2021 VW ID 4 77kWh RWD Pro performance Max
downtime
Finland
C?ID=280813
My new car
Autoscan in stock state. Some errors which cleared out just fine.
Only thing I've coded is driver seat easy entry but it's not in this scan yet.
Tuesday,04,May,2021,20:32:41:18875
VIN: WVGZZZE2ZMP028717   License Plate: xxxxx
Mileage: 30km-18mi   Repair Order:
Chassis Type: E2-VWE3 (1EA)
Scan: 01 03 05 06 08 09 10 13 14 15 16 17 19 23 2B 36 3C 42 44 51
          52 5F 69 6C 6D 75 82 8C A5 BB BC C0 C6 CA D6 D7 8105 8107 811E 811F
          8120 8121 8123 8124 8125 8128 C002 C003
VIN: WVGZZZE2ZMP028717   Mileage: 30km-18miles
C0-Act. for Ext. Noise -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
8105-DC/DC Converter 12V -- Status: OK 0000
8107-Antenna -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623-EBJA)       Labels: None
   Part No SW: 0EA 906 012 AT    HW: 0EA 907 425 C
   Component: E-Vehicle     H01 1533
   Coding: 010200060364140070080000001000803008080000000000
   ASAM Dataset: EV_VCU00XXX0200EA906012AT 001003
   ROD: EV_VCU00XXX0200EA906012AT_VWE3.rod
   VCID: 7DA7F9E78D75F553E45-8028
   Radiator shutter:
   Subsystem 1 - Part No SW: 1EA 965 501     HW: 1EA 965 501
   Component: V711           022 0006
   Serial number: 20210218060404077556
17179 - Databus
                    Mileage: 22 km
                    Date: 2021.05.04
                    Time: 15:00:11
                    Engine RPM: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 14.570 V
   Part No SW: 1EA 614 517 AA    HW: 1EA 614 517
   Component: ESC-ZF_EBC470 H15 0177
   Serial number: B0030UX
   Coding: 1A955C85593D583E3A439ADF22E032A6484A6D266433114928444C651252B66426CC889214EEEBBCFD0077D73DBF00
   ASAM Dataset: EV_Brake1ZFESCEPBMEB 013149
   ROD: EV_Brake1ZFESCEPBMEB_013_VWE3.rod
   VCID: 71BFD5D7C12D813370D-8024
20485 - Function Limitation due to Implausible Signal
          C1248 00 [046] - -
                    Fault Frequency: 79
                    Mileage: 30 km
                    Date: 2082.04.11
                    Time: 22:28:03
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 5WA 959 436 G    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w.rod
   VCID: 58E988734297F07B973-800C
   Part No SW: 1EA 959 760 H    HW: 1EA 959 760 H
   Component: MEM-BFS       010 0560
   Serial number: 2130601KA01360
   Coding: 0118BA00000132008803010101010000000000000000000000000000211000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 43D34F1FAB1143A3D21-8016
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 1EA 907 727 AB    HW: 1EA 907 727 AB
   Component: Climatronic   H01 0342
   Coding: 602022247020320010100010111001102000102110221101000000000000
   ASAM Dataset: EV_ACClimaBHBMEB31X 002006
   ROD: EV_ACClimaBHBMEB31X_002.rod
   VCID: 7AADF2FB9C5BC26BC17-802E
   A/C compressor sub:
   Humidity sensor: exterior:
   Auxiliary Heater Control Module/PTC 2:
   Interior temperature sensor:
   Expansion valve 1 for refrigerant:
   Expansion valve 2 for refrigerant:
   Expansion valve 3 for refrigerant:
   Carbon dioxide content sensor:
   A/C pressure/coolant temperature sensor 2:
   A/C pressure/coolant temperature sensor 3:
   Shut-off valve 1 for refrigerant:
   Shut-off valve 2 for refrigerant:
   Shut-off valve 3 for refrigerant:
   Shut-off valve 4 for refrigerant:
   Shut-off valve 5 for refrigerant:
   A/C pressure/coolant temperature sensor 4:
   A/C pressure/coolant temperature sensor 5:
   A/C pressure/coolant temperature sensor 6:
   Rear A/C control head:
   Part No SW: 1EA 937 089 M    HW: 1EA 937 089 B
   Component: SAM_H+        H22 0130
   Serial number: 00102106600188-
   ASAM Dataset: EV_SAMVW31x 003001
   ROD: EV_SAMVW31x_003_VWE3.rod
   VCID: 48C95833923760FB073-801C
   Subsystem 1 - Part No SW: 11B 955 119     HW: 11B 955 119
   Component: FWISCHER_MYJT  003 0032
   Serial number: 907353F0402100902691
   Subsystem 2 - Part No SW: 5Q0 955 555 B    HW: 5Q0 955 555 B
   Component: RLHSS          054 0208
   Serial number: S7Y21M03D12H11M33S45
   Subsystem 3 - Part No SW: 10A 941 193 G    HW: 10A 941 193 G
   Component: LiSi           H04 0513
   Serial number: TW571424022100020348
   Subsystem 4 - Part No SW: 10A 925 200 D    HW: 10A 925 200 D
   Component: DiEta          H07 0513
   Serial number: TW571415032100011975
   Subsystem 5 - Part No SW: 10A 959 561 H    HW: 10A 959 561 H
   Component: DACHKONSOLE    006 0007
   Serial number: 92661UBC00272-------
Address 10: Park/Steer Assist (-----)       Labels:* None
   Part No SW: 1EA 919 294 B    HW: 1EA 919 294
   Component: PDC08K------- H02 0208
   Serial number: 000013022194630
   Coding: 0040014101
   ASAM Dataset: EV_EPHBO18VW3100000 002016
   ROD: EV_EPHBO18VW3100000_VWE3.rod
   VCID: 3B2337FFD3E13B639A1-806E
   Part No SW: 1EA 907 572 G    HW: 1EA 907 572
   Component: ARS510VW19 H02 0123
   Coding: 058318F34071404512474008000040C5AF4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 003008
   ROD: EV_FRONTRADARCONTIVW310_003_VWE3.rod
   VCID: 3C2134E3D6EF3C5B93B-8068
0110 - Transport Mode Active
          U1105 00 [128] - -
          MIL ON - Intermittent - Not Confirmed - Tested Since Memory Clear
2068 - Databus
          U1123 00 [168] - Received Error Message
          [FAULT_TSK_IRREV_ERROR]
                    Reset counter: 28
                    Mileage: 22 km
                    Date: 2021.05.04
                    Time: 15:02:15
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 1EA 907 376 B    HW: 1EA 907 376
   Component: DAEMPFUNGS-SG H05 0456
   Serial number: 2C7673241106102
   ASAM Dataset: EV_DCC3CONTITEMIC 002006
   ROD: EV_DCC3CONTITEMIC.rod
   VCID: 392F2DF7D9DD097388D-806C
Address 15: Airbags (J234)       Labels: None
   Part No SW: 1EA 959 655 CD    HW: 1EA 959 655 CD
   Component: VW40Airbag    009 0366
   Serial number: V058VzE17A7
   Coding: 88CC008000F0C000000000200000000051540000A1540000C000F680002B0065
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X.rod
   VCID: 05579107E5A5BD93BC5-8050
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 10A 980 945     HW: 10A 980 945
   Component: BeltPretRevFL  602 0100
   Serial number: 11B857705K0060V00306
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 10A 980 946     HW: 10A 980 946
   Component: BeltPretRevFR  602 0100
   Serial number: 11B857706K0058V00219
   Subsystem 3 - Part No SW: -----------    HW: 440 001 711 20
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ000000E263C6D4K
   Subsystem 4 - Part No SW: -----------    HW: 440 001 611 20
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ000000768C88C4Q
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 440 001 202 21
   Component: Side_Sens_B_D  00A 0149
   Serial number: I0PCJ322C91AA2165008
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 6 - Part No SW: -----------    HW: 440 001 302 21
   Component: Side_Sens_B_P  00A 0149
   Serial number: I0QCJ2C637A25693600H
   Subsystem 7 - Part No SW: -----------    HW: 440 001 202 21
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJ322C91AA246500K
   Subsystem 8 - Part No SW: -----------    HW: 440 001 302 21
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJ2C637A25683600P
   Subsystem 9 - Part No SW: -----------    HW: 440 000 103 21
   Component: FrontSensor_P  00A 010A
   Serial number: 356ckC6C07C1DA69800D
   Subsystem 10 - Part No SW: -----------    HW: 440 000 203 21
   Component: FrontSensor_D  00A 010A
   Serial number: 355CJAEC1735B3D0500%
Address 16: Steering wheel (J527)       Labels:* None
   Part No SW: 1EA 953 507 G    HW: 1EA 953 507 G
   Component: GSMMEB        006 0071
   Serial number: 000000160321260
   Coding: 0000
   ASAM Dataset: EV_SMLSKLOMEB 010001
   ROD: EV_SMLSKLOMEB_010.rod
131380 - Databus
          U1121 00 [040] - Missing Message
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 09:30:14
Address 17: Instruments (J1254)       Labels:* None
   Part No SW: 10A 920 320 A    HW: 10A 920 320
   Component: FAHRERDISPLAY 009 0520
   Serial number: 1A1X5585-552664
   Coding: 6E70
   ASAM Dataset: EV_DashBoardLGMEB 001027
   ROD: EV_DashBoardLGMEB.rod
   VCID: 1373BF5F9BF11323221-8046
   Part No SW: 1EA 937 012 L    HW: 1EA 937 012 A
   Component: ICAS1 Host-SG 065 0123
   Serial number: SJ8ICS170321117
   ASAM Dataset: EV_GatewICAS1MEB 005001
   ROD: EV_GatewICAS1MEB_VWE3.rod
   Subsystem 1 - Part No SW: 1EA 915 181 A    HW: 1EA 915 181 A
   Component: J367-BDMConti  H04 1073
   Serial number: 773861010021030105A5
   Subsystem 2 - Part No SW: 3G0 959 542 A    HW: 3G0 959 542 A
   Component: J IEEHOD1ZONE  251 0301
   Serial number: 00000000230300217822
   Subsystem 3 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 25158264
   left tail lamp 1:
   Subsystem 4 - Part No SW: 11A 945 207     HW: 11A 945 207
   Component: SHLli1         H04 0063
   Serial number: 20210115025001
   left tail lamp 2:
   Subsystem 5 - Part No SW: 11A 945 307     HW: 11A 945 307
   Component: SHLli2         H04 0063
   Serial number: 20210114005901
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 11A 945 208     HW: 11A 945 208
   Component: SHLre1         H04 0063
   Serial number: 20201204016402
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 11A 945 307     HW: 11A 945 307
   Component: SHLre2         H04 0063
   Serial number: 20210213074601
   Subsystem 8 - Part No: 5Q0 951 172 A
   Component: Sensor, DWA    005 0403
   Serial number: 000000000ZL21057A1UE
   Subsystem 10 - Part No SW: 1EA 959 442     HW: 1EA 959 442
   Component: MFL            H08 0028
   Serial number: 17029815090412100980
8 Faults Found:
8397062 - Unknown Error Code
          P1A85 00 [036] - -
          [12_V_test_pulse_not_available_by_reason_of_EMHLR]
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 08:27:51
                    Reason for rejection: 1
                    Bad counter: 1
                    Test pulse counter not OK: 0
                    Counter increase not OK: 0
                    BZE_test_pulse_request: 2
                    BZE_test_pulse_result: 3
8540417 - Unknown Error Code
          U15FA 00 [044] - -
          [EgoMaster_Input_data_failure]
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 08:21:42
8491266 - Unknown Error Code
          U14FE 00 [044] - -
          [SOK_signature_verification_failed]
                    Date: 2021.05.04
                    Time: 07:34:09
9371914 - predictive route data
          B1630 02 [046] - Signal Failure
                    Fault Frequency: 28
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 06:41:55
2494569 - Unknown Error Code
          U1643 00 [047] - -
          [Rearview_camera_system_control_module_no_communication_vlan]
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 06:17:43
8515664 - Control Pilot
          P0CF4 00 [100] - Implausible Signal
          [HVLM_no_cp_communication_possible]
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 10:14:03
8516406 - Unknown Error Code
          C1249 F6 [046] - Unknown Error Elaboration
          [HVLMSF_error_plug_locking_status_not_locked]
                    Fault Frequency: 48
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 06:38:16
2498823 - Unknown Error Code
          U1662 00 [038] - -
          [Application_server_1_system_2_Java_internal_malfunction_vlan]
                    Mileage: 22 km
                    Date: 2021.05.04
                    Time: 14:49:08
   Part No SW: 1EA 909 059 N    HW: 1EA 909 059
   Component: EBB-ZF-Gen1   H28 0275
   Serial number: ÿÿÿÿÿÿÿ
   Coding: 18953285003D183E4C4300DF20E02020202020202021212121000404040404040404848484840008001000
   ASAM Dataset: EV_BrakeBoostZFMEB 012139
   ROD: EV_BrakeBoostZFMEB_012_VWE3.rod
   VCID: 45D75107A5257D93FC5-8010
2101863 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [174] - Performance
                    Mileage: 30 km
                    Date: 2021.05.04
                    Time: 16:35:40
Address 2B: Steer. Col. Lock (J764)       Labels:* None
   Part No SW: 1EA 905 861     HW: 2Q0 905 861 B
   Component: ELV-MEB       H09 0040
   Serial number: 21000056452015
   Coding: 8800000000000000
   Shop #: WSC 00028 000 00000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 74B1DCC3BE3FB41B9BB-8020
   Component: MEM-FS        010 0560
   Serial number: 2130601KA01351
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 E    HW: 2Q0 907 686 E
   Component: HRE_Master    H25 0284
   Serial number: 00000570767376
   Coding: 66954750
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 E    HW: 2Q0 907 685 E
   Component: HRE_Slave      H25 0284
   Serial number: 00000570621981
   Part No SW: 1EA 959 593 D    HW: 1EA 959 593
   Component: TSG FS        003 0543
   Serial number: 0000436991368
   Coding: 0035DA20D2000480A6009000
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
   ROD: EV_DCU3DriveSideMAXHCONT.rod
   Door operating panel: driver side:
   Subsystem 1 - Part No SW: 10A 959 862 S    HW: 10A 959 862 S
   Component: EX36 TBF_FS    H21 0107
   Serial number: 0398-01.03.21-------
   Part No SW: 1EA 907 144 AG    HW: 1EA 907 144 H
   Component: BASGEN1MQB37  246 5024
   Serial number: 00698961
   Coding: 0000000000000201000002010100010000000100010102
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   VCID: 78A9E8F3A257D07BB73-802C
   Part No SW: 1EA 907 121 C    HW: 1EA 907 121 C
   Component: MEB PSM       H09 6035
   Serial number: VES_N1000422287
   ASAM Dataset: EV_DMCM15000F11EA907121C 001009
   ROD: EV_DMCM15000F11EA907121C.rod
   VCID: 2E050EAB1093DECB2DF-807A
   Part No SW: 1EA 959 592 D    HW: 1EA 959 592
   Component: TSG BFS       003 0543
   Serial number: 0000437386932
   Coding: 00355020DE000480A2809000
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
   ROD: EV_DCU3PasseSideMAXHCONT.rod
   VCID: 42DD4A1BB40B4AABD97-8016
   Part No SW: 10A 035 816 E    HW: 10A 035 816 A
   Component: IC3-SF-AR-EU  H20 0792
   Coding: 23166030000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 001001
   ROD: EV_MUICASSAFEPart_VWE3.rod
   VCID: 1E65DE6B60334E4B9DF-804A
   Subsystem 1 - Part No SW: 10A 919 606 M    HW: 10A 919 606 M
   Component: ABT_E_12       H36 6071
   Serial number: APUF7406032100030182
Address 69: Trailer (J345)       Labels:* None
   Part No SW: 5H2 907 383 B    HW: 5H2 907 383
   Component: Anhaenger     H10 0057
   Serial number: 000000000005710
   Coding: 0100000202001400
   ASAM Dataset: EV_TrailFunctGener3Hella 001012
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 2F3B13AF1799D7C3269-807A
655882 - Bulb for Brake Light on Trailer
          C10F3 15 [040] - Open or Short to Plus
                    Mileage: 22 km
                    Date: 2021.05.04
                    Time: 15:00:11
   Part No SW: 1EA 907 556 F    HW: 5WA 907 556 C
   Component: TV eEntry     H17 0144
   Serial number: FZ6ESP230221000
   Coding: 02030100FC3000
   ASAM Dataset: EV_CamSysTVFicosMEB 006005
   ROD: EV_CamSysTVFicosMEB.rod
   VCID: 3D2739E7CDF53553A45-8068
   Front peripheral camera slave:
   Subsystem 1 - Part No SW: 5WA 980 546 C    HW: 5WA 980 546 C
   Component: R243 UmfKamSV  H12 0040
   Serial number: FCLMAR31122000066495
   Peripheral camera slave: left:
   Subsystem 2 - Part No SW: 5WA 980 546 C    HW: 5WA 980 546 C
   Component: R244 UmfKamSL  H12 0040
   Serial number: FCLMAR30012100052719
   Right peripheral camera slave:
   Subsystem 3 - Part No SW: 5WA 980 546 C    HW: 5WA 980 546 C
   Component: R245 UmfKamSR  H12 0040
   Serial number: FCLMAR01022100063076
   Rear peripheral camera slave:
   Subsystem 4 - Part No SW: 5WA 980 546 C    HW: 5WA 980 546 C
   Component: R246 UmfKamSH  H12 0040
   Serial number: FCLMAR10022100047556
Address 6D: Trunk Elect. (J605)       Labels:* None
   Part No SW: 1EA 959 107 A    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0173
   Revision: --------    Serial number: A2-C776-3300-0
   Coding: 5088
   ASAM Dataset: EV_DeckLidCONTIAU736 001018
   VCID: 372B2BCFEFC91F037E9-8062
   Part No SW: 10A 035 284 C    HW: 10A 035 284
   Component: OCUGen4       H17 0436
   Serial number: 0000000102VIKE8
   Coding: 02316010106880008005460000000000
   ASAM Dataset: EV_OCUGen4 001034
   ROD: EV_OCUGen4.rod
   VCID: 1B63D77F73215B637A1-804E
1375744 - Unknown Error Code
          U14FE 00 [046] - -
                    Date: 2021.05.04
                    Time: 07:34:29
Address 82: Heads Up Display (J898)       Labels: None
   Part No SW: 11B 919 608 A    HW: 11B 919 608
   Component: HeadupDisplay H19 0114
   Serial number: ARHUD
   ASAM Dataset: EV_ARHeadUpDisplMEB 001030
   ROD: EV_ARHeadUpDisplMEB.rod
   VCID: 2615F68B3863968BD5F-8072
   Part No SW: 0Z1 915 184 E    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 007 0850
   Serial number: 000000050321020
   ASAM Dataset: EV_BMCeVWBSMEB 001011
   ROD: EV_BMCeVWBSMEB_VWE3.rod
   Cell module control module 1:
   Subsystem 1 - Part No SW: 0Z1 915 140 D    HW: 0Z1 915 140 D
   Component: SX6  X74  CMC  005 0800
   Serial number: 00000004032127020873
   Cell module control module 5:
   Subsystem 2 - Part No SW: 0Z1 915 140 D    HW: 0Z1 915 140 D
   Serial number: 00000004032127060875
   Cell module control module 9:
   Subsystem 3 - Part No SW: 0Z1 915 140 D    HW: 0Z1 915 140 D
   Serial number: 00000004032127050877
   Coolant heating:
   Subsystem 4 - Part No SW: 1EA 963 231     HW: 1EA 963 231
   Component: J848 HV-PTC    H03 0500
   Serial number: CH210113014402000722
   Part No SW: 1EA 980 654 F    HW: 1EA 980 654
   Component: MEB MFK 4.1   H03 5229
   Coding: 0008306E1F9100E8162420000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001017
   ROD: EV_MFK41ValeoMEB_VWE3.rod
1124497 - Databus
          U1123 00 [044] - Received Error Message
          [ACC_18_ACC_Status_ACC_irreversibel_ERROR]
                    Mileage: 21 km
                    Date: 2021.05.04
                    Time: 15:00:12
   Part No SW: 1EA 959 597 D    HW: 1EA 959 597
   Component: TSG HFS       003 0543
   Serial number: 0000436997759
   Coding: 0001D02001000480A2009000
   ASAM Dataset: EV_DCU3RearDriveMAXHCONT 001002
   ROD: EV_DCU3RearDriveMAXHKLO.rod
   VCID: 47CB5B0F9F296F830E9-8012
   Part No SW: 1EA 959 596 D    HW: 1EA 959 596
   Component: TSG HBFS      003 0543
   Serial number: 0000437001324
   ASAM Dataset: EV_DCU3RearPasseMAXHCONT 001002
   ROD: EV_DCU3RearPasseMAXHKLO.rod
   VCID: 46D5560B9823768BF5F-8012
Address C0: Act. for Ext. Noise (J943)       Labels: None
   Part No SW: 11A 035 335 H    HW: 1EA 035 335
   Component: E_SOUND_SG    H05 0008
   Serial number: JTK072060321812
   ASAM Dataset: EV_ESoundMEBHarma 004011
   ROD: EV_ESoundMEBHarma_004_VWE3.rod
4194347 - Databus
          U1123 00 [047] - Received Error Message
          [data_bus_value_fault_diagnose_01]
                    Fault Frequency: 30
                    Mileage: 6 km
   Part No SW: 1EA 915 684 BG    HW: 1EA 915 684 BF
   Component: HV_CHARGER    H52 0013
   Serial number: 93100TKO00059
   Coding: 1080
   ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002010
   ROD: EV_OCCXPhase1KLOMEB01B_002_VWE3.rod
   VCID: 015F8517F18D91B380D-8054
3280899 - Unknown Error Code
          B1AD0 F0 [047] - Unknown Error Elaboration
          [ETHTRCV_30_AR7000_SLAC_STEP_3_PARAM_REQ_Timeout]
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 10:14:32
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Frequency: 1001 Hz
                    Control voltage: 6063.0 mV
                    Duty cycle: 12.9 %
                    Activation charge cover lock charge socket A: not requested
                    Lock for high-voltage charging connector: not locked
                    Status connect. recognition: detected
                    Charge socket temperature sensor AC: 30.0 °C
                    Temperature sensor 1: resistance value: 1091 Ohm
                    DID 15E2: 15.0 °C
                    DID 081C: 26 W
                    DID 081D: 0 W
                    DID 081E: 0 W
                    DID 0286: 12.3 V
                    DID 497C: not active
                    DID 537A: 14.4 V
                    DID 1525: 3884 mV
                    Status of voltage freedom: High voltage power off recognized
                    DID 5372: 16.0 °C
                    No. of lockings: 9
                    No. of connections: 0
                    Number of successful charging connector locks: 2
                    Wake-up counter: contact (proximity): 0
                    Wake-up counter: Control Pilot: 2
                    Charging standard abort: status: not active
                    Loading plan: status: Not available
                    Price/performance table: status: Not available
                    Transport Layer Security (TLS) status communication: not active
                    DID 103A: supported
                    number_evse_slac: 0
                    PLC_modem_status: active
                    number_slac_attemps: 1
                    DID 1033: SLAC_failed
                    DID 1038: no_description
                    DID 1039: supported
                    Target HV charge current: 0.0 A
13705218 - Databus
                    Fault Frequency: 24
                    Reset counter: 36
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 06:45:12
                    DID 0286: 14.3 V
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Status connect. recognition: not detected
                    Temperature sensor 1: resistance value: 1094 Ohm
                    DID 15E2: 11.0 °C
                    DID 537A: 14.4 V
                    DID 5372: 11.0 °C
Address CA: Sunroof (J245)       Labels:* None
   Part No SW: 89A 907 594 BD    HW: 89A 907 594
   Component: SAD_STG_1     006 0031
   Coding: 01002073166F
   ASAM Dataset: EV_SunRoofCONTIAU736 009012
   ROD: EV_SunRoofCONTIAU736_VWE3.rod
   Part No SW: 992 941 572 AE    HW: 992 941 572 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 6695B68BF8E3568B15F-8032
   Component: LED1R         H08 9202
Address 8105: DC/DC Converter 12V (A19)       Labels: None
   Part No SW: 1EA 907 190 D    HW: 1EA 907 190 D
   Component: DCDC Gen4H12 1140
   Revision: 00H12000
   ASAM Dataset: EV_DCDC10030111EA907190D 001021
   ROD: EV_DCDC10030111EA907190D.rod
   VCID: 353721C7F5C5ED136C5-8060
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 1EA 035 741 D    HW: 1EA 035 741 D
   Component: TrxModulHigh  H07 0164
   Serial number: 0000000012VIPAB
   Coding: 02316411440280
   ASAM Dataset: EV_TrxMLGEMEB 006014
   ROD: EV_TrxMLGEMEB_006.rod
Address 811E: Burglary Protection FL (J518)       Labels: None
   Part No SW: 5WA 962 133 D    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w.rod
   VCID: 49CF5D37893D99F318D-801C
Address 811F: Burglary Protection FR (J518)       Labels: None
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w.rod
Address 8120: Burglary Protection RL (J518)       Labels: None
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: None
   ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: None
   Part No: V04 007 003 EA
   Component: ICAS1 Sys_Ada 0123
   ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
   ROD: EV_AppServe1Syste1ICAS1_VWE3.rod
   VCID: 6A8DC2BBECFB72EB317-803E
Address 8124: App server 1 system 2 Java (SWC5)       Labels: None
   Part No: V04 007 003 EB
   Component: ICAS1 Sys_Jav 0123
   ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
   ROD: EV_AppServe1Syste2ICAS1_VWE3.rod
   VCID: 6B83C7BFE3016BE34A1-803E
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:* None
   Part No: V04 007 003 R
   Component: IC3-IVI-D-EU  0792
   ASAM Dataset: EV_MUICASIVIPart 002007
   ROD: EV_MUICASIVIPart_002_VWE3.rod
   VCID: 363526CBE8C3E60B65F-8062
5688 - Control Head for Mulimedia System
          B13C9 F2 [008] - On/Off Switch
                    Mileage: 6 km
                    Date: 2021.05.04
                    Time: 06:36:57
                    Voltage terminal 30: 14.2 V
Address 8128: Light line display (J145)       Labels: None
   Part No SW: 11B 919 451 B    HW: 11B 919 451 B
   Component: Lichtlinie1   004 0106
   ASAM Dataset: EV_SmartLight1MEB 002001
   ROD: EV_SmartLight1MEB_002.rod
   VCID: 2313EF9F4B5163A3B21-8076
Address C002: SW Cluster Embedded (SWC2)       Labels: None
   Part No: V04 007 003 EC
   Component: ICAS1 SWCL_Em 0123
   ASAM Dataset: EV_SWCLEmbed1ICAS1 005001
   ROD: EV_SWCLEmbed1ICAS1_VWE3.rod
   VCID: 6C81C4A3E60F6CDB43B-8038
Address C003: SW Cluster Housekeeping (SWC3)       Labels: None
   Part No: V04 007 003 ED
   Component: ICAS1 SWCL_HK 0123
   ASAM Dataset: EV_SWCLHouse1ICAS1 005001
   ROD: EV_SWCLHouse1ICAS1_VWE3.rod
   VCID: 6D87C9A7DD1565D3545-8038
End----------(Elapsed Time: 02:14, VBatt start/end: 13.7V/13.7V)-----------
Andy
Sector 7G
HC424490
Congrats on the new car, fellow ID.4 owner Internet thumbs up! :thumbs:
downtime
Finland
C?ID=280813
Thanks Andy.
How's your feelings on the car, I think you've had it already for some time? My initial impressions after 40 km's is that I'm not going to miss traditional gasoline or diesel engine :) The power delivery is just uber smooth.
Also I think VW has done a marvellous job with ID4. ID3 was a bit cheapish on many aspects but that is not the case with ID4. It's really posh in interior materials and overall quality feeling.
downtime
Finland
C?ID=280813
Small improvements for the audio part on the car coming.
I've been reading fellow ID4 owners in US side changing their stock speakers to Focal sets that are specifically designed for ID4. ISVW165 set to front doors + a pillar tweeters and iCVW165 coaxials to back doors.
They're completely plug'play speakers and car is reverseable to stock any time without any visible changes.
Very very good reviews on the sets and how they improve the stock sound.
Let's see (or hear :) ) when I get the sets next week.
Andy
Sector 7G
HC424490
@downtime sorry I missed your earlier question to me. The ID.4 has proved to be pretty efficient for the size of vehicle and I haven't had any real charging problems, between L1 at home and work, DCFC on road trips, etc. I have gotten used to some of the horrible ergonomic decisions but still wouldn't say I like them (only two window switches, capacitive touch everything). The electronics have been intermittently glitchy including the infotainment screen failing to acknowledge finger presses today while driving home for lunch. I held down the screen's bottom left power "button" til it reset and then it worked fine. I would not recommend this car for any non-geeks.
massimo23
Ireland
C?ID=364379
Hey Andy , talking about glitches? the Golf 8 is King in that department…
I am in a Golf 8 Group with over 600 owners and everyday i hear of errors appearing on the infotainment and Dashboard displays, displays going black or touch screen not working, driving profile button not working, aircon not working, last settings disappearing, cant register weconnect, cant connect to the car, parking sensors errors, side assist errors, travel assist errors, RVC video jittering or too dark, 48v battery going dead, wireless Apple connection not connecting or connecting and disconnecting and loads of software bugs. My car has some infotainment bugs and RVC video jittering. Replaced the camera 3 times, checked cables, swapped the infotainment system and the center display. Still not fixed. Big software update coming soon that should do miracles😜
@downtime: Nice car!! - do you have a GEKO account for SFD and how have you dealt with start-stop (if at all)?
downtime
Finland
C?ID=280813
@DV52, Yes I have GEKO account but no SFD. In a full electric car, there's no start-stop :)
And @Andy I fully agree with you. This car is really not for non-geeks.
I've not had any bigger issues. Some software glitches but I can live with those and most likely some of them are fixed in the coming updates anyway. The biggest issue for me is the not functioning scheduled charging. I would really need that when charging at home to time the charge to cheapest hour in electricity prices.
Also I really really dislike the weconnect ID app. It's an app of lost possibillities. It is really stripped down version of the normal weconnect app. And after I'm spoiled with Volvo On Call, this is just pathetic piece of software compared to that.
I've also used mainly home charging. I have 1-phase 3.7kW wallbox charger and it's been more than enough for me. No need for 11kW. On trips I've used 50kW fast chargers and 350kW HPC's.
Done a few longer road trips and I have to say that an electric car with this size battery, zero issues with range. There's enough chargers so that you can quite freely decide coffee or food breaks and charge at the same time. Trip time has not been any longer than with petrol / diesel car earlier.
But even with the software bugs, glitches and some idiotic design flaws, I still love this car. Not as racy as Tesla and not even quite as efficient BUT it's powerful enough, it does not have the same stupid quality issues as with Tesla and the equipment is posh for the price range. And it's a VW. So there's no problems with maintenance or dealer network like with Tesla in Finland. Only two authorized workshops which both are in southern part. That means a 1000km maintenance trip.
Andy
Sector 7G
HC424490
@massimo23 Ooh, the same cursed infotainment as the ID.4!
@downtime Do you know the expression "The grass is always greener on the other side of the fence"? You should see the app we get in the US, called Car-Net. If you have an ICE car, it lets you see the lock status, remotely lock and unlock, etc. In the ID.4 the only functions it gives you are Battery Level (including the ability to start and stop charging), remote climate, and find a charging station. That's it.
Depends on one's trip habits, I guess. I regularly do 1000 km trips in under 9 hours door-to-door. Time spent stopped along the way is probably no more than 20 minutes (just a couple of quick bathroom breaks and possibly one re-fueling). That would not be possible in an EV at present.
massimo23
Ireland
C?ID=364379
With the Golf 8 eHybrid I use both the WeConnect and WeConnect ID apps. Is it not the same with the ID3/4?
downtime
Finland
C?ID=280813
WeConnect does not work for ID cars at all. I initially installed that and it just stated that this is not for you, you need ID app :)
