ALit
- May 3, 2021
- 3
- 0
- Hawthorne, Ca, USA
- C?ID=440221 (NAC)
Hi ,I have HEX-V2
I have problem with my VCDS program.
I want to change idle speed in my Passat. When I open menu I done not found Idle speed adjustment. Can anyone help me solve this problem?
Wednesday,28,April,2021,10:48:12:47610
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
VIN: WVWLK73C87E003506 License Plate:
Mileage: 292120km-181514mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
6D 72
VIN: WVWLK73C87E003506 Mileage: 292120km-181514miles
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 F HW: 3C0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H10--- Serial number: VWZCZ000000000
Coding: 040C010A19070160
Shop #: WSC 25155 444 52307
VCID: 2313E54487DE67B3B21-8076
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction - Intermittent
Mileage: 292025 km
Date: 2021.04.10
Time: 12:20:40
RPM: 797 /min
Load: 38.8 %
Speed: 1.0 km/h
Temperature: 93.0°C
Temperature: 38.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
001393 - Brake Switch (F)
P0571 - 008 - Implausible Signal
Fault Status: 01101000
Mileage: 292027 km
Date: 2021.04.10
Time: 18:13:29
RPM: 1040 /min
Load: 28.6 %
Speed: 53.0 km/h
Temperature: 71.0°C
Temperature: 29.0°C
Voltage: 13.970 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 008 - Mechanical Malfunction - Intermittent
Mileage: 292029 km
Date: 2021.04.10
Time: 18:20:22
RPM: 2319 /min
Load: 12.2 %
Speed: 116.0 km/h
Temperature: 94.0°C
Temperature: 25.0°C
Voltage: 14.097 V
Readiness: 0000 0001
Part No SW: 09G 927 750 CJ HW: 09G 927 750 CJ
Component: AQ 250 6F 0841
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 05311 000 00000
VCID: 7BA3FD245FEEFF73DA1-802E
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0100000787
Coding: 0046523
Shop #: WSC 25155 444 59542
VCID: 323D1000C824FE3B497-8066
00599 - Plausibility of Pressure/Brake Light Switch
Fault Frequency: 151
Reset counter: 128
Mileage: 291016 km
Date: 2021.03.18
Time: 19:58:39
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
VCID: 698FB76C25727DE338D-803C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000002287148
Coding: 148C8F0340041A00400A00000F00000000285D435C0000
VCID: 372B211423461B137E9-8062
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7E8013042
VCID: 2A0D0860E0F4B6FBF17-807E
Reset counter: 168
Mileage: 292073 km
Date: 2021.04.11
Time: 17:25:59
01304 - Radio
Reset counter: 105
Mileage: 265875 km
Date: 2020.02.13
Time: 00:24:53
Reset counter: 218
Mileage: 276687 km
Date: 2020.07.18
Time: 20:55:22
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0N AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3PQNC8BZ
Coding: 0012366
VCID: 2E050470DC1CDADB2DF-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000031VZ9
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0D335F32Fÿ†63
Subsystem 5 - Serial number: 35F32Fÿ†6342MSME0C63615FKÿ†63
Subsystem 6 - Serial number: 3615FKÿ†6351HTS61IK2TN93Sÿ†63
Subsystem 7 - Serial number: 2TN93Sÿ†6361HTS61IKIQ133Eÿ†63
Subsystem 8 - Serial number: IQ133Eÿ†63727TS6I2IM5OM2Tÿ†63
Subsystem 9 - Serial number: M5OM2Tÿ†63827TS6I2IQHBP2-ÿ
Subsystem 10 - Serial number: QHBP2-ÿ
03032 - Supply Voltage for Seat Occupied Recognition Control Module
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C9953507R
Coding: 0002014
VCID: 313F1F0CCD22C52330D-8064
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Component: KOMBIINSTRUMENT VD1 4240
Revision: X0033000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 25155 067 57207
VCID: 33331504373EF733421-8066
Fault Frequency: 11
Reset counter: 209
Mileage: 290407 km
Date: 2021.03.06
Time: 00:26:41
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05C080608
Coding: 3FFD0E0CD32002
VCID: 211FEF4C9DC275A3A0D-8074
Reset counter: 116
Time Indication: 15
Part No SW: 3C0 919 965 A HW: 3C0 919 965 A
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1339817TPYA502
Reset counter: 108
Part No SW: 3C0 959 433 Q HW: 3C0 959 433 Q
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 22103 444 999999
VCID: 382922282E58146B773-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
01176 - Key
Fault Frequency: 9
Reset counter: 168
Mileage: 265025 km
Date: 2019.09.08
Time: 08:13:33
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0001205
VCID: 36352C10244CE21B65F-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Component: A_ KSG PQ46 RDK 051 0218
Coding: 13900E88D1032E521804141FF00A0F0E081800
Shop #: WSC 25155 444 53427
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio PM6 016 0017
Revision: 00016000 Serial number: VWZ5Z7E2047445
Coding: 0040400
VCID: 2019EA4896C87CABAF3-8074
Fault Status: 00110100
Fault Frequency: 16
Reset counter: 196
Reset counter: 199
Mileage: 291883 km
Date: 2021.04.07
Time: 13:34:59
Fault Status: 00101011
Reset counter: 210
Mileage: 232481 km
Date: 2018.06.11
Time: 17:29:20
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703 A
Component: Tuer-SG 021 2505
Coding: 0000144
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Component: RDK 0420
Coding: 0100100
Fault Status: 01110100
Mileage: 292073 km
Date: 2021.04.11
Time: 15:27:51
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 B HW: 3C9 827 383 C
Component: J605 HECKDECKEL 0405
Revision: 00H20001
Shop #: WSC 23250 384 715754
VCID: 30391A08C628CC2B3F3-8064
Subsystem 1 - Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0405
Subsystem 2 - Serial number: 0600H20001001A0106ÿ
00317 - Rear Lid Control Module (J605)
Reset counter: 210
Mileage: 290173 km
Date: 2019.03.29
Time: 00:01:54
Reset counter: 208
Mileage: 291883 km
Date: 2021.04.07
Time: 13:35:01
Reset counter: 210
Mileage: 290173 km
Date: 2019.03.29
Time: 00:01:54
Reset counter: 210
Reset counter: 210
Mileage: 283006 km
Date: 2020.10.30
Time: 14:06:03
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704 A
Coding: 0000144
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----(Elapsed Time: 01:28, VBatt start/end: 11.4V/11.4V. VIgn 11.2V)-----
