Cluster Swap - Fraud
Righteouness
Australia
C?ID=434582
Hi all,
I’ve made a post in multiple forums and it appears that people are contesting the accuracy of VCDS when it comes to a ECU scan. The following was performed recently:
For: https://imgur.com/gallery/rxwnZCC
There may have been a rollback down on the cluster. Is there anyway to confirm this? Here’s some code for further info:
Advanced Identification
    Serial number: 00000610060902
    Identification: TFK-030
    Date: 06.10.06
    Revision: 04507000
    Test stand: 8501
    Manufacturer number: 0902
Flash Status
    Prog attempts: 2
    Successful attempts: 2
    Prog Status: 00000000
    Req Conditions: 00000000
    Flash Tool Code: 90108 2069 00000
    Flash Date: 00.00.00
Software
    000B
Misc.
    Hardware number: 02E927770AE
    Lot number: C30
    Type Lock: 0001
VCDS Info:
    Labels: 02E-927-770.clb
Backstory: In Australia, we are not able to retrieve esafety checks of the vehicle due to privacy concerns although this would show odometer history done by mechanics when approving the safety of the vehicle. Carhistory reports did not shown at mileage in history section. There are no logbooks. Volkswagen Australia have purged the history from 2009 (43,000KMS) to current.
is it likely that this vehicle has done 118,000KMS only? This vehicle has checked my boxes when it comes to good condition.
Hi and welcome.
Can we get a complete Auto-Scan for context please?
You can never be 100% certain. For example, it's possible the ECU in this car has been swapped out with a different one at some point.
Righteouness
Australia
C?ID=434582
Thursday,29,April,2021,17:13:58:52175
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4543.4
VIN: WVWZZZ1KZ7M149041   License Plate: 01HOLY
Mileage: 118020km-73334mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ7M149041   Mileage: 118020km-73334miles
62-Door, Rear Left -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 021 KK    HW: 03G 906 021 KK
   Component: R4 2,0L EDC G000AG  9970
   Revision: --H06---    Serial number: VWZ7Z0G9035647
   Coding: 0000078
   Shop #: WSC 20117 959 97404
   VCID: F2B630B2A8A31D6B097-80A6
   Part No SW: 02E 300 043 M    HW: 02E 927 770 AE
   Component: GSG DSG         070 1302
   Revision: 04507000    Serial number: 00000610060902
   Shop #: WSC 00066 000 00000
   VCID: 9E6E34020CBBE90B1DF-80CA
   Revision: 00H11001
   Coding: 0006786
   VCID: F3B835B6D7B91463021-80A6
   Part No SW: 1K0 907 044 BH    HW: 1K0 907 044 BH
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: EE8E24C2BC9B398BEDF-80BA
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000000570867
   Coding: E4010EA700041500470000000F000000000850035C0000
   Shop #: WSC 12345 111 45725
   VCID: EB882DD68F89CCA3CA1-80BE
   Component: Wischer 090307 020  0501
   Coding: 00038805
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     040207 020  0105
   Coding: 00208933
   Shop #: WSC 12345
8 Faults Found:
                    Fault Status: 00111100
                    Reset counter: 176
                    Mileage: 116874 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.35 V
                    Fault Status: 00101100
                    Reset counter: 176
                    Mileage: 116836 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.90 V
00985 - Right Tail Light (M2)
                    Reset counter: 176
                    Mileage: 116874 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.55 V
02399 - Control Circuit for Terminal 30 for Interior Illumination
                    Fault Status: 00111001
                    Reset counter: 182
                    Mileage: 116836 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
                    Fault Status: 00101001
                    Reset counter: 186
                    Mileage: 117362 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.60 V
                    Reset counter: 186
                    Mileage: 117362 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.45 V
                    Reset counter: 186
                    Mileage: 117362 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.45 V
                    Reset counter: 182
                    Mileage: 116836 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.20 V
   Component: 2T AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0ZLVLS
   Coding: 0012884
   VCID: BD2CD38EA17D9213245-80E8
   Subsystem 1 - Serial number: 6332MSME156871166
   Subsystem 2 - Serial number: 6342MSME166026351
   Subsystem 3 - Serial number: 6351HSME0C605B247
   Subsystem 4 - Serial number: 6361HSME0C6032191
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012021
   VCID: 81546F7E9D0536F300D-80D4
   Part No SW: 1K0 920 863 B    HW: 1K0 920 863 B
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0G9035647
   Coding: 0019703
   Shop #: WSC 20117 067 57207
   VCID: AA06E8D240F315AB717-80FE
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 230207F1002218
   Coding: 3F3F074007001003
   VCID: AF30F9C67B117083A69-80FA
                    Fault Status: 00110100
                    Reset counter: 186
                    Mileage: 117362 km
                    Time: 13:36:37
                    Reset counter: 186
                    Mileage: 117362 km
                    Time: 13:36:37
   Component: IMMO            3HL 1610
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1134
   Revision: 31008001    Serial number: 00000507778130
   Coding: 0000692
   VCID: BC2ADE8ABA679B1B13B-80E8
                    Fault Status: 00100101
                    Reset counter: 205
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: B53CCBAE994D4A53EC5-80E0
   Component:    KSG PQ35 G2  020 0203
   Coding: 80900A000106087F2D060E0F6008DF0380F8C0
   VCID: 83586576871924E3121-80D6
                    Fault Frequency: 47
                    Reset counter: 189
                    Mileage: 117065 km
                    Time: 16:28:28
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1134
   Revision: 31008001    Serial number: 00000549078210
   Coding: 0000948
                    Reset counter: 205
00097 - Front Passengers Central Locking (Safe) Motor (V162)
                    Reset counter: 205
                    Mileage: 116836 km
                    Fault Status: 01101000
                    Fault Frequency: 221
                    Reset counter: 165
                    Mileage: 116836 km
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0046
   Revision: 00034000    Serial number: VWZ1Z2G4479381
   Coding: 0040400
   VCID: B720C1A68341B843FE9-80E2
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000001096754
   Coding: 0000144
00934 - Electric Window Motor; Rear Left (V26)
                    Reset counter: 205
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000001078281
   Coding: 0000144
   VCID: BE2ED482AC7B890B3DF-80EA
00935 - Electric Window Motor; Rear Right (V27)
                    Reset counter: 205
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 12 Einparkhilfe     0101
   VCID: AD0CE3CE711D0293945-80F8
End----------(Elapsed Time: 01:45, VBatt start/end: 12.4V/12.3V)-----------
Hello, how may I found out about the ECU has been swapped?
Thanks for the welcome too.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
It is really hard to tell is it ECU been replaced in past or km was manipulated . One way is to check but still not 100%, it is pedals, Brake and gas pedal , they will be worn pretty good at 350000kmh.
With 118000kmh they will look very good almost like new on mk5 vehicle .
If you can post picture of pedals.
Righteouness
Australia
C?ID=434582
Hi and thank you for the response. That’s a shame about the ECU.
Here is the quality of the pedals with and without the floor mat. Please note this is 2 months owner by me. It needs a vacuum obviously.
Here is the ECU taken out to inspect:
VWT6
Finland
C?ID=295527
How about DSG blockmaps?
This car has an old-school pre-UDS DSG. If it has total mileage somewhere, I don't think it's documented. But it certainly couldn't hurt to post an MVB map.
Righteouness
Australia
C?ID=434582
Hey there, could you please assist with trying to locate the MVB map? I’m quite fresh with this system.
VWT6
Finland
C?ID=295527
VCDS ->
Applications ->
Controller Channel Map
Single Controller Address - 02​
Login - leave empty​
Function - Measuring values​
Output - CSV file​
Go​
The results will automatically be saved to C:\Ross-Tech\VCDS\Logs directory​
Full manual page:
Righteouness
Australia
C?ID=434582
;SW:02E-300-043-M HW:02E-927-770-AE --- Auto Trans
;Component:GSG DSG 070 1302Coding:0000020
;Thursday
6​
May
2021​
17:06:20:52175
;VCDS Version: Release 21.3.0 (x64) Data version: 20210226 DS325.0
;VCID: 9E6E34020CBBE90B1DF-80CA
GroupField 1Data typeField 2Data typeField 3Data typeField 4
1​
PN Active0.0 km/h
2​
PP
0​
P
3​
PPNot Oper.Not Oper.
4​
PNot Recogn.0 /min0 /min
5​
PActivated12.90 V12.90 V
6​
P0.000 A
18.00%​
0.804 A
7​
P0.000 A
18.00%​
0.804 A
8​
832 /min0 /min0 /min0 /min
9​
832 /min832 /min0 /min0 /min
10​
0.00%​
16.0 Nm37.0 Nm
11​
0 /min-600.0 Nm0.000 A0.00 bar
12​
13​
0.000 A
18.00%​
0.00%​
0.00%​
14​
0.000 A
18.00%​
0.00%​
0.00%​
15​
521​
301​
511​
282​
16​
0.0 mm-8.6 mm-0.3 mm-8.7 mm
17​
-2.6 mm-3.2 mm-0.2 mm-2.7 mm
18​
3.2 mm2.5 mm2.5 mm2.3 mm
19​
69.0°C67.0°C74.0°CIdle
30​
0.275 A0.260 A0.880 A0.880 A
31​
0.245 A0.235 A0.775 A0.775 A
32​
0.245 A1.000 A0.235 A1.000 A
33​
28575​
0​
23366​
0​
34​
29770​
0​
21716​
0​
35​
0​
0​
0​
0​
36​
4744​
4604​
4998​
4692​
37​
5108​
5034​
4996​
5090​
38​
5590​
5443​
5460​
5494​
39​
0​
0​
0​
0​
40​
27773​
0x6C7D
41​
v0696F0202ea__getriebe_DSG_VM6F
48​
C13
49​
6.90 V10.90 V7.40 V10.30 V
50​
1K2 71325 AA 0 1 K4
51​
272​
65535​
65535​
65535​
52​
65535​
65535​
65535​
65535​
53​
65535​
65535​
65535​
65535​
54​
G41Q0326
59​
0​
0​
0​
0​
60​
0​
0​
0​
0​
61​
0​
0​
0​
0​
63​
0​
64​
0​
0​
65​
1.25 bar1.25 bar1.15 bar1.05 bar
66​
11111​
11111​
10101​
11111​
67​
0.275 A0.245 AN/AN/A
68​
0.245 A0.235 AN/AN/A
69​
1​
0 1
1​
70​
0​
0​
N/AN/A
71​
0000354927 00240 00000 01785
72​
0000189873 00000 00000 00310
80​
TFK-030 06.10.06 04507000 8501 0902
81​
<> 00000610060902 <>
82​
9010800002069 00.00.00 C30 01 <> <>
90​
65535​
0​
0.00%​
0​
91​
0 /min0 /min0 /min0 /min
92​
0​
0​
0​
0​
93​
0.000 A0.000 A0.000 A-60.0°C
94​
65535​
0​
0.00%​
0​
95​
96​
0​
0​
0​
0​
97​
104​
0x00000x00000.00 V-98.0 Nm
105​
0.00 bar0.000 A0.00 bar0.000 A
106​
107​
109​
345020 km
95.00%​
0.50%​
3.50%​
110​
0 kmN/AN/AN/A
111​
0 kmN/AN/AN/A
120​
100.00%​
100.00%​
0​
22150​
121​
100.00%​
100.00%​
100.00%​
100.00%​
122​
100.00%​
100.00%​
100.00%​
100.00%​
123​
100.00%​
100.00%​
100.00%​
100.00%​
124​
100.00%​
100.00%​
100.00%​
100.00%​
125​
Engine 1ABS 1Instruments 1Sel.Lev. 1
126​
Gateway 1St. Wheel 1Steer. ang. 1Park Brake 0
130​
120 km
0​
120 km
0​
140​
5436 h600 h0.00 s0.00 s
141​
0.00 s0.00 s104.0°CN/A
225​
0​
0​
0​
0​
226​
0​
0​
0​
255​
Righteouness
Australia
C?ID=434582
VCDS ->
Applications ->
Output - CSV file​
Go​
Full manual page:
Is there any noticeable difference? I see the 345,000kms but this may be logged by the ECU? I’m hoping that the ECU was replaced by another ECU due to failure but I still have no idea. Please note that I’ve noticed a highline steering wheel is installed as opposed to a mid line in conjunction to the midline MFD. Perhaps the ECU was swapped and the steering wheel was installed for the steering module to allow the ECU to function?
NEtech
Denmark
C?ID=56995
MWB 109 showing 345000 km, is Driving statistics.
Driven 345000 km, in D and S with CC 95%, in S without CC 0.5%, in tiptronic 3.5%
Righteouness
Australia
C?ID=434582
Isn’t this driving statistic stored in the ECU? Possibly why the ECU has been swapped?
VWT6
Finland
C?ID=295527
Well, to me it looks like the DSG has done approx. 345.000 km. Also MWB 140seems to indicate 5436 hours accumulated (which would equal 63 km/h in average).
Checked another DSG (0AM-300-058-D, year 2013 still non-UDS data) and the MWB 109 there matches with accumulated kilometers in Instruments.
Yep! ECU says 349,000. TCU says 345,000. I'm confident that these are computed independently, and the 118,000 shown in the cluster does not reflect reality.
