A373D8573421-8066
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 23121001210382
   Coding: 352002
   VCID: 3039ED16CA2BBE6B3F3-8064
                    Fault Status: 00110100
                    Fault Frequency: 20
                    Reset counter: 222
                    Mileage: 249671 km
                    Date: 2015.09.11
                    Time: 10:58:45
03272 - Control Module for Audio Interface
                    Reset counter: 207
                    Mileage: 249930 km
                    Date: 2015.09.14
                    Time: 13:11:21
   Part No SW: 5K0 953 234     HW: 5K0 920 871 A
   Component: IMMO          H23 0210
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
   VCID: 6A8D3F7E2CF704BB317-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668831470
   VCID: 270B064AFFE5F9D3EE9-8072
   Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0307
   Revision: 12101005    Serial number: 0001769714
   Coding: 0010B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 28090576F27BF6ABE73-807C
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005406043
   Coding: 000090
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 182
66561 - Motor for mirror fold-in
          B11F6 01 [009] - Electrical Failure
                    Reset counter: 124
                    Mileage: 248079 km
                    Date: 2021.02.24
                    Time: 10:14:15
132610 - Motors for Rear Central Locking
          B122C 01 [009] - Electrical Failure
                    Reset counter: 117
                    Mileage: 247870 km
                    Date: 2021.02.10
                    Time: 14:55:53
132866 - Switch for Rear Central Locking
          B122E 29 [009] - Signal Implausible
                    Fault Frequency: 214
                    Reset counter: 182
                    Mileage: 247870 km
                    Date: 2021.02.10
                    Time: 14:55:53
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 313FE812CD21B76330D-8064
   Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0307
   Revision: 14101005    Serial number: 0001761345
   Coding: 0001B4
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 290F0072E971CFA3F8D-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005418202
   Coding: 000090
66821 - Position Sensor for Mirror Adjustment
          B11FA 29 [009] - Signal Implausible
                    Reset counter: 115
                    Mileage: 247796 km
                    Date: 2021.02.04
                    Time: 12:23:15
   Coding: 1442908
   VCID: 3431E1063233824B5BB-8060
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000022
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
   Component: Radio RCD510  041 0166
   Revision: 00000001    Serial number: VWZ1Z3K9801966
   Coding: 0800040104
   VCID: 26150B4EF8EFE0DBD5F-8072
                    Fault Frequency: 19
                    Reset counter: 222
                    Mileage: 250363 km
                    Date: 2015.09.26
                    Time: 15:46:35
                    Reset counter: 207
                    Mileage: 249930 km
                    Date: 2015.09.14
                    Time: 13:26:26
   Component: Anhaenger     H07 0100
   Revision: 3A001001    Serial number: 00000138625053
   Coding: 410D000100000000
            011 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10101011
                    Reset counter: 222
   Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668876529
   Coding: 0200010000000001
   ASAM Dataset: UHVNA A01007
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 313FE812C1A1B76330D-8064
          U1014 00 [009] - -
                    Reset counter: 161
                    Mileage: 249616 km
                    Date: 2021.04.14
                    Time: 13:44:16
End----------(Elapsed Time: 01:27, VBatt start/end: 12.1V/12.1V)-----------
          72 77
                    Mileage: 250116 km
                    Date: 2021.05.02
                    Time: 10:53:17
   Revision: 00H31001
                    Reset counter: 191
                    Mileage: 249203 km
                    Date: 2015.08.21
                    Time: 14:38:11
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50690
                    Count: 769
   Revision: 00003001
   Coding: 0000000002
   Revision: BE011001
   Coding: 009795
   Coding: 03302D
                    Reset counter: 182
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 00:22:50
                    Voltage: 13.95 V
                    Reset counter: 182
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 00:22:50
                    Voltage: 13.95 V
                    Reset counter: 222
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 00:21:31
                    Voltage: 13.80 V
                    Reset counter: 222
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 00:21:31
                    Voltage: 13.80 V
   Coding: 118003
   Coding: 00003536
   Coding: 1082140000
   Coding: 820000
   Coding: 170F01
   Coding: 0031012
   Coding: 352002
                    Fault Frequency: 20
                    Reset counter: 222
                    Mileage: 249671 km
                    Date: 2015.09.11
                    Time: 10:58:45
                    Reset counter: 207
                    Mileage: 249930 km
                    Date: 2015.09.14
                    Time: 13:11:21
   Coding: 0010B5
   Slave Driver:
   Coding: 000090
                    Reset counter: 182
                    Reset counter: 124
                    Mileage: 248079 km
                    Date: 2021.02.24
                    Time: 10:14:15
                    Reset counter: 117
                    Mileage: 247870 km
                    Date: 2021.02.10
                    Time: 14:55:53
                    Reset counter: 182
                    Mileage: 247870 km
                    Date: 2021.02.10
                    Time: 14:55:53
   Revision: 00H17000
   Coding: 0001B4
   Slave Passenger:
   Coding: 000090
                    Reset counter: 115
                    Mileage: 247796 km
                    Date: 2021.02.04
                    Time: 12:23:15
   Coding: 1442908
   Coding: 00000022
   Coding: 00000022
   Coding: 0800040104
                    Fault Frequency: 19
                    Reset counter: 222
                    Mileage: 250363 km
                    Date: 2015.09.26
                    Time: 15:46:35
                    Reset counter: 207
                    Mileage: 249930 km
                    Date: 2015.09.14
                    Time: 13:26:26
                    Reset counter: 222
          U1014 00 [009] - -
                    Reset counter: 161
                    Mileage: 249616 km
                    Date: 2021.04.14
                    Time: 13:44:16
End----------(Elapsed Time: 01:26, VBatt start/end: 12.0V/12.0V)-----------
Wednesday,05,May,2021,20:54:44:36574
          72 77
                    Mileage: 250116 km
                    Date: 2021.05.02
                    Time: 10:53:17
   Revision: 00H31001
                    Reset counter: 191
                    Mileage: 249203 km
                    Date: 2015.08.21
                    Time: 14:38:11
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50690
                    Count: 769
   Revision: 00003001
   Coding: 0000000002
   Revision: BE011001
   Coding: 23180CB8982D02C04008008174008BE447750008733D2560808020240040
   Coding: 009795
   Coding: 03302D
                    Reset counter: 183
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 04:08:03
                    Voltage: 13.95 V
                    Reset counter: 183
                    Mileage: 250362 km
                    Date: 2015.09.26
                    Time: 04:08:03
                    Voltage: 13.95 V
   Coding: 118003
   Coding: 00003536
   Coding: 1082140000
   Coding: 820000
   Coding: 170F01
   Coding: 0031012
   Coding: 352002
                    Fault Frequency: 20
                    Reset counter: 222
                    Mileage: 249671 km
                    Date: 2015.09.11
                    Time: 10:58:45
                    Reset counter: 207
                    Mileage: 249930 km
                    Date: 2015.09.14
                    Time: 13:11:21
   Coding: 0010B5
   Slave Driver:
   Coding: 000090
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 222
                    Reset counter: 124
                    Mileage: 248079 km
                    Date: 2021.02.24
                    Time: 10:14:15
                    Reset counter: 117
                    Mileage: 247870 km
                    Date: 2021.02.10
                    Time: 14:55:53
                    Fault Frequency: 217
                    Reset counter: 182
                    Mileage: 247870 km
                    Date: 2021.02.10
                    Time: 14:55:53
   Revision: 00H17000
   Coding: 0001B4
   Slave Passenger:
   Coding: 000090
                    Reset counter: 115
                    Mileage: 247796 km
                    Date: 2021.02.04
                    Time: 12:23:15
   Coding: 1442908
   Coding: 00000022
   Coding: 00000022
   Coding: 0800040104
                    Fault Frequency: 19
                    Reset counter: 222
                    Mileage: 250363 km
                    Date: 2015.09.26
                    Time: 15:46:35
                    Reset counter: 207
                    Mileage: 249930 km
                    Date: 2015.09.14
                    Time: 13:26:26
                    Reset counter: 222
          U1014 00 [009] - -
                    Reset counter: 161
                    Mileage: 249616 km
                    Date: 2021.04.14
                    Time: 13:44:16
End----------(Elapsed Time: 01:26, VBatt start/end: 14.0V/14.0V)-----------
Address 09,5K0 937 087 M,recoded (Long Coding),from,23180CB8982D02C04008008174008BE447750008733D2560808020240040,to,23180CB8982D02C04008008174008BE447710008733D2560808020240040,(00066/123/12345),
Address 09: DTCs cleared
Address 09,5K0 937 087 M,recoded (Long Coding),from,23180CB8982D02C04008008174008BE447710008733D2560808020240040,to,23180CB8982D02C04008008174008BE447750008733D2560808020240040,(00066/123/12345),
Address 09,5K0 937 087 M,recoded (Long Coding),from,23180CB8982D02C04008008174008BE447750008733D2560808020240040,to,23180CB8982D02C04008008174008BE447750008733D2560018020240040,(00066/123/12345),
Address 09,5K0 937 087 M,recoded (Long Coding),from,23180CB8982D02C04008008174008BE447750008733D2560018020240040,to,23180CB8982D02C04008008174008BE447750008733D2560818020240040,(00066/123/12345),
Address 09,5K0 937 087 M,recoded (Long Coding),from,23180CB8982D02C04008008174008BE447750008733D2560818020240040,to,23180CB8982D02C04008008174008BE447750008733D2560818028240040,(00066/123/12345),
Address 09,5K0 937 087 M,recoded (Long Coding),from,23180CB8982D02C04008008174008BE447750008733D2560818028240040,to,23180CB8982D02C04008008174008BE447750008733D2560818028200040,(00066/123/12345),
Address 09,5K0 937 087 M,recoded (Long Coding),from,23180CB8982D02C04008008174008BE447750008733D2560818028200040,to,23180CB8982D02C04008008174008BC447750008733D2560818028200040,(00066/123/12345),
Address 09,5K0 937 087 M,recoded (Long Coding),from,23180CB8982D02C04008008174008BC447750008733D2560818028200040,to,23180CB8982D02C04008008174008BE447750008733D2560818028200040,(00066/123/12345)
spido
Romania
HC494068 (?)
You made changes to the bcm coding?
try to remove the battery terminal 2 min
cleo
Norway
C?ID=330917
Can try disconnecting the battery, maybe it helps
can not figure out what has been changed, tried disabling bulb alert but put it back. But maybe something has changed but I can not see what has changed?
Trowbridge, UK
IMHO the fault codes are saying the LED bulb is too high resistance so the cold diagnostics is turning off the power to the bulbs.
So you either need to tell the BCM that you have fitted LED bulbs (if that is supported on the Mk6), find LED bulbs that do not produce the error or (worst case) add resistors in parallel to 'fool' the bulb diagnostics. I'm not a Mk6 expert so will have to duck out at this point.
cleo
Norway
C?ID=330917
The original bulbs in the tealights became very hot almost as they melt the glass and bulb. but where is drl connected can not see there are some fuses that have gone. Is the control tik drl inside the headlight possible also it is incorrectly coded as well
cleo
Norway
C?ID=330917
small update has got back drl when the switch is on auto changed some coding. But now there is a problem with me putting the light switch on park so it is lit at the back but no light at the front. some tips for that. Maybe some codes need to be changed?
@cleo
If you made Coding changes with VCDS the CodingLog.CSV file contents would be very helpful:
If you open the CSV file with Notepad the text can be pasted in reply wrapped in CODE tags (like the scan).
However, if someone made the changes using another PC or another automotive scan tool it will not be extremely easy to build the factory coding strong from scratch. If you believe that's what happened here please let us know if the LED DRLs are OEM (i.e Genuine VW equiptment) and if they are inside the Xenon headlamps -or- separate from the headlamp (possibly located in the bumper or fog lamp area).
cleo
Norway
C?ID=330917
@cleo
Found an old autoscan file do not know if this can be helpful is it possible to see if something has changed on this?
   Coding: 820000
   Coding: 170F01
   VCID: 2C01F966E683DA8BFFB-8078
   Coding: 0031012
   VCID: 3333E21A373D8573BE1-8066
01407 - Flame Extinguished
                    Reset counter: 143
                        Start
                    Temperature: -10.0°C
                    Temperature: -48.0°C
                    Voltage: 11.92 V
   Coding: 352002
   VCID: 3039ED16CA2BBE6BC33-8064
                    Reset counter: 95
                    Mileage: 246565 km
                    Date: 2015.05.29
                    Time: 13:29:01
   VCID: 6A8D3F7E2CF704BBCD7-803E
   Coding: 0010B5
   VCID: 28090576F27BF6AB1B3-807C
   Slave Driver:
   Coding: 000090
                    Reset counter: 105
                    Mileage: 247073 km
                    Date: 2021.01.16
                    Time: 18:05:05
          B122E 29 [008] - Signal Implausible
                    Reset counter: 145
                    Mileage: 247073 km
                    Date: 2021.01.16
                    Time: 18:03:51
   Revision: 00H17000
   VCID: 313FE812CD21B763CCD-8064
Address 46: Central Conv.
   Coding: 0001B4
   VCID: 290F0072E971CFA304D-807C
   Slave Passenger:
   Coding: 000090
                    Reset counter: 105
                    Mileage: 247056 km
                    Date: 2021.01.16
                    Time: 16:57:59
   Coding: 1442908
   VCID: 3431E1063233824BA7B-8060
   Coding: 00000022
   Coding: 00000022
Address 56: Radio
   Coding: 0A01000000010101
   ROD: UHVNA.rod
   VCID: 313FE812C1A1B763CCD-8064
          B104F 13 [009] - Short to GND
                    Fault Frequency: 20
                    Reset counter: 105
                    Mileage: 246989 km
                    Date: 2021.01.13
                    Time: 12:41:36
          B104E 13 [009] - Short to GND
                    Reset counter: 103
                    Mileage: 246989 km
                    Date: 2021.01.13
                    Time: 12:41:36
End----------(Elapsed Time: 01:12, VBatt start/end: 12.2V/12.3V)-----------
Thursday,05,November,2020,20:15:05:36574
Dealer/Shop Name: F526727B
Mileage: 243780km-151477mi   Repair Order:
          72 77
VIN: WVWZZZ1KZBM662266   Mileage: 243780km-151477miles
2E-Media Player 3 -- Status: Cannot be reached 1100
   VCID: 76B51B0E684FD05B78F-8022
   Revision: 00H31001
   VCID: 76B51B0E68CFD05B78F-8022
   Revision: 00003001
   Coding: 0000000002
   VCID: 70B92D160A2BFE6BA23-8024
          B10AB F0 [009] - Too Low
                    Reset counter: 241
                    Mileage: 239605 km
                    Date: 2020.09.02
                    Time: 13:55:33
   Revision: BE011001
   Coding: 01180EBA982D02C040080080740089E443750008733D2560808000200040
   VCID: 3FDBBE2A077551136B9-806A
   Coding: 009795
   Coding: 03302D
   Coding: 118003
   VCID: 392FD03219517F2355D-806C
   Coding: 00003536
   VCID: 323DE71EC4A78C7B947-8066
   Coding: 1082140000
   VCID: 72BD271E0427CC7B547-8026
   Coding: 820000
530190 - Local Databus
          U1030 00 [008] - Electrical Malfunction
                    Reset counter: 92
                    Mileage: 243317 km
                    Date: 2020.11.02
                    Time: 14:21:40
   Coding: 170F01
   VCID: 2C01F966E683DA8BDEB-8078
   Coding: 0031012
   VCID: 3333E21A373D85739F1-8066
                    Reset counter: 78
                    Mileage: 242726 km
                    Date: 2015.03.13
                    Time: 15:01:01
                        Start
                    Temperature: 22.0°C
                    Temperature: 21.0°C
                    Voltage: 14.24 V
   Coding: 352002
   VCID: 3039ED16CA2BBE6BE23-8064
                    Reset counter: 53
                    Mileage: 243783 km
                    Date: 2015.03.29
                    Time: 20:08:22
   VCID: 6A8D3F7E2CF704BBEC7-803E
   Coding: 0000B4
   VCID: 28090576F27BF6AB3A3-807C
   Slave Driver:
   Coding: 000090
   Revision: 00H17000
   VCID: 313FE812CD21B763EDD-8064
   Coding: 0001B4
   VCID: 290F0072E971CFA325D-807C
   Slave Passenger:
   Coding: 000090
                    Reset counter: 241
                    Mileage: 239605 km
                    Date: 2020.09.02
                    Time: 13:56:15
   Coding: 1442908
   VCID: 3431E1063233824B86B-8060
   Coding: 00000022
   Coding: 00000022
Address 56: Radio
   ROD: UHVNA.rod
   VCID: 313FE812C1A1B763EDD-8064
                    Fault Frequency: 22
                    Reset counter: 53
                    Mileage: 243317 km
                    Date: 2020.11.02
                    Time: 13:52:21
                    Reset counter: 52
                    Mileage: 243317 km
                    Date: 2020.11.02
                    Time: 13:52:21
End----------(Elapsed Time: 01:20, VBatt start/end: 12.3V/12.4V)-----------
OK, the first scan was cut short and only contains data from Address 17 and beyond but the second scan had Address 09: Cent. Elect. (J519) coded to:
If this is not resolved yet I would start by pasting that coding back into the 09 module, clearing fault codes and operating the lights to see if there is any improvement.
cleo
Norway
C?ID=330917
Then I tried this pasted the code so I got back the drl lights when the switch is in position 0 and on auto. But when I put it in the park on the switch, it only lights up behind and not in front. So something starts to happen but the error code comes up right away again
cleo
Norway
C?ID=330917
What I wonder is if there is any mistake a place here in the picture if it should be changed to something else.
You do not want to modify Byte 18 if it isn't what caused the problem (otherwise you may create new problems). The CodingLog.CSV file contents would be very helpful so we can see what was modified using VCDS.
cleo
Norway
C?ID=330917
hi i'm wondering how to get into security access and basic settings on channel 09. Does anyone know the code there?
I can not get into Basic Setting?
Does a PQ35 BCM even have any Basic Settings? What is it you think you're going to accomplish there?
No it doesn't support basic settings and it does not require a SA code prior to Coding or Adaptation.
cleo
Norway
C?ID=330917
.I've got light on this car now. But it seems that no parking lights are not installed, so I was wondering if there was something behind the basic settings. or that I could install it inside security access? when switch is on parking light on mass block it is 99% and 00% drl thus no park lights are lit but all other lights are working now.
