B8.5 A5 ZF8HP 03-ABS Module
jonesn00
Alabama, USA
C?ID=243696
Hello, I have been struggling trying to figure out how to get my APR Stage 2 tune to work nicely with ESP and traction control without having it feel neutered like stock where it's pulling torque. I can go full ESP off and it feels like it should for stage 2. The car is a 2014 Audi A5 with flex fuel CPMB and ZF 8 speed Auto Trans. Nothing wrong mechanically, car is sound. Feels more like torque management cutting in, and trying to experiment with coding of ESP to see if it helps a little. Our platform is dead for TCU tuning help. :(
I understand the precaution of playing with coding in the ABS Module, but I'm wondering if changing from "2D1D1801" to "291D1801" does anything. Seems like the ZF equipped b8's with 4 cylinders ran "2D" in the original coding. The S4/S5 b8s ran "29" at the beginning of the coding of the ABS Module. Does this correlate to letting ABS know which trans the car has or how sporty it is?
I'm attaching my quick scan log. The engine DTC is due to an aftermarket diverter valve, which I have since reverted back to factory with no DTC's set anymore.
P.S: I apologize if this is in the wrong section.
Friday,29,January,2021,18:24:38:24081
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.12.0.1 (x64)  HEX-NET CB: 0.4529.4
VIN: WAUMFAFR9EA072437   License Plate:
Mileage: 147760km-91813mi   Repair Order:
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56
          5F 6C
VIN: WAUMFAFR9EA072437   Mileage: 147760km-91813miles
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 5A2A0013242600062000
   Shop #: WSC 65150 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
   ROD: EV_ECM20TFS0118K5907115N.rod
   VCID: 3D3228FFAC2FBF6C29-8069
7663 - Boost Pressure Control Valve (N249)
          P2261 00 [046] - Mechanical Malfunction
                    Fault Frequency: 146
                    Mileage: 146876 km
                    Date: 2021.01.21
                    Time: 07:09:46
                    Engine RPM: 1829.50 /min
                    Normed load value: 4.3 %
                    Vehicle speed: 78 km/h
                    Coolant temperature: 57 ∞C
                    Intake air temperature: 11 ∞C
                    Voltage terminal 30: 14.088 V
                    Engine status: COENG_RUNNING
Readiness: 0010 0000
   Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H18 1005
   Revision: --H18---
   Coding: 000002
   VCID: 47DE4A17FEF3E5BC83-8013
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 2D1D1801
   Shop #: WSC 06325 123 12345
   VCID: 095A8C2FA06753CC55-805D
   Part No SW: 8K0 907 064 JM    HW: 8K0 907 064 JM
   Component: BCM2 2.0      H14 0650
   Coding: 05804040000000000000
   Shop #: WSC 06325 000 00000
   VCID: 04449D1B87450EA426-8051
   Serial number: 0214000076129001
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0077
   Revision: AA000000    Serial number: 00000100138425
   Coding: 08037025002400001000
   VCID: 45C2401FCCFFF7AC71-8011
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01020520140148
   Coding: 6482608000
   VCID: 77BEFAD7C693553C33-8023
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000808589201
   Coding: 26000091873CAFE00181408300003D0DCF9CD288A2090221000008004000030100000030000000
   VCID: 78BCF9EBCB8D5A443A-802D
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 240414  H15 0080
   Serial number: SWF14044245454
   Coding: 00FD11
   Serial number: 22578244
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002304140242
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RBAYT03
   Serial number: B729C327000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KJDC0904.
   Coding: 303343334830303030304A55304C38543053
   VCID: 4AD87323EDE118D49C-801F
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R140000KP6N
   Serial number: 6334MSME445D6813H
   Serial number: 6344MSME445D31116
   Serial number: 6352QSME153D1B44J
   Serial number: 6362QSME684102504
   Serial number: 63732SME0C40577C3
   Serial number: 63832SME0F402D483
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NE3001M8
   Coding: 000036
   VCID: 48DC492BFBEDEAC48A-801D
   Part No SW: 8T0 920 984 N    HW: 8T0 920 984 N
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: Z9F25NP4F
   Coding: 8FBF01000301D705020000
   VCID: 4AD87323E5E118D49C-801F
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z1442502C6
   Coding: 80C303FF00
   VCID: 4CD4753BEF9506E4AE-8019
   Serial number: 9280113303
   Component: MEM-FS        H10 0077
   Revision: AA000000    Serial number: 00000100135684
   Coding: 081B7B25002400001000
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0332695096
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3FCE52F7A623AD7C3B-806B
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0333037940
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C13224E00120102
   VCID: 56E0975321594C3408-8003
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0018508322
   Coding: 100000010001
   Shop #: WSC 06324 123 12345
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 352230DF941F672CE1-8061
   Revision: 00002001    Serial number: 0334361773
   Coding: 01060E9A00FA400582B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000827489
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H05 0220
   Revision: 00005001    Serial number: 94813029124804
   VCID: 2D1218BF744F2FEC99-8079
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55E2905F3C5F472C01-8001
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 10000000367193
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A3823E3BD0188540C-806F
   Revision: AB001007    Serial number: 156DP0E8002126
   Coding: 020007010000000001
   VCID: 2404FD9B2785EEA446-8071
   Part No SW: 8R1 035 746 E    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0756
   Revision: --------    Serial number: 204EZ0E7660348
   Coding: 130200020006A1EF55028B5E00000403140000000000000000
   VCID: 393A3CEFB007834C05-806D
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Component: DU7 High  H42 0104
   Serial number: A130DI0E3015380
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001843822
   Component: CD-Database  5571
   Revision: --H09---    Serial number: 525PA8-J4292MV
   Coding: 1000008
   VCID: 383C39EB4B0D9A44FA-806D
End----------(Elapsed Time: 01:46, VBatt start/end: 14.8V/14.8V)-----------
I can't find any documentation regarding Byte 0 in that ABS. My guess is the ABS will complain that it is "Incorrectly Coded" if you change it from 2D to 29, and that it's more likely defines the engine type than something regarding the transmission behavior.
jonesn00
Alabama, USA
C?ID=243696
I changed the coding last night from 2D to 29, so far no coding issues or rejection. ESP and traction control fully on seems to have more torque with less intervention, transmission still behaves the same. I'm going to give it a week to relearn before jumping to conclusions. Thank you for looking into it on your side!
Also, my driving habits involve more spirited driving, and using the manual shift mode 80%-90% of the time.
